Linux 4.1.39
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Add alias for FEC ethernet on Vybrid to allow bootloaders (like U-Boot)
patch-in the MAC address using this alias.
Linux 4.1.32
Linux 4.1.24
Add USB WDM class (Wireless Mobile Communication Device Management)
as well as USB driver for GSM and CDMA modems (Option and others).
Instead of using gpio-backlight driver for BL_ON control,
use pwm-backlight driver 'enable-gpios' property.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
[ Upstream commit b0996ae48285364710bce812e70ce67771ea6ef7 ]
Commit 609e36d372ad ("KVM: x86: pass host_initiated to functions that
read MSRs") modified kvm_get_msr_common function to use msr_info->data
instead of data but missed one occurrence. Replace it and remove the
unused local variable.
Fixes: 609e36d372ad ("KVM: x86: pass host_initiated to functions that
read MSRs")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
[ Upstream commit 81b1b9ca6d5ca5f3ce91c0095402def657cf5db3 ]
The current handling of accesses to guest MSR_TSC_AUX returns error if
vcpu does not support rdtscp, though those accesses are initiated by
host. This can result in the reboot failure of some versions of
QEMU. This patch fixes this issue by passing those host initiated
accesses for further handling instead.
Signed-off-by: Haozhong Zhang <haozhong.zhang@intel.com>
[ Upstream commit 609e36d372ad9329269e4a1467bd35311893d1d6 ]
SMBASE is only readable from SMM for the VCPU, but it must be always
accessible if userspace is accessing it. Thus, all functions that
read MSRs are changed to accept a struct msr_data; the host_initiated
and index fields are pre-initialized, while the data field is filled
on return.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit 9e3440481845b2ec22508f60837ee2cab2b6054f ]
The 64-bit get_user() wasn't clearing the high word due to a typo in the
error handler. The exception handler entry was already correct, though.
Noticed during recent usercopy test additions in lib/test_user_copy.c.
Cc: stable@vger.kernel.org
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit a524c218bc94c705886a0e0fedeee45d1931da32 ]
Reported-by: Jo-Philipp Wich <jo@mein.io>
Fixes: 9aed02feae57bf7 ("ARC: [arcompact] handle unaligned access delay slot")
Cc: linux-snps-arc@lists.infradead.org
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
[ Upstream commit 228dbbfb5d77f8e047b2a1d78da14b7158433027 ]
Ensure that if userspace supplies insufficient data to
PTRACE_SETREGSET to fill all the registers, the thread's old
registers are preserved.
Cc: <stable@vger.kernel.org> # 3.0.x-
Fixes: 5be6f62b0059 ("ARM: 6883/1: ptrace: Migrate to regsets framework")
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit 2ad5d52d42810bed95100a3d912679d8864421ec ]
In swab.h the "#if BITS_PER_LONG > 32" breaks compiling userspace programs if
BITS_PER_LONG is #defined by userspace with the sizeof() compiler builtin.
Solve this problem by using __BITS_PER_LONG instead. Since we now
#include asm/bitsperlong.h avoid further potential userspace pollution
by moving the #define of SHIFT_PER_LONG to bitops.h which is not
exported to userspace.
This patch unbreaks compiling qemu on hppa/parisc.
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit 9aed02feae57bf7a40cb04ea0e3017cb7a998db4 ]
After emulating an unaligned access in delay slot of a branch, we
pretend as the delay slot never happened - so return back to actual
branch target (or next PC if branch was not taken).
Curently we did this by handling STATUS32.DE, we also need to clear the
BTA.T bit, which is disregarded when returning from original misaligned
exception, but could cause weirdness if it took the interrupt return
path (in case interrupt was acive too)
One ARC700 customer ran into this when enabling unaligned access fixup
for kernel mode accesses as well
[ Upstream commit f05fea5b3574a5926c53865eea27139bb40b2f2b ]
In __eeh_clear_pe_frozen_state(), we should pass the flag's value
instead of its address to eeh_unfreeze_pe(). The isolated flag is
cleared if no error returned from __eeh_clear_pe_frozen_state(). We
never observed the error from the function. So the isolated flag should
have been always cleared, no real issue is caused because of the misused
@flag.
This fixes the code by passing the value of @flag to eeh_unfreeze_pe().
