The PINCTRL_SUNXI configuration was kept only to deal with the introduction of
per-machine symbols and the various pintrl drivers through different tree.
Now that it's not useful anymore, we can just remove it.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Pads for PB0-PB3, PC0-PC4, PE26-PE31 and PF24-PF31 does not exist on
the i.MX27 SOC. There is no reason to define them, the presence of
such definitions in the DTS files is a bug.
This patch removes these nonexistent pad definitions.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
git://git.linaro.org/people/mike.turquette/linux
Pull more clock framework updates from Mike Turquette:
"This contains the second half the of the clk changes for 3.16.
They are simply fixes and code refactoring for the OMAP clock drivers.
The sunxi clock driver changes include splitting out the one
mega-driver into several smaller pieces and adding support for the A31
SoC clocks"
* tag 'clk-for-linus-3.16-part2' of git://git.linaro.org/people/mike.turquette/linux: (25 commits)
clk: sunxi: document PRCM clock compatible strings
clk: sunxi: add PRCM (Power/Reset/Clock Management) clks support
clk: sun6i: Protect SDRAM gating bit
clk: sun6i: Protect CPU clock
clk: sunxi: Rework clock protection code
clk: sunxi: Move the GMAC clock to a file of its own
clk: sunxi: Move the 24M oscillator to a file of its own
clk: sunxi: Remove calls to clk_put
clk: sunxi: document new A31 USB clock compatible
clk: sunxi: Implement A31 USB clock
ARM: dts: OMAP5/DRA7: use omap5-mpu-dpll-clock capable of dealing with higher frequencies
CLK: TI: dpll: support OMAP5 MPU DPLL that need special handling for higher frequencies
ARM: OMAP5+: dpll: support Duty Cycle Correction(DCC)
CLK: TI: clk-54xx: Set the rate for dpll_abe_m2x2_ck
CLK: TI: Driver for DRA7 ATL (Audio Tracking Logic)
dt:/bindings: DRA7 ATL (Audio Tracking Logic) clock bindings
ARM: dts: dra7xx-clocks: Correct name for atl clkin3 clock
CLK: TI: gate: add composite interface clock to OMAP2 only build
ARM: OMAP2: clock: add DT boot support for cpufreq_ck
CLK: TI: OMAP2: add clock init support
Pull x86 vdso fixes from Peter Anvin:
"Fixes for x86/vdso.
One is a simple build fix for bigendian hosts, one is to make "make
vdso_install" work again, and the rest is about working around a bug
in Google's Go language -- two are documentation patches that improves
the sample code that the Go coders took, modified, and broke; the
other two implements a workaround that keeps existing Go binaries from
segfaulting at least"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso: Fix vdso_install
x86/vdso: Hack to keep 64-bit Go programs working
x86/vdso: Add PUT_LE to store little-endian values
x86/vdso/doc: Make vDSO examples more portable
x86/vdso/doc: Rename vdso_test.c to vdso_standalone_test_x86.c
x86, vdso: Remove one final use of htole16()
"make vdso_install" installs unstripped versions of the vdso objects
for the benefit of the debugger. This was broken by checkin:
6f121e548f83 x86, vdso: Reimplement vdso.so preparation in build-time C
The filenames are different now, so update the Makefile to cope.
This still installs the 64-bit vdso as vdso64.so. We believe this
will be okay, as the only known user is a patched gdb which is known
to use build-ids, but if it turns out to be a problem we may have to
add a link.
Inspired by a patch from Sam Ravnborg.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Tested-by: Josh Boyer <jwboyer@fedoraproject.org>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/b10299edd8ba98d17e07dafcd895b8ecf4d99eff.1402586707.git.luto@amacapital.net
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Kbuild changes for v3.16-rc1:
- cross-compilation fix so that cc-option is testing the right
compiler
- Fix for make defconfig all
- Using relative paths to the object and source directory where
possible, plus fixes for the fallout of the change
- several cleanups in the Makefiles and scripts
The powerpc fix is from today, because it was only discovered
recently. The rest has been in linux-next for some time"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
powerpc: Avoid circular dependency with zImage.%
kbuild: create include/config directory in scripts/kconfig/Makefile
kbuild: do not create include/linux directory
Makefile: Fix unrecognized cross-compiler command line options
kbuild: do not add "selinux" to subdir- twice
um: Fix for relative objtree when generating x86 headers
kbuild: Use relative path when building in a subdir of the source tree
kbuild: Use relative path when building in the source tree
kbuild: Use relative path for $(objtree)
firmware: Use $(quote) in the Makefile
firmware: Simplify directory creation
kbuild: trivial - fix comment block indent
kbuild: trivial - remove trailing spaces
kbuild: support simultaneous "make %config" and "make all"
kbuild: move extra gcc checks to scripts/Makefile.extrawarn
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull more powerpc updates from Ben Herrenschmidt:
"Here are the remaining bits I was mentioning earlier. Mostly bug
fixes and new selftests from Michael (yay !). He also removed the WSP
platform and A2 core support which were dead before release, so less
clutter.
