path: root/arch
2010-09-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc: Kill all BKL usage.
2010-09-10x86, tsc: Fix a preemption leak in restore_sched_clock_state()Peter Zijlstra
A real life genuine preemption leak.. Reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-10Merge branch 'kvm-updates/2.6.36' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.36' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: Perform hardware_enable in CPU_STARTING callback KVM: i8259: fix migration KVM: fix i8259 oops when no vcpus are online KVM: x86 emulator: fix regression with cmpxchg8b on i386 hosts
2010-09-10Merge branch 'at91-fixes-for-linus' of git://github.com/at91linux/linux-2.6-at91Linus Torvalds
* 'at91-fixes-for-linus' of git://github.com/at91linux/linux-2.6-at91: AT91: at91sam9261ek: remove C99 comments but keep information AT91: at91sam9261ek board: remove warnings related to use of SPI or SD/MMC AT91: dm9000 initialization update AT91: SAM9G45 - add a separate clock entry for every single TC block AT91: clock: peripheral clocks can have other parent than mck AT91: change dma resource index
2010-09-10AT91: at91sam9261ek: remove C99 comments but keep informationNicolas Ferre
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-09-10AT91: at91sam9261ek board: remove warnings related to use of SPI or SD/MMCNicolas Ferre
The sd/mmc data structure is not used if SPI is selected. The configuration of PIO on the board prevent from using both interfaces at the same time (board dependent). Remove the warnings at compilation time adding a preprocessor condition. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-09-10AT91: dm9000 initialization updateNicolas Ferre
Add information in dm9000 mac/phy chip initialization: - irq resource details - platform data details Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-09-09arch/powerpc/include/asm/fsldma.h needs slab.hIra W. Snyder
The slab.h header is required to use the kmalloc() family of functions. Due to recent kernel changes, this header must be directly included by code that calls into the memory allocator. Without this patch, any code which includes this header fails to build. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-09Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (30 commits) ARM: Update mach-types ARM: Partially revert "Auto calculate ZRELADDR and provide option for exceptions" ARM: Ensure PTE modifications via dma_alloc_coherent are visible ARM: 6359/1: ep93xx: move clock initialization earlier Revert "[ARM] pxa: remove now unnecessary dma_needs_bounce()" ARM: 6352/1: perf: fix event validation ARM: 6344/1: Mark CPU_32v6K as depended on CPU_V7 ARM: 6343/1: wire up fanotify and prlimit64 syscalls on ARM ARM: 6330/1: perf: reword comments relating to perf_event_do_pending ARM: pxa168fb: fix section mismatch ARM: pxa: Make id const in pwm_probe() ARM: pxa: fix CI_HSYNC and CI_VSYNC MFP defines for pxa300 ARM: pxa: remove __init from cpufreq_driver->init() ARM: imx: set cache line size to 64 bytes for i.MX5 mx5/clock: fix clear bit fields issue in _clk_ccgr_disable function mxc/tzic: add base address when accessing TZIC registers ARM: mach-shmobile: ap4evb: fix write protect for SDHI1 ARM: mach-shmobile: ap4evb: modify FSI2 ID ARM: mach-shmobile: do not enable the PLLC2 clock on init ARM: mach-shmobile: Clock framework comment fix ...
