commit 94f28da8409c6059135e89ac64a0839993124155 upstream.
Here are the powerpc bits to remove TIF_ABI_PENDING now that
set_personality() is called at the appropriate place in exec.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit d8cc108f4fab42b380c6b3f3356f99e8dd5372e2 upstream.
With multiplexing enabled oprofile crashs when profiling more than 28
events. This patch fixes this.
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit e83e452b0692c9c13372540deb88a77d4ae2553d upstream.
Add Xeon 7500 series support to oprofile.
Straight forward: it's the same as Core i7, so just detect
the model number. No user space changes needed.
(cherry picked from afbcf7ab8d1bc8c2d04792f6d9e786e0adeb328d)
When we migrate a kvm guest that uses pvclock between two hosts, we may
suffer a large skew. This is because there can be significant differences
between the monotonic clock of the hosts involved. When a new host with
a much larger monotonic time starts running the guest, the view of time
will be significantly impacted.
Situation is much worse when we do the opposite, and migrate to a host with
a smaller monotonic clock.
This proposed ioctl will allow userspace to inform us what is the monotonic
clock value in the source host, so we can keep the time skew short, and
more importantly, never goes backwards. Userspace may also need to trigger
the current data, since from the first migration onwards, it won't be
reflected by a simple call to clock_gettime() anymore.
[marcelo: future-proof abi with a flags field]
[jan: fix KVM_GET_CLOCK by clearing flags field instead of checking it]
Signed-off-by: Glauber Costa <glommer@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit d91afd15b041f27d34859c79afa9e172018a86f4 upstream.
The variable i in this function could be increased to over
2**32 which would result in an integer overflow when using
int. Fix it by changing i to unsigned long.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 7c099ce1575126395f186ecf58b51a60d5c3be7d upstream.
Commit 6aa542a694dc9ea4344a8a590d2628c33d1b9431 added a quirk for the
Intel DG45ID board due to low memory corruption. The Intel DG45FC
shares the same BIOS (and the same bug) as noted in:
http://bugzilla.kernel.org/show_bug.cgi?id=13736
Signed-off-by: David Härdeman <david@hardeman.nu>
LKML-Reference: <20100128200254.GA9134@hardeman.nu>
Cc: Alexey Fisher <bug-track@fisher-privat.net>
Cc: ykzhao <yakui.zhao@intel.com>
Cc: Tony Bones <aabonesml@gmail.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 35ea63d70f827a26c150993b4b940925bb02b03f upstream.
Dell OptiPlex 760 hangs on reboot unless reboot=bios is used. Add quirk
to reboot through the BIOS.
BugLink: https://bugs.launchpad.net/bugs/488319
Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com>
LKML-Reference: <1264634958.27335.1091.camel@emiko>
commit 73472a46b5b28116b145fb5fc05242c1aa8e1461 upstream
HPET MSI on platforms with ATI SB700/SB800 as they seem to have some
side-effects on floppy DMA. Do not use HPET MSI on such platforms.
Original problem report from Mark Hounschell
http://lkml.indiana.edu/hypermail/linux/kernel/0912.2/01118.html
Tested-by: Mark Hounschell <markh@compro.net>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: <stable@kernel.org>
LKML-Reference: <20100121190952.GA32523@linux-os.sc.intel.com>
commit 05d43ed8a89c159ff641d472f970e3f1baa66318 upstream.
Now that the previous commit made it possible to do the personality
setting at the point of no return, we do just that for ELF binaries.
And suddenly all the reasons for that insane TIF_ABI_PENDING bit go
away, and we can just make SET_PERSONALITY() just do the obvious thing
for a 32-bit compat process.
Everything becomes much more straightforward this way.
commit 94673e968cbcce07fa78dac4b0ae05d24b5816e1 upstream.
Here are the sparc bits to remove TIF_ABI_PENDING now that
commit 221af7f87b97431e3ee21ce4b0e77d5411cf1549 upstream.
'flush_old_exec()' is the point of no return when doing an execve(), and
it is pretty badly misnamed. It doesn't just flush the old executable
environment, it also starts up the new one.
Which is very inconvenient for things like setting up the new
personality, because we want the new personality to affect the starting
of the new environment, but at the same time we do _not_ want the new
personality to take effect if flushing the old one fails.
