Enabled DAP (debug access port) by default. This enables the hw-
breakpoint framework to make use of the breakpoints and watchpoints
supported by hardware.
[ 0.215805] hw-breakpoint: found 2 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.224624] hw-breakpoint: maximum watchpoint size is 4 bytes.
Without this clock, the hw-breakpoint driver claims an undefined
instruction during initialization:
[ 0.227380] hw-breakpoint: Debug register access (0xee003e17) caused undefined instruction on CPU 0
[ 0.227519] hw-breakpoint: CPU 0 failed to disable vector catch
When compiling the kernel on a machine without LZO or LZ4 support,
the minimal initramfs compiled into the kernel will be GZIP. But,
without GZIP support built-in, such a kernel fails to boot. On
Vybrid the tty is initialized after the initramfs unpack. Hence,
such a kernel even does not show any output. Stay on the safe side
and enable GZIP by default again.
Add pinmux for on module FlexCAN controller instances.
Complete the clock definitions for SAI0/SAI2. On Vybrid, there are
not much useful choices, actually you can choose between the SAI
input clock and no clock. However, not having them specified leads
to error message due to missing clocks.
This is the 3.18.5 stable release
arch/arm/mach-imx/clk-imx6q.c
Add Wolfson WM9712 driver and SAI AC97 machine support for Audio
and resitive touch support on Colibri VF61.
This adds a clock driver to use the bitclock (TX_BCLK) as a master
clock.
Activate SAI0/SAI2 according to our needs and create a sound node
which enables the Wolfson WM9712 compatible AC97 codec.
Disable unnecessary configurations such as PM tests or highmem.
Enable LZO and LZ4 decompressor for initramfs. Disable appended
DTB since it is not recommended for production kernels.
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 38a1dfda8e77d7ba74c94d06d8bc41ba98a4bc8c upstream.
Commit 0dbc6078c06bc0 ('x86, build, pci: Fix PCI_MSI build on !SMP')
introduced the dependency that X86_UP_APIC is only available when
PCI_MSI is false. This effectively prevents PCI_MSI support on 32bit
UP systems because it disables both APIC and IO-APIC. But APIC support
is architecturally required for PCI_MSI.
The intention of the patch was to enforce APIC support when PCI_MSI is
enabled, but failed to do so.
Remove the !PCI_MSI dependency from X86_UP_APIC and enforce
X86_UP_APIC when PCI_MSI support is enabled on 32bit UP systems.
[ tglx: Massaged changelog ]
Fixes 0dbc6078c06bc0 'x86, build, pci: Fix PCI_MSI build on !SMP'
Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: http://lkml.kernel.org/r/1421967529-9037-1-git-send-email-pure.logic@nexus-software.ie
commit 3669ef9fa7d35f573ec9c0e0341b29251c2734a7 upstream.
The Witcher 2 did something like this to allocate a TLS segment index:
struct user_desc u_info;
bzero(&u_info, sizeof(u_info));
u_info.entry_number = (uint32_t)-1;
syscall(SYS_set_thread_area, &u_info);
Strictly speaking, this code was never correct. It should have set
read_exec_only and seg_not_present to 1 to indicate that it wanted
to find a free slot without putting anything there, or it should
have put something sensible in the TLS slot if it wanted to allocate
a TLS entry for real. The actual effect of this code was to
allocate a bogus segment that could be used to exploit espfix.
The set_thread_area hardening patches changed the behavior, causing
set_thread_area to return -EINVAL and crashing the game.
This changes set_thread_area to interpret this as a request to find
a free slot and to leave it empty, which isn't *quite* what the game
expects but should be close enough to keep it working. In
particular, using the code above to allocate two segments will
allocate the same segment both times.
According to FrostbittenKing on Github, this fixes The Witcher 2.
If this somehow still causes problems, we could instead allocate
a limit==0 32-bit data segment, but that seems rather ugly to me.
Fixes: 41bdc78544b8 x86/tls: Validate TLS entries to protect espfix
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: torvalds@linux-foundation.org
Link: http://lkml.kernel.org/r/0cb251abe1ff0958b8e468a9a9a905b80ae3a746.1421954363.git.luto@amacapital.net
commit e30ab185c490e9a9381385529e0fd32f0a399495 upstream.
32-bit programs don't have an lm bit in their ABI, so they can't
reliably cause LDT_empty to return true without resorting to memset.
They shouldn't need to do this.
This should fix a longstanding, if minor, issue in all 64-bit kernels
as well as a potential regression in the TLS hardening code.
