Basically, this extends original dp264 fixup to all dp264 variations.
Here is one minor change: mask out bits 4-7 of a value assigned by SRM,
because
- newer consoles report ISA IRQs with offset 0xe0;
- even if console IRQ value is bogus, we'll have a value < 16
so it should be harmless as it won't clash with native IRQs.
Particularly this fixes USB interrupt problem on xp1000 and es40.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Richard Henderson <rth@twiddle.net>
Fix:
arch/arm/mach-sa1100/generic.c:224: warning: 'struct mcp_plat_data' declared inside parameter list
caused by mussing structure and function declaration.
Newer binutils complains:
/tmp/cc07pbI9.s:146: Warning: ignoring changed section type for .sched.text
Fix this warning by adding %progbits to the .section.
Patch from Deepak Saxena
Building a kernel for IXDP425 currently includes the machine descriptors
for IXDP465 and PRPMC1100 even if those machines are not configured.
This means we can build a kernel that boots on those machines even
though the machine_is_xxx() macro will always return 0 and other bits
such as PCI won't be compiled in. This can lead to many wasted hours
wondering what you have done to your kernel to make it randomly crash
thus requireing large quantities of beer to be consumed. While I am
all for consumption of large quantities of beer, there are better
reasons to do so then stupid kernel bugs.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
They seem to have been due to AMD errata 63/122; the fix is to disable
TLB flush filtering in SMP configurations.
Confirmed to fix the problem by Andrew Walrond <andrew@walrond.org>
[ Let's see if we'll have a better fix eventually, this is the Q&D
"let's get this fixed and out there" version ]
With the new fdtable locking rules, you have to protect fdtable with either
->file_lock or rcu_read_lock/unlock(). There are some places where we
aren't doing either. This patch fixes those places.
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Using native cmpxchg offers a slight performance improvement in uml/i386.
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Added ppc_sys device and system definitions for PowerQUICC I devices. This
will allow drivers for PQI to be proper platform device drivers. Currently
sys section contains only MPC885 and MPC866. Identification should be done
with identify_ppc_sys_by_name call, with board-specific "name" string
passed, since PQI do not have any register that could identify the SOC.
Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
Signed-off-by: Marcelo Tosatti <marcelo.tosatti@cyclades.com>
I forgot to include siginfo.h when I added data breakpoint support. We
must include it in a round-a-bout way in mainline.
For EXPORT_SYMBOL.
Cc: Andi Kleen <ak@muc.de>
Fix up some pm_message_t types
Signed-Off-By: Richard Purdie <rpurdie@rpsys.net>
asm/elf.h is bad on x86_64, and i386 doesn't need it any more after Al's
cleanup.
Cc: Paolo Giarrusso <blaisorblade@yahoo.it>
do_aio used to return -1 on error instead of errno.
The serial UML OS-abstraction layer patch (um/kernel dir).
This joins mem_user.c and mem.c files.
Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com>
This moves all system calls from mem_user.c and tempfile.c files under
os-Linux dir.
The poster child for this patch is the third tuntap_user hunk. When an ioctl
fails, it properly closes the opened file descriptor and returns. However,
the close resets errno to 0, and the 'return errno' that follows returns 0
rather than the value that ioctl set. This caused the caller to believe that
the device open succeeded and had opened file descriptor 0, which caused no
end of interesting behavior.
The rest of this patch is a pass through the UML sources looking for places
where errno could be reset before being passed back out. A common culprit is
printk, which could call write, being called before errno is returned.
In some cases, where the code ends up being much smaller, I just deleted the
printk.
There was another case where a caller of run_helper looked at errno after a
failure, rather than the return value of run_helper, which was the errno value
that it wanted.
These ugly double-casts are the result of gdb complaining about size
linux/inet.h isn't needed, and on my system, is empty.
This removes a file which is no longer used.
This patch implements a stack trace for a thread, not unlike sysrq-t does.
The advantage to this is that a break point can be placed on showreqs, so that
upon showing the stack, you jump immediately into the debugger. While sysrq-t
does the same thing, sysrq-t shows *all* threads stacks. It also doesn't work
right now. In the future, I thought it might be acceptable to make this show
all pids stacks, but perhaps leaving well enough alone and just using sysrq-t
would be okay. For now, upon receiving the stack command, UML switches
context to that thread, dumps its registers, and then switches context back to
the original thread. Since UML compacts all threads into one of 4 host
threads, this sort of mechanism could be expanded in the future to include
other debugging helpers that sysrq does not cover.
Note by jdike - The main benefit to this is that it brings an arbitrary thread
back into context, where it can be examined by gdb. The fact that it dumps it
stack is secondary. This provides the capability to examine a sleeping
thread, which has existed in tt mode, but not in skas mode until now.
Also, the other threads, that sysrq doesn't cover, can be gdb-ed directly
anyway.
Signed-off-by: Allan Graves<allan.graves@gmail.com>
This patch moves code that is in both switch_to_tt and switch_to_skas to the
top level _switch_to function, keeping us from duplicating code. It is
required for the stack trace patch to work properly.
Signed-off-by: Allan Graves <allan.graves@gmail.com>
When an asynchronous interruption occurs during the execution of the
'critical section' within the generic interruption handling code (entry.S),
a faulty check for a userspace PSW may result in a corrupted kernel stack
pointer which subsequently triggers a stack overflow check.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Remove nowhere referenced file (egrep "hw-bse\." didn't find anything).