As a result, the x86-64 '32-bit' personality is actually done using this
insane "I'm going to change the ABI, but I haven't done it yet" bit
(TIF_ABI_PENDING), with SET_PERSONALITY() not actually setting the
personality, but just the "pending" bit, so that "flush_thread()" can do
the actual personality magic.
This patch in no way changes any of that insanity, but it does split the
'flush_old_exec()' function up into a preparatory part that can fail
(still called flush_old_exec()), and a new part that will actually set
up the new exec environment (setup_new_exec()). All callers are changed
to trivially comply with the new world order.
commit 04e4f2b18c8de1389d1e00fef0f42a8099910daf upstream.
The current code will load the stack size and protection markings, but
then only use the markings in the MMU code path. The NOMMU code path
always passes PROT_EXEC to the mmap() call. While this doesn't matter
to most people whilst the code is running, it will cause a pointless
icache flush when starting every FDPIC application. Typically this
icache flush will be of a region on the order of 128KB in size, or may
be the entire icache, depending on the facilities available on the CPU.
In the case where the arch default behaviour seems to be desired
(EXSTACK_DEFAULT), we probe VM_STACK_FLAGS for VM_EXEC to determine
whether we should be setting PROT_EXEC or not.
For arches that support an MPU (Memory Protection Unit - an MMU without
the virtual mapping capability), setting PROT_EXEC or not will make an
important difference.
It should be noted that this change also affects the executability of
the brk region, since ELF-FDPIC has that share with the stack. However,
this is probably irrelevant as NOMMU programs aren't likely to use the
brk region, preferring instead allocation via mmap().
commit b160091802d4a76dd063facb09fcf10bf5d5d747 upstream.
CONFIG_X86_CPU_DEBUG, which provides some parsed versions of the x86
CPU configuration via debugfs, has caused boot failures on real
hardware. The value of this feature has been marginal at best, as all
this information is already available to userspace via generic
interfaces.
Causes crashes that have not been fixed + minimal utility -> remove.
See the referenced LKML thread for more information.
Reported-by: Ozan Çağlayan <ozan@pardus.org.tr>
LKML-Reference: <alpine.LFD.2.00.1001221755320.13231@localhost.localdomain>
Cc: Jaswinder Singh Rajput <jaswinder@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Yinghai Lu <yinghai@kernel.org>
commit 3a5fc0e40cb467e692737bc798bc99773c81e1e2 upstream.
nodes_possible_map does not currently include nodes that have SRAT
entries that are all ACPI_SRAT_MEM_HOT_PLUGGABLE since the bit is
cleared in nodes_parsed if it does not have an online address range.
Unequivocally setting the bit in nodes_parsed is insufficient since
existing code, such as acpi_get_nodes(), assumes all nodes in the map
have online address ranges. In fact, all code using nodes_parsed
assumes such nodes represent an address range of online memory.
nodes_possible_map is created by unioning nodes_parsed and
cpu_nodes_parsed; the former represents nodes with online memory and
the latter represents memoryless nodes. We now set the bit for
hotpluggable nodes in cpu_nodes_parsed so that it also gets set in
nodes_possible_map.
[ hpa: Haicheng Li points out that this makes the naming of the
variable cpu_nodes_parsed somewhat counterintuitive. However, leave
it as is in the interest of keeping the pure bug fix patch small. ]
Signed-off-by: David Rientjes <rientjes@google.com>
Tested-by: Haicheng Li <haicheng.li@linux.intel.com>
LKML-Reference: <alpine.DEB.2.00.1001201152040.30528@chino.kir.corp.google.com>
commit 21ec7f6dbf10492ce9a21718040677d3e68bd57d upstream.
If irq flags tracing is enabled the TRACE_IRQS_ON macros expands to
a function call which clobbers registers %r0-%r5. The macro is used
in the code path for single stepped system calls. The argument
registers %r2-%r6 need to be restored from the stack before the system
call function is called.
drivers.
commit da482474b8396e1a099c37ffc6541b78775aedb4 upstream.
Pass the number of minors when unregistering MSR and CPUID drivers.
Reported-by: Dean Nelson <dnelson@redhat.com>
Signed-off-by: Dean Nelson <dnelson@redhat.com>
LKML-Reference: <20100127023722.GA22305@sgi.com>
Signed-off-by: Russ Anderson <rja@sgi.com>
commit 6c56ccecf05fafe100ab4ea94f6fccbf5ff00db7 upstream.
