path: root/arch
2013-10-13tile: use a more conservative __my_cpu_offset in CONFIG_PREEMPTChris Metcalf
commit f862eefec0b68e099a9fa58d3761ffb10bad97e1 upstream. It turns out the kernel relies on barrier() to force a reload of the percpu offset value. Since we can't easily modify the definition of barrier() to include "tp" as an output register, we instead provide a definition of __my_cpu_offset as extended assembly that includes a fake stack read to hazard against barrier(), forcing gcc to know that it must reread "tp" and recompute anything based on "tp" after a barrier. This fixes observed hangs in the slub allocator when we are looping on a percpu cmpxchg_double. A similar fix for ARMv7 was made in June in change 509eb76ebf97. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13mm, show_mem: suppress page counts in non-blockable contextsDavid Rientjes
commit 4b59e6c4730978679b414a8da61514a2518da512 upstream. On large systems with a lot of memory, walking all RAM to determine page types may take a half second or even more. In non-blockable contexts, the page allocator will emit a page allocation failure warning unless __GFP_NOWARN is specified. In such contexts, irqs are typically disabled and such a lengthy delay may even result in NMI watchdog timeouts. To fix this, suppress the page walk in such contexts when printing the page allocation failure warning. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mgorman@suse.de> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc32: Fix exit flag passed from traced sys_sigreturnKirill Tkhai
[ Upstream commit 7a3b0f89e3fea680f93932691ca41a68eee7ab5e ] Pass 1 in %o1 to indicate that syscall_trace accounts exit. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix not SRA'ed %o5 in 32-bit traced syscallKirill Tkhai
[ Upstream commit ab2abda6377723e0d5fbbfe5f5aa16a5523344d1 ] (From v1 to v2: changed comment) On the way linux_sparc_syscall32->linux_syscall_trace32->goto 2f, register %o5 doesn't clear its second 32-bit. Fix that. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix off by one in trampoline TLB mapping installation loop.David S. Miller
[ Upstream commit 63d499662aeec1864ec36d042aca8184ea6a938e ] Reported-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Remove RWSEM export leftoversKirill Tkhai
[ Upstream commit 61d9b9355b0d427bd1e732bd54628ff9103e496f ] The functions __down_read __down_read_trylock __down_write __down_write_trylock __up_read __up_write __downgrade_write are implemented inline, so remove corresponding EXPORT_SYMBOLs (They lead to compile errors on RT kernel). Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13sparc64: Fix ITLB handler of null pageKirill Tkhai
[ Upstream commit 1c2696cdaad84580545a2e9c0879ff597880b1a9 ] 1)Use kvmap_itlb_longpath instead of kvmap_dtlb_longpath. 2)Handle page #0 only, don't handle page #1: bleu -> blu (KERNBASE is 0x400000, so #1 does not exist too. But everything is possible in the future. Fix to not to have problems later.) 3)Remove unused kvmap_itlb_nonlinear. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc: Fix parameter clobber in csum_partial_copy_generic()Paul E. McKenney
commit d9813c3681a36774b254c0cdc9cce53c9e22c756 upstream. The csum_partial_copy_generic() uses register r7 to adjust the remaining bytes to process. Unfortunately, r7 also holds a parameter, namely the address of the flag to set in case of access exceptions while reading the source buffer. Lacking a quantum implementation of PowerPC, this commit instead uses register r9 to do the adjusting, leaving r7's pointer uncorrupted. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/vio: Fix modalias_show return valuesPrarit Bhargava
commit e82b89a6f19bae73fb064d1b3dd91fcefbb478f4 upstream. modalias_show() should return an empty string on error, not -ENODEV. This causes the following false and annoying error: > find /sys/devices -name modalias -print0 | xargs -0 cat >/dev/null cat: /sys/devices/vio/4000/modalias: No such device cat: /sys/devices/vio/4001/modalias: No such device cat: /sys/devices/vio/4002/modalias: No such device cat: /sys/devices/vio/4004/modalias: No such device cat: /sys/devices/vio/modalias: No such device Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-13powerpc/iommu: Use GFP_KERNEL instead of GFP_ATOMIC in iommu_init_table()Nishanth Aravamudan
