path: root/arch
2011-04-14Revert "x86: Cleanup highmap after brk is concluded"Greg Kroah-Hartman
This reverts upstream commit e5f15b45ddf3afa2bbbb10c7ea34fb32b6de0a0e It caused problems in the stable tree and should not have been there. Cc: Yinghai Lu <yinghai@kernel.org> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14x86, mtrr, pat: Fix one cpu getting out of sync during resumeSuresh Siddha
commit 84ac7cdbdd0f04df6b96153f7a79127fd6e45467 upstream. On laptops with core i5/i7, there were reports that after resume graphics workloads were performing poorly on a specific AP, while the other cpu's were ok. This was observed on a 32bit kernel specifically. Debug showed that the PAT init was not happening on that AP during resume and hence it contributing to the poor workload performance on that cpu. On this system, resume flow looked like this: 1. BP starts the resume sequence and we reinit BP's MTRR's/PAT early on using mtrr_bp_restore() 2. Resume sequence brings all AP's online 3. Resume sequence now kicks off the MTRR reinit on all the AP's. 4. For some reason, between point 2 and 3, we moved from BP to one of the AP's. My guess is that printk() during resume sequence is contributing to this. We don't see similar behavior with the 64bit kernel but there is no guarantee that at this point the remaining resume sequence (after AP's bringup) has to happen on BP. 5. set_mtrr() was assuming that we are still on BP and skipped the MTRR/PAT init on that cpu (because of 1 above) 6. But we were on an AP and this led to not reprogramming PAT on this cpu leading to bad performance. Fix this by doing unconditional mtrr_if->set_all() in set_mtrr() during MTRR/PAT init. This might be unnecessary if we are still running on BP. But it is of no harm and will guarantee that after resume, all the cpu's will be in sync with respect to the MTRR/PAT registers. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1301438292-28370-1-git-send-email-eric@anholt.net> Signed-off-by: Eric Anholt <eric@anholt.net> Tested-by: Keith Packard <keithp@keithp.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14powerpc: Fix accounting of softirq time when idleAnton Blanchard
commit ad5d1c888e556bc00c4e86f452cad4a3a87d22c1 upstream. commit cf9efce0ce31 (powerpc: Account time using timebase rather than PURR) used in_irq() to detect if the time was spent in interrupt processing. This only catches hardirq context so if we are in softirq context and in the idle loop we end up accounting it as idle time. If we instead use in_interrupt() we catch both softirq and hardirq time. The issue was found when running a network intensive workload. top showed the following: 0.0%us, 1.1%sy, 0.0%ni, 85.7%id, 0.0%wa, 9.9%hi, 3.3%si, 0.0%st 85.7% idle. But this was wildly different to the perf events data. To confirm the suspicion I ran something to keep the core busy: # yes > /dev/null & 8.2%us, 0.0%sy, 0.0%ni, 0.0%id, 0.0%wa, 10.3%hi, 81.4%si, 0.0%st We only got 8.2% of the CPU for the userspace task and softirq has shot up to 81.4%. With the patch below top shows the correct stats: 0.0%us, 0.0%sy, 0.0%ni, 5.3%id, 0.0%wa, 13.3%hi, 81.3%si, 0.0%st Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-14crypto: aesni-intel - fixed problem with packets that are not multiple of ↵Tadeusz Struk
64bytes commit 60af520cf264ea26b2af3a6871bbd71850522aea upstream. This patch fixes problem with packets that are not multiple of 64bytes. Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27x86: Cleanup highmap after brk is concludedYinghai Lu
commit e5f15b45ddf3afa2bbbb10c7ea34fb32b6de0a0e upstream. Now cleanup_highmap actually is in two steps: one is early in head64.c and only clears above _end; a second one is in init_memory_mapping() and tries to clean from _brk_end to _end. It should check if those boundaries are PMD_SIZE aligned but currently does not. Also init_memory_mapping() is called several times for numa or memory hotplug, so we really should not handle initial kernel mappings there. This patch moves cleanup_highmap() down after _brk_end is settled so we can do everything in one step. Also we honor max_pfn_mapped in the implementation of cleanup_highmap. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> LKML-Reference: <alpine.DEB.2.00.1103171739050.3382@kaball-desktop> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27sh: Fix ptrace hw_breakpoint handlingDavid Engraf
