path: root/arch
2015-08-27Merge tag 'powerpc-4.2-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: "Fix MSI/MSI-X on pseries from Guilherme" * tag 'powerpc-4.2-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc/PCI: Disable MSI/MSI-X interrupts at PCI probe time in OF case PCI: Make pci_msi_setup_pci_dev() non-static for use by arch code
2015-08-27Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull amr64 kvm fix from Will Deacon: "We've uncovered a nasty bug in the arm64 KVM code which allows a badly behaved 32-bit guest to bring down the host. The fix is simple (it's what I believe we call a "brown paper bag" bug) and I don't think it makes sense to sit on this, particularly as Russell ended up triggering this rather than just somebody noticing a potential problem by inspection. Usually arm64 KVM changes would go via Paolo's tree, but he's on holiday at the moment and the deal is that anything urgent gets shuffled via the arch trees, so here it is. Summary: Fix arm64 KVM issue when injecting an abort into a 32-bit guest, which would lead to an illegal exception return at EL2 and a subsequent host crash" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: KVM: Fix host crash when injecting a fault into a 32bit guest
2015-08-27arm64: KVM: Fix host crash when injecting a fault into a 32bit guestMarc Zyngier
When injecting a fault into a misbehaving 32bit guest, it seems rather idiotic to also inject a 64bit fault that is only going to corrupt the guest state. This leads to a situation where we perform an illegal exception return at EL2 causing the host to crash instead of killing the guest. Just fix the stupid bug that has been there from day 1. Cc: <stable@vger.kernel.org> Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2015-08-26powerpc/PCI: Disable MSI/MSI-X interrupts at PCI probe time in OF caseGuilherme G. Piccoli
Since commit 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel doesn't support MSI"), the setup of dev->msi_cap/msix_cap and the disable of MSI/MSI-X interrupts isn't being done at PCI probe time, as the logic responsible for this was moved in the aforementioned commit from pci_device_add() to pci_setup_device(). The latter function is not reachable on PowerPC pseries platform during Open Firmware PCI probing time. This exhibits as drivers not being able to enable MSI, eg: bnx2x 0000:01:00.0: no msix capability found This patch calls pci_msi_setup_pci_dev() explicitly to disable MSI/MSI-X during PCI probe time on pSeries platform. Fixes: 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel doesn't support MSI") [mpe: Flesh out change log and clarify comment] Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-25Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fix from Thomas Gleixner: "A single fix for a APIC regression introduced in 4.0 which went undetected until now. I screwed up the x2apic cleanup in a subtle way. The screwup is only visible on systems which have x2apic preenabled in the BIOS and need to disable it during boot" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/apic: Fix fallout from x2apic cleanup
2015-08-23Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS bug fixes from Ralf Baechle: "Two more fixes for 4.2. One fixes a build issue with the LLVM assembler - LLVM assembler macro names are case sensitive, GNU as macro names are insensitive; the other corrects a license string (GPL v2, not GPLv2) such that the module loader will recognice the license correctly" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: FIRMWARE: bcm47xx_nvram: Fix module license. MIPS: Fix LLVM build issue.
2015-08-22Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another couple of small ARM fixes. A patch from Masahiro Yamada who noticed that "make -jN all zImage" would end up generating bad images where N > 1, and a patch from Nicolas to fix the Marvell CPU user access optimisation code when page faults are disabled" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8418/1: add boot image dependencies to not generate invalid images ARM: 8414/1: __copy_to_user_memcpy: fix mmap semaphore usage
2015-08-22Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Various low level fixes: fix more fallout from the FPU rework and the asm entry code rework, plus an MSI rework fix, and an idle-tracing fix" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/fpu/math-emu: Fix crash in fork() x86/fpu/math-emu: Fix math-emu boot crash x86/idle: Restore trace_cpu_idle to mwait_idle() calls x86/irq: Build correct vector mapping for multiple MSI interrupts Revert "sched/x86_64: Don't save flags on context switch"
2015-08-22x86/apic: Fix fallout from x2apic cleanupThomas Gleixner
In the recent x2apic cleanup I got two things really wrong: 1) The safety check in __disable_x2apic which allows the function to be called unconditionally is backwards. The check is there to prevent access to the apic MSR in case that the machine has no apic. Though right now it returns if the machine has an apic and therefor the disabling of x2apic is never invoked. 2) x2apic_disable() sets x2apic_mode to 0 after registering the local apic. That's wrong, because register_lapic_address() checks x2apic mode and therefor takes the wrong code path. This results in boot failures on machines with x2apic preenabled by BIOS and can also lead to an fatal MSR access on machines without apic. The solutions are simple: 1) Correct the sanity check for apic availability 2) Clear x2apic_mode _before_ calling register_lapic_address() Fixes: 659006bf3ae3 'x86/x2apic: Split enable and setup function' Reported-and-tested-by: Javier Monteagudo <javiermon@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://bugzilla.redhat.com/show_bug.cgi?id=1224764 Cc: stable@vger.kernel.org # 4.0+ Cc: Laura Abbott <labbott@redhat.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de>