One little "feature" I snuck in is the doorbell IPI support for
non-virtualized P8 which speeds up IPIs significantly between threads
of a core"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits)
powerpc/book3s: Fix some ABIv2 issues in machine check code
powerpc/book3s: Fix guest MC delivery mechanism to avoid soft lockups in guest.
powerpc/book3s: Increment the mce counter during machine_check_early call.
powerpc/book3s: Add stack overflow check in machine check handler.
powerpc/book3s: Fix machine check handling for unhandled errors
powerpc/eeh: Dump PE location code
powerpc/powernv: Enable POWER8 doorbell IPIs
powerpc/cpuidle: Only clear LPCR decrementer wakeup bit on fast sleep entry
powerpc/powernv: Fix killed EEH event
powerpc: fix typo 'CONFIG_PMAC'
powerpc: fix typo 'CONFIG_PPC_CPU'
powerpc/powernv: Don't escalate non-existing frozen PE
powerpc/eeh: Report frozen parent PE prior to child PE
powerpc/eeh: Clear frozen state for child PE
powerpc/powernv: Reduce panic timeout from 180s to 10s
powerpc/xmon: avoid format string leaking to printk
selftests/powerpc: Add tests of PMU EBBs
selftests/powerpc: Add support for skipping tests
selftests/powerpc: Put the test in a separate process group
selftests/powerpc: Fix instruction loop for ABIv2 (LE)
http://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux
Pull blackfin updates from Steven Miao.
* tag 'blackfin-for-linus' of http://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux:
blackfin: defconfigs: add MTD_SPI_NOR (new dependency for M25P80)
Revert "blackfin: dma: current count mmr is read only"
bf533: fix build error: add linux/gpio.h
Pull x86 irq fixes from Ingo Molnar:
"Two changes: a cpu-hotplug/irq race fix, plus a HyperV related fix"
* 'x86-irq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/irq: Fix fixup_irqs() error handling
x86, irq, pic: Probe for legacy PIC and set legacy_pic appropriately
Pull more scheduler updates from Ingo Molnar:
"Second round of scheduler changes:
- try-to-wakeup and IPI reduction speedups, from Andy Lutomirski
- continued power scheduling cleanups and refactorings, from Nicolas
Pitre
- misc fixes and enhancements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/deadline: Delete extraneous extern for to_ratio()
sched/idle: Optimize try-to-wake-up IPI
sched/idle: Simplify wake_up_idle_cpu()
sched/idle: Clear polling before descheduling the idle thread
sched, trace: Add a tracepoint for IPI-less remote wakeups
cpuidle: Set polling in poll_idle
sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...)
sched: Rename capacity related flags
sched: Final power vs. capacity cleanups
sched: Remove remaining dubious usage of "power"
sched: Let 'struct sched_group_power' care about CPU capacity
sched/fair: Disambiguate existing/remaining "capacity" usage
sched/fair: Change "has_capacity" to "has_free_capacity"
sched/fair: Remove "power" from 'struct numa_stats'
sched: Fix signedness bug in yield_to()
sched/fair: Use time_after() in record_wakee()
sched/balancing: Reduce the rate of needless idle load balancing
sched/fair: Fix unlocked reads of some cfs_b->quota/period
Pull more perf updates from Ingo Molnar:
"A second round of perf updates:
- wide reaching kprobes sanitization and robustization, with the hope
of fixing all 'probe this function crashes the kernel' bugs, by
Masami Hiramatsu.
- uprobes updates from Oleg Nesterov: tmpfs support, corner case
fixes and robustization work.
