commit 4cb7df64c732b2b9918424095c11660c2a8c4a33 upstream.
The audio_mclk_root_clk was added as a gate with the CCGR121 (0x4790),
but according to the reference manual, there is no such gate. Moreover,
the consumer driver of the mentioned clock might gate it and leave
the ECSPI2 (the true owner of that gate) hanging. So lets use the
audio_mclk_post_div, which is the parent.
Signed-off-by: Abel Vesa <abel.vesa@nxp.com>
[ps: backport to 5.4]
This is the 5.4.193 stable release
[ Upstream commit 1714a4eb6fb0cb79f182873cd011a8ed60ac65e8 ]
As commit 0c5f81dad46 ("KVM: LAPIC: Inject timer interrupt via posted
interrupt") mentioned that the host admin should well tune the guest
setup, so that vCPUs are placed on isolated pCPUs, and with several pCPUs
surplus for *busy* housekeeping. In this setup, it is preferrable to
disable mwait/hlt/pause vmexits to keep the vCPUs in non-root mode.
However, if only some guests isolated and others not, they would not
have any benefit from posted timer interrupts, and at the same time lose
VMX preemption timer fast paths because kvm_can_post_timer_interrupt()
returns true and therefore forces kvm_can_use_hv_timer() to false.
By guaranteeing that posted-interrupt timer is only used if MWAIT or
HLT are done without vmexit, KVM can make a better choice and use the
VMX preemption timer and the corresponding fast paths.
Reported-by: Aili Yao <yaoaili@kingsoft.com>
Reviewed-by: Sean Christopherson <seanjc@google.com>
Cc: Aili Yao <yaoaili@kingsoft.com>
Cc: Sean Christopherson <seanjc@google.com>
Signed-off-by: Wanpeng Li <wanpengli@tencent.com>
Message-Id: <1643112538-36743-1-git-send-email-wanpengli@tencent.com>
[ Upstream commit 0361bdfddca20c8855ea3bdbbbc9c999912b10ff ]
MSR_KVM_POLL_CONTROL is cleared on reset, thus reverting guests to
host-side polling after suspend/resume. Non-bootstrap CPUs are
restored correctly by the haltpoll driver because they are hot-unplugged
during suspend and hot-plugged during resume; however, the BSP
is not hotpluggable and remains in host-sde polling mode after
the guest resume. The makes the guest pay for the cost of vmexits
every time the guest enters idle.
Fix it by recording BSP's haltpoll state and resuming it during guest
resume.
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Message-Id: <1650267752-46796-1-git-send-email-wanpengli@tencent.com>
[ Upstream commit 5a1bde46f98b893cda6122b00e94c0c40a6ead3c ]
On some x86 processors, CPUID leaf 0xA provides information
on Architectural Performance Monitoring features. It
advertises a PMU version which Qemu uses to determine the
availability of additional MSRs to manage the PMCs.
Upon receiving a KVM_GET_SUPPORTED_CPUID ioctl request for
the same, the kernel constructs return values based on the
x86_pmu_capability irrespective of the vendor.
This leaf and the additional MSRs are not supported on AMD
and Hygon processors. If AMD PerfMonV2 is detected, the PMU
version is set to 2 and guest startup breaks because of an
attempt to access a non-existent MSR. Return zeros to avoid
this.
Fixes: a6c06ed1a60a ("KVM: Expose the architectural performance monitoring CPUID leaf")
Reported-by: Vasant Hegde <vasant.hegde@amd.com>
Signed-off-by: Sandipan Das <sandipan.das@amd.com>
Message-Id: <3fef83d9c2b2f7516e8ff50d60851f29a4bcb716.1651058600.git.sandipan.das@amd.com>
commit 5b89966bc96a06f6ad65f64ae4b0461918fcc9d3 upstream.
The Linux tool "lscpu" shows the double amount of CPUs if we have
"model" and "model name" in two different lines in /proc/cpuinfo.
This change combines the model and the model name into one line.
Signed-off-by: Helge Deller <deller@gmx.de>
Cc: stable@vger.kernel.org
commit f0a6c68f69981214cb7858738dd2bc81475111f7 upstream.
Fix the discrepancy between the two places we check for the CP0 counter
erratum in along with the incorrect comparison of the R4400 revision
number against 0x30 which matches none and consistently consider all
R4000 and R4400 processors affected, as documented in processor errata
publications[1][2][3], following the mapping between CP0 PRId register
values and processor models:
PRId | Processor Model
00000422 | R4000 Revision 2.2
00000430 | R4000 Revision 3.0
00000440 | R4400 Revision 1.0
00000450 | R4400 Revision 2.0
00000460 | R4400 Revision 3.0
No other revision of either processor has ever been spotted.
Contrary to what has been stated in commit ce202cbb9e0b ("[MIPS] Assume
R4000/R4400 newer than 3.0 don't have the mfc0 count bug") marking the
CP0 counter as buggy does not preclude it from being used as either a
clock event or a clock source device. It just cannot be used as both at
a time, because in that case clock event interrupts will be occasionally
lost, and the use as a clock event device takes precedence.
Compare against 0x4ff in `can_use_mips_counter' so that a single machine
instruction is produced.
References:
[1] "MIPS R4000PC/SC Errata, Processor Revision 2.2 and 3.0", MIPS
Technologies Inc., May 10, 1994, Erratum 53, p.13
[2] "MIPS R4400PC/SC Errata, Processor Revision 1.0", MIPS Technologies
Inc., February 9, 1994, Erratum 21, p.4
[3] "MIPS R4400PC/SC Errata, Processor Revision 2.0 & 3.0", MIPS
Technologies Inc., January 24, 1995, Erratum 14, p.3
Signed-off-by: Maciej W. Rozycki <macro@orcam.me.uk>
Fixes: ce202cbb9e0b ("[MIPS] Assume R4000/R4400 newer than 3.0 don't have the mfc0 count bug")
Cc: stable@vger.kernel.org # v2.6.24+
Reviewed-by: Philippe Mathieu-Daudé <f4bug@amsat.org>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit f9e14dbbd454581061c736bf70bf5cbb15ac927c upstream.
