commit b21ebf2fb4cde1618915a97cc773e287ff49173e upstream.
On i386, there are 2 types of PLTs, PIC and non-PIC. PIE and shared
objects must use PIC PLT. To use PIC PLT, you need to load
_GLOBAL_OFFSET_TABLE_ into EBX first. There is no need for that on
x86-64 since x86-64 uses PC-relative PLT.
On x86-64, for 32-bit PC-relative branches, we can generate PLT32
relocation, instead of PC32 relocation, which can also be used as
a marker for 32-bit PC-relative branches. Linker can always reduce
PLT32 relocation to PC32 if function is defined locally. Local
functions should use PC32 relocation. As far as Linux kernel is
concerned, R_X86_64_PLT32 can be treated the same as R_X86_64_PC32
since Linux kernel doesn't use PLT.
R_X86_64_PLT32 for 32-bit PC-relative branches has been enabled in
binutils master branch which will become binutils 2.31.
[ hjl is working on having better documentation on this all, but a few
more notes from him:
"PLT32 relocation is used as marker for PC-relative branches. Because
of EBX, it looks odd to generate PLT32 relocation on i386 when EBX
doesn't have GOT.
As for symbol resolution, PLT32 and PC32 relocations are almost
interchangeable. But when linker sees PLT32 relocation against a
protected symbol, it can resolved locally at link-time since it is
used on a branch instruction. Linker can't do that for PC32
relocation"
but for the kernel use, the two are basically the same, and this
commit gets things building and working with the current binutils
master - Linus ]
Signed-off-by: H.J. Lu <hjl.tools@gmail.com>
Cc: Matthias Kaehlcke <mka@chromium.org>
commit eda9cec4c9a12208a6f69fbe68f72a6311d50032 upstream.
There have been some cases where external tooling (e.g., kpatch-build)
creates a corrupt relocation which targets the wrong address. This is a
silent failure which can corrupt memory in unexpected places.
On x86, the bytes of data being overwritten by relocations are always
initialized to zero beforehand. Use that knowledge to add sanity checks
to detect such cases before they corrupt memory.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: jeyu@kernel.org
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/37450d6c6225e54db107fba447ce9e56e5f758e9.1509713553.git.jpoimboe@redhat.com
[ Restructured the messages, as it's unclear whether the relocation or the target is corrupted. ]
commit 863204cfdae98626a92535ac928ad79f4d6b74ff upstream.
In configurations without CONFIG_OMAP3 but with secure RAM support,
we now run into a link failure:
arch/arm/mach-omap2/omap-secure.o: In function `omap3_save_secure_ram':
omap-secure.c:(.text+0x130): undefined reference to `save_secure_ram_context'
The omap3_save_secure_ram() function is only called from the OMAP34xx
power management code, so we can simply hide that function in the
appropriate #ifdef.
Fixes: d09220a887f7 ("ARM: OMAP2+: Fix SRAM virt to phys translation for save_secure_ram_context")
Tested-by: Dan Murphy <dmurphy@ti.com>
commit 3010a0663fd949d122eca0561b06b0a9453f7866 upstream.
Paravirt emits indirect calls which get flagged by objtool retpoline
checks, annotate it away because all these indirect calls will be
patched out before we start userspace.
This patching happens through alternative_instructions() ->
apply_paravirt() -> pv_init_ops.patch() which will eventually end up
in paravirt_patch_default(). This function _will_ write direct
alternatives.
Reviewed-by: David Woodhouse <dwmw@amazon.co.uk>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
commit d72f4e29e6d84b7ec02ae93088aa459ac70e733b upstream.
firmware_restrict_branch_speculation_*() recently started using
preempt_enable()/disable(), but those are relatively high level
primitives and cause build failures on some 32-bit builds.
Since we want to keep <asm/nospec-branch.h> low level, convert
them to macros to avoid header hell...
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: arjan.van.de.ven@intel.com
Cc: bp@alien8.de
Cc: dave.hansen@intel.com
Cc: jmattson@google.com
Cc: karahmed@amazon.de
Cc: kvm@vger.kernel.org
Cc: pbonzini@redhat.com
Cc: rkrcmar@redhat.com
commit bd89004f6305cbf7352238f61da093207ee518d6 upstream.
The objtool retpoline validation found this indirect jump. Seeing how
it's on CPU bringup before we run userspace it should be safe, annotate
it.
commit 9e0e3c5130e949c389caabc8033e9799b129e429 upstream.
Annotate the indirect calls/jumps in the CALL_NOSPEC/JUMP_NOSPEC
alternatives.
commit 87358710c1fb4f1bf96bbe2349975ff9953fc9b2 upstream.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: bp@alien8.de
Link: http://lkml.kernel.org/r/1519037457-7643-5-git-send-email-dwmw@amazon.co.uk
commit dd84441a797150dcc49298ec95c459a8891d8bb1 upstream.
Retpoline means the kernel is safe because it has no indirect branches.
But firmware isn't, so use IBRS for firmware calls if it's available.
Block preemption while IBRS is set, although in practice the call sites
already had to be doing that.
Ignore hpwdt.c for now. It's taking spinlocks and calling into firmware
code, from an NMI handler. I don't want to touch that with a bargepole.
Cc: bp@alien8.de
Link: http://lkml.kernel.org/r/1519037457-7643-2-git-send-email-dwmw@amazon.co.uk
commit d1c99108af3c5992640aa2afa7d2e88c3775c06e upstream.
This reverts commit 1dde7415e99933bb7293d6b2843752cbdb43ec11. By putting
the RSB filling out of line and calling it, we waste one RSB slot for
returning from the function itself, which means one fewer actual function
call we can make if we're doing the Skylake abomination of call-depth
counting.
It also changed the number of RSB stuffings we do on vmexit from 32,
which was correct, to 16. Let's just stop with the bikeshedding; it
didn't actually *fix* anything anyway.
Cc: bp@alien8.de
Link: http://lkml.kernel.org/r/1519037457-7643-4-git-send-email-dwmw@amazon.co.uk
commit 36268223c1e9981d6cfc33aff8520b3bde4b8114 upstream.