- perf tooling updates and fixes from Jiri Olsa, Namhyung Ki, Arnaldo
et al:
* Add support to accumulate hist periods (Namhyung Kim)
* various fixes, refactorings and enhancements"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (101 commits)
perf: Differentiate exec() and non-exec() comm events
perf: Fix perf_event_comm() vs. exec() assumption
uprobes/x86: Rename arch_uprobe->def to ->defparam, minor comment updates
perf/documentation: Add description for conditional branch filter
perf/x86: Add conditional branch filtering support
perf/tool: Add conditional branch filter 'cond' to perf record
perf: Add new conditional branch filter 'PERF_SAMPLE_BRANCH_COND'
uprobes: Teach copy_insn() to support tmpfs
uprobes: Shift ->readpage check from __copy_insn() to uprobe_register()
perf/x86: Use common PMU interrupt disabled code
perf/ARM: Use common PMU interrupt disabled code
perf: Disable sampled events if no PMU interrupt
perf: Fix use after free in perf_remove_from_context()
perf tools: Fix 'make help' message error
perf record: Fix poll return value propagation
perf tools: Move elide bool into perf_hpp_fmt struct
perf tools: Remove elide setup for SORT_MODE__MEMORY mode
perf tools: Fix "==" into "=" in ui_browser__warning assignment
perf tools: Allow overriding sysfs and proc finding with env var
perf tools: Consider header files outside perf directory in tags target
The Go runtime has a buggy vDSO parser that currently segfaults.
This writes an empty SHT_DYNSYM entry that causes Go's runtime to
malfunction by thinking that the vDSO is empty rather than
malfunctioning by running off the end and segfaulting.
This affects x86-64 only as far as we know, so we do not need this for
the i386 and x32 vdsos.
Link: http://lkml.kernel.org/r/d10618176c4bd39b457a5e85c497295c90cab1bc.1402620737.git.luto@amacapital.net
Add PUT_LE() by analogy with GET_LE() to write littleendian values in
addition to reading them.
Link: http://lkml.kernel.org/r/3d9b27e92745b27b6fda1b9a98f70dc9c1246c7a.1402620737.git.luto@amacapital.net
Pull more locking changes from Ingo Molnar:
"This is the second round of locking tree updates for v3.16, offering
large system scalability improvements:
- optimistic spinning for rwsems, from Davidlohr Bueso.
- 'qrwlocks' core code and x86 enablement, from Waiman Long and PeterZ"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, locking/rwlocks: Enable qrwlocks on x86
locking/rwlocks: Introduce 'qrwlocks' - fair, queued rwlocks
locking/mutexes: Documentation update/rewrite
locking/rwsem: Fix checkpatch.pl warnings
locking/rwsem: Fix warnings for CONFIG_RWSEM_GENERIC_SPINLOCK
locking/rwsem: Support optimistic spinning
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Pull drm updates from Dave Airlie:
"This is the main drm merge window pull request, changes all over the
place, mostly normal levels of churn.
Highlights:
Core drm:
More cleanups, fix race on connector/encoder naming, docs updates,
object locking rework in prep for atomic modeset
i915:
mipi DSI support, valleyview power fixes, cursor size fixes,
execlist refactoring, vblank improvements, userptr support, OOM
radeon:
GPUVM tuning and large page size support, gart fixes, deep color
HDMI support, HDMI audio cleanups
nouveau:
- displayport rework should fix lots of issues
- initial gk20a support
- gk110b support
- gk208 fixes
exynos:
probe order fixes, HDMI changes, IPP consolidation
msm:
debugfs updates, misc fixes
ast:
ast2400 support, sync with UMS driver
tegra:
cleanups, hdmi + hw cursor for Tegra 124.
panel:
fixes existing panels add some new ones.