Link: http://lkml.kernel.org/r/72a059de55e86ad5e2935c80aa91880ddf19d07c.1421954363.git.luto@amacapital.net
commit 63ea0a49ae0b145b91ff2b070c01b66fc75854b9 upstream.
STR and SLDT with rip-relative operand can cause a host kernel oops.
Mark them as DstMem as well.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
commit f3747379accba8e95d70cec0eae0582c8c182050 upstream.
SYSENTER emulation is broken in several ways:
1. It misses the case of 16-bit code segments completely (CVE-2015-0239).
2. MSR_IA32_SYSENTER_CS is checked in 64-bit mode incorrectly (bits 0 and 1 can
still be set without causing #GP).
3. MSR_IA32_SYSENTER_EIP and MSR_IA32_SYSENTER_ESP are not masked in
legacy-mode.
4. There is some unneeded code.
Fix it.
commit f285f4a21c3253887caceed493089ece17579d59 upstream.
On 64-bit, relocation is not required unless the load address gets
changed. Without this, relocations do unexpected things when the kernel
is above 4G.
Reported-by: Baoquan He <bhe@redhat.com>
Tested-by: Thomas D. <whissi@whissi.de>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Jan Beulich <JBeulich@suse.com>
Cc: Junjie Mao <eternal.n08@gmail.com>
Link: http://lkml.kernel.org/r/20150116005146.GA4212@www.outflux.net
commit 520452172e6b318f3a8bd9d4fe1e25066393de25 upstream.
Many users see this message when booting without knowning that it is
of no importance and that TSC calibration may have succeeded by
another way.
As explained by Paul Bolle in
http://lkml.kernel.org/r/1348488259.1436.22.camel@x61.thuisdomein
"Fast TSC calibration failed" should not be considered as an error
since other calibration methods are being tried afterward. At most,
those send a warning if they fail (not an error). So let's change
the message from error to warning.
[ tglx: Make if pr_info. It's really not important at all ]
Fixes: c767a54ba065 x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
Signed-off-by: Alexandre Demers <alexandre.f.demers@gmail.com>
Link: http://lkml.kernel.org/r/1418106470-6906-1-git-send-email-alexandre.f.demers@gmail.com
commit 32c6590d126836a062b3140ed52d898507987017 upstream.
The Hyper-V clocksource is continuous; mark it accordingly.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: jasowang@redhat.com
Cc: gregkh@linuxfoundation.org
Cc: devel@linuxdriverproject.org
Cc: olaf@aepfle.de
Cc: apw@canonical.com
Link: http://lkml.kernel.org/r/1421108762-3331-1-git-send-email-kys@microsoft.com
commit 4a0d3107d6b19125f21172c2b7d95f9c30ecaf6f upstream.
The mis-naming likely was a copy-and-paste effect.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/54B9408B0200007800055E8B@mail.emea.novell.com
commit 8f1e8ee28660018a935c7576b9af8ffe1feab54c upstream.
The current hardware I/O coherency is known to cause problems with DMA
coherent buffers, as it still requires explicit I/O synchronization
barriers, which is not compatible with the semantics expected by the
Linux DMA coherent buffers API.
So, in order to have enough time to validate a new solution based on
automatic I/O synchronization barriers, this commit disables hardware
I/O coherency entirely. Future patches will re-enable it.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
commit 7ecd0bde5bfea524a843ad8fa8cb66ccbce68779 upstream.
Currently PWM functionality is broken on mx25 due to the wrong assignment of the
PWM "per" clock.
According to Documentation/devicetree/bindings/clock/imx25-clock.txt:
pwm_ipg_per 52
,so update the pwm "per" to use 'pwm_ipg_per' instead of 'per10' clock.
With this change PWM can work fine on mx25.
Reported-by: Carlos Soto <csotoalonso@gmail.com>
commit 851b09369255a91e77f56d83e3643439ac5b209a upstream.
Every PCI-PCI bridge window should fit inside an upstream bridge window
because orphaned address space is unreachable from the primary side of the
upstream bridge. If we inherit invalid bridge windows that overlap an
upstream window from firmware, clip them to fit and update the bridge
accordingly.
[bhelgaas: changelog]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=85491
Reported-by: Marek Kordik <kordikmarek@gmail.com>
Tested-by: Marek Kordik <kordikmarek@gmail.com>
Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources")
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Ingo Molnar <mingo@redhat.com>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: x86@kernel.org
commit 78051e3b7e35722ad3f31dd611f1b34770bddab8 upstream.
If L0 has disabled EPT, don't advertise unrestricted
mode at all since it depends on EPT to run real mode code.