commit 1cf389df090194a0976dc867b7fffe99d9d490cb upstream. Under heavy (DLPAR?) stress, we tripped this panic() in arch/powerpc/kernel/iommu.c::iommu_init_table(): page = alloc_pages_node(nid, GFP_ATOMIC, get_order(sz)); if (!page) panic("iommu_init_table: Can't allocate %ld bytes\n", sz); Before the panic() we got a page allocation failure for an order-2 allocation. There appears to be memory free, but perhaps not in the ATOMIC context. I looked through all the call-sites of iommu_init_table() and didn't see any obvious reason to need an ATOMIC allocation. Most call-sites in fact have an explicit GFP_KERNEL allocation shortly before the call to iommu_init_table(), indicating we are not in an atomic context. There is some indirection for some paths, but I didn't see any locks indicating that GFP_KERNEL is inappropriate. With this change under the same conditions, we have not been able to reproduce the panic. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05x86, efi: Don't map Boot Services on i386Josh Boyer
commit 700870119f49084da004ab588ea2b799689efaf7 upstream. Add patch to fix 32bit EFI service mapping (rhbz 726701) Multiple people are reporting hitting the following WARNING on i386, WARNING: at arch/x86/mm/ioremap.c:102 __ioremap_caller+0x3d3/0x440() Modules linked in: Pid: 0, comm: swapper Not tainted 3.9.0-rc7+ #95 Call Trace: [<c102b6af>] warn_slowpath_common+0x5f/0x80 [<c1023fb3>] ? __ioremap_caller+0x3d3/0x440 [<c1023fb3>] ? __ioremap_caller+0x3d3/0x440 [<c102b6ed>] warn_slowpath_null+0x1d/0x20 [<c1023fb3>] __ioremap_caller+0x3d3/0x440 [<c106007b>] ? get_usage_chars+0xfb/0x110 [<c102d937>] ? vprintk_emit+0x147/0x480 [<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de [<c102406a>] ioremap_cache+0x1a/0x20 [<c1418593>] ? efi_enter_virtual_mode+0x1e4/0x3de [<c1418593>] efi_enter_virtual_mode+0x1e4/0x3de [<c1407984>] start_kernel+0x286/0x2f4 [<c1407535>] ? repair_env_string+0x51/0x51 [<c1407362>] i386_start_kernel+0x12c/0x12f Due to the workaround described in commit 916f676f8 ("x86, efi: Retain boot service code until after switching to virtual mode") EFI Boot Service regions are mapped for a period during boot. Unfortunately, with the limited size of the i386 direct kernel map it's possible that some of the Boot Service regions will not be directly accessible, which causes them to be ioremap()'d, triggering the above warning as the regions are marked as E820_RAM in the e820 memmap. There are currently only two situations where we need to map EFI Boot Service regions, 1. To workaround the firmware bug described in 916f676f8 2. To access the ACPI BGRT image but since we haven't seen an i386 implementation that requires either, this simple fix should suffice for now. [ Added to changelog - Matt ] Reported-by: Bryan O'Donoghue <bryan.odonoghue.lkml@nexus-software.ie> Acked-by: Tom Zanussi <tom.zanussi@intel.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05x86/reboot: Add quirk to make Dell C6100 use reboot=pci automaticallyMasoud Sharbiani
commit 4f0acd31c31f03ba42494c8baf6c0465150e2621 upstream. Dell PowerEdge C6100 machines fail to completely reboot about 20% of the time. Signed-off-by: Masoud Sharbiani <msharbiani@twitter.com> Signed-off-by: Vinson Lee <vlee@twitter.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Link: http://lkml.kernel.org/r/1379717947-18042-1-git-send-email-vlee@freedesktop.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26MIPS: ath79: Fix ar933x watchdog clockFelix Fietkau
commit a1191927ace7e6f827132aa9e062779eb3f11fa5 upstream. The watchdog device on the AR933x is connected to the AHB clock, however the current code uses the reference clock. Due to the wrong rate, the watchdog driver can't calculate correct register values for a given timeout value and the watchdog unexpectedly restarts the system. The code uses the wrong value since the initial commit 04225e1d227c8e68d685936ecf42ac175fec0e54 (MIPS: ath79: add AR933X specific clock init) The patch fixes the code to use the correct clock rate to avoid the problem. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5777/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26ARM: PCI: versatile: Fix SMAP register offsetsPeter Maydell