Fixes: 5cfb20b96f6 ("powerpc/eeh: Emulate EEH recovery for VFIO devices")
Cc: stable@vger.kernel.org # v3.18+
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
[ Upstream commit af2b7fa17eb92e52b65f96604448ff7a2a89ee99 ]
prom_init.c calls 'instance-to-package' twice, but the return
is not checked during prom_find_boot_cpu(). The result is then
passed to prom_getprop(), which could be PROM_ERROR. Add a return check
to prevent this.
This was found on a pasemi system, where CFE doesn't have a working
'instance-to package' prom call.
Before Commit 5c0484e25ec0 ('powerpc: Endian safe trampoline') the area
around addr 0 was mostly 0's and this doesn't cause a problem. Once the
macro 'FIXUP_ENDIAN' has been added to head_64.S, the low memory area
now has non-zero values, which cause the prom_getprop() call
to hang.
mpe: Also confirmed that under SLOF if 'instance-to-package' did fail
with PROM_ERROR we would crash in SLOF. So the bug is not specific to
CFE, it's just that other open firmwares don't trigger it because they
have a working 'instance-to-package'.
Fixes: 5c0484e25ec0 ("powerpc: Endian safe trampoline")
Cc: stable@vger.kernel.org # v3.13+
Signed-off-by: Darren Stevens <darren@stevens-zone.net>
[ Upstream commit 11e3b725cfc282efe9d4a354153e99d86a16af08 ]
Update the ARMv8 Crypto Extensions and the plain NEON AES implementations
in CBC and CTR modes to return the next IV back to the skcipher API client.
This is necessary for chaining to work correctly.
Note that for CTR, this is only done if the request is a round multiple of
the block size, since otherwise, chaining is impossible anyway.
Cc: <stable@vger.kernel.org> # v3.16+
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[ Upstream commit 43849785e1079f6606a31cb7fda92d1200849728 ]
Read access to the SPI flash are broken on da850-evm, i.e. the data
read is not what is actually programmed on the flash.
According to the datasheet for the M25P64 part present on the da850-evm,
if the SPI frequency is higher than 20MHz then the READ command is not
usable anymore and only the FAST_READ command can be used to read data.
This commit specifies in the DTS that we should use FAST_READ command
instead of the READ command.
Tested-by: Kevin Hilman <khilman@baylibre.com>
Signed-off-by: Fabien Parent <fparent@baylibre.com>
[nsekhar@ti.com: subject line adjustment]
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[ Upstream commit ad9e202aa1ce571b1d7fed969d06f66067f8a086 ]
We cannot preserve partial fields for hardware breakpoints, because
the values written by userspace to the hardware breakpoint
registers can't subsequently be recovered intact from the hardware.
So, just reject attempts to write incomplete fields with -EINVAL.
Cc: <stable@vger.kernel.org> # 3.7.x-
Fixes: 478fcb2cdb23 ("arm64: Debugging support")
Acked-by: Will Deacon <Will.Deacon@arm.com>
[ Upstream commit aeb1f39d814b2e21e5e5706a48834bfd553d0059 ]
This patch adds an explicit __reserved[] field to user_fpsimd_state
to replace what was previously unnamed padding.
This ensures that data in this region are propagated across
assignment rather than being left possibly uninitialised at the
destination.
Fixes: 60ffc30d5652 ("arm64: Exception handling")
[ Upstream commit 9a17b876b573441bfb3387ad55d98bf7184daf9d ]
[ Upstream commit cef84c302fe051744b983a92764d3fcca933415d ]
KVM's lapic emulation uses static_key_deferred (apic_{hw,sw}_disabled).
These are implemented with delayed_work structs which can still be
pending when the KVM module is unloaded. We've seen this cause kernel
panics when the kvm_intel module is quickly reloaded.
Use the new static_key_deferred_flush() API to flush pending updates on
module unload.
Signed-off-by: David Matlack <dmatlack@google.com>
[ Upstream commit 89e9f7bcd8744ea25fcf0ac671b8d72c10d7d790 ]
Martin reported that the Supermicro X8DTH-i/6/iF/6F advertises incorrect
host bridge windows via _CRS:
pci_root PNP0A08:00: host bridge window [io 0xf000-0xffff]
pci_root PNP0A08:01: host bridge window [io 0xf000-0xffff]
Both bridges advertise the 0xf000-0xffff window, which cannot be correct.
