path: root/arch
2011-05-18Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: drivercore: revert addition of of_match to struct device of: fix race when matching drivers
2011-05-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Kludge IP27 build for 2.6.39. MIPS: AR7: Fix GPIO register size for Titan variant. MIPS: Fix duplicate invocation of notify_die. MIPS: RB532: Fix iomap resource size miscalculation.
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-18MIPS: Kludge IP27 build for 2.6.39.Ralf Baechle
2011-05-18MIPS: AR7: Fix GPIO register size for Titan variant.Florian Fainelli
The 'size' variable contains the correct register size for both AR7 and Titan, but we never used it to ioremap the correct register size. This problem only shows up on Titan. [ralf@linux-mips.org: Fixed the fix. The original patch as in patchwork recognizes the problem correctly then fails to fix it ...] Reported-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: https://patchwork.linux-mips.org/patch/2380/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18MIPS: Fix duplicate invocation of notify_die.Ralf Baechle
Initial patch by Yury Polyanskiy <ypolyans@princeton.edu>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2373/
2011-05-18MIPS: RB532: Fix iomap resource size miscalculation.Ralf Baechle
This is the MIPS portion of Joe Perches <joe@perches.com>'s https://patchwork.linux-mips.org/patch/2172/ which seems to have been lost in time and space. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, AMD: Fix ARAT feature setting again Revert "x86, AMD: Fix APIC timer erratum 400 affecting K8 Rev.A-E processors" x86, apic: Fix spurious error interrupts triggering on all non-boot APs x86, mce, AMD: Fix leaving freed data in a list x86: Fix UV BAU for non-consecutive nasids x86, UV: Fix NMI handler for UV platforms
2011-05-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf evlist: Fix per thread mmap setup perf tools: Honour the cpu list parameter when also monitoring a thread list kprobes, x86: Disable irqs during optimized callback
2011-05-18um: fix abortRichard Weinberger
os_dump_core() uses abort() to terminate UML in case of an fatal error. glibc's abort() calls raise(SIGABRT) which makes use of tgkill(). tgkill() has no effect within UML's kernel threads because they are not pthreads. As fallback abort() executes an invalid instruction to terminate the process. Therefore UML gets killed by SIGSEGV and leaves a ugly log entry in the host's kernel ring buffer. To get rid of this we use our own abort routine. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-17x86, AMD: Fix ARAT feature setting againBorislav Petkov
Trying to enable the local APIC timer on early K8 revisions uncovers a number of other issues with it, in conjunction with the C1E enter path on AMD. Fixing those causes much more churn and troubles than the benefit of using that timer brings so don't enable it on K8 at all, falling back to the original functionality the kernel had wrt to that. Reported-and-bisected-by: Nick Bowler <nbowler@elliptictech.com> Cc: Boris Ostrovsky <Boris.Ostrovsky@amd.com> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Nick Bowler <nbowler@elliptictech.com> Cc: Joerg-Volker-Peetz <jvpeetz@web.de> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Link: http://lkml.kernel.org/r/1305636919-31165-3-git-send-email-bp@amd64.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-17Revert "x86, AMD: Fix APIC timer erratum 400 affecting K8 Rev.A-E processors"Borislav Petkov
This reverts commit e20a2d205c05cef6b5783df339a7d54adeb50962, as it crashes certain boxes with specific AMD CPU models. Moving the lower endpoint of the Erratum 400 check to accomodate earlier K8 revisions (A-E) opens a can of worms which is simply not worth to fix properly by tweaking the errata checking framework: * missing IntPenging MSR on revisions < CG cause #GP: http://marc.info/?l=linux-kernel&m=130541471818831 * makes earlier revisions use the LAPIC timer instead of the C1E idle routine which switches to HPET, thus not waking up in deeper C-states: http://lkml.org/lkml/2011/4/24/20 Therefore, leave the original boundary starting with K8-revF. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-16Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP3: set the core dpll clk rate in its set_rate function omap: iommu: Return IRQ_HANDLED in fault handler when no fault occured