ipuv3:
moved from staging to drivers/gpu"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (761 commits)
drm/nouveau/disp/dp: fix tmds passthrough on dp connector
drm/nouveau/dp: probe dpcd to determine connectedness
drm/nv50-: trigger update after all connectors disabled
drm/nv50-: prepare for attaching a SOR to multiple heads
drm/gf119-/disp: fix debug output on update failure
drm/nouveau/disp/dp: make use of postcursor when its available
drm/g94-/disp/dp: take max pullup value across all lanes
drm/nouveau/bios/dp: parse lane postcursor data
drm/nouveau/dp: fix support for dpms
drm/nouveau: register a drm_dp_aux channel for each dp connector
drm/g94-/disp: add method to power-off dp lanes
drm/nouveau/disp/dp: maintain link in response to hpd signal
drm/g94-/disp: bash and wait for something after changing lane power regs
drm/nouveau/disp/dp: split link config/power into two steps
drm/nv50/disp: train PIOR-attached DP from second supervisor
drm/nouveau/disp/dp: make use of existing output data for link training
drm/gf119/disp: start removing direct vbios parsing from supervisor
drm/nv50/disp: start removing direct vbios parsing from supervisor
drm/nouveau/disp/dp: maintain receiver caps in response to hpd signal
drm/nouveau/disp/dp: create subclass for dp outputs
Fix this dependency on the locking tree's smp_mb*() API changes:
kernel/sched/idle.c:247:3: error: implicit declaration of function ‘smp_mb__after_atomic’ [-Werror=implicit-function-declaration]
These defconfigs contain the CONFIG_M25P80 symbol, which is now
dependent on the MTD_SPI_NOR symbol. Add CONFIG_MTD_SPI_NOR to the
relevant defconfigs.
At the same time, drop the now-nonexistent CONFIG_MTD_CHAR symbol.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Cc: Steven Miao <realmz6@gmail.com>
Cc: adi-buildroot-devel@lists.sourceforge.net
The rule to create the final images uses a zImage.% pattern.
Unfortunately, this also matches the names of the zImage.*.lds linker
scripts, which appear as a dependency of the final images. This somehow
worked when $(srctree) used to be an absolute path, but now the pattern
matches too much. List only the images from $(image-y) as the target of
the rule, to avoid the circular dependency.
Reported-and-tested-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Pull arch/tile changes from Chris Metcalf:
"These mostly just address smaller issues reported to me"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch: tile: kernel: unaligned.c: Cleaning up uninitialized variables
drivers/tty/hvc/hvc_tile.c: use PTR_ERR_OR_ZERO
replace strict_strto* call with kstrto*
tile: Update comments for generic idle conversion
tile: cleanup the comment in init_pgprot
tile: use BOOTMEM_DEFAULT instead of magic number 0 for reserve_bootmem flags
Commit 2749a2f26a7c (powerpc/book3s: Fix machine check handling for
unhandled errors) introduced a few ABIv2 issues.
We can maintain ABIv1 and ABIv2 compatibility by branching to the
function rather than the dot symbol.
Fixes: 2749a2f26a7c ("powerpc/book3s: Fix machine check handling for unhandled errors")
net/core/rtnetlink.c
net/core/skbuff.c
Both conflicts were very simple overlapping changes.
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm changes from Thierry Reding:
"The majority of these changes are cleanups and fixes across all
drivers. Redundant error messages are removed and more PWM
controllers set the .can_sleep flag to signal that they can't be used
in atomic context.
Support is added for the Broadcom Kona family of SoCs and the Intel
LPSS driver can now probe PCI devices in addition to ACPI devices.
Upon shutdown, the pwm-backlight driver will now power off the
backlight. It also uses the new descriptor-based GPIO API for more
concise GPIO handling.
A large chunk of these changes also converts platforms to use the
lookup mechanism rather than relying on the global number space to
reference PWM devices. This is largely in preparation for more
unification and cleanups in future patches. Eventually it will allow
the legacy PWM API to be removed"
* tag 'pwm/for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (38 commits)
pwm: fsl-ftm: set pwm_chip can_sleep flag
pwm: ab8500: Fix wrong value shift for disable/enable PWM
pwm: samsung: do not set manual update bit in pwm_samsung_config
pwm: lp3943: Set pwm_chip can_sleep flag
pwm: atmel: set pwm_chip can_sleep flag
pwm: mxs: set pwm_chip can_sleep flag
pwm: tiehrpwm: inline accessor functions
pwm: tiehrpwm: don't build PM related functions when not needed
pwm-backlight: retrieve configured PWM period
leds: leds-pwm: retrieve configured PWM period
ARM: pxa: hx4700: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: shmobile: armadillo: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: OMAP3: Beagle: use PWM_LOOKUP to initialize struct pwm_lookup
pwm: modify PWM_LOOKUP to initialize all struct pwm_lookup members
ARM: pxa: hx4700: initialize all the struct pwm_lookup members
ARM: OMAP3: Beagle: initialize all the struct pwm_lookup members
pwm: renesas-tpu: remove unused struct tpu_pwm_platform_data
ARM: shmobile: armadillo: initialize all struct pwm_lookup members
pwm: add period and polarity to struct pwm_lookup
pwm: twl: Really disable twl6030 PWMs
Pull part two of ARM SoC updates from Arnd Bergmann:
"This is a small follow-up to the larger ARM SoC updates merged last
week, almost entirely for the keystone platform.
