The recent ioapic cleanups changed the affinity setting in
setup_ioapic_dest() from a direct write to the hardware to the delayed
affinity setup via irq_set_affinity().
That results in a warning from chained_irq_exit():
WARNING: CPU: 0 PID: 5 at kernel/irq/migration.c:32 irq_move_masked_irq
[<ffffffff810a0a88>] irq_move_masked_irq+0xb8/0xc0
[<ffffffff8103c161>] ioapic_ack_level+0x111/0x130
[<ffffffff812bbfe8>] intel_gpio_irq_handler+0x148/0x1c0
The reason is that irq_set_affinity() does not write directly to the
hardware. It marks the affinity setting as pending and executes it
from the next interrupt. The chained handler infrastructure does not
take the irq descriptor lock for performance reasons because such a
chained interrupt is not visible to any interfaces. So the delayed
affinity setting triggers the warning in irq_move_masked_irq().
Restore the old behaviour by calling the set_affinity function of the
ioapic chip in setup_ioapic_dest(). This is safe as none of the
interrupts can be on the fly at this point.
Fixes: aa5cb97f14a2 'x86/irq: Remove x86_io_apic_ops.set_affinity and related interfaces'
Reported-and-tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: jarkko.nikula@linux.intel.com
When restoring the system register state for an AArch32 guest at EL2,
writes to DACR32_EL2 may not be correctly synchronised by Cortex-A57,
which can lead to the guest effectively running with junk in the DACR
and running into unexpected domain faults.
This patch works around the issue by re-ordering our restoration of the
AArch32 register aliases so that they happen before the AArch64 system
registers. Ensuring that the registers are restored in this order
guarantees that they will be correctly synchronised by the core.
Cc: <stable@vger.kernel.org>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
KVM/ARM changes for 4.3-rc2
- Fix timer interrupt injection after the rework
that went in during the merge window
- Reset the timer to zero on reboot
- Make sure the TCR_EL2 RES1 bits are really set to 1
- Fix a PSCI affinity bug for non-existing vcpus
It's not used anywhere.
Signed-off-by: Juergen Gross <jgross@suse.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: akataria@vmware.com
Cc: chrisw@sous-sol.org
Cc: jeremy@goop.org
Cc: virtualization@lists.linux-foundation.org
Link: http://lkml.kernel.org/r/1442227343-403-1-git-send-email-jgross@suse.com
Depending on CONFIG_ARM64_HW_AFDBM, we use either bit 57 or 51 of the
pte to represent PTE_WRITE. Given that bit 51 is reserved prior to
ARMv8.1, we can just use that bit regardless of the config option. That
also matches what happens if a kernel configured with ARM64_HW_AFDBM=y
is run on a CPU without the DBM functionality.
Cc: Julien Grall <julien.grall@citrix.com>
Tested-by: Julien Grall <julien.grall@citrix.com>
The pte_modify() function with hardware AF/DBM enabled must transfer the
hardware dirty information to the software PTE_DIRTY bit. However, it
was setting this bit in newprot and the mask does not cover such bit.
This patch sets PTE_DIRTY on the original pte which will be preserved in
the returned value.
Fixes: 2f4b829c625e ("arm64: Add support for hardware updates of the access and dirty pte bits")
Tested-by: Will Deacon <will.deacon@arm.com>
Commit 2f4b829c625e ("arm64: Add support for hardware updates of the
access and dirty pte bits") introduced support for handling hardware
updates of the access flag and dirty status. The PTE is automatically
dirtied in hardware (if supported) by clearing the PTE_RDONLY bit when
the PTE_DBM/PTE_WRITE bit is set. The pte_hw_dirty() macro was added to
detect a hardware dirtied pte. The pte_dirty() macro checks for both
software PTE_DIRTY and pte_hw_dirty().
Functions like pte_modify() clear the PTE_RDONLY bit since it is meant
to be set in set_pte_at() when written to memory. In such cases,
pte_hw_dirty() would return true even though such pte is clean. This
patch changes pte_hw_dirty() to test the PTE_DBM/PTE_WRITE bit together
with PTE_RDONLY.
Reported-by: Julien Grall <julien.grall@citrix.com>
If CMA is turned on and CMA size is set to zero, kernel should
behave as if CMA was not enabled at compile time.
Every dma allocation should check existence of cma area
before requesting memory.
Arm has done this by commit e464ef16c4f0 ("arm: dma-mapping: add
checking cma area initialized"), also do this for arm64.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
While the following commit:
37868fe113 ("x86/ldt: Make modify_ldt synchronous")
added a nice comment explaining that Xen needs page-aligned
whole page chunks for guest descriptor tables, it then
nevertheless used kzalloc() on the small size path.