2011-05-16x86, apic: Fix spurious error interrupts triggering on all non-boot APsYouquan Song
This patch fixes a bug reported by a customer, who found that many unreasonable error interrupts reported on all non-boot CPUs (APs) during the system boot stage. According to Chapter 10 of Intel Software Developer Manual Volume 3A, Local APIC may signal an illegal vector error when an LVT entry is set as an illegal vector value (0~15) under FIXED delivery mode (bits 8-11 is 0), regardless of whether the mask bit is set or an interrupt actually happen. These errors are seen as error interrupts. The initial value of thermal LVT entries on all APs always reads 0x10000 because APs are woken up by BSP issuing INIT-SIPI-SIPI sequence to them and LVT registers are reset to 0s except for the mask bits which are set to 1s when APs receive INIT IPI. When the BIOS takes over the thermal throttling interrupt, the LVT thermal deliver mode should be SMI and it is required from the kernel to keep AP's LVT thermal monitoring register programmed as such as well. This issue happens when BIOS does not take over thermal throttling interrupt, AP's LVT thermal monitor register will be restored to 0x10000 which means vector 0 and fixed deliver mode, so all APs will signal illegal vector error interrupts. This patch check if interrupt delivery mode is not fixed mode before restoring AP's LVT thermal monitor register. Signed-off-by: Youquan Song <youquan.song@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Yong Wang <yong.y.wang@intel.com> Cc: hpa@linux.intel.com Cc: joe@perches.com Cc: jbaron@redhat.com Cc: trenn@suse.de Cc: kent.liu@intel.com Cc: chaohong.guo@intel.com Cc: <stable@kernel.org> # As far back as possible Link: http://lkml.kernel.org/r/1303402963-17738-1-git-send-email-youquan.song@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-13alpha: Wire up syscalls new to 2.6.39Michael Cree
Wire up the syscalls: name_to_handle_at open_by_handle_at clock_adjtime syncfs and adjust some whitespace in the neighbourhood to align commments. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-05-13alpha: convert to clocksource_register_hzJohn Stultz
Converts alpha to use clocksource_register_hz. Signed-off-by: John Stultz <johnstul@us.ibm.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Matt Turner <mattst88@gmail.com>
2011-05-13x86, mce, AMD: Fix leaving freed data in a listJulia Lawall
b may be added to a list, but is not removed before being freed in the case of an error. This is done in the corresponding deallocation function, so the code here has been changed to follow that. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E1,E2; identifier l; @@ *list_add(&E->l,E1); ... when != E1 when != list_del(&E->l) when != list_del_init(&E->l) when != E = E2 *kfree(E);// </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Borislav Petkov <borislav.petkov@amd.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/1305294731-12127-1-git-send-email-julia@diku.dk Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-13OMAP3: set the core dpll clk rate in its set_rate functionAvinash H.M
The debug l3_ick/rate is not displaying the actual rate of the clock in hardware. This is because, the core dpll set_rate function doesn't update the clk.rate. After fixing, the l3_ick/rate is displaying proper values. Signed-off-by: Shweta Gulati <shweta.gulati@ti.com> Signed-off-by: Avinash.H.M <avinashhm@ti.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: Paul Wamsley <paul@pwsan.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-12x86: Fix UV BAU for non-consecutive nasidsCliff Wickman
