Configure the pins in external interrupt mode, as done for Snow in
e5e5c6d14e39 ("ARM: dts: Add power and lid GPIO keys pinctrl for
exynos5250-snow").
Reported-by: Kukjin Kim <kgene@kernel.org>
Suggested-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Fixes: 53dd4138bb0a ("ARM: dts: Add exynos5250-spring device tree")
Signed-off-by: Andreas Faerber <afaerber@suse.de>
Reviewed-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
Resolve a merge conflict with mmc refactoring aaa25a5a33cb ("ARM: dts:
unuse the slot-node and deprecate the supports-highspeed for dw-mmc in
exynos") by dropping the slot@0 nodes, moving its bus-width property to
the mmc node and replacing supports-highspeed with cap-{mmc,sd}-highspeed,
matching exynos5250-snow.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: <stable@vger.kernel.org> [3.19+]
Pull more vfs updates from Al Viro:
"Assorted stuff from this cycle. The big ones here are multilayer
overlayfs from Miklos and beginning of sorting ->d_inode accesses out
from David"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits)
autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation
procfs: fix race between symlink removals and traversals
debugfs: leave freeing a symlink body until inode eviction
Documentation/filesystems/Locking: ->get_sb() is long gone
trylock_super(): replacement for grab_super_passive()
fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions
Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions
VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)
SELinux: Use d_is_positive() rather than testing dentry->d_inode
Smack: Use d_is_positive() rather than testing dentry->d_inode
TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR()
Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode
Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb
VFS: Split DCACHE_FILE_TYPE into regular and special types
VFS: Add a fallthrough flag for marking virtual dentries
VFS: Add a whiteout dentry type
VFS: Introduce inode-getting helpers for layered/unioned fs environments
Infiniband: Fix potential NULL d_inode dereference
posix_acl: fix reference leaks in posix_acl_create
autofs4: Wrong format for printing dentry
Pull ARM fix from Russell King:
"Just one fix this time around. __iommu_alloc_buffer() can cause a
BUG() if dma_alloc_coherent() is called with either __GFP_DMA32 or
__GFP_HIGHMEM set. The patch from Alexandre addresses this"
* 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: 8305/1: DMA: Fix kzalloc flags in __iommu_alloc_buffer()
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS:
- a number of fixes that didn't make the 3.19 release.
- a number of cleanups.
- preliminary support for Cavium's Octeon 3 SOCs which feature up to
48 MIPS64 R3 cores with FPU and hardware virtualization.
- support for MIPS R6 processors.
Revision 6 of the MIPS architecture is a major revision of the MIPS
architecture which does away with many of original sins of the
architecture such as branch delay slots. This and other changes in
R6 require major changes throughout the entire MIPS core
architecture code and make up for the lion share of this pull
request.
- finally some preparatory work for eXtendend Physical Address
support, which allows support of up to 40 bit of physical address
space on 32 bit processors"
[ Ahh, MIPS can't leave the PAE brain damage alone. It's like
every CPU architect has to make that mistake, but pee in the snow
by changing the TLA. But whether it's called PAE, LPAE or XPA,
it's horrid crud - Linus ]
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (114 commits)
MIPS: sead3: Corrected get_c0_perfcount_int
MIPS: mm: Remove dead macro definitions
MIPS: OCTEON: irq: add CIB and other fixes
MIPS: OCTEON: Don't do acknowledge operations for level triggered irqs.
MIPS: OCTEON: More OCTEONIII support
MIPS: OCTEON: Remove setting of processor specific CVMCTL icache bits.
MIPS: OCTEON: Core-15169 Workaround and general CVMSEG cleanup.
MIPS: OCTEON: Update octeon-model.h code for new SoCs.
MIPS: OCTEON: Implement DCache errata workaround for all CN6XXX
MIPS: OCTEON: Add little-endian support to asm/octeon/octeon.h
MIPS: OCTEON: Implement the core-16057 workaround
MIPS: OCTEON: Delete unused COP2 saving code
MIPS: OCTEON: Use correct instruction to read 64-bit COP0 register
MIPS: OCTEON: Save and restore CP2 SHA3 state
MIPS: OCTEON: Fix FP context save.
MIPS: OCTEON: Save/Restore wider multiply registers in OCTEON III CPUs
MIPS: boot: Provide more uImage options
MIPS: Remove unneeded #ifdef __KERNEL__ from asm/processor.h
MIPS: ip22-gio: Remove legacy suspend/resume support
mips: pci: Add ifdef around pci_proc_domain
Pull ARM SoC fixes from Arnd Bergmann:
"A few fixes that came in too late to make it into the first set of
pull requests but would still be nice to have in -rc1.