2015-08-22Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "A series of small fixlets for a regression visible on OMAP devices caused by the conversion of the OMAP interrupt chips to hierarchical interrupt domains. Mostly one liners on the driver side plus a small helper function in the core to avoid open coded mess in the drivers" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip/crossbar: Restore set_wake functionality irqchip/crossbar: Restore the mask on suspend behaviour ARM: OMAP: wakeupgen: Restore the irq_set_type() mechanism irqchip/crossbar: Restore the irq_set_type() mechanism genirq: Introduce irq_chip_set_type_parent() helper genirq: Don't return ENOSYS in irq_chip_retrigger_hierarchy
2015-08-22x86/fpu/math-emu: Fix crash in fork()Ingo Molnar
During later stages of math-emu bootup the following crash triggers: math_emulate: 0060:c100d0a8 Kernel panic - not syncing: Math emulation needed in kernel CPU: 0 PID: 1511 Comm: login Not tainted 4.2.0-rc7+ #1012 [...] Call Trace: [<c181d50d>] dump_stack+0x41/0x52 [<c181c918>] panic+0x77/0x189 [<c1003530>] ? math_error+0x140/0x140 [<c164c2d7>] math_emulate+0xba7/0xbd0 [<c100d0a8>] ? fpu__copy+0x138/0x1c0 [<c1109c3c>] ? __alloc_pages_nodemask+0x12c/0x870 [<c136ac20>] ? proc_clear_tty+0x40/0x70 [<c136ac6e>] ? session_clear_tty+0x1e/0x30 [<c1003530>] ? math_error+0x140/0x140 [<c1003575>] do_device_not_available+0x45/0x70 [<c100d0a8>] ? fpu__copy+0x138/0x1c0 [<c18258e6>] error_code+0x5a/0x60 [<c1003530>] ? math_error+0x140/0x140 [<c100d0a8>] ? fpu__copy+0x138/0x1c0 [<c100c205>] arch_dup_task_struct+0x25/0x30 [<c1048cea>] copy_process.part.51+0xea/0x1480 [<c115a8e5>] ? dput+0x175/0x200 [<c136af70>] ? no_tty+0x30/0x30 [<c1157242>] ? do_vfs_ioctl+0x322/0x540 [<c104a21a>] _do_fork+0xca/0x340 [<c1057b06>] ? SyS_rt_sigaction+0x66/0x90 [<c104a557>] SyS_clone+0x27/0x30 [<c1824a80>] sysenter_do_call+0x12/0x12 The reason is the incorrect assumption in fpu_copy(), that FNSAVE can be executed from math-emu kernels as well. Don't try to copy the registers, the soft state will be copied by fork anyway, so the child task inherits the parent task's soft math state. With this fix applied math-emu kernels boot up fine on modern hardware and the 'no387 nofxsr' boot options. Cc: Andy Lutomirski <luto@amacapital.net> Cc: Bobby Powers <bobbypowers@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-22x86/fpu/math-emu: Fix math-emu boot crashIngo Molnar
On a math-emu bootup the following crash occurs: Initializing CPU#0 ------------[ cut here ]------------ kernel BUG at arch/x86/kernel/traps.c:779! invalid opcode: 0000 [#1] SMP [...] EIP is at do_device_not_available+0xe/0x70 [...] Call Trace: [<c18238e6>] error_code+0x5a/0x60 [<c1002bd0>] ? math_error+0x140/0x140 [<c100bbd9>] ? fpu__init_cpu+0x59/0xa0 [<c1012322>] cpu_init+0x202/0x330 [<c104509f>] ? __native_set_fixmap+0x1f/0x30 [<c1b56ab0>] trap_init+0x305/0x346 [<c1b548af>] start_kernel+0x1a5/0x35d [<c1b542b4>] i386_start_kernel+0x82/0x86 The reason is that in the following commit: b1276c48e91b ("x86/fpu: Initialize fpregs in fpu__init_cpu_generic()") I failed to consider math-emu's limitation that it cannot execute the FNINIT instruction in kernel mode. The long term fix might be to allow math-emu to execute (certain) kernel mode FPU instructions, but for now apply the safe (albeit somewhat ugly) fix: initialize the emulation state explicitly without trapping out to the FPU emulator. Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-20x86/idle: Restore trace_cpu_idle to mwait_idle() callsJisheng Zhang
Commit b253149b843f ("sched/idle/x86: Restore mwait_idle() to fix boot hangs, to improve power savings and to improve performance") restores mwait_idle(), but the trace_cpu_idle related calls are missing. This causes powertop on my old desktop powered by Intel Core2 E6550 to report zero wakeups and zero events. Add them back to restore the proper behaviour. Fixes: b253149b843f ("sched/idle/x86: Restore mwait_idle() to ...") Signed-off-by: Jisheng Zhang <jszhang@marvell.com> Cc: <len.brown@intel.com> Cc: stable@vger.kernel.org # 4.1 Link: http://lkml.kernel.org/r/1440046479-4262-1-git-send-email-jszhang@marvell.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-20Merge tag 'for-linus-4.2-rc7-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen build fix from David Vrabel: "Fix i386 build with an (uncommon) configuration" * tag 'for-linus-4.2-rc7-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: x86/xen: make CONFIG_XEN depend on CONFIG_X86_LOCAL_APIC
2015-08-20x86/xen: make CONFIG_XEN depend on CONFIG_X86_LOCAL_APICDavid Vrabel