As I'm unaware of guarantees for kmalloc(PAGE_SIZE, ) to return
page-aligned memory blocks, I believe this needs to be switched
back to __get_free_page() (or better get_zeroed_page()).
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/55E735D6020000780009F1E6@prv-mh.provo.novell.com
The CONFIG_VM86 Kconfig help text is actively misleading, so fix it:
- Don't mark it 'obsolete' in the text as we'll support the ABI as long as CPUs
support it.
- Qualify the part about software emulation and mention that for some apps you
want a real vm86 mode.
- Don't scare users away from the option, instead explain what it does.
Reported-by: Stas Sergeev <stsp@list.ru>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Austin S Hemmelgarn <ahferroin7@gmail.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: linuxppc-dev@lists.ozlabs.org
Julia Lawall.
Cc: Scott Wood <scottwood@freescale.com>
Julia Lawall.
Sasha reported that we can get here with .idx==-1, and
cpuc->event_constraints unallocated.
Suggested-by: Stephane Eranian <eranian@google.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Fixes: b371b5943178 ("perf/x86: Fix event/group validation")
924e101a7ab6 ("x86/debug: Dump family, model, stepping of the
boot CPU") had its good intentions to dump the exact F/M/S as an
aid during debugging sessions but its output can be ambiguous.
Fix that:
-smpboot: CPU0: Intel Core Processor (Broadwell) (fam: 06, model: 47, stepping: 02)
+smpboot: CPU0: Intel Core Processor (Broadwell) (family: 0x6, model: 0x47, stepping: 0x2)
Also, spell out "family".
Link: http://lkml.kernel.org/r/1441914927-32037-1-git-send-email-bp@alien8.de
git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris
Pull CRIS updates from Jesper Nilsson:
"Mostly removal of old cruft of which we can use a generic version, or
fixes for code not commonly run in the cris port, but also additions
to enable some good debug"
* tag 'cris-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/jesper/cris: (25 commits)
CRISv10: delete unused lib/dmacopy.c
CRISv10: delete unused lib/old_checksum.c
CRIS: fix switch_mm() lockdep splat
CRISv32: enable LOCKDEP_SUPPORT
CRIS: add STACKTRACE_SUPPORT
CRISv32: annotate irq enable in idle loop
CRISv32: add support for irqflags tracing
CRIS: UAPI: use generic types.h
CRIS: UAPI: use generic shmbuf.h
CRIS: UAPI: use generic msgbuf.h
CRIS: UAPI: use generic socket.h
CRIS: UAPI: use generic sembuf.h
CRIS: UAPI: use generic sockios.h
CRIS: UAPI: use generic auxvec.h
CRIS: UAPI: use generic headers via Kbuild
CRIS: UAPI: fix elf.h export
CRIS: don't make asm/elf.h depend on asm/user.h
CRIS: UAPI: fix ptrace.h
CRISv32: Squash compile warnings for axisflashmap
CRISv32: Add GPIO driver to the default configs
Merge fourth patch-bomb from Andrew Morton:
- sys_membarier syscall
- seq_file interface changes
- a few misc fixups
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
revert "ocfs2/dlm: use list_for_each_entry instead of list_for_each"
mm/early_ioremap: add explicit #include of asm/early_ioremap.h
fs/seq_file: convert int seq_vprint/seq_printf/etc... returns to void
selftests: enhance membarrier syscall test
selftests: add membarrier syscall test
sys_membarrier(): system-wide memory barrier (generic, x86)
MODSIGN: fix a compilation warning in extract-cert
Newer bitfiles needs the reduced clk even for SMP builds
Cc: <stable@vger.kernel.org> #4.2
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Here is an implementation of a new system call, sys_membarrier(), which
executes a memory barrier on all threads running on the system. It is
implemented by calling synchronize_sched(). It can be used to
distribute the cost of user-space memory barriers asymmetrically by
transforming pairs of memory barriers into pairs consisting of
sys_membarrier() and a compiler barrier. For synchronization primitives
that distinguish between read-side and write-side (e.g. userspace RCU
[1], rwlocks), the read-side can be accelerated significantly by moving
the bulk of the memory barrier overhead to the write-side.
The existing applications of which I am aware that would be improved by
this system call are as follows:
* Through Userspace RCU library (http://urcu.so)
- DNS server (Knot DNS) https://www.knot-dns.cz/
- Network sniffer (http://netsniff-ng.org/)
- Distributed object storage (https://sheepdog.github.io/sheepdog/)
- User-space tracing (http://lttng.org)
- Network storage system (https://www.gluster.org/)
- Virtual routers (https://events.linuxfoundation.org/sites/events/files/slides/DPDK_RCU_0MQ.pdf)
- Financial software (https://lkml.org/lkml/2015/3/23/189)
Those projects use RCU in userspace to increase read-side speed and
scalability compared to locking. Especially in the case of RCU used by
libraries, sys_membarrier can speed up the read-side by moving the bulk of
the memory barrier cost to synchronize_rcu().
