commit e262eb9381ad51b5de7a9e762ee773bbd25ce650 upstream.
Fix misspelled define.
Fixes: 33692f27597f ("vm: add VM_FAULT_SIGSEGV handling support")
commit 7fb08eca45270d0ae86e1ad9d39c40b7a55d0190 upstream.
This replaces four copies in various stages of mm_fault_error() handling
with just a single one. It will also allow for more natural placement
of the unlocking after some further cleanup.
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
[shengyong: Backport to 3.10
- adjust context
- ignore modification for arch nios2, because 3.10 does not support it
- ignore modification for driver lustre, because 3.10 does not support it
- ignore VM_FAULT_FALLBACK in VM_FAULT_ERROR, becase 3.10 does not support
this flag
- add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.10 does not
separate it to copro_fault.c
- add SIGSEGV handling in mm/memory.c, because 3.10 does not separate it
to gup.c
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.10 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit f3747379accba8e95d70cec0eae0582c8c182050 upstream.
SYSENTER emulation is broken in several ways:
1. It misses the case of 16-bit code segments completely (CVE-2015-0239).
2. MSR_IA32_SYSENTER_CS is checked in 64-bit mode incorrectly (bits 0 and 1 can
still be set without causing #GP).
3. MSR_IA32_SYSENTER_EIP and MSR_IA32_SYSENTER_ESP are not masked in
legacy-mode.
4. There is some unneeded code.
Fix it.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
[zhangzhiqiang: backport to 3.10:
- adjust context
- in 3.10 context "ctxt->eflags &= ~(EFLG_VM | EFLG_IF | EFLG_RF)" is replaced by
"ctxt->eflags &= ~(EFLG_VM | EFLG_IF)" in upstream, which was changed by another commit.
- After the above adjustments, becomes same to the original patch:
https://github.com/torvalds/linux/commit/f3747379accba8e95d70cec0eae0582c8c182050
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
commit bb344ca5b90df62b1a3b7a35c6a9d00b306a170d upstream.
Commit 746c9e9f92dd "of/base: Fix PowerPC address parsing hack" limited
the applicability of the workaround whereby a missing ranges is treated
as an empty ranges. This workaround was hiding a bug in the etsec2
device tree nodes, which have children with reg, but did not have
ranges.
Reported-by: Alexander Graf <agraf@suse.de>
commit 84e871660bebfddb9a62ebd6f19d02536e782f0a upstream.
at91rm9200 standby and suspend to ram has been broken since
00482a4078f4. It is wrongly using AT91_BASE_SYS which is a physical address
and actually doesn't correspond to any register on at91rm9200.
Use the correct at91_ramc_base[0] instead.
Fixes: 00482a4078f4 (ARM: at91: implement the standby function for pm/cpuidle)
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 875ebe940d77a41682c367ad799b4f39f128d3fa upstream.
Anton has a busy ppc64le KVM box where guests sometimes hit the infamous
"kernel BUG at kernel/smpboot.c:134!" issue during boot:
BUG_ON(td->cpu != smp_processor_id());
Basically a per CPU hotplug thread scheduled on the wrong CPU. The oops
output confirms it:
CPU: 0
Comm: watchdog/130
The problem is that we aren't ensuring the CPU active bit is set for the
secondary before allowing the master to continue on. The master unparks
the secondary CPU's kthreads and the scheduler looks for a CPU to run
on. It calls select_task_rq() and realises the suggested CPU is not in
the cpus_allowed mask. It then ends up in select_fallback_rq(), and
since the active bit isnt't set we choose some other CPU to run on.
This seems to have been introduced by 6acbfb96976f "sched: Fix hotplug
vs. set_cpus_allowed_ptr()", which changed from setting active before
online to setting active after online. However that was in turn fixing a
bug where other code assumed an active CPU was also online, so we can't
just revert that fix.
The simplest fix is just to spin waiting for both active & online to be
set. We already have a barrier prior to set_cpu_online() (which also
sets active), to ensure all other setup is completed before online &
active are set.
Fixes: 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()")
commit e893286918d2cde3a94850d8f7101cd1039e0c62 upstream.
On gcc5 the kernel does not link:
ld: .eh_frame_hdr table[4] FDE at 0000000000000648 overlaps table[5] FDE at 0000000000000670.
Because prior GCC versions always emitted NOPs on ALIGN directives, but
gcc5 started omitting them.
.LSTARTFDEDLSI1 says:
/* HACK: The dwarf2 unwind routines will subtract 1 from the
return address to get an address in the middle of the
presumed call instruction. Since we didn't get here via
a call, we need to include the nop before the real start
to make up for it. */
.long .LSTART_sigreturn-1-. /* PC-relative start address */
But commit 69d0627a7f6e ("x86 vDSO: reorder vdso32 code") from 2.6.25
replaced .org __kernel_vsyscall+32,0x90 by ALIGN right before
__kernel_sigreturn.
Of course, ALIGN need not generate any NOP in there. Esp. gcc5 collapses
vclock_gettime.o and int80.o together with no generated NOPs as "ALIGN".