When resuming from system sleep state, restore_processor_state()
restores the boot CPU MSRs. These MSRs could be emulated by microcode.
If microcode is not loaded yet, writing to emulated MSRs leads to
unchecked MSR access error:
PM: Calling lapic_suspend+0x0/0x210
unchecked MSR access error: WRMSR to 0x10f (tried to write 0x0...0) at rIP: ... (native_write_msr)
Call Trace:
<TASK>
? restore_processor_state
x86_acpi_suspend_lowlevel
acpi_suspend_enter
suspend_devices_and_enter
pm_suspend.cold
state_store
kobj_attr_store
sysfs_kf_write
kernfs_fop_write_iter
new_sync_write
vfs_write
ksys_write
__x64_sys_write
do_syscall_64
entry_SYSCALL_64_after_hwframe
RIP: 0033:0x7fda13c260a7
To ensure microcode emulated MSRs are available for restoration, load
the microcode on the boot CPU before restoring these MSRs.
[ Pawan: write commit message and productize it. ]
Fixes: e2a1256b17b1 ("x86/speculation: Restore speculation related MSRs during S3 resume")
Reported-by: Kyle D. Pelton <kyle.d.pelton@intel.com>
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Tested-by: Kyle D. Pelton <kyle.d.pelton@intel.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=215841
Link: https://lore.kernel.org/r/4350dfbf785cd482d3fafa72b2b49c83102df3ce.1650386317.git.pawan.kumar.gupta@linux.intel.com
[ Upstream commit a6823e4e360fe975bd3da4ab156df7c74c8b07f3 ]
The first "if" condition in __memcpy_flushcache is supposed to align the
"dest" variable to 8 bytes and copy data up to this alignment. However,
this condition may misbehave if "size" is greater than 4GiB.
The statement min_t(unsigned, size, ALIGN(dest, 8) - dest); casts both
arguments to unsigned int and selects the smaller one. However, the
cast truncates high bits in "size" and it results in misbehavior.
For example:
suppose that size == 0x100000001, dest == 0x200000002
min_t(unsigned, size, ALIGN(dest, 8) - dest) == min_t(0x1, 0xe) == 0x1;
dest += 0x1;
so we copy just one byte "and" dest remains unaligned.
This patch fixes the bug by replacing unsigned with size_t.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
[ Upstream commit 0310b5aa0656a94102344f1e9ae2892e342a665d ]
The ROHM BD71847 PMIC has a 32.768 kHz clock.
Describe the PMIC clock to fix the following boot errors:
bd718xx-clk bd71847-clk.1.auto: No parent clk found
bd718xx-clk: probe of bd71847-clk.1.auto failed with error -22
Based on the same fix done for imx8mm-evk as per commit
a6a355ede574 ("arm64: dts: imx8mm-evk: Add 32.768 kHz clock to PMIC")
Fixes: 3e44dd09736d ("arm64: dts: imx8mn-ddr4-evk: Add rohm,bd71847 PMIC support")
Signed-off-by: Fabio Estevam <festevam@denx.de>
[ Upstream commit 45974e4276a8d6653394f66666fc57d8ffa6de9a ]
The correct spelling for the property is gpios. Otherwise, the regulator
will neither reserve nor control any GPIOs. Thus, any SD/MMC card which
can use UHS-I modes will fail.
Fixes: c2e4987e0e02 ("ARM: dts: imx6ull: add Toradex Colibri iMX6ULL support")
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
[ Upstream commit 46ff3df87215ff42c0cd2c4bdb7d74540384a69c ]
The pinout of the OMAP35 and DM37 variants of the SOM-LV are the
same, but the macros which define the pinmuxing are different
between OMAP3530 and DM3730. The pinmuxing was correct for
for the DM3730, but wrong for the OMAP3530. Since the boot loader
was correctly pin-muxing the pins, this was not obvious. As the
bootloader not guaranteed to pinmux all the pins any more, this
causes an issue, so the pinmux needs to be moved from a common
file to their respective board files.
Fixes: f8a2e3ff7103 ("ARM: dts: Add minimal support for LogicPD OMAP35xx SOM-LV devkit")
Message-Id: <20220303171818.11060-1-aford173@gmail.com>
[ Upstream commit 942da3af32b2288e674736eb159d1fc676261691 ]
The bootloader for the AM3517 has previously done much of the pin
muxing, but as the bootloader is moving more and more to a model
based on the device tree, it may no longer automatically mux the
pins, so it is necessary to add the pinmuxing to the Linux device
trees so the respective peripherals can remain functional.
Fixes: 6ed1d7997561 ("ARM: dts: am3517-evm: Add support for UI board and Audio")
Message-Id: <20220226214820.747847-1-aford173@gmail.com>
[ Upstream commit 09269dd050094593fc747f2a5853d189fefcb6b5 ]
Commit a1ebdb374199 ("ARM: dts: Fix swapped mmc order for omap3")
introduces general mmc aliases. Let's tailor them to the need
of the GTA04 board which does not make use of mmc2 and mmc3 interfaces.
Fixes: a1ebdb374199 ("ARM: dts: Fix swapped mmc order for omap3")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Message-Id: <dc9173ee3d391d9e92b7ab8ed4f84b29f0a21c83.1646744420.git.hns@goldelico.com>
[ Upstream commit 0e486fe341fabd8e583f3d601a874cd394979c45 ]
The MCLK of the WM8731 on the AT91SAM9G20-EK board is connected to the
PCK0 output of the SoC and is expected to be set to 12MHz. Previously
this was mapped using pre-common clock API calls in the audio machine
driver but the conversion to the common clock framework broke that so
describe things in the DT instead.
