path: root/arch
2007-03-14Disable NMI watchdog by default properlyLinus Torvalds
This reverts commit 6ebf622b2577c50b1f496bd6a5e8739e55ae7b1c and replaces it with one that actually works. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] sparc: nr_free_pages() is unsigned longAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] pasemi trivial iomem annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] constant should be longAl Viro
2007-03-14[PATCH] misc NULL noiseAl Viro
2007-03-14[PATCH] stacktrace doesn't work on umlAl Viro
and no, it's not the case of "let's pull bits from underlying architecture" Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] (uml) sparse flags for userland glue are missing $(CF)Al Viro
2007-03-14[PATCH] appldata build fixAl Viro
PGALLOC_DMA is defined only if we have CONFIG_ZONE_DMA Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-13Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Add missing HPAGE_MASK masks on address parameters. [SPARC]: Hook up missing syscalls.
2007-03-13Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] kspd: ioctl needs a translation entry. [MIPS] Viper2: Remove defective support. [MIPS] Oprofile: Reset all performance registers for MIPS_MT_SMP configs
2007-03-13[MIPS] kspd: ioctl needs a translation entry.Ralf Baechle
2007-03-13[MIPS] Viper2: Remove defective support.Ralf Baechle
A defconfig file and the 10 lines of code (including comments ...) that are rotting since lmo commit 6516a42dc8b40c6c00010346dd51496125b16644 don't quite make proper support, so let's trash it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-13[MIPS] Oprofile: Reset all performance registers for MIPS_MT_SMP configsChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-12[SPARC64]: Add missing HPAGE_MASK masks on address parameters.David S. Miller
These pte loops all assume the passed in address is HPAGE aligned, make sure that is actually true. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-12[SPARC]: Hook up missing syscalls.David S. Miller
sys_mbind sys_get_mempolicy sys_set_mempolicy sys_kexec_load sys_move_pages sys_getcpu sys_epoll_pwait This work is largely a result of David Woodhouse's most excellent missing syscalls patch. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-12Merge branch 'merge' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] sys_move_pages should be callable from an SPU [POWERPC] Wire up sys_epoll_pwait [POWERPC] Allocate syscall number for sys_getcpu [POWERPC] update cell_defconfig [POWERPC] ps3: always make sure were running on a PS3 [POWERPC] Fix spu SLB invalidations [POWERPC] avoid SPU_ACTIVATE_NOWAKE optimization [POWERPC] spufs: fix possible memory corruption is spufs_mem_write
2007-03-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC]: Fix TIF_USEDFPU flag atomicity [SPARC64]: Fix atomicity of TIF update in flush_thread() [BW2]: Fix section mismatch warnings. [CG14]: Fix section mismatch warnings. [SPARC]: We do not need OLD_GETRLIMIT.
2007-03-12[SPARC]: Fix TIF_USEDFPU flag atomicityWilliam Lee Irwin III
From: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-12[PATCH] Fix VMI and COMPAT_VDSO for 2.6.21Zachary Amsden
VMI is broken under COMPAT_VDSO, as Xen and other non hardware assisted hypervisors will be. I have been working on a fix for this which works for older glibcs that panic when the new relocatable VDSO is used. However, I believe at this time that the fix is going to be too radical to consider at this stage in the release of 2.6.21. We don't expect this config option to be turned on by vendors for new distributions, so at this point we are willing to drop support for it when VMI is compiled in, and work on a patch for 2.6.22 which more fully addresses the problem. Signed-off-by: Zachary Amsden <zach@vmware.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4263/1: fix IXP4XX_NPE[ABC]_BASE_VIRT address [ARM] 4256/1: i.MX/MX1 SDHC fix/workaround of SD card recognition problems [ARM] 4255/1: i.MX/MX1 Correct MPU PLL reference clock value. [ARM] 4254/1: i.MX/MX1 CPU Frequency scaling honor boot loader set BCLK_DIV. [ARM] 4251/1: Fix sharpsl_pm dependency [ARM] 4250/1: Fix locomo backlight conversion error/compile failure [ARM] 4249/1: Fix tosa compile failure [ARM] 4248/1: lh7a40x: fix missing definitions for get_irqnr_preamble [ARM] 4247/1: Fix long name for cc9p9360dev ARM: OMAP: Fix OMAP2 dss2 so clk_set_parent works ARM: OMAP: Fix missing workqueue include in board-h2.c ARM: OMAP: Include missing header
2007-03-12[ARM] 4255/1: i.MX/MX1 Correct MPU PLL reference clock value.Pavel Pisa
Only System PLL clock source is selectable by CSCR_SYSTEM_SEL bit. MPU PLL is driven by 512*CLK32 for each case. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-12[ARM] 4254/1: i.MX/MX1 CPU Frequency scaling honor boot loader set BCLK_DIV.Pavel Pisa