commit 99f2b130370b904ca5300079243fdbcafa2c708b upstream. The SMAP register offsets in the versatile PCI controller code were all off by four. (This didn't have any observable bad effects because on this board PHYS_OFFSET is zero, and (a) writing zero to the flags register at offset 0x10 has no effect and (b) the reset value of the SMAP register is zero anyway, so failing to write SMAP2 didn't matter.) Signed-off-by: Peter Maydell <peter.maydell@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26powerpc: Handle unaligned ldbrx/stdbrxAnton Blanchard
commit 230aef7a6a23b6166bd4003bfff5af23c9bd381f upstream. Normally when we haven't implemented an alignment handler for a load or store instruction the process will be terminated. The alignment handler uses the DSISR (or a pseudo one) to locate the right handler. Unfortunately ldbrx and stdbrx overlap lfs and stfs so we incorrectly think ldbrx is an lfs and stdbrx is an stfs. This bug is particularly nasty - instead of terminating the process we apply an incorrect fixup and continue on. With more and more overlapping instructions we should stop creating a pseudo DSISR and index using the instruction directly, but for now add a special case to catch ldbrx/stdbrx. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14Revert "KVM: X86 emulator: fix source operand decoding for 8bit mov[zs]x ↵Greg Kroah-Hartman
instructions" This reverts commit 5b5b30580218eae22609989546bac6e44d0eda6e, which was commit 660696d1d16a71e15549ce1bf74953be1592bcd3 upstream. Paul Gortmaker <paul.gortmaker@windriver.com> writes: [this patch] introduces the following: arch/x86/kvm/emulate.c: In function ‘decode_operand’: arch/x86/kvm/emulate.c:3974:4: warning: passing argument 1 of ‘decode_register’ makes integer from pointer +without a cast [enabled by default] arch/x86/kvm/emulate.c:789:14: note: expected ‘u8’ but argument is of type ‘struct x86_emulate_ctxt *’ arch/x86/kvm/emulate.c:3974:4: warning: passing argument 2 of ‘decode_register’ makes pointer from integer +without a cast [enabled by default] arch/x86/kvm/emulate.c:789:14: note: expected ‘long unsigned int *’ but argument is of type ‘u8’ Based on the severity of the warnings above, I'm reasonably sure there will be some kind of runtime regressions due to this, but I stopped to investigate the warnings as soon as I saw them, before any run time testing. It happens because mainline v3.7-rc1~113^2~40 (dd856efafe60) does this: -static void *decode_register(u8 modrm_reg, unsigned long *regs, +static void *decode_register(struct x86_emulate_ctxt *ctxt, u8 modrm_reg, Since 660696d1d16a71e1 was only applied to stable 3.4, 3.8, and 3.9 -- and the prerequisite above is in 3.7+, the issue should be limited to 3.4.44+ Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14m32r: make memset() global for CONFIG_KERNEL_BZIP2=yGeert Uytterhoeven
commit 9a75c6e5240f7edc5955e8da5b94bde6f96070b3 upstream. Fix the m32r compile error: arch/m32r/boot/compressed/misc.c:31:14: error: static declaration of 'memset' follows non-static declaration make[5]: *** [arch/m32r/boot/compressed/misc.o] Error 1 make[4]: *** [arch/m32r/boot/compressed/vmlinux] Error 2 by removing the static keyword. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14m32r: add memcpy() for CONFIG_KERNEL_GZIP=yGeert Uytterhoeven
commit a8abbca6617e1caa2344d2d38d0a35f3e5928b79 upstream. Fix the m32r link error: LD arch/m32r/boot/compressed/vmlinux arch/m32r/boot/compressed/misc.o: In function `zlib_updatewindow': misc.c:(.text+0x190): undefined reference to `memcpy' misc.c:(.text+0x190): relocation truncated to fit: R_M32R_26_PLTREL against undefined symbol `memcpy' make[5]: *** [arch/m32r/boot/compressed/vmlinux] Error 1 by adding our own implementation of memcpy(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14m32r: consistently use "suffix-$(...)"Geert Uytterhoeven
commit df12aef6a19bb2d69859a94936bda0e6ccaf3327 upstream. Commit a556bec9955c ("m32r: fix arch/m32r/boot/compressed/Makefile") changed "$(suffix_y)" to "$(suffix-y)", but didn't update any location where "suffix_y" is set, causing: make[5]: *** No rule to make target `arch/m32r/boot/compressed/vmlinux.bin.', needed by `arch/m32r/boot/compressed/piggy.o'. Stop. make[4]: *** [arch/m32r/boot/compressed/vmlinux] Error 2 make[3]: *** [zImage] Error 2 Correct the other locations to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07powerpc: Work around gcc miscompilation of __pa() on 64-bitPaul Mackerras