commit fb7f045ace0624f1e59a7db8497e460bd54b1cbc upstream. Since commit 34d0b5af50a063cded842716633501b38ff815fb it is no longer possible to debug an application using singlestep. The old commit converted singlestep handling via ptrace to hw_breakpoints. The hw_breakpoint is disabled when an event is triggered and not re-enabled again. This patch re-enables the existing hw_breakpoint before the existing breakpoint is reused. Signed-off-by: David Engraf <david.engraf@sysgo.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27sh: Fix ptrace fpu state initialisationPhil Edworthy
commit c49b6ecf0870e78fa40497cd8b142915c1d5c7c9 upstream. Commit 0ea820cf introduced the PTRACE_GETFPREGS/SETFPREGS cmds, but gdb-server still accesses the FPU state using the PTRACE_PEEKUSR/POKEUSR commands. In this case, xstate was not initialised. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27x86: Fix binutils-2.21 symbol related build failuresSedat Dilek
commit 2ae9d293b14d17f35eff624272cfecac7979a2ee upstream. [only 1/2 of the upstream commit was needed for stable - gkh] New binutils version 2.21.0.20110302-1 started checking that the symbol parameter to the .size directive matches the entry name's symbol parameter, unearthing two mismatches: AS arch/x86/kernel/acpi/wakeup_rm.o arch/x86/kernel/acpi/wakeup_rm.S: Assembler messages: arch/x86/kernel/acpi/wakeup_rm.S:12: Error: .size expression with symbol `wakeup_code_start' does not evaluate to a constant arch/x86/kernel/entry_32.S: Assembler messages: arch/x86/kernel/entry_32.S:1421: Error: .size expression with symbol `apf_page_fault' does not evaluate to a constant The problem was discovered while using Debian's binutils (2.21.0.20110302-1) and experimenting with binutils from upstream. Thanks Alexander and H.J. for the vital help. Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Alexander van Heukelum <heukelum@fastmail.fm> Cc: H.J. Lu <hjl.tools@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Rafael J. Wysocki <rjw@sisk.pl> LKML-Reference: <1299620364-21644-1-git-send-email-sedat.dilek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27xen: set max_pfn_mapped to the last pfn mappedStefano Stabellini
commit 14988a4d350ce3b41ecad4f63c4f44c56f5ae34d upstream. Do not set max_pfn_mapped to the end of the initial memory mappings, that also contain pages that don't belong in pfn space (like the mfn list). Set max_pfn_mapped to the last real pfn mapped in the initial memory mappings that is the pfn backing _end. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> LKML-Reference: <alpine.DEB.2.00.1103171739050.3382@kaball-desktop> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-27ASoC: mini2440: Fix uda134x codec problem.Marek Belisko
commit a110f4ef810ee29d810876df725f41d66629733e upstream. ASoC audio for mini2440 platform in current kenrel doesn't work. First problem is samsung_asoc_dma device is missing in initialization. Next problem is with codec. Codec is initialized but never probed because no platform_device exist for codec driver. It leads to errors during codec binding to asoc dai. Next problem was platform data which was passed from board to asoc main driver but not passed to codec when called codec_soc_probe(). Following patch should fix issues. But not sure if in correct way. Please review. Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23davinci: DM644x EVM: register MUSB device earlierSergei Shtylyov
commit 60d97a840175d3becb2e6de36537a5cdfc0ec3a9 upstream. The MUSB driver doesn't see its platform device on DM644x EVM board anymore since commit 73b089b052a69020b953312a624a6e1eb5b81fab (usb: musb: split davinci to its own platform_driver) because the new probe is called as subsys_initcall() now, and the device is registered later than that by the board code. Move the registration to davinci_evm_init() -- it's safe to do so because the MUSB core device still gets initialized as fs_initcall() -- which is late enough for the I2C GPIO expander (which controls VBUS) to be initialized. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Felipe Balbi <balbi@ti.com> Tested-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23x86, binutils, xen: Fix another wrong size directiveAlexander van Heukelum
