[ Upstream commit e04ed38d4e0cd32141f723560efcc8252b0241e2 ]
For chips like Niagara2 that have true overflow indications
in the %pcr (which we don't actually need and don't use)
the interrupt signal persists until the overflow bits are
cleared by an explicit %pcr write.
[ Upstream commit 8183e2b38480672a1f61d416812ac078ce94b67b ]
If perf events are active, we should not reset the %pcr to
PCR_PIC_PRIV. That perf events code does the management.
commit 2d1c861871d767153538a77c498752b36d4bb4b8 upstream
The cardbus code creates PCI devices without ever going through the
necessary fixup bits and pieces that normal PCI devices go through.
There's in fact a commented out call to pcibios_fixup_bus() in there,
it's commented because ... it doesn't work.
I could make pcibios_fixup_bus() do the right thing on powerpc easily
but I felt it cleaner instead to provide a specific hook pci_fixup_cardbus
for which a weak empty implementation is provided by the PCI core.
This fixes cardbus on powerbooks and probably all other PowerPC
platforms which was broken completely for ever on some platforms and
since 2.6.31 on others such as PowerBooks when we made the DMA ops
mandatory (since those are setup by the fixups).
Acked-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit fcfbb2b5facd65efa7284cc315225bfe3d1856c2 upstream.
This fixes the problem of the initialization code not correctly
mapping the entire MMIO space on a UV system. A side effect is
the map_high() interface needed to be changed to accommodate
different address and size shifts.
Signed-off-by: Mike Travis <travis@sgi.com>
Reviewed-by: Mike Habeck <habeck@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <4B479202.7080705@sgi.com>
commit dfea91d5a7c795fd6f4e1a97489a98e4e767463e upstream.
Chris McDermott from IBM confirmed that hurricane chipset in IBM summit
platforms doesn't support logical flat mode. Irrespective of the other
things like apic_id's, total number of logical cpu's, Linux kernel
should default to physical mode for this system.
The 32-bit kernel does so using the OEM checks for the IBM summit
platform. Add a similar OEM platform check for the 64bit kernel too.
Otherwise the linux kernel boot can hang on this platform under certain
bios/platform settings.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Tested-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Chris McDermott <lcm@linux.vnet.ibm.com>
Cc: Yinghai Lu <yinghai@kernel.org>
commit 485a2e1973fd9f98c2c6776e66ac4721882b69e0 upstream.
Add check if APIC is not disabled since thermal
monitoring depends on it. As only apic gets disabled
we should not try to install "thermal monitor" vector,
print out that thermal monitoring is enabled and etc...
Note that "Intel Correct Machine Check Interrupts" already
has such a check.
Also I decided to not add cpu_has_apic check into
mcheck_intel_therm_init since even if it'll call apic_read on
disabled apic -- it's safe here and allow us to save a few code
bytes.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <4B25FDC2.3020401@jp.fujitsu.com>
commit d4703aefdbc8f9f347f6dcefcddd791294314eb7 upstream.
powerpc applies relocations to the kcrctab. They're absolute symbols,
but it's not completely unreasonable: other archs may too, but the
relocation is often 0.
http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-November/077972.html
Inspired-by: Neil Horman <nhorman@tuxdriver.com>
Tested-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Paul Mackerras <paulus@samba.org>
pre-Pentium"
commit db677ffa5f5a4f15b9dad4d132b3477b80766d82 upstream.
This reverts commit ae1b22f6e46c03cede7cea234d0bf2253b4261cf.
As Linus said in 982d007a6ee: "There was something really messy about
cmpxchg8b and clone CPU's, so if you enable it on other CPUs later, do it
carefully."
This breaks lguest for those configs, but we can fix that by emulating
if we have to.