The main change here is to use the new dma-ranges parsing code that
came in through Russell's ARM tree. This allows the keystone platform
to do cache-coherent DMA and to finally support all the available
physical memory when LPAE is enabled.
Aside from this, the keystone reset driver has been rewritten, and
there is a small bug fix to allow building the orion5x platform again"
* tag 'soc2-for-3.16' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: keystone: Drop use of meminfo since its not available anymore
ARM: orion5x: fix mvebu_mbus_dt_init call
ARM: configs: keystone: enable reset driver support
ARM: dts: keystone: update reset node to work with reset driver
ARM: keystone: remove redundant reset stuff
ARM: keystone: Update the dma offset for non-dt platform devices
ARM: keystone: Switch over to coherent memory address space
ARM: configs: keystone: add MTD_SPI_NOR (new dependency for M25P80)
ARM: configs: keystone: drop CONFIG_COMMON_CLK_DEBUG
Pull MTD updates from Brian Norris:
- refactor m25p80.c driver for use as a general SPI NOR framework for
other drivers which may speak to SPI NOR flash without providing full
SPI support (i.e., not part of drivers/spi/)
- new Freescale QuadSPI driver (utilizing new SPI NOR framework)
- updates for the STMicro "FSM" SPI NOR driver
- fix sync/flush behavior on mtd_blkdevs
- fixup subpage write support on a few NAND drivers
- correct the MTD OOB test for odd-sized OOB areas
- add BCH-16 support for OMAP NAND
- fix warnings and trivial refactoring
- utilize new ECC DT bindings in pxa3xx NAND driver
- new LPDDR NVM driver
- address a few assorted bugs caught by Coverity
- add new imx6sx support for GPMI NAND
- use a bounce buffer for NAND when non-DMA-able buffers are used
* tag 'for-linus-20140610' of git://git.infradead.org/linux-mtd: (77 commits)
mtd: gpmi: add gpmi support for imx6sx
mtd: maps: remove check for CONFIG_MTD_SUPERH_RESERVE
mtd: bf5xx_nand: use the managed version of kzalloc
mtd: pxa3xx_nand: make the driver work on big-endian systems
mtd: nand: omap: fix omap_calculate_ecc_bch() for-loop error
mtd: nand: r852: correct write_buf loop bounds
mtd: nand_bbt: handle error case for nand_create_badblock_pattern()
mtd: nand_bbt: remove unused variable
mtd: maps: sc520cdp: fix warnings
mtd: slram: fix unused variable warning
mtd: pfow: remove unused variable
mtd: lpddr: fix Kconfig dependency, for I/O accessors
mtd: nand: pxa3xx: Add supported ECC strength and step size to the DT binding
mtd: nand: pxa3xx: Use ECC strength and step size devicetree binding
mtd: nand: pxa3xx: Clean pxa_ecc_init() error handling
mtd: nand: Warn the user if the selected ECC strength is too weak
mtd: nand: omap: Documentation: How to select correct ECC scheme for your device ?
mtd: nand: omap: add support for BCH16_ECC - NAND driver updates
mtd: nand: omap: add support for BCH16_ECC - ELM driver updates
mtd: nand: omap: add support for BCH16_ECC - GPMC driver updates
Currently we forward MCEs to guest which have been recovered by guest.
And for unhandled errors we do not deliver the MCE to guest. It looks like
with no support of FWNMI in qemu, guest just panics whenever we deliver the
recovered MCEs to guest. Also, the existig code used to return to host for
unhandled errors which was casuing guest to hang with soft lockups inside
guest and makes it difficult to recover guest instance.
This patch now forwards all fatal MCEs to guest causing guest to crash/panic.