Since commit feb44f1f7a4ac299d1ab1c3606860e70b9b89d69 (x86/xen: Provide a "Xen PV" APIC driver to support >255 VCPUs) Xen guests need a full APIC driver and thus should depend on X86_LOCAL_APIC. This fixes an i386 build failure with !SMP && !CONFIG_X86_UP_APIC by disabling Xen support in this configuration. Users needing Xen support in a non-SMP i386 kernel will need to enable CONFIG_X86_UP_APIC. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Cc: <stable@vger.kernel.org>
2015-08-20ARM: OMAP: wakeupgen: Restore the irq_set_type() mechanismGrygorii Strashko
The conversion of the wakeupgen irqchip to hierarchical irq domains failed to provide a mechanism to properly set the trigger type of an interrupt. The wakeupgen irq chip itself has no mechanism and therefor no irq_set_type() callback. The code before the conversion relayed the trigger configuration directly to the underlying GIC. Restore the correct behaviour by setting the wakeupgen irq_set_type callback to irq_chip_set_type_parent(). This propagates the set_trigger() call to the underlying GIC irqchip. [ tglx: Massaged changelog ] Fixes: 7136d457f365 ('ARM: omap: convert wakeupgen to stacked domains') Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: <linux@arm.linux.org.uk> Cc: <nsekhar@ti.com> Cc: <jason@lakedaemon.net> Cc: <balbi@ti.com> Cc: <linux-arm-kernel@lists.infradead.org> Cc: <marc.zyngier@arm.com> Cc: stable@vger.kernel.org # 4.1 Link: http://lkml.kernel.org/r/1439554830-19502-5-git-send-email-grygorii.strashko@ti.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-19Merge branch 'x86/asm/urgent' to pick up an entry code fixIngo Molnar
2015-08-18x86/irq: Build correct vector mapping for multiple MSI interruptsJiang Liu
Alex Deucher, Mark Rustad and Alexander Holler reported a regression with the latest v4.2-rc4 kernel, which breaks some SATA controllers. With multi-MSI capable SATA controllers, only the first port works, all other ports time out when executing SATA commands. This happens because the first argument to assign_irq_vector_policy() is always the base linux irq number of the multi MSI interrupt block, so all subsequent vector assignments operate on the base linux irq number, so all MSI irqs are handled as the first irq number. Therefor the other MSI irqs of a device are never set up correctly and never fire. Add the loop iterator to the base irq number so all vectors are assigned correctly. Fixes: b5dc8e6c21e7 "x86/irq: Use hierarchical irqdomain to manage CPU interrupt vectors" Reported-and-tested-by: Alex Deucher <alexdeucher@gmail.com> Reported-and-tested-by: Mark Rustad <mrustad@gmail.com> Reported-and-tested-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/1439911228-9880-1-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-18ARM: 8418/1: add boot image dependencies to not generate invalid imagesMasahiro Yamada
U-Boot is often used to boot the kernel on ARM boards, but uImage is not built by "make all", so we are often inclined to do "make all uImage" to generate DTBs, modules and uImage in a single command, but we should notice a pitfall behind it. In fact, "make all uImage" could generate an invalid uImage if it is run with the parallel option (-j). You can reproduce this problem with the following procedure: [1] First, build "all" and "uImage" separately. You will get a valid uImage $ git clean -f -x -d $ export CROSS_COMPILE=<your-tools-prefix> $ make -s -j8 ARCH=arm multi_v7_defconfig $ make -s -j8 ARCH=arm all $ make -j8 ARCH=arm UIMAGE_LOADADDR=0x80208000 uImage CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CHK include/generated/timeconst.h CHK include/generated/bounds.h CHK include/generated/asm-offsets.h CALL scripts/checksyscalls.sh CHK include/generated/compile.h Kernel: arch/arm/boot/Image is ready Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage Image Name: Linux-4.2.0-rc5-00156-gdd2384a-d Created: Sat Aug 8 23:21:35 2015 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 6138648 Bytes = 5994.77 kB = 5.85 MB Load Address: 80208000 Entry Point: 80208000 Image arch/arm/boot/uImage is ready $ ls -l arch/arm/boot/*Image -rwxrwxr-x 1 masahiro masahiro 13766656 Aug 8 23:20 arch/arm/boot/Image -rw-rw-r-- 1 masahiro masahiro 6138712 Aug 8 23:21 arch/arm/boot/uImage -rwxrwxr-x 1 masahiro masahiro 6138648 Aug 8 23:20 arch/arm/boot/zImage [2] Update some source file(s) $ touch init/main.c [3] Then, re-build "all" and "uImage" simultaneously. You will get an invalid uImage at random. $ make -j8 ARCH=arm UIMAGE_LOADADDR=0x80208000 all uImage CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h make[1]: `include/generated/mach-types.h' is up to date. CHK include/generated/timeconst.h CHK include/generated/bounds.h CHK include/generated/asm-offsets.h CALL scripts/checksyscalls.sh CC init/main.o CHK include/generated/compile.h LD init/built-in.o LINK vmlinux LD vmlinux.o MODPOST vmlinux.o GEN .version CHK include/generated/compile.h UPD include/generated/compile.h CC init/version.o LD init/built-in.o KSYM .tmp_kallsyms1.o KSYM .tmp_kallsyms2.o LD vmlinux SORTEX vmlinux SYSMAP System.map OBJCOPY arch/arm/boot/Image Building modules, stage 2. Kernel: arch/arm/boot/Image is ready GZIP arch/arm/boot/compressed/piggy.gzip AS arch/arm/boot/compressed/piggy.gzip.o Kernel: arch/arm/boot/Image is ready LD arch/arm/boot/compressed/vmlinux GZIP arch/arm/boot/compressed/piggy.gzip OBJCOPY arch/arm/boot/zImage Kernel: arch/arm/boot/zImage is ready UIMAGE arch/arm/boot/uImage Image Name: Linux-4.2.0-rc5-00156-gdd2384a-d Created: Sat Aug 8 23:23:14 2015 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 