* Direct users of sys_membarrier
- core dotnet garbage collector (https://github.com/dotnet/coreclr/issues/198)
Microsoft core dotnet GC developers are planning to use the mprotect()
side-effect of issuing memory barriers through IPIs as a way to implement
Windows FlushProcessWriteBuffers() on Linux. They are referring to
sys_membarrier in their github thread, specifically stating that
sys_membarrier() is what they are looking for.
To explain the benefit of this scheme, let's introduce two example threads:
Thread A (non-frequent, e.g. executing liburcu synchronize_rcu())
Thread B (frequent, e.g. executing liburcu
rcu_read_lock()/rcu_read_unlock())
In a scheme where all smp_mb() in thread A are ordering memory accesses
with respect to smp_mb() present in Thread B, we can change each
smp_mb() within Thread A into calls to sys_membarrier() and each
smp_mb() within Thread B into compiler barriers "barrier()".
Before the change, we had, for each smp_mb() pairs:
Thread A Thread B
previous mem accesses previous mem accesses
smp_mb() smp_mb()
following mem accesses following mem accesses
After the change, these pairs become:
Thread A Thread B
prev mem accesses prev mem accesses
sys_membarrier() barrier()
follow mem accesses follow mem accesses
As we can see, there are two possible scenarios: either Thread B memory
accesses do not happen concurrently with Thread A accesses (1), or they
do (2).
1) Non-concurrent Thread A vs Thread B accesses:
Thread A Thread B
prev mem accesses
sys_membarrier()
follow mem accesses
prev mem accesses
barrier()
follow mem accesses
In this case, thread B accesses will be weakly ordered. This is OK,
because at that point, thread A is not particularly interested in
ordering them with respect to its own accesses.
2) Concurrent Thread A vs Thread B accesses
Thread A Thread B
In this case, thread B accesses, which are ensured to be in program
order thanks to the compiler barrier, will be "upgraded" to full
smp_mb() by synchronize_sched().
* Benchmarks
On Intel Xeon E5405 (8 cores)
(one thread is calling sys_membarrier, the other 7 threads are busy
looping)
1000 non-expedited sys_membarrier calls in 33s =3D 33 milliseconds/call.
* User-space user of this system call: Userspace RCU library
Both the signal-based and the sys_membarrier userspace RCU schemes
permit us to remove the memory barrier from the userspace RCU
rcu_read_lock() and rcu_read_unlock() primitives, thus significantly
accelerating them. These memory barriers are replaced by compiler
barriers on the read-side, and all matching memory barriers on the
write-side are turned into an invocation of a memory barrier on all
active threads in the process. By letting the kernel perform this
synchronization rather than dumbly sending a signal to every process
threads (as we currently do), we diminish the number of unnecessary wake
ups and only issue the memory barriers on active threads. Non-running
threads do not need to execute such barrier anyway, because these are
implied by the scheduler context switches.
Results in liburcu:
Operations in 10s, 6 readers, 2 writers:
memory barriers in reader: 1701557485 reads, 2202847 writes
signal-based scheme: 9830061167 reads, 6700 writes
sys_membarrier: 9952759104 reads, 425 writes
sys_membarrier (dyn. check): 7970328887 reads, 425 writes
The dynamic sys_membarrier availability check adds some overhead to
the read-side compared to the signal-based scheme, but besides that,
sys_membarrier slightly outperforms the signal-based scheme. However,
this non-expedited sys_membarrier implementation has a much slower grace
period than signal and memory barrier schemes.
Besides diminishing the number of wake-ups, one major advantage of the
membarrier system call over the signal-based scheme is that it does not
need to reserve a signal. This plays much more nicely with libraries,
and with processes injected into for tracing purposes, for which we
cannot expect that signals will be unused by the application.
An expedited version of this system call can be added later on to speed
up the grace period. Its implementation will likely depend on reading
the cpu_curr()->mm without holding each CPU's rq lock.
This patch adds the system call to x86 and to asm-generic.
[1] http://urcu.so
membarrier(2) man page:
MEMBARRIER(2) Linux Programmer's Manual MEMBARRIER(2)
NAME
membarrier - issue memory barriers on a set of threads
SYNOPSIS
#include <linux/membarrier.h>
int membarrier(int cmd, int flags);
DESCRIPTION
The cmd argument is one of the following:
MEMBARRIER_CMD_QUERY
Query the set of supported commands. It returns a bitmask of
supported commands.