The majority of these are trivial build fixes for bugs that I found
myself using randconfig testing, and a set of two patches from Uwe to
mark DT strings as 'const' where appropriate, to resolve inconsistent
section attributes"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: make of_device_ids const
ARM: make arrays containing machine compatible strings const
ARM: mm: Remove Kconfig symbol CACHE_PL310
ARM: rockchip: force built-in regulator support for PM
ARM: mvebu: build armada375-smp code conditionally
ARM: sti: always enable RESET_CONTROLLER
ARM: rockchip: make rockchip_suspend_init conditional
ARM: ixp4xx: fix {in,out}s{bwl} data types
ARM: prima2: do not select SMP_ON_UP
ARM: at91: fix pm declarations
ARM: davinci: multi-soc kernels require AUTO_ZRELADDR
ARM: davinci: davinci_cfg_reg cannot be init
ARM: BCM: put back ARCH_MULTI_V7 dependency for mobile
ARM: vexpress: use ARM_CPU_SUSPEND if needed
ARM: dts: add I2C device nodes for Broadcom Cygnus
ARM: dts: BCM63xx: fix L2 cache properties
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull more input updates from Dmitry Torokhov:
"The second round of updates for the input subsystem.
Updates to ALPS an bfin_roraty drivers and a couple oother fixups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: psmouse - use IS_ENABLED instead of homegrown code
Input: bfin_rotary - introduce open and close methods
Input: bfin_rotary - convert to use managed resources
Input: bfin_rotary - use generic IO functions
Input: bfin_rotary - move pin lists into into platform data
Input: bfin_rotary - move platform header to linux/platform_data
Input: bfin_rotary - mark suspend and resume code as __maybe_unused
Input: bfin_rotary - fix potential oops in interrupt handler
Input: ALPS - move v7 packet info to Documentation and v6 packet info
Input: ALPS - fix confusing comment in protocol data
Input: ALPS - do not mix trackstick and external PS/2 mouse data
Input: ALPS - fix trackstick detection on some Dell Latitudes
Input: ALPS - consolidate setting protocol parameters
Input: ALPS - split protocol data from model info
Input: ALPS - make Rushmore a separate protocol
Input: ALPS - renumber protocol numbers
Input: adi - remove an unnecessary check
Input: pxa27x_keypad - remove an unneeded NULL check
Input: soc_button_array - use "Windows" key for "Home"
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework updates from Mike Turquette:
"The clock framework changes contain the usual driver additions,
enhancements and fixes mostly for ARM32, ARM64, MIPS and Power-based
devices.
Additionally the framework core underwent a bit of surgery with two
major changes:
- The boundary between the clock core and clock providers (e.g clock
drivers) is now more well defined with dedicated provider helper
functions. struct clk no longer maps 1:1 with the hardware clock
but is a true per-user cookie which helps us tracker users of
hardware clocks and debug bad behavior.
- The addition of rate constraints for clocks. Rate ranges are now
supported which are analogous to the voltage ranges in the
regulator framework.
Unfortunately these changes to the core created some breakeage. We
think we fixed it all up but for this reason there are lots of last
minute commits trying to undo the damage"
* tag 'clk-for-linus-3.20' of git://git.linaro.org/people/mike.turquette/linux: (113 commits)
clk: Only recalculate the rate if needed
Revert "clk: mxs: Fix invalid 32-bit access to frac registers"
clk: qoriq: Add support for the platform PLL
powerpc/corenet: Enable CLK_QORIQ
clk: Replace explicit clk assignment with __clk_hw_set_clk
clk: Add __clk_hw_set_clk helper function
clk: Don't dereference parent clock if is NULL
MIPS: Alchemy: Remove bogus args from alchemy_clk_fgcs_detr
clkdev: Always allocate a struct clk and call __clk_get() w/ CCF
clk: shmobile: div6: Avoid division by zero in .round_rate()
clk: omap: compile legacy omap3 clocks conditionally
clkdev: Export clk_register_clkdev
clk: Add rate constraints to clocks
clk: remove clk-private.h
pci: xgene: do not use clk-private.h
arm: omap2+ remove dead clock code
clk: Make clk API return per-user struct clk instances
clk: tegra: Define PLLD_DSI and remove dsia(b)_mux
clk: tegra: Add support for the Tegra132 CAR IP block
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"Two patches to save some memory if CONFIG_NR_CPUS is large, a changed
default for the use of compare-and-delay, and a couple of bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/spinlock: disabled compare-and-delay by default
s390/mm: align 64-bit PIE binaries to 4GB
s390/cacheinfo: coding style changes
s390/cacheinfo: fix shared cpu masks
s390/smp: reduce size of struct pcpu
s390/topology: convert cpu_topology array to per cpu variable
s390/topology: delay initialization of topology cpu masks
s390/vdso: fix clock_gettime for CLOCK_THREAD_CPUTIME_ID, -2 and -3
Pull Intel Quark SoC support from Ingo Molnar:
"This adds support for Intel Quark X1000 SoC boards, used in the low
power 32-bit x86 Intel Galileo microcontroller board intended for the
Arduino space.