This is a fix for the SGI Altix-UV Broadcast Assist Unit code, which is used for TLB flushing. Certain hardware configurations (that customers are ordering) cause nasids (numa address space id's) to be non-consecutive. Specifically, once you have more than 4 blades in a IRU (Individual Rack Unit - or 1/2 rack) but less than the maximum of 16, the nasid numbering becomes non-consecutive. This currently results in a 'catastrophic error' (CATERR) detected by the firmware during OS boot. The BAU is generating an 'INTD' request that is targeting a non-existent nasid value. Such configurations may also occur when a blade is configured off because of hardware errors. (There is one UV hub per blade.) This patch is required to support such configurations. The problem with the tlb_uv.c code is that is using the consecutive hub numbers as indices to the BAU distribution bit map. These are simply the ordinal position of the hub or blade within its partition. It should be using physical node numbers (pnodes), which correspond to the physical nasid values. Use of the hub number only works as long as the nasids in the partition are consecutive and increase with a stride of 1. This patch changes the index to be the pnode number, thus allowing nasids to be non-consecutive. It also provides a table in local memory for each cpu to translate target cpu number to target pnode and nasid. And it improves naming to properly reflect 'node' and 'uvhub' versus 'nasid'. Signed-off-by: Cliff Wickman <cpw@sgi.com> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/E1QJmxX-0002Mz-Fk@eag09.americas.sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-12Merge branch 'stable/bug-fixes-for-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug-fixes-for-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: x86/mm: Fix section mismatch derived from native_pagetable_reserve() x86,xen: introduce x86_init.mapping.pagetable_reserve Revert "xen/mmu: Add workaround "x86-64, mm: Put early page table high""
2011-05-12x86/mm: Fix section mismatch derived from native_pagetable_reserve()Sedat Dilek
With CONFIG_DEBUG_SECTION_MISMATCH=y I see these warnings in next-20110415: LD vmlinux.o MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x1ba48): Section mismatch in reference from the function native_pagetable_reserve() to the function .init.text:memblock_x86_reserve_range() The function native_pagetable_reserve() references the function __init memblock_x86_reserve_range(). This is often because native_pagetable_reserve lacks a __init annotation or the annotation of memblock_x86_reserve_range is wrong. This patch fixes the issue. Thanks to pipacs from PaX project for help on IRC. Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12x86,xen: introduce x86_init.mapping.pagetable_reserveStefano Stabellini
Introduce a new x86_init hook called pagetable_reserve that at the end of init_memory_mapping is used to reserve a range of memory addresses for the kernel pagetable pages we used and free the other ones. On native it just calls memblock_x86_reserve_range while on xen it also takes care of setting the spare memory previously allocated for kernel pagetable pages from RO to RW, so that it can be used for other purposes. A detailed explanation of the reason why this hook is needed follows. As a consequence of the commit: commit 4b239f458c229de044d6905c2b0f9fe16ed9e01e Author: Yinghai Lu <yinghai@kernel.org> Date: Fri Dec 17 16:58:28 2010 -0800 x86-64, mm: Put early page table high at some point init_memory_mapping is going to reach the pagetable pages area and map those pages too (mapping them as normal memory that falls in the range of addresses passed to init_memory_mapping as argument). Some of those pages are already pagetable pages (they are in the range pgt_buf_start-pgt_buf_end) therefore they are going to be mapped RO and everything is fine. Some of these pages are not pagetable pages yet (they fall in the range pgt_buf_end-pgt_buf_top; for example the page at pgt_buf_end) so they are going to be mapped RW. When these pages become pagetable pages and are hooked into the pagetable, xen will find that the guest has already a RW mapping of them somewhere and fail the operation. The reason Xen requires pagetables to be RO is that the hypervisor needs to verify that the pagetables are valid before using them. The validation operations are called "pinning" (more details in arch/x86/xen/mmu.c). In order to fix the issue we mark all the pages in the entire range pgt_buf_start-pgt_buf_top as RO, however when the pagetable allocation is completed only the range pgt_buf_start-pgt_buf_end is reserved by init_memory_mapping. Hence the kernel is going to crash as soon as one of the pages in the range pgt_buf_end-pgt_buf_top is reused (b/c those ranges are RO). For this reason we need a hook to reserve the kernel pagetable pages we used and free the other ones so that they can be reused for other purposes. On native it just means calling memblock_x86_reserve_range, on Xen it also means marking RW the pagetable pages that we allocated before but that haven't been used before. Another way to fix this is without using the hook is by adding a 'if (xen_pv_domain)' in the 'init_memory_mapping' code and calling the Xen counterpart, but that is just nasty. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Yinghai Lu <yinghai@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12Revert "xen/mmu: Add workaround "x86-64, mm: Put early page table high""Konrad Rzeszutek Wilk
This reverts commit a38647837a411f7df79623128421eef2118b5884. It does not work with certain AMD machines. last_pfn = 0x100000 max_arch_pfn = 0x400000000 initial memory mapped : 0 - 02c3a000 Base memory trampoline at [ffff88000009b000] 9b000 size 20480 init_memory_mapping: 0000000000000000-0000000100000000 0000000000 - 0100000000 page 4k kernel direct mapping tables up to 100000000 @ ff7fb000-100000000 init_memory_mapping: 0000000100000000-00000001e0800000 0100000000 - 01e0800000 page 4k kernel direct mapping tables up to 1e0800000 @ 1df0f3000-1e0000000 xen: setting RW the range fffdc000 - 100000000 RAMDISK: 0203b000 - 02c3a000 No NUMA configuration found Faking a node at 0000000000000000-00000001e0800000 NUMA: Using 63 for the hash shift. Initmem setup node 0 0000000000000000-00000001e0800000 NODE_DATA [00000001dfffb000 - 00000001dfffffff] BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea PGD 0 Oops: 0003 [#1] SMP last sysfs file: CPU 0 Modules linked in: Pid: 0, comm: swapper Not tainted 2.6.39-0-virtual #6~smb1 RIP: e030:[<ffffffff81cf6a75>] [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea RSP: e02b:ffffffff81c01e38 EFLAGS: 00010046 RAX: 0000000000000000 RBX: 00000001e0800000 RCX: 0000000000001040 RDX: 0000000000004100 RSI: 0000000000000000 RDI: ffff8801dfffb000 RBP: ffffffff81c01e58 R08: 0000000000000020 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000bfe400 FS: 0000000000000000(0000) GS:ffffffff81cca000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 0000000001c03000 CR4: 0000000000000660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 0, threadinfo ffffffff81c00000, task ffffffff81c0b020) Stack: 0000000000000040 0000000000000001 0000000000000000 ffffffffffffffff ffffffff81c01e88 ffffffff81cf6c25 0000000000000000 0000000000000000 ffffffff81cf687f 0000000000000000 ffffffff81c01ea8 ffffffff81cf6e45 Call Trace: [<ffffffff81cf6c25>] numa_register_memblks.constprop.3+0x150/0x181 [<ffffffff81cf687f>] ? numa_add_memblk+0x7c/0x7c [<ffffffff81cf6e45>] numa_init.part.2+0x1c/0x7c [<ffffffff81cf687f>] ? numa_add_memblk+0x7c/0x7c [<ffffffff81cf6f67>] numa_init+0x6c/0x70 [<ffffffff81cf7057>] initmem_init+0x39/0x3b [<ffffffff81ce5865>] setup_arch+0x64e/0x769 [<ffffffff815e43c1>] ? printk+0x51/0x53 [<ffffffff81cdf92b>] start_kernel+0xd4/0x3f3 [<ffffffff81cdf388>] x86_64_start_reservations+0x132/0x136 [<ffffffff81ce2ed4>] xen_start_kernel+0x588/0x58f Code: 41 00 00 48 8b 3c c5 a0 24 cc 81 31 c0 40 f6 c7 01 74 05 aa 66 ba ff 40 40 f6 c7 02 74 05 66 ab 83 ea 02 89 d1 c1 e9 02 f6 c2 02 <f3> ab 74 02 66 ab 80 e2 01 74 01 aa 49 63 c4 48 c1 eb 0c 44 89 RIP [<ffffffff81cf6a75>] setup_node_bootmem+0x18a/0x1ea RSP <ffffffff81c01e38> CR2: 0000000000000000 ---[ end trace a7919e7f17c0a725 ]--- Kernel panic - not syncing: Attempted to kill the idle task! Pid: 0, comm: swapper Tainted: G D 2.6.39-0-virtual #6~smb1 Reported-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc32: Fixed unaligned memory copying in function __csum_partial_copy_sparc_generic sparc32: fix sparcstation 5 boot sparc32: fix section mismatch warnings in apc, pmc and time_32
2011-05-12Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6870/1: The mandatory barrier rmb() must be a dsb() in for device accesses ARM: 6892/1: handle ptrace requests to change PC during interrupted system calls ARM: 6890/1: memmap: only free allocated memmap entries when using SPARSEMEM ARM: zImage: the page table memory must be considered before relocation ARM: zImage: make sure not to relocate on top of the relocation code ARM: zImage: Fix bad SP address after relocating kernel ARM: zImage: make sure the stack is 64-bit aligned ARM: RiscPC: acornfb: fix section mismatches ARM: RiscPC: etherh: fix section mismatches
