(cherry picked from commit 7c8a83b75a38a807d37f5a4398eca2a42c8cf513)
kvm_handle_hva, called by MMU notifiers, manipulates mmu data only with
the protection of mmu_lock.
Update kvm_mmu_change_mmu_pages callers to take mmu_lock, thus protecting
against kvm_handle_hva.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
(cherry picked from commit 8986ecc0ef58c96eec48d8502c048f3ab67fd8e2)
Verify the cr3 address stored in vcpu->arch.cr3 points to an existant
memslot. If not, inject a triple fault.
(cherry picked from commit f00be0cae4e6ad0a8c7be381c6d9be3586800b3e)
free_mmu_pages() should only undo what alloc_mmu_pages() does.
Free mmu pages from the generic VM destruction function, kvm_destroy_vm().
Signed-off-by: Gleb Natapov <gleb@redhat.com>
(cherry picked from commit a2edf57f510cce6a389cc14e58c6ad0a4296d6f9)
The processor is documented to reload the PDPTRs while in PAE mode if any
of the CR4 bits PSE, PGE, or PAE change. Linux relies on this
behaviour when zapping the low mappings of PAE kernels during boot.
The code already handled changes to CR4.PAE; augment it to also notice changes
to PSE and PGE.
This triggered while booting an F11 PAE kernel; the futex initialization code
runs before any CR3 reloads and writes to a NULL pointer; the futex subsystem
ended up uninitialized, killing PI futexes and pulseaudio which uses them.
(cherry picked from commit a8cd0244e9cebcf9b358d24c7e7410062f3665cb)
The paravirt tlb flush may be used not only to flush TLBs, but also
to reload the four page-directory-pointer-table entries, as it is used
as a replacement for reloading CR3. Change the code to do the entire
CR3 reloading dance instead of simply flushing the TLB.
(cherry picked from commit e3c7cb6ad7191e92ba89d00a7ae5f5dd1ca0c214)
IF a guest tries to use vmx instructions, inject a #UD to let it know the
instruction is not implemented, rather than crashing.
This prevents guest userspace from crashing the guest kernel.
(cherry picked from commit e286e86e6d2042d67d09244aa0e05ffef75c9d54)
Some processors don't have EFER; don't oops if userspace wants us to
read EFER when we check NX.
(cherry picked from commit 99f85a28a78e96d28907fe036e1671a218fee597)
KVM optimizes guest port 80 accesses by passthing them through to the host.
Some AMD machines die on port 80 writes, allowing the guest to hard-lock the
host.
Remove the port passthrough to avoid the problem.
Reported-by: Piotr Jaroszyński <p.jaroszynski@gmail.com>
Tested-by: Piotr Jaroszyński <p.jaroszynski@gmail.com>
(cherry picked from commit 16175a796d061833aacfbd9672235f2d2725df65)
vmx_set_msr() does not allow i386 guests to touch EFER, but they can still
do so through the default: label in the switch. If they set EFER_LME, they
can oops the host.
Fix by having EFER access through the normal channel (which will check for
EFER_LME) even on i386.
Reported-and-tested-by: Benjamin Gilbert <bgilbert@cs.cmu.edu>
(cherry picked from commit 928d4bf747e9c290b690ff515d8f81e8ee226d97)
There is a potential issue that, when guest using pagetable without vmexit when
EPT enabled, guest would use PAT/PCD/PWT bits to index PAT msr for it's memory,
which would be inconsistent with host side and would cause host MCE due to
inconsistent cache attribute.
The patch set IGMT bit in EPT entry to ignore guest PAT and use WB as default
memory type to protect host (notice that all memory mapped by KVM should be WB).
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
(cherry picked from commit c41ef344de212bd918f7765af21b5008628c03e0)
The page fault path can use two rmap_desc structures, if:
- walk_addr's dirty pte update allocates one rmap_desc.
- mmu_lock is dropped, sptes are zapped resulting in rmap_desc being
freed.
- fetch->mmu_set_spte allocates another rmap_desc.
Increase to 4 for safety.
(cherry picked from commit 29415c37f043d1d54dcf356601d738ff6633b72b)
The vcpu thread can be preempted after the guest_debug_pre() callback,
resulting in invalid debug registers on the new vcpu.
Move it inside the non-preemptable section.