There's been some preparatory core x86 patches for Quark CPU quirks
merged already, but this rounds it all up and adds Kconfig enablement.
It's a clean hardware enablement addition tree at this point"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/intel/quark: Fix simple_return.cocci warnings
x86/intel/quark: Fix ptr_ret.cocci warnings
x86/intel/quark: Add Intel Quark platform support
x86/intel/quark: Add Isolated Memory Regions for Quark X1000
Pull locking fixes from Ingo Molnar:
"Two fixes: the paravirt spin_unlock() corruption/crash fix, and an
rtmutex NULL dereference crash fix"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/spinlocks/paravirt: Fix memory corruption on unlock
locking/rtmutex: Avoid a NULL pointer dereference on deadlock
Pull misc x86 fixes from Ingo Molnar:
"This contains:
- EFI fixes
- a boot printout fix
- ASLR/kASLR fixes
- intel microcode driver fixes
- other misc fixes
Most of the linecount comes from an EFI revert"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm/ASLR: Avoid PAGE_SIZE redefinition for UML subarch
x86/microcode/intel: Handle truncated microcode images more robustly
x86/microcode/intel: Guard against stack overflow in the loader
x86, mm/ASLR: Fix stack randomization on 64-bit systems
x86/mm/init: Fix incorrect page size in init_memory_mapping() printks
x86/mm/ASLR: Propagate base load address calculation
Documentation/x86: Fix path in zero-page.txt
x86/apic: Fix the devicetree build in certain configs
Revert "efi/libstub: Call get_memory_map() to obtain map and desc sizes"
x86/efi: Avoid triple faults during EFI mixed mode calls
Pull x86 uprobe/kprobe fixes from Ingo Molnar:
"This contains two uprobes fixes, an uprobes comment update and a
kprobes fix"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
kprobes/x86: Mark 2 bytes NOP as boostable
uprobes/x86: Fix 2-byte opcode table
uprobes/x86: Fix 1-byte opcode tables
uprobes/x86: Add comment with insn opcodes, mnemonics and why we dont support them
Pull rcu fix and x86 irq fix from Ingo Molnar:
- Fix a bug that caused an RCU warning splat.
- Two x86 irq related fixes: a hotplug crash fix and an ACPI IRQ
registry fix.
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
rcu: Clear need_qs flag to prevent splat
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/irq: Check for valid irq descriptor in check_irq_vectors_for_cpu_disable()
x86/irq: Fix regression caused by commit b568b8601f05
Commit e9de688dac65 ("irqchip: mips-gic: Support local interrupts")
updated several platforms. This is a copy paste error.
Signed-off-by: Niklas Cassel <niklass@axis.com>
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9245/
In commit c441d4a54c6e ("MIPS: mm: Only build one microassembler that
is suitable"), the Makefile at arch/mips/mm was rewritten to only
build the "right" microassembler file, depending on whether
CONFIG_CPU_MICROMIPS is set or not.
In the files, however, there are still preprocessor definitions
depending on CONFIG_CPU_MICROMIPS. The #ifdef around them can now
never evaluate to true, so let's remove them altogether.
This inconsistency was found using the undertaker-checkpatch tool.
Signed-off-by: Andreas Ruprecht <rupran@einserver.de>
Reviewed-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Valentin Rothberg <valentinrothberg@gmail.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Patchwork: https://patchwork.linux-mips.org/patch/9267/
- Use of_irq_init() to initialize interrupt controllers
- Get rid of some unlikely()
- Add CIB to support SATA and other interrupts
- Add support for CIU SUM2 interrupt sources
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Leonid Rosenboim <lrosenboim@caviumnetworks.com>
Signed-off-by: Aleksey Makarov <aleksey.makarov@auriga.com>
Signed-off-by: Peter Swain <peter.swain@cavium.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: devicetree@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/8947/
The acknowledge bits don't exist for level triggered irqs, so setting
them causes the simulator to terminate.