2010-09-09ARM: Update mach-typesRussell King
2010-09-09ARM: Partially revert "Auto calculate ZRELADDR and provide option for ↵Russell King
exceptions" Partially revert e69edc7, which introduced automatic zreladdr support. The change in the way the manual definition is defined seems to be error and conflict prone. Go back to the original way we were handling this for the time being, while keeping the automatic zreladdr facility. Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-09Merge branch 'origin'Russell King
2010-09-09AT91: SAM9G45 - add a separate clock entry for every single TC blockFabian Godehardt
Without this patch you will not be able to register the first block because of the second association call on at91_add_device_tc(). Signed-off-by: Fabian Godehardt <fg@emlix.com> [nicolas.ferre@atmel.com: change tcb1_clk to fake child clock of tcb0_clk] Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-09-09AT91: clock: peripheral clocks can have other parent than mckNicolas Ferre
While registering clock allow to set parent clock other than mck. It is useful for clocks than can be seen as child clock of a peripheral. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Andrew Victor <linux@maxim.org.za>
2010-09-08sparc: Kill all BKL usage.David S. Miller
They were all bogus artifacts and completely unnecessary. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mcheck: Avoid duplicate sysfs links/files for thresholding banks io-mapping: Fix the address space annotations x86: Fix the address space annotations of iomap_atomic_prot_pfn() x86, mm: Fix CONFIG_VMSPLIT_1G and 2G_OPT trampoline x86, hwmon: Fix unsafe smp_processor_id() in thermal_throttle_add_dev
2010-09-08Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, x86: Try to handle unknown nmis with an enabled PMU perf, x86: Fix handle_irq return values perf, x86: Fix accidentally ack'ing a second event on intel perf counter oprofile, x86: fix init_sysfs() function stub lockup_detector: Sync touch_*_watchdog back to old semantics tracing: Fix a race in function profile oprofile, x86: fix init_sysfs error handling perf_events: Fix time tracking for events with pid != -1 and cpu != -1 perf: Initialize callchains roots's childen hits oprofile: fix crash when accessing freed task structs
2010-09-08KVM: i8259: fix migrationGleb Natapov
Top of kvm_kpic_state structure should have the same memory layout as kvm_pic_state since it is copied by memcpy. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-09-08KVM: fix i8259 oops when no vcpus are onlineAvi Kivity
If there are no vcpus, found will be NULL. Check before doing anything with it. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-09-08KVM: x86 emulator: fix regression with cmpxchg8b on i386 hostsAvi Kivity
operand::val and operand::orig_val are 32-bit on i386, whereas cmpxchg8b operands are 64-bit. Fix by adding val64 and orig_val64 union members to struct operand, and using them where needed. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-09-08ARM: Ensure PTE modifications via dma_alloc_coherent are visibleRussell King
Dave Hylands reports: | We've observed a problem with dma_alloc_writecombine when the system | is under heavy load (heavy bus traffic). We've managed to reduce the | problem to the following snippet, which is run from a kthread in a | continuous loop: | | void *virtAddr; | dma_addr_t physAddr; | unsigned int numBytes = 256; | | for (;;) { | virtAddr = dma_alloc_writecombine(NULL, | numBytes, &physAddr, GFP_KERNEL); | if (virtAddr == NULL) { | printk(KERN_ERR "Running out of memory\n"); | break; | } | | /* access DMA memory allocated */ | tmp = virtAddr; | *tmp = 0x77; | | /* free DMA memory */ | dma_free_writecombine(NULL, | numBytes, virtAddr, physAddr); | | ...sleep here... | } | | By itself, the code will run forever with no issues. However, as we | increase our bus traffic (typically using DMA) then the *tmp = 0x77 | line will eventually cause a page fault. If we add a small delay (a | few microseconds) before the *tmp = 0x77, then we don't see a page | fault, even under heavy load. A dsb() is required after modifying the PTE entries to ensure that they will always be visible. Add this dsb(). Reported-by: Dave Hylands <dhylands@gmail.com> Tested-by: Dave Hylands <dhylands@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-08ARM: 6359/1: ep93xx: move clock initialization earlierMika Westerberg