2011-05-12ARM: 6870/1: The mandatory barrier rmb() must be a dsb() in for device accessesCatalin Marinas
Since mandatory barriers may be used (explicitly or implicitly via readl etc.) to ensure the ordering between Device and Normal memory accesses, a DMB is not enough. This patch converts it to a DSB. Cc: Colin Cross <ccross@android.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: 6892/1: handle ptrace requests to change PC during interrupted system callsArnd Bergmann
GDB's interrupt.exp test cases currenly fail on ARM. The problem is how do_signal handled restarting interrupted system calls: The entry.S assembler code determines that we come from a system call; and that information is passed as "syscall" parameter to do_signal. That routine then calls get_signal_to_deliver [*] and if a signal is to be delivered, calls into handle_signal. If a system call is to be restarted either after the signal handler returns, or if no handler is to be called in the first place, the PC is updated after the get_signal_to_deliver call, either in handle_signal (if we have a handler) or at the end of do_signal (otherwise). Now the problem is that during [*], the call to get_signal_to_deliver, a ptrace intercept may happen. During this intercept, the debugger may change registers, including the PC. This is done by GDB if it wants to execute an "inferior call", i.e. the execution of some code in the debugged program triggered by GDB. To this purpose, GDB will save all registers, allocate a stack frame, set up PC and arguments as appropriate for the call, and point the link register to a dummy breakpoint instruction. Once the process is restarted, it will execute the call and then trap back to the debugger, at which point GDB will restore all registers and continue original execution. This generally works fine. However, now consider what happens when GDB attempts to do exactly that while the process was interrupted during execution of a to-be- restarted system call: do_signal is called with the syscall flag set; it calls get_signal_to_deliver, at which point the debugger takes over and changes the PC to point to a completely different place. Now get_signal_to_deliver returns without a signal to deliver; but now do_signal decides it should be restarting a system call, and decrements the PC by 2 or 4 -- so it now points to 2 or 4 bytes before the function GDB wants to call -- which leads to a subsequent crash. To fix this problem, two things need to be supported: - do_signal must be able to recognize that get_signal_to_deliver changed the PC to a different location, and skip the restart-syscall sequence - once the debugger has restored all registers at the end of the inferior call sequence, do_signal must recognize that *now* it needs to restart the pending system call, even though it was now entered from a breakpoint instead of an actual svc instruction This set of issues is solved on other platforms, usually by one of two mechanisms: - The status information "do_signal is handling a system call that may need restarting" is itself carried in some register that can be accessed via ptrace. This is e.g. on Intel the "orig_eax" register; on Sparc the kernel defines a magic extra bit in the flags register for this purpose. This allows GDB to manage that state: reset it when doing an inferior call, and restore it after the call is finished. - On s390, do_signal transparently handles this problem without requiring GDB interaction, by performing system call restarting in the following way: first, adjust the PC as necessary for restarting the call. Then, call get_signal_to_deliver; and finally just continue execution at the PC. This way, if GDB does not change the PC, everything is as before. If GDB *does* change the PC, execution will simply continue there -- and once GDB restores the PC it saved at that point, it will automatically point to the *restarted* system call. (There is the minor twist how to handle system calls that do *not* need restarting -- do_signal will undo the PC change in this case, after get_signal_to_deliver has returned, and only if ptrace did not change the PC during that call.) Because there does not appear to be any obvious register to carry the syscall-restart information on ARM, we'd either have to introduce a new artificial ptrace register just for that purpose, or else handle the issue transparently like on s390. The patch below implements the second option; using this patch makes the interrupt.exp test cases pass on ARM, with no regression in the GDB test suite otherwise. Cc: patches@linaro.org Signed-off-by: Ulrich Weigand <ulrich.weigand@linaro.org> Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: 6890/1: memmap: only free allocated memmap entries when using SPARSEMEMWill Deacon