MEMBARRIER_CMD_SHARED
Execute a memory barrier on all threads running on the system.
Upon return from system call, the caller thread is ensured that
all running threads have passed through a state where all memory
accesses to user-space addresses match program order between
entry to and return from the system call (non-running threads
are de facto in such a state). This covers threads from all pro=E2=80=90
cesses running on the system. This command returns 0.
The flags argument needs to be 0. For future extensions.
All memory accesses performed in program order from each targeted
thread is guaranteed to be ordered with respect to sys_membarrier(). If
we use the semantic "barrier()" to represent a compiler barrier forcing
memory accesses to be performed in program order across the barrier,
and smp_mb() to represent explicit memory barriers forcing full memory
ordering across the barrier, we have the following ordering table for
each pair of barrier(), sys_membarrier() and smp_mb():
The pair ordering is detailed as (O: ordered, X: not ordered):
barrier() smp_mb() sys_membarrier()
barrier() X X O
smp_mb() X O O
sys_membarrier() O O O
RETURN VALUE
On success, these system calls return zero. On error, -1 is returned,
and errno is set appropriately. For a given command, with flags
argument set to 0, this system call is guaranteed to always return the
same value until reboot.
ERRORS
ENOSYS System call is not implemented.
EINVAL Invalid arguments.
Linux 2015-04-15 MEMBARRIER(2)
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Nicholas Miell <nmiell@comcast.net>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
On old ARM chips, unaligned accesses to memory are not trapped and
fixed. On module load, symbols are relocated, and the relocation of
__bug_table symbols is done on a u32 basis. Yet the section is not
aligned to a multiple of 4 address, but to a multiple of 2.
This triggers an Oops on pxa architecture, where address 0xbf0021ea
is the first relocation in the __bug_table section :
apply_relocate(): pxa3xx_nand: section 13 reloc 0 sym ''
Unable to handle kernel paging request at virtual address bf0021ea
pgd = e1cd0000
[bf0021ea] *pgd=c1cce851, *pte=c1cde04f, *ppte=c1cde01f
Internal error: Oops: 23 [#1] ARM
Modules linked in:
CPU: 0 PID: 606 Comm: insmod Not tainted 4.2.0-rc8-next-20150828-cm-x300+ #887
Hardware name: CM-X300 module
task: e1c68700 ti: e1c3e000 task.ti: e1c3e000
PC is at apply_relocate+0x2f4/0x3d4
LR is at 0xbf0021ea
pc : [<c000e7c8>] lr : [<bf0021ea>] psr: 80000013
sp : e1c3fe30 ip : 60000013 fp : e49e8c60
r10: e49e8fa8 r9 : 00000000 r8 : e49e7c58
r7 : e49e8c38 r6 : e49e8a58 r5 : e49e8920 r4 : e49e8918
r3 : bf0021ea r2 : bf007034 r1 : 00000000 r0 : bf000000
Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 0000397f Table: c1cd0018 DAC: 00000051
Process insmod (pid: 606, stack limit = 0xe1c3e198)
[<c000e7c8>] (apply_relocate) from [<c005ce5c>] (load_module+0x1248/0x1f5c)
[<c005ce5c>] (load_module) from [<c005dc54>] (SyS_init_module+0xe4/0x170)
[<c005dc54>] (SyS_init_module) from [<c000a420>] (ret_fast_syscall+0x0/0x38)
Fix this by ensuring entries in __bug_table are all aligned to at least
of multiple of 4. This transforms a module section __bug_table as :
- [12] __bug_table PROGBITS 00000000 002232 000018 00 A 0 0 1
+ [12] __bug_table PROGBITS 00000000 002232 000018 00 A 0 0 4
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
When Xen is copying data to/from the guest it will check if the kernel
has the right to do the access. If not, the hypercall will return an
error.
After the commit a5e090acbf545c0a3b04080f8a488b17ec41fe02 "ARM:
software-based privileged-no-access support", the kernel can't access
any longer the user space by default. This will result to fail on every
hypercall made by the userspace (i.e via privcmd).
We have to enable the userspace access and then restore the correct
permission every time the privcmd is used to made an hypercall.
I didn't find generic helpers to do a these operations, so the change
is only arm32 specific.
Reported-by: Riku Voipio <riku.voipio@linaro.org>
Signed-off-by: Julien Grall <julien.grall@citrix.com>
We need to have memory dependencies on get_domain/set_domain to avoid
the compiler over-optimising these inline assembly instructions.
Loads/stores must not be reordered across a set_domain(), so introduce
a compiler barrier for that assembly.