Work around this by ignoring _CRS on this system. The downside is that we
may not assign resources correctly to hot-added PCI devices (if they are
possible on this system).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=42606
Reported-by: Martin Burnicki <martin.burnicki@meinberg.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: stable@vger.kernel.org
[ Upstream commit ddc37832a1349f474c4532de381498020ed71d31 ]
On APQ8060, the kernel crashes in arch_hw_breakpoint_init, taking an
undefined instruction trap within write_wb_reg. This is because Scorpion
CPUs erroneously appear to set DBGPRSR.SPD when WFI is issued, even if
the core is not powered down. When DBGPRSR.SPD is set, breakpoint and
watchpoint registers are treated as undefined.
It's possible to trigger similar crashes later on from userspace, by
requesting the kernel to install a breakpoint or watchpoint, as we can
go idle at any point between the reset of the debug registers and their
later use. This has always been the case.
Given that this has always been broken, no-one has complained until now,
and there is no clear workaround, disable hardware breakpoints and
watchpoints on Scorpion to avoid these issues.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reported-by: Linus Walleij <linus.walleij@linaro.org>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Russell King <linux@armlinux.org.uk>
[ Upstream commit fd7c99142d77dc4a851879a66715abf12a3193fb ]
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
[ Upstream commit 32eb12a6c11034867401d56b012e3c15d5f8141e ]
Flush the KVM entry code from the icache on all CPUs, not just the one
that built the entry code.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: "Radim Krčmář" <rkrcmar@redhat.com>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
Cc: <stable@vger.kernel.org> # 3.16.x-
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit ef37427ac5677331145ab27a17e6f5f1b43f0c11 ]
Similarly to the aemif clock - this screws up the linked list of clock
children. Create a separate clock for mdio inheriting the rate from
emac_clk.
Cc: <stable@vger.kernel.org> # 3.12.x-
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
[nsekhar@ti.com: add a comment over mdio_clk to explaing its existence +
commit headline updates]
[ Upstream commit ef85b67385436ddc1998f45f1d6a210f935b3388 ]
When L2 exits to L0 due to "exception or NMI", software exceptions
(#BP and #OF) for which L1 has requested an intercept should be
handled by L1 rather than L0. Previously, only hardware exceptions
were forwarded to L1.
Signed-off-by: Jim Mattson <jmattson@google.com>
[ Upstream commit 24d5373dda7c00a438d26016bce140299fae675e ]
The function xen_guest_init is using __alloc_percpu with an alignment
which are not power of two.
However, the percpu allocator never supported alignments which are not power
of two and has always behaved incorectly in thise case.
Commit 3ca45a4 "percpu: ensure requested alignment is power of two"
introduced a check which trigger a warning [1] when booting linux-next
on Xen. But in reality this bug was always present.
This can be fixed by replacing the call to __alloc_percpu with
alloc_percpu. The latter will use an alignment which are a power of two.