Fixes: 92fbc7b195b824e201d9f06f2b93105f72384d65
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Bandan Das <bsd@redhat.com>
commit b485342bd79af363c77ef1a421c4a0aef2de9812 upstream.
Commit a074335a370e ("x86, um: Mark system call tables readonly") was
supposed to mark the sys_call_table in UML as RO by adding the const,
but it doesn't have the desired effect as it's nevertheless being placed
into the data section since __cacheline_aligned enforces sys_call_table
being placed into .data..cacheline_aligned instead. We need to use
the ____cacheline_aligned version instead to fix this issue.
Before:
$ nm -v arch/x86/um/sys_call_table_64.o | grep -1 "sys_call_table"
U sys_writev
0000000000000000 D sys_call_table
0000000000000000 D syscall_table_size
After:
U sys_writev
0000000000000000 R sys_call_table
Fixes: a074335a370e ("x86, um: Mark system call tables readonly")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit f911d731054ab3d82ee72a16b889e17ca3a2332a upstream.
futex_atomic_cmpxchg_inatomic() does not work on UML because
it triggers a copy_from_user() in kernel context.
On UML copy_from_user() can only be used if the kernel was called
by a real user space process such that UML can use ptrace()
to fetch the value.
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Tested-by: Daniel Walter <d.walter@0x90.at>
commit 69d2626f97b7f017ee4416b7dc071e9499c2c944 upstream.
64KiB is allocated for qspi dtb partition which is not
sufficient, so updating the partition table size to 512KiB
for device tree partition.
This also aligns the QSPI partition definitions between
kernel and U-Boot.
Fixes: dc2dd5b8 ("ARM: dts: dra7: Add qspi device")
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
commit b0ddb319db3d7a1943445f0de0a45c07a7f3457a upstream.
The sh73a0 INTC can't mask interrupts properly most likely due to a
hardware bug. Set the .control_parent flag to delegate masking to the
parent interrupt controller, like was already done for irqpin1.
Without this, accessing the three-axis digital accelerometer ADXL345
on kzm9g through /dev/input/event1 causes an interrupt storm, which
requires a power-cycle to recover from.
This was inspired by a patch for arch/arm/boot/dts/sh73a0.dtsi from
Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Fixes: 341eb5465f67437a ("ARM: shmobile: INTC External IRQ pin driver on sh73a0")
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit 5adba7c2daaecccf377e7ed5a2996caedd5384f1 upstream.
There's no card detection for the eMMC, so this patch adds the missing
broken-cd property. This patch also sets bus width as 8 to add
MMC_CAP_8_BIT_DATA in the Host capabilities.
Fixes: 3047086dfd56 ("ARM: dts: berlin: enable SD card reader and eMMC for the BG2Q DMP")
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
commit 999f934de195a1506089b52c77429fdba25da688 upstream.
If the boot loader enables HYP mode on the boot CPU, the secondary CPU
also needs to call into the ROM to switch to HYP mode before booting.
The firmwares on the omap5 and dra7xx unfortunately do not take care
of this, so it has to be handled by the kernel.
This patch is based on "[PATCH 2/2] ARM: OMAP5: Add HYP mode entry support
for secondary CPUs" by Santosh Shilimkar <santosh.shilimkar@ti.com>,
except this version does not require a compile time CONFIG to control
if it should enable HYP mode or not, it simply does it based on the mode
of the boot CPU, so it works whether the CPU boots in SVC or HYP mode,
and should even work as a guest kernel inside kvm if qemu decides to
support emulating the omap5 or dra7xx.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
commit 572b24e6d85d98cdc552f07e9fb9870d9460d81b upstream.
The switch statement of the possible list of SYSCLK1 frequencies is
missing a 0 in 4 out of the 7 frequencies.
Fixes: fa6d79d27614 ("ARM: OMAP: Add initialisation for the real-time counter")
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
commit 81ef447950bf0955aca46f4a7617d8ce435cf0ce upstream.
The post dividers do not work on i.MX6Q rev T0 1.0 so they must be fixed
to 1. As the table index was wrong, a divider a of 4 could still be
requested which implied the clock not to be set properly. This is the
root cause of the HDMI not working at high resolution on rev T0 1.0 of
the SoC.
Signed-off-by: Gary Bisson <bisson.gary@gmail.com>
Cc: <stable@vger.kernel.org>
commit d2a10a1727b3948019128e83162f22c65859f1fd upstream.
Drop unnecessary semicolon after closing curly bracket.
Signed-off-by: Dmitry Voytik <voytikd@gmail.com>
commit 7a9f0604bd56936b2b18f49824e0e392dc7878c3 upstream.