commit bdbc29c19b2633b1d9c52638fb732bcde7a2031a upstream. On 64-bit, __pa(&static_var) gets miscompiled by recent versions of gcc as something like: addis 3,2,.LANCHOR1+4611686018427387904@toc@ha addi 3,3,.LANCHOR1+4611686018427387904@toc@l This ends up effectively ignoring the offset, since its bottom 32 bits are zero, and means that the result of __pa() still has 0xC in the top nibble. This happens with gcc 4.8.1, at least. To work around this, for 64-bit we make __pa() use an AND operator, and for symmetry, we make __va() use an OR operator. Using an AND operator rather than a subtraction ends up with slightly shorter code since it can be done with a single clrldi instruction, whereas it takes three instructions to form the constant (-PAGE_OFFSET) and add it on. (Note that MEMORY_START is always 0 on 64-bit.) Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29x86/xen: do not identity map UNUSABLE regions in the machine E820David Vrabel
commit 3bc38cbceb85881a8eb789ee1aa56678038b1909 upstream. If there are UNUSABLE regions in the machine memory map, dom0 will attempt to map them 1:1 which is not permitted by Xen and the kernel will crash. There isn't anything interesting in the UNUSABLE region that the dom0 kernel needs access to so we can avoid making the 1:1 mapping and treat it as RAM. We only do this for dom0, as that is where tboot case shows up. A PV domU could have an UNUSABLE region in its pseudo-physical map and would need to be handled in another patch. This fixes a boot failure on hosts with tboot. tboot marks a region in the e820 map as unusable and the dom0 kernel would attempt to map this region and Xen does not permit unusable regions to be mapped by guests. (XEN) 0000000000000000 - 0000000000060000 (usable) (XEN) 0000000000060000 - 0000000000068000 (reserved) (XEN) 0000000000068000 - 000000000009e000 (usable) (XEN) 0000000000100000 - 0000000000800000 (usable) (XEN) 0000000000800000 - 0000000000972000 (unusable) tboot marked this region as unusable. (XEN) 0000000000972000 - 00000000cf200000 (usable) (XEN) 00000000cf200000 - 00000000cf38f000 (reserved) (XEN) 00000000cf38f000 - 00000000cf3ce000 (ACPI data) (XEN) 00000000cf3ce000 - 00000000d0000000 (reserved) (XEN) 00000000e0000000 - 00000000f0000000 (reserved) (XEN) 00000000fe000000 - 0000000100000000 (reserved) (XEN) 0000000100000000 - 0000000630000000 (usable) Signed-off-by: David Vrabel <david.vrabel@citrix.com> [v1: Altered the patch and description with domU's with UNUSABLE regions] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20m68k/atari: ARAnyM - Fix NatFeat module supportGeert Uytterhoeven
commit e8184e10f89736a23ea6eea8e24cd524c5c513d2 upstream. As pointed out by Andreas Schwab, pointers passed to ARAnyM NatFeat calls should be physical addresses, not virtual addresses. Fortunately on Atari, physical and virtual kernel addresses are the same, as long as normal kernel memory is concerned, so this usually worked fine without conversion. But for modules, pointers to literal strings are located in vmalloc()ed memory. Depending on the version of ARAnyM, this causes the nf_get_id() call to just fail, or worse, crash ARAnyM itself with e.g. Gotcha! Illegal memory access. Atari PC = $968c This is a big issue for distro kernels, who want to have all drivers as loadable modules in an initrd. Add a wrapper for nf_get_id() that copies the literal to the stack to work around this issue. Reported-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20m68k: Truncate base in do_div()Andreas Schwab
commit ea077b1b96e073eac5c3c5590529e964767fc5f7 upstream. Explicitly truncate the second operand of do_div() to 32 bits to guard against bogus code calling it with a 64-bit divisor. [Thorsten] After upgrading from 3.2 to 3.10, mounting a btrfs volume fails with: btrfs: setting nodatacow, compression disabled btrfs: enabling auto recovery btrfs: disk space caching is enabled *** ZERO DIVIDE *** FORMAT=2 Current process id is 722 BAD KERNEL TRAP: 00000000 Modules linked in: evdev mac_hid ext4 crc16 jbd2 mbcache btrfs xor lzo_compress zlib_deflate raid6_pq crc32c libcrc32c PC: [<319535b2>] __btrfs_map_block+0x11c/0x119a [btrfs] SR: 2000 SP: 30c1fab4 a2: 30f0faf0 d0: 00000000 d1: 00001000 d2: 00000000 d3: 00000000 d4: 00010000 d5: 00000000 a0: 3085c72c a1: 3085c72c Process mount (pid: 722, task=30f0faf0) Frame format=2 instr addr=319535ae Stack from 30c1faec: 00000000 00000020 00000000 00001000 00000000 01401000 30253928 300ffc00 00a843ac 3026f640 00000000 00010000 0009e250 00d106c0 00011220 00000000 00001000 301c6830 0009e32a 000000ff 00000009 3085c72c 00000000 