The value of get_domain() must not be cached across a set_domain(), but
we still want to allow the compiler to optimise it away. Introduce a
dependency on current_thread_info()->cpu_domain to avoid this; the new
memory clobber in set_domain() should therefore cause the compiler to
re-load this. The other advantage of using this is we should have its
address in the register set already, or very soon after at most call
sites.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
As of 1eef5d2f1b46 ("ARM: domains: switch to keeping domain value in
register") we no longer need to include asm/domains.h into
asm/thread_info.h. Remove it.
new logic
Since event->hw.itrace_started is now set in pmu::start() to signal the beginning of
the trace, do so also in the intel_bts driver.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: acme@infradead.org
Cc: adrian.hunter@intel.com
Cc: hpa@zytor.com
Link: http://lkml.kernel.org/r/1437140050-23363-4-git-send-email-alexander.shishkin@linux.intel.com
guest support
Only emit the test-and-set fallback for Hypervisors lacking
PARAVIRT_SPINLOCKS support when building for guests.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: stable@vger.kernel.org # 4.2
Dave ran into horrible performance on a VM without PARAVIRT_SPINLOCKS
set and Linus noted that the test-and-set implementation was retarded.
One should spin on the variable with a load, not a RMW.
While there, remove 'queued' from the name, as the lock isn't queued
at all, but a simple test-and-set.
Reported-by: Dave Chinner <david@fromorbit.com>
Tested-by: Dave Chinner <david@fromorbit.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: stable@vger.kernel.org # v4.2+
Link: http://lkml.kernel.org/r/20150904152523.GR18673@twins.programming.kicks-ass.net
Merge third patch-bomb from Andrew Morton:
- even more of the rest of MM
- lib/ updates
- checkpatch updates
- small changes to a few scruffy filesystems
- kmod fixes/cleanups
- kexec updates
- a dma-mapping cleanup series from hch
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits)
dma-mapping: consolidate dma_set_mask
dma-mapping: consolidate dma_supported
dma-mapping: cosolidate dma_mapping_error
dma-mapping: consolidate dma_{alloc,free}_noncoherent
dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent}
mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd()
mm: make sure all file VMAs have ->vm_ops set
mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff()
mm: mark most vm_operations_struct const
namei: fix warning while make xmldocs caused by namei.c
ipc: convert invalid scenarios to use WARN_ON
zlib_deflate/deftree: remove bi_reverse()
lib/decompress_unlzma: Do a NULL check for pointer
lib/decompressors: use real out buf size for gunzip with kernel
fs/affs: make root lookup from blkdev logical size
sysctl: fix int -> unsigned long assignments in INT_MIN case
kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo
kexec: align crash_notes allocation to make it be inside one physical page
kexec: remove unnecessary test in kimage_alloc_crash_control_pages()
kexec: split kexec_load syscall from kexec core code
Pull late ARM SoC updates from Kevin Hilman:
"This is a collection of a few late fixes and other misc stuff that had
dependencies on things being merged from other trees.
The bulk of the changes are for samsung/exynos SoCs for some changes
that needed a few minor reworks so ended up a bit late. The others
are mainly for qcom SoCs: a couple fixes and some DTS updates"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits)
ARM: multi_v7_defconfig: Enable PBIAS regulator
soc: qcom: smd: Correct fBLOCKREADINTR handling
soc: qcom: smd: Use correct remote processor ID
soc: qcom: smem: Fix errant private access
ARM: dts: qcom: msm8974-sony-xperia-honami: Use stdout-path
ARM: dts: qcom: msm8960-cdp: Use stdout-path
ARM: dts: qcom: msm8660-surf: Use stdout-path
ARM: dts: qcom: ipq8064-ap148: Use stdout-path
ARM: dts: qcom: apq8084-mtp: Use stdout-path
ARM: dts: qcom: apq8084-ifc6540: Use stdout-path
ARM: dts: qcom: apq8074-dragonboard: Use stdout-path
ARM: dts: qcom: apq8064-ifc6410: Use stdout-path
ARM: dts: qcom: apq8064-cm-qs600: Use stdout-path
ARM: dts: qcom: Label serial nodes for aliasing and stdout-path
reset: ath79: Fix missing spin_lock_init
reset: Add (devm_)reset_control_get stub functions
ARM: EXYNOS: switch to using generic cpufreq driver for exynos4x12
cpufreq: exynos: Remove unselectable rule for arm-exynos-cpufreq.o
ARM: dts: add iommu property to JPEG device for exynos4
ARM: dts: enable SPI1 for exynos4412-odroidu3
Pull more kvm updates from Paolo Bonzini:
"ARM:
- Full debug support for arm64
- Active state switching for timer interrupts
- Lazy FP/SIMD save/restore for arm64
- Generic ARMv8 target
PPC:
- Book3S: A few bug fixes
- Book3S: Allow micro-threading on POWER8
x86:
- Compiler warnings
Generic:
- Adaptive polling for guest halt"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (49 commits)
kvm: irqchip: fix memory leak
kvm: move new trace event outside #ifdef CONFIG_KVM_ASYNC_PF
KVM: trace kvm_halt_poll_ns grow/shrink
KVM: dynamic halt-polling
KVM: make halt_poll_ns per-vCPU
Silence compiler warning in arch/x86/kvm/emulate.c
kvm: compile process_smi_save_seg_64() only for x86_64
KVM: x86: avoid uninitialized variable warning
KVM: PPC: Book3S: Fix typo in top comment about locking
KVM: PPC: Book3S: Fix size of the PSPB register
KVM: PPC: Book3S HV: Exit on H_DOORBELL if HOST_IPI is set
KVM: PPC: Book3S HV: Fix race in starting secondary threads
KVM: PPC: Book3S: correct width in XER handling
KVM: PPC: Book3S HV: Fix preempted vcore stolen time calculation
KVM: PPC: Book3S HV: Fix preempted vcore list locking
KVM: PPC: Book3S HV: Implement H_CLEAR_REF and H_CLEAR_MOD
KVM: PPC: Book3S HV: Fix bug in dirty page tracking
KVM: PPC: Book3S HV: Fix race in reading change bit when removing HPTE
KVM: PPC: Book3S HV: Implement dynamic micro-threading on POWER8
KVM: PPC: Book3S HV: Make use of unused threads when running guests
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen terminology fixes from David Vrabel:
"Use the correct GFN/BFN terms more consistently"
* tag 'for-linus-4.3-rc0b-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/xenbus: Rename the variable xen_store_mfn to xen_store_gfn
xen/privcmd: Further s/MFN/GFN/ clean-up
hvc/xen: Further s/MFN/GFN clean-up
video/xen-fbfront: Further s/MFN/GFN clean-up
xen/tmem: Use xen_page_to_gfn rather than pfn_to_gfn
xen: Use correctly the Xen memory terminologies
arm/xen: implement correctly pfn_to_mfn
xen: Make clear that swiotlb and biomerge are dealing with DMA address
Pull microblaze update from Michal Simek.
* 'next' of git://git.monstr.eu/linux-2.6-microblaze:
elf-em.h: move EM_MICROBLAZE to the common header
git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel
Pull hexagon updates from Richard Kuo:
"Just two fixes -- one for a uapi header and one for a timer interface"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rkuo/linux-hexagon-kernel:
Revert "Hexagon: fix signal.c compile error"
hexagon/time: Migrate to new 'set-state' interface
Almost everyone implements dma_set_mask the same way, although some time
that's hidden in ->set_dma_mask methods.
This patch consolidates those into a common implementation that either
calls ->set_dma_mask if present or otherwise uses the default
implementation. Some architectures used to only call ->set_dma_mask
after the initial checks, and those instance have been fixed to do the
full work. h8300 implemented dma_set_mask bogusly as a no-ops and has
been fixed.
Unfortunately some architectures overload unrelated semantics like changing
the dma_ops into it so we still need to allow for an architecture override
for now.
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Most architectures just call into ->dma_supported, but some also return 1
if the method is not present, or 0 if no dma ops are present (although
that should never happeb). Consolidate this more broad version into
common code.
Also fix h8300 which inorrectly always returned 0, which would have been
a problem if it's dma_set_mask implementation wasn't a similarly buggy
noop.
As a few architectures have much more elaborate implementations, we
still allow for arch overrides.
Currently there are three valid implementations of dma_mapping_error:
(1) call ->mapping_error
(2) check for a hardcoded error code
(3) always return 0
This patch provides a common implementation that calls ->mapping_error
if present, then checks for DMA_ERROR_CODE if defined or otherwise
returns 0.
Most architectures do not support non-coherent allocations and either
define dma_{alloc,free}_noncoherent to their coherent versions or stub
them out.
Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips
implements them directly.
This patch moves the Openrisc version to common code, and handles the
DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance.
Note that actual non-coherent allocations require a dma_cache_sync
implementation, so if non-coherent allocations didn't work on
an architecture before this patch they still won't work after it.
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
Add the additional "vm_flags_t vm_flags" argument to do_mmap_pgoff(),
rename it to do_mmap(), and re-introduce do_mmap_pgoff() as a simple
wrapper on top of do_mmap(). Perhaps we should update the callers of
do_mmap_pgoff() and kill it later.
This way mpx_mmap() can simply call do_mmap(vm_flags => VM_MPX) and do not
play with vm internals.