As:
1) It's known that hypervisors lie about the environment anyhow (host
mismatch)
2) Even if the hypervisor (Xen, KVM, VMWare, etc) provided a valid
"correct" value, it all gets to be very murky when migration happens
(do you provide the "new" microcode of the machine?).
And in reality the cloud vendors are the ones that should make sure that
the microcode that is running is correct and we should just sing lalalala
and trust them.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Wanpeng Li <kernellwp@gmail.com>
Cc: kvm <kvm@vger.kernel.org>
Cc: Krčmář <rkrcmar@redhat.com>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180226213019.GE9497@char.us.oracle.com
commit b3b7c4795ccab5be71f080774c45bbbcc75c2aaf upstream.
The check_interval file in
/sys/devices/system/machinecheck/machinecheck<cpu number>
directory is a global timer value for MCE polling. If it is changed by one
CPU, mce_restart() broadcasts the event to other CPUs to delete and restart
the MCE polling timer and __mcheck_cpu_init_timer() reinitializes the
mce_timer variable.
If more than one CPU writes a specific value to the check_interval file
concurrently, mce_timer is not protected from such concurrent accesses and
all kinds of explosions happen. Since only root can write to those sysfs
variables, the issue is not a big deal security-wise.
However, concurrent writes to these configuration variables is void of
reason so the proper thing to do is to serialize the access with a mutex.
Boris:
- Make store_int_with_restart() use device_store_ulong() to filter out
negative intervals
- Limit min interval to 1 second
- Correct locking
- Massage commit message
Signed-off-by: Seunghun Han <kkamagui@gmail.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20180302202706.9434-1-kkamagui@gmail.com
commit f07afa0462b76a5b9c4f3a43d5ac24fdb86a90c2 upstream.
Even if we don't have extended SCA support, we can have more than 64 CPUs
if we don't enable any HW features that might use the SCA entries.
Now, this works just fine, but we missed a return, which is why we
would actually store the SCA entries. If we have more than 64 CPUs, this
means writing outside of the basic SCA - bad.
Let's fix this. This allows > 64 CPUs when running nested (under vSIE)
without random crashes.
Fixes: a6940674c384 ("KVM: s390: allow 255 VCPUs when sca entries aren't used")
Reported-by: Christian Borntraeger <borntraeger@de.ibm.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: David Hildenbrand <david@redhat.com>
Message-Id: <20180306132758.21034-1-david@redhat.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 902f4d067a50ccf645a58dd5fb1d113b6e0f9b5b upstream.
The allocation of host_data is not null checked, leading to a null
pointer dereference if the allocation fails. Fix this by adding a null
check and return with -ENOMEM.
Fixes: 64b139f97c01 ("MIPS: OCTEON: irq: add CIB and other fixes")
Acked-by: David Daney <david.daney@cavium.com>
Cc: "Steven J. Hill" <Steven.Hill@cavium.com>
Cc: linux-mips@linux-mips.org
Cc: <stable@vger.kernel.org> # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/18658/
Signed-off-by: James Hogan <jhogan@kernel.org>
commit 1b22b4b28fd5fbc51855219e3238b3ab81da8466 upstream.
Currently there is no null check on a failed allocation of board_data,
and hence a null pointer dereference will occurr. Fix this by checking
for the out of memory null pointer.
Fixes: a7473717483e ("MIPS: ath25: add board configuration detection")
Cc: <stable@vger.kernel.org> # 3.19+
Patchwork: https://patchwork.linux-mips.org/patch/18657/
commit 06a3f0c9f2725f5d7c63c4203839373c9bd00c28 upstream.
Commit a3e6c1eff548 ("MIPS: IRQ: Fix disable_irq on CPU IRQs") fixes an
issue where disable_irq did not actually disable the irq. The bug caused
our IPIs to not be disabled, which actually is the correct behavior.
With the addition of commit a3e6c1eff548 ("MIPS: IRQ: Fix disable_irq on
CPU IRQs"), the IPIs were getting disabled going into suspend, thus
schedule_ipi() was not being called. This caused deadlocks where
schedulable task were not being scheduled and other cpus were waiting
for them to do something.
Add the IRQF_NO_SUSPEND flag so an irq_disable will not be called on the
IPIs during suspend.
Signed-off-by: Justin Chen <justinpopo6@gmail.com>
Fixes: a3e6c1eff548 ("MIPS: IRQ: Fix disabled_irq on CPU IRQs")
Cc: Florian Fainelli <f.fainelli@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/17385/
[jhogan@kernel.org: checkpatch: wrap long lines and fix commit refs]
[ upstream commit d269176e766c71c998cb75b4ea8cbc321cc0019d ]
While working on 16338a9b3ac3 ("bpf, arm64: fix out of bounds access in
tail call") I noticed that ppc64 JIT is partially affected as well. While
the bound checking is correctly performed as unsigned comparison, the
register with the index value however, is never truncated into 32 bit
space, so e.g. a index value of 0x100000000ULL with a map of 1 element
would pass with PPC_CMPLW() whereas we later on continue with the full
64 bit register value. Therefore, as we do in interpreter and other JITs
truncate the value to 32 bit initially in order to fix access.
Fixes: ce0761419fae ("powerpc/bpf: Implement support for tail calls")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Reviewed-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 16338a9b3ac30740d49f5dfed81bac0ffa53b9c7 ]
I recently noticed a crash on arm64 when feeding a bogus index
into BPF tail call helper. The crash would not occur when the
interpreter is used, but only in case of JIT. Output looks as
follows:
[ 347.007486] Unable to handle kernel paging request at virtual address fffb850e96492510
[ 347.043065] [fffb850e96492510] address between user and kernel address ranges
[ 347.050205] Internal error: Oops: 96000004 [#1] SMP
[ 347.190829] x13: 0000000000000000 x12: 0000000000000000
[ 347.196128] x11: fffc047ebe782800 x10: ffff808fd7d0fd10
[ 347.201427] x9 : 0000000000000000 x8 : 0000000000000000
[ 347.206726] x7 : 0000000000000000 x6 : 001c991738000000
[ 347.212025] x5 : 0000000000000018 x4 : 000000000000ba5a
[ 347.217325] x3 : 00000000000329c4 x2 : ffff808fd7cf0500
[ 347.222625] x1 : ffff808fd7d0fc00 x0 : ffff808fd7cf0500
[ 347.227926] Process test_verifier (pid: 4548, stack limit = 0x000000007467fa61)
[ 347.235221] Call trace:
[ 347.237656] 0xffff000002f3a4fc
[ 347.240784] bpf_test_run+0x78/0xf8
[ 347.244260] bpf_prog_test_run_skb+0x148/0x230
[ 347.248694] SyS_bpf+0x77c/0x1110
[ 347.251999] el0_svc_naked+0x30/0x34
[ 347.255564] Code: 9100075a d280220a 8b0a002a d37df04b (f86b694b)
In this case the index used in BPF r3 is the same as in r1
at the time of the call, meaning we fed a pointer as index;
here, it had the value 0xffff808fd7cf0500 which sits in x2.