00000000 30c1fd14 00000000 00000020 00000000 30c1fd14 0009e26c 00000020 00000003 00000000 0009dd8a 300b0b6c 30253928 00a843ac 00001000 00000000 00000000 0000a008 3194e76a 30253928 00a843ac 00001000 00000000 00000000 00000002 Call Trace: [<00001000>] kernel_pg_dir+0x0/0x1000 [...] Code: 222e ff74 2a2e ff5c 2c2e ff60 4c45 1402 <2d40> ff64 2d41 ff68 2205 4c2e 1800 ff68 4c04 0800 2041 d1c0 2206 4c2e 1400 ff68 [Geert] As diagnosed by Andreas, fs/btrfs/volumes.c:__btrfs_map_block() calls do_div(stripe_nr, stripe_len); with stripe_len u64, while do_div() assumes the divisor is a 32-bit number. Due to the lack of truncation in the m68k-specific implementation of do_div(), the division is performed using the upper 32-bit word of stripe_len, which is zero. This was introduced by commit 53b381b3abeb86f12787a6c40fee9b2f71edc23b ("Btrfs: RAID5 and RAID6"), which changed the divisor from map->stripe_len (struct map_lookup.stripe_len is int) to a 64-bit temporary. Reported-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Tested-by: Thorsten Glaser <tg@debian.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20ARM: 7809/1: perf: fix event validation for software group leadersWill Deacon
commit c95eb3184ea1a3a2551df57190c81da695e2144b upstream. It is possible to construct an event group with a software event as a group leader and then subsequently add a hardware event to the group. This results in the event group being validated by adding all members of the group to a fake PMU and attempting to allocate each event on their respective PMU. Unfortunately, for software events wthout a corresponding arm_pmu, this results in a kernel crash attempting to dereference the ->get_event_idx function pointer. This patch fixes the problem by checking explicitly for software events and ignoring those in event validation (since they can always be scheduled). We will probably want to revisit this for 3.12, since the validation checks don't appear to work correctly when dealing with multiple hardware PMUs anyway. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20xtensa: replace xtensa-specific _f{data,text} by _s{data,text}Geert Uytterhoeven
commit 5e7b6ed8e9bf3c8e3bb579fd0aec64f6526f8c81 upstream. commit a2d063ac216c161 ("extable, core_kernel_data(): Make sure all archs define _sdata") missed xtensa. Xtensa does have a start of data marker, but calls it _fdata, causing kernel/built-in.o:(.text+0x964): undefined reference to `_sdata' _stext was already defined, but it was duplicated by _fdata. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20xtensa: fix linker script transformation for .text.unlikelyMax Filippov
commit f6a03a12ecdbe0dd80a55f6df3b7206c5a403a49 upstream. Now that binutils generate *.unlikely sections which don't follow documented (info as) literal section naming rules, section name transformation script doesn't work well resulting in the following errors at vmlinux link time: main.c:(.text.unlikely+0x3): dangerous relocation: l32r: literal placed after use: .literal.unlikely Fix section name transformation script by adding specific rule for .text.unlikely sections. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Chris Zankel <chris@zankel.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20MIPS: Rewrite pfn_valid to work in modules, too.Ralf Baechle
Upstream commit 8b9232141bf40788cce31f893c13f344ec31ee66. This fixes: MODPOST 393 modules ERROR: "min_low_pfn" [arch/mips/kvm/kvm.ko] undefined! make[3]: *** [__modpost] Error 1 It would have been possible to just export min_low_pfn but in the end pfn_valid should return 1 for any pfn argument for which a struct page exists so using min_low_pfn was wrong anyway. [Backport to 3.4 kernel. Applies cleanly on top of current 3.4 patch queue, and fixes "make ARCH=mips allmodconfig; make ARCH=mips" build problem. - Guenter] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20sparc32: Add ucmpdi2.o to obj-y instead of lib-y.David S. Miller
commit 74c7b28953d4eaa6a479c187aeafcfc0280da5e8 upstream. Otherwise if no references exist in the static kernel image, we won't export the symbol properly to modules. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20sparc32: add ucmpdi2Sam Ravnborg
