path: root/arch
2007-06-11[PATCH] SPARC64: Don't be picky about virtual-dma values on sun4v.David Miller
Handle arbitrary base and length values as long as they are multiples of IO_PAGE_SIZE. Bug found by Arun Kumar Rao. Signed-off-by: David S. Miller <davem@davemloft.net> [chrisw: backport to 2.6.20] Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] SPARC64: Fix _PAGE_EXEC_4U check in sun4u I-TLB miss handler.David Miller
It was using an immediate _PAGE_EXEC_4U value in an 'and' instruction to perform the test. This doesn't work because the immediate field is signed 13-bit, this the mask being tested against the PTE was 0x1000 sign-extended to 32-bits instead of just plain 0x1000. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] SPARC64: Fix two bugs wrt. kernel 4MB TSB.David Miller
1) The TSB lookup was not using the correct hash mask. 2) It was not aligned on a boundary equal to it's size, which is required by the sun4v Hypervisor. wasn't having it's return value checked, and that bug will be fixed up as well in a subsequent changeset. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-06-11[PATCH] iop13xx: fix i/o address translationDan Williams
PCI devices were being programmed with an incorrect base address value. This patch moves I/O space into a 16-bit addressable region and corrects the i/o offset. Much thanks to Martin Michlmayr for tracking this issue and testing debug patches. Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-11[PATCH] x86-64: Always flush all pages in change_page_attrAndi Kleen
change_page_attr on x86-64 only flushed the TLB for pages that got reverted. That's not correct: it has to be flushed in all cases. This bug was added in some earlier changes. Just flush all pages for now. This could be done more efficiently, but for this late in the release this seem to be the best fix. Pointed out by Jan Beulich Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01x86: Don't probe for DDC on VBE1.2Zwane Mwaikambo
[PATCH] x86: Don't probe for DDC on VBE1.2 VBE1.2 doesn't support function 15h (DDC) resulting in a 'hang' whilst uncompressing kernel with some video cards. Make sure we check VBE version before fiddling around with DDC. http://bugzilla.kernel.org/show_bug.cgi?id=1458 Opened: 2003-10-30 09:12 Last update: 2007-02-13 22:03 Much thanks to Tobias Hain for help in testing and investigating the bug. Tested on; i386, Chips & Technologies 65548 VESA VBE 1.2 CONFIG_VIDEO_SELECT=Y CONFIG_FIRMWARE_EDID=Y Untested on x86_64. Signed-off-by: Zwane Mwaikambo <zwane@infradead.org> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01cache_k8_northbridges() overflows beyond allocationBadari Pulavarty
cache_k8_northbridges() overflows beyond allocation cache_k8_northbridges() is storing config values to incorrect locations (in flush_words) and also its overflowing beyond the allocation, causing slab verification failures. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01Fix bogus inline directive in sparc64 PCI codeTom "spot" Callaway
[SPARC64]: Fix inline directive in pci_iommu.c While building a test kernel for the new esp driver (against git-current), I hit this bug. Trivial fix, put the inline declaration in the right place. :) Signed-off-by: Tom "spot" Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01Fix compat sys_ipc() on sparc64David Miller
The 32-bit syscall trampoline for sys_ipc() on sparc64 was sign extending various arguments, which is bogus when using compat_sys_ipc() since that function expects zero extended copies of all the arguments. This bug breaks the sparc64 kernel when built with gcc-4.2.x among other things. [SPARC64]: Fix arg passing to compat_sys_ipc(). Do not sign extend args using the sys32_ipc stub, that is buggy and unnecessary. Based upon an excellent report by Mikael Pettersson. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-01Fix sparc64 SBUS IOMMU allocatorDavid Miller
[SPARC64]: Fix SBUS IOMMU allocation code. There are several IOMMU allocator bugs. Instead of trying to fix this overly complicated code, just mirror the PCI IOMMU arena allocator which is very stable and well stress tested. I tried to make the code as identical as possible so we can switch sun4u PCI and SBUS over to a common piece of IOMMU code. All that will be need are two callbacks, one to do a full IOMMU flush and one to do a streaming buffer flush. This patch gets rid of a lot of hangs and mysterious crashes on SBUS sparc64 systems, at least for me. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-13i386: fix file_read_actor() and pipe_read() for original i386 systemsThomas Gleixner