While I found tail calls to be working in general (also for
hitting the error cases), I noticed the following in the code
emission:
# bpftool p d j i 988
38: ldr w10, [x1,x10]
3c: cmp w2, w10
40: b.ge 0x000000000000007c <-- signed cmp
44: mov x10, #0x20 // #32
48: cmp x26, x10
4c: b.gt 0x000000000000007c
50: add x26, x26, #0x1
54: mov x10, #0x110 // #272
58: add x10, x1, x10
5c: lsl x11, x2, #3
60: ldr x11, [x10,x11] <-- faulting insn (f86b694b)
64: cbz x11, 0x000000000000007c
Meaning, the tests passed because commit ddb55992b04d ("arm64:
bpf: implement bpf_tail_call() helper") was using signed compares
instead of unsigned which as a result had the test wrongly passing.
Change this but also the tail call count test both into unsigned
and cap the index as u32. Latter we did as well in 90caccdd8cc0
("bpf: fix bpf_tail_call() x64 JIT") and is needed in addition here,
too. Tested on HiSilicon Hi1616.
Result after patch:
# bpftool p d j i 268
3c: add w2, w2, #0x0
40: cmp w2, w10
44: b.cs 0x0000000000000080
48: mov x10, #0x20 // #32
4c: cmp x26, x10
50: b.hi 0x0000000000000080
54: add x26, x26, #0x1
58: mov x10, #0x110 // #272
5c: add x10, x1, x10
60: lsl x11, x2, #3
64: ldr x11, [x10,x11]
68: cbz x11, 0x0000000000000080
Fixes: ddb55992b04d ("arm64: bpf: implement bpf_tail_call() helper")
[ upstream commit a493a87f38cfa48caaa95c9347be2d914c6fdf29 ]
Implement a retpoline [0] for the BPF tail call JIT'ing that converts
the indirect jump via jmp %rax that is used to make the long jump into
another JITed BPF image. Since this is subject to speculative execution,
we need to control the transient instruction sequence here as well
when CONFIG_RETPOLINE is set, and direct it into a pause + lfence loop.
The latter aligns also with what gcc / clang emits (e.g. [1]).
JIT dump after patch:
# bpftool p d x i 1
0: (18) r2 = map[id:1]
2: (b7) r3 = 0
3: (85) call bpf_tail_call#12
4: (b7) r0 = 2
5: (95) exit
With CONFIG_RETPOLINE:
# bpftool p d j i 1
33: cmp %edx,0x24(%rsi)
36: jbe 0x0000000000000072 |*
38: mov 0x24(%rbp),%eax
3e: cmp $0x20,%eax
41: ja 0x0000000000000072 |
43: add $0x1,%eax
46: mov %eax,0x24(%rbp)
4c: mov 0x90(%rsi,%rdx,8),%rax
54: test %rax,%rax
57: je 0x0000000000000072 |
59: mov 0x28(%rax),%rax
5d: add $0x25,%rax
61: callq 0x000000000000006d |+
66: pause |
68: lfence |
6b: jmp 0x0000000000000066 |
6d: mov %rax,(%rsp) |
71: retq |
72: mov $0x2,%eax
* relative fall-through jumps in error case
+ retpoline for indirect jump
Without CONFIG_RETPOLINE:
# bpftool p d j i 1
36: jbe 0x0000000000000063 |*
3e: cmp $0x20,%eax
41: ja 0x0000000000000063 |
43: add $0x1,%eax
54: test %rax,%rax
57: je 0x0000000000000063 |
5d: add $0x25,%rax
61: jmpq *%rax |-
63: mov $0x2,%eax
- plain indirect jump as before
[0] https://support.google.com/faqs/answer/7625886
[1] https://github.com/gcc-mirror/gcc/commit/a31e654fa107be968b802786d747e962c2fcdb2b
The backport of upstream commit 45d55e7bac40 ("x86/apic/vector: Fix off by
one in error path") missed to fixup the legacy interrupt data which is not
longer available upstream.
Handle legacy irq data correctly by clearing the legacy storage to prevent
use after free.
Fixes: 7fd133539289 ("x86/apic/vector: Fix off by one in error path") - 4.4.y
Fixes: c557481a9491 ("x86/apic/vector: Fix off by one in error path") - 4.9.y
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 18bf3c3ea8ece8f03b6fc58508f2dfd23c7711c7 upstream.
Flush indirect branches when switching into a process that marked itself
non dumpable. This protects high value processes like gpg better,
without having too high performance overhead.
If done naïvely, we could switch to a kernel idle thread and then back
to the original process, such as:
process A -> idle -> process A
In such scenario, we do not have to do IBPB here even though the process
is non-dumpable, as we are switching back to the same process after a
hiatus.
To avoid the redundant IBPB, which is expensive, we track the last mm
user context ID. The cost is to have an extra u64 mm context id to track
the last mm we were using before switching to the init_mm used by idle.
Avoiding the extra IBPB is probably worth the extra memory for this
common scenario.
For those cases where tlb_defer_switch_to_init_mm() returns true (non
PCID), lazy tlb will defer switch to init_mm, so we will not be changing
the mm for the process A -> idle -> process A switch. So IBPB will be
skipped for this case.
Thanks to the reviewers and Andy Lutomirski for the suggestion of
using ctx_id which got rid of the problem of mm pointer recycling.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: ak@linux.intel.com
Cc: arjan@linux.intel.com
Cc: torvalds@linux-foundation.org
Cc: linux@dominikbrodowski.net
Cc: peterz@infradead.org
Cc: bp@alien8.de
Cc: luto@kernel.org
Link: https://lkml.kernel.org/r/1517263487-3708-1-git-send-email-dwmw@amazon.co.uk
commit f39681ed0f48498b80455095376f11535feea332 upstream.