And, for recovered errors we just go back to normal functioning of guest
instead of returning to host. This fixes soft lockup issues in guest.
This patch also fixes an issue where guest MCE events were not logged to
host console.
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
We don't see MCE counter getting increased in /proc/interrupts which gives
false impression of no MCE occurred even when there were MCE events.
The machine check early handling was added for PowerKVM and we missed to
increment the MCE count in the early handler.
We also increment mce counters in the machine_check_exception call, but
in most cases where we handle the error hypervisor never reaches there
unless its fatal and we want to crash. Only during fatal situation we may
see double increment of mce count. We need to fix that. But for
now it always good to have some count increased instead of zero.
Currently machine check handler does not check for stack overflow for
nested machine check. If we hit another MCE while inside the machine check
handler repeatedly from same address then we get into risk of stack
overflow which can cause huge memory corruption. This patch limits the
nested MCE level to 4 and panic when we cross level 4.
Current code does not check for unhandled/unrecovered errors and return from
interrupt if it is recoverable exception which in-turn triggers same machine
check exception in a loop causing hypervisor to be unresponsive.
This patch fixes this situation and forces hypervisor to panic for
unhandled/unrecovered errors.
This patch also fixes another issue where unrecoverable_exception routine
was called in real mode in case of unrecoverable exception (MSR_RI = 0).
This causes another exception vector 0x300 (data access) during system crash
leading to confusion while debugging cause of the system crash.
Also turn ME bit off while going down, so that when another MCE is hit during
panic path, system will checkstop and hypervisor will get restarted cleanly
by SP.
With the above fixes we now throw correct console messages (see below) while
crashing the system in case of unhandled/unrecoverable machine checks.
Severe Machine check interrupt [[Not recovered]
Initiator: CPU
Error type: UE [Instruction fetch]
Effective address: 0000000030002864
Oops: Machine check, sig: 7 [#1]
SMP NR_CPUS=2048 NUMA PowerNV
Modules linked in: bork(O) bridge stp llc kvm [last unloaded: bork]
CPU: 36 PID: 55162 Comm: bash Tainted: G O 3.14.0mce #1
task: c000002d72d022d0 ti: c000000007ec0000 task.ti: c000002d72de4000
NIP: 0000000030002864 LR: 00000000300151a4 CTR: 000000003001518c
REGS: c000000007ec3d80 TRAP: 0200 Tainted: G O (3.14.0mce)
MSR: 9000000000041002 <SF,HV,ME,RI> CR: 28222848 XER: 20000000
CFAR: 0000000030002838 DAR: d0000000004d0000 DSISR: 00000000 SOFTE: 1
GPR00: 000000003001512c 0000000031f92cb0 0000000030078af0 0000000030002864
GPR04: d0000000004d0000 0000000000000000 0000000030002864 ffffffffffffffc9
GPR08: 0000000000000024 0000000030008af0 000000000000002c c00000000150e728
GPR12: 9000000000041002 0000000031f90000 0000000010142550 0000000040000000
GPR16: 0000000010143cdc 0000000000000000 00000000101306fc 00000000101424dc
GPR20: 00000000101424e0 000000001013c6f0 0000000000000000 0000000000000000
GPR24: 0000000010143ce0 00000000100f6440 c000002d72de7e00 c000002d72860250
GPR28: c000002d72860240 c000002d72ac0038 0000000000000008 0000000000040000
NIP [0000000030002864] 0x30002864
LR [00000000300151a4] 0x300151a4
Call Trace:
Instruction dump:
XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
---[ end trace 7285f0beac1e29d3 ]---
Sending IPI to other CPUs
IPI complete
OPAL V3 detected !
As Ben suggested, it's meaningful to dump PE's location code
for site engineers when hitting EEH errors. The patch introduces
function eeh_pe_loc_get() to retireve the location code from
dev-tree so that we can output it when hitting EEH errors.
If primary PE bus is root bus, the PHB's dev-node would be tried
prior to root port's dev-node. Otherwise, the upstream bridge's
dev-node of the primary PE bus will be check for the location code
directly.
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
The macro 'A' used in internal BPF interpreter:
#define A regs[insn->a_reg]
was easily confused with the name of classic BPF register 'A', since
'A' would mean two different things depending on context.