After this change mmap_region() has a single user outside of mmap.c,
arch/tile/mm/elf.c:arch_setup_additional_pages(). It would be nice to
change arch/tile/ and unexport mmap_region().
[kirill@shutemov.name: fix build]
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Minchan Kim <minchan@kernel.org>
With two exceptions (drm/qxl and drm/radeon) all vm_operations_struct
structs should be constant.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
When loading x86 64bit kernel above 4GiB with patched grub2, got kernel
gunzip error.
| early console in decompress_kernel
| decompress_kernel:
| input: [0x807f2143b4-0x807ff61aee]
| output: [0x807cc00000-0x807f3ea29b] 0x027ea29c: output_len
| boot via startup_64
| KASLR using RDTSC...
| new output: [0x46fe000000-0x470138cfff] 0x0338d000: output_run_size
| decompress: [0x46fe000000-0x47007ea29b] <=== [0x807f2143b4-0x807ff61aee]
| Decompressing Linux... gz...
| uncompression error
| -- System halted
the new buffer is at 0x46fe000000ULL, decompressor_gzip is using
0xffffffb901ffffff as out_len. gunzip in lib/zlib_inflate/inflate.c cap
that len to 0x01ffffff and decompress fails later.
We could hit this problem with crashkernel booting that uses kexec loading
kernel above 4GiB.
We have decompress_* support:
1. inbuf[]/outbuf[] for kernel preboot.
2. inbuf[]/flush() for initramfs
3. fill()/flush() for initrd.
This bug only affect kernel preboot path that use outbuf[].
Add __decompress and take real out_buf_len for gunzip instead of guessing
wrong buf size.
Fixes: 1431574a1c4 (lib/decompressors: fix "no limit" output buffer length)
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Jon Medhurst <tixy@linaro.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
This fixes a race which can result in the same virtual IRQ number
being assigned to two different MSI interrupts. The most visible
consequence of that is usually a warning and stack trace from the
sysfs code about an attempt to create a duplicate entry in sysfs.
The race happens when one CPU (say CPU 0) is disposing of an MSI
while another CPU (say CPU 1) is setting up an MSI. CPU 0 calls
(for example) pnv_teardown_msi_irqs(), which calls
msi_bitmap_free_hwirqs() to indicate that the MSI (i.e. its
hardware IRQ number) is no longer in use. Then, before CPU 0 gets
to calling irq_dispose_mapping() to free up the virtal IRQ number,
CPU 1 comes in and calls msi_bitmap_alloc_hwirqs() to allocate an
MSI, and gets the same hardware IRQ number that CPU 0 just freed.
CPU 1 then calls irq_create_mapping() to get a virtual IRQ number,
which sees that there is currently a mapping for that hardware IRQ
number and returns the corresponding virtual IRQ number (which is
the same virtual IRQ number that CPU 0 was using). CPU 0 then
calls irq_dispose_mapping() and frees that virtual IRQ number.
Now, if another CPU comes along and calls irq_create_mapping(), it
is likely to get the virtual IRQ number that was just freed,
resulting in the same virtual IRQ number apparently being used for
two different hardware interrupts.
To fix this race, we just move the call to msi_bitmap_free_hwirqs()
to after the call to irq_dispose_mapping(). Since virq_to_hw()
doesn't work for the virtual IRQ number after irq_dispose_mapping()
has been called, we need to call it before irq_dispose_mapping() and
remember the result for the msi_bitmap_free_hwirqs() call.
The pattern of calling msi_bitmap_free_hwirqs() before
irq_dispose_mapping() appears in 5 places under arch/powerpc, and
appears to have originated in commit 05af7bd2d75e ("[POWERPC] MPIC
U3/U4 MSI backend") from 2007.
Fixes: 05af7bd2d75e ("[POWERPC] MPIC U3/U4 MSI backend")
Cc: stable@vger.kernel.org # v2.6.22+
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
The linux/audit.h header uses EM_MICROBLAZE in order to define
AUDIT_ARCH_MICROBLAZE, but it's only available in the microblaze
asm headers. Move it to the common elf-em.h header so that the
define can be used on non-microblaze systems. Otherwise we get
build errors that EM_MICROBLAZE isn't defined when we try to use
the AUDIT_ARCH_MICROBLAZE symbol.
git://codeaurora.org/quic/kernel/agross-msm into next/late
Qualcomm ARM Based Device Tree Updates for v4.3-rc2
* Add labels for serial nodes to be used for aliasing and stdout-path
* Add stdout-path for APQ8064 Compulab QS600
* Add stdout-path for APQ8064 Inforce 6410
* Add stdout-path for APQ8074 Dragonboard
* Add stdout-path for APQ8084 Inforce 6540
* Add stdout-path for APQ8084 MTP
* Add stdout-path for IPQ8064 AP148
* Add stdout-path for MSM8660 Surf
* Add stdout-path for MSM8960 CDP
* Add stdout-path for MSM8974 Xperia Honami
* tag 'qcom-dt-for-4.3-rc2' of git://codeaurora.org/quic/kernel/agross-msm: (24 commits)
ARM: dts: qs600: Add real regulators to sdcc
ARM: dts: ifc6410: add real regulators for sdcc nodes.