The minimal bus clock prescaler should be kept at value selected by the board / boot loader designer. Switching frequency above startup limit could lead to the external memory/devices misbehave. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-12Merge branch 'cell-merge' of ↵Paul Mackerras
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/cell-2.6 into merge
2007-03-10[SPARC64]: Fix atomicity of TIF update in flush_thread()Mathieu Desnoyers
Fix atomicity of TIF update in flush_thread() for sparc64 Fixes correctly the race by using *_ti_thread_flag. Race : parent process executing : sys_ptrace() (lock_kernel()) (ptrace_get_task_struct(pid)) arch_ptrace() ptrace_detach() ptrace_disable(child); clear_singlestep(child); clear_tsk_thread_flag(child, TIF_SINGLESTEP); (which clears the TIF_SINGLESTEP flag atomically from a different process) (put_task_struct(child)) (unlock_kernel()) And at the same time, in the child process : sys_execve() do_execve() search_binary_handler() load_elf_binary() flush_old_exec() flush_thread() doing a non-atomic thread flag update Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-09Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] refresh config files [IA64] put kdump_find_rsvd_region in __init [IA64] Remove sparse warning from unwind code [IA64] add missing syscall trace clear [IA64] Cleanup in crash.c [IA64] kexec: declare ia64_mca_pal_base in mca.h rather than kexec.h [IA64] pci_get_legacy_ide_irq should return irq (not GSI) [IA64] whitespace fixes for include/asm-ia64/sal.h [IA64] Cache error recovery [IA64] Proper handling of TLB errors from duplicate itr.d dropins
2007-03-09Pull bugzilla-5966 into release branchLen Brown
2007-03-09Pull altix into release branchLen Brown
2007-03-10[POWERPC] update cell_defconfigArnd Bergmann
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-03-10[POWERPC] ps3: always make sure were running on a PS3Geert Uytterhoeven
Add missing checks to PS3 specific drivers ps3av and sys-manager to verify that we are actually running on a PS3 (pointed out by Arnd). Correct existing checks in other subsystems/drivers to return -ENODEV instead of zero. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-03-10[POWERPC] Fix spu SLB invalidationsBenjamin Herrenschmidt
The SPU code doesn't properly invalidate SPUs SLBs when necessary, for example when changing a segment size from the hugetlbfs code. In addition, it saves and restores the SLB content on context switches which makes it harder to properly handle those invalidations. This patch removes the saving & restoring for now, something more efficient might be found later on. It also adds a spu_flush_all_slbs(mm) that can be used by the core mm code to flush the SLBs of all SPEs that are running a given mm at the time of the flush. In order to do that, it adds a spinlock to the list of all SPEs and move some bits & pieces from spufs to spu_base.c Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2007-03-10[POWERPC] avoid SPU_ACTIVATE_NOWAKE optimizationChristoph Hellwig
This optimization was added recently but is still buggy, so back it out for now. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2007-03-10[POWERPC] spufs: fix possible memory corruption is spufs_mem_writeArnd Bergmann
Due to a buggy unsigned comparison, it was possible to write beyond the end of the local store file in spufs under some circumstances. This rewrites the buggy function to look more like simple_copy_from_buffer. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Cc: Ulrich Weigand <Ulrich.Weigand@de.ibm.com>
2007-03-09Merge branch 'merge' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] 85xx: Enable CONFIG_SERIAL_8250_SHARE_IRQ [POWERPC] Select u-image as default image for Linkstation [POWERPC] 83xx: Minor fixes for 834x_mds USB setup code [POWERPC] Fix warning in powermac pci.c [POWERPC] Fix warning in powermac feature.c [POWERPC] Fix warning in prom_parse.c of_irq_map_oldworld() [POWERPC] Celleb: bug fix caused by not casting pointer types [POWERPC] Add missing newline in xmon help output [POWERPC] No DEEPNAP on 970MP 1.0
2007-03-09[MIPS] Sibyte: Fix ZBbus profilerRalf Baechle
o Fix build error. o Handle error returns. o Deal with signals received while sleeping. o Don't allow to be selected when we're not building the directory with the driver anyway. o Coding style cleanups. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-09[MIPS] Sibyte: Do not allow enabling LDT support if PCI is disabled.Ralf Baechle
2007-03-09Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] DEC: Remove call to register_prom_console.