Signed-off-by: Avi Kivity <avi@qumranet.com>
(cherry picked from commit a89c1ad270ca7ad0eec2667bc754362ce7b142be)
Currently KVM implements MC0-MC4_MISC read support. When booting Linux this
results in KVM warnings in the kernel log when the guest tries to read
MC5_MISC. Fix this warnings with this patch.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
(cherry picked from commit 6ad18fba05228fb1d47cdbc0339fe8b3fca1ca26)
We're in a hot path. We can't use kmalloc() because
it might impact performance. So, we just stick the buffer that
we need into the kvm_vcpu_arch structure. This is used very
often, so it is not really a waste.
We also have to move the buffer structure's definition to the
arch-specific x86 kvm header.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
(cherry picked from commit b772ff362ec6b821c8a5227a3355e263f917bfad)
[sheng: fix KVM_GET_LAPIC using wrong size]
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
(cherry picked from commit f0d662759a2465babdba1160749c446648c9d159)
On my machine with gcc 3.4, kvm uses ~2k of stack in a few
select functions. This is mostly because gcc fails to
notice that the different case: statements could have their
stack usage combined. It overflows very nicely if interrupts
happen during one of these large uses.
This patch uses two methods for reducing stack usage.
1. dynamically allocate large objects instead of putting
on the stack.
2. Use a union{} member for all of the case variables. This
tricks gcc into combining them all into a single stack
allocation. (There's also a comment on this)
(cherry picked from commit 3201b5d9f0f7ef392886cd76dcd2c69186d9d5cd)
The accessed bit was accidentally turned on in a random flag word, rather
than, the spte itself, which was lucky, since it used the non-EPT compatible
PT_ACCESSED_MASK.
Fix by turning the bit on in the spte and changing it to use the portable
accessed mask.
(cherry picked from commit 171d595d3b3254b9a952af8d1f6965d2e85dcbaa)
Otherwise, the cpu may allow writes to the tracked pages, and we lose
some display bits or fail to migrate correctly.
(cherry picked from commit 2245a28fe2e6fdb1bdabc4dcde1ea3a5c37e2a9e)
It was generally safe due to slots_lock being held for write, but it wasn't
very nice.
(cherry picked from commit acee3c04e8208c17aad1baff99baa68d71640a19)
There is no reason to share internal memory slots with fork()ed instances.
(cherry picked from commit f4bbd9aaaae23007e4d79536d35a30cbbb11d407)
Real mode segments to not reference the GDT or LDT; they simply compute
base = selector * 16.
(cherry picked from commit a16b20da879430fdf245ed45461ed40ffef8db3c)
This is more emulation friendly, if not 100% correct.
(cherry picked from commit 5706be0dafd6f42852f85fbae292301dcad4ccec)
Real mode cs is a data segment, not a code segment.
commit fe2245c905631a3a353504fc04388ce3dfaf9d9e upstream.
The current code to set up the GART as an IOMMU enables GART
translations before it removes the aperture from the kernel memory
map, sets the GART PTEs to UC, sets up the guard and scratch
pages, or does a wbinvd(). This leaves the possibility of cache
aliasing open and can cause system crashes.
Re-order the code so as to enable the GART translations only
after all safeguards are in place and the tlb has been flushed.
AMD has tested this patch on both Istanbul systems and 1st
generation Opteron systems with APG enabled and seen no adverse
effects. Istanbul systems with HT Assist enabled sometimes
see MCE errors due to cache artifacts with the unmodified
code.
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Cc: akpm@linux-foundation.org
Cc: jbarnes@virtuousgeek.org
commit e82a3b75127188f20c7780bec580e148beb29da7 upstream
parisc: ensure broadcast tlb purge runs single threaded
The TLB flushing functions on hppa, which causes PxTLB broadcasts on the system
bus, needs to be protected by irq-safe spinlocks to avoid irq handlers to deadlock
the kernel. The deadlocks only happened during I/O intensive loads and triggered
pretty seldom, which is why this bug went so long unnoticed.
Signed-off-by: Helge Deller <deller@gmx.de>
[edited to use spin_lock_irqsave on UP as well since we'd been locking there
all this time anyway, --kyle]
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
[ Upstream commit 7f8189068726492950bf1a2dcfd9b51314560abf - modified
for stable to not use the sloppy __VIRTUAL_MASK_SHIFT ]
It's really not right to use 'access_ok()', since that is meant for the
normal "get_user()" and "copy_from/to_user()" accesses, which are done
through the TLB, rather than through the page tables.