This adds two new variables to mmu_context_t: ctx_id and tlb_gen.
ctx_id uniquely identifies the mm_struct and will never be reused.
For a given mm_struct (and hence ctx_id), tlb_gen is a monotonic
count of the number of times that a TLB flush has been requested.
The pair (ctx_id, tlb_gen) can be used as an identifier for TLB
flush actions and will be used in subsequent patches to reliably
determine whether all needed TLB flushes have occurred on a given
CPU.
This patch is split out for ease of review. By itself, it has no
real effect other than creating and updating the new variables.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Nadav Amit <nadav.amit@gmail.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/413a91c24dab3ed0caa5f4e4d017d87b0857f920.1498751203.git.luto@kernel.org
commit 74402055a2d3ec998a1ded599e86185a27d9bbf4 upstream.
The pinmuxing was missing for I2C1 which was causing intermittent issues
with the PMIC which is connected to I2C1. The bootloader did not quite
configure the I2C1 either, so when running at 2.6MHz, it was generating
errors at time.
This correctly sets the I2C1 pinmuxing so it can operate at 2.6MHz
Fixes: 687c27676151 ("ARM: dts: Add minimal support for LogicPD Torpedo
DM3730 devkit")
commit 84c7efd607e7fb6933920322086db64654f669b2 upstream.
errors at times.
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730
SOM-LV")
path as unlikely()
commit 946fbbc13dce68902f64515b610eeb2a6c3d7a64 upstream.
vmx_vcpu_run() and svm_vcpu_run() are large functions, and giving
branch hints to the compiler can actually make a substantial cycle
difference by keeping the fast path contiguous in memory.
With this optimization, the retpoline-guest/retpoline-host case is
about 50 cycles faster.
Reviewed-by: Jim Mattson <jmattson@google.com>
Cc: KarimAllah Ahmed <karahmed@amazon.de>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Link: http://lkml.kernel.org/r/20180222154318.20361-3-pbonzini@redhat.com
commit ecb586bd29c99fb4de599dec388658e74388daad upstream.
Having a paravirt indirect call in the IBRS restore path is not a
good idea, since we are trying to protect from speculative execution
of bogus indirect branch targets. It is also slower, so use
native_wrmsrl() on the vmentry path too.
Fixes: d28b387fb74da95d69d2615732f50cceb38e9a4d
Link: http://lkml.kernel.org/r/20180222154318.20361-2-pbonzini@redhat.com
commit 67870eb1204223598ea6d8a4467b482e9f5875b5 upstream.
In banked-sr.c, we use a top-level '__asm__(".arch_extension virt")'
statement to allow compilation of a multi-CPU kernel for ARMv6
and older ARMv7-A that don't normally support access to the banked
registers.
This is considered to be a programming error by the gcc developers
and will no longer work in gcc-8, where we now get a build error:
/tmp/cc4Qy7GR.s:34: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_usr'
/tmp/cc4Qy7GR.s:41: Error: Banked registers are not available with this architecture. -- `mrs r3,ELR_hyp'
/tmp/cc4Qy7GR.s:55: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_svc'
/tmp/cc4Qy7GR.s:62: Error: Banked registers are not available with this architecture. -- `mrs r3,LR_svc'
/tmp/cc4Qy7GR.s:69: Error: Banked registers are not available with this architecture. -- `mrs r3,SPSR_svc'
/tmp/cc4Qy7GR.s:76: Error: Banked registers are not available with this architecture. -- `mrs r3,SP_abt'
Passign the '-march-armv7ve' flag to gcc works, and is ok here, because
we know the functions won't ever be called on pre-ARMv7VE machines.
Unfortunately, older compiler versions (4.8 and earlier) do not understand
that flag, so we still need to keep the asm around.
Backporting to stable kernels (4.6+) is needed to allow those to be built
with future compilers as well.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=84129
Fixes: 33280b4cd1dc ("ARM: KVM: Add banked registers save/restore")
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 8aa36a8dcde3183d84db7b0d622ffddcebb61077 upstream.
The MACH_ARMADA_375 and MACH_ARMADA_38X boards select ARM_ERRATA_753970,
but it was renamed to PL310_ERRATA_753970 by commit fa0ce4035d48 ("ARM:
7162/1: errata: tidy up Kconfig options for PL310 errata workarounds").
Fix the selects to use the new name.
Discovered with the
https://github.com/ulfalizer/Kconfiglib/blob/master/examples/list_undefined.py
script.
Fixes: fa0ce4035d48 ("ARM: 7162/1: errata: tidy up Kconfig options for
cc: stable@vger.kernel.org
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
commit 028091f82eefd5e84f81cef81a7673016ecbe78b upstream.
When the Intel Edison module is powered with 3.3V, the reboot command makes
the module stuck. If the module is powered at a greater voltage, like 4.4V
(as the Edison Mini Breakout board does), reboot works OK.
The official Intel Edison BSP sends the IPCMSG_COLD_RESET message to the
SCU by default. The IPCMSG_COLD_BOOT which is used by the upstream kernel
is only sent when explicitely selected on the kernel command line.
Use IPCMSG_COLD_RESET unconditionally which makes reboot work independent
of the power supply voltage.
[ tglx: Massaged changelog ]
Fixes: bda7b072de99 ("x86/platform/intel-mid: Implement power off sequence")
Signed-off-by: Sebastian Panceac <sebastian@resin.io>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Link: https://lkml.kernel.org/r/1519810849-15131-1-git-send-email-sebastian@resin.io
commit 71c208dd54ab971036d83ff6d9837bae4976e623 upstream.
Older Xen versions (4.5 and before) might have problems migrating pv
guests with MSR_IA32_SPEC_CTRL having a non-zero value. So before
suspending zero that MSR and restore it after being resumed.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Jan Beulich <jbeulich@suse.com>
Cc: xen-devel@lists.xenproject.org
Cc: boris.ostrovsky@oracle.com
Link: https://lkml.kernel.org/r/20180226140818.4849-1-jgross@suse.com
commit 0adb24e03a124b79130c9499731936b11ce2677d upstream.