The __copy_to_user_inatomic() calls in file_read_actor() and pipe_read() are broken on original i386 machines, where WP-works-ok == false, as __copy_to_user_inatomic() on such systems calls functions which might sleep and/or contain cond_resched() calls inside of a kmap_atomic() region. The original check for WP-works-ok was in access_ok(), but got moved during the 2.5 series to fix a race vs. swap. Return the number of bytes to copy in the case where we are in an atomic region, so the non atomic code pathes in file_read_actor() and pipe_read() are taken. This could be optimized to avoid the kmap_atomic by moving the check for WP-works-ok into fault_in_pages_writeable(), but this is more intrusive and can be done later. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06uml: fix unreasonably long udelayPaolo 'Blaisorblade' Giarrusso
Currently we have a confused udelay implementation. * __const_udelay does not accept usecs but xloops in i386 and x86_64 * our implementation requires usecs as arg * it gets a xloops count when called by asm/arch/delay.h Bugs related to this (extremely long shutdown times) where reported by some x86_64 users, especially using Device Mapper. To hit this bug, a compile-time constant time parameter must be passed - that's why UML seems to work most times. Fix this with a simple udelay implementation. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06UML - use correct register file size everywhereJeff Dike
This patch uses MAX_REG_NR consistently to refer to the register file size. FRAME_SIZE isn't sufficient because on x86_64, it is smaller than the ptrace register file size. MAX_REG_NR was introduced as a consistent way to get the number of registers, but wasn't used everywhere it should be. When this causes a problem, it makes PTRACE_SETREGS fail on x86_64 because of a corrupted segment register value in the known-good register file. The patch also adds a register dump at that point in case there are any future problems here. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-06UML - host VDSO fixJeff Dike
This fixes a problem seen by a number of people running UML on newer host kernels. init would hang with an infinite segfault loop. It turns out that the host kernel was providing a AT_SYSINFO_EHDR of 0xffffe000, which faked UML into believing that the host VDSO page could be reused. However, AT_SYSINFO pointed into the middle of the address space, and was unmapped as a result. Because UML was providing AT_SYSINFO_EHDR and AT_SYSINFO to its own processes, these would branch to nowhere when trying to use the VDSO. The fix is to also check the location of AT_SYSINFO when deciding whether to use the host's VDSO. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23Fix niagara memory corruptionDavid Miller
[SPARC64]: store-init needs trailing membar. The manual says that it is required and we actually have crash reports where loads see stale data due to not having membars here. In one case the networking does: memset(skb, 0, offsetof(struct sk_buff, truesize)); and then some code later checks skb->nohdr for zero, but it's still the value that was there before the memset(). Note that arch/sparc64/lib/xor.S already got this right. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23UML - arch_prctl should set thread fsJeff Dike
x86_64 needs some TLS fixes. What was missing was remembering the child thread id during clone and stuffing it into the child during each context switch. The %fs value is stored separately in the thread structure since the host controls what effect it has on the actual register file. The host also needs to store it in its own thread struct, so we need the value kept outside the register file. arch_prctl_skas was fixed to call PTRACE_ARCH_PRCTL appropriately. There is some saving and restoring of registers in the ARCH_SET_* cases so that the correct set of registers are changed on the host and restored to the process when it runs again. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23Fix page allocation debugging on sparc64David Miller
[SPARC64]: Get DEBUG_PAGEALLOC working again. We have to make sure to use base-pagesize TLB entries even during the early transition period where we need TLB miss handling but don't have the kernel page tables setup yet for the linear region. Also, it is necessary therefore to not use the 4MB TSB for these translations, and instead use the normal kernel TSB. This allows us to also get rid of the 4MB tsb for debug builds which shrinks the kernel a little bit. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23Fix sparc64 hugepage bugsDavid Miller
[SPARC64]: Add missing HPAGE_MASK masks on address parameters. These pte loops all assume the passed in address is HPAGE aligned, make sure that is actually true. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-23IA64: fix NULL pointer in ia64/irq_chip-mask/unmask functionKAMEZAWA Hiroyuki