The SPARSEMEM code allocates memmap entries only for sections which are present (i.e. those which contain some valid memory). The membank checks in free_unused_memmap do not take this into account and can incorrectly attempt to free memory which is not allocated, resulting in a BUG() in the bootmem code. However, if memory is configured as follows: |<----section---->|<----hole---->|<----section---->| +--------+--------+--------------+--------+--------+ | bank 0 | unused | | bank 1 | unused | +--------+--------+--------------+--------+--------+ where a bank only occupies part of a section, the memmap allocated for the remainder of the section *can* be freed. This patch modifies the checks in free_unused_memmap so that only valid memmap entries are considered for removal. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-11sparc32: Fixed unaligned memory copying in function ↵Tkhai Kirill
__csum_partial_copy_sparc_generic When we are in the label cc_dword_align, registers %o0 and %o1 have the same last 2 bits, but it's not guaranteed one of them is zero. So we can get unaligned memory access in label ccte. Example of parameters which lead to this: %o0=0x7ff183e9, %o1=0x8e709e7d, %g1=3 With the parameters I had a memory corruption, when the additional 5 bytes were rewritten. This patch corrects the error. One comment to the patch. We don't care about the third bit in %o1, because cc_end_cruft stores word or less. Signed-off-by: Tkhai Kirill <tkhai@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] fix alloc_pgste check in init_new_context [S390] oprofile: fix min/max interval query checks [S390] replace diag10() with diag10_range() function [S390] disassembler: handle b280/spp instruction [S390] kernel: Initialize register 14 when starting new CPU [S390] dasd: prevent IO error during reserve/release loop [S390] sclp/memory hotplug: fix initial usecount of increments
2011-05-11omap: iommu: Return IRQ_HANDLED in fault handler when no fault occuredLaurent Pinchart
Commit d594f1f31afe13edd8c02f3854a65cc58cfb3b74 (omap: IOMMU: add support to callback during fault handling) broke interrupt line sharing between the OMAP3 ISP and its IOMMU. Because of this, every interrupt generated by the OMAP3 ISP is handled by the IOMMU driver instead of being passed to the OMAP3 ISP driver. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-11kprobes, x86: Disable irqs during optimized callbackJiri Olsa
Disable irqs during optimized callback, so we dont miss any in-irq kprobes. The following commands: # cd /debug/tracing/ # echo "p mutex_unlock" >> kprobe_events # echo "p _raw_spin_lock" >> kprobe_events # echo "p smp_apic_timer_interrupt" >> ./kprobe_events # echo 1 > events/enable Cause the optimized kprobes to be missed. None is missed with the fix applied. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20110511110613.GB2390@jolsa.brq.redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-10MIPS: Alchemy: fix xxs1500 build errorManuel Lauss
This fixes: alchemy/xxs1500/init.c: In function 'prom_init': alchemy/xxs1500/init.c:57:17: error: ignoring return value of 'kstrtoul', declared with attribute warn_unused_result Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2340/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Invalidate old TLB mappings when updating huge page PTEs.David Daney
Without this, stale Icache or TLB entries may be used. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org https://patchwork.linux-mips.org/patch/2318/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Hibernation: Fixes for PAGE_SIZE >= 64kbWu Zhangjin