commit de36e66d5fa52bc6e2dacd95c701a1762b5308a7 upstream. Based on copy from microblaze add ucmpdi2 implementation. This fixes build of niu driver which failed with: drivers/built-in.o: In function `niu_get_nfc': niu.c:(.text+0x91494): undefined reference to `__ucmpdi2' This driver will never be used on a sparc32 system, but patch added to fix build breakage with all*config builds. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20alpha: makefile: don't enforce small data model for kernel buildsWill Deacon
commit cd8d2331756751b6aeb855a3c9cb0a92fbd9c725 upstream. Due to all of the goodness being packed into today's kernels, the resulting image isn't as slim as it once was. In light of this, don't pass -msmall-data to gcc, which otherwise results in link failures due to impossible relocations when compiling anything but the most trivial configurations. Reviewed-by: Matt Turner <mattst88@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Tested-by: Thorsten Kranzkowski <dl8bcu@dl8bcu.de> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Michael Cree <mcree@orcon.net.nz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20powerpc/numa: Avoid stupid uninitialized warning from gccBenjamin Herrenschmidt
commit aa709f3bc92c6daaf177cd7e3446da2ef64426c6 upstream. Newer gcc are being a bit blind here (it's pretty obvious we don't reach the code path using the array if we haven't initialized the pointer) but none of that is performance critical so let's just silence it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20frv: Use core allocator for task_structThomas Gleixner
commit c6ae063aaf3786b9db7f19a90bf4ed8aaebb7f90 upstream. There is no point having a copy of the core allocator. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20120503085033.967140188@linutronix.de Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20frv: Use correct size for task_struct allocationThomas Gleixner
commit cce4517f33384c3794c759e206cc8e1bb6df146b upstream. alloc_task_struct_node() allocates THREAD_SIZE and maintains some weird refcount in the allocated memory. This never blew up as task_struct size on 32bit machines was always less than THREAD_SIZE Allocate just sizeof(struct task_struct) and get rid of the magic refcounting. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20120503085033.898475542@linutronix.de Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20CRIS: Add _sdata to vmlinux.lds.SJesper Nilsson
commit 473e162eea465e60578edb93341752e7f1c1dacc upstream. Fixes link error: LD vmlinux kernel/built-in.o: In function `core_kernel_data': (.text+0x13e44): undefined reference to `_sdata' Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20cris: Remove old legacy "-traditional" flag from arch-v10/lib/MakefilePaul Gortmaker
commit 7b91747d42a1012e3781dd09fa638d113809e3fd upstream. Most of these have been purged years ago. This one silently lived on until commit 69349c2dc01c489eccaa4c472542c08e370c6d7e "kconfig: fix IS_ENABLED to not require all options to be defined" In the above, we use some macro trickery to create a conditional that is valid in CPP and in C usage. However that trickery doesn't sit well if you have the legacy "-traditional" flag enabled. You'll get: AS arch/cris/arch-v10/lib/checksum.o In file included from <command-line>:4:0: include/linux/kconfig.h:23:0: error: syntax error in macro parameter list make[2]: *** [arch/cris/arch-v10/lib/checksum.o] Error 1 Everything builds fine w/o "-traditional" so simply drop it from this location as well. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20cris: posix_types.h, include asm-generic/posix_types.hJiri Slaby
commit 74f077d2a7651409c44bb323471f219a4b0d2aab upstream. Without that I cannot build anything: In file included from include/linux/page-flags.h:8:0, from kernel/bounds.c:9: include/linux/types.h:25:1: error: unknown type name '__kernel_ino_t' include/linux/types.h:29:1: error: unknown type name '__kernel_off_t' ... Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: linux-cris-kernel@axis.com Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20microblaze: Update microblaze defconfigsMichal Simek
commit d0e045401f268a8de6f87d65678214748b772680 upstream. The main reason is 0-day testing system which can directly use these defconfigs for testing. Enable support for all xilinx drivers which Microblaze can use and disable dependency on external rootfs.cpio. There is only one exception which is axi ethernet driver which still uses NO_IRQ which is not defined for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20MIPS: Expose missing pci_io{map,unmap} declarationsMarkos Chandras