[IA64] fix NULL pointer in ia64/irq_chip-mask/unmask function This patch fixes boot failure because irq_desc->mask() is NULL. - Added mask/unmask functions to ia64's irq desc function table. - rename hw_interrupt_type to irq_chip. hw_interrupt_type is old name. - Tony: Added same change to arch/ia64/sn/kernel/irq.c as pointed out by Eric Biederman ... mask/unmask functions there can be no-op. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tony Luck <tony.luck@intel.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-13Fix sparc64 device register probingDavid Miller
[SPARC]: Fix bus handling in build_device_resources(). We mistakedly modify 'bus' in the innermost loop. What should happen is that at each register index iteration, we start with the same 'bus'. So preserve it's value at the top level, and use a loop local variable 'dbus' for iteration. This bug causes registers other than the first to be decoded improperly. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09x86-64: survive having no irq mapping for a vectorEric W. Biederman
Occasionally the kernel has bugs that result in no irq being found for a given cpu vector. If we acknowledge the irq the system has a good chance of continuing even though we dropped an irq message. If we continue to simply print a message and not acknowledge the irq the system is likely to become non-responsive shortly there after. AK: Fixed compilation for UP kernels Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: "Luigi Genoni" <luigi.genoni@pirelli.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-03-09ATA: convert GSI to irq on ia64Zhang, Yanmin
If an ATA drive uses legacy mode, ata driver will choose 14 and 15 as the fixed irq number. On ia64 platform, such numbers are GSI and should be converted to irq vector. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09m32r: build fix for processors without ISA_DSP_LEVEL2Hirokazu Takata
Additional fixes for processors without ISA_DSP_LEVEL2. sigcontext_t does not have dummy_acc1h, dummy_acc1l members any longer. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09Fix MTRR compat ioctlZwane Mwaikambo
The MTRR compat code wasn't calling the lowlevel MTRR setup due to a switch block not handling the compat case. Before: (WW) I810(0): Failed to set up write-combining range (0xd0000000,0x10000000) After: reg00: base=0x00000000 ( 0MB), size=1024MB: write-back, count=1 reg01: base=0x40000000 (1024MB), size= 512MB: write-back, count=1 reg02: base=0x5f700000 (1527MB), size= 1MB: uncachable, count=1 reg03: base=0x5f800000 (1528MB), size= 8MB: uncachable, count=1 reg04: base=0xd0000000 (3328MB), size= 256MB: write-combining, count=1 Signed-off-by: Zwane Mwaikambo <zwane@infradead.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09kexec: Fix CONFIG_SMP=n compilation V2 (ia64)Magnus Damm
Kexec support for 2.6.20 on ia64 does not build properly using a config made up by CONFIG_SMP=n and CONFIG_HOTPLUG_CPU=n: CC arch/ia64/kernel/machine_kexec.o arch/ia64/kernel/machine_kexec.c: In function `machine_shutdown': arch/ia64/kernel/machine_kexec.c:77: warning: implicit declaration of function `cpu_down' AS arch/ia64/kernel/relocate_kernel.o CC arch/ia64/kernel/crash.o arch/ia64/kernel/crash.c: In function `kdump_cpu_freeze': arch/ia64/kernel/crash.c:139: warning: implicit declaration of function `ia64_jump_to_sal' arch/ia64/kernel/crash.c:139: error: `sal_boot_rendez_state' undeclared (first use in this function) arch/ia64/kernel/crash.c:139: error: (Each undeclared identifier is reported only once arch/ia64/kernel/crash.c:139: error: for each function it appears in.) arch/ia64/kernel/crash.c: At top level: arch/ia64/kernel/crash.c:84: warning: 'kdump_wait_cpu_freeze' defined but not used make[1]: *** [arch/ia64/kernel/crash.o] Error 1 make: *** [arch/ia64/kernel] Error 2 Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Acked-by: Simon Horman <horms@verge.net.au> Acked-by: Jay Lan <jlan@sgi.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09Fix interrupt probing on E450 sparc64 systemsDavid Miller
[SPARC64]: Fix PCI interrupts on E450 et al. When the PCI controller OBP node lacks an interrupt-map and interrupt-map-mask property, we need to form the INO by hand. The PCI swizzle logic was not doing that properly. This was a regression added by the of_device code. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09POWERPC: Fix performance monitor exceptionLivio Soares