PAGE_SIZE >= 64kb (1 << 16) is too big to be the immediate of the addiu/daddiu instruction, so, use addu/daddu instruction instead. The following compiling error is fixed: AS arch/mips/power/hibernate.o arch/mips/power/hibernate.S: Assembler messages: arch/mips/power/hibernate.S:38: Error: expression out of range make[2]: *** [arch/mips/power/hibernate.o] Error 1 make[1]: *** [arch/mips/power] Error 2 Reported-by: Roman Mamedov <rm@romanrm.ru> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2313/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: JZ4740: Set one-shot feature flag for the clockeventLars-Peter Clausen
The code for supporting one-shot mode for the clockevent is already there, only the feature flag was not set. Setting the one-shot flag allows the kernel to run in tickless mode. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2261/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: JZ4740: Export symbols to the watchdog driver moduleRalf Baechle
MODPOST 356 modules ERROR: "jz4740_timer_disable_watchdog" [drivers/watchdog/jz4740_wdt.ko] undefine d! ERROR: "jz4740_timer_enable_watchdog" [drivers/watchdog/jz4740_wdt.ko] undefined ! make[1]: *** [__modpost] Error 1 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: JZ4740: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/jz4740/dma.o arch/mips/jz4740/dma.c: In function 'jz4740_dma_chan_irq': arch/mips/jz4740/dma.c:245:11: error: variable 'status' set but not used [-Werro r=unused-but-set-variable] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Audit: Fix success success argument pass to audit_syscall_exitRalf Baechle
2011-05-10MIPS: Fix calc_vmlinuz_load_addr build warnings.Ralf Baechle
HOSTCC arch/mips/boot/compressed/calc_vmlinuz_load_addr arch/mips/boot/compressed/calc_vmlinuz_load_addr.c: In function 'main': arch/mips/boot/compressed/calc_vmlinuz_load_addr.c:35:2: warning: format '%llx' expects type 'long long unsigned int *', but argument 3 has type 'uint64_t *' arch/mips/boot/compressed/calc_vmlinuz_load_addr.c:54:2: warning: format '%llx' expects type 'long long unsigned int', but argument 2 has type 'uint64_t' Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Alchemy: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/alchemy/devboards/db1x00/board_setup.o arch/mips/alchemy/devboards/db1x00/board_setup.c: In function 'board_setup': arch/mips/alchemy/devboards/db1x00/board_setup.c:130:6: error: variable 'pin_func' set but not used [-Werror=unused-but-set-variable] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Document former use of timerfd(2) syscall number.Ralf Baechle
2011-05-10MIPS: IP27: Fix GCC 4.6.0 build error.Ralf Baechle
CC arch/mips/sgi-ip27/ip27-hubio.o arch/mips/sgi-ip27/ip27-hubio.c: In function 'hub_pio_map': arch/mips/sgi-ip27/ip27-hubio.c:32:20: error: variable 'junk' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: bcm63xx: Fix header_crc comment in bcm963xx_tag.hJonas Gorski
The CRC32 actually includes the tag_version. Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2275/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Octeon: Guard the Kconfig body with CPU_CAVIUM_OCTEONDavid Daney
Instead of making each Octeon specific option depend on CPU_CAVIUM_OCTEON, gate the body of the entire file with CPU_CAVIUM_OCTEON. With this change, CAVIUM_OCTEON_SPECIFIC_OPTIONS becomes useless, so get rid of it as well. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2091/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Octeon: Cleanup Kconfig IRQ_CPU* symbols.David Daney
Octeon doesn't use IRQ_CPU, so don't select it. IRQ_CPU_OCTEON is a completely unused symbol, remove it completely. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2086/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: Rename .data..mostly and properly handle it in linker scriptCatalin Marinas
2011-05-10MIPS: MSP: Fix build errorRalf Baechle
Reported and original patch by Yoichi Yuasa <yuasa@linux-mips.org>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-10MIPS: MSP71xx: Fix typo in msp_per_irq_controllerYoichi Yuasa
CC arch/mips/pmc-sierra/msp71xx/msp_irq_per.o arch/mips/pmc-sierra/msp71xx/msp_irq_per.c:101:2: error: expected identifier before '.' token make[2]: *** [arch/mips/pmc-sierra/msp71xx/msp_irq_per.o] Error 1 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2246/ Cc: linux-mips <linux-mips@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