commit 371c394af27ab7d1e58a66bc19d9f1f3ac1f67b4 upstream. The latest binutils (2.21.0.20110302/Ubuntu) breaks the build yet another time, under CONFIG_XEN=y due to a .size directive that refers to a slightly differently named (hence, to the now very strict and unforgiving assembler, non-existent) symbol. [ mingo: This unnecessary build breakage caused by new binutils version 2.21 gets escallated back several kernel releases spanning several years of Linux history, affecting over 130,000 upstream kernel commits (!), on CONFIG_XEN=y 64-bit kernels (i.e. essentially affecting all major Linux distro kernel configs). Git annotate tells us that this slight debug symbol code mismatch bug has been introduced in 2008 in commit 3d75e1b8: 3d75e1b8 (Jeremy Fitzhardinge 2008-07-08 15:06:49 -0700 1231) ENTRY(xen_do_hypervisor_callback) # do_hypervisor_callback(struct *pt_regs) The 'bug' is just a slight assymetry in ENTRY()/END() debug-symbols sequences, with lots of assembly code between the ENTRY() and the END(): ENTRY(xen_do_hypervisor_callback) # do_hypervisor_callback(struct *pt_regs) ... END(do_hypervisor_callback) Human reviewers almost never catch such small mismatches, and binutils never even warned about it either. This new binutils version thus breaks the Xen build on all upstream kernels since v2.6.27, out of the blue. This makes a straightforward Git bisection of all 64-bit Xen-enabled kernels impossible on such binutils, for a bisection window of over hundred thousand historic commits. (!) This is a major fail on the side of binutils and binutils needs to turn this show-stopper build failure into a warning ASAP. ] Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jan Beulich <jbeulich@novell.com> Cc: H.J. Lu <hjl.tools@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Kees Cook <kees.cook@canonical.com> LKML-Reference: <1299877178-26063-1-git-send-email-heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23fix per-cpu flag problem in the cpu affinity checkersThomas Gleixner
commit 9804c9eaeacfe78651052c5ddff31099f60ef78c upstream. The CHECK_IRQ_PER_CPU is wrong, it should be checking irq_to_desc(irq)->status not just irq. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23x86: Flush TLB if PGD entry is changed in i386 PAE modeShaohua Li
commit 4981d01eada5354d81c8929d5b2836829ba3df7b upstream. According to intel CPU manual, every time PGD entry is changed in i386 PAE mode, we need do a full TLB flush. Current code follows this and there is comment for this too in the code. But current code misses the multi-threaded case. A changed page table might be used by several CPUs, every such CPU should flush TLB. Usually this isn't a problem, because we prepopulate all PGD entries at process fork. But when the process does munmap and follows new mmap, this issue will be triggered. When it happens, some CPUs keep doing page faults: http://marc.info/?l=linux-kernel&m=129915020508238&w=2 Reported-by: Yasunori Goto<y-goto@jp.fujitsu.com> Tested-by: Yasunori Goto<y-goto@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Shaohua Li<shaohua.li@intel.com> Cc: Mallick Asit K <asit.k.mallick@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-mm <linux-mm@kvack.org> LKML-Reference: <1300246649.2337.95.camel@sli10-conroe> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23perf, powerpc: Handle events that raise an exception without overflowingAnton Blanchard
commit 0837e3242c73566fc1c0196b4ec61779c25ffc93 upstream. Events on POWER7 can roll back if a speculative event doesn't eventually complete. Unfortunately in some rare cases they will raise a performance monitor exception. We need to catch this to ensure we reset the PMC. In all cases the PMC will be 256 or less cycles from overflow. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110309143842.6c22845e@kryten> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23x86: stop_machine_text_poke() should issue sync_core()Mathieu Desnoyers