Fixes: ff78a189b0ae55f ("ARM: at91: remove old at91-specific clock driver")
Signed-off-by: Mark Brown <broonie@kernel.org>
Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Link: https://lore.kernel.org/r/20220404102806.581374-2-broonie@kernel.org
[ Upstream commit 0f83e6b4161617014017a694888dd8743f46f071 ]
The of_find_compatible_node() function returns a node pointer with
refcount incremented, We should use of_node_put() on it when done
Add the missing of_node_put() to release the refcount.
Fixes: fd1c07861491 ("ARM: OMAP4: Fix the init code to have OMAP4460 errata available in DT build")
Signed-off-by: Miaoqian Lin <linmq006@gmail.com>
Message-Id: <20220309104302.18398-1-linmq006@gmail.com>
[ Upstream commit fa51e1dc4b91375bc18349663a52395ad585bd3c ]
On a custom carrier board with a i.MX6Q Apalis SoM, the sgtl5000 codec
on the SoM is often not detected and the following error message is
seen when the sgtl5000 driver tries to read the ID register:
sgtl5000 1-000a: Error reading chip id -6
The reason for the error is that the MCLK clock is not provided
early enough.
Fix the problem by describing the MCLK pinctrl inside the codec
node instead of placing it inside the audmux pinctrl group.
With this change applied the sgtl5000 is always detected on every boot.
Fixes: 693e3ffaae5a ("ARM: dts: imx6: Add support for Toradex Apalis iMX6Q/D SoM")
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Tim Harvey <tharvey@gateworks.com>
[ Upstream commit fd86d85401c2049f652293877c0f7e6e5afc3bbc ]
Amlogic SM1 devices experience CPU stalls and random board wedges when
the system idles and CPU cores clock down to lower opp points. Recent
vendor kernels include a change to remove 100-250MHz and other distro
sources also remove the 500/667MHz points. Unless all 100-667Mhz opps
are removed or the CPU governor forced to performance stalls are still
observed, so let's remove them to improve stability and uptime.
Fixes: 3d9e76483049 ("arm64: dts: meson-sm1-sei610: enable DVFS")
Signed-off-by: Christian Hewitt <christianshewitt@gmail.com>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Link: https://lore.kernel.org/r/20220210100638.19130-3-christianshewitt@gmail.com
[ Upstream commit 6c4d636bc00dc17c63ffb2a73a0da850240e26e3 ]
Amlogic G12B devices experience CPU stalls and random board wedges when
Fixes: b96d4e92709b ("arm64: dts: meson-g12b: support a311d and s922x cpu operating points")
Link: https://lore.kernel.org/r/20220210100638.19130-2-christianshewitt@gmail.com
commit b1c6ecfdd06907554518ec384ce8e99889d15193 upstream.
Function syscall_trace_exit expects pointer to pt_regs. However
r0 is also used to keep syscall return value. Restore pointer
to pt_regs before calling syscall_trace_exit.
Cc: <stable@vger.kernel.org>
Signed-off-by: Sergey Matyukevich <sergey.matyukevich@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@kernel.org>
commit 839769c35477d4acc2369e45000ca7b0b6af39a7 upstream.
Fast coprocessor exception handler saves a3..a6, but coprocessor context
load/store code uses a4..a7 as temporaries, potentially clobbering a7.
'Potentially' because coprocessor state load/store macros may not use
all four temporary registers (and neither FPU nor HiFi macros do).
Use a3..a6 as intended.
Fixes: c658eac628aa ("[XTENSA] Add support for configurable registers and coprocessors")
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit ee69d4be8fd064cd08270b4808d2dfece3614ee0 upstream.
These patch_text implementations are using stop_machine_cpuslocked
infrastructure with atomic cpu_count. The original idea: When the
master CPU patch_text, the others should wait for it. But current
implementation is using the first CPU as master, which couldn't
guarantee the remaining CPUs are waiting. This patch changes the
last CPU as the master to solve the potential risk.
Fixes: 64711f9a47d4 ("xtensa: implement jump_label support")
Signed-off-by: Guo Ren <guoren@linux.alibaba.com>
Signed-off-by: Guo Ren <guoren@kernel.org>
Reviewed-by: Max Filippov <jcmvbkbc@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Message-Id: <20220407073323.743224-4-guoren@kernel.org>
[ Upstream commit 0dcad700bb2776e3886fe0a645a4bf13b1e747cd ]
When scheduling a group of events, there are constraint checks done to
make sure all events can go in a group. Example, one of the criteria is
that events in a group cannot use the same PMC. But platform specific
PMU supports alternative event for some of the event codes. During
perf_event_open(), if any event group doesn't match constraint check
criteria, further lookup is done to find alternative event.
By current design, the array of alternatives events in PMU code is
expected to be sorted by column 0. This is because in
find_alternative() the return criteria is based on event code
comparison. ie. "event < ev_alt[i][0])". This optimisation is there
since find_alternative() can be called multiple times. In power9 PMU
code, the alternative event array is not sorted properly and hence there
is breakage in finding alternative events.
To work with existing logic, fix the alternative event array to be
sorted by column 0 for power9-pmu.c
Results:
With alternative events, multiplexing can be avoided. That is, for
example, in power9 PM_LD_MISS_L1 (0x3e054) has alternative event,
PM_LD_MISS_L1_ALT (0x400f0). This is an identical event which can be
programmed in a different PMC.
Before:
# perf stat -e r3e054,r300fc
Performance counter stats for 'system wide':
1057860 r3e054 (50.21%)
379 r300fc (49.79%)
0.944329741 seconds time elapsed
Since both the events are using PMC3 in this case, they are
multiplexed here.