26472 Bytes = 25.85 kB = 0.03 MB Load Address: 80208000 Entry Point: 80208000 Image arch/arm/boot/uImage is ready MODPOST 192 modules AS arch/arm/boot/compressed/piggy.gzip.o LD arch/arm/boot/compressed/vmlinux OBJCOPY arch/arm/boot/zImage Kernel: arch/arm/boot/zImage is ready $ ls -l arch/arm/boot/*Image -rwxrwxr-x 1 masahiro masahiro 13766656 Aug 8 23:23 arch/arm/boot/Image -rw-rw-r-- 1 masahiro masahiro 26536 Aug 8 23:23 arch/arm/boot/uImage -rwxrwxr-x 1 masahiro masahiro 6138648 Aug 8 23:23 arch/arm/boot/zImage Please notice the uImage is extremely small when this issue is encountered. Besides, "Kernel: arch/arm/boot/zImage is ready" is displayed twice, before and after the uImage log. The root cause of this is the race condition between zImage and uImage. Actually, uImage depends on zImage, but the dependency between the two is only described in arch/arm/boot/Makefile. Because arch/arm/boot/Makefile is not included from the top-level Makefile, it cannot know the dependency between zImage and uImage. Consequently, when we run make with the parallel option, Kbuild updates vmlinux first, and then two different threads descends into the arch/arm/boot/Makefile almost at the same time, one for updating zImage and the other for uImage. While one thread is re-generating zImage, the other also tries to update zImage before creating uImage on top of that. zImage is overwritten by the slower thread and then uImage is created based on the half-written zImage. This is the reason why "Kernel: arch/arm/boot/zImage is ready" is displayed twice, and a broken uImage is created. The same problem could happen on bootpImage. This commit adds dependencies among Image, zImage, uImage, and bootpImage to arch/arm/Makefile, which is included from the top-level Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-08-18ARM: 8414/1: __copy_to_user_memcpy: fix mmap semaphore usageNicolas Pitre
The mmap semaphore should not be taken when page faults are disabled. Since pagefault_disable() no longer disables preemption, we now need to use faulthandler_disabled() in place of in_atomic(). Signed-off-by: Nicolas Pitre <nico@linaro.org> Tested-by: Mark Salter <msalter@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-08-18MIPS: Fix LLVM build issue.Ralf Baechle
Matthew Fortune <Matthew.Fortune@imgtec.com> reports: The genex.S file appears to mix the case of a macro between its definition and use. A cut down example of this is below. The macro __build_clear_none has lower case 'build' but ends up being instantiated with upper case BUILD. Can this be fixed on master. It has been picked up by the LLVM integrated assembler which is currently case sensitive. We are likely to fix the assembler as well but the code is currently inconsistent in the kernel. .macro __build_clear_none .endm .macro __BUILD_HANDLER exception handler clear verbose ext .align 5 .globl handle_\exception; .align 2; .type handle_\exception, @function; .ent handle_\exception, 0; handle_\exception: .frame $29, 184, $29 .set noat .globl handle_\exception\ext; .type handle_\exception\ext, @function; handle_\exception\ext: __BUILD_clear_\clear .endm .macro BUILD_HANDLER exception handler clear verbose __BUILD_HANDLER \exception \handler \clear \verbose _int .endm BUILD_HANDLER ftlb ftlb none silent Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Matthew Fortune <Matthew.Fortune@imgtec.com>
2015-08-18Revert "sched/x86_64: Don't save flags on context switch"Andy Lutomirski
This reverts commit: 2c7577a75837 ("sched/x86_64: Don't save flags on context switch") It was a nice speedup. It's also not quite correct: SYSENTER enables interrupts too early. We can re-add this optimization once the SYSENTER code is beaten into shape, which should happen in 4.3 or 4.4. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org # v3.19 Link: http://lkml.kernel.org/r/85f56651f59f76624e80785a8fd3bdfdd089a818.1439838962.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-16Merge tag 'armsoc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A smallish batch of fixes, a little more than expected this late, but all fixes are contained to their platforms and seem reasonably low risk: - a somewhat large SMP fix for ux500 that still seemed warranted to include here - OMAP DT fixes for pbias regulator specification that broke due to some DT reshuffling - PCIe IRQ routing bugfix for i.MX - networking fixes for keystone - runtime PM for OMAP GPMC - a couple of error path bug fixes for exynos" * tag 'armsoc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific file ARM: dts: keystone: fix the clock node for mdio memory: omap-gpmc: Don't try to save uninitialized GPMC context ARM: imx6: correct i.MX6 PCIe interrupt routing ARM: ux500: add an SMP enablement type and move cpu nodes ARM: dts: dra7: Fix broken pbias device creation ARM: dts: OMAP5: Fix broken pbias device creation ARM: dts: OMAP4: Fix broken pbias device creation ARM: dts: omap243x: Fix broken pbias device creation ARM: EXYNOS: fix double of_node_put() on error path ARM: EXYNOS: Fix potentian kfree() of ro memory
2015-08-16Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS bugfix from Ralf Baechle: "Only a single MIPS fix - the math when invoking syscall_trace_enter was wrong" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Fix seccomp syscall argument for MIPS64