commit 0e00f7aed6af21fc09b2a94d28bc34e449bd3a53 upstream. Intel Archiecture Software Developer's Manual section 7.1.3 specifies that a core serializing instruction such as "cpuid" should be executed on _each_ core before the new instruction is made visible. Failure to do so can lead to unspecified behavior (Intel XMC erratas include General Protection Fault in the list), so we should avoid this at all cost. This problem can affect modified code executed by interrupt handlers after interrupt are re-enabled at the end of stop_machine, because no core serializing instruction is executed between the code modification and the moment interrupts are reenabled. Because stop_machine_text_poke performs the text modification from the first CPU decrementing stop_machine_first, modified code executed in thread context is also affected by this problem. To explain why, we have to split the CPUs in two categories: the CPU that initiates the text modification (calls text_poke_smp) and all the others. The scheduler, executed on all other CPUs after stop_machine, issues an "iret" core serializing instruction, and therefore handles core serialization for all these CPUs. However, the text modification initiator can continue its execution on the same thread and access the modified text without any scheduler call. Given that the CPU that initiates the code modification is not guaranteed to be the one actually performing the code modification, it falls into the XMC errata. Q: Isn't this executed from an IPI handler, which will return with IRET (a serializing instruction) anyway? A: No, now stop_machine uses per-cpu workqueue, so that handler will be executed from worker threads. There is no iret anymore. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> LKML-Reference: <20110303160137.GB1590@Krystal> Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23microblaze: Fix /dev/zero corruption from __clear_user()Steven J. Magnani
commit 6f3946b421395ff853bc0bcdab9c26b50ebbba8f upstream. A userland read of more than PAGE_SIZE bytes from /dev/zero results in (a) not all of the bytes returned being zero, and (b) memory corruption due to zeroing of bytes beyond the user buffer. This is caused by improper constraints on the assembly __clear_user function. The constrints don't indicate to the compiler that the pointer argument is modified. Since the function is inline, this results in double-incrementing of the pointer when __clear_user() is invoked through a multi-page read() of /dev/zero. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23x86, quirk: Fix SB600 revision checkAndreas Herrmann
commit 1d3e09a304e6c4e004ca06356578b171e8735d3c upstream. Commit 7f74f8f28a2bd9db9404f7d364e2097a0c42cc12 (x86 quirk: Fix polarity for IRQ0 pin2 override on SB800 systems) introduced a regression. It removed some SB600 specific code to determine the revision ID without adapting a corresponding revision ID check for SB600. See this mail thread: http://marc.info/?l=linux-kernel&m=129980296006380&w=2 This patch adapts the corresponding check to cover all SB600 revisions. Tested-by: Wang Lei <f3d27b@gmail.com> Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <20110315143137.GD29499@alberich.amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23x86: Emit "mem=nopentium ignored" warning when not supportedKamal Mostafa
commit 9a6d44b9adb777ca9549e88cd55bd8f2673c52a2 upstream. Emit warning when "mem=nopentium" is specified on any arch other than x86_32 (the only that arch supports it). Signed-off-by: Kamal Mostafa <kamal@canonical.com> BugLink: http://bugs.launchpad.net/bugs/553464 Cc: Yinghai Lu <yinghai@kernel.org> Cc: Len Brown <len.brown@intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> LKML-Reference: <1296783486-23033-2-git-send-email-kamal@canonical.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23x86: Fix panic when handling "mem={invalid}" paramKamal Mostafa
commit 77eed821accf5dd962b1f13bed0680e217e49112 upstream. Avoid removing all of memory and panicing when "mem={invalid}" is specified, e.g. mem=blahblah, mem=0, or mem=nopentium (on platforms other than x86_32). Signed-off-by: Kamal Mostafa <kamal@canonical.com> BugLink: http://bugs.launchpad.net/bugs/553464 Cc: Yinghai Lu <yinghai@kernel.org> Cc: Len Brown <len.brown@intel.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> LKML-Reference: <1296783486-23033-1-git-send-email-kamal@canonical.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-14Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: MN10300: atomic_read() should ensure it emits a load MN10300: The SMP_ICACHE_INV_FLUSH_RANGE IPI command does not exist MN10300: Proper use of macros get_user() in the case of incremented pointers