Commit 7cfe24947 ("ARM: AMBA: Add pclk support to AMBA bus infrastructure") changed AMBA bus to handle the PCLK automatically. However, in EP93xx clock initialization is arch_initcall which is done later than AMBA device identification. This causes amba_get_enable_pclk() to fail resulting device where UARTs are not functional. So change ep93xx_clock_init() to be postcore_initcall. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-08Revert "[ARM] pxa: remove now unnecessary dma_needs_bounce()"Russell King
This reverts commit 4fa5518, which causes a compilation regression for IXP4xx platforms. Reported-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: bus speed strings should be const PCI hotplug: Fix build with CONFIG_ACPI unset PCI: PCIe: Remove the port driver module exit routine PCI: PCIe: Move PCIe PME code to the pcie directory PCI: PCIe: Disable PCIe port services during port initialization PCI: PCIe: Ask BIOS for control of all native services at once ACPI/PCI: Negotiate _OSC control bits before requesting them ACPI/PCI: Do not preserve _OSC control bits returned by a query ACPI/PCI: Make acpi_pci_query_osc() return control bits ACPI/PCI: Reorder checks in acpi_pci_osc_control_set() PCI: PCIe: Introduce commad line switch for disabling port services PCI: PCIe AER: Introduce pci_aer_available() x86/PCI: only define pci_domain_nr if PCI and PCI_DOMAINS are set PCI: provide stub pci_domain_nr function for !CONFIG_PCI configs
2010-09-07Merge branch 'for-linus' of git://android.kernel.org/kernel/tegraLinus Torvalds
* 'for-linus' of git://android.kernel.org/kernel/tegra: [ARM] tegra: Add ZRELADDR default for ARCH_TEGRA
git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6: alpha: Fix printk format errors alpha: convert perf_event to use local_t Fix call to replaced SuperIO functions alpha: remove homegrown L1_CACHE_ALIGN macro
2010-09-07Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/pseries: Correct rtas_data_buf locking in dlpar code powerpc/85xx: Add P1021 PCI IDs and quirks arch/powerpc/sysdev/qe_lib/qe.c: Add of_node_put to avoid memory leak arch/powerpc/platforms/83xx/mpc837x_mds.c: Add missing iounmap fsl_rio: fix compile errors powerpc/85xx: Fix compile issue with p1022_ds due to lmb rename to memblock powerpc/85xx: Fix compilation of mpc85xx_mds.c powerpc: Don't use kernel stack with translation off powerpc/perf_event: Reduce latency of calling perf_event_do_pending powerpc/kexec: Adds correct calling convention for kexec purgatory
2010-09-07m68knommu: fix missing linker segmentsGreg Ungerer
Recent changes to linker segments that hold per-cpu data broke linking for m68knommu targets: LD vmlinux /usr/local/bin/m68k-uclinux-ld.real: error: no memory region specified for loadable section `.data..shared_aligned' Add missing segments into the m68knommu linker script. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: Fix missing consts in kernel_execve()David Howells
Fix missing consts in h8300's kernel_execve(): arch/h8300/kernel/sys_h8300.c: In function 'kernel_execve': arch/h8300/kernel/sys_h8300.c:59: warning: initialization from incompatible pointer type arch/h8300/kernel/sys_h8300.c:60: warning: initialization from incompatible pointer type Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: Fix die()David Howells