2015-08-16Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Merge x86 fixes from Ingo Molnar: "Two followup fixes related to the previous LDT fix" Also applied a further FPU emulation fix from Andy Lutomirski to the branch before actually merging it. * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip x86/ldt: Further fix FPU emulation x86/ldt: Correct FPU emulation access to LDT x86/ldt: Correct LDT access in single stepping logic
2015-08-16x86/ldt: Further fix FPU emulationAndy Lutomirski
The previous fix confused a selector with a segment prefix. Fix it. Compile-tested only. Cc: stable@vger.kernel.org Cc: Juergen Gross <jgross@suse.com> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Fixes: 4809146b86c3 ("x86/ldt: Correct FPU emulation access to LDT") Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-16Merge tag 'keystone-dts-late-fixes-v2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone into fixes ARM: Couple of Keysyone MDIO DTS fixes for 4.2-rc6+ These are necessary to get the NIC card working on all Keystone EVMs. Couple of boards are broken without these two fixes. * tag 'keystone-dts-late-fixes-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/ssantosh/linux-keystone: ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific file ARM: dts: keystone: fix the clock node for mdio Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-16MIPS: Fix seccomp syscall argument for MIPS64Markos Chandras
Commit 4c21b8fd8f14 ("MIPS: seccomp: Handle indirect system calls (o32)") fixed indirect system calls on O32 but it also introduced a bug for MIPS64 where it erroneously modified the v0 (syscall) register with the assumption that the sycall offset hasn't been taken into consideration. This breaks seccomp on MIPS64 n64 and n32 ABIs. We fix this by replacing the addition with a move instruction. Fixes: 4c21b8fd8f14 ("MIPS: seccomp: Handle indirect system calls (o32)") Cc: <stable@vger.kernel.org> # 3.15+ Reviewed-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/10951/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-08-14Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "Just two very small & simple patches" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: Use adjustment in guest cycles when handling MSR_IA32_TSC_ADJUST KVM: x86: zero IDT limit on entry to SMM
2015-08-14Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixes: PMU driver corner cases, tooling fixes, and an 'AUX' (Intel PT) race related core fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/cqm: Do not access cpu_data() from CPU_UP_PREPARE handler perf/x86/intel: Fix memory leak on hot-plug allocation fail perf: Fix PERF_EVENT_IOC_PERIOD migration race perf: Fix double-free of the AUX buffer perf: Fix fasync handling on inherited events perf tools: Fix test build error when bindir contains double slash perf stat: Fix transaction lenght metrics perf: Fix running time accounting
2015-08-13Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Another few small ARM fixes, mostly addressing some VDSO issues" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8410/1: VDSO: fix coarse clock monotonicity regression ARM: 8409/1: Mark ret_fast_syscall as a function ARM: 8408/1: Fix the secondary_startup function in Big Endian case ARM: 8405/1: VDSO: fix regression with toolchains lacking ld.bfd executable
2015-08-13x86: fix error handling for 32-bit compat out-of-range system call numbersLinus Torvalds
Commit 3f5159a9221f ("x86/asm/entry/32: Update -ENOSYS handling to match the 64-bit logic") broke the ENOSYS handling for the 32-bit compat case. The proper error return value was never loaded into %rax, except if things just happened to go through the audit paths, which ended up reloading the return value. This moves the loading or %rax into the normal system call path, just to make sure the error case triggers it. It's kind of sad, since it adds a useless instruction to reload the register to the fast path, but it's not like that single load from the stack is going to be noticeable. Reported-by: David Drysdale <drysdale@google.com> Tested-by: Kees Cook <keescook@chromium.org> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-13Merge tag 'for-linus-4.2-rc6-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen bug fixes from David Vrabel: - revert a fix from 4.2-rc5 that was causing lots of WARNING spam. - fix a memory leak affecting backends in HVM guests. - fix PV domU hang with certain configurations. * tag 'for-linus-4.2-rc6-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/xenbus: Don't leak memory when unmapping the ring on HVM backend Revert "xen/events/fifo: Handle linked events when closing a port" x86/xen: build "Xen PV" APIC driver for domU as well
2015-08-13Revert x86 sigcontext cleanupsLinus Torvalds
This reverts commits 9a036b93a344 ("x86/signal/64: Remove 'fs' and 'gs' from sigcontext") and c6f2062935c8 ("x86/signal/64: Fix SS handling for signals delivered to 64-bit programs"). They were cleanups, but they break dosemu by changing the signal return behavior (and removing 'fs' and 'gs' from the sigcontext struct - while not actually changing any behavior - causes build problems). Reported-and-tested-by: Stas Sergeev <stsp@list.ru> Acked-by: Andy Lutomirski <luto@amacapital.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-13ARM: dts: keystone: Fix the mdio bindings by moving it to soc specific fileMurali Karicheri