2011-03-14Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (26 commits) MIPS: Alchemy: Fix reset for MTX-1 and XXS1500 MIPS: MTX-1: Make au1000_eth probe all PHY addresses MIPS: Jz4740: Add HAVE_CLK MIPS: Move idle task creation to work queue MIPS, Perf-events: Use unsigned delta for right shift in event update MIPS, Perf-events: Work with the new callchain interface MIPS, Perf-events: Fix event check in validate_event() MIPS, Perf-events: Work with the new PMU interface MIPS, Perf-events: Work with irq_work MIPS: Fix always CONFIG_LOONGSON_UART_BASE=y MIPS: Loongson: Fix potentially wrong string handling MIPS: Fix GCC-4.6 'set but not used' warning in arch/mips/mm/init.c MIPS: Fix GCC-4.6 'set but not used' warning in ieee754int.h MIPS: Remove unused code from arch/mips/kernel/syscall.c MIPS: Fix GCC-4.6 'set but not used' warning in signal*.c MIPS: MSP: Fix MSP71xx bpci interrupt handler return value MIPS: Select R4K timer lib for all MSP platforms MIPS: Loongson: Remove ad-hoc cmdline default MIPS: Clear the correct flag in sysmips(MIPS_FIXADE, ...). MIPS: Add an unreachable return statement to satisfy buggy GCCs. ...
2011-03-14Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: ce4100: Set pci ops via callback instead of module init x86/mm: Fix pgd_lock deadlock x86/mm: Handle mm_fault_error() in kernel space x86: Don't check for BIOS corruption in first 64K when there's no need to
2011-03-14MIPS: Alchemy: Fix reset for MTX-1 and XXS1500Florian Fainelli
Since commit 32fd6901 (MIPS: Alchemy: get rid of common/reset.c) Alchemy-based boards use their own reset function. For MTX-1 and XXS1500, the reset function pokes at the BCSR.SYSTEM_RESET register, but this does not work. According to Bruno Randolf, this was not tested when written. Previously, the generic au1000_restart() routine called the board specific reset function, which for MTX-1 and XXS1500 did not work, but finally made a jump to the reset vector, which really triggers a system restart. Fix reboot for both targets by jumping to the reset vector. Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2093/ Acked-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: MTX-1: Make au1000_eth probe all PHY addressesFlorian Fainelli
When au1000_eth probes the MII bus for PHY address, if we do not set au1000_eth platform data's phy_search_highest_address, the MII probing logic will exit early and will assume a valid PHY is found at address 0. For MTX-1, the PHY is at address 31, and without this patch, the link detection/speed/duplex would not work correctly. CC: stable@kernel.org Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2111/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Jz4740: Add HAVE_CLKMaurus Cuelenaere
Jz4740 supports the clock framework but doesn't have HAVE_CLK defined, so define it! Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2112/ Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Move idle task creation to work queueMaksim Rayskiy
To avoid forking usermode thread when creating an idle task, move fork_idle to a work queue. If kernel starts with maxcpus= option which does not bring all available cpus online at boot time, idle tasks for offline cpus are not created. If later offline cpus are hotplugged through sysfs, __cpu_up is called in the context of the user task, and fork_idle copies its non-zero mm pointer. This causes BUG() in per_cpu_trap_init. This also avoids issues with resource limits of the CPU writing to sysfs, containers, maybe others. Signed-off-by: Maksim Rayskiy <mrayskiy@broadcom.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2070/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Use unsigned delta for right shift in event updateDeng-Cheng Zhu
Leverage the commit for ARM by Will Deacon: - 446a5a8b1eb91a6990e5c8fe29f14e7a95b69132 ARM: 6205/1: perf: ensure counter delta is treated as unsigned Hardware performance counters on ARM are 32-bits wide but atomic64_t variables are used to represent counter data in the hw_perf_event structure. The armpmu_event_update function right-shifts a signed 64-bit delta variable and adds the result to the event count. This can lead to shifting in sign-bits if the MSB of the 32-bit counter value is set. This results in perf output such as: Performance counter stats for 'sleep 20': 18446744073460670464 cycles <-- 0xFFFFFFFFF12A6000 7783773 instructions # 0.000 IPC 465 context-switches 161 page-faults 1172393 branches 20.154242147 seconds time elapsed This patch ensures that the delta value is treated as unsigned so that the right shift sets the upper bits to zero. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: wuzhangjin@gmail.com Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Patchwork: http://patchwork.linux-mips.org/patch/2015/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Work with the new callchain interfaceDeng-Cheng Zhu