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14884
This backports the following upstream commits all as one patch:
54f5de709984bae0d31d823ff03de755f9dcac54
ecc1a8993751de4e82eb18640d631dae1f626bd6
1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f
f106af4e90eadd76cfc0b5325f659619e08fb762
097eed103862f9c6a97f2e415e21d1134017b135
935874141df839c706cd6cdc438e85eb69d1525e
0ec62d290912bb4b989be7563851bc364ec73b56
c4caa778157dbbf04116f0ac2111e389b5cd7a29
2ea1d13f64efdf49319e86c87d9ba38c30902782
570dcf2c15463842e384eb597a87c1e39bead99b
564b3bffc619dcbdd160de597b0547a7017ea010
0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301
f8b7256096a20436f6d0926747e3ac3d64c81d24
8c7b49b3ecd48923eb64ff57e07a1cdb74782970
9206de95b1ea68357996ec02be5db0638a0de2c1
2c6a10161d0b5fc047b5bd81b03693b9af99fab5
05d72faa6d13c9d857478a5d35c85db9adada685
bb52d6694002b9d632bb355f64daa045c6293a4e
e77414e0aad6a1b063ba5e5750c582c75327ea6a
aa65607373a4daf2010e8c3867b6317619f3c1a3
Backport done by Greg Kroah-Hartman. Only minor tweaks were needed.
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
commit 6ede31e03084ee084bcee073ef3d1136f68d0906 upstream.
Randy Dunlap reported the following build error:
"When CONFIG_SMP=n, CONFIG_X86_MSR=m:
ERROR: "msrs_free" [drivers/edac/amd64_edac_mod.ko] undefined!
ERROR: "msrs_alloc" [drivers/edac/amd64_edac_mod.ko] undefined!"
This is due to the fact that <arch/x86/lib/msr.c> is conditioned on
CONFIG_SMP and in the UP case we have only the stubs in the header.
Fork off SMP functionality into a new file (msr-smp.c) and build
msrs_{alloc,free} unconditionally.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
LKML-Reference: <20091216231625.GD27228@liondog.tnic>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 505422517d3f126bb939439e9d15dece94e11d2c upstream.
The current rd/wrmsr_on_cpus helpers assume that the supplied
cpumasks are contiguous. However, there are machines out there
like some K8 multinode Opterons which have a non-contiguous core
enumeration on each node (e.g. cores 0,2 on node 0 instead of 0,1), see
http://www.gossamer-threads.com/lists/linux/kernel/1160268.
This patch fixes out-of-bounds writes (see URL above) by adding per-CPU
msr structs which are used on the respective cores.
Additionally, two helpers, msrs_{alloc,free}, are provided for use by
the callers of the MSR accessors.
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Aristeu Rozanski <aris@redhat.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <20091211171440.GD31998@aftab>
commit b8a4754147d61f5359a765a3afd3eb03012aa052 upstream.
Since rdmsr_on_cpus and wrmsr_on_cpus are almost identical, unify them
into a common __rwmsr_on_cpus helper thus avoiding code duplication.
While at it, convert cpumask_t's to const struct cpumask *.
commit 04a1e62c2cec820501f93526ad1e46073b802dc4 upstream.
The loop condition is fragile: we compare an unsigned value to zero, and
then decrement it by something larger than one in the loop. All the
callers should be passing in appropriately aligned buffer lengths, but
it's better to just not rely on it, and have some appropriate defensive
loop limits.
Acked-by: Roland McGrath <roland@redhat.com>
commit 6e24a6eff4571002cd48b99a2b92dc829ce39cb9 upstream.
The vcpus are initialized with irr_pending set to false, but
loading the LAPIC registers with pending IRR fails to reset
the irr_pending variable.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit fb341f572d26e0786167cd96b90cc4febed830cf upstream.
The invlpg prefault optimization breaks Windows 2008 R2 occasionally.
The visible effect is that the invlpg handler instantiates a pte which
is, microseconds later, written with a different gfn by another vcpu.
The OS could have other mechanisms to prevent a present translation from
being used, which the hypervisor is unaware of.
While the documentation states that the cpu is at liberty to prefetch tlb
entries, it looks like this is not heeded, so remove tlb prefetch from
invlpg.
commit 0f764806438d5576ac58898332e5dcf30bb8a679 upstream.
The assumption that acpi_table_parse passes the return value
of the hanlder function to the caller proved wrong
recently. The return value of the handler function is
totally ignored. This makes the initialization code for AMD
IOMMU buggy in a way that could cause a kernel panic on
initialization. This patch fixes the issue in the AMD IOMMU
driver.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 39d30770992895d55789de64bad2349510af68d0 upstream.
The wrong address was being used to write the SCIR led regs on
remote hubs. Also, there was an inconsistency between how BIOS
and the kernel indexed these regs. Standardize on using the
lower 6 bits of the APIC ID as the index.