To the issue: some point during 2.6.20 development, Paul Mackerras introduced the "lazy IRQ disabling" patch (very cool work, BTW). In that patch, the performance monitor unit exception was marked as "maskable", in the sense that if interrupts were soft-disabled, that exception could be ignored. This broke my PowerPC profiling code. The symptom that I see is that a varying number of interrupts (from 0 to $n$, typically closer to 0) get delivered, when, in reality, it should always be very close to $n$. The issue stems from the way masking is being done. Masking in this fashion seems to work well with the decrementer and external interrupts, because they are raised again until "really" handled. For the PMU, however, this does not apply (at least on my Xserver machine with a 970FX processor). If the PMU exception is not handled, it will _not_ be re-raised (at least on my machine). The documentation states that the PMXE bit in MMCR0 is set to 0 when the PMU exception is raised. However, software must re-set the bit to re-enable PMU exceptions. If the exception is ignored (as currently) not only is that interrupt lost, but because software does not re-set PMXE, the PMU registers are "frozen" forever. [This patch means that performance monitor exceptions are taken and handled even if irqs are off, as long as some other interrupt hasn't come along and caused interrupts to be hard-disabled. In this sense the PMU exception becomes like an NMI. The oprofile code for most powerpc processors does nothing that is unsafe in an NMI context, but the Cell oprofile code does a spin_lock_irqsave. However, that turns out to be OK because Cell doesn't actually use the performance monitor exception; performance monitor interrupts come in as a regular interrupt on Cell, so will be disabled when irqs are off. -- paulus.] From: Livio Soares <livio@eecg.toronto.edu> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09UML - Fix 2.6.20 hangJeff Dike
A previous cleanup misused need_poll, which had a fairly broken interface. It implemented a growable array, changing the used elements count itself, but leaving it up to the caller to fill in the actual elements, including the entire array if the array had to be reallocated. This worked because the previous users were switching between two such structures, and the elements were copied from the inactive array to the active array after making sure the active array had enough room. maybe_sigio_broken was made to use need_poll, but it was operating on a single array, so when the buffer was reallocated, the previous contents were lost. This patch makes need_poll implement more sane semantics. It merely assures that the array is of the proper size and that the contents are preserved. It is up to the caller to adjust the used elements count and to ensure that the proper elements are resent. This manifested itself as a hang in 2.6.20 as the uninitialized buffer convinced UML that one of its own file descriptors didn't support SIGIO and needed to be watched by poll in a separate thread. The result was an interrupt flood as control traffic over this descriptor sparked interrupts, which resulted in more control traffic, ad nauseum. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09i386: Fix broken CONFIG_COMPAT_VDSO on i386Jan Beulich
After updating several machines to 2.6.20, I can't boot anymore the single one of them that supports the NX bit and is configured as a 32-bit system. My understanding is that the VDSO changes in 2.6.20-rc7 were not fully cooked, in that with that config option enabled VDSO_SYM(x) now equals x, meaning that an address in the fixmap area is now being passed to apps via AT_SYSINFO. However, the page is mapped with PAGE_READONLY rather than PAGE_READONLY_EXEC. I'm not certain whether having app code go through the fixmap area is intended, but in case it is here is the simple patch that makes things work again. Cc: Theodore Tso <tytso@mit.edu> Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09x86: Don't require the vDSO for handling a.out signalsAndi Kleen
x86: Don't require the vDSO for handling a.out signals and in other strange binfmts. vDSO is not necessarily mapped there. This fixes signals in a.out programs Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09Fix compile error for e500 core based processorsRojhalat Ibrahim
We get the following compiler error: CC arch/ppc/kernel/ppc_ksyms.o arch/ppc/kernel/ppc_ksyms.c:275: error: '__mtdcr' undeclared here (not in a function) arch/ppc/kernel/ppc_ksyms.c:275: warning: type defaults to 'int' in declaration of '__mtdcr' arch/ppc/kernel/ppc_ksyms.c:276: error: '__mfdcr' undeclared here (not in a function) arch/ppc/kernel/ppc_ksyms.c:276: warning: type defaults to 'int' in declaration of '__mfdcr' make[1]: *** [arch/ppc/kernel/ppc_ksyms.o] Error 1 This is due to the EXPORT_SYMBOL for __mtdcr/__mfdcr not having the proper CONFIG protection Signed-off-by: Rojhalat Ibrahim <imr@rtschenk.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09x86_64: fix 2.6.18 regression - PTRACE_OLDSETOPTIONS should be acceptedPaolo 'Blaisorblade' Giarrusso