Fix h8300's die() to take care of a number of problems: CC arch/h8300/kernel/traps.o In file included from arch/h8300/include/asm/bitops.h:10, from include/linux/bitops.h:22, from include/linux/kernel.h:17, from include/linux/sched.h:54, from arch/h8300/kernel/traps.c:18: arch/h8300/include/asm/system.h:136: warning: 'struct pt_regs' declared inside parameter list arch/h8300/include/asm/system.h:136: warning: its scope is only this definition or declaration, which is probably not what you want arch/h8300/kernel/traps.c:100: error: conflicting types for 'die' arch/h8300/include/asm/system.h:136: error: previous declaration of 'die' was here make[2]: *** [arch/h8300/kernel/traps.o] Error 1 Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07h8300: IRQ flags should be stored in an unsigned longDavid Howells
Fix h8300's asm/atomic.h to store the IRQ flags in an unsigned long to deal with warnings of the following type: arch/h8300/include/asm/atomic.h: In function 'atomic_add_return': arch/h8300/include/asm/atomic.h:22: warning: comparison of distinct pointer types lacks a cast arch/h8300/include/asm/atomic.h:24: warning: comparison of distinct pointer types lacks a cast Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-07AT91: change dma resource indexNicolas Ferre
Reported-by: Dan Liang <dan.liang@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-09-05x86, mcheck: Avoid duplicate sysfs links/files for thresholding banksAndreas Herrmann
kobject_add_internal failed for threshold_bank2 with -EEXIST, don't try to register things with the same name in the same directory: Pid: 1, comm: swapper Tainted: G W 2.6.31 #1 Call Trace: [<ffffffff81161b07>] ? kobject_add_internal+0x156/0x180 [<ffffffff81161cc0>] ? kobject_add+0x66/0x6b [<ffffffff81161793>] ? kobject_init+0x42/0x82 [<ffffffff81161cf9>] ? kobject_create_and_add+0x34/0x63 [<ffffffff81393963>] ? threshold_create_bank+0x14f/0x259 [<ffffffff8139310a>] ? mce_create_device+0x8d/0x1b8 [<ffffffff81646497>] ? threshold_init_device+0x3f/0x80 [<ffffffff81646458>] ? threshold_init_device+0x0/0x80 [<ffffffff81009050>] ? do_one_initcall+0x4f/0x143 [<ffffffff816413a0>] ? kernel_init+0x14c/0x1a2 [<ffffffff8100c8da>] ? child_rip+0xa/0x20 [<ffffffff81641254>] ? kernel_init+0x0/0x1a2 [<ffffffff8100c8d0>] ? child_rip+0x0/0x20 kobject_create_and_add: kobject_add error: -17 (Probably the for_each_cpu loop should be entirely removed.) Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> LKML-Reference: <20100827092006.GB5348@loge.amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-05x86: Fix the address space annotations of iomap_atomic_prot_pfn()Francisco Jerez
This patch fixes the sparse warnings when the return pointer of iomap_atomic_prot_pfn() is used as an argument of iowrite32() and friends. Signed-off-by: Francisco Jerez <currojerez@riseup.net> LKML-Reference: <1283633804-11749-1-git-send-email-currojerez@riseup.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-03perf, x86: Try to handle unknown nmis with an enabled PMURobert Richter
When the PMU is enabled it is valid to have unhandled nmis, two events could trigger 'simultaneously' raising two back-to-back NMIs. If the first NMI handles both, the latter will be empty and daze the CPU. The solution to avoid an 'unknown nmi' massage in this case was simply to stop the nmi handler chain when the PMU is enabled by stating the nmi was handled. This has the drawback that a) we can not detect unknown nmis anymore, and b) subsequent nmi handlers are not called. This patch addresses this. Now, we check this unknown NMI if it could be a PMU back-to-back NMI. Otherwise we pass it and let the kernel handle the unknown nmi. This is a debug log: cpu #6, nmi #32333, skip_nmi #32330, handled = 1, time = 1934364430 cpu #6, nmi #32334, skip_nmi #32330, handled = 1, time = 1934704616 cpu #6, nmi #32335, skip_nmi #32336, handled = 2, time = 1936032320 cpu #6, nmi #32336, skip_nmi #32336, handled = 0, time = 1936034139 cpu #6, nmi #32337, skip_nmi #32336, handled = 1, time = 1936120100 cpu #6, nmi #32338, skip_nmi #32336, handled = 1, time = 1936404607 cpu #6, nmi #32339, skip_nmi #32336, handled = 1, time = 1937983416 cpu #6, nmi #32340, skip_nmi #32341, handled = 2, time = 1938201032 cpu #6, nmi #32341, skip_nmi #32341, handled = 0, time = 1938202830 cpu #6, nmi #32342, skip_nmi #32341, handled = 1, time = 1938443743 cpu #6, nmi #32343, skip_nmi #32341, handled = 1, time = 1939956552 cpu #6, nmi #32344, skip_nmi #32341, handled = 1, time = 1940073224 cpu #6, nmi #32345, skip_nmi #32341, handled = 1, time = 1940485677 cpu #6, nmi #32346, skip_nmi #32347, handled = 2, time = 1941947772 cpu #6, nmi #32347, skip_nmi #32347, handled = 1, time = 1941949818 cpu #6, nmi #32348, skip_nmi #32347, handled = 0, time = 1941951591 Uhhuh. NMI received for unknown reason 00 on CPU 6. Do you have a strange power saving mode enabled? Dazed and confused, but trying to continue Deltas: nmi #32334 340186 nmi #32335 1327704 nmi #32336 1819 <<<< back-to-back nmi [1] nmi #32337 85961 nmi #32338 284507 nmi #32339 1578809 nmi #32340 217616 nmi #32341 1798 <<<< back-to-back nmi [2] nmi #32342 240913 nmi #32343 1512809 nmi #32344 116672 nmi #32345 412453 nmi #32346 1462095 <<<< 1st nmi (standard) handling 2 counters nmi #32347 2046 <<<< 2nd nmi (back-to-back) handling one counter nmi #32348 1773 <<<< 3rd nmi (back-to-back) handling no counter! [3] For back-to-back nmi detection there are the following rules: The PMU nmi handler was handling more than one counter and no counter was handled in the subsequent nmi (see [1] and [2] above). There is another case if there are two subsequent back-to-back nmis [3]. The 2nd is detected as back-to-back because the first handled more than one counter. If the second handles one counter and the 3rd handles nothing, we drop the 3rd nmi because it could be a back-to-back nmi. Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> [ renamed nmi variable to pmu_nmi to avoid clash with .nmi in entry.S ] Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: peterz@infradead.org Cc: gorcunov@gmail.com Cc: fweisbec@gmail.com Cc: ying.huang@intel.com Cc: ming.m.lin@intel.com Cc: eranian@google.com LKML-Reference: <1283454469-1909-3-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-03perf, x86: Fix handle_irq return valuesPeter Zijlstra
Now that we rely on the number of handled overflows, ensure all handle_irq implementations actually return the right number. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: peterz@infradead.org Cc: robert.richter@amd.com Cc: gorcunov@gmail.com Cc: fweisbec@gmail.com Cc: ying.huang@intel.com Cc: ming.m.lin@intel.com Cc: eranian@google.com LKML-Reference: <1283454469-1909-4-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-03perf, x86: Fix accidentally ack'ing a second event on intel perf counterDon Zickus
During testing of a patch to stop having the perf subsytem swallow nmis, it was uncovered that Nehalem boxes were randomly getting unknown nmis when using the perf tool. Moving the ack'ing of the PMI closer to when we get the status allows the hardware to properly re-set the PMU bit signaling another PMI was triggered during the processing of the first PMI. This allows the new logic for dealing with the shortcomings of multiple PMIs to handle the extra NMI by 'eat'ing it later. Now one can wonder why are we getting a second PMI when we disable all the PMUs in the begining of the NMI handler to prevent such a case, for that I do not know. But I know the fix below helps deal with this quirk. Tested on multiple Nehalems where the problem was occuring. With the patch, the code now loops a second time to handle the second PMI (whereas before it was not). Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: peterz@infradead.org Cc: robert.richter@amd.com Cc: gorcunov@gmail.com Cc: fweisbec@gmail.com Cc: ying.huang@intel.com Cc: ming.m.lin@intel.com Cc: eranian@google.com LKML-Reference: <1283454469-1909-2-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-02ARM: 6352/1: perf: fix event validationWill Deacon