Commit 83ce4009 did the following change
If the TSC is constant and non-stop, also set it reliable.
But, there seems to be few systems that will end up with TSC warp across
sockets, depending on how the cpus come out of reset. Skipping TSC sync
test on such systems may result in time inconsistency later.
So, reenable TSC sync test even on constant and non-stop TSC systems.
Set, sched_clock_stable to 1 by default and reset it in
mark_tsc_unstable, if TSC sync fails.
This change still gives perf benefit mentioned in 83ce4009 for systems
where TSC is reliable.
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <20091217202702.GA18015@linux-os.sc.intel.com>
commit 443c39bc9ef7d8f648408d74c97e943f3bb3f48a upstream.
In function kvm_arch_vcpu_init(), if the memory malloc for
vcpu->arch.mce_banks is fail, it does not free the memory
of lapic date. This patch fixed it.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
commit 36cb93fd6b6bf7e9163a69a8bf20207aed5fea44 upstream.
vcpu->arch.mce_banks is malloc in kvm_arch_vcpu_init(), but
never free in any place, this may cause memory leak. So this
patch fixed to free it in kvm_arch_vcpu_uninit().
commit 82b7005f0e72d8d1a8226e4c192cbb0850d10b3f upstream.
When found a error hva, should not return PAGE_SIZE but the level...
Also clean up the coding style of the following loop.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
commit a6085fbaf65ab09bfb5ec8d902d6d21680fe1895 upstream.
Exit the guest pagetable walk loop if reading gpte failed. Otherwise its
possible to enter an endless loop processing the previous present pte.
commit a5d36f82c4f3e852b61fdf1fee13463c8aa91b90 upstream.
When we queue an interrupt to the local apic, we set the IRR before the TMR.
The vcpu can pick up the IRR and inject the interrupt before setting the TMR,
and perhaps even EOI it, causing incorrect behaviour.
The race is really insignificant since it can only occur on the first
interrupt (usually following interrupts will not change TMR), but it's better
closed than open.
Fixed by reordering setting the TMR vs IRR.
commit 062d5e9b0d714f449b261bb522eadaaf6f00f438 upstream.
kvm_handle_sie_intercept uses a jump table to get the intercept handler
for a SIE intercept. Static code analysis revealed a potential problem:
the intercept_funcs jump table was defined to contain (0x48 >> 2) entries,
but we only checked for code > 0x48 which would cause an off-by-one
array overflow if code == 0x48.
Use the compiler and ARRAY_SIZE to automatically set the limits.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit f63dd12da29f47c37bbc093abec098538e04357c upstream.
DM6467 silicon revisions 3.x have variant field in JTAGID register as '1'.
This path adds entry for the same in dm646x_ids to be able to boot on boards
with 3.x revision chips.
Also modifies name for 'variant=0' (revisions 1.0, 1.1).
Signed-off-by: Hemant Pedanekar <hemantp@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit a3f62bd2b20c769ddc989b242ddd274179e19ee6 upstream by
Kumar Gala <galak@kernel.crashing.org>. I have adjusted the patch
context for 2.6.32.
commit 2992e545ea006992ec9dc91c4fa996ce1e15f921 upstream.
Thomas Schlichter reported:
> X.org uses libpciaccess which tries to mmap with write combining enabled via
> /sys/bus/pci/devices/*/resource0_wc. Currently, when PAT is not enabled, the
> kernel does fall back to uncached mmap. Then libpciaccess thinks it succeeded
> mapping with write combining enabled and does not set up suited MTRR entries.
Instead of silently mapping pci mmap region as UC minus in the case
of !pat_enabled and wc request, we can return error. Eric Anholt mentioned
that caller (like X) typically follows up with UC minus pci mmap request and
if there is a free mtrr slot, caller will manage adding WC mtrr.
Jesse Barnes says:
> Older versions of libpciaccess will behave better if we do it that way
> (iirc it only allocates an MTRR if the resource_wc file doesn't exist or
> fails to get mapped).
Reported-by: Thomas Schlichter <thomas.schlichter@web.de>
Signed-off-by: Thomas Schlichter <thomas.schlichter@web.de>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Eric Anholt <eric@anholt.net>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 0b962d473af32ec334df271b54ff4973cb2b4c73 upstream.
register_chrdev() hardcodes registering 256 minors, presumably to
avoid breaking old drivers. However, we need to register enough
minors so that we have all possible CPUs.
checkpatch warns on this patch, but the patch is correct: NR_CPUS here
is a static *upper bound* on the *maximum CPU index* (not *number of
CPUs!*) and that is what we want.