This patch is trying to clean up the naming and clarify its usage in the
following way:
- A and X are names of two classic BPF registers
- BPF_REG_A denotes internal BPF register R0 used to map classic register A
in internal BPF programs generated from classic
- BPF_REG_X denotes internal BPF register R7 used to map classic register X
- internal BPF instruction format:
struct sock_filter_int {
__u8 code; /* opcode */
__u8 dst_reg:4; /* dest register */
__u8 src_reg:4; /* source register */
__s16 off; /* signed offset */
__s32 imm; /* signed immediate constant */
- BPF_X/BPF_K is 1 bit used to encode source operand of instruction
In classic:
BPF_X - means use register X as source operand
BPF_K - means use 32-bit immediate as source operand
In internal:
BPF_X - means use 'src_reg' register as source operand
Suggested-by: Chema Gonzalez <chema@google.com>
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Chema Gonzalez <chema@google.com>
This patch enables POWER8 doorbell IPIs on powernv.
Since doorbells can only IPI within a core, we test to see when we can use
doorbells and if not we fall back to XICS. This also enables hypervisor
doorbells to wakeup us up from nap/sleep via the LPCR PECEDH bit.
Based on tests by Anton, the best case IPI latency between two threads dropped
from 894ns to 512ns.
Signed-off-by: Michael Neuling <mikey@neuling.org>
On PowerNV platform, EEH errors are reported by IO accessors or poller
driven by interrupt. After the PE is isolated, we won't produce EEH
event for the PE. The current implementation has possibility of EEH
event lost in this way:
The interrupt handler queues one "special" event, which drives the poller.
EEH thread doesn't pick the special event yet. IO accessors kicks in, the
frozen PE is marked as "isolated" and EEH event is queued to the list.
EEH thread runs because of special event and purge all existing EEH events.
However, we never produce an other EEH event for the frozen PE. Eventually,
the PE is marked as "isolated" and we don't have EEH event to recover it.
The patch fixes the issue to keep EEH events for PEs that have been
marked as "isolated" with the help of additional "force" help to
eeh_remove_event().
Reported-by: Rolf Brudeseth <rolfb@us.ibm.com>
Commit b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling
perf_event_do_pending") added a check for CONFIG_PMAC were a check for
CONFIG_PPC_PMAC was clearly intended.
Fixes: b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling perf_event_do_pending")
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Commit cd64d1697cf0 ("powerpc: mtmsrd not defined") added a check for
CONFIG_PPC_CPU were a check for CONFIG_PPC_FPU was clearly intended.
Fixes: cd64d1697cf0 ("powerpc: mtmsrd not defined")
Commit cb5b242c ("powerpc/eeh: Escalate error on non-existing PE")
escalates the frozen state on non-existing PE to fenced PHB. It
was to improve kdump reliability. After that, commit 361f2a2a
("powrpc/powernv: Reset PHB in kdump kernel") was introduced to
issue complete reset on all PHBs to increase the reliability of
kdump kernel.
Commit cb5b242c becomes unuseful and it would be reverted.
When we have the corner case of frozen parent and child PE at the
same time, we have to handle the frozen parent PE prior to the
child. Without clearning the frozen state on parent PE, the child
PE can't be recovered successfully.
The patch searches the EEH PE hierarchy tree and returns the toppest
frozen PE to be handled. It ensures the frozen parent PE will be
handled prior to child PE.
Since commit cb523e09 ("powerpc/eeh: Avoid I/O access during PE
reset"), the PE is kept as frozen state on hardware level until
the PE reset is done completely. After that, we explicitly clear
the frozen state of the affected PE. However, there might have
frozen child PEs of the affected PE and we also need clear their
frozen state as well. Otherwise, the recovery is going to fail.
We've already dropped the default pseries timeout to 10s, do
the same for powernv.
This makes sure format strings cannot leak into printk (the string has
already been correctly processed for format arguments).
In commit 330a1eb "Core EBB support for 64-bit book3s" I messed up
clear_task_ebb(). It clears some but not all of the task's Event Based
Branch (EBB) registers when we duplicate a task struct.
That allows a child task to observe the EBBHR & EBBRR of its parent,
which it should not be able to do.
Fix it by clearing EBBHR & EBBRR.
Cc: stable@vger.kernel.org [v3.11+]
memory_return_from_buffer returns a signed value, so ret should be
ssize_t.