Patchwork: https://patchwork.linux-mips.org/patch/8946/
Read clock rate from the correct CSR. Don't clear COP0_DCACHE for OCTEONIII.
Signed-off-by: Chandrakala Chavva <cchavva@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/8945/
CN38XX pass 1 required icache prefetching to be turned off. This chip never
reached production and is long dead. Other processor specific icache settings
are done by the bootloader. Remove these bits from the kernel.
Signed-off-by: Chad Reese <kreese@caviumnetworks.com>
Cc: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/8944/
Patchwork: https://patchwork.linux-mips.org/patch/8943/
Add coverage for OCTEON III models.
Patchwork: https://patchwork.linux-mips.org/patch/8942/
Make messages refer to all CN6XXX.
Patchwork: https://patchwork.linux-mips.org/patch/8941/
Also update union octeon_cvmemctl with new OCTEON II fields.
[aleksey.makarov@auriga.com: use __BITFIELD_FIELD]
Patchwork: https://patchwork.linux-mips.org/patch/8940/
Disable ICache prefetch for certian Octeon II processors.
Patchwork: https://patchwork.linux-mips.org/patch/8938/
Commit 2c952e06e4f5 ("MIPS: Move cop2 save/restore to switch_to()")
removes assembler code to store COP2 registers. Commit
a36d8225bceb ("MIPS: OCTEON: Enable use of FPU") mistakenly
restores it
Fixes: a36d8225bceb ("MIPS: OCTEON: Enable use of FPU")
Patchwork: https://patchwork.linux-mips.org/patch/8937/
Use dmfc0/dmtc0 instructions for reading CvmMemCtl COP0 register,
its a 64-bit wide.
Patchwork: https://patchwork.linux-mips.org/patch/8936/
Allocate new save space, and then save/restore the registers if
OCTEON III.
Patchwork: https://patchwork.linux-mips.org/patch/8935/
It wasn't being saved on task switch.
Patchwork: https://patchwork.linux-mips.org/patch/8934/
The wide multiplier is twice as wide, so we need to save twice as much
state. Detect the multiplier type (CPU type) at start up and install
model specific handlers.
conflict resolution,
support for old compilers]
Patchwork: https://patchwork.linux-mips.org/patch/8933/
Allow more compression algorithms as well as uncompressed uImage.bin
to be generated. An uncompressed image might be useful to rule out
problems in the decompression code in the bootloader or even speed
up the boot process at the expense of a bigger uImage file.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9271/
Patchwork: https://patchwork.linux-mips.org/patch/8737/
There are currently no gio device drivers that implement suspend/resume
and this patch removes the bus specific legacy suspend and resume callbacks.
This will allow us to eventually remove struct bus_type legacy suspend and
resume support altogether.
gio device drivers wanting to implement suspend and resume can use dev PM
ops which will work out of the box without further modifications necessary.
Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Patchwork: https://patchwork.linux-mips.org/patch/8920/
Without these, there are multiple definitions of pci_proc_domain()
and pci_domain_nr() if linux/pci.h and asm/pci.h are included.
Add #ifdefs around them
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
Reviewed-by: Markos Chandras <Markos.Chandras@imgtec.com>
Cc: Markos.Chandras@imgtec.com
Patchwork: https://patchwork.linux-mips.org/patch/8670/
The current code uses bits 0-6 of the sys_cpupll register to calculate
core clock speed. However this is only valid on Au1300, on all earlier
models the hardware only uses bits 0-5 to generate core clock.
This fixes clock calculation on the MTX1 (Au1500), where bit 6 of cpupll
is set as well, which ultimately lead the code to calculate a bogus cpu
core clock and also uart base clock down the line.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Reported-by: John Crispin <blogic@openwrt.org>
Tested-by: Bruno Randolf <br1@einfach.org>
Cc: stable@vger.kernel.org [v3.17+]
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/9279/
set_cpuspec() has been dropped with commit 074cf656700ddd1d2bd7f815f78e785418beb898
("MIPS: Alchemy: remove cpu_table.") in late 2008.