Reported-and-tested-by: Russ Anderson <rja@sgi.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Takashi Iwai <tiwai@suse.de>
LKML-Reference: <tip-*@git.kernel.org>
[ Upstream commit e04ed38d4e0cd32141f723560efcc8252b0241e2 ]
For chips like Niagara2 that have true overflow indications
in the %pcr (which we don't actually need and don't use)
the interrupt signal persists until the overflow bits are
cleared by an explicit %pcr write.
[ Upstream commit 8183e2b38480672a1f61d416812ac078ce94b67b ]
If perf events are active, we should not reset the %pcr to
PCR_PIC_PRIV. That perf events code does the management.
commit 2d1c861871d767153538a77c498752b36d4bb4b8 upstream
The cardbus code creates PCI devices without ever going through the
necessary fixup bits and pieces that normal PCI devices go through.
There's in fact a commented out call to pcibios_fixup_bus() in there,
it's commented because ... it doesn't work.
I could make pcibios_fixup_bus() do the right thing on powerpc easily
but I felt it cleaner instead to provide a specific hook pci_fixup_cardbus
for which a weak empty implementation is provided by the PCI core.
This fixes cardbus on powerbooks and probably all other PowerPC
platforms which was broken completely for ever on some platforms and
since 2.6.31 on others such as PowerBooks when we made the DMA ops
mandatory (since those are setup by the fixups).
Acked-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
commit fcfbb2b5facd65efa7284cc315225bfe3d1856c2 upstream.
This fixes the problem of the initialization code not correctly
mapping the entire MMIO space on a UV system. A side effect is
the map_high() interface needed to be changed to accommodate
different address and size shifts.
Signed-off-by: Mike Travis <travis@sgi.com>
Reviewed-by: Mike Habeck <habeck@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <4B479202.7080705@sgi.com>
commit dfea91d5a7c795fd6f4e1a97489a98e4e767463e upstream.
Chris McDermott from IBM confirmed that hurricane chipset in IBM summit
platforms doesn't support logical flat mode. Irrespective of the other
things like apic_id's, total number of logical cpu's, Linux kernel
should default to physical mode for this system.
The 32-bit kernel does so using the OEM checks for the IBM summit
platform. Add a similar OEM platform check for the 64bit kernel too.
Otherwise the linux kernel boot can hang on this platform under certain
bios/platform settings.
Tested-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Chris McDermott <lcm@linux.vnet.ibm.com>
commit 485a2e1973fd9f98c2c6776e66ac4721882b69e0 upstream.
Add check if APIC is not disabled since thermal
monitoring depends on it. As only apic gets disabled
we should not try to install "thermal monitor" vector,
print out that thermal monitoring is enabled and etc...
Note that "Intel Correct Machine Check Interrupts" already
has such a check.
Also I decided to not add cpu_has_apic check into
mcheck_intel_therm_init since even if it'll call apic_read on
disabled apic -- it's safe here and allow us to save a few code
bytes.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <4B25FDC2.3020401@jp.fujitsu.com>
commit d4703aefdbc8f9f347f6dcefcddd791294314eb7 upstream.
powerpc applies relocations to the kcrctab. They're absolute symbols,
but it's not completely unreasonable: other archs may too, but the
relocation is often 0.
http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-November/077972.html
Inspired-by: Neil Horman <nhorman@tuxdriver.com>
Tested-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Paul Mackerras <paulus@samba.org>
pre-Pentium"
commit db677ffa5f5a4f15b9dad4d132b3477b80766d82 upstream.
This reverts commit ae1b22f6e46c03cede7cea234d0bf2253b4261cf.
As Linus said in 982d007a6ee: "There was something really messy about
cmpxchg8b and clone CPU's, so if you enable it on other CPUs later, do it
carefully."
This breaks lguest for those configs, but we can fix that by emulating
if we have to.