This patch fixes the problem of writing to an errant address to
a cpu # >= 64.
Reviewed-by: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
LKML-Reference: <4B3922F9.3060905@sgi.com>
[ v2: fix a number of annoying checkpatch artifacts and whitespace noise ]
commit bb7f20b1c639606def3b91f4e4aca6daeee5d80a upstream.
This patch fixes the handling of VSX alignment faults in little-endian
mode (the current code assumes the processor is in big-endian mode).
The patch also makes the handlers clear the top 8 bytes of the register
when handling an 8 byte VSX load.
This is based on 2.6.32.
Signed-off-by: Neil Campbell <neilc@linux.vnet.ibm.com>
Acked-by: Michael Neuling <mikey@neuling.org>
commit 45a94d7cd45ed991914011919e7d40eb6d2546d1 upstream.
xsave_cntxt_init() does something like:
cpuid(0xd, ..); // find out what features FP/SSE/.. etc are supported
xsetbv(); // enable the features known to OS
cpuid(0xd, ..); // find out the size of the context for features enabled
Depending on what features get enabled in xsetbv(), value of the
cpuid.eax=0xd.ecx=0.ebx changes correspondingly (representing the
size of the context that is enabled).
As we don't have volatile keyword for native_cpuid(), gcc 4.1.2
optimizes away the second cpuid and the kernel continues to use
the cpuid information obtained before xsetbv(), ultimately leading to kernel
crash on processors supporting more state than the legacy FP/SSE.
Add "volatile" for native_cpuid().
LKML-Reference: <1261009542.2745.55.camel@sbs-t61.sc.intel.com>
commit cd7bcf32d42b15891620b3f1387a00178b54291a upstream.
Needed for commit 2c992208 ("intel-iommu: Detect DMAR in hyperspace at
probe time.) to build on IA64.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Upstream commit a2202aa29289db64ca7988b12343158b67b27f10.
On platforms where bios handles the thermal monitor interrupt,
APIC_LVTTHMR on each logical CPU is programmed to generate a SMI and OS
can't touch it.
Unfortunately AP bringup sequence using INIT-SIPI-SIPI clear all
the LVT entries except the mask bit. Essentially this results in
all LVT entries including the thermal monitoring interrupt set to masked
(clearing the bios programmed value for APIC_LVTTHMR).
And this leads to kernel take over the thermal monitoring interrupt
on AP's but not on BSP (leaving the bios programmed value only on BSP).
As a result of this, we have seen system hangs when the thermal
monitoring interrupt is generated.
Fix this by reading the initial value of thermal LVT entry on BSP
and if bios has taken over the control, then program the same value
on all AP's and leave the thermal monitoring interrupt control
on all the logical cpu's to the bios.
Signed-off-by: Yong Wang <yong.y.wang@intel.com>
Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <20091110013824.GA24940@ywang-moblin2.bj.intel.com>
commit 03a05ed1152944000151d57b71000de287a1eb02 upstream.
Currently, ARB_DISABLE is a NOP on all of the recent Intel platforms.
For such platforms, reduce contention on c3_lock by skipping the fake
ARB_DISABLE.
The cpu model id on one laptop is 14. If we disable ARB_DISABLE on this box,
the box can't be booted correctly. But if we still enable ARB_DISABLE on this
box, the box can be booted correctly.
So we still use the ARB_DISABLE for the cpu which mode id is less than 0x0f.
http://bugzilla.kernel.org/show_bug.cgi?id=14700
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
[ Upstream commit 7f5620a5fcd658f219e85831d3691908f1eccbde ]
"ARCH" can be just about anything, so we shouldn't end up
with UTS_MACHINE of "sparc" in a 64-bit kernel build just
because someone set the personality using 'sparc32' or
similar. CONFIG_SPARC64 drives the compilation and
therefore provides the definitive value, not "ARCH".
This mirrors commit 8c6531f7a99f29ba8817ffb12cc9ecf190049bd6
(x86: correctly set UTS_MACHINE for "make ARCH=x86")
[ Upstream commit 166e553a575f09485f6d0df8a1ef3c5991f7d953 ]
Commit 4f70f7a91bffdcc39f088748dc678953eb9a3fbd
(sparc64: Implement IRQ stacks.) has two bugs.