The change to flush_kernel_vmap_range() wasn't sufficient to avoid the
SMP stalls. The problem is some drivers call these routines with
interrupts disabled. Interrupts need to be enabled for flush_tlb_all()
and flush_cache_all() to work. This version adds checks to ensure
interrupts are not disabled before calling routines that need IPI
interrupts. When interrupts are disabled, we now drop into slower code.
The attached change fixes the ordering of cache and TLB flushes in
several cases. When we flush the cache using the existing PTE/TLB
entries, we need to flush the TLB after doing the cache flush. We don't
need to do this when we flush the entire instruction and data caches as
these flushes don't use the existing TLB entries. The same is true for
tmpalias region flushes.
The flush_kernel_vmap_range() and invalidate_kernel_vmap_range()
routines have been updated.
Secondly, we added a new purge_kernel_dcache_range_asm() routine to
pacache.S and use it in invalidate_kernel_vmap_range(). Nominally,
purges are faster than flushes as the cache lines don't have to be
written back to memory.
Hopefully, this is sufficient to resolve the remaining problems due to
cache speculation. So far, testing indicates that this is the case. I
did work up a patch using tmpalias flushes, but there is a performance
hit because we need the physical address for each page, and we also need
to sequence access to the tmpalias flush code. This increases the
probability of stalls.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # 4.9+
Signed-off-by: Helge Deller <deller@gmx.de>
commit ebabcf17bcd7ce968b1631ebe08236275698f39b upstream.
GCC7 is a bit too eager to generate suboptimal __multi3 calls (128bit
multiply with 128bit result) for MIPS64r6 builds, even in code which
doesn't explicitly use 128bit types, such as the following:
unsigned long func(unsigned long a, unsigned long b)
return a > (~0UL) / b;
Which GCC rearanges to:
return (unsigned __int128)a * (unsigned __int128)b > 0xffffffffffffffff;
Therefore implement __multi3, but only for MIPS64r6 with GCC7 as under
normal circumstances we wouldn't expect any calls to __multi3 to be
generated from kernel code.
Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Tested-by: Waldemar Brodkorb <wbx@openadk.org>
Cc: Maciej W. Rozycki <macro@mips.com>
Cc: Matthew Fortune <matthew.fortune@mips.com>
Cc: Florian Fainelli <florian@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/17890/
Commit 45ee9d5e97a4 ("KVM: arm/arm64: Check pagesize when allocating a
hugepage at Stage 2") lost the check for PMD_SIZE during the backport
to 4.9.
Fix this by correcting the condition to detect hugepages during stage
2 allocation.
Fixes: 45ee9d5e97a4 ("KVM: arm/arm64: Check pagesize when allocating a hugepage at Stage 2")
Reported-by: Ioana Ciornei <ioana.ciornei@nxp.com>
Signed-off-by: Punit Agrawal <punit.agrawal@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
[ Upstream commit 195e2addbce09e5afbc766efc1e6567c9ce840d3 ]
The 'sh_eth' driver's probe() method would fail on the SolutionEngine7710
board and crash on SolutionEngine7712 board as the platform code is
hopelessly behind the driver's platform data -- it passes the PHY address
instead of 'struct sh_eth_plat_data *'; pass the latter to the driver in
order to fix the bug...
Fixes: 71557a37adb5 ("[netdrvr] sh_eth: Add SH7619 support")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 506e8a912661c97b41adc8a286b875d01323ec45 ]
dtc warns about two 'clocks' properties that have an extraneous '1'
at the end:
arch/arm/boot/dts/ls1021a-qds.dtb: Warning (clocks_property): arch/arm/boot/dts/ls1021a-twr.dtb: Warning (clocks_property): Property 'clocks', cell 1 is not a phandle reference in /soc/i2c@2180000/mux@77/i2c@4/sgtl5000@2a
arch/arm/boot/dts/ls1021a-qds.dtb: Warning (clocks_property): Missing property '#clock-cells' in node /soc/interrupt-controller@1400000 or bad phandle (referred from /soc/i2c@2180000/mux@77/i2c@4/sgtl5000@2a:clocks[1])
Property 'clocks', cell 1 is not a phandle reference in /soc/i2c@2190000/sgtl5000@a
arch/arm/boot/dts/ls1021a-twr.dtb: Warning (clocks_property): Missing property '#clock-cells' in node /soc/interrupt-controller@1400000 or bad phandle (referred from /soc/i2c@2190000/sgtl5000@a:clocks[1])
The clocks that get referenced here are fixed-rate, so they do not
take any argument, and dtc interprets the next cell as a phandle, which
is invalid.
[ Upstream commit ca26cffa4e4aaeb09bb9e308f95c7835cb149248 ]
Up to f5caf621ee35 ("x86/asm: Fix inline asm call constraints for Clang")
we were able to use x86 headers to build to the 'bpf' clang target, as
done by the BPF code in tools/perf/.
With that commit, we ended up with following failure for 'perf test LLVM', this
is because "clang ... -target bpf ..." fails since 4.0 does not have bpf inline
asm support and 6.0 does not recognize the register 'esp', fix it by guarding
that part with an #ifndef __BPF__, that is defined by clang when building to
the "bpf" target.