This is the MIPS part of the following commits by Frederic Weisbecker: - f72c1a931e311bb7780fee19e41a89ac42cab50e perf: Factorize callchain context handling Store the kernel and user contexts from the generic layer instead of archs, this gathers some repetitive code. - 56962b4449af34070bb1994621ef4f0265eed4d8 perf: Generalize some arch callchain code - Most archs use one callchain buffer per cpu, except x86 that needs to deal with NMIs. Provide a default perf_callchain_buffer() implementation that x86 overrides. - Centralize all the kernel/user regs handling and invoke new arch handlers from there: perf_callchain_user() / perf_callchain_kernel() That avoid all the user_mode(), current->mm checks and so... - Invert some parameters in perf_callchain_*() helpers: entry to the left, regs to the right, following the traditional (dst, src). - 70791ce9ba68a5921c9905ef05d23f62a90bc10c perf: Generalize callchain_store() callchain_store() is the same on every archs, inline it in perf_event.h and rename it to perf_callchain_store() to avoid any collision. This removes repetitive code. - c1a65932fd7216fdc9a0db8bbffe1d47842f862c perf: Drop unappropriate tests on arch callchains Drop the TASK_RUNNING test on user tasks for callchains as this check doesn't seem to make any sense. Also remove the tests for !current that is not supposed to happen and current->pid as this should be handled at the generic level, with exclude_idle attribute. Reported-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: dengcheng.zhu@gmail.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Patchwork: http://patchwork.linux-mips.org/patch/2014/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Fix event check in validate_event()Deng-Cheng Zhu
Ignore events that are in off/error state or belong to a different PMU. This patch originates from the following commit for ARM by Will Deacon: - 65b4711ff513767341aa1915c822de6ec0de65cb ARM: 6352/1: perf: fix event validation The validate_event function in the ARM perf events backend has the following problems: 1.) Events that are disabled count towards the cost. 2.) Events associated with other PMUs [for example, software events or breakpoints] do not count towards the cost, but do fail validation, causing the group to fail. This patch changes validate_event so that it ignores events in the PERF_EVENT_STATE_OFF state or that are scheduled for other PMUs. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: wuzhangjin@gmail.com Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: dengcheng.zhu@gmail.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Cc: ddaney@caviumnetworks.com Patchwork: http://patchwork.linux-mips.org/patch/2013/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Work with the new PMU interfaceDeng-Cheng Zhu
This is the MIPS part of the following commits by Peter Zijlstra: - a4eaf7f14675cb512d69f0c928055e73d0c6d252 perf: Rework the PMU methods Replace pmu::{enable,disable,start,stop,unthrottle} with pmu::{add,del,start,stop}, all of which take a flags argument. The new interface extends the capability to stop a counter while keeping it scheduled on the PMU. We replace the throttled state with the generic stopped state. This also allows us to efficiently stop/start counters over certain code paths (like IRQ handlers). It also allows scheduling a counter without it starting, allowing for a generic frozen state (useful for rotating stopped counters). The stopped state is implemented in two different ways, depending on how the architecture implemented the throttled state: 1) We disable the counter: a) the pmu has per-counter enable bits, we flip that b) we program a NOP event, preserving the counter state 2) We store the counter state and ignore all read/overflow events For MIPSXX, the stopped state is implemented in the way of 1.b as above. - 33696fc0d141bbbcb12f75b69608ea83282e3117 perf: Per PMU disable Changes perf_disable() into perf_pmu_disable(). - 24cd7f54a0d47e1d5b3de29e2456bfbd2d8447b7 perf: Reduce perf_disable() usage Since the current perf_disable() usage is only an optimization, remove it for now. This eases the removal of the __weak hw_perf_enable() interface. - b0a873ebbf87bf38bf70b5e39a7cadc96099fa13 perf: Register PMU implementations Simple registration interface for struct pmu, this provides the infrastructure for removing all the weak functions. - 51b0fe39549a04858001922919ab355dee9bdfcf perf: Deconstify struct pmu sed -ie 's/const struct pmu\>/struct pmu/g' `git grep -l "const struct pmu\>"` Reported-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: a.p.zijlstra@chello.nl To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: wuzhangjin@gmail.com Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: dengcheng.zhu@gmail.