So fix this by adding to that point at least a single NOP and make the
function ALIGN possibly with more NOPs then.
Kudos for reporting and diagnosing should go to Richard.
Reported-by: Richard Biener <rguenther@suse.de>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/1425543211-12542-1-git-send-email-jslaby@suse.cz
commit f4c3686386393c120710dd34df2a74183ab805fd upstream.
drop_fpu() does clear_used_math() and usually this is correct
because tsk == current.
However switch_fpu_finish()->restore_fpu_checking() is called before
__switch_to() updates the "current_task" variable. If it fails,
we will wrongly clear the PF_USED_MATH flag of the previous task.
So use clear_stopped_child_used_math() instead.
Cc: Pekka Riikonen <priikone@iki.fi>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Link: http://lkml.kernel.org/r/20150309171041.GB11388@redhat.com
__restore_xstate_sig()
commit a7c80ebcac3068b1c3cb27d538d29558c30010c8 upstream.
math_state_restore() assumes it is called with irqs disabled,
but this is not true if the caller is __restore_xstate_sig().
This means that if ia32_fxstate == T and __copy_from_user()
fails, __restore_xstate_sig() returns with irqs disabled too.
This triggers:
BUG: sleeping function called from invalid context at kernel/locking/rwsem.c:41
dump_stack
___might_sleep
? _raw_spin_unlock_irqrestore
__might_sleep
down_read
print_vma_addr
signal_fault
sys32_rt_sigreturn
Change __restore_xstate_sig() to call set_used_math()
unconditionally. This avoids enabling and disabling interrupts
in math_state_restore(). If copy_from_user() fails, we can
simply do fpu_finit() by hand.
[ Note: this is only the first step. math_state_restore() should
not check used_math(), it should set this flag. While
init_fpu() should simply die. ]
Link: http://lkml.kernel.org/r/20150307153844.GB25954@redhat.com
commit ccfe8c3f7e52ae83155cb038753f4c75b774ca8a upstream.
The kernel crypto API logic requires the caller to provide the
length of (ciphertext || authentication tag) as cryptlen for the
AEAD decryption operation. Thus, the cipher implementation must
calculate the size of the plaintext output itself and cannot simply use
cryptlen.
The RFC4106 GCM decryption operation tries to overwrite cryptlen memory
in req->dst. As the destination buffer for decryption only needs to hold
the plaintext memory but cryptlen references the input buffer holding
(ciphertext || authentication tag), the assumption of the destination
buffer length in RFC4106 GCM operation leads to a too large size. This
patch simply uses the already calculated plaintext size.
In addition, this patch fixes the offset calculation of the AAD buffer
pointer: as mentioned before, cryptlen already includes the size of the
tag. Thus, the tag does not need to be added. With the addition, the AAD
will be written beyond the already allocated buffer.
Note, this fixes a kernel crash that can be triggered from user space
via AF_ALG(aead) -- simply use the libkcapi test application
from [1] and update it to use rfc4106-gcm-aes.
Using [1], the changes were tested using CAVS vectors to demonstrate
that the crypto operation still delivers the right results.
[1] http://www.chronox.de/libkcapi.html
CC: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Stephan Mueller <smueller@chronox.de>
[ Upstream commit 2077cef4d5c29cf886192ec32066f783d6a80db8 ]
Firstly, handle zero length calls properly. Believe it or not there
are a few of these happening during early boot.
Next, we can't just drop to a memcpy() call in the forward copy case
where dst <= src. The reason is that the cache initializing stores
used in the Niagara memcpy() implementations can end up clearing out
cache lines before we've sourced their original contents completely.
For example, considering NG4memcpy, the main unrolled loop begins like
this:
load src + 0x00
load src + 0x08
load src + 0x10
load src + 0x18
load src + 0x20
store dst + 0x00
Assume dst is 64 byte aligned and let's say that dst is src - 8 for
this memcpy() call. That store at the end there is the one to the
first line in the cache line, thus clearing the whole line, which thus
clobbers "src + 0x28" before it even gets loaded.
To avoid this, just fall through to a simple copy only mildly
optimized for the case where src and dst are 8 byte aligned and the
length is a multiple of 8 as well. We could get fancy and call
GENmemcpy() but this is good enough for how this thing is actually
used.