After:
1006948 r3e054
182 r300fc
Fixes: 91e0bd1e6251 ("powerpc/perf: Add PM_LD_MISS_L1 and PM_BR_2PATH to power9 event list")
Signed-off-by: Athira Rajeev <atrajeev@linux.vnet.ibm.com>
Reviewed-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
Link: https://lore.kernel.org/r/20220419114828.89843-1-atrajeev@linux.vnet.ibm.com
[ Upstream commit 26a62b750a4e6364b0393562f66759b1494c3a01 ]
The LoPAPR spec defines a guest visible IOMMU with a variable page size.
Currently QEMU advertises 4K, 64K, 2M, 16MB pages, a Linux VM picks
the biggest (16MB). In the case of a passed though PCI device, there is
a hardware IOMMU which does not support all pages sizes from the above -
P8 cannot do 2MB and P9 cannot do 16MB. So for each emulated
16M IOMMU page we may create several smaller mappings ("TCEs") in
the hardware IOMMU.
The code wrongly uses the emulated TCE index instead of hardware TCE
index in error handling. The problem is easier to see on POWER8 with
multi-level TCE tables (when only the first level is preallocated)
as hash mode uses real mode TCE hypercalls handlers.
The kernel starts using indirect tables when VMs get bigger than 128GB
(depends on the max page order).
The very first real mode hcall is going to fail with H_TOO_HARD as
in the real mode we cannot allocate memory for TCEs (we can in the virtual
mode) but on the way out the code attempts to clear hardware TCEs using
emulated TCE indexes which corrupts random kernel memory because
it_offset==1<<59 is subtracted from those indexes and the resulting index
is out of the TCE table bounds.
This fixes kvmppc_clear_tce() to use the correct TCE indexes.
While at it, this fixes TCE cache invalidation which uses emulated TCE
indexes instead of the hardware ones. This went unnoticed as 64bit DMA
is used these days and VMs map all RAM in one go and only then do DMA
and this is when the TCE cache gets populated.
Potentially this could slow down mapping, however normally 16MB
emulated pages are backed by 64K hardware pages so it is one write to
the "TCE Kill" per 256 updates which is not that bad considering the size
of the cache (1024 TCEs or so).
Fixes: ca1fc489cfa0 ("KVM: PPC: Book3S: Allow backing bigger guest IOMMU pages with smaller physical pages")
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Tested-by: David Gibson <david@gibson.dropbear.id.au>
Reviewed-by: Frederic Barrat <fbarrat@linux.ibm.com>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Link: https://lore.kernel.org/r/20220420050840.328223-1-aik@ozlabs.ru
[ Upstream commit 932aba1e169090357a77af18850a10c256b50819 ]
struct stat (defined in arch/x86/include/uapi/asm/stat.h) has 32-bit
st_dev and st_rdev; struct compat_stat (defined in
arch/x86/include/asm/compat.h) has 16-bit st_dev and st_rdev followed by
a 16-bit padding.
This patch fixes struct compat_stat to match struct stat.
[ Historical note: the old x86 'struct stat' did have that 16-bit field
that the compat layer had kept around, but it was changes back in 2003
by "struct stat - support larger dev_t":
https://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git/commit/?id=e95b2065677fe32512a597a79db94b77b90c968d
and back in those days, the x86_64 port was still new, and separate
from the i386 code, and had already picked up the old version with a
16-bit st_dev field ]
Note that we can't change compat_dev_t because it is used by
compat_loop_info.
Also, if the st_dev and st_rdev values are 32-bit, we don't have to use
old_valid_dev to test if the value fits into them. This fixes
-EOVERFLOW on filesystems that are on NVMe because NVMe uses the major
number 259.
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: Matthew Wilcox <willy@infradead.org>
[ Upstream commit b3f1dd52c991d79118f35e6d1bf4d7cb09882e38 ]
When building multi_v7_defconfig+CONFIG_SMP=n, -Warray-bounds exposes
a couple negative array index accesses:
arch/arm/mach-vexpress/spc.c: In function 've_spc_clk_init':
arch/arm/mach-vexpress/spc.c:583:21: warning: array subscript -1 is below array bounds of 'bool[2]' {aka '_Bool[2]'} [-Warray-bounds]
583 | if (init_opp_table[cluster])
arch/arm/mach-vexpress/spc.c:556:7: note: while referencing 'init_opp_table'
556 | bool init_opp_table[MAX_CLUSTERS] = { false };
arch/arm/mach-vexpress/spc.c:592:18: warning: array subscript -1 is below array bounds of 'bool[2]' {aka '_Bool[2]'} [-Warray-bounds]
592 | init_opp_table[cluster] = true;
Skip this logic when built !SMP.
Link: https://lore.kernel.org/r/20220331190443.851661-1-keescook@chromium.org
Cc: Liviu Dudau <liviu.dudau@arm.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
Acked-by: Liviu Dudau <liviu.dudau@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
commit 83a1cde5c74bfb44b49cb2a940d044bb2380f4ea upstream.
With newer versions of GCC, there is a panic in da850_evm_config_emac()
when booting multi_v5_defconfig in QEMU under the palmetto-bmc machine:
Unable to handle kernel NULL pointer dereference at virtual address 00000020
pgd = (ptrval)
[00000020] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 5.15.0 #1
Hardware name: Generic DT based system
PC is at da850_evm_config_emac+0x1c/0x120
LR is at do_one_initcall+0x50/0x1e0
The emac_pdata pointer in soc_info is NULL because davinci_soc_info only
gets populated on davinci machines but da850_evm_config_emac() is called
on all machines via device_initcall().
Move the rmii_en assignment below the machine check so that it is only
dereferenced when running on a supported SoC.
Fixes: bae105879f2f ("davinci: DA850/OMAP-L138 EVM: implement autodetect of RMII PHY")
Signed-off-by: Nathan Chancellor <nathan@kernel.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Reviewed-by: Bartosz Golaszewski <brgl@bgdev.pl>
Link: https://lore.kernel.org/r/YcS4xVWs6bQlQSPC@archlinux-ax161/
[ Upstream commit ffa0b64e3be58519ae472ea29a1a1ad681e32f48 ]
mpe: On 64-bit Book3E vmalloc space starts at 0x8000000000000000.