2007-03-09[MIPS] DEC: Remove call to register_prom_console.Ralf Baechle
Register_prom_console was removed when mips was converted to early printk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-08[PATCH] build fix for i386 earlyquirk.cDave Jones
missing close bracket. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] ACPI: repair nvidia early quirk breakage on x86_64Len Brown
x86_64 nvidia_bugs() broke when we bailed out on not finding the HPET. However, the quirk works by checking for _not_ finding the HPET... Delete the nvidia_hpet_detected flag and simply test for not finding the HPET, which is simple to do now that acpi_table_parse returns 1 on failure. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[IA64] refresh config filesTony Luck
Bring defconfig, tiger_defconfig and zx1_defconfig up to date. Also sprinkle KEXEC and KDUMP combinations around liberally so that my usual regression test builds will see all combinations: tiger_defconfig gets KEXEC=y, CRASH_DUMP=n zx1_defconfig gets KEXEC=n, CRASH_DUMP=y defconfig gets KEXEC=y, CRASH_DUMP=y others remain at KEXEC=n, CRASH_DUMP=n Signed-off-by: Tony Luck <tomy.luck@intel.com>
2007-03-08[IA64] put kdump_find_rsvd_region in __initHorms
kdump_find_rsvd_region() is only called by reserve_memory() which is in __init, so it seems that kdump_find_rsvd_region() should also be in there. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-08[IA64] add missing syscall trace clearAkiyama, Nobuyuki
The ptrace misses clearing the syscall trace flag. The increased syscall overhead is retained after the trace is finished. This case happens when strace is terminated by force. Signed-off-by: Akiyama, Nobuyuki <akiyama.nobuyuk@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-08[IA64] Cleanup in crash.cSimon Horman
Grammatical fixes (s/freezed/frozen/) Make some variables static Change a C++ "//" comment to "/* ... */" Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-08[IA64] Cache error recoveryRuss Anderson
Similar to memory error recovery, when a cache error is consumed by a user process terminate the user instead of crashing the system. Signed-off-by: Russ Anderson (rja@sgi.com) Acked-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-08[IA64] Proper handling of TLB errors from duplicate itr.d dropinsRuss Anderson
Jack Steiner noticed that duplicate TLB DTC entries do not cause a linux panic. See discussion: http://www.gelato.unsw.edu.au/archives/linux-ia64/0307/6108.html The current TLB recovery code is recovering from the duplicate itr.d dropins, masking the underlying problem. This change modifies the MCA recovery code to look for the TLB check signature of the duplicate TLB entry and panic in that case. Signed-off-by: Russ Anderson (rja@sgi.com) Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-03-08[PATCH] uml: arch_prctl should set thread fsJeff Dike
In my previous x86_64 thread fix, I forgot to initialize thread.arch.fs in arch_prctl. A process calling arch_prctl to set %fs would lose it on the next context switch. It also turns out that you can switch to a process which is in the process of exiting and which has lost its mm. In this case, it's worse than useless to try to call arch_prctl on the host process. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] Add epoll compat_ code to fs/compat.cDavide Libenzi
IA64 and ARM-OABI are currently using their own version of epoll compat_ code. An architecture needs epoll_event translation if alignof(u64) in 32 bit mode is different from alignof(u64) in 64 bit mode. If an architecture needs epoll_event translation, it must define struct compat_epoll_event in asm/compat.h and set CONFIG_HAVE_COMPAT_EPOLL_EVENT and use compat_sys_epoll_ctl and compat_sys_epoll_wait. All 64 bit architecture should use compat_sys_epoll_pwait. [sfr: restructure and move to fs/compat.c, remove MIPS version of compat_sys_epoll_pwait, use __put_user_unaligned] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] x86_64: fix 2.6.18 regression - PTRACE_OLDSETOPTIONS should be acceptedPaolo 'Blaisorblade' Giarrusso
Also PTRACE_OLDSETOPTIONS should be accepted, as done by kernel/ptrace.c and forced by binary compatibility. UML/32bit breaks because of this - since it is wise enough to use PTRACE_OLDSETOPTIONS to be binary compatible with 2.4 host kernels. Until 2.6.17 (commit f0f2d6536e3515b5b1b7ae97dc8f176860c8c2ce) we had: default: return sys_ptrace(request, pid, addr, data); Instead here we have: case PTRACE_GET_THREAD_AREA: case ...: return sys_ptrace(request, pid, addr, data); default: return -EINVAL; This change was a style change - when a case is added, it must be explicitly tested this way. In this case, not enough testing was done. Cc: Andi Kleen <ak@suse.de> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] um: fix errno usagePaolo 'Blaisorblade' Giarrusso
Avoid reusing userspace errno twice - it can be cleared by libc code everywhere (in particular printk() does clear it in my setup). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] uml: activate_fd: return ENOMEM only when appropriatePaolo 'Blaisorblade' Giarrusso
Avoid returning ENOMEM in case of a duplicate IRQ - ENOMEM was saved into err earlier. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