Reported-by: David Ahern <david.ahern@oracle.com>
Reported-by: Bob Picco <bpicco@meloft.net>
[ Upstream commit 31aaa98c248da766ece922bbbe8cc78cfd0bc920 ]
With the increase in number of CPUs calls to functions that dump
output to console (e.g., arch_trigger_all_cpu_backtrace) can take
a long time to complete. If IRQs are disabled eventually the NMI
watchdog kicks in and creates more havoc. Avoid by telling the NMI
watchdog everything is ok.
Signed-off-by: David Ahern <david.ahern@oracle.com>
[ Upstream commit d51291cb8f32bfae6b331e1838651f3ddefa73a5 ]
Currently perf-stat (aka, counting mode) does not work:
$ perf stat ls
Performance counter stats for 'ls':
1.585665 task-clock (msec) # 0.580 CPUs utilized
24 context-switches # 0.015 M/sec
0 cpu-migrations # 0.000 K/sec
86 page-faults # 0.054 M/sec
<not supported> cycles
<not supported> stalled-cycles-frontend
<not supported> stalled-cycles-backend
<not supported> instructions
<not supported> branches
<not supported> branch-misses
0.002735100 seconds time elapsed
The reason is that state is never reset (stays with PERF_HES_UPTODATE set).
Add a call to sparc_pmu_enable_event during the added_event handling.
Clean up the encoding since pmu_start calls sparc_pmu_enable_event which
does the same. Passing PERF_EF_RELOAD to sparc_pmu_start means the call
to sparc_perf_event_set_period can be removed as well.
With this patch:
$ perf stat ls
1.552890 task-clock (msec) # 0.552 CPUs utilized
86 page-faults # 0.055 M/sec
5,748,997 cycles # 3.702 GHz
<not supported> stalled-cycles-frontend:HG
<not supported> stalled-cycles-backend:HG
1,684,362 instructions:HG # 0.29 insns per cycle
295,133 branches:HG # 190.054 M/sec
28,007 branch-misses:HG # 9.49% of all branches
0.002815665 seconds time elapsed
Acked-by: Bob Picco <bob.picco@oracle.com>
[ Upstream commit 5b0d4b5514bbcce69b516d0742f2cfc84ebd6db3 ]
perf_pmu_disable is called by core perf code before pmu->del and the
enable function is called by core perf code afterwards. No need to
call again within sparc_pmu_del.
Ditto for pmu->add and sparc_pmu_add.
[ Upstream commit 53eb2516972b8c4628651dfcb926cb9ef8b2864a ]
A bug was reported that the semtimedop() system call was always
failing eith ENOSYS.
Since SEMCTL is defined as 3, and SEMTIMEDOP is defined as 4,
the comparison "call <= SEMCTL" will always prevent SEMTIMEDOP
from getting through to the semaphore ops switch statement.
This is corrected by changing the comparison to "call <= SEMTIMEDOP".
Orabug: 20633375
Signed-off-by: Rob Gardner <rob.gardner@oracle.com>
[ Upstream commit 66d0f7ec9f1038452178b1993fc07fd96d30fd38 ]
Load balancing can be triggered in the critical sections protected by
srmmu_context_spinlock in destroy_context() and switch_mm() and can hang
the cpu waiting for the rq lock of another cpu that in turn has called
switch_mm hangning on srmmu_context_spinlock leading to deadlock.
So, disable interrupt while taking srmmu_context_spinlock in
destroy_context() and switch_mm() so we don't deadlock.
See also commit 77b838fa1ef0 ("[SPARC64]: destroy_context() needs to disable
interrupts.")
Signed-off-by: Andreas Larsson <andreas@gaisler.com>
commit b3cffac04eca9af46e1e23560a8ee22b1bd36d43 upstream.
Currently the guest exit trace event saves the VCPU pointer to the
structure, and the guest PC is retrieved by dereferencing it when the
event is printed rather than directly from the trace record. This isn't
safe as the printing may occur long afterwards, after the PC has changed
and potentially after the VCPU has been freed. Usually this results in
the same (wrong) PC being printed for multiple trace events. It also
isn't portable as userland has no way to access the VCPU data structure
when interpreting the trace record itself.
Lets save the actual PC in the structure so that the correct value is
accessible later.
Fixes: 669e846e6c4e ("KVM/MIPS32: MIPS arch specific APIs for KVM")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 4ff6f8e61eb7f96d3ca535c6d240f863ccd6fb7d upstream.
This has been broken for a long time: it broke first in 2.6.35, then was
almost fixed in 2.6.36 but this one-liner slipped through the cracks.
The bug shows up as an infinite loop in Windows 7 (and newer) boot on
32-bit hosts without EPT.
Windows uses CMPXCHG8B to write to page tables, which causes a
page fault if running without EPT; the emulator is then called from
kvm_mmu_page_fault. The loop then happens if the higher 4 bytes are
not 0; the common case for this is that the NX bit (bit 63) is 1.