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com Cc: ddaney@caviumnetworks.com Patchwork: http://patchwork.linux-mips.org/patch/2012/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Perf-events: Work with irq_workDeng-Cheng Zhu
This is the MIPS part of the following commit by Peter Zijlstra: - e360adbe29241a0194e10e20595360dd7b98a2b3 irq_work: Add generic hardirq context callbacks Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. For MIPSXX, we need to call irq_work_run() at the tail of the perf IRQ handler as described above. Reported-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> To: fweisbec@gmail.com To: will.deacon@arm.com Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: paulus@samba.org Cc: mingo@elte.hu Cc: acme@redhat.com Cc: matt@console-pimps.org Cc: sshtylyov@mvista.com, Patchwork: http://patchwork.linux-mips.org/patch/2011/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix always CONFIG_LOONGSON_UART_BASE=yYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2055/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Loongson: Fix potentially wrong string handlingStefan Weil
This error was reported by cppcheck: arch/mips/loongson/common/machtype.c:56: error: Dangerous usage of 'str' (strncpy doesn't always 0-terminate it) If strncpy copied MACHTYPE_LEN bytes, the destination string str was not terminated. The patch adds one more byte to str and makes sure that this byte is always 0. Signed-off-by: Stefan Weil <weil@mail.berlios.de> Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Arnaud Patard <apatard@mandriva.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/2053/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in arch/mips/mm/init.cDavid Daney
Under some combinations of CONFIG_*, lastpfn in page_is_ram is 'set but not used'. Mark it as __maybe_unused to quiet the warning/error. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2033/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in ieee754int.hDavid Daney
GCC-4.6 can find more unused code than previous versions could. In the case of arch/mips/math-emu/ieee754int.h, the COMPXSP and COMPXDP macros are used in several places, but a couple of them leave xs unused. The easiest thing to do is mark it as __maybe_unused to quiet the warning. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2032/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Remove unused code from arch/mips/kernel/syscall.cDavid Daney
The variable arg3 in _sys_sysmips() is unused. Remove it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2034/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in signal*.cDavid Daney
GCC-4.6 can find more unused code than previous versions could. In the case of protected_restore_fp_context{,32}, the variable tmp is really used. Its use is tricky in that we really care about the side effects of the __put_user() calls. So we must mark tmp with __maybe_unused to quiet the warning. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2035/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: MSP: Fix MSP71xx bpci interrupt handler return valueAnoop P A
Signed-off-by: Anoop P A <anoop.pa@gmail.com> To: Ben Hutchings <ben@decadent.org.uk> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1804/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Select R4K timer lib for all MSP platformsAnoop P A
Signed-off-by: Anoop P A <anoop.pa@gmail.com> To: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1803/ Tested-by: Shane McDonald <mcdonald.shane@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Loongson: Remove ad-hoc cmdline defaultRobert Millan
Loongson builds have an ad-hoc cmdline default of "console=ttyS0,115200 root=/dev/hda1". These settings come from a vendor; I remember builds from Lemote branch requiring a "console=tty" override in order to get a working console. At least on Yeeloong, they're particularly useless: there's no external serial port, and the IDE drive is now recognised as /dev/sda. Signed-off-by: Robert Millan <rmh@gnu.org> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1759/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Clear the correct flag in sysmips(MIPS_FIXADE, ...).Stefan Oberhumer
