This fixes the following error during boot:
[ 1.588204] fsl_lpspi 5a020000.lpspi: chipselect 0 already in use
[ 1.594461] spi_master spi0: spi_device register error
/lpspi@5a020000/spidev@0
[ 1.601850] spi_master spi0: Failed to create SPI device for
This fixes the following systemd error during boot:
[ 4.225226] systemd[1]: File /lib/systemd/system/systemd-journald.
service:36 configures an IP firewall (IPAddressDeny=any), but the local
system does not support BPF/cgroup based firewalling.
[ 4.242360] systemd[1]: Proceeding WITHOUT firewalling in effect!
(This warning is only shown for the first loaded unit using IP
firewalling.)
scl-gpios should be (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN) since
commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery GPIO")
Fix on-boot warning:
"enforced open drain please flag it properly in DT/ACPI DSDT/board file"
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Disable CAAM SM Test which is a Keystore Test/Example meant for
development. This gets rid of lots of messages in the kernel log.
Enable deprecated/obsolete ARMv8 instructions emulation. This allows
to run ARMv6 binaries (e.g. Raspberry Pi) on ARMv8 machines.
Also delete the no longer needed hardcoded timings.
- Remove Lontium V1.0 board settings
- Disable RGB display
- Add eval.dtsi
And remove unnecessary enabled hardware
This commit only creates fsl-imx8qxp-colibri-eval-v3.dtsi and moves
code.
It does not change code.
This commit hooks the panel directly onto adma_lcdif and leaves out
lcd_display as it is not compatible with mxsfb-drm.
Move display and camera related enables out of SoM level into carrier
board level.
Those settings belong to carrier board as only the carrier board knows
wich connectors it has and therefore what it needs enabled.
This commit adds proper sleep state muxing, needed for carrier boards
that have a vmmc switch in there so we can prevent backfeeding.
Disabling write protection as this pin is not routed.
Remove ext_io from pinmuxing of the extcon_usbc_det. It is not used
and actually misleading.
And give the SoM level its naming.
This patch also puts some comments.
The setup LCDIF -> LCD Panel supports both LCD panels on parallel
display connectors and VGA monitor. Use this setup by default.
Keep ability to switch to dumb-vga-dac driver.
There is not needed to use imx-parallel-display to connect
simple LCD panel to LCDIF output interface.
Remove imx-parallel-display, so panel starts working well.
Fix commit '46a30aca7f5c MLK-20052 L2 Cache TEE/Linux shared mutex' when
CONFIG_OPTEE is not defined. Compiler warning:
| arch/arm/mm/cache-l2x0.c:151:12: warning: ‘l2c_set_mutex’ defined but not used [-Wunused-function]
fns.set_mutex and l2c_set_mutex() are guarded by CONFIG_OPTEE.
On top of that the function pointer is tested for NULL before calling.
Usdhc1 had wrong stuff in it due to the merge request. Fix that
In order for the otg ports, that these modules support, it is needed
that dr_mode is on otg. Switch to use that feature.
By default, Colibri iMX8QXP uses 18-bit output bus of eLCDIF. Set bus width
correctly fixes framebuffer translation issue.
gpio_bl_on is used as output to enable linked consumers of eLCDIF: panel or
bridge. Fix pinmux mode for this pin.
Support DAC VGA converter and parallel display interface as output
ports of LCDIF block.
Add VDD regulator for VGA encoder ADV7125.
This driver serves ADV7125 VGA DAC Coverter on Colibri Evaluation board.
Fix working of eLCDIF block.
This commit makes eLCDIF clocks to be set and work properly.
Probably need to reinvestigate to find the root cause.
Related to: #42565
Related to: #32172
If using DMA mode the chip select gets deasserted and asserted again
with each word in a transmission. PIO mode on the other hand asserts
at the beginning of a transmission and de-asserts at the end which for
most use-cases is prefered.
Related to: #51387
Follow commit 'a1204e3b0e7a dts: lpspi: add dma mode support' for lpspi2.
This requires a follow up to dtbs which delete the edma0 node in favour
of their own implementation.
Related to: #51387
(cherry picked from commit 1ff8709cc875557d3ba3c105af3be6bd6033c122)
Fixed power-domain stuff after imx_4.14.98_2.3.0 resp. 4.14-2.3.x-imx
merge.
Remove firmware kobject uevent fallback mechanism and make imx_sdma
a module so it gets loaded when rootfs is mounted.
This prevents the error, that firmware can't be loaded from rootfs
There where some defconfigs missed in the commit with the same name
before, correct that.