Fixes: 6550e1f165f384f3a46b60a1be9aba4bc3c2adad
Fixes: 16518d5ada690643453eb0aef3cc7841d3623c2d
Reported-by: Erik Rull <erik.rull@rdsoftware.de>
Tested-by: Erik Rull <erik.rull@rdsoftware.de>
commit 956421fbb74c3a6261903f3836c0740187cf038b upstream.
'ret_from_fork' checks TIF_IA32 to determine whether 'pt_regs' and
the related state make sense for 'ret_from_sys_call'. This is
entirely the wrong check. TS_COMPAT would make a little more
sense, but there's really no point in keeping this optimization
at all.
This fixes a return to the wrong user CS if we came from int
0x80 in a 64-bit task.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/4710be56d76ef994ddf59087aad98c000fbab9a4.1424989793.git.luto@amacapital.net
[ Backported from tip:x86/asm. ]
commit 3ce465e04bfd8de9956d515d6e9587faac3375dc upstream.
Export the _save_fp asm function used by the lose_fpu(1) macro to GPL
modules so that KVM can make use of it when it is built as a module.
This fixes the following build error when CONFIG_KVM=m due to commit
f798217dfd03 ("KVM: MIPS: Don't leak FPU/DSP to guest"):
ERROR: "_save_fp" [arch/mips/kvm/kvm.ko] undefined!
Fixes: f798217dfd03 (KVM: MIPS: Don't leak FPU/DSP to guest)
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9260/
[james.hogan@imgtec.com: Only export when CPU_R4K_FPU=y prior to v3.16,
so as not to break the Octeon build which excludes FPU support. KVM
depends on MIPS32r2 anyway.]
commit 4e7c22d447bb6d7e37bfe39ff658486ae78e8d77 upstream.
The issue is that the stack for processes is not properly randomized on
64 bit architectures due to an integer overflow.
The affected function is randomize_stack_top() in file
"fs/binfmt_elf.c":
static unsigned long randomize_stack_top(unsigned long stack_top)
unsigned int random_variable = 0;
if ((current->flags & PF_RANDOMIZE) &&
!(current->personality & ADDR_NO_RANDOMIZE)) {
random_variable = get_random_int() & STACK_RND_MASK;
random_variable <<= PAGE_SHIFT;
return PAGE_ALIGN(stack_top) + random_variable;
return PAGE_ALIGN(stack_top) - random_variable;
Note that, it declares the "random_variable" variable as "unsigned int".
Since the result of the shifting operation between STACK_RND_MASK (which
is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64):
then the two leftmost bits are dropped when storing the result in the
"random_variable". This variable shall be at least 34 bits long to hold
the (22+12) result.
These two dropped bits have an impact on the entropy of process stack.
Concretely, the total stack entropy is reduced by four: from 2^28 to
2^30 (One fourth of expected entropy).
This patch restores back the entropy by correcting the types involved
in the operations in the functions randomize_stack_top() and
stack_maxrandom_size().
The successful fix can be tested with:
$ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done
7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack]
7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack]
7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack]
7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack]
Once corrected, the leading bytes should be between 7ffc and 7fff,
rather than always being 7fff.
Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es>
Signed-off-by: Ismael Ripoll <iripoll@upv.es>
[ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ]
Fixes: CVE-2015-1593
Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net
commit c2996cb29bfb73927a79dc96e598a718e843f01a upstream.
The KSTK_EIP() and KSTK_ESP() macros should return the user program
counter (PC) and stack pointer (A0StP) of the given task. These are used
to determine which VMA corresponds to the user stack in
/proc/<pid>/maps, and for the user PC & A0StP in /proc/<pid>/stat.
However for Meta the PC & A0StP from the task's kernel context are used,
resulting in broken output. For example in following /proc/<pid>/maps
output, the 3afff000-3b021000 VMA should be described as the stack:
# cat /proc/self/maps
100b0000-100b1000 rwxp 00000000 00:00 0 [heap]
3afff000-3b021000 rwxp 00000000 00:00 0
And in the following /proc/<pid>/stat output, the PC is in kernel code
(1074234964 = 0x40078654) and the A0StP is in the kernel heap
(1335981392 = 0x4fa17550):
# cat /proc/self/stat
51 (cat) R ... 1335981392 1074234964 ...
Fix the definitions of KSTK_EIP() and KSTK_ESP() to use
task_pt_regs(tsk)->ctx rather than (tsk)->thread.kernel_context. This
gets the registers from the user context stored after the thread info at
the base of the kernel stack, which is from the last entry into the
kernel from userland, regardless of where in the kernel the task may
have been interrupted, which results in the following more correct
/proc/<pid>/maps output:
0800b000-08070000 r-xp 00000000 00:02 207 /lib/libuClibc-0.9.34-git.so
3afff000-3b021000 rwxp 00000000 00:00 0 [stack]
And /proc/<pid>/stat now correctly reports the PC in libuClibc
(134320308 = 0x80190b4) and the A0StP in the [stack] region (989864576 =
0x3b002280):
51 (cat) R ... 989864576 134320308 ...