First, the softirq range check forgets to subtract STACK_BIAS
before comparing with %sp. Next, on failure the wrong label
is jumped to, resulting in a bogus stack being loaded.
Reported-by: Igor Kovalenko <igor.v.kovalenko@gmail.com>
[ Upstream commit 4230fa3b89ea1c413766bd411a8315a3d05aa6c7 ]
When we are trying to see if a range property entry applies
to a given address, we are overly strict about the type.
We should only allow I/O ranges for I/O addresses, and only allow
CONFIG space ranges for CONFIG space address.
However for MEM ranges, they come in 32-bit and 64-bit flavors.
And a lack of an exact match is OK if the range is 32-bit and
the address is 64-bit. We can assign a 64-bit address properly
into a 32-bit parent range just fine.
So allow it.
Reported-by: Patrick Finnegan <pat@computer-refuge.org>
[ Upstream commit 08a036d583409e3517e3d15b7478d029b25f2cf2 ]
IRQF_SHARED and IRQF_DISABLED don't mix.
commit 6aaf5d633bb6cead81b396d861d7bae4b9a0ba7e upstream.
If Xen wants to return to a 32b usermode with sysret it must use the
right form. When using VCGF_in_syscall to trigger this, it looks at
the code segment and does a 32b sysret if it is FLAT_USER_CS32.
However, this is different from __USER32_CS, so it fails to return
properly if we use the normal Linux segment.
So avoid the whole mess by dropping VCGF_in_syscall and simply use
plain iret to return to usermode.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Jan Beulich <jbeulich@novell.com>
commit f6eafe3665bcc374c66775d58312d1c06c55303f upstream.
tick_resume() is never called on secondary processors. Presumably this
is because they are offlined for suspend on native and so this is
normally taken care of in the CPU onlining path. Under Xen we keep all
CPUs online over a suspend.
This patch papers over the issue for me but I will investigate a more
generic, less hacky, way of doing to the same.
tick_suspend is also only called on the boot CPU which I presume should
be fixed too.
Signed-off-by: Ian Campbell <Ian.Campbell@citrix.com>
commit 499d19b82b586aef18727b9ae1437f8f37b66e91 upstream.
printk timestamping uses sched_clock, which in turn relies on runstate
info under Xen. So make sure we set it up before any printks can
be called.
commit 028896721ac04f6fa0697f3ecac3f98761746363 upstream.
The commit "xen: re-register runstate area earlier on resume" caused us
to never try and setup the runstate area for secondary CPUs. Ensure that
we do this...
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
commit f350c7922faad3397c98c81a9e5658f5a1ef0214 upstream.
Otherwise the timer is disabled by dpm_suspend_noirq() which in turn prevents
correct operation of stop_machine on multi-processor systems and breaks
suspend.
commit fa24ba62ea2869308ffc9f0b286ac9650b4ca6cb upstream.
pvops kernels >= 2.6.30 can currently only be saved and restored once. The
second attempt to save results in:
ERROR Internal error: Frame# in pfn-to-mfn frame list is not in pseudophys
ERROR Internal error: entry 0: p2m_frame_list[0] is 0xf2c2c2c2, max 0x120000
ERROR Internal error: Failed to map/save the p2m frame list
I finally narrowed it down to:
commit cdaead6b4e657f960d6d6f9f380e7dfeedc6a09b
Author: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Date: Fri Feb 27 15:34:59 2009 -0800
xen: split construction of p2m mfn tables from registration
Build the p2m_mfn_list_list early with the rest of the p2m table, but
register it later when the real shared_info structure is in place.
The unforeseen side-effect of this change was to cause the mfn list list to not
be rebuilt on resume. Prior to this change it would have been rebuilt via
xen_post_suspend() -> xen_setup_shared_info() -> xen_setup_mfn_list_list().
Fix by explicitly calling xen_build_mfn_list_list() from xen_post_suspend().
commit 3905bb2aa7bb801b31946b37a4635ebac4009051 upstream.
Even if have_vcpu_info_placement is not set, we still need to set up
the runstate area on each resumed vcpu.
commit be012920ecba161ad20303a3f6d9e96c58cf97c7 upstream.