Signed-off-by: Domen Puncer <domen@coderock.org>
Acked-by: Ian Molton <spyro@f2s.com>
Add code to support the re-IPL method using diagnose 0x308.
Disable preemption in show_cpuinfo to avoid problems and the warning about
smp_processor_id.
Update default configuration of s390.
master.kernel.org:/pub/scm/linux/kernel/git/aegl/linux-2.6
There were some trailing white spaces, long lines, brackets in
weird style etc. This patch cleans them up.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
This patch removes some compilation warnings, mostly
trivially. acpi.c fix also noted by Kenji Kaneshige.
Signed-off-by; Peter Chubb <peterc@gelato.unsw.edu.au>
As noted by Olof Johansson <olof@lixom.net>:
"A recent patch changed the way the LPAR bit is checked during early
boot. This resulted in a polarity change in a conditional branch
without changing the branch, causing at least some legacy machines to
not boot."
This fixes it.
Signed-off-by: Jimi Xenidis <jimix@watson.ibm.com>
Patch from Richard Purdie
This patch adds MMC and UDC support to the PXA Poodle platform.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
This patch cleans up the PXA Poodle platform code removing an unneeded
static iomap. It also corrects errors in the platform header file and
adds a missing GPIO define.
This patch cleans up the PXA Corgi platform code removing an unneeded
static iomap, an unneeded function and some debug messages.
This patch adds a missing parameter to the scoop calls made by collie.c
Patch from Lennert Buytenhek
It's silly to have I2C enabled in all ixp2000 defconfigs but not to
have the ixp2000 bus driver enabled in any of them. This patch enables
CONFIG_I2C_IXP2000 for all in-tree ixp2000 boards.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Several implementations were essentialy a common piece of C code using
the cmpxchg() macro. Put the implementation in one spot that everyone
can share, and convert sparc64 over to using this.
Alpha is the lone arch-specific implementation, which codes up a
special fast path for the common case in order to avoid GP reloading
which a pure C version would require.
Commit 66759a01adbfe8828dd063e32cf5ed3f46696181 introduced the fix for
time ticking too fast on some boards by disabling one of the doubly
connected timer pins on ATI boards.
However, it ends up being _much_ too broad a brush, and that just makes
some other ATI boards not work at all since they now have no timer
source.
So disable the automatic ATI southbridge detection, and just rely on
people who see this problem disabling it by hand with the option
"disable_timer_pin_1" on the kernel command line.
Maybe somebody can figure out the proper tests at a later date.
Acked-by: Peter Osterlund <petero2@telia.com>
Patch from Nicolas Pitre
This apparently fell in the crack somewhere. Add it back.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Pavel Emelianov and Kirill Korotaev observe that fs and arch users of
security_vm_enough_memory tend to forget to vm_unacct_memory when a
failure occurs further down (typically in setup_arg_pages variants).
These are all users of insert_vm_struct, and that reservation will only
be unaccounted on exit if the vma is marked VM_ACCOUNT: which in some
cases it is (hidden inside VM_STACK_FLAGS) and in some cases it isn't.
So x86_64 32-bit and ppc64 vDSO ELFs have been leaking memory into
Committed_AS each time they're run. But don't add VM_ACCOUNT to them,
it's inappropriate to reserve against the very unlikely case that gdb
be used to COW a vDSO page - we ought to do something about that in
do_wp_page, but there are yet other inconsistencies to be resolved.
The safe and economical way to fix this is to let insert_vm_struct do
the security_vm_enough_memory check when it finds VM_ACCOUNT is set.
And the MIPS irix_brk has been calling security_vm_enough_memory before
calling do_brk which repeats it, doubly accounting and so also leaking.
Remove that, and all the fs and arch calls to security_vm_enough_memory:
give it a less misleading name later on.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-Off-By: Kirill Korotaev <dev@sw.ru>
disable_timer_pin_1 needs IO-APIC, not just local APIC.
Signed-off-by: Cal Peake <cp@absolutedigital.net>
Patch from George G. Davis
As pointed out be Matthew Klahn <MKLAHN@motorola.com>, some sys_ipc()
call options require six args, e.g. SEMTIMEDOP. This patch adds an ARM sys_ipc_wrapper to save the sys_ipc() 'fifth' arg on the stack.
Signed-off-by: George G. Davis <gdavis@mvista.com>
arch/arm/kernel/calls.S | 2 +-
arch/arm/kernel/entry-common.S | 5 +++++
Fixes
> if [ -r System.map -a -x /sbin/depmod ]; then /sbin/depmod -ae -F
> System.map 2. 6.14-rc1; fi
> WARNING: /lib/modules/2.6.14-rc1/kernel/drivers/char/agp/amd64-agp.ko
> needs unknown symbol end_pfn
Signed-off-by: Andi Kleen <ak@suse.de>
Masked FPU exceptions should obviously not happen in the first place,
but if they do, ignoring them seems to be the right thing to do.
Although there is no documentation available for Cyrix MII, I did find
erratum F-7 for Winchip C6, "FPU instruction may result in spurious
exception under certain conditions" which seems to indicate that this
can happen.
That would also explain the behaviour Ondrej Zary reported on the MII.
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