Reported-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Reported-by: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: linux-metag@vger.kernel.org
commit 9d42d48a342aee208c1154696196497fdc556bbf upstream.
The native (64-bit) sigval_t union contains sival_int (32-bit) and
sival_ptr (64-bit). When a compat application invokes a syscall that
takes a sigval_t value (as part of a larger structure, e.g.
compat_sys_mq_notify, compat_sys_timer_create), the compat_sigval_t
union is converted to the native sigval_t with sival_int overlapping
with either the least or the most significant half of sival_ptr,
depending on endianness. When the corresponding signal is delivered to a
compat application, on big endian the current (compat_uptr_t)sival_ptr
cast always returns 0 since sival_int corresponds to the top part of
sival_ptr. This patch fixes copy_siginfo_to_user32() so that sival_int
is copied to the compat_siginfo_t structure.
Reported-by: Bamvor Jian Zhang <bamvor.zhangjian@huawei.com>
Tested-by: Bamvor Jian Zhang <bamvor.zhangjian@huawei.com>
commit a52d209336f8fc7483a8c7f4a8a7d2a8e1692a6c upstream.
Since the removal of CONFIG_REGULATOR_DUMMY option, the touchscreen stopped
working. This patch enables the "replacement" for REGULATOR_DUMMY and
allows the touchscreen to work even though there is no regulator for "vcc".
Signed-off-by: Martin Vajnar <martin.vajnar@gmail.com>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 7f187922ddf6b67f2999a76dcb71663097b75497 upstream.
When the guest writes to the TSC, the masterclock TSC copy must be
updated as well along with the TSC_OFFSET update, otherwise a negative
tsc_timestamp is calculated at kvm_guest_time_update.
Once "if (!vcpus_matched && ka->use_master_clock)" is simplified to
"if (ka->use_master_clock)", the corresponding "if (!ka->use_master_clock)"
becomes redundant, so remove the do_request boolean and collapse
everything into a single condition.
commit f798217dfd038af981a18bbe4bc57027a08bb182 upstream.
The FPU and DSP are enabled via the CP0 Status CU1 and MX bits by
kvm_mips_set_c0_status() on a guest exit, presumably in case there is
active state that needs saving if pre-emption occurs. However neither of
these bits are cleared again when returning to the guest.
This effectively gives the guest access to the FPU/DSP hardware after
the first guest exit even though it is not aware of its presence,
allowing FP instructions in guest user code to intermittently actually
execute instead of trapping into the guest OS for emulation. It will
then read & manipulate the hardware FP registers which technically
belong to the user process (e.g. QEMU), or are stale from another user
process. It can also crash the guest OS by causing an FP exception, for
which a guest exception handler won't have been registered.
First lets save and disable the FPU (and MSA) state with lose_fpu(1)
before entering the guest. This simplifies the problem, especially for
when guest FPU/MSA support is added in the future, and prevents FR=1 FPU
state being live when the FR bit gets cleared for the guest, which
according to the architecture causes the contents of the FPU and vector
registers to become UNPREDICTABLE.
We can then safely remove the enabling of the FPU in
kvm_mips_set_c0_status(), since there should never be any active FPU or
MSA state to save at pre-emption, which should plug the FPU leak.
DSP state is always live rather than being lazily restored, so for that
it is simpler to just clear the MX bit again when re-entering the guest.
Cc: Sanjay Lal <sanjayl@kymasys.com>
Cc: <stable@vger.kernel.org> # v3.10+: 044f0f03eca0: MIPS: KVM: Deliver guest interrupts
commit 06f34e1c28f3608b0ce5b310e41102d3fe7b65a1 upstream.
We used to calculate page address differently in 2 cases:
1. In virt_to_page(x) we do
--->8---
mem_map + (x - CONFIG_LINUX_LINK_BASE) >> PAGE_SHIFT
--->8---
2. In in pte_page(x) we do
--->8---
mem_map + (pte_val(x) - PAGE_OFFSET) >> PAGE_SHIFT
--->8---
That leads to problems in case PAGE_OFFSET != CONFIG_LINUX_LINK_BASE -
different pages will be selected depending on where and how we calculate
page address.
In particular in the STAR 9000853582 when gdb attempted to read memory
of another process it got improper page in get_user_pages() because this
is exactly one of the places where we search for a page by pte_page().
The fix is trivial - we need to calculate page address similarly in both
cases.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 9bc78f32c2e430aebf6def965b316aa95e37a20c upstream.