Why? access_ok() does both too few, and too many checks. Too many,
because it is meant for regular kernel accesses that will not honor the
'user' bit in the page tables, and because it honors the USER_DS vs
KERNEL_DS distinction that we shouldn't care about in GUP. And too few,
because it doesn't do the 'canonical' check on the address on x86-64,
since the TLB will do that for us.
So instead of using a function that isn't meant for this, and does
something else and much more complicated, just do the real rules: we
don't want the range to overflow, and on x86-64, we want it to be a
canonical low address (on 32-bit, all addresses are canonical).
commit 429b2b319af3987e808c18f6b81313104caf782c upstream.
Need to clear both nodes and nodes_add state for start/end.
LKML-Reference: <20090718065657.GA2898@basil.fritz.box>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 8c5dd8f43367f4f266dd616f11658005bc2d20ef upstream.
On a system where system memory (according e820) is not covered by
mtrr, mtrr_trim_memory converts a portion of memory to reserved, but
bootloader has already put the initrd in that range.
Thus, we need to have 64bit to use relocate_initrd too.
[ Impact: fix using initrd when mtrr_trim_memory happen ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
commit 093bac154c142fa1fb31a3ac69ae1bc08930231b upstream.
Dell Optiplex 330 appears to hang on reboot. This is resolved by adding
a quirk to set bios reboot.
Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com>
Signed-off-by: Steve Conklin <steve.conklin@canonical.com>
Cc: Jean Delvare <khali@linux-fr.org>
commit 4a4aca641bc4598e77b866804f47c651ec4a764d upstream.
The Dell Optiplex 360 hangs on reboot, just like the Optiplex 330, so
the same quirk is needed.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Steve Conklin <steve.conklin@canonical.com>
Cc: Leann Ogasawara <leann.ogasawara@canonical.com>
LKML-Reference: <200906051202.38311.jdelvare@suse.de>
commit ff0c0874905fb312ca1491bbdac2653b0b48c20b upstream.
Impact: reactivate DMI quirks on EFI hardware
DMI tables are loaded by EFI, so the dmi calls must happen after
efi_init() and not before.
Currently Apple hardware uses DMI to determine the framebuffer mappings
for efifb. Without DMI working you also have no video on MacBook Pro.
This patch resolves the DMI issue for EFI hardware (DMI is now properly
detected at boot), and additionally efifb now loads on Apple hardware
(i.e. video works).
Signed-off-by: Brian Maly <bmaly@redhat>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Cc: ying.huang@intel.com
LKML-Reference: <49ADEDA3.1030406@redhat.com>
commit 75e613cdc7bb2ba3795b1bc3ddf19476c767ba68 upstream.
Pascal reported and bisected a commit:
| x86/PCI: don't call e820_all_mapped with -1 in the mmconfig case
which broke one system system.
ACPI: Using IOAPIC for interrupt routing
PCI: MCFG configuration 0: base f0000000 segment 0 buses 0 - 255
PCI: MCFG area at f0000000 reserved in ACPI motherboard resources
PCI: Using MMCONFIG for extended config space
it didn't have
PCI: updated MCFG configuration 0: base f0000000 segment 0 buses 0 - 63
anymore, and try to use 0xf000000 - 0xffffffff for mmconfig
For 32bit, mcfg_res->end could be 32bit only (if 64 resources aren't used)
So use end - 1 to pass the value in mcfg->end to avoid overflow.
We don't need to worry about the e820 path, they are always 64 bit.
Reported-by: Pascal Terjan <pterjan@mandriva.com>
Bisected-by: Pascal Terjan <pterjan@mandriva.com>
Tested-by: Pascal Terjan <pterjan@mandriva.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
shared or not
commit 32b154c0b0bae2879bf4e549d861caf1759a3546 upstream.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13302
On x86 and x86-64, it is possible that page tables are shared beween
shared mappings backed by hugetlbfs. As part of this,
page_table_shareable() checks a pair of vma->vm_flags and they must match
if they are to be shared. All VMA flags are taken into account, including
VM_LOCKED.
The problem is that VM_LOCKED is cleared on fork(). When a process with a
shared memory segment forks() to exec() a helper, there will be shared
VMAs with different flags. The impact is that the shared segment is
sometimes considered shareable and other times not, depending on what
process is checking.