Patchwork: https://patchwork.linux-mips.org/patch/9150/
This was lost during the rewrite of clock framework support.
Patchwork: https://patchwork.linux-mips.org/patch/9149/
The Au1000 and Au1500 calculate the LRCLK a bit differently than
newer models: a single bit in MEM_STCFG0 selects if pclk is divided
by 4 or 5.
Patchwork: https://patchwork.linux-mips.org/patch/9148/
Build set and clear macros for the PageGrain register.
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9289/
There doesn't seem to be any valid reason to allocate the pages array
with the same flags as the buffer itself. Doing so can eventually lead
to the following safeguard in mm/slab.c's cache_grow() to be hit:
if (unlikely(flags & GFP_SLAB_BUG_MASK)) {
pr_emerg("gfp: %un", flags & GFP_SLAB_BUG_MASK);
BUG();
This happens when buffers are allocated with __GFP_DMA32 or
__GFP_HIGHMEM.
Fix this by allocating the pages array with GFP_KERNEL to follow what is
done elsewhere in this file. Using GFP_KERNEL in __iommu_alloc_buffer()
is safe because atomic allocations are handled by __iommu_alloc_atomic().
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Commit f47233c2d34 ("x86/mm/ASLR: Propagate base load address
calculation") causes PAGE_SIZE redefinition warnings for UML
subarch builds. This is caused by added includes that were
leftovers from previous patch versions are are not actually
needed (especially page_types.h inlcude in module.c). Drop
those stray includes.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1502201017240.28769@pobox.suse.cz
Since _PAGE_PROTNONE aliases _PAGE_GLOBAL it is only valid if
_PAGE_PRESENT is clear. Make pte_protnone() and pmd_protnone() check
for this.
This fixes a 64-bit Xen PV guest regression introduced by 8a0516ed8b90
("mm: convert p[te|md]_numa users to p[te|md]_protnone_numa"). Any
userspace process would endlessly fault.
In a 64-bit PV guest, userspace page table entries have _PAGE_GLOBAL set
by the hypervisor. This meant that any fault on a present userspace
entry (e.g., a write to a read-only mapping) would be misinterpreted as
a NUMA hinting fault and the fault would not be correctly handled,
resulting in the access endlessly faulting.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
* Clean up white spaces and tabs.
* Get rid of remaining hardcoded values for calculating
shifts and masks.
* Get rid of redundant macro values.
* Do not use page table bits directly in #ifdef's.
Patchwork: https://patchwork.linux-mips.org/patch/9287/
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kconfig updates from Michal Marek:
"Yann E Morin was supposed to take over kconfig maintainership, but
this hasn't happened. So I'm sending a few kconfig patches that I
collected:
- Fix for missing va_end in kconfig
- merge_config.sh displays used if given too few arguments
- s/boolean/bool/ in Kconfig files for consistency, with the plan to
only support bool in the future"
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: use va_end to match corresponding va_start
merge_config.sh: Display usage if given too few arguments
kconfig: use bool instead of boolean for type definition attributes
Pull kbuild updates from Michal Marek:
- several cleanups in kbuild
- serialize multiple *config targets so that 'make defconfig kvmconfig'
works
- The cc-ifversion macro got support for an else-branch
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild,gcov: simplify kernel/gcov/Makefile more
kbuild: allow cc-ifversion to have the argument for false condition
kbuild,gcov: remove unnecessary workaround
kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion
kbuild: fix cc-ifversion macro
kbuild: drop $(version_h) from MRPROPER_FILES
kbuild: use mixed-targets when two or more config targets are given
kbuild: remove redundant line from bounds.h/asm-offsets.h
kbuild: merge bounds.h and asm-offsets.h rules
kbuild: Drop support for clean-rule
Until we have hard performance data about the effects of CAD in the
spinlock loop disable the instruction by default.
git://git.linux-mips.org/pub/scm/mchandras/linux into mips-for-linux-next
Export the _save_msa asm function used by the lose_fpu(1) macro to GPL
modules so that KVM can make use of it when it is built as a module.
This fixes the following build error when CONFIG_KVM=m and
CONFIG_CPU_HAS_MSA=y due to commit f798217dfd03 ("KVM: MIPS: Don't leak
FPU/DSP to guest"):
ERROR: "_save_msa" [arch/mips/kvm/kvm.ko] undefined!
Fixes: f798217dfd03 (KVM: MIPS: Don't leak FPU/DSP to guest)
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: kvm@vger.kernel.org
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/9261/