# perf test -v LLVM
37: LLVM search and compile :
37.1: Basic BPF llvm compile :
--- start ---
test child forked, pid 25526
Kernel build dir is set to /lib/modules/4.14.0+/build
set env: KBUILD_DIR=/lib/modules/4.14.0+/build
unset env: KBUILD_OPTS
include option is set to -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/7/include -I/home/acme/git/linux/arch/x86/include -I./arch/x86/include/generated -I/home/acme/git/linux/include -I./include -I/home/acme/git/linux/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/home/acme/git/linux/include/uapi -I./include/generated/uapi -include /home/acme/git/linux/include/linux/kconfig.h
set env: NR_CPUS=4
set env: LINUX_VERSION_CODE=0x40e00
set env: CLANG_EXEC=/usr/local/bin/clang
set env: CLANG_OPTIONS=-xc
set env: KERNEL_INC_OPTIONS= -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/7/include -I/home/acme/git/linux/arch/x86/include -I./arch/x86/include/generated -I/home/acme/git/linux/include -I./include -I/home/acme/git/linux/arch/x86/include/uapi -I./arch/x86/include/generated/uapi -I/home/acme/git/linux/include/uapi -I./include/generated/uapi -include /home/acme/git/linux/include/linux/kconfig.h
set env: WORKING_DIR=/lib/modules/4.14.0+/build
set env: CLANG_SOURCE=-
llvm compiling command template: echo '/*
* bpf-script-example.c
* Test basic LLVM building
#ifndef LINUX_VERSION_CODE
# error Need LINUX_VERSION_CODE
# error Example: for 4.2 kernel, put 'clang-opt="-DLINUX_VERSION_CODE=0x40200" into llvm section of ~/.perfconfig'
#endif
#define BPF_ANY 0
#define BPF_MAP_TYPE_ARRAY 2
#define BPF_FUNC_map_lookup_elem 1
#define BPF_FUNC_map_update_elem 2
static void *(*bpf_map_lookup_elem)(void *map, void *key) =
(void *) BPF_FUNC_map_lookup_elem;
static void *(*bpf_map_update_elem)(void *map, void *key, void *value, int flags) =
(void *) BPF_FUNC_map_update_elem;
struct bpf_map_def {
unsigned int type;
unsigned int key_size;
unsigned int value_size;
unsigned int max_entries;
#define SEC(NAME) __attribute__((section(NAME), used))
struct bpf_map_def SEC("maps") flip_table = {
.type = BPF_MAP_TYPE_ARRAY,
.key_size = sizeof(int),
.value_size = sizeof(int),
.max_entries = 1,
SEC("func=SyS_epoll_wait")
int bpf_func__SyS_epoll_wait(void *ctx)
int ind =0;
int *flag = bpf_map_lookup_elem(&flip_table, &ind);
int new_flag;
if (!flag)
return 0;
/* flip flag and store back */
new_flag = !*flag;
bpf_map_update_elem(&flip_table, &ind, &new_flag, BPF_ANY);
return new_flag;
char _license[] SEC("license") = "GPL";
int _version SEC("version") = LINUX_VERSION_CODE;
' | $CLANG_EXEC -D__KERNEL__ -D__NR_CPUS__=$NR_CPUS -DLINUX_VERSION_CODE=$LINUX_VERSION_CODE $CLANG_OPTIONS $KERNEL_INC_OPTIONS -Wno-unused-value -Wno-pointer-sign -working-directory $WORKING_DIR -c "$CLANG_SOURCE" -target bpf -O2 -o -
test child finished with 0
---- end ----
LLVM search and compile subtest 0: Ok
37.2: kbuild searching :
--- start ---
test child forked, pid 25950
set env: NR_CPUS=4
* bpf-script-test-kbuild.c
* Test include from kernel header
#endif
#include <uapi/linux/fs.h>
#include <uapi/asm/ptrace.h>
SEC("func=vfs_llseek")
int bpf_func__vfs_llseek(void *ctx)
return 0;
In file included from <stdin>:12:
In file included from /home/acme/git/linux/arch/x86/include/uapi/asm/ptrace.h:5:
In file included from /home/acme/git/linux/include/linux/compiler.h:242:
In file included from /home/acme/git/linux/arch/x86/include/asm/barrier.h:5:
In file included from /home/acme/git/linux/arch/x86/include/asm/alternative.h:10:
/home/acme/git/linux/arch/x86/include/asm/asm.h:145:50: error: unknown register name 'esp' in asm
register unsigned long current_stack_pointer asm(_ASM_SP);
/home/acme/git/linux/arch/x86/include/asm/asm.h:44:18: note: expanded from macro '_ASM_SP'
#define _ASM_SP __ASM_REG(sp)
/home/acme/git/linux/arch/x86/include/asm/asm.h:27:32: note: expanded from macro '__ASM_REG'
#define __ASM_REG(reg) __ASM_SEL_RAW(e##reg, r##reg)
/home/acme/git/linux/arch/x86/include/asm/asm.h:18:29: note: expanded from macro '__ASM_SEL_RAW'
# define __ASM_SEL_RAW(a,b) __ASM_FORM_RAW(a)
/home/acme/git/linux/arch/x86/include/asm/asm.h:11:32: note: expanded from macro '__ASM_FORM_RAW'
# define __ASM_FORM_RAW(x) #x
<scratch space>:4:1: note: expanded from here
"esp"
1 error generated.
ERROR: unable to compile -
Hint: Check error message shown above.
Hint: You can also pre-compile it into .o using:
clang -target bpf -O2 -c -
with proper -I and -D options.
Failed to compile test case: 'kbuild searching'
test child finished with -1
---- end ----
LLVM search and compile subtest 1: FAILED!
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: David Ahern <dsahern@gmail.com>
Cc: Dmitriy Vyukov <dvyukov@google.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Miguel Bernal Marin <miguel.bernal.marin@linux.intel.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Cc: Yonghong Song <yhs@fb.com>
Link: https://lkml.kernel.org/r/20171128175948.GL3298@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 36b0cb84ee858f02c256d26f0cb4229c78e3399e ]
An additional 'ip' will be pushed to the stack, for restoring the
DACR later, if CONFIG_CPU_SW_DOMAIN_PAN defined.
However, the fixup still get the err_ptr by add #8*4 to sp, which
results in the fact that the code area pointed by the LR will be
overwritten, or the kernel will crash if CONFIG_DEBUG_RODATA is enabled.
This patch fixes the stack mismatch.
Fixes: a5e090acbf54 ("ARM: software-based priviledged-no-access support")
Signed-off-by: Lvqiang Huang <Lvqiang.Huang@spreadtrum.com>
Signed-off-by: Chunyan Zhang <zhang.lyra@gmail.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
speculation attack surface
commit 8e1eb3fa009aa7c0b944b3c8b26b07de0efb3200 upstream.
At entry userspace may have (maliciously) populated the extra registers
outside the syscall calling convention with arbitrary values that could
be useful in a speculative execution (Spectre style) attack.
Clear these registers to minimize the kernel's attack surface.
Note, this only clears the extra registers and not the unused
registers for syscalls less than 6 arguments, since those registers are
likely to be clobbered well before their values could be put to use
under speculation.