Because of the way __pa() works we have:
__pa(0x8000000000000000) == 0, and therefore
virt_to_pfn(0x8000000000000000) == 0, and therefore
virt_addr_valid(0x8000000000000000) == true
Which is wrong, virt_addr_valid() should be false for vmalloc space.
In fact all vmalloc addresses that alias with a valid PFN will return
true from virt_addr_valid(). That can cause bugs with hardened usercopy
as described below by Kefeng Wang:
When running ethtool eth0 on 64-bit Book3E, a BUG occurred:
usercopy: Kernel memory exposure attempt detected from SLUB object not in SLUB page?! (offset 0, size 1048)!
kernel BUG at mm/usercopy.c:99
usercopy_abort+0x64/0xa0 (unreliable)
__check_heap_object+0x168/0x190
__check_object_size+0x1a0/0x200
dev_ethtool+0x2494/0x2b20
dev_ioctl+0x5d0/0x770
sock_do_ioctl+0xf0/0x1d0
sock_ioctl+0x3ec/0x5a0
__se_sys_ioctl+0xf0/0x160
system_call_exception+0xfc/0x1f0
system_call_common+0xf8/0x200
The code shows below,
data = vzalloc(array_size(gstrings.len, ETH_GSTRING_LEN));
copy_to_user(useraddr, data, gstrings.len * ETH_GSTRING_LEN))
The data is alloced by vmalloc(), virt_addr_valid(ptr) will return true
on 64-bit Book3E, which leads to the panic.
As commit 4dd7554a6456 ("powerpc/64: Add VIRTUAL_BUG_ON checks for __va
and __pa addresses") does, make sure the virt addr above PAGE_OFFSET in
the virt_addr_valid() for 64-bit, also add upper limit check to make
sure the virt is below high_memory.
Meanwhile, for 32-bit PAGE_OFFSET is the virtual address of the start
of lowmem, high_memory is the upper low virtual address, the check is
suitable for 32-bit, this will fix the issue mentioned in commit
602946ec2f90 ("powerpc: Set max_mapnr correctly") too.
On 32-bit there is a similar problem with high memory, that was fixed in
commit 602946ec2f90 ("powerpc: Set max_mapnr correctly"), but that
commit breaks highmem and needs to be reverted.
We can't easily fix __pa(), we have code that relies on its current
behaviour. So for now add extra checks to virt_addr_valid().
For 64-bit Book3S the extra checks are not necessary, the combination of
virt_to_pfn() and pfn_valid() should yield the correct result, but they
are harmless.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Reviewed-by: Christophe Leroy <christophe.leroy@csgroup.eu>
[mpe: Add additional change log detail]
Link: https://lore.kernel.org/r/20220406145802.538416-1-mpe@ellerman.id.au
[ Upstream commit a2c0b0fbe01419f8f5d1c0b9c581631f34ffce8b ]
The alternatives code must be `noinstr` such that it does not patch itself,
as the cache invalidation is only performed after all the alternatives have
been applied.
Mark patch_alternative() as `noinstr`. Mark branch_insn_requires_update()
and get_alt_insn() with `__always_inline` since they are both only called
through patch_alternative().
Booting a kernel in QEMU TCG with KCSAN=y and ARM64_USE_LSE_ATOMICS=y caused
a boot hang:
[ 0.241121] CPU: All CPU(s) started at EL2
The alternatives code was patching the atomics in __tsan_read4() from LL/SC
atomics to LSE atomics.
The following fragment is using LL/SC atomics in the .text section:
| <__tsan_unaligned_read4+304>: ldxr x6, [x2]
| <__tsan_unaligned_read4+308>: add x6, x6, x5
| <__tsan_unaligned_read4+312>: stxr w7, x6, [x2]
| <__tsan_unaligned_read4+316>: cbnz w7, <__tsan_unaligned_read4+304>
This LL/SC atomic sequence was to be replaced with LSE atomics. However since
the alternatives code was instrumentable, __tsan_read4() was being called after
only the first instruction was replaced, which led to the following code in memory:
| <__tsan_unaligned_read4+304>: ldadd x5, x6, [x2]
This caused an infinite loop as the `stxr` instruction never completed successfully,
so `w7` was always 0.
Signed-off-by: Joey Gouly <joey.gouly@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Will Deacon <will@kernel.org>
Link: https://lore.kernel.org/r/20220405104733.11476-1-joey.gouly@arm.com
Signed-off-by: Will Deacon <will@kernel.org>
commit 01f6c7338ce267959975da65d86ba34f44d54220 upstream.
Currently the first thing checked is whether the PCSI cpu_suspend function
has been initialized.
Another change will be overloading `acpi_processor_ffh_lpi_probe` and
calling it sooner. So make the `has_lpi` check the first thing checked
to prepare for that change.
Reviewed-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Mario Limonciello <mario.limonciello@amd.com>
commit 4013e26670c590944abdab56c4fa797527b74325 upstream.
On ELF, (NOLOAD) sets the section type to SHT_NOBITS[1]. It is conceptually
inappropriate for .plt and .text.* sections which are always
SHT_PROGBITS.
In GNU ld, if PLT entries are needed, .plt will be SHT_PROGBITS anyway
and (NOLOAD) will be essentially ignored. In ld.lld, since
https://reviews.llvm.org/D118840 ("[ELF] Support (TYPE=<value>) to
customize the output section type"), ld.lld will report a `section type
mismatch` error. Just remove (NOLOAD) to fix the error.
[1] https://lld.llvm.org/ELF/linker_script.html As of today, "The
section should be marked as not loadable" on
https://sourceware.org/binutils/docs/ld/Output-Section-Type.html is
outdated for ELF.