Add regulator_has_full_constraints() call to poodle board file to let
regulator core know that we do not have any additional regulators left.
This lets it substitute unprovided regulators with dummy ones.
This fixes the following warnings that can be seen on poodle if
regulators are enabled:
ads7846 spi1.0: unable to get regulator: -517
spi spi1.0: Driver ads7846 requests probe deferral
wm8731 0-001b: Failed to get supply 'AVDD': -517
wm8731 0-001b: Failed to request supplies: -517
wm8731 0-001b: ASoC: failed to probe component -517
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Acked-by: Mark Brown <broonie@kernel.org>
commit 271e80176aae4e5b481f4bb92df9768c6075bbca upstream.
Add regulator_has_full_constraints() call to corgi board file to let
This fixes the following warnings that can be seen on corgi if
corgi-audio corgi-audio: ASoC: failed to instantiate card -517
commit 91117a20245b59f70b563523edbf998a62fc6383 upstream.
The 'pfn' returned by axonram was completely bogus, and has been since
2008.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit e461894dc2ce7778ccde1c3483c9b15a85a7fc5f upstream.
StrongARM core uses RCSR SMR bit to tell to bootloader that it was reset
by entering the sleep mode. After we have resumed, there is little point
in having that bit enabled. Moreover, if this bit is set before reboot,
the bootloader can become confused. Thus clear the SMR bit on resume
just before clearing the scratchpad (resume address) register.
commit 044f0f03eca0110e1835b2ea038a484b93950328 upstream.
When about to run the guest, deliver guest interrupts after disabling
host interrupts. This should prevent an hrtimer interrupt from being
handled after delivering guest interrupts, and therefore not delivering
the guest timer interrupt until after the next guest exit.
commit d974baa398f34393db76be45f7d4d04fbdbb4a0a upstream.
CR4 isn't constant; at least the TSD and PCE bits can vary.
TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks
like it's correct.
This adds a branch and a read from cr4 to each vm entry. Because it is
extremely likely that consecutive entries into the same vcpu will have
the same host cr4 value, this fixes up the vmcs instead of restoring cr4
after the fact. A subsequent patch will add a kernel-wide cr4 shadow,
reducing the overhead in the common case to just two memory reads and a
branch.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
[wangkai: Backport to 3.10: adjust context]
Signed-off-by: Wang Kai <morgan.wang@huawei.com>
commit a642fc305053cc1c6e47e4f4df327895747ab485 upstream.
On systems with invvpid instruction support (corresponding bit in
IA32_VMX_EPT_VPID_CAP MSR is set) guest invocation of invvpid
causes vm exit, which is currently not handled and results in
propagation of unknown exit to userspace.
Fix this by installing an invvpid vm exit handler.
This is CVE-2014-3646.
Cc: stable@vger.kernel.org
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
commit 44b82b7700d05a52cd983799d3ecde1a976b3bed upstream.
Commit d7a49086f263164a (arm64: cpuinfo: print info for all CPUs)
attempted to clean up /proc/cpuinfo, but due to concerns regarding
further changes was reverted in commit 5e39977edf6500fd (Revert "arm64:
cpuinfo: print info for all CPUs").
There are two major issues with the arm64 /proc/cpuinfo format
currently:
* The "Features" line describes (only) the 64-bit hwcaps, which is
problematic for some 32-bit applications which attempt to parse it. As
the same names are used for analogous ISA features (e.g. aes) despite
these generally being architecturally unrelated, it is not possible to
simply append the 64-bit and 32-bit hwcaps in a manner that might not
be misleading to some applications.
Various potential solutions have appeared in vendor kernels. Typically
the format of the Features line varies depending on whether the task
is 32-bit.
* Information is only printed regarding a single CPU. This does not
match the ARM format, and does not provide sufficient information in
big.LITTLE systems where CPUs are heterogeneous. The CPU information
printed is queried from the current CPU's registers, which is racy
w.r.t. cross-cpu migration.
This patch attempts to solve these issues. The following changes are
made:
* When a task with a LINUX32 personality attempts to read /proc/cpuinfo,
the "Features" line contains the decoded 32-bit hwcaps, as with the
arm port. Otherwise, the decoded 64-bit hwcaps are shown. This aligns
with the behaviour of COMPAT_UTS_MACHINE and COMPAT_ELF_PLATFORM. In
the absense of compat support, the Features line is empty.
The set of hwcaps injected into a task's auxval are unaffected.
* Properties are printed per-cpu, as with the ARM port. The per-cpu
information is queried from pre-recorded cpu information (as used by
the sanity checks).
* As with the previous attempt at fixing up /proc/cpuinfo, the hardware
field is removed. The only users so far are 32-bit applications tied
to particular boards, so no portable applications should be affected,
and this should prevent future tying to particular boards.