Note, Linus found that the XOR instructions can be executed with
minimized cost if interleaved with the PUSH instructions, and Ingo's
analysis found that R10 and R11 should be included in the register
clearing beyond the typical 'extra' syscall calling convention
registers.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Reported-by: Andi Kleen <ak@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/151787988577.7847.16733592218894189003.stgit@dwillia2-desk3.amr.corp.intel.com
[ Made small improvements to the changelog and the code comments. ]
commit 5ee39a71fd89ab7240c5339d04161c44a8e03269 upstream.
aarch64 unhandled signal kernel messages are very verbose, suggesting
them to be more of a debugging aid:
sigsegv[33]: unhandled level 2 translation fault (11) at 0x00000000, esr
0x92000046, in sigsegv[400000+71000]
CPU: 1 PID: 33 Comm: sigsegv Tainted: G W 4.15.0-rc3+ #3
Hardware name: linux,dummy-virt (DT)
pstate: 60000000 (nZCv daif -PAN -UAO)
pc : 0x4003f4
lr : 0x4006bc
sp : 0000fffffe94a060
x29: 0000fffffe94a070 x28: 0000000000000000
x27: 0000000000000000 x26: 0000000000000000
x25: 0000000000000000 x24: 00000000004001b0
x23: 0000000000486ac8 x22: 00000000004001c8
x21: 0000000000000000 x20: 0000000000400be8
x19: 0000000000400b30 x18: 0000000000484728
x17: 000000000865ffc8 x16: 000000000000270f
x15: 00000000000000b0 x14: 0000000000000002
x13: 0000000000000001 x12: 0000000000000000
x11: 0000000000000000 x10: 0008000020008008
x9 : 000000000000000f x8 : ffffffffffffffff
x7 : 0004000000000000 x6 : ffffffffffffffff
x5 : 0000000000000000 x4 : 0000000000000000
x3 : 00000000004003e4 x2 : 0000fffffe94a1e8
x1 : 000000000000000a x0 : 0000000000000000
Disable them by default, so they can be enabled using
/proc/sys/debug/exception-trace.
Signed-off-by: Michael Weiser <michael.weiser@gmx.de>
commit 85c615eb52222bc5fab6c7190d146bc59fac289e upstream.
GCC-8 shows a warning for the x86 oprofile code that copies per-CPU
data from CPU 0 to all other CPUs, which when building a non-SMP
kernel turns into a memcpy() with identical source and destination
pointers:
arch/x86/oprofile/nmi_int.c: In function 'mux_clone':
arch/x86/oprofile/nmi_int.c:285:2: error: 'memcpy' source argument is the same as destination [-Werror=restrict]
memcpy(per_cpu(cpu_msrs, cpu).multiplex,
per_cpu(cpu_msrs, 0).multiplex,
sizeof(struct op_msr) * model->num_virt_counters);
arch/x86/oprofile/nmi_int.c: In function 'nmi_setup':
arch/x86/oprofile/nmi_int.c:466:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict]
arch/x86/oprofile/nmi_int.c:470:3: error: 'memcpy' source argument is the same as destination [-Werror=restrict]
I have analyzed a number of such warnings now: some are valid and the
GCC warning is welcome. Others turned out to be false-positives, and
GCC was changed to not warn about those any more. This is a corner case
that is a false-positive but the GCC developers feel it's better to keep
warning about it.
In this case, it seems best to work around it by telling GCC
a little more clearly that this code path is never hit with
an IS_ENABLED() configuration check.
Cc:stable as we also want old kernels to build cleanly with GCC-8.
Cc: Jessica Yu <jeyu@kernel.org>
Cc: Martin Sebor <msebor@gcc.gnu.org>
Cc: Robert Richter <rric@kernel.org>
Cc: oprofile-list@lists.sf.net
Link: http://lkml.kernel.org/r/20180220205826.2008875-1-arnd@arndb.de
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=84095
commit 6ac5a11dc674bc5016ea716e8082fff61f524dc1 upstream.
Xtensa memory initialization code frees high memory pages without
checking whether they are in the reserved memory regions or not. That
results in invalid value of totalram_pages and duplicate page usage by
CMA and highmem. It produces a bunch of BUGs at startup looking like
this:
BUG: Bad page state in process swapper pfn:70800
page:be60c000 count:0 mapcount:-127 mapping: (null) index:0x1
flags: 0x80000000()
raw: 80000000 00000000 00000001 ffffff80 00000000 be60c014 be60c014 0000000a
page dumped because: nonzero mapcount
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Tainted: G B 4.16.0-rc1-00015-g7928b2cbe55b-dirty #23
Stack:
bd839d33 00000000 00000018 ba97b64c a106578c bd839d70 be60c000 00000000
a1378054 bd86a000 00000003 ba97b64c a1066166 bd839da0 be60c000 ffe00000
a1066b58 bd839dc0 be504000 00000000 000002f4 bd838000 00000000 0000001e
Call Trace:
[<a1065734>] bad_page+0xac/0xd0
[<a106578c>] free_pages_check_bad+0x34/0x4c
[<a1066166>] __free_pages_ok+0xae/0x14c
[<a1066b58>] __free_pages+0x30/0x64
[<a1365de5>] init_cma_reserved_pageblock+0x35/0x44
[<a13682dc>] cma_init_reserved_areas+0xf4/0x148
[<a10034b8>] do_one_initcall+0x80/0xf8
[<a1361c16>] kernel_init_freeable+0xda/0x13c
[<a125b59d>] kernel_init+0x9/0xd0
[<a1004304>] ret_from_kernel_thread+0xc/0x18
Only free high memory pages that are not reserved.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit bcdde302b8268ef7dbc4ddbdaffb5b44eafe9a1e upstream
- Expose all invalidation types to the L1
- Reject invvpid instruction, if L1 passed zero vpid value to single
context invalidations
Signed-off-by: Jan Dakinevich <jan.dakinevich@gmail.com>
Tested-by: Ladi Prosek <lprosek@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[jwang: port to 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit 63f3ac48133a19110c8a3666028dbd9b1bf3dcb3 upstream
- Remove VMX_EPT_EXTENT_INDIVIDUAL_ADDR, since there is no such type of
EPT invalidation
- Add missing VPID types names
exceptions simultaneously
commit 9a6e7c39810e4a8bc7fc95056cefb40583fe07ef upstream.