Tested-by: Nathan Chancellor <nathan@kernel.org>
Reported-by: Nathan Chancellor <nathan@kernel.org>
Signed-off-by: Fangrui Song <maskray@google.com>
Acked-by: Ard Biesheuvel <ardb@kernel.org>
Link: https://lore.kernel.org/r/20220218081209.354383-1-maskray@google.com
[nathan: Fix conflicts due to lack of 596b0474d3d9]
commit 31a099dbd91e69fcab55eef4be15ed7a8c984918 upstream.
Fixes: ae16480785de ("arm64: introduce interfaces to hotpatch kernel and module code")
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Link: https://lore.kernel.org/r/20220407073323.743224-2-guoren@kernel.org
commit e2a1256b17b16f9b9adf1b6fea56819e7b68e463 upstream.
After resuming from suspend-to-RAM, the MSRs that control CPU's
speculative execution behavior are not being restored on the boot CPU.
These MSRs are used to mitigate speculative execution vulnerabilities.
Not restoring them correctly may leave the CPU vulnerable. Secondary
CPU's MSRs are correctly being restored at S3 resume by
identify_secondary_cpu().
During S3 resume, restore these MSRs for boot CPU when restoring its
processor state.
Fixes: 772439717dbf ("x86/bugs/intel: Set proper CPU features and setup RDS")
Reported-by: Neelima Krishnan <neelima.krishnan@intel.com>
Tested-by: Neelima Krishnan <neelima.krishnan@intel.com>
Acked-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com>
commit 73924ec4d560257004d5b5116b22a3647661e364 upstream.
The mechanism to save/restore MSRs during S3 suspend/resume checks for
the MSR validity during suspend, and only restores the MSR if its a
valid MSR. This is not optimal, as an invalid MSR will unnecessarily
throw an exception for every suspend cycle. The more invalid MSRs,
higher the impact will be.
Check and save the MSR validity at setup. This ensures that only valid
MSRs that are guaranteed to not throw an exception will be attempted
during suspend.
Fixes: 7a9c2dd08ead ("x86/pm: Introduce quirk framework to save/restore extra MSR registers around suspend/resume")
Suggested-by: Dave Hansen <dave.hansen@linux.intel.com>
Will reports that with CONFIG_EXPERT=y and CONFIG_HARDEN_BRANCH_PREDICTOR=n,
the kernel dereferences a NULL pointer during boot:
[ 2.384444] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 2.384461] pstate: 20400085 (nzCv daIf +PAN -UAO)
[ 2.384472] pc : cpu_hyp_reinit+0x114/0x30c
[ 2.384476] lr : cpu_hyp_reinit+0x80/0x30c
[ 2.384529] Call trace:
[ 2.384533] cpu_hyp_reinit+0x114/0x30c
[ 2.384537] _kvm_arch_hardware_enable+0x30/0x54
[ 2.384541] flush_smp_call_function_queue+0xe4/0x154
[ 2.384544] generic_smp_call_function_single_interrupt+0x10/0x18
[ 2.384549] ipi_handler+0x170/0x2b0
[ 2.384555] handle_percpu_devid_fasteoi_ipi+0x120/0x1cc
[ 2.384560] __handle_domain_irq+0x9c/0xf4
[ 2.384563] gic_handle_irq+0x6c/0xe4
[ 2.384566] el1_irq+0xf0/0x1c0
[ 2.384570] arch_cpu_idle+0x28/0x44
[ 2.384574] do_idle+0x100/0x2a8
[ 2.384577] cpu_startup_entry+0x20/0x24
[ 2.384581] secondary_start_kernel+0x1b0/0x1cc
[ 2.384589] Code: b9469d08 7100011f 540003ad 52800208 (f9400108)
[ 2.384600] ---[ end trace 266d08dbf96ff143 ]---
[ 2.385171] Kernel panic - not syncing: Fatal exception in interrupt
In this configuration arm64_get_bp_hardening_data() returns NULL.
Add a check in kvm_get_hyp_vector().
Link: https://lore.kernel.org/linux-arm-kernel/20220408120041.GB27685@willie-the-truck/
Fixes: 26129ea2953b ("KVM: arm64: Add templates for BHB mitigation sequences")
Cc: stable@vger.kernel.org # 5.4.x
Signed-off-by: James Morse <james.morse@arm.com>
[ Upstream commit a9fe7fa7d874a536e0540469f314772c054a0323 ]
This change fixes the following:
1) The flags variable is not initialized. Always use raw_spin_lock_irqsave
and raw_spin_unlock_irqrestore to serialize patching.
2) flush_kernel_vmap_range is primarily intended for DMA flushes. Since
__patch_text_multiple is often called with interrupts disabled, it is
better to directly call flush_kernel_dcache_range_asm and
flush_kernel_icache_range_asm. This avoids an extra call.
3) The final call to flush_icache_range is unnecessary.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
[ Upstream commit eed05744322da07dd7e419432dcedf3c2e017179 ]
The sched_clock() can be used very early since commit 857baa87b642
("sched/clock: Enable sched clock early"). In addition, with commit
38669ba205d1 ("x86/xen/time: Output xen sched_clock time from 0"), kdump
kernel in Xen HVM guest may panic at very early stage when accessing
&__this_cpu_read(xen_vcpu)->time as in below:
setup_arch()
-> init_hypervisor_platform()
-> x86_init.hyper.init_platform = xen_hvm_guest_init()
-> xen_hvm_init_time_ops()
-> xen_clocksource_read()
-> src = &__this_cpu_read(xen_vcpu)->time;
This is because Xen HVM supports at most MAX_VIRT_CPUS=32 'vcpu_info'
embedded inside 'shared_info' during early stage until xen_vcpu_setup() is
used to allocate/relocate 'vcpu_info' for boot cpu at arbitrary address.