The sysmips(MIPS_FIXADE, ...) case contains an obvious copy-and-paste error in the handling of the TIF_LOGADE flag. Fix that Patchwork: https://patchwork.linux-mips.org/patch/1997/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS: Add an unreachable return statement to satisfy buggy GCCs.David Daney
It was reported that GCC-4.3.3 (with CodeSourcery extensions) fails without this. Reported-by: Jonas Gorski <jonas.gorski@gmail.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2010/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-14MIPS, Tracing: Fix set_graph_function of function graph tracerWu Zhangjin
trace.func should be set to the recorded ip of the mcount calling site in the __mcount_loc section to filter the function entries configured through the tracing/set_graph_function interface, but before, this is set to the self_ra(the return address of mcount), which has made set_graph_function not work as expected. This fixes it via calculating the right recorded ip in the __mcount_loc section and assign it to trace.func. Reported-by: Zhiping Zhong <xzhong86@163.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2017/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Clean up ftrace_make_nop()Wu Zhangjin
This moves the comments out of ftrace_make_nop() and cleans it. At the same time, a macro MCOUNT_OFFSET_INSNS is defined for sharing with the next patch. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2008/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Clean up prepare_ftrace_return()Wu Zhangjin
The old prepare_ftrace_return() for MIPS is confused and have introduced some problem. This patch cleans up the names of the arguments, variables and related functions. For MIPS, the 2nd argument of prepare_ftrace_return() is not really the 'selfpc' described in ftrace-design.txt but instead it is the self return address. This did break the compatibility of the generic interface but really reduced one unneeded calculation for to get the current function name, the parent return address and the self return address are enough, no need to tranform the self return address to the self address. But set_graph_function of function graph tracer is an exception, it does need the 2nd argument of prepare_ftrace_return() as 'selfpc', for it will use 'selfpc' to match user's configuration of function graph entries, but in reality, it doesn't need the 'selfpc' but the recorded ip address of the mcount calling site in the __mcount_loc section. So, the 2nd argument of prepare_ftrace_return() is not important, the real requirement is the right recorded ip address should be calculated and assign to trace.func, this will be fixed in the next patches. Reported-by: Zhiping Zhong <xzhong86@163.com> Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2007/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Substitute in_kernel_space() for in_module()Wu Zhangjin
The old in_module() may not work in some situations(e.g. when module & kernel are in the same address space when CONFIG_MAPPED_KERNEL=y), The in_kernel_space() is more generic and it is also easy to be implemented via cloning the existing core_kernel_text(), so, replace the in_module() with in_kernel_space(). Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2005/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS, Tracing: Speed up function graph tracerWu Zhangjin
This simply moves the "ip-=4" statement down to the end of the do { ... } while (...); loop, which reduces one unneeded subtration and the subsequent memory loading and comparison. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2006/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MIPS: Replace deprecated spinlock initializationThomas Gleixner
SPIN_LOCK_UNLOCK is deprecated. Use the lockdep capable variant instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2025/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2011-03-14MN10300: atomic_read() should ensure it emits a loadDavid Howells
atomic_read() needs to ensure that it emits a load (which it can do by using ACCESS_ONCE()). Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: David Howells <dhowells@redhat.com>