This is necessary to ensure the runstate area is available to
xen_sched_clock before any calls to printk which will require it in
order to provide a timestamp.
I chose to pull the xen_setup_runstate_info out of xen_time_init into
the caller in order to maintain parity with calling
xen_setup_runstate_info separately from calling xen_time_resume.
commit e090aa80321b64c3b793f3b047e31ecf1af9538d upstream.
e821ea70f3b4873b50056a1e0f74befed1014c09 introduced a bug by copying
some 64-bit originated code as-is to be used by both 32 and 64-bit
but this code contains a 64-bit ony "cmpdi" instruction.
This changes it to cmpwi, which is fine since VRSAVE can only contains
a 32-bit value anyway.
commit a946d8f11f0da9cfc714248036fcfd3a794d1e27 upstream.
apic_noop is used to provide dummy apic functions. It's installed
when the CPU has no APIC or when the APIC is disabled on the kernel
command line.
The apic_noop implementation of apic_write() warns when the CPU has
an APIC or when the APIC is not disabled.
That's bogus. The warning should only happen when the CPU has an
APIC _AND_ the APIC is not disabled. apic_noop.apic_read() has the
correct check.
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
LKML-Reference: <alpine.LFD.2.00.0912071255420.3089@localhost.localdomain>
commit 1b82e4c32fba96d8805b1e2126ba5382e56fac32 upstream.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit cf87b7439ec81b9374e7772e44e9cb2eb9e57160 upstream.
When the kernel is IPLed without the CLEAR option and switches
to 64-bit, the high-order half of the registers might contain
random values. This can cause addressing exceptions and the
kernel enters an interrupt loop.
Initialize the high-order half of the general purpose registers
with zeros after switching to 64-bit mode.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
commit e02e0e1a130b9ca37c5186d38ad4b3aaf58bb149 upstream.
I double-checked the datasheet. One of the existing
descriptors has a typo: it should be 2MB not 2038 KB.
Signed-off-by: Dave Jones <davej@redhat.com>
LKML-Reference: <20091110200120.GA27090@redhat.com>
commit 85160b92fbd35321104819283c91bfed2b553e3c upstream.
The latest rev of Intel doc AP-485 details new cache descriptors
that we don't yet support. 12MB, 18MB and 24MB 24-way assoc L3
caches.
LKML-Reference: <20091110184924.GA20337@redhat.com>
commit 1d865fb728bd6bbcdfbd6ec1e2b8ade3b4805641 upstream.
Interrupt vector 0xec has been doubly defined in irq_vectors.h
It seems arbitrary whether LOCAL_PENDING_VECTOR or
UV_BAU_MESSAGE is the higher number. As long as they are
unique. If they are not unique we'll hit a BUG in
alloc_system_vector().
Signed-off-by: Cliff Wickman <cpw@sgi.com>
LKML-Reference: <E1NJ9Pe-0004P7-0Q@eag09.americas.sgi.com>
commit e38e2af1c57c3eb5211331a5b4fcaae0c4a2a918 upstream.
A memory mapped register that affects the SGI UV Broadcast
Assist Unit's interrupt handling may sometimes be unintialized.
Remove the condition on its initialization, as that condition
can be randomly satisfied by a hardware reset.
LKML-Reference: <E1NBGB9-0005nU-Dp@eag09.americas.sgi.com>
commit bc09effabf0c5c6c7021e5ef9af15a23579b32a8 upstream.
mce_timer must be passed to setup_timer() in all cases, no
matter whether it is going to be actually used. Otherwise, when
the CPU gets brought down, its call to del_timer_sync() will
never return, as the timer won't have a base associated, and
hence lock_timer_base() will loop infinitely.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4B1DB831.2030801@jp.fujitsu.com>
commit fe5ed91ddce85a0ed0e4f92c10b099873ef62167 upstream.
Even it is in error path unlikely taken, add_timer_on() at
CPU_DOWN_FAILED* needs to be skipped if mce_timer is disabled.
Cc: Huang Ying <ying.huang@intel.com>
Cc: Jan Beulich <jbeulich@novell.com>
commit b8b7d791a8ff01d2380089279a69afa99115fb23 upstream.
commit 746357d (x86: Prevent GCC 4.4.x (pentium-mmx et al) function
prologue wreckage) uses -mtune=generic to work around the function
prologue problem with mcount on -march=pentium-mmx and others.