Currently mdio bindings are defined in keystone.dtsi and this results in incorrect unit address for the node on K2E and K2L SoCs. Fix this by moving them to SoC specific DTS file. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2015-08-13ARM: dts: keystone: fix the clock node for mdioMurali Karicheri
Currently the MDIO clock is pointing to clkpa instead of clkcpgmac. MDIO is part of the ethss and the clock should be clkcpgmac. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Santosh Shilimkar <ssantosh@kernel.org>
2015-08-13Merge tag 'imx-fixes-4.2-3' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes The i.MX fixes for 4.2, 3rd round: - Fix i.MX6 PCIe interrupt routing which gets missed from stacked IRQ domain conversion. The PCIe wakeup support is currently broken because of this. * tag 'imx-fixes-4.2-3' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: ARM: imx6: correct i.MX6 PCIe interrupt routing Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-13Merge tag 'samsung-mach-fixes-4.2' of https://github.com/krzk/linux into fixesOlof Johansson
Two fixes for bugs in Exynos power domain error exit path: 1. kfree() of read-only memory (name of power domain returned by kstrdup_const()), 2. Doubled of_node_put() leading to invalid ref count for OF node. * tag 'samsung-mach-fixes-4.2' of https://github.com/krzk/linux: ARM: EXYNOS: fix double of_node_put() on error path ARM: EXYNOS: Fix potentian kfree() of ro memory Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-12perf/x86/intel/cqm: Do not access cpu_data() from CPU_UP_PREPARE handlerMatt Fleming
Tony reports that booting his 144-cpu machine with maxcpus=10 triggers the following WARN_ON(): [ 21.045727] WARNING: CPU: 8 PID: 647 at arch/x86/kernel/cpu/perf_event_intel_cqm.c:1267 intel_cqm_cpu_prepare+0x75/0x90() [ 21.045744] CPU: 8 PID: 647 Comm: systemd-udevd Not tainted 4.2.0-rc4 #1 [ 21.045745] Hardware name: Intel Corporation BRICKLAND/BRICKLAND, BIOS BRHSXSD1.86B.0066.R00.1506021730 06/02/2015 [ 21.045747] 0000000000000000 0000000082771b09 ffff880856333ba8 ffffffff81669b67 [ 21.045748] 0000000000000000 0000000000000000 ffff880856333be8 ffffffff8107b02a [ 21.045750] ffff88085b789800 ffff88085f68a020 ffffffff819e2470 000000000000000a [ 21.045750] Call Trace: [ 21.045757] [<ffffffff81669b67>] dump_stack+0x45/0x57 [ 21.045759] [<ffffffff8107b02a>] warn_slowpath_common+0x8a/0xc0 [ 21.045761] [<ffffffff8107b15a>] warn_slowpath_null+0x1a/0x20 [ 21.045762] [<ffffffff81036725>] intel_cqm_cpu_prepare+0x75/0x90 [ 21.045764] [<ffffffff81036872>] intel_cqm_cpu_notifier+0x42/0x160 [ 21.045767] [<ffffffff8109a33d>] notifier_call_chain+0x4d/0x80 [ 21.045769] [<ffffffff8109a44e>] __raw_notifier_call_chain+0xe/0x10 [ 21.045770] [<ffffffff8107b538>] _cpu_up+0xe8/0x190 [ 21.045771] [<ffffffff8107b65a>] cpu_up+0x7a/0xa0 [ 21.045774] [<ffffffff8165e920>] cpu_subsys_online+0x40/0x90 [ 21.045777] [<ffffffff81433b37>] device_online+0x67/0x90 [ 21.045778] [<ffffffff81433bea>] online_store+0x8a/0xa0 [ 21.045782] [<ffffffff81430e78>] dev_attr_store+0x18/0x30 [ 21.045785] [<ffffffff8126b6ba>] sysfs_kf_write+0x3a/0x50 [ 21.045786] [<ffffffff8126ad40>] kernfs_fop_write+0x120/0x170 [ 21.045789] [<ffffffff811f0b77>] __vfs_write+0x37/0x100 [ 21.045791] [<ffffffff811f38b8>] ? __sb_start_write+0x58/0x110 [ 21.045795] [<ffffffff81296d2d>] ? security_file_permission+0x3d/0xc0 [ 21.045796] [<ffffffff811f1279>] vfs_write+0xa9/0x190 [ 21.045797] [<ffffffff811f2075>] SyS_write+0x55/0xc0 [ 21.045800] [<ffffffff81067300>] ? do_page_fault+0x30/0x80 [ 21.045804] [<ffffffff816709ae>] entry_SYSCALL_64_fastpath+0x12/0x71 [ 21.045805] ---[ end trace fe228b836d8af405 ]--- The root cause is that CPU_UP_PREPARE is completely the wrong notifier action from which to access cpu_data(), because smp_store_cpu_info() won't have been executed by the target CPU at that point, which in turn means that ->x86_cache_max_rmid and ->x86_cache_occ_scale haven't been filled out. Instead let's invoke our handler from CPU_STARTING and rename it appropriately. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ashok Raj <ashok.raj@intel.com> Cc: Kanaka Juvva <kanaka.d.juvva@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vikas Shivappa <vikas.shivappa@intel.com> Link: http://lkml.kernel.org/r/1438863163-14083-1-git-send-email-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-12perf/x86/intel: Fix memory leak on hot-plug allocation failPeter Zijlstra
We fail to free the shared_regs allocation if the constraint_list allocation fails. Cure this and be more consistent in NULL-ing the pointers after free. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-11Merge tag 'omap-for-v4.2/fixes-rc5' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Few trivial omap MMC regression fixes for card voltages where the syscon areas for PBIAS regulator were missing "simple-bus" that prevents probing of the children in the mapped region. This probably was not noticed earlier as the bootloader has already configured the regulator for the card in the slot. * tag 'omap-for-v4.2/fixes-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: dts: dra7: Fix broken pbias device creation ARM: dts: OMAP5: Fix broken pbias device creation ARM: dts: OMAP4: Fix broken pbias device creation ARM: dts: omap243x: Fix broken pbias device creation Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-11ARM: 8410/1: VDSO: fix coarse clock monotonicity regressionNathan Lynch