However, when Xen HVM guest panic on vcpu >= 32, since
xen_vcpu_info_reset(0) would set per_cpu(xen_vcpu, cpu) = NULL when
vcpu >= 32, xen_clocksource_read() on vcpu >= 32 would panic.
This patch calls xen_hvm_init_time_ops() again later in
xen_hvm_smp_prepare_boot_cpu() after the 'vcpu_info' for boot vcpu is
registered when the boot vcpu is >= 32.
This issue can be reproduced on purpose via below command at the guest
side when kdump/kexec is enabled:
"taskset -c 33 echo c > /proc/sysrq-trigger"
The bugfix for PVM is not implemented due to the lack of testing
environment.
[boris: xen_hvm_init_time_ops() returns on errors instead of jumping to end]
Cc: Joe Jin <joe.jin@oracle.com>
Signed-off-by: Dongli Zhang <dongli.zhang@oracle.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: https://lore.kernel.org/r/20220302164032.14569-3-dongli.zhang@oracle.com
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit e85d29ba4b24f68e7a78cb85c55e754362eeb2de ]
DTC issues the following warnings when building xtfpga device trees:
/soc/flash@00000000/partition@0x0: unit name should not have leading "0x"
/soc/flash@00000000/partition@0x6000000: unit name should not have leading "0x"
/soc/flash@00000000/partition@0x6800000: unit name should not have leading "0x"
/soc/flash@00000000/partition@0x7fe0000: unit name should not have leading "0x"
Drop leading 0x from flash partition unit names.
[ Upstream commit d17b66417308996e7e64b270a3c7f3c1fbd4cfc8 ]
With KCFLAGS="-O3", I was able to trigger a fortify-source
memcpy() overflow panic on set_vi_srs_handler().
Although O3 level is not supported in the mainline, under some
conditions that may've happened with any optimization settings,
it's just a matter of inlining luck. The panic itself is correct,
more precisely, 50/50 false-positive and not at the same time.
From the one side, no real overflow happens. Exception handler
defined in asm just gets copied to some reserved places in the
memory.
But the reason behind is that C code refers to that exception
handler declares it as `char`, i.e. something of 1 byte length.
It's obvious that the asm function itself is way more than 1 byte,
so fortify logics thought we are going to past the symbol declared.
The standard way to refer to asm symbols from C code which is not
supposed to be called from C is to declare them as
`extern const u8[]`. This is fully correct from any point of view,
as any code itself is just a bunch of bytes (including 0 as it is
for syms like _stext/_etext/etc.), and the exact size is not known
at the moment of compilation.
Adjust the type of the except_vec_vi_*() and related variables.
Make set_handler() take `const` as a second argument to avoid
cast-away warnings and give a little more room for optimization.
Signed-off-by: Alexander Lobakin <alobakin@pm.me>
[ Upstream commit 4a0a1436053b17e50b7c88858fb0824326641793 ]
of_node_put(np) needs to be called when pdev == NULL.
Signed-off-by: Hangyu Hua <hbh25y@gmail.com>
[ Upstream commit 7c5ed82b800d8615cdda00729e7b62e5899f0b13 ]
On large config LPARs (having 192 and more cores), Linux fails to boot
due to insufficient memory in the first memblock. It is due to the
memory reservation for the crash kernel which starts at 128MB offset of
the first memblock. This memory reservation for the crash kernel doesn't
leave enough space in the first memblock to accommodate other essential
system resources.
The crash kernel start address was set to 128MB offset by default to
ensure that the crash kernel get some memory below the RMA region which
is used to be of size 256MB. But given that the RMA region size can be
512MB or more, setting the crash kernel offset to mid of RMA size will
leave enough space for the kernel to allocate memory for other system
resources.
Since the above crash kernel offset change is only applicable to the LPAR
platform, the LPAR feature detection is pushed before the crash kernel
reservation. The rest of LPAR specific initialization will still
be done during pseries_probe_fw_features as usual.
This patch is dependent on changes to paca allocation for boot CPU. It
expect boot CPU to discover 1T segment support which is introduced by
the patch posted here:
https://lists.ozlabs.org/pipermail/linuxppc-dev/2022-January/239175.html
Reported-by: Abdul haleem <abdhalee@linux.vnet.ibm.com>
Signed-off-by: Sourabh Jain <sourabhjain@linux.ibm.com>
Link: https://lore.kernel.org/r/20220204085601.107257-1-sourabhjain@linux.ibm.com
[ Upstream commit 17846485dff91acce1ad47b508b633dffc32e838 ]
T1040RDB has two RTL8211E-VB phys which requires setting
of internal delays for correct work.
Changing the phy-connection-type property to `rgmii-id`
will fix this issue.
Signed-off-by: Maxim Kiselev <bigunclemax@gmail.com>
Reviewed-by: Maxim Kochetkov <fido_max@inbox.ru>
Reviewed-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Link: https://lore.kernel.org/r/20211230151123.1258321-1-bigunclemax@gmail.com
[ Upstream commit 9b026073db2f1ad0e4d8b61c83316c8497981037 ]
AMD EPYC CPUs never raise a #GP for a WRMSR to a PerfEvtSeln MSR. Some
reserved bits are cleared, and some are not. Specifically, on
Zen3/Milan, bits 19 and 42 are not cleared.
When emulating such a WRMSR, KVM should not synthesize a #GP,
regardless of which bits are set. However, undocumented bits should
not be passed through to the hardware MSR. So, rather than checking
for reserved bits and synthesizing a #GP, just clear the reserved
bits.
This may seem pedantic, but since KVM currently does not support the
"Host/Guest Only" bits (41:40), it is necessary to clear these bits
rather than synthesizing #GP, because some popular guests (e.g Linux)
will set the "Host Only" bit even on CPUs that don't support
EFER.SVME, and they don't expect a #GP.