Jakub pointed out that we can use -maccumulate-outgoing-args instead
which is selected by -mtune=generic and prevents the problem without
losing the -march specific optimizations.
Pointed-out-by: Jakub Jelinek <jakub@redhat.com>
commit 746357d6a526d6da9d89a2ec645b28406e959c2e upstream.
When the kernel is compiled with -pg for tracing GCC 4.4.x inserts
stack alignment of a function _before_ the mcount prologue if the
-march=pentium-mmx is set and -mtune=generic is not set. This breaks
the assumption of the function graph tracer which expects that the
mcount prologue
push %ebp
mov %esp, %ebp
is the first stack operation in a function because it needs to modify
the function return address on the stack to trap into the tracer
before returning to the real caller.
The generated code is:
push %edi
lea 0x8(%esp),%edi
and $0xfffffff0,%esp
pushl -0x4(%edi)
push %ebp
mov %esp,%ebp
so the tracer modifies the copy of the return address which is stored
after the stack alignment and therefor does not trap the return which
in turn breaks the call chain logic of the tracer and leads to a
kernel panic.
Aside of the fact that the generated code is horrible for no good
reason other -march -mtune options generate the expected:
push %ebp
mov %esp,%ebp
which does the same and keeps everything intact.
After some experimenting we found out that this problem is restricted
to gcc4.4.x and to the following -march settings:
i586, pentium, pentium-mmx, k6, k6-2, k6-3, winchip-c6, winchip2, c3,
geode
By adding -mtune=generic the code generator produces always the
expected code.
So forcing -mtune=generic when CONFIG_FUNCTION_GRAPH_TRACER=y is not
pretty, but at the moment the only way to prevent that the kernel
trips over gcc-shrooms induced code madness.
Most distro kernels have CONFIG_X86_GENERIC=y anyway which forces
-mtune=generic as well so it will not impact those.
References: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=42109
http://lkml.org/lkml/2009/11/19/17
LKML-Reference: <alpine.LFD.2.00.0911200206570.24119@localhost.localdomain>
Cc: Frederic Weisbecker <fweisbec@gmail.com>,
Cc: Jeff Law <law@redhat.com>
Cc: gcc@gcc.gnu.org
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Andrew Haley <aph@redhat.com>
Cc: Richard Guenther <richard.guenther@gmail.com>
commit e3267cbbbfbcbe9c18833e89b10beabb1117cb55 upstream.
For a while now, we are issuing a rdmsr instruction to find out which
msrs in our save list are really supported by the underlying machine.
However, it fails to account for kvm-specific msrs, such as the pvclock
ones.
This patch moves then to the beginning of the list, and skip testing them.
Signed-off-by: Glauber Costa <glommer@redhat.com>
commit d7b0b5eb3000c6fb902f08c619fcd673a23d8fab upstream.
This patch moves s390 processor status word into the base kvm_run
struct and keeps it up-to date on all userspace exits.
The userspace ABI is broken by this, however there are no applications
in the wild using this. A capability check is provided so users can
verify the updated API exists.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
commit f50146bd7bdb75435638e60d4960edd9bcdf88b8 upstream.
This patch corrects the checking of the new address for the prefix register.
On s390, the prefix register is used to address the cpu's lowcore (address
0...8k). This check is supposed to verify that the memory is readable and
present.
copy_from_guest is a helper function, that can be used to read from guest
memory. It applies prefixing, adds the start address of the guest memory in
user, and then calls copy_from_user. Previous code was obviously broken for
two reasons:
- prefixing should not be applied here. The current prefix register is
going to be updated soon, and the address we're looking for will be
0..8k after we've updated the register
- we're adding the guest origin (gmsor) twice: once in subject code
and once in copy_from_guest
With kuli, we did not hit this problem because (a) we were lucky with
previous prefix register content, and (b) our guest memory was mmaped
very low into user address space.
Reported-by: Alexander Graf <agraf@suse.de>
commit eb3c79e64a70fb8f7473e30fa07e89c1ecc2c9bb upstream.
While we are never normally passed an instruction that exceeds 15 bytes,
smp games can cause us to attempt to interpret one, which will cause
large latencies in non-preempt hosts.