Fixes the following issue reported by David Binderman:
[linux-3.15/arch/powerpc/platforms/powernv/opal-msglog.c:65]: (style)
Checking if unsigned variable 'ret' is less than zero.
[linux-3.15/arch/powerpc/platforms/powernv/opal-msglog.c:82]: (style)
Local variable "ret" is of type size_t. This is always unsigned,
so it is pointless to check if it is less than zero.
https://bugzilla.kernel.org/show_bug.cgi?id=77551
Fixing this exposes a real bug for the case where the entire count
bytes is successfully read from the POS_WRAP case. The second
memory_read_from_buffer will return EINVAL, causing the entire read to
return EINVAL to userspace, despite the data being copied correctly. The
fix is to test for the case where the data has been read and return
early.
Signed-off-by: Joel Stanley <joel@jms.id.au>
The SPUFS_CNTL_MAP_SIZE define is cut and pasted twice so we can delete
the second instance.
Acked-by: Jeremy Kerr <jk@ozlabs.org>
The FCC_GFMR_TTX define is cut and pasted twice so we can remove the
second instance.
EEH information fetched from OPAL need fix before using in LE environment.
To be included in sparse's endian check, declare them as __beXX and
access them by accessors.
Cc: Gavin Shan <gwshan@linux.vnet.ibm.com>
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Everyone can write to these files, which is not what we want.
Cc: stable@vger.kernel.org # 3.15
Build throws following errors when CONFIG_SMP=n
arch/powerpc/platforms/powernv/subcore.c: In function ‘cpu_update_split_mode’:
arch/powerpc/platforms/powernv/subcore.c:274:15: error: ‘setup_max_cpus’ undeclared (first use in this function)
arch/powerpc/platforms/powernv/subcore.c:285:5: error: lvalue required as left operand of assignment
'setup_max_cpus' variable is relevant only on SMP, so there is no point
working around it for UP. Furthermore, subcore itself is relevant only
on SMP and hence the better solution is to exclude subcore.o and
subcore-asm.o for UP builds.
Signed-off-by: Shreyas B. Prabhu <shreyas@linux.vnet.ibm.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
arch/powerpc/platforms/powernv/setup.c: In function ‘pnv_kexec_wait_secondaries_down’:
arch/powerpc/platforms/powernv/setup.c:179:4: error: implicit declaration of function ‘get_hard_smp_processor_id’
rc = opal_query_cpu_status(get_hard_smp_processor_id(i),
The usage of get_hard_smp_processor_id() needs the declaration from
<asm/smp.h>. The file setup.c includes <linux/sched.h>, which in-turn
includes <linux/smp.h>. However, <linux/smp.h> includes <asm/smp.h>
only on SMP configs and hence UP builds fail.
Fix this by directly including <asm/smp.h> in setup.c unconditionally.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
OPAL will mark a CPU that is guarded as "bad" in the status property of the CPU
node.
Unfortunatley Linux doesn't check this property and will put the bad CPU in the
present map. This has caused hangs on booting when we try to unsplit the core.
This patch checks the CPU is avaliable via this status property before putting
it in the present map.
Tested-by: Anton Blanchard <anton@samba.org>
cc: stable@vger.kernel.org
Correct the DSCR SPR becoming temporarily corrupted if a task is
context switched during a transaction.
The problem occurs while suspending the task and is caused by saving
the DSCR to thread.dscr after it has already been set to the CPU's
default value:
__switch_to() calls __switch_to_tm()
which calls tm_reclaim_task()
which calls tm_reclaim_thread()
which calls tm_reclaim()
where the DSCR is set to the CPU's default
__switch_to() calls _switch()
where thread.dscr is set to the DSCR
When the task is resumed, it's transaction will be doomed (as usual)
and the DSCR SPR will be corrupted, although the checkpointed value
will be correct. Therefore the DSCR will be immediately corrected by
the transaction aborting, unless it has been suspended. In that case
the incorrect value can be seen by the task until it resumes the
transaction.
The fix is to treat the DSCR similarly to the TAR and save it early
in __switch_to().
A program exposing the problem is added to the kernel self tests as:
tools/testing/selftests/powerpc/tm/tm-resched-dscr.
Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com>
CC: <stable@vger.kernel.org> [v3.10+]