The following differences remain:
* No model_name is printed, as this cannot be queried from the hardware
and cannot be provided in a stable fashion. Use of the CPU
{implementor,variant,part,revision} fields is sufficient to identify a
CPU and is portable across arm and arm64.
* The following system-wide properties are not provided, as they are not
possible to provide generally. Programs relying on these are already
tied to particular (32-bit only) boards:
- Hardware
- Revision
- Serial
No software has yet been identified for which these remaining
differences are problematic.
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Serban Constantinescu <serban.constantinescu@arm.com>
Cc: cross-distro@lists.linaro.org
Cc: linux-api@vger.kernel.org
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
[Mark: backport to v3.10.x]
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
commit c7754e75100ed5e3068ac5085747f2bfc386c8d6 upstream.
As printk() invocation can cause e.g. a TLB miss, printk() cannot be
called before the exception handlers have been properly initialized.
This can happen e.g. when netconsole has been loaded as a kernel module
and the TLB table has been cleared when a CPU was offline.
Call cpu_report() in start_secondary() only after the exception handlers
have been initialized to fix this.
Without the patch the kernel will randomly either lockup or crash
after a CPU is onlined and the console driver is a module.
Signed-off-by: Hemmo Nieminen <hemmo.nieminen@iki.fi>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/8953/
commit a3e6c1eff54878506b2dddcc202df9cc8180facb upstream.
If the irq_chip does not define .irq_disable, any call to disable_irq
will defer disabling the IRQ until it fires while marked as disabled.
This assumes that the handler function checks for this condition, which
handle_percpu_irq does not. In this case, calling disable_irq leads to
an IRQ storm, if the interrupt fires while disabled.
This optimization is only useful when disabling the IRQ is slow, which
is not true for the MIPS CPU IRQ.
Disable this optimization by implementing .irq_disable and .irq_enable
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/8949/
commit 51ac3d2f0c505ca36ffc9715ffd518d756589ef8 upstream.
NEC OEMs the same platforms as Stratus does, which have multiple devices on
some PCIe buses under downstream ports.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=51331
Fixes: 1278998f8ff6 ("PCI: Work around Stratus ftServer broken PCIe hierarchy (fix DMI check)")
Signed-off-by: Charlotte Richardson <charlotte.richardson@stratus.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Myron Stowe <myron.stowe@redhat.com>
commit ded9477984690d026e46dd75e8157392cea3f13f upstream.
For LPAE, we have the following means for encoding writable or dirty
ptes:
L_PTE_DIRTY L_PTE_RDONLY
!pte_dirty && !pte_write 0 1
!pte_dirty && pte_write 0 1
pte_dirty && !pte_write 1 1
pte_dirty && pte_write 1 0
So we can't distinguish between writeable clean ptes and read only
ptes. This can cause problems with ptes being incorrectly flagged as
read only when they are writeable but not dirty.
This patch renumbers L_PTE_RDONLY from AP[2] to a software bit #58,
and adds additional logic to set AP[2] whenever the pte is read only
or not dirty. That way we can distinguish between clean writeable ptes
and read only ptes.
HugeTLB pages will use this new logic automatically.
We need to add some logic to Transparent HugePages to ensure that they
correctly interpret the revised pgprot permissions (L_PTE_RDONLY has
moved and no longer matches PMD_SECT_AP2). In the process of revising
THP, the names of the PMD software bits have been prefixed with L_ to
make them easier to distinguish from their hardware bit counterparts.
Signed-off-by: Steve Capper <steve.capper@linaro.org>
Reviewed-by: Will Deacon <will.deacon@arm.com>
[hpy: Backported to 3.10
- adjust the context
- ignore change related to pmd, because 3.10 does not support HugePage ]
Signed-off-by: Hou Pengyang <houpengyang@huawei.com>
commit f2950706871c4b6e8c0f0d7c3f62d35930b8de63 upstream.
Long descriptors on ARM are 64 bits, and some pte functions such as
pte_dirty return a bitwise-and of a flag with the pte value. If the
flag to be tested resides in the upper 32 bits of the pte, then we run
into the danger of the result being dropped if downcast.
For example:
gather_stats(page, md, pte_dirty(*pte), 1);
where pte_dirty(*pte) is downcast to an int.
This patch introduces a new macro pte_isset which performs the bitwise
and, then performs a double logical invert (where needed) to ensure
predictable downcasting. The logical inverse pte_isclear is also
introduced.
Equivalent pmd functions for Transparent HugePages have also been
added.
[hpy: Backported to 3.10:
- ignore change to pmd, because 3.10 does not support HugePage.]
commit 6b076991dca9817e75c37e2f0db6d52611ea42fa upstream.