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14884
This backports the following upstream commits all as one patch:
54f5de709984bae0d31d823ff03de755f9dcac54
ecc1a8993751de4e82eb18640d631dae1f626bd6
1a0ef85f84feb13f07b604fcf5b90ef7c2b5c82f
f106af4e90eadd76cfc0b5325f659619e08fb762
097eed103862f9c6a97f2e415e21d1134017b135
935874141df839c706cd6cdc438e85eb69d1525e
0ec62d290912bb4b989be7563851bc364ec73b56
c4caa778157dbbf04116f0ac2111e389b5cd7a29
2ea1d13f64efdf49319e86c87d9ba38c30902782
570dcf2c15463842e384eb597a87c1e39bead99b
564b3bffc619dcbdd160de597b0547a7017ea010
0067bd8a55862ac9dd212bd1c4f6f5bff1ca1301
f8b7256096a20436f6d0926747e3ac3d64c81d24
8c7b49b3ecd48923eb64ff57e07a1cdb74782970
9206de95b1ea68357996ec02be5db0638a0de2c1
2c6a10161d0b5fc047b5bd81b03693b9af99fab5
05d72faa6d13c9d857478a5d35c85db9adada685
bb52d6694002b9d632bb355f64daa045c6293a4e
e77414e0aad6a1b063ba5e5750c582c75327ea6a
aa65607373a4daf2010e8c3867b6317619f3c1a3
Backport done by Greg Kroah-Hartman. Only minor tweaks were needed.
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
commit 6ede31e03084ee084bcee073ef3d1136f68d0906 upstream.
Randy Dunlap reported the following build error:
"When CONFIG_SMP=n, CONFIG_X86_MSR=m:
ERROR: "msrs_free" [drivers/edac/amd64_edac_mod.ko] undefined!
ERROR: "msrs_alloc" [drivers/edac/amd64_edac_mod.ko] undefined!"
This is due to the fact that <arch/x86/lib/msr.c> is conditioned on
CONFIG_SMP and in the UP case we have only the stubs in the header.
Fork off SMP functionality into a new file (msr-smp.c) and build
msrs_{alloc,free} unconditionally.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
LKML-Reference: <20091216231625.GD27228@liondog.tnic>
commit 505422517d3f126bb939439e9d15dece94e11d2c upstream.
The current rd/wrmsr_on_cpus helpers assume that the supplied
cpumasks are contiguous. However, there are machines out there
like some K8 multinode Opterons which have a non-contiguous core
enumeration on each node (e.g. cores 0,2 on node 0 instead of 0,1), see
http://www.gossamer-threads.com/lists/linux/kernel/1160268.
This patch fixes out-of-bounds writes (see URL above) by adding per-CPU
msr structs which are used on the respective cores.
Additionally, two helpers, msrs_{alloc,free}, are provided for use by
the callers of the MSR accessors.
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Aristeu Rozanski <aris@redhat.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <20091211171440.GD31998@aftab>
commit b8a4754147d61f5359a765a3afd3eb03012aa052 upstream.
Since rdmsr_on_cpus and wrmsr_on_cpus are almost identical, unify them
into a common __rwmsr_on_cpus helper thus avoiding code duplication.
While at it, convert cpumask_t's to const struct cpumask *.
commit 04a1e62c2cec820501f93526ad1e46073b802dc4 upstream.
The loop condition is fragile: we compare an unsigned value to zero, and
then decrement it by something larger than one in the loop. All the
callers should be passing in appropriately aligned buffer lengths, but
it's better to just not rely on it, and have some appropriate defensive
loop limits.
Acked-by: Roland McGrath <roland@redhat.com>
commit 6e24a6eff4571002cd48b99a2b92dc829ce39cb9 upstream.
The vcpus are initialized with irr_pending set to false, but
loading the LAPIC registers with pending IRR fails to reset
the irr_pending variable.
commit fb341f572d26e0786167cd96b90cc4febed830cf upstream.
The invlpg prefault optimization breaks Windows 2008 R2 occasionally.
The visible effect is that the invlpg handler instantiates a pte which
is, microseconds later, written with a different gfn by another vcpu.
The OS could have other mechanisms to prevent a present translation from
being used, which the hypervisor is unaware of.
While the documentation states that the cpu is at liberty to prefetch tlb
entries, it looks like this is not heeded, so remove tlb prefetch from
invlpg.
commit 0f764806438d5576ac58898332e5dcf30bb8a679 upstream.
The assumption that acpi_table_parse passes the return value
of the hanlder function to the caller proved wrong
recently. The return value of the handler function is
totally ignored. This makes the initialization code for AMD
IOMMU buggy in a way that could cause a kernel panic on
initialization. This patch fixes the issue in the AMD IOMMU
driver.
commit 39d30770992895d55789de64bad2349510af68d0 upstream.