[1]
[ 0.023921] illegal size (48) or align (48) for percpu allocation
[ 0.024167] ------------[ cut here ]------------
[ 0.024344] WARNING: CPU: 0 PID: 1 at linux/mm/percpu.c:892 pcpu_alloc+0x88/0x6c0
[ 0.024584] Modules linked in:
[ 0.024708]
[ 0.024804] CPU: 0 PID: 1 Comm: swapper/0 Not tainted
4.9.0-rc7-next-20161128 #473
[ 0.025012] Hardware name: Foundation-v8A (DT)
[ 0.025162] task: ffff80003d870000 task.stack: ffff80003d844000
[ 0.025351] PC is at pcpu_alloc+0x88/0x6c0
[ 0.025490] LR is at pcpu_alloc+0x88/0x6c0
[ 0.025624] pc : [<ffff00000818e678>] lr : [<ffff00000818e678>]
pstate: 60000045
[ 0.025830] sp : ffff80003d847cd0
[ 0.025946] x29: ffff80003d847cd0 x28: 0000000000000000
[ 0.026147] x27: 0000000000000000 x26: 0000000000000000
[ 0.026348] x25: 0000000000000000 x24: 0000000000000000
[ 0.026549] x23: 0000000000000000 x22: 00000000024000c0
[ 0.026752] x21: ffff000008e97000 x20: 0000000000000000
[ 0.026953] x19: 0000000000000030 x18: 0000000000000010
[ 0.027155] x17: 0000000000000a3f x16: 00000000deadbeef
[ 0.027357] x15: 0000000000000006 x14: ffff000088f79c3f
[ 0.027573] x13: ffff000008f79c4d x12: 0000000000000041
[ 0.027782] x11: 0000000000000006 x10: 0000000000000042
[ 0.027995] x9 : ffff80003d847a40 x8 : 6f697461636f6c6c
[ 0.028208] x7 : 6120757063726570 x6 : ffff000008f79c84
[ 0.028419] x5 : 0000000000000005 x4 : 0000000000000000
[ 0.028628] x3 : 0000000000000000 x2 : 000000000000017f
[ 0.028840] x1 : ffff80003d870000 x0 : 0000000000000035
[ 0.029056]
[ 0.029152] ---[ end trace 0000000000000000 ]---
[ 0.029297] Call trace:
[ 0.029403] Exception stack(0xffff80003d847b00 to
0xffff80003d847c30)
[ 0.029621] 7b00: 0000000000000030 0001000000000000
ffff80003d847cd0 ffff00000818e678
[ 0.029901] 7b20: 0000000000000002 0000000000000004
ffff000008f7c060 0000000000000035
[ 0.030153] 7b40: ffff000008f79000 ffff000008c4cd88
ffff80003d847bf0 ffff000008101778
[ 0.030402] 7b60: 0000000000000030 0000000000000000
ffff000008e97000 00000000024000c0
[ 0.030647] 7b80: 0000000000000000 0000000000000000
[ 0.030895] 7ba0: 0000000000000035 ffff80003d870000
000000000000017f 0000000000000000
[ 0.031144] 7bc0: 0000000000000000 0000000000000005
ffff000008f79c84 6120757063726570
[ 0.031394] 7be0: 6f697461636f6c6c ffff80003d847a40
0000000000000042 0000000000000006
[ 0.031643] 7c00: 0000000000000041 ffff000008f79c4d
ffff000088f79c3f 0000000000000006
[ 0.031877] 7c20: 00000000deadbeef 0000000000000a3f
[ 0.032051] [<ffff00000818e678>] pcpu_alloc+0x88/0x6c0
[ 0.032229] [<ffff00000818ece8>] __alloc_percpu+0x18/0x20
[ 0.032409] [<ffff000008d9606c>] xen_guest_init+0x174/0x2f4
[ 0.032591] [<ffff0000080830f8>] do_one_initcall+0x38/0x130
[ 0.032783] [<ffff000008d90c34>] kernel_init_freeable+0xe0/0x248
[ 0.032995] [<ffff00000899a890>] kernel_init+0x10/0x100
[ 0.033172] [<ffff000008082ec0>] ret_from_fork+0x10/0x50
Reported-by: Wei Chen <wei.chen@arm.com>
Link: https://lkml.org/lkml/2016/11/28/669
Signed-off-by: Julien Grall <julien.grall@arm.com>
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
[ Upstream commit 6dff5b67054e17c91bd630bcdda17cfca5aa4215 ]
GCC 5 generates different code for this bootwrapper null check that
causes the PS3 to hang very early in its bootup. This check is of
limited value, so just get rid of it.
Signed-off-by: Geoff Levand <geoff@infradead.org>
[ Upstream commit f064a0de1579fabded8990bed93971e30deb9ecb ]
The hashed page table MMU in POWER processors can update the R
(reference) and C (change) bits in a HPTE at any time until the
HPTE has been invalidated and the TLB invalidation sequence has
completed. In kvmppc_h_protect, which implements the H_PROTECT
hypercall, we read the HPTE, modify the second doubleword,
invalidate the HPTE in memory, do the TLB invalidation sequence,
and then write the modified value of the second doubleword back
to memory. In doing so we could overwrite an R/C bit update done
by hardware between when we read the HPTE and when the TLB
invalidation completed. To fix this we re-read the second
doubleword after the TLB invalidation and OR in the (possibly)
new values of R and C. We can use an OR since hardware only ever
sets R and C, never clears them.