qemu-system-x86-8600 [004] d..1 7205.687530: kvm_entry: vcpu 2
qemu-system-x86-8600 [004] .... 7205.687532: kvm_exit: reason EXCEPTION_NMI rip 0xffffffffa921297d info ffffeb2c0e44e018 80000b0e
qemu-system-x86-8600 [004] .... 7205.687532: kvm_page_fault: address ffffeb2c0e44e018 error_code 0
qemu-system-x86-8600 [004] .... 7205.687620: kvm_try_async_get_page: gva = 0xffffeb2c0e44e018, gfn = 0x427e4e
qemu-system-x86-8600 [004] .N.. 7205.687628: kvm_async_pf_not_present: token 0x8b002 gva 0xffffeb2c0e44e018
kworker/4:2-7814 [004] .... 7205.687655: kvm_async_pf_completed: gva 0xffffeb2c0e44e018 address 0x7fcc30c4e000
qemu-system-x86-8600 [004] .... 7205.687703: kvm_async_pf_ready: token 0x8b002 gva 0xffffeb2c0e44e018
qemu-system-x86-8600 [004] d..1 7205.687711: kvm_entry: vcpu 2
After running some memory intensive workload in guest, I catch the kworker
which completes the GUP too quickly, and queues an "Page Ready" #PF exception
after the "Page not Present" exception before the next vmentry as the above
trace which will result in #DF injected to guest.
This patch fixes it by clearing the queue for "Page not Present" if "Page Ready"
occurs before the next vmentry since the GUP has already got the required page
and shadow page table has already been fixed by "Page Ready" handler.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Fixes: 7c90705bf2a3 ("KVM: Inject asynchronous page fault into a PV guest if page is swapped out.")
[Changed indentation and added clearing of injected. - Radim]
[port from upstream v4.14-rc1, Don't assign to kvm_queued_exception::injected or
x86_exception::async_page_fault]
preemptibility bug
commit dac6ca243c4c49a9ca7507d3d66140ebfac8b04b upstream.
With CONFIG_DEBUG_PREEMPT enabled, I get:
BUG: using smp_processor_id() in preemptible [00000000] code: swapper/0/1
caller is debug_smp_processor_id
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.12.0-rc2+ #2
Call Trace:
dump_stack
check_preemption_disabled
save_microcode_in_initrd_amd
? microcode_init
because, well, it says it above, we're using smp_processor_id() in
preemptible code.
But passing the CPU number is not really needed. It is only used to
determine whether we're on the BSP, and, if so, to save the microcode
patch for early loading.
[ We don't absolutely need to do it on the BSP but we do that
customarily there. ]
Instead, convert that function parameter to a boolean which denotes
whether the patch should be saved or not, thereby avoiding the use of
smp_processor_id() in preemptible code.
Link: http://lkml.kernel.org/r/20170528200414.31305-1-bp@alien8.de
[arnd: rebased to 4.9, after running into warning:
arch/x86/kernel/cpu/microcode/amd.c:881:30: self-comparison always evaluates to true]
commit 12f043ff2b28fa64c9123b454cbe30a8a9e1967e upstream.
With 4 levels of 16KB pages, we get this warning about the fact that we are
copying a whole page into an array that is declared as having only two pointers
for the top level of the page table:
arch/arm64/mm/mmu.c: In function 'paging_init':
arch/arm64/mm/mmu.c:528:2: error: 'memcpy' writing 16384 bytes into a region of size 16 overflows the destination [-Werror=stringop-overflow=]
This is harmless since we actually reserve a whole page in the definition of the
array that comes from, and just the extern declaration is short. The pgdir
is initialized to zero either way, so copying the actual entries here seems
like the best solution.
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
[slightly adapted to apply on 4.9]
commit 900a9020af7a023f9b64c919fddf8a7486108962 upstream.
The sunxi clk driver causes a link error when the reset controller
subsystem is disabled:
drivers/clk/built-in.o: In function `sun4i_ve_clk_setup':
:(.init.text+0xd040): undefined reference to `reset_controller_register'
drivers/clk/built-in.o: In function `sun4i_a10_display_init':
:(.init.text+0xe5e0): undefined reference to `reset_controller_register'
drivers/clk/built-in.o: In function `sunxi_usb_clk_setup':
:(.init.text+0x10074): undefined reference to `reset_controller_register'
We already force it to be enabled on arm32 and some other arm64 platforms,
but not on arm64/sunxi. This adds the respective Kconfig statements to
also select it here.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[arnd: manually rebased to 4.9]
commit e42eef4ba38806b18c4a74f0c276fb2e0b548173 upstream.
The rework of the posted interrupt handling broke building without
support for the local APIC:
ERROR: "boot_cpu_physical_apicid" [arch/x86/kvm/kvm-intel.ko] undefined!
That configuration is probably not particularly useful anyway, so
we can avoid the randconfig failures by adding a Kconfig dependency.
Fixes: 8b306e2f3c41 ("KVM: VMX: avoid double list add with VT-d posted interrupts")
commit 2e449048a25eb75d48dff12882b93f26d130a1c6 upstream.
Fix warning:
"(COMPAT) selects COMPAT_BINFMT_ELF which has unmet direct dependencies
(COMPAT && BINFMT_ELF)"
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
commit 3ba5b5ea7dc3a10ef50819b43a9f8de2705f4eec upstream.
GCC complains about unused variable 'vma' in mark_screen_rdonly() if THP is
disabled:
arch/x86/kernel/vm86_32.c: In function ‘mark_screen_rdonly’:
arch/x86/kernel/vm86_32.c:180:26: warning: unused variable ‘vma’
[-Wunused-variable]
struct vm_area_struct *vma = find_vma(mm, 0xA0000);
That's silly. pmd_trans_huge() resolves to 0 when THP is disabled, so the
whole block should be eliminated.
Moving the variable declaration outside the if() block shuts GCC up.
Reported-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Tested-by: Borislav Petkov <bp@suse.de>
Cc: Carlos O'Donell <carlos@redhat.com>
Link: http://lkml.kernel.org/r/20170213125228.63645-1-kirill.shutemov@linux.intel.com