Since 906c55579a63 ("timekeeping: Copy the shadow-timekeeper over the real timekeeper last") it has become possible on ARM to: - Obtain a CLOCK_MONOTONIC_COARSE or CLOCK_REALTIME_COARSE timestamp via syscall. - Subsequently obtain a timestamp for the same clock ID via VDSO which predates the first timestamp (by one jiffy). This is because ARM's update_vsyscall is deriving the coarse time using the __current_kernel_time interface, when it should really be using the timekeeper object provided to it by the timekeeping core. It happened to work before only because __current_kernel_time would access the same timekeeper object which had been passed to update_vsyscall. This is no longer the case. Cc: stable@vger.kernel.org Fixes: 906c55579a63 ("timekeeping: Copy the shadow-timekeeper over the real timekeeper last") Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-08-10arm64: VDSO: fix coarse clock monotonicity regressionNathan Lynch
Since 906c55579a63 ("timekeeping: Copy the shadow-timekeeper over the real timekeeper last") it has become possible on arm64 to: - Obtain a CLOCK_MONOTONIC_COARSE or CLOCK_REALTIME_COARSE timestamp via syscall. - Subsequently obtain a timestamp for the same clock ID via VDSO which predates the first timestamp (by one jiffy). This is because arm64's update_vsyscall is deriving the coarse time using the __current_kernel_time interface, when it should really be using the timekeeper object provided to it by the timekeeping core. It happened to work before only because __current_kernel_time would access the same timekeeper object which had been passed to update_vsyscall. This is no longer the case. Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2015-08-10x86/xen: build "Xen PV" APIC driver for domU as wellJason A. Donenfeld
It turns out that a PV domU also requires the "Xen PV" APIC driver. Otherwise, the flat driver is used and we get stuck in busy loops that never exit, such as in this stack trace: (gdb) target remote localhost:9999 Remote debugging using localhost:9999 __xapic_wait_icr_idle () at ./arch/x86/include/asm/ipi.h:56 56 while (native_apic_mem_read(APIC_ICR) & APIC_ICR_BUSY) (gdb) bt #0 __xapic_wait_icr_idle () at ./arch/x86/include/asm/ipi.h:56 #1 __default_send_IPI_shortcut (shortcut=<optimized out>, dest=<optimized out>, vector=<optimized out>) at ./arch/x86/include/asm/ipi.h:75 #2 apic_send_IPI_self (vector=246) at arch/x86/kernel/apic/probe_64.c:54 #3 0xffffffff81011336 in arch_irq_work_raise () at arch/x86/kernel/irq_work.c:47 #4 0xffffffff8114990c in irq_work_queue (work=0xffff88000fc0e400) at kernel/irq_work.c:100 #5 0xffffffff8110c29d in wake_up_klogd () at kernel/printk/printk.c:2633 #6 0xffffffff8110ca60 in vprintk_emit (facility=0, level=<optimized out>, dict=0x0 <irq_stack_union>, dictlen=<optimized out>, fmt=<optimized out>, args=<optimized out>) at kernel/printk/printk.c:1778 #7 0xffffffff816010c8 in printk (fmt=<optimized out>) at kernel/printk/printk.c:1868 #8 0xffffffffc00013ea in ?? () #9 0x0000000000000000 in ?? () Mailing-list-thread: https://lkml.org/lkml/2015/8/4/755 Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Cc: <stable@vger.kernel.org> Signed-off-by: David Vrabel <david.vrabel@citrix.com>
2015-08-09Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "Another round of MIPS fixes for 4.2. No area does particularly stand out but we have a two unpleasant ones: - Kernel ptes are marked with a global bit which allows the kernel to share kernel TLB entries between all processes. For this to work both entries of an adjacent even/odd pte pair need to have the global bit set. There has been a subtle race in setting the other entry's global bit since ~ 2000 but it take particularly pathological workloads that essentially do mostly vmalloc/vfree to trigger this. This pull request fixes the 64-bit case but leaves the case of 32 bit CPUs with 64 bit ptes unsolved for now. The unfixed cases affect hardware that is not available in the field yet. - Instruction emulation requires loading instructions from user space but the current fast but simplistic approach will fail on pages that are PROT_EXEC but !PROT_READ. For this reason we temporarily do not permit this permission and will map pages with PROT_EXEC | PROT_READ. The remainder of this pull request is more or less across the field and the short log explains them well" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Make set_pte() SMP safe. MIPS: Replace add and sub instructions in relocate_kernel.S with addiu MIPS: Flush RPS on kernel entry with EVA Revert "MIPS: BCM63xx: Provide a plat_post_dma_flush hook" MIPS: BMIPS: Delete unused Kconfig symbol MIPS: Export get_c0_perfcount_int() MIPS: show_stack: Fix stack trace with EVA MIPS: do_mcheck: Fix kernel code dump with EVA MIPS: SMP: Don't increment irq_count multiple times for call function IPIs MIPS: Partially disable RIXI support. MIPS: Handle page faults of executable but unreadable pages correctly. MIPS: Malta: Don't reinitialise RTC MIPS: unaligned: Fix build error on big endian R6 kernels MIPS: Fix sched_getaffinity with MT FPAFF enabled MIPS: Fix build with CONFIG_OF=y for non OF-enabled targets CPUFREQ: Loongson2: Fix broken build due to incorrect include.