Also PTRACE_OLDSETOPTIONS should be accepted, as done by kernel/ptrace.c and forced by binary compatibility. UML/32bit breaks because of this - since it is wise enough to use PTRACE_OLDSETOPTIONS to be binary compatible with 2.4 host kernels. Until 2.6.17 (commit f0f2d6536e3515b5b1b7ae97dc8f176860c8c2ce) we had: default: return sys_ptrace(request, pid, addr, data); Instead here we have: case PTRACE_GET_THREAD_AREA: case ...: return sys_ptrace(request, pid, addr, data); default: return -EINVAL; This change was a style change - when a case is added, it must be explicitly tested this way. In this case, not enough testing was done. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-04[PATCH] EFI x86: pass firmware call parameters on the stackFrédéric Riss
When calling into the EFI firmware, the parameters need to be passed on the stack. The recent change to use -mregparm=3 breaks x86 EFI support. This patch is needed to allow the new Intel-based Macs to suspend to ram (efi.get_time is called during the suspend phase). Signed-off-by: Frederic Riss <frederic.riss@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03[PATCH] Altix: more ACPI PRT supportJohn Keller
The SN Altix platform does not conform to the IOSAPIC IRQ routing model. Add code in acpi_unregister_gsi() to check if (acpi_irq_model == ACPI_IRQ_MODEL_PLATFORM) and return. Due to an oversight, this code was not added previously when similar code was added to acpi_register_gsi(). http://marc.theaimsgroup.com/?l=linux-acpi&m=116680983430121&w=2 Signed-off-by: John Keller <jpk@sgi.com> Acked-by: Len Brown <lenb@kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03[PATCH] kexec: Avoid migration of already disabled irqs (ia64)Magnus Damm
This patch fixes up ia64 kexec support for HP rx2620 hardware. It does this by skipping migration of already disabled irqs. This is most likely a problem on other ia64 platforms as well, but I've only been able to reproduce it on one machine so far. The full story is that handle_bad_irq() gets invoked before starting the new kernel without this patch. This seems to happen when fixup_irqs() calls generic_handle_irq() on already migrated (and disabled) irqs. So by avoiding migration of disabled irqs we stay away of handle_bad_irq(). The code has been tested on three different ia64 machines, all with good results. It is possible to trigger the same bug by offlining a processor using echo 0 > /sys/devices/system/cpu/cpuX/online. More detailed information is available in the following mail thread: http://lists.osdl.org/pipermail/fastboot/2007-January/thread.html#5774 Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Acked-by: Simon Horman <horms@verge.net.au> Acked-by: Zou, Nanhai <nanhai.zou@intel.com> Acked-by: Jay Lan <jlan@sgi.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02Revert "[PATCH] fix typo in geode_configre()@cyrix.c"Linus Torvalds
This reverts commit e4f0ae0ea63caceff37a13f281a72652b7ea71ba. It's not wrong, but it's not right either, and everybody seems to agree that the right fix is probably to do the ccr3 write after the ccr4 one (and that we also should clean it up a bit). And after that we need to really validate that all the bits that we write to ccr4 actually do work. The old 2.6.19 code was insane, and basically didn't change ccr4 at all (even though it certainly looks like it was the *intent* to do so). So let's revert the change that may fix things, just because it's not what was actually ever tested when the code was written, even if it _was_ the intent. There's a discussion on http://lkml.org/lkml/2007/1/9/63 that was started by the patch that now gets reverted, and that discussion may well contain the proper long-term fix. Suggested-by: Adrian Bunk <bunk@stusta.de> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] sanitize sections for sparc32 smpAl Viro
a) sun4d_boot_one_cpu() should be __cpuinit (called only from __cpuinit __cpu_up(), for one thing, leads to calls of __cpuinit functions for another). b) got externs in arch/sparc/kernel/smp.c to match reality. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] __crc_... is intended to be absoluteAl Viro
i386 boot/compressed/relocs checks for absolute symbols and warns about unexpected ones. If you build with modversions, you get ~2500 warnings about __crc_<symbol>. These suckers are really absolute symbols - we do _not_ want to modify them on relocation. They are generated by genksyms - EXPORT_... generates a weak alias, then genksyms produces an ld script with __crc_<symbol> = <checksum> and it's fed to ld to produce the final object file. Their only use is to match kernel and module at modprobe time; they _must_ be absolute. boot/compressed/relocs has a whitelist of known absolute symbols, but it doesn't know about __crc_... stuff. As the result, we get shitloads of false positives on any ld(1) version. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] mca_nmi_hook() can be called at any pointAl Viro