What happens is that the segment page tables are being shared but the
count is inaccurate depending on the ordering of events. As the page
tables are freed with put_page(), bad pmd's are found when some of the
children exit. The hugepage counters also get corrupted and the Total and
Free count will no longer match even when all the hugepage-backed regions
are freed. This requires a reboot of the machine to "fix".
This patch addresses the problem by comparing all flags except VM_LOCKED
when deciding if pagetables should be shared or not for hugetlbfs-backed
mapping.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: <starlight@binnacle.cx>
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: Adam Litke <agl@us.ibm.com>
Cc: Andy Whitcroft <apw@canonical.com>
commit 211b3d03c7400f48a781977a50104c9d12f4e229 upstream
[Trivial backport to 2.6.27 by cebbert@redhat.com]
x86: work around Fedora-11 x86-32 kernel failures on Intel Atom CPUs
Impact: work around boot crash
Work around Intel Atom erratum AAH41 (probabilistically) - it's triggering
in the field.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Kyle McMartin <kyle@redhat.com>
Cc: <cebbert@redhat.com>
[ Upstream commit 42cc77c861e8e850e86252bb5b1e12e006261973 ]
Otherwise it might interrupt switch_to() midstream and use
half-cooked register window state.
Reported-by: Chris Torek <chris.torek@windriver.com>
[ Upstream commit d0cac39e4ec8097e4c7099d291b1fdcc0fe56b58 ]
Based upon a report by Meelis Roos.
Sparc64 SBUS and PCI controllers use a combination of IMAP and ICLR
registers to manage device interrupts.
The IMAP register contains the "valid" enable bit as well as CPU
targetting information. Whereas the ICLR register is written with
zero at the end of handling an interrupt to reset the state machine
for that interrupt to IDLE so it can be sent again.
For PCI slot and SBUS slot devices we can have multiple interrupts
sharing the same IMAP register. There are individual ICLR registers
but only one IMAP register for managing those.
We represent each shared case with individual virtual IRQs so the
generic IRQ layer thinks there is only one user of the IRQ instance.
In such shared IMAP cases this is wrong, so if there are multiple
active users then a free_irq() call will prematurely turn off the
interrupt by clearing the Valid bit in the IMAP register even though
there are other active users.
Fix this by simply doing nothing in sun4u_disable_irq() and checking
IRQF_DISABLED during IRQ dispatch.
This situation doesn't exist in the hypervisor sun4v cases, so I left
those alone.
Tested-by: Meelis Roos <mroos@linux.ee>
[ Upstream commit 192d7a4667c6d11d1a174ec4cad9a3c5d5f9043c ]
When you compile kernel on Sparc64 with heap memory checking and type
"cat /proc/iomem", you get a crash, because pointers in struct
resource are uninitialized.
Most code fills struct resource with zeros, so I assume that it is
responsibility of the caller of request_resource to initialized it,
not the responsibility of request_resource functuion.
After 2.6.29 is out, there could be a check for uninitialized fields
added to request_resource to avoid crashes like this.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
[ Upstream commit 86ee79c3dbd48d7430fd81edc1da3516c9f6dabc ]
tlb_flush_mmu() needs to flush pending TLB entries before
processing the mmu_gather ->pages list.
Noticed by Benjamin Herrenschmidt.
[ Upstream commit f9384d41c02408dd404aa64d66d0ef38adcf6479 ]
As explained by Benjamin Herrenschmidt:
> CPU 0 is running the context, task->mm == task->active_mm == your
> context. The CPU is in userspace happily churning things.
> CPU 1 used to run it, not anymore, it's now running fancyfsd which
> is a kernel thread, but current->active_mm still points to that
> same context.
> Because there's only one "real" user, mm_users is 1 (but mm_count is
> elevated, it's just that the presence on CPU 1 as active_mm has no
> effect on mm_count().
> At this point, fancyfsd decides to invalidate a mapping currently mapped
> by that context, for example because a networked file has changed
> remotely or something like that, using unmap_mapping_ranges().
> So CPU 1 goes into the zapping code, which eventually ends up calling
> flush_tlb_pending(). Your test will succeed, as current->active_mm is
> indeed the target mm for the flush, and mm_users is indeed 1. So you
> will -not- send an IPI to the other CPU, and CPU 0 will continue happily
> accessing the pages that should have been unmapped.