commit 78857614104a26cdada4c53eea104752042bf5a1 upstream. The GENERIC_PCI_IOMAP does not depend on CONFIG_PCI so move it to the CONFIG_MIPS symbol so it's always selected for MIPS. This fixes the missing pci_iomap declaration for MIPS. Moreover, the pci_iounmap function was not defined in the io.h header file if the CONFIG_PCI symbol is not set, but it should since MIPS is not using CONFIG_GENERIC_IOMAP. This fixes the following problem on a allyesconfig: drivers/net/ethernet/3com/3c59x.c:1031:2: error: implicit declaration of function 'pci_iomap' [-Werror=implicit-function-declaration] drivers/net/ethernet/3com/3c59x.c:1044:3: error: implicit declaration of function 'pci_iounmap' [-Werror=implicit-function-declaration] Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Acked-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5478/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20perf/arm: Fix armpmu_map_hw_event()Stephen Boyd
commit b88a2595b6d8aedbd275c07dfa784657b4f757eb upstream. Fix constraint check in armpmu_map_hw_event(). Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11x86, fpu: correct the asm constraints for fxsave, unbreak mxcsr.dazH.J. Lu
commit eaa5a990191d204ba0f9d35dbe5505ec2cdd1460 upstream. GCC will optimize mxcsr_feature_mask_init in arch/x86/kernel/i387.c: memset(&fx_scratch, 0, sizeof(struct i387_fxsave_struct)); asm volatile("fxsave %0" : : "m" (fx_scratch)); mask = fx_scratch.mxcsr_mask; if (mask == 0) mask = 0x0000ffbf; to memset(&fx_scratch, 0, sizeof(struct i387_fxsave_struct)); asm volatile("fxsave %0" : : "m" (fx_scratch)); mask = 0x0000ffbf; since asm statement doesn’t say it will update fx_scratch. As the result, the DAZ bit will be cleared. This patch fixes it. This bug dates back to at least kernel 2.6.12. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04s390: move dummy io_remap_pfn_range() to asm/pgtable.hLinus Torvalds
commit 4f2e29031e6c67802e7370292dd050fd62f337ee upstream. Commit b4cbb197c7e7 ("vm: add vm_iomap_memory() helper function") added a helper function wrapper around io_remap_pfn_range(), and every other architecture defined it in <asm/pgtable.h>. The s390 choice of <asm/io.h> may make sense, but is not very convenient for this case, and gratuitous differences like that cause unexpected errors like this: mm/memory.c: In function 'vm_iomap_memory': mm/memory.c:2439:2: error: implicit declaration of function 'io_remap_pfn_range' [-Werror=implicit-function-declaration] Glory be the kbuild test robot who noticed this, bisected it, and reported it to the guilty parties (ie me). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> [bwh: Backported to 3.2: the macro was not defined, so this is an addition and not a move] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04powerpc/modules: Module CRC relocation fix causes perf issuesAnton Blanchard
commit 0e0ed6406e61434d3f38fb58aa8464ec4722b77e upstream. Module CRCs are implemented as absolute symbols that get resolved by a linker script. We build an intermediate .o that contains an unresolved symbol for each CRC. genksysms parses this .o, calculates the CRCs and writes a linker script that "resolves" the symbols to the calculated CRC. Unfortunately the ppc64 relocatable kernel sees these CRCs as symbols that need relocating and relocates them at boot. Commit d4703aef (module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y) added a hook to reverse the bogus relocations. Part of this patch created a symbol at 0x0: # head -2 /proc/kallsyms 0000000000000000 T reloc_start c000000000000000 T .__start This reloc_start symbol is causing lots of confusion to perf. It thinks reloc_start is a massive function that stretches from 0x0 to 0xc000000000000000 and we get various cryptic errors out of perf, including: problem incrementing symbol count, skipping event This patch removes the reloc_start linker script label and instead defines it as PHYSICAL_START. We also need to wrap it with CONFIG_PPC64 because the ppc32 kernel can set a non zero PHYSICAL_START at compile time and we wouldn't want to subtract it from the CRCs in that case. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sparc: tsb must be flushed before tlbDave Kleikamp