GPIO2_5 is the reset GPIO for the USB3317 ULPI PHY. Instead of modelling it as
a regulator, the correct approach is to use the 'reset_gpios' property of the
"usb-nop-xceiv" node.
GPIO1_7 is the reset GPIO for the USB2517 USB hub. As we currently don't have
dt bindings to describe a HUB reset, let's keep using the regulator approach.
Rename the regulator to 'reg_hub_reset' to better describe its function and bind
it with the USB host1 port instead.
USB host support has been introduced by commit 9bf206a9d13be3 ("ARM: dts:
imx51-babbage: Add USB Host1 support"), which landed in 3.16 and it seems that
USB has only been functional due to previous bootloader initialization.
With this patch applied we can get USB host to work without relying on the
bootloader.
commit 7a87e9cbc3a2f0ff0955815335e08c9862359130 upstream.
From Documentation/devicetree/bindings/clock/imx25-clock.txt:
cspi1_ipg 78
cspi2_ipg 79
cspi3_ipg 80
, so fix the SPI1 clocks accordingly to avoid a kernel hang when trying to
access SPI1.
commit 7c168ed898931f6c3314d696e63cf993378ca192 upstream.
The default qspi2_clk_sel field of register CCM_CS2CDR contains '110' which is
marked as 'reserved', so we can't rely on the default value.
Provide a proper parent for QSPI clocks to avoid a kernel oops:
[ 1.037920] Division by zero in kernel.
[ 1.041807] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.18.0-rc7-next-20141204-00002-g5aa23e1 #2143
[ 1.050967] Hardware name: Freescale i.MX6 SoloX (Device Tree)
[ 1.056853] Backtrace:
[ 1.059360] [<80011ea0>] (dump_backtrace) from [<8001203c>] (show_stack+0x18/0x1c)
[ 1.066982] r6:00000000 r5:00000000 r4:00000000 r3:00000000
[ 1.072754] [<80012024>] (show_stack) from [<806b7100>] (dump_stack+0x88/0xa4)
[ 1.080038] [<806b7078>] (dump_stack) from [<80011d20>] (__div0+0x18/0x20)
[ 1.086958] r5:be018500 r4:be017c00
[ 1.090600] [<80011d08>] (__div0) from [<802aa418>] (Ldiv0+0x8/0x10)
[ 1.097012] [<80504fbc>] (clk_divider_set_rate) from [<80503ddc>] (clk_change_rate+0x14c/0x17c)
[ 1.105759] r7:00000000 r6:00000000 r5:be018500 r4:00000000
[ 1.111516] [<80503c90>] (clk_change_rate) from [<80503ea0>] (clk_set_rate+0x94/0x98)
[ 1.119391] r8:be7e0368 r7:00000000 r6:be11a000 r5:be018500 r4:00000000 r3:00000000
[ 1.127290] [<80503e0c>] (clk_set_rate) from [<80410558>] (fsl_qspi_probe+0x23c/0x75c)
[ 1.135260] r5:be11a010 r4:be350010
[ 1.138900] [<8041031c>] (fsl_qspi_probe) from [<80385a18>] (platform_drv_probe+0x50/0xac)
commit 40d1746d2eeec5e05956d749cca6364573b472b6 upstream.
CONFIG_GENERIC_CPUFREQ_CPU0 disappeared with commit bbcf071969b20f
("cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'")
Use the renamed CONFIG_CPUFREQ_DT generic driver. It looks like with
v3.18-rc1, commit bbcf071969b20f and fdc509b15eb3eb came in via
different trees causing the resultant v3.18-rc1 to be non-functional for
cpufreq as default supported with omap2plus_defconfig.
Fixes: fdc509b15eb3eb ("ARM: omap2plus_defconfig: Add cpufreq to defconfig")
Signed-off-by: Nishanth Menon <nm@ti.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 5138d5c562e3bfe30964e20ab46eec9f8b89225d upstream.
The gpio4 and gpio5 are in 0xf7fc0000 apb which is located in the SM domain.
This patch moves gpio4 and gpio5 to the correct location. This patch also
renames them as the following to match the names we internally used in
marvell:
gpio4 -> sm_gpio1
gpio5 -> sm_gpio0
porte -> portf
portf -> porte
This also matches what we did for BG2 and BG2CD's SM GPIO.
Fixes: cedf57fc4f2f ("ARM: dts: berlin: add the BG2Q GPIO nodes")
commit 237d28db036e411f22c03cfd5b0f6dc2aa9bf3bc upstream.