The validate_event function in the ARM perf events backend has the following problems: 1.) Events that are disabled count towards the cost. 2.) Events associated with other PMUs [for example, software events or breakpoints] do not count towards the cost, but do fail validation, causing the group to fail. This patch changes validate_event so that it ignores events in the PERF_EVENT_STATE_OFF state or that are scheduled for other PMUs. Reported-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Jamie Iles <jamie.iles@picochip.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-02ARM: 6344/1: Mark CPU_32v6K as depended on CPU_V7Catalin Marinas
CPU_32v6K is selected by CPU_V7 but it only depends on CPU_V6. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-02powerpc/pseries: Correct rtas_data_buf locking in dlpar codeNathan Fontenot
The dlpar code can cause a deadlock to occur when making the RTAS configure-connector call. This occurs because we make kmalloc calls, which can block, while parsing the rtas_data_buf and holding the rtas_data_buf_lock. This an cause issues if someone else attempts to grab the rtas_data_bug_lock. This patch alleviates this issue by copying the contents of the rtas_data_buf to a local buffer before parsing. This allows us to only hold the rtas_data_buf_lock around the RTAS configure-connector calls. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-09-01[ARM] tegra: Add ZRELADDR default for ARCH_TEGRAErik Gilling
fixes the warning: .config:369:warning: symbol value '' invalid for ZRELADDR and the prompt for ZRELADDR on make Signed-off-by: Erik Gilling <konkers@android.com>
2010-09-01Merge branch 'urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
2010-09-01oprofile, x86: fix init_sysfs() function stubRobert Richter
The use of the return value of init_sysfs() with commit 10f0412 oprofile, x86: fix init_sysfs error handling discovered the following build error for !CONFIG_PM: .../linux/arch/x86/oprofile/nmi_int.c: In function ‘op_nmi_init’: .../linux/arch/x86/oprofile/nmi_int.c:784: error: expected expression before ‘do’ make[2]: *** [arch/x86/oprofile/nmi_int.o] Error 1 make[1]: *** [arch/x86/oprofile] Error 2 This patch fixes this. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: stable@kernel.org Signed-off-by: Robert Richter <robert.richter@amd.com>
2010-09-01alpha: Fix printk format errorsMichael Cree
When compiling alpha generic build get errors such as: arch/alpha/kernel/err_marvel.c: In function ‘marvel_print_err_cyc’: arch/alpha/kernel/err_marvel.c:119: error: format ‘%ld’ expects type ‘long int’, but argument 6 has type ‘u64’ Replaced a number of %ld format specifiers with %lld since u64 is unsigned long long. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
2010-09-01Merge branch 'imx-for-2.6.36' of git://git.pengutronix.de/git/imx/linux-2.6Russell King
2010-09-01Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
2010-09-01Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/genesis-2.6Russell King
2010-09-01ARM: 6343/1: wire up fanotify and prlimit64 syscalls on ARMMikael Pettersson
The 2.6.36-rc kernel added three new system calls: fanotify_init, fanotify_mark, and prlimit64. This patch wires them up on ARM. The only non-trivial issue here is the u64 argument to sys_fanotify_mark(), but it is the 3rd argument and thus passed in r2/r3 in both kernel and user space, so it causes no problems. Tested with a 2.6.36-rc2 EABI kernel on an ixp4xx machine. Tested-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-01ARM: 6330/1: perf: reword comments relating to perf_event_do_pendingWill Deacon
This is purely a cosmetic change to the ARM perf backend because the current comments about the relationship between NMIs, interrupt context and perf_event_do_pending are misleading. This patch updates the comments so that they reflect what the code actually does (which is in line with other architectures). Acked-by: Jamie Iles <jamie.iles@picochip.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-31alpha: convert perf_event to use local_tMichael Cree
Updates the Alpha perf_event code to match the changes recently made to the core perf_event code in commit e78505958cf123048fb48cb56b79cebb8edd15fb. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Matt Turner <mattst88@gmail.com>