ARM: dts: apq8064: remove temporary fixed regulator for mmc
ARM: dts: apq8064: fix missing gsbi cell-index
ARM: dts: apq8064: Add DT support for GSBI6 and for UART pin mux
ARM: dts: apq8064: add pm8921 mpp support
ARM: dts: apq8064: Add pm8921 mfd and its gpio node
ARM: dts: msm8974: Add smem reservation and node
ARM: dts: msm8974: Add tcsr mutex node
ARM: dts: qcom: Add ks8851 node for wired ethernet
* next/defconfig: (45 commits)
ARM: add TC2 PM support to multi_v7_defconfig
ARM: tegra: Update multi_v7_defconfig
ARM: tegra: Update default configuration
ARM: at91/defconfig: at91_dt: remove ARM_AT91_ETHER
ARM: at91/defconfig: at91_dt: enable DRM hlcdc support
ARM: at91: at91_dt_defconfig: enable ISI and ov2640 support
ARM: multi_v7_defconfig: Enable Allwinner P2WI, PWM, DMA_SUN6I, cryptodev
ARM: sunxi_defconfig: Enable DMA_SUN6I, P2WI, PWM, cryptodev, EXTCON, FHANDLE
ARM: shmobile: Enable fixed voltage regulator in shmobile_defconfig
ARM: multi_v7_defconfig: Select MX6UL and MX7D
ARM: prima2_defconfig: enable build for hwspinlock
ARM: prima2_defconfig: enable build for RTC
ARM: prima2_defconfig: enable build for misc input
ARM: prima2_defconfig: enable build for SiRFSoC SDHC host
ARM: prima2_defconfig: fix the outdated defconfig
ARM: imx_v6_v7_defconfig: Select CONFIG_IKCONFIG_PROC
ARM: defconfig: orion5x: add DT support
ARM: qcom_defconfig: Enable options for KS8851 ethernet
ARM: multi_v7_defconfig: Enable support for PWM Regulators
PBIAS regulator is required for MMC module in OMAP2, OMAP3, OMAP4,
OMAP5 and DRA7 SoCs. Enable it here.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
* drivers/reset:
reset: reset-zynq: Adding support for Xilinx Zynq reset controller.
docs: dts: Added documentation for Xilinx Zynq Reset Controller bindings.
MIPS: ath79: Add the reset controller to the AR9132 dtsi
reset: Add a driver for the reset controller on the AR71XX/AR9XXX
devicetree: Add bindings for the ATH79 reset controller
reset: socfpga: Update reset-socfpga to read the altr,modrst-offset property
doc: dt: add documentation for lpc1850-rgu reset driver
reset: add driver for lpc18xx rgu
reset: sti: constify of_device_id array
ARM: STi: DT: Move reset controller constants into common location
MAINTAINERS: add include/dt-bindings/reset path to reset controller entry
The use of get_domain() in copy_thread() results in an oops on
ARMv7M/noMMU systems. The thread cpu_domain value is only used when
CONFIG_CPU_USE_DOMAINS is enabled, so there's no need to save the
value in copy_thread() except when this is enabled, and this option
will never be enabled on these platforms.
Unhandled exception: IPSR = 00000006 LR = fffffff1
CPU: 0 PID: 0 Comm: swapper Not tainted 4.2.0-next-20150909-00001-gb8ec5ad #41
Hardware name: NXP LPC18xx/43xx (Device Tree)
task: 2823fbe0 ti: 2823c000 task.ti: 2823c000
PC is at copy_thread+0x18/0x92
LR is at copy_thread+0x19/0x92
pc : [<2800a46e>] lr : [<2800a46f>] psr: 4100000b
sp : 2823df00 ip : 00000000 fp : 287c81c0
r10: 00000000 r9 : 00800300 r8 : 287c8000
r7 : 287c8000 r6 : 2818908d r5 : 00000000 r4 : 287ca000
r3 : 00000000 r2 : 00000000 r1 : fffffff0 r0 : 287ca048
xPSR: 4100000b
Reported-by: Ariel D'Alessandro <ariel@vanguardiasur.com.ar>
This macro is never referenced, remove it.