When setting up the CMA region, we must ensure that the old section
mappings are flushed from the TLB before replacing them with page
tables, otherwise we can suffer from mismatched aliases if the CPU
speculatively prefetches from these mappings at an inopportune time.
A mismatched alias can occur when the TLB contains a section mapping,
but a subsequent prefetch causes it to load a page table mapping,
resulting in the possibility of the TLB containing two matching
mappings for the same virtual address region.
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Hou Pengyang <houpengyang@huawei.com>
commit efea3403d4b7c6d1dd5d5ac3234c161e8b314d66 upstream.
The definition of virt_addr_valid is that virt_addr_valid should
return true if and only if virt_to_page returns a valid pointer.
The current definition of virt_addr_valid only checks against the
virtual address range. There's no guarantee that just because a
virtual address falls bewteen PAGE_OFFSET and high_memory the
associated physical memory has a valid backing struct page. Follow
the example of other architectures and convert to pfn_valid to
verify that the virtual address is actually valid. The check for
an address between PAGE_OFFSET and high_memory is still necessary
as vmalloc/highmem addresses are not valid with virt_to_page.
Cc: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
commit b713aa0b15015a65ad5421543b80df86de043d62 upstream.
Jason Gunthorpe reports a build failure when ARM_PATCH_PHYS_VIRT is
not defined:
In file included from arch/arm/include/asm/page.h:163:0,
from include/linux/mm_types.h:16,
from include/linux/sched.h:24,
from arch/arm/kernel/asm-offsets.c:13:
arch/arm/include/asm/memory.h: In function '__virt_to_phys':
arch/arm/include/asm/memory.h:244:40: error: 'PHYS_OFFSET' undeclared (first use in this function)
arch/arm/include/asm/memory.h:244:40: note: each undeclared identifier is reported only once for each function it appears in
arch/arm/include/asm/memory.h: In function '__phys_to_virt':
arch/arm/include/asm/memory.h:249:13: error: 'PHYS_OFFSET' undeclared (first use in this function)
Fixes: ca5a45c06cd4 ("ARM: mm: use phys_addr_t appropriately in p2v and v2p conversions")
Tested-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
- MPU is not supported by 3.10, so ignore fix to MPU compared with the original patch.]
in atomic_cmpxchg().
commit 4dcc1cf7316a26e112f5c9fcca531ff98ef44700 upstream.
For atomic_cmpxchg(), the type of 'oldval' need be 'int' to match the
type of "*ptr" (used by 'ldrex' instruction) and 'old' (used by 'teq'
instruction).
Signed-off-by: Chen Gang <gang.chen@asianux.com>
commit 237f12337cfa2175474e4dd015bc07a25eb9080d upstream.
atomic* value is signed value, and atomic* functions need also process
signed value (parameter value, and return value), so 32-bit arm need
use 'long long' instead of 'u64'.
After replacement, it will also fix a bug for atomic64_add_negative():
"u64 is never less than 0".
The modifications are:
in vim, use "1,% s/\<u64\>/long long/g" command.
remove '__aligned(8)' which is useless for 64-bit.
be sure of 80 column limitation after replacement.
commit e38a517578d6c0f764b0d0f6e26dcdf9f70c69d7 upstream.
For 2-level page tables, PTE_HWTABLE_PTRS describes the offset between
Linux PTEs and hardware PTEs. On LPAE, there is no distinction (since
we have 64-bit descriptors with plenty of space) so PTE_HWTABLE_PTRS
should be 0. Unfortunately, it is wrongly defined as PTRS_PER_PTE,
meaning that current pte table flushing is off by a page. Luckily,
all current LPAE implementations are SMP, so the hardware walker can
snoop L1.
This patch fixes the broken definition.
commit 5b20c5b2f014ecc0a6310988af69cd7ede9e7c67 upstream.
On LPAE machines, PHYS_OFFSET evaluates to a phys_addr_t and this type is
inherited by the PHYS_PFN_OFFSET definition as well. Consequently, the kernel
build emits warnings of the form:
init/main.c: In function 'start_kernel':
init/main.c:588:7: warning: format '%lx' expects argument of type 'long unsigned int', but argument 2 has type 'phys_addr_t' [-Wformat]
This patch fixes this warning by pinning down the PFN type to unsigned long.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Subash Patel <subash.rp@samsung.com>
commit 20d6956d8cd2452cec0889ff040f18afc03c2e6b upstream.
This patch fixes the alloc_init_pud() function to use phys_addr_t instead of
unsigned long when passing in the phys argument.
This is an extension to commit 97092e0c56830457af0639f6bd904537a150ea4a (ARM:
pgtable: use phys_addr_t for physical addresses), which applied similar changes
elsewhere in the ARM memory management code.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