This race was found by code inspection. In principle this bug could
cause occasional guest memory corruption under host memory pressure.
Fixes: a8606e20e41a ("KVM: PPC: Handle some PAPR hcalls in the kernel", 2011-06-29)
Cc: stable@vger.kernel.org # v3.19+
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
[ Upstream commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 ]
When switching from/to a guest that has a transaction in progress,
we need to save/restore the checkpointed register state. Although
XER is part of the CPU state that gets checkpointed, the code that
does this saving and restoring doesn't save/restore XER.
This fixes it by saving and restoring the XER. To allow userspace
to read/write the checkpointed XER value, we also add a new ONE_REG
specifier.
The visible effect of this bug is that the guest may see its XER
value being corrupted when it uses transactions.
Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support")
Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit")
Cc: stable@vger.kernel.org # v3.15+
Reviewed-by: Thomas Huth <thuth@redhat.com>
[ Upstream commit 90944e40ba1838de4b2a9290cf273f9d76bd3bdd ]
If the gcc is configured to do -fPIE by default then the build aborts
later with:
| Unsupported relocation type: unknown type rel type name (29)
Tagging it stable so it is possible to compile recent stable kernels as
well.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Michal Marek <mmarek@suse.com>
[ Upstream commit e1bfc11c5a6f40222a698a818dc269113245820e ]
cr4_init_shadow() will panic on 486-like machines without CR4. Fix
it using __read_cr4_safe().
Reported-by: david@saggiorato.net
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: 1e02ce4cccdc ("x86: Store a per-cpu shadow copy of CR4")
Link: http://lkml.kernel.org/r/43a20f81fb504013bf613913dc25574b45336a61.1475091074.git.luto@kernel.org
[ Upstream commit d248220f0465b818887baa9829e691fe662b2c5e ]
Since commit 6ce0d2001692 ("ARM: dma: Use dma_pfn_offset for dma address translation"),
dma_to_pfn() already returns the PFN with the physical memory start offset
so we don't need to add it again.
This fixes USB mass storage lock-up problem on systems that can't do DMA
over the entire physical memory range (e.g.) Keystone 2 systems with 4GB RAM
can only do DMA over the first 2GB. [K2E-EVM].
What happens there is that without this patch SCSI layer sets a wrong
bounce buffer limit in scsi_calculate_bounce_limit() for the USB mass
storage device. dma_max_pfn() evaluates to 0x8fffff and bounce_limit
is set to 0x8fffff000 whereas maximum DMA'ble physical memory on Keystone 2
is 0x87fffffff. This results in non DMA'ble pages being given to the
USB controller and hence the lock-up.
NOTE: in the above case, USB-SCSI-device's dma_pfn_offset was showing as 0.
This should have really been 0x780000 as on K2e, LOWMEM_START is 0x80000000
and HIGHMEM_START is 0x800000000. DMA zone is 2GB so dma_max_pfn should be
0x87ffff. The incorrect dma_pfn_offset for the USB storage device is because
USB devices are not correctly inheriting the dma_pfn_offset from the
USB host controller. This will be fixed by a separate patch.
Fixes: 6ce0d2001692 ("ARM: dma: Use dma_pfn_offset for dma address translation")
Cc: Santosh Shilimkar <santosh.shilimkar@oracle.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Linus Walleij <linus.walleij@linaro.org>
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
[ Upstream commit 6ed518328d0189e0fdf1bb7c73290d546143ea66 ]
We have one critical section in the syscall entry path in which we switch from
the userspace stack to kernel stack. In the event of an external interrupt, the
interrupt code distinguishes between those two states by analyzing the value of
sr7. If sr7 is zero, it uses the kernel stack. Therefore it's important, that
the value of sr7 is in sync with the currently enabled stack.
This patch now disables interrupts while executing the critical section. This
prevents the interrupt handler to possibly see an inconsistent state which in
the worst case can lead to crashes.
Interestingly, in the syscall exit path interrupts were already disabled in the
critical section which switches back to the userspace stack.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
[ Upstream commit e1e575f6b026734be3b1f075e780e91ab08ca541 ]
The advancing of the PC when completing an MMIO load is done before
re-entering the guest, i.e. before restoring the guest ASID. However if
the load is in a branch delay slot it may need to access guest code to
read the prior branch instruction. This isn't safe in TLB mapped code at
the moment, nor in the future when we'll access unmapped guest segments
using direct user accessors too, as it could read the branch from host
user memory instead.