2015-08-08x86/ldt: Correct FPU emulation access to LDTJuergen Gross
Commit 37868fe113ff ("x86/ldt: Make modify_ldt synchronous") introduced a new struct ldt_struct anchored at mm->context.ldt. Adapt the x86 fpu emulation code to use that new structure. Signed-off-by: Juergen Gross <jgross@suse.com> Reviewed-by: Andy Lutomirski <luto@kernel.org> Cc: <stable@vger.kernel.org> # On top of: 37868fe113ff: x86/ldt: Make modify_ldt synchronous Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: billm@melbpc.org.au Link: http://lkml.kernel.org/r/1438883674-1240-1-git-send-email-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-08x86/ldt: Correct LDT access in single stepping logicJuergen Gross
Commit 37868fe113ff ("x86/ldt: Make modify_ldt synchronous") introduced a new struct ldt_struct anchored at mm->context.ldt. convert_ip_to_linear() was changed to reflect this, but indexing into the ldt has to be changed as the pointer is no longer void *. Signed-off-by: Juergen Gross <jgross@suse.com> Reviewed-by: Andy Lutomirski <luto@kernel.org> Cc: <stable@vger.kernel.org> # On top of: 37868fe113ff: x86/ldt: Make modify_ldt synchronous Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: bp@suse.de Link: http://lkml.kernel.org/r/1438848278-12906-1-git-send-email-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-08Merge tag 'arc-v4.2-rc6-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC fixes from Vineet Gupta: "Here's a late pull request for accumulated ARC fixes which came out of extended testing of the new ARCv2 port with LTP etc. llock/scond livelock workaround has been reviewed by PeterZ. The changes look a lot but I've crafted them into finer grained patches for better tracking later. I have some more fixes (ARC Futex backend) ready to go but those will have to wait for tglx to return from vacation. Summary: - Enable a reduced config of HS38 (w/o div-rem, ll64...) - Add software workaround for LLOCK/SCOND livelock - Fallout of a recent pt_regs update" * tag 'arc-v4.2-rc6-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: ARCv2: spinlock/rwlock/atomics: reduce 1 instruction in exponential backoff ARC: Make pt_regs regs unsigned ARCv2: spinlock/rwlock: Reset retry delay when starting a new spin-wait cycle ARCv2: spinlock/rwlock/atomics: Delayed retry of failed SCOND with exponential backoff ARC: LLOCK/SCOND based rwlock ARC: LLOCK/SCOND based spin_lock ARC: refactor atomic inline asm operands with symbolic names Revert "ARCv2: STAR 9000837815 workaround hardware exclusive transactions livelock" ARCv2: [axs103_smp] Reduce clk for Quad FPGA configs ARCv2: Fix the peripheral address space detection ARCv2: allow selection of page size for MMUv4 ARCv2: lib: memset: Don't assume 64-bit load/stores ARCv2: lib: memcpy: Missing PREFETCHW ARCv2: add knob for DIV_REV in Kconfig ARC/time: Migrate to new 'set-state' interface
2015-08-08Merge tag 'usb-4.2-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are some USB and PHY fixes for 4.2-rc6 that resolve some reported issues. All of these have been in the linux-next tree for a while, full details on the patches are in the shortlog below" * tag 'usb-4.2-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: ARM: dts: dra7: Add syscon-pllreset syscon to SATA PHY drivers/usb: Delete XHCI command timer if necessary xhci: fix off by one error in TRB DMA address boundary check usb: udc: core: add device_del() call to error pathway phy: ti-pipe3: i783 workaround for SATA lockup after dpll unlock/relock phy-sun4i-usb: Add missing EXPORT_SYMBOL_GPL for sun4i_usb_phy_set_squelch_detect USB: sierra: add 1199:68AB device ID usb: gadget: f_printer: actually limit the number of instances usb: gadget: f_hid: actually limit the number of instances usb: gadget: f_uac2: fix calculation of uac2->p_interval usb: gadget: bdc: fix a driver crash on disconnect usb: chipidea: ehci_init_driver is intended to call one time USB: qcserial: Add support for Dell Wireless 5809e 4G Modem USB: qcserial/option: make AT URCs work for Sierra Wireless MC7305/MC7355
2015-08-07ARM: 8409/1: Mark ret_fast_syscall as a functionDrew Richardson
ret_fast_syscall runs when user space makes a syscall. However it needs to be marked as such so the ELF information is correct. Before it was: 101: 8000f300 0 NOTYPE LOCAL DEFAULT 2 ret_fast_syscall But with this change it correctly shows as: 101: 8000f300 96 FUNC LOCAL DEFAULT 2 ret_fast_syscall I see this function when using perf to unwind call stacks from kernel space to user space. Without this change I would need to add some special case logic when using the vmlinux ELF information. Signed-off-by: Drew Richardson <drew.richardson@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