For example,
root@Ubuntu1804:~# perf stat -e r26 -a sleep 1
0 r26
1.001070977 seconds time elapsed
Feb 23 03:59:58 Ubuntu1804 kernel: [ 405.379957] unchecked MSR access error: WRMSR to 0xc0010200 (tried to write 0x0000020000130026) at rIP: 0xffffffff9b276a28 (native_write_msr+0x8/0x30)
Feb 23 03:59:58 Ubuntu1804 kernel: [ 405.379958] Call Trace:
Feb 23 03:59:58 Ubuntu1804 kernel: [ 405.379963] amd_pmu_disable_event+0x27/0x90
Fixes: ca724305a2b0 ("KVM: x86/vPMU: Implement AMD vPMU code for KVM")
Reported-by: Lotus Fenn <lotusf@google.com>
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Like Xu <likexu@tencent.com>
Reviewed-by: David Dunn <daviddunn@google.com>
Message-Id: <20220226234131.2167175-1-jmattson@google.com>
[ Upstream commit 8b2360c7157b462c4870d447d1e65d30ef31f9aa ]
__setup() handlers should return 1 to obsolete_checksetup() in
init/main.c to indicate that the boot option has been handled.
A return of 0 causes the boot option/value to be listed as an Unknown
kernel parameter and added to init's (limited) argument or environment
strings. Also, error return codes don't mean anything to
obsolete_checksetup() -- only non-zero (usually 1) or zero.
So return 1 from jive_mtdset().
Fixes: 9db829f485c5 ("[ARM] JIVE: Initial machine support for Logitech Jive")
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Alim Akhtar <alim.akhtar@samsung.com>
Cc: linux-samsung-soc@vger.kernel.org
Cc: patches@armlinux.org.uk
Signed-off-by: Russell King (Oracle) <rmk+kernel@armlinux.org.uk>
[ Upstream commit 60210a3d86dc57ce4a76a366e7841dda746a33f7 ]
inappropriate for .plt, .got, and .got.plt sections which are always
SHT_PROGBITS.
mismatch` error (later changed to a warning). Just remove (NOLOAD) to
fix the warning.
outdated for ELF.
Link: https://github.com/ClangBuiltLinux/linux/issues/1597
Fixes: ab1ef68e5401 ("RISC-V: Add sections of PLT and GOT for kernel module")
Signed-off-by: Palmer Dabbelt <palmer@rivosinc.com>
commit b1e34d325397a33d97d845e312d7cf2a8b646b44 upstream.
Setting non-zero values to SYNIC/STIMER MSRs activates certain features,
this should not happen when KVM_CAP_HYPERV_SYNIC{,2} was not activated.
Note, it would've been better to forbid writing anything to SYNIC/STIMER
MSRs, including zeroes, however, at least QEMU tries clearing
HV_X64_MSR_STIMER0_CONFIG without SynIC. HV_X64_MSR_EOM MSR is somewhat
'special' as writing zero there triggers an action, this also should not
happen when SynIC wasn't activated.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Message-Id: <20220325132140.25650-4-vkuznets@redhat.com>
commit 2a8859f373b0a86f0ece8ec8312607eacf12485d upstream.
FNAME(cmpxchg_gpte) is an inefficient mess. It is at least decent if it
can go through get_user_pages_fast(), but if it cannot then it tries to
use memremap(); that is not just terribly slow, it is also wrong because
it assumes that the VM_PFNMAP VMA is contiguous.
The right way to do it would be to do the same thing as
hva_to_pfn_remapped() does since commit add6a0cd1c5b ("KVM: MMU: try to
fix up page faults before giving up", 2016-07-05), using follow_pte()
and fixup_user_fault() to determine the correct address to use for
memremap(). To do this, one could for example extract hva_to_pfn()
for use outside virt/kvm/kvm_main.c. But really there is no reason to
do that either, because there is already a perfectly valid address to
do the cmpxchg() on, only it is a userspace address. That means doing
user_access_begin()/user_access_end() and writing the code in assembly
to handle exceptions correctly. Worse, the guest PTE can be 8-byte
even on i686 so there is the extra complication of using cmpxchg8b to
account for. But at least it is an efficient mess.
(Thanks to Linus for suggesting improvement on the inline assembly).
Reported-by: Qiuhao Li <qiuhao@sysec.org>
Reported-by: Gaoning Pan <pgn@zju.edu.cn>
Reported-by: Yongkang Jia <kangel@zju.edu.cn>
Reported-by: syzbot+6cde2282daa792c49ab8@syzkaller.appspotmail.com
Debugged-by: Tadeusz Struk <tadeusz.struk@linaro.org>
Tested-by: Maxim Levitsky <mlevitsk@redhat.com>
Fixes: bd53cb35a3e9 ("X86/KVM: Handle PFNs outside of kernel reach when touching GPTEs")
commit 1a3a6a2a035bb6c3a7ef4c788d8fd69a7b2d6284 upstream.
Moving to an EPOLL based IRQ controller broke uml_mconsole stop/go
commands. This fixes it and restores stop/go functionality.
Fixes: ff6a17989c08 ("Epoll based IRQ controller")
Signed-off-by: Anton Ivanov <anton.ivanov@cambridgegreys.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 31d3687d6017c7ce6061695361598d9cda70807a upstream.
Reorder dmas and dma-names property for spi controller node to make it
compliant with bindings.
Fixes: 6e8887f60f60 ("ARM: SPEAr13xx: Pass generic DW DMAC platform data from DT")
Signed-off-by: Kuldeep Singh <singh.kuldeep87k@gmail.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Link: https://lore.kernel.org/r/20220326042313.97862-2-singh.kuldeep87k@gmail.com'
commit 583d6b0062640def86f3265aa1042ecb6672516e upstream.
Reorder dma and dma-names property for serial node to make it compliant
with bindings.
Link: https://lore.kernel.org/r/20220326042313.97862-3-singh.kuldeep87k@gmail.com'