Therefore calculate the resume PC in advance while we're still in the
right context and save it in the new vcpu->arch.io_pc (replacing the no
longer needed vcpu->arch.pending_load_cause), and restore it on MMIO
completion.
Fixes: e685c689f3a8 ("KVM/MIPS32: Privileged instruction/target branch emulation.")
Cc: "Radim Krčmář <rkrcmar@redhat.com>
Cc: <stable@vger.kernel.org> # 3.10.x-
[ Upstream commit ede5f3e7b54a4347be4d8525269eae50902bd7cd ]
The ERET instruction to return from exception is used for returning from
exception level (Status.EXL) and error level (Status.ERL). If both bits
are set however we should be returning from ERL first, as ERL can
interrupt EXL, for example when an NMI is taken. KVM however checks EXL
first.
Fix the order of the checks to match the pseudocode in the instruction
set manual.
[ Upstream commit 80f23935cadb1c654e81951f5a8b7ceae0acc1b4 ]
PowerPC's "cmp" instruction has four operands. Normally people write
"cmpw" or "cmpd" for the second cmp operand 0 or 1. But, frequently
people forget, and write "cmp" with just three operands.
With older binutils this is silently accepted as if this was "cmpw",
while often "cmpd" is wanted. With newer binutils GAS will complain
about this for 64-bit code. For 32-bit code it still silently assumes
"cmpw" is what is meant.
In this instance the code comes directly from ISA v2.07, including the
cmp, but cmpd is correct. Backport to stable so that new toolchains can
build old kernels.
Fixes: 948cf67c4726 ("powerpc: Add NAP mode support on Power7 in HV mode")
Cc: stable@vger.kernel.org # v3.0
Reviewed-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Signed-off-by: Segher Boessenkool <segher@kernel.crashing.org>
[ Upstream commit 60e21a0ef54cd836b9eb22c7cb396989b5b11648 ]
The WnR bit in the HSR/ESR_EL2 indicates whether a data abort was
generated by a read or a write instruction. For stage 2 data aborts
generated by a stage 1 translation table walk (i.e. the actual page
table access faults at EL2), the WnR bit therefore reports whether the
instruction generating the walk was a load or a store, *not* whether the
page table walker was reading or writing the entry.
For page tables marked as read-only at stage 2 (e.g. due to KSM merging
them with the tables from another guest), this could result in livelock,
where a page table walk generated by a load instruction attempts to
set the access flag in the stage 1 descriptor, but fails to trigger
CoW in the host since only a read fault is reported.
This patch modifies the arm64 kvm_vcpu_dabt_iswrite function to
take into account stage 2 faults in stage 1 walks. Since DBM cannot be
disabled at EL2 for CPUs that implement it, we assume that these faults
are always causes by writes, avoiding the livelock situation at the
expense of occasional, spurious CoWs.
We could, in theory, do a bit better by checking the guest TCR
configuration and inspecting the page table to see why the PTE faulted.
However, I doubt this is measurable in practice, and the threat of
livelock is real.
Cc: Julien Grall <julien.grall@arm.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
[ Upstream commit 57c841f131ef295b583365d2fddd6b0d16e82c10 ]
So far, our handling of cache maintenance by VA has been pretty
simple: Either the access is in the guest RAM and generates a S2
fault, which results in the page being mapped RW, or we go down
the io_mem_abort() path, and nuke the guest.
The first one is fine, but the second one is extremely weird.
Treating the CM as an I/O is wrong, and nothing in the ARM ARM
indicates that we should generate a fault for something that
cannot end-up in the cache anyway (even if the guest maps it,
it will keep on faulting at stage-2 for emulation).
So let's just skip this instruction, and let the guest get away
with it.