To fix this problem, check ->mm instead of ->active_mm, and this
means:
> So if you test current->mm, you effectively account for mm_users == 1,
> so the only way the mm can be active on another processor is as a lazy
> mm for a kernel thread. So your test should work properly as long
> as you don't have a HW that will do speculative TLB reloads into the
> TLB on that other CPU (and even if you do, you flush-on-switch-in should
> get rid of any crap here).
And therefore we should be OK.
If there is a dummy "espdma" or "ledma" parent device above ESP scsi
or LE ethernet device nodes, we have to match the bus as SBUS.
Otherwise the address and size cell counts are wrong and we don't
calculate the final physical device resource values correctly at all.
Commit 5280267c1dddb8d413595b87dc406624bb497946 ("sparc: Fix handling
of LANCE and ESP parent nodes in of_device.c") was meant to fix this
problem, but that only influences the inner loop of
build_device_resources(). We need this logic to also kick in at the
beginning of build_device_resources() as well, when we make the first
attempt to determine the device's immediate parent bus type for 'reg'
property element extraction.
Based almost entirely upon a patch by Friedrich Oslage.
[ Upstream commit 8e255baa449df3049a8827a7f1f4f12b6921d0d1 ]
Interrupts must be disabled when taking the IPI lock.
Caught by lockdep.
Reported-by: Meelis Roos <mroos@linux.ee>
Backport of upstream commits by:
Ralf Baechle <ralf@linux-mips.org>
Xiaotian Feng <Xiaotian.Feng@windriver.com>
upstream commits:
dbda6ac0897603f6c6dfadbbc37f9882177ec7ac
d6c178e9694e7e0c7ffe0289cf4389a498cac735
c189846ecf900cd6b3ad7d3cef5b45a746ce646b
Signed-off-by: dann frazier <dannf@debian.org>
commit 044cd80942e47b9de0915b627902adf05c52377f upstream.
e820_all_mapped need end is (addr + size) instead of (addr + size - 1)
Cc: stable@kernel.org
This has been backported to 2.6.27.x from commit efbda86098 in Linus' tree.
On powerpc64 machines running 32-bit userspace, we can get garbage bits in the
stack pointer passed into the kernel. Most places handle this correctly, but
the signal handling code uses the passed value directly for allocating signal
stack frames.
This fixes the issue by introducing a get_clean_sp function that returns a
sanitized stack pointer. For 32-bit tasks on a 64-bit kernel, the stack
pointer is masked correctly. In all other cases, the stack pointer is simply
returned.
Additionally, we pass an 'is_32' parameter to get_sigframe now in order to
get the properly sanitized stack. The callers are know to be 32 or 64-bit
statically.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
upstream commit: 306a82881b14d950d59e0b59a55093a07d82aa9a
Richard Henderson pointed out that the powerpc __futex_atomic_op has a
bug: it will write the wrong value if the stwcx. fails and it has to
retry the lwarx/stwcx. loop, since 'oparg' will have been overwritten
by the result from the first time around the loop. This happens
because it uses the same register for 'oparg' (an input) as it uses
for the result.
This fixes it by using separate registers for 'oparg' and 'ret'.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: 01522df346f846906eaf6ca57148641476209909
Jordan Hargrave diagnosed a BIOS clobbering %esi in the E820 call.
That particular BIOS has been fixed, but there is a possibility that
this is responsible for other occasional reports of early boot
failure, and it does not hurt to add %esi to the clobbers.
-stable candidate patch.
Cc: Justin Forbes <jmforbes@linuxtx.org>
Signed-off-by: Michael K Johnson <johnsonm@rpath.com>
upstream commit: 3ff42da5048649503e343a32be37b14a6a4e8aaf
Impact: bug fix + BIOS workaround
BIOS is expected to clear the SYSCFG[MtrrFixDramModEn] on AMD CPUs
after fixed MTRRs are configured.
Some BIOSes do not clear SYSCFG[MtrrFixDramModEn] on BP (and on APs).
This can lead to obfuscation in Linux when this bit is not cleared on
BP but cleared on APs. A consequence of this is that the saved
fixed-MTRR state (from BP) differs from the fixed-MTRRs of APs --
because RdDram/WrDram bits are read as zero when
SYSCFG[MtrrFixDramModEn] is cleared -- and Linux tries to sync
fixed-MTRR state from BP to AP. This implies that Linux sets
SYSCFG[MtrrFixDramEn] and activates those bits.