The wrong address was being used to write the SCIR led regs on
remote hubs. Also, there was an inconsistency between how BIOS
and the kernel indexed these regs. Standardize on using the
lower 6 bits of the APIC ID as the index.
This patch fixes the problem of writing to an errant address to
a cpu # >= 64.
Reviewed-by: Jack Steiner <steiner@sgi.com>
Cc: Robin Holt <holt@sgi.com>
LKML-Reference: <4B3922F9.3060905@sgi.com>
[ v2: fix a number of annoying checkpatch artifacts and whitespace noise ]
commit bb7f20b1c639606def3b91f4e4aca6daeee5d80a upstream.
This patch fixes the handling of VSX alignment faults in little-endian
mode (the current code assumes the processor is in big-endian mode).
The patch also makes the handlers clear the top 8 bytes of the register
when handling an 8 byte VSX load.
This is based on 2.6.32.
Signed-off-by: Neil Campbell <neilc@linux.vnet.ibm.com>
Acked-by: Michael Neuling <mikey@neuling.org>
commit 45a94d7cd45ed991914011919e7d40eb6d2546d1 upstream.
xsave_cntxt_init() does something like:
cpuid(0xd, ..); // find out what features FP/SSE/.. etc are supported
xsetbv(); // enable the features known to OS
cpuid(0xd, ..); // find out the size of the context for features enabled
Depending on what features get enabled in xsetbv(), value of the
cpuid.eax=0xd.ecx=0.ebx changes correspondingly (representing the
size of the context that is enabled).
As we don't have volatile keyword for native_cpuid(), gcc 4.1.2
optimizes away the second cpuid and the kernel continues to use
the cpuid information obtained before xsetbv(), ultimately leading to kernel
crash on processors supporting more state than the legacy FP/SSE.
Add "volatile" for native_cpuid().
LKML-Reference: <1261009542.2745.55.camel@sbs-t61.sc.intel.com>
commit cd7bcf32d42b15891620b3f1387a00178b54291a upstream.
Needed for commit 2c992208 ("intel-iommu: Detect DMAR in hyperspace at
probe time.) to build on IA64.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Upstream commit a2202aa29289db64ca7988b12343158b67b27f10.
On platforms where bios handles the thermal monitor interrupt,
APIC_LVTTHMR on each logical CPU is programmed to generate a SMI and OS
can't touch it.
Unfortunately AP bringup sequence using INIT-SIPI-SIPI clear all
the LVT entries except the mask bit. Essentially this results in
all LVT entries including the thermal monitoring interrupt set to masked
(clearing the bios programmed value for APIC_LVTTHMR).
And this leads to kernel take over the thermal monitoring interrupt
on AP's but not on BSP (leaving the bios programmed value only on BSP).
As a result of this, we have seen system hangs when the thermal
monitoring interrupt is generated.
Fix this by reading the initial value of thermal LVT entry on BSP
and if bios has taken over the control, then program the same value
on all AP's and leave the thermal monitoring interrupt control
on all the logical cpu's to the bios.
Signed-off-by: Yong Wang <yong.y.wang@intel.com>
Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <20091110013824.GA24940@ywang-moblin2.bj.intel.com>
commit 03a05ed1152944000151d57b71000de287a1eb02 upstream.
Currently, ARB_DISABLE is a NOP on all of the recent Intel platforms.
For such platforms, reduce contention on c3_lock by skipping the fake
ARB_DISABLE.
The cpu model id on one laptop is 14. If we disable ARB_DISABLE on this box,
the box can't be booted correctly. But if we still enable ARB_DISABLE on this
box, the box can be booted correctly.
So we still use the ARB_DISABLE for the cpu which mode id is less than 0x0f.
http://bugzilla.kernel.org/show_bug.cgi?id=14700
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
[ Upstream commit 7f5620a5fcd658f219e85831d3691908f1eccbde ]
"ARCH" can be just about anything, so we shouldn't end up
with UTS_MACHINE of "sparc" in a 64-bit kernel build just
because someone set the personality using 'sparc32' or
similar. CONFIG_SPARC64 drives the compilation and
therefore provides the definitive value, not "ARCH".
This mirrors commit 8c6531f7a99f29ba8817ffb12cc9ecf190049bd6
(x86: correctly set UTS_MACHINE for "make ARCH=x86")