[ Upstream commit 8678654e3c7ad7b0f4beb03fa89691279cba71f9 ]
gcc 7 warns:
arch/x86/kvm/ioapic.c: In function 'kvm_ioapic_reset':
arch/x86/kvm/ioapic.c:597:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
And it is right. Memset whole array using sizeof operator.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: x86@kernel.org
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
[Added x86 subject tag]
[ Upstream commit 1e6e57d9b34a9075d5f9e2048ea7b09756590d11 ]
Writing the outer loop of an LL/SC sequence using do {...} while
constructs potentially allows the compiler to hoist memory accesses
between the STXR and the branch back to the LDXR. On CPUs that do not
guarantee forward progress of LL/SC loops when faced with memory
accesses to the same ERG (up to 2k) between the failed STXR and the
branch back, we may end up livelocking.
This patch avoids this issue in our percpu atomics by rewriting the
outer loop as part of the LL/SC inline assembly block.
Fixes: f97fc810798c ("arm64: percpu: Implement this_cpu operations")
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
[ Upstream commit d2cf909cda5f8c5609cb7ed6cda816c3e15528c7 ]
If a cxl adapter faults on an invalid address for a kernel context, we
may enter copro_calculate_slb() with a NULL mm pointer (kernel
context) and an effective address which looks like a user
address. Which will cause a crash when dereferencing mm. It is clearly
an AFU bug, but there's no reason to crash either. So return an error,
so that cxl can ack the interrupt with an address error.
Fixes: 73d16a6e0e51 ("powerpc/cell: Move data segment faulting code out of cell platform")
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Acked-by: Ian Munsie <imunsie@au1.ibm.com>
[ Upstream commit 850540351bb1a4fa5f192e5ce55b89928cc57f42 ]
Commit f436b2ac90a0 ("arm64: kernel: fix architected PMU registers
unconditional access") made sure we wouldn't access unimplemented
PMU registers, but also left MDCR_EL2 uninitialized in that case,
leading to trap bits being potentially left set.
Make sure we always write something in that register.
Fixes: f436b2ac90a0 ("arm64: kernel: fix architected PMU registers unconditional access")
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
[ Upstream commit 548acf19234dbda5a52d5a8e7e205af46e9da840 ]
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
[ Upstream commit 8e4b72054f554967827e18be1de0e8122e6efc04 ]
Since commit acb2505d0119 ("openrisc: fix copy_from_user()"),
copy_from_user() returns the number of bytes requested, not the
number of bytes not copied.
Fixes: acb2505d0119 ("openrisc: fix copy_from_user()")
[ Upstream commit 65c0044ca8d7c7bbccae37f0ff2972f0210e9f41 ]
avr32 builds fail with:
arch/avr32/kernel/built-in.o: In function `arch_ptrace':
(.text+0x650): undefined reference to `___copy_from_user'
arch/avr32/kernel/built-in.o:(___ksymtab+___copy_from_user+0x0): undefined
kernel/built-in.o: In function `proc_doulongvec_ms_jiffies_minmax':
(.text+0x5dd8): undefined reference to `___copy_from_user'
kernel/built-in.o: In function `proc_dointvec_minmax_sysadmin':
sysctl.c:(.text+0x6174): undefined reference to `___copy_from_user'
kernel/built-in.o: In function `ptrace_has_cap':
ptrace.c:(.text+0x69c0): undefined reference to `___copy_from_user'
kernel/built-in.o:ptrace.c:(.text+0x6b90): more undefined references to
`___copy_from_user' follow
Fixes: 8630c32275ba ("avr32: fix copy_from_user()")
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
[ Upstream commit 8f46cca1e6c06a058374816887059bcc017b382f ]
This patch fixes the possibility of a deadlock when bringing up
secondary CPUs.
The deadlock occurs because the set_cpu_online() is called before
synchronise_count_slave(). This can cause a deadlock if the boot CPU,
having scheduled another thread, attempts to send an IPI to the
secondary CPU, which it sees has been marked online. The secondary is
blocked in synchronise_count_slave() waiting for the boot CPU to enter
synchronise_count_master(), but the boot cpu is blocked in
smp_call_function_many() waiting for the secondary to respond to it's
IPI request.
Fix this by marking the CPU online in cpu_callin_map and synchronising
counters before declaring the CPU online and calculating the maps for
IPIs.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Reported-by: Justin Chen <justinpopo6@gmail.com>
Tested-by: Justin Chen <justinpopo6@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: stable@vger.kernel.org # v4.1+
Patchwork: https://patchwork.linux-mips.org/patch/14302/