More important is that (some) systems change these bits in SMM when
ACPI is enabled. Hence it is racy if Linux modifies RdMem/WrMem bits,
too.
(1) The patch modifies an old fix from Bernhard Kaindl to get
suspend/resume working on some Acer Laptops. Bernhard's patch
tried to sync RdMem/WrMem bits of fixed MTRR registers and that
helped on those old Laptops. (Don't ask me why -- can't test it
myself). But this old problem was not the motivation for the
patch. (See http://lkml.org/lkml/2007/4/3/110)
(2) The more important effect is to fix issues on some more current systems.
On those systems Linux panics or just freezes, see
http://bugzilla.kernel.org/show_bug.cgi?id=11541
(and also duplicates of this bug:
http://bugzilla.kernel.org/show_bug.cgi?id=11737
http://bugzilla.kernel.org/show_bug.cgi?id=11714)
The affected systems boot only using acpi=ht, acpi=off or
when the kernel is built with CONFIG_MTRR=n.
The acpi options prevent full enablement of ACPI. Obviously when
ACPI is enabled the BIOS/SMM modfies RdMem/WrMem bits. When
CONFIG_MTRR=y Linux also accesses and modifies those bits when it
needs to sync fixed-MTRRs across cores (Bernhard's fix, see (1)).
How do you synchronize that? You can't. As a consequence Linux
shouldn't touch those bits at all (Rationale are AMD's BKDGs which
recommend to clear the bit that makes RdMem/WrMem accessible).
This is the purpose of this patch. And (so far) this suffices to
fix (1) and (2).
I suggest not to touch RdDram/WrDram bits of fixed-MTRRs and
SYSCFG[MtrrFixDramEn] and to clear SYSCFG[MtrrFixDramModEn] as
suggested by AMD K8, and AMD family 10h/11h BKDGs.
BIOS is expected to do this anyway. This should avoid that
Linux and SMM tread on each other's toes ...
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: trenn@suse.de
Cc: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20090312163937.GH20716@alberich.amd.com>
Cc: <stable@kernel.org>
upstream commit: 9cdec049389ce2c324fd1ec508a71528a27d4a07
While looking at the issue in the thread:
http://marc.info/?l=dri-devel&m=123606627824556&w=2
noticed a bug in pci PAT code and memory type setting.
PCI mmap code did not set the proper protection in vma, when it
inherited protection in reserve_memtype. This bug only affects
the case where there exists a WC mapping before X does an mmap
with /proc or /sys pci interface. This will cause X userlevel
mmap from /proc or /sysfs to fail on fork.
Reported-by: Kevin Winchester <kjwinchester@gmail.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Dave Airlie <airlied@redhat.com>
LKML-Reference: <20090323190720.GA16831@linux-os.sc.intel.com>
TSEC/MDIO will not work with older device trees because of a semicolon
at the end of a macro resulting in an empty for loop body.
This fix only applies to 2.6.28; this code is gone in 2.6.29, according
to Grant Likely!
Signed-off-by: Johns Daniel <johns.daniel@gmail.com>
Fix misreporting of #cores for the Intel Quad Core Q9550.
For the Q9550, in x86_64 mode, /proc/cpuinfo mistakenly
reports the #cores present as the #hyperthreads present.
i386 mode was not examined but is assumed to have the
same problem.
A backport of the following three 2.6.29-rc1 patches
fixes the problem:
066941bd4eeb159307a5d7d795100d0887c00442:
[PATCH] x86: unmask CPUID levels on Intel CPUs
99fb4d349db7e7dacb2099c5cc320a9e2d31c1ef:
[PATCH] x86: unmask CPUID levels on Intel CPUs, fix
bdf21a49bab28f0d9613e8d8724ef9c9168b61b9:
[PATCH] x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h>
From the first patch: "If the CPUID limit bit in
MSR_IA32_MISC_ENABLE is set, clear it to make all CPUID
information available. This is required for some features
to work, in particular XSAVE."
Originally-Developed-by: H. Peter Anvin <hpa@linux.intel.com>
Backported-by: Joe Korty <joe.korty@ccur.com>
Signed-off-by: Joe Korty <joe.korty@ccur.com>