... and having it __init is a bad idea. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] uml: fix signal frame alignmentJeff Dike
Use the same signal frame alignment calculations as the underlying architecture. x86_64 appeared to do this, but the "- 8" was really subtracting 8 * sizeof(struct rt_sigframe) rather than 8 bytes. UML/i386 might have been OK, but I changed the calculation to match i386 just to be sure. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: <stable@kernel.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Antoine Martin <antoine@nagafix.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Remove unneeded errata workaround from p4-clockmod. [CPUFREQ] check sysfs_create_link return value
2007-01-30[PATCH] fix indentation-related breakage in Kconfig.i386Al Viro
Kconfig recognizes the end of help text by receding indentation depth. Recent patch had broken HOST_VMSPLIT_... choice in arch/um/Kconfig.i386 - all alternatives are interpreted as part of help text now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] missing exports of pm_power_off() on alpha and sparc32Al Viro
2007-01-30Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Fix typo of "CONFIG_MT_SMP". [MIPS] Ocelot G: Fix a few misspellings of CONFIG_GALILEO_GT64240_ETH [PATCH] Malta: Fix build if CONFIG_MTD is diabled.
2007-01-30[PATCH] i386: In assign_irq_vector look at all vectors before giving upEric W. Biederman
When the world was a simple and static place setting up irqs was easy. It sufficed to allocate a linux irq number and a find a free cpu vector we could receive that linux irq on. In those days it was a safe assumption that any allocated vector was actually in use so after one global pass through all of the vectors we would have none left. These days things are much more dynamic with interrupt controllers (in the form of MSI or MSI-X) appearing on plug in cards and linux irqs appearing and disappearing. As these irqs come and go vectors are allocated and freed, invalidating the ancient assumption that all allocated vectors stayed in use forever. So this patch modifies the vector allocator to walk through every possible vector before giving up, and to check to see if a vector is in use before assigning it. With these changes we stop leaking freed vectors and it becomes possible to allocate and free irq vectors all day long. This changed was modeled after the vector allocator on x86_64 where this limitation has already been removed. In essence we don't update the static variables that hold the position of the last vector we allocated until have successfully allocated another vector. This allows us to detect if we have completed one complete scan through all of the possible vectors. Acked-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4117/1: S3C2412: Fix writel() usage in selection code [ARM] 4111/1: Allow VFP to work with thread migration on SMP [ARM] 4112/1: Only ioremap to supersections if DOMAIN_IO is zero [ARM] 4106/1: S3C2410: typo fixes in register definitions [ARM] 4102/1: Allow for PHYS_OFFSET on any valid 2MiB address [ARM] Fix AMBA serial drivers for non-first serial ports [ARM] 4100/1: iop3xx: fix cpu mask for iop333 [ARM] Update mach-types [ARM] Fix show_mem() for discontigmem [ARM] 4096/1: S3C24XX: change return code form s3c2410_gpio_getcfg() [ARM] 4095/1: S3C24XX: Fix GPIO set for Bank A [ARM] 4092/1: i.MX/MX1 CPU Frequency scaling latency definition [ARM] 4089/1: AT91: GPIO wake IRQ cleanup [ARM] 4088/1: AT91: Unbalanced IRQ in serial driver suspend/resume [ARM] 4087/1: AT91: CPU reset for SAM9x processors [ARM] 4086/1: AT91: Whitespace cleanup [ARM] 4085/1: AT91: Header fixes. [ARM] 4084/1: Remove CONFIG_DEBUG_WAITQ
2007-01-30[MIPS] Fix typo of "CONFIG_MT_SMP".Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-01-30[MIPS] Ocelot G: Fix a few misspellings of CONFIG_GALILEO_GT64240_ETHRalf Baechle
Reported by Robert P. J. Day <rpjday@mindspring.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-01-30[PATCH] Malta: Fix build if CONFIG_MTD is diabled.Jan Altenberg
Signed-off-by: Jan Altenberg <jan@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-01-29[ARM] 4117/1: S3C2412: Fix writel() usage in selection codeBen Dooks
The S3C2412 DMA selection code has the arguments to writel() the wrong way around. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