If the function graph tracer traces a jprobe callback, the system will
crash. This can easily be demonstrated by compiling the jprobe
sample module that is in the kernel tree, loading it and running the
function graph tracer.
# modprobe jprobe_example.ko
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
# ls
The first two commands end up in a nice crash after the first fork.
(do_fork has a jprobe attached to it, so "ls" just triggers that fork)
The problem is caused by the jprobe_return() that all jprobe callbacks
must end with. The way jprobes works is that the function a jprobe
is attached to has a breakpoint placed at the start of it (or it uses
ftrace if fentry is supported). The breakpoint handler (or ftrace callback)
will copy the stack frame and change the ip address to return to the
jprobe handler instead of the function. The jprobe handler must end
with jprobe_return() which swaps the stack and does an int3 (breakpoint).
This breakpoint handler will then put back the saved stack frame,
simulate the instruction at the beginning of the function it added
a breakpoint to, and then continue on.
For function tracing to work, it hijakes the return address from the
stack frame, and replaces it with a hook function that will trace
the end of the call. This hook function will restore the return
address of the function call.
If the function tracer traces the jprobe handler, the hook function
for that handler will not be called, and its saved return address
will be used for the next function. This will result in a kernel crash.
To solve this, pause function tracing before the jprobe handler is called
and unpause it before it returns back to the function it probed.
Some other updates:
Used a variable "saved_sp" to hold kcb->jprobe_saved_sp. This makes the
code look a bit cleaner and easier to understand (various tries to fix
this bug required this change).
Note, if fentry is being used, jprobes will change the ip address before
the function graph tracer runs and it will not be able to trace the
function that the jprobe is probing.
Link: http://lkml.kernel.org/r/20150114154329.552437962@goodmis.org
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
to be page aligned"
commit 0145058c3d30b4319d747f64caa16a9cb15f0581 upstream.
This patch partially reverts commit 421520ba98290a73b35b7644e877a48f18e06004
(only the arm64 part). There is no guarantee that the boot-loader places other
images like dtb in a different page than initrd start/end, especially when the
kernel is built with 64KB pages. When this happens, such pages must not be
freed. The free_reserved_area() already takes care of rounding up "start" and
rounding down "end" to avoid freeing partially used pages.
Reported-by: Peter Maydell <Peter.Maydell@arm.com>
commit bfe5fda8e7ced129716f5741cf7ed2592a338824 upstream.
Patch c49f63530bb6 ("powernv: Add OPAL tracepoints") has a spurious
store to the stack:
ld r12,opal_tracepoint_refcount@toc(r2); \
std r12,32(r1); \
The store was originally used to save the current tracepoint status
so the entry and the exit tracepoints were always balanced. In the
end I just created a separate path when tracepoints are enabled.
The offset on the stack used for this store is not valid for ABIv2
and it causes strange issues. I noticed it because OPAL console input
was broken.
Fixes: c49f63530bb6 ("powernv: Add OPAL tracepoints")
commit 280dbc572357eb50184663fc9e4aaf09c8141e9b upstream.
Commit 9def39be4e96 ("x86: Support compiling out human-friendly
processor feature names") made two source file targets
conditional. Such conditional targets will not be cleaned
automatically by make mrproper.
Fix by adding explicit clean-files targets for the two files.
Fixes: 9def39be4e96 ("x86: Support compiling out human-friendly processor feature names")
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/1419335863-10608-1-git-send-email-bjorn@mork.no
commit 45db07382a5c78b0c43b3b0002b63757fb60e873 upstream.
The __ldcw macro has a problem when its argument needs to be reloaded from
memory. The output memory operand and the input register operand both need to
be reloaded using a register in class R1_REGS when generating 64-bit code.
This fails because there's only a single register in the class. Instead, use a
memory clobber. This also makes the __ldcw macro a compiler memory barrier.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 96ed6046d3bf1113de3bdbd6dbb7f40e6d0ae0ef upstream.
On BG2Q, the sdhci2 host uses nfcecc for "io" clk and nfc for "core" clk.
The shdci2 can't work without this patch due to the "core" clk is gated.
Fixes: 0d859a6a9d14 ("ARM: dts: berlin: add the SDHCI nodes for the BG2Q")
commit e8ef060b37c2d3cc5fd0c0edbe4e42ec1cb9768b upstream.
This allows the sdplite/Zebu images to run on OSCI simulation platform
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
The ADC clock frequency is limited depending on modes used. Add
device tree property which allow to set the mode used and the
maximum frequency ratings for the instance.
Add SPI, DSPI and spidev by default
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