Upstream commit 23a01138efe216f8084cfaa74b0b90dd4b097441 This fixes a race where a cpu may re-load a tlb from a stale tsb right after it has been flushed by a remote function call. I still see some instability when stressing the system with parallel kernel builds while creating memory pressure by writing to /proc/sys/vm/nr_hugepages, but this patch improves the stability significantly. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Acked-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sparc64 address-congruence propertybob picco
Upstream commit 771a37ff4d80b80db3b0df3e7696f14b298c67b7 The Machine Description (MD) property "address-congruence-offset" is optional. According to the MD specification the value is assumed 0UL when not present. This caused early boot failure on T5. Signed-off-by: Bob Picco <bob.picco@oracle.com> CC: sparclinux@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28sparc32: vm_area_struct access for old Sun SPARCs.Olivier DANET
Upstream commit 961246b4ed8da3bcf4ee1eb9147f341013553e3c Commit e4c6bfd2d79d063017ab19a18915f0bc759f32d9 ("mm: rearrange vm_area_struct for fewer cache misses") changed the layout of the vm_area_struct structure, it broke several SPARC32 assembly routines which used numerical constants for accessing the vm_mm field. This patch defines the VMA_VM_MM constant to replace the immediate values. Signed-off-by: Olivier DANET <odanet@caramail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ARM: 7765/1: perf: Record the user-mode PC in the call chain.Jed Davis
commit c5f927a6f62196226915f12194c9d0df4e2210d7 upstream. With this change, we no longer lose the innermost entry in the user-mode part of the call chain. See also the x86 port, which includes the ip. It's possible to partially work around this problem by post-processing the data to use the PERF_SAMPLE_IP value, but this works only if the CPU wasn't in the kernel when the sample was taken. Signed-off-by: Jed Davis <jld@mozilla.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21xen/time: remove blocked time accounting from xen "clockchip"Laszlo Ersek
commit 0b0c002c340e78173789f8afaa508070d838cf3d upstream. ... because the "clock_event_device framework" already accounts for idle time through the "event_handler" function pointer in xen_timer_interrupt(). The patch is intended as the completion of [1]. It should fix the double idle times seen in PV guests' /proc/stat [2]. It should be orthogonal to stolen time accounting (the removed code seems to be isolated). The approach may be completely misguided. [1] https://lkml.org/lkml/2011/10/6/10 [2] http://lists.xensource.com/archives/html/xen-devel/2010-08/msg01068.html John took the time to retest this patch on top of v3.10 and reported: "idle time is correctly incremented for pv and hvm for the normal case, nohz=off and nohz=idle." so lets put this patch in. Signed-off-by: Laszlo Ersek <lersek@redhat.com> Signed-off-by: John Haxby <john.haxby@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03ARM: 7772/1: Fix missing flush_kernel_dcache_page() for noMMUSimon Baatz
commit 63384fd0b1509acf522a8a8fcede09087eedb7df upstream. Commit 1bc3974 (ARM: 7755/1: handle user space mapped pages in flush_kernel_dcache_page) moved the implementation of flush_kernel_dcache_page() into mm/flush.c but did not implement it on noMMU ARM. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-03ARM: 7755/1: handle user space mapped pages in flush_kernel_dcache_pageSimon Baatz
commit 1bc39742aab09248169ef9d3727c9def3528b3f3 upstream. Commit f8b63c1 made flush_kernel_dcache_page a no-op assuming that the pages it needs to handle are kernel mapped only. However, for example when doing direct I/O, pages with user space mappings may occur. Thus, continue to do lazy flushing if there are no user space mappings. Otherwise, flush the kernel cache lines directly. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-27KVM: x86: remove vcpu's CPL check in host-invoked XCR setZhanghaoyu (A)
commit 764bcbc5a6d7a2f3e75c9f0e4caa984e2926e346 upstream. __kvm_set_xcr function does the CPL check when set xcr. __kvm_set_xcr is called in two flows, one is invoked by guest, call stack shown as below, handle_xsetbv(or xsetbv_interception) kvm_set_xcr __kvm_set_xcr the other one is invoked by host, for example during system reset: kvm_arch_vcpu_ioctl kvm_vcpu_ioctl_x86_set_xcrs __kvm_set_xcr The former does need the CPL check, but the latter does not. Signed-off-by: Zhang Haoyu <haoyu.zhang@huawei.com> [Tweaks to commit message. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
