commit 207d543f472c1ac9552df79838dc807cbcaa9740 upstream.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 8ef5d844cc3a644ea6f7665932a4307e9fad01fa upstream.
following statement can only change device size from 8-bit(0) to 16-bit(1),
but not vice versa:
regval |= GPMC_CONFIG1_DEVICESIZE(wval);
so as this field has 1 reserved bit, that could be used in future,
just clear both bits and then OR with the desired value
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
commit 8130b9d7b9d858aa04ce67805e8951e3cb6e9b2f upstream.
If we are context switched whilst copying into a thread's
vfp_hard_struct then the partial copy may be corrupted by the VFP
context switching code (see "ARM: vfp: flush thread hwstate before
restoring context from sigframe").
This patch updates the ptrace VFP set code so that the thread state is
flushed before the copy, therefore disabling VFP and preventing
corruption from occurring.
commit 247f4993a5974e6759606c4d380748eecfd273ff upstream.
In a preemptible kernel, vfp_set() can be preempted, causing the
hardware VFP context to be switched while the thread vfp state is
being read and modified. This leads to a race condition which can
cause the thread vfp state to become corrupted if lazy VFP context
save occurs due to preemption in between the time thread->vfpstate
is read and the time the modified state is written back.
This may occur if preemption occurs during the execution of a
ptrace() call which modifies the VFP register state of a thread.
Such instances should be very rare in most realistic scenarios --
none has been reported, so far as I am aware. Only uniprocessor
systems should be affected, since VFP context save is not currently
lazy in SMP kernels.
The problem was introduced by my earlier patch migrating to use
regsets to implement ptrace.
This patch does a vfp_sync_hwstate() before reading
thread->vfpstate, to make sure that the thread's VFP state is not
live in the hardware registers while the registers are modified.
Thanks to Will Deacon for spotting this.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
commit 2af276dfb1722e97b190bd2e646b079a2aa674db upstream.
Following execution of a signal handler, we currently restore the VFP
context from the ucontext in the signal frame. This involves copying
from the user stack into the current thread's vfp_hard_struct and then
flushing the new data out to the hardware registers.
This is problematic when using a preemptible kernel because we could be
context switched whilst updating the vfp_hard_struct. If the current
thread has made use of VFP since the last context switch, the VFP
notifier will copy from the hardware registers into the vfp_hard_struct,
overwriting any data that had been partially copied by the signal code.
Disabling preemption across copy_from_user calls is a terrible idea, so
instead we move the VFP thread flush *before* we update the
vfp_hard_struct. Since the flushing is performed lazily, this has the
effect of disabling VFP and clearing the CPU's VFP state pointer,
therefore preventing the thread from being updated with stale data on
the next context switch.
Tested-by: Peter Maydell <peter.maydell@linaro.org>
[ Upstream commit d00a9dd21bdf7908b70866794c8313ee8a5abd5c ]
Several problems fixed in this patch :
1) Target of the conditional jump in case a divide by 0 is performed
by a bpf is wrong.
2) Must 'generate' the full function prologue/epilogue at pass=0,
or else we can stop too early in pass=1 if the proglen doesnt change.
(if the increase of prologue/epilogue equals decrease of all
instructions length because some jumps are converted to near jumps)
3) Change the wrong length detection at the end of code generation to
issue a more explicit message, no need for a full stack trace.
Reported-by: Phil Oester <kernel@linuxace.com>
commit 612539e81f655f6ac73c7af1da8701c1ee618aee upstream.
On v7, we use the same cache maintenance instructions for data lines
as for unified lines. This was not the case for v6, where HARVARD_CACHE
was defined to indicate the L1 cache topology.
This patch removes the erroneous compile-time check for HARVARD_CACHE in
proc-v7.S, ensuring that we perform I-side invalidation at boot.
Reported-and-Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Catalin Marinas <Catalin.Marinas@arm.com>
commit d65015f7c5c5be9fd3f5e567889c844ba81bdc9c upstream.
This applies ARM errata 764369 for all ux500 platforms.
Signed-off-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
commit 5b68edc91cdc972c46f76f85eded7ffddc3ff5c2 upstream.
We've decided to provide CPU family specific container files
(starting with CPU family 15h). E.g. for family 15h we have to
load microcode_amd_fam15h.bin instead of microcode_amd.bin
Rationale is that starting with family 15h patch size is larger
than 2KB which was hard coded as maximum patch size in various
microcode loaders (not just Linux).
Container files which include patches larger than 2KB cause
different kinds of trouble with such old patch loaders. Thus we
have to ensure that the default container file provides only
patches with size less than 2KB.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: <stable@kernel.org>
Link: http://lkml.kernel.org/r/20120120164412.GD24508@alberich.amd.com
[ documented the naming convention and tidied the code a bit. ]
commit 5a51467b146ab7948d2f6812892eac120a30529c upstream.
uv_gpa_to_soc_phys_ram() was inadvertently ignoring the
shift values. This fix takes the shift into account.
Signed-off-by: Russ Anderson <rja@sgi.com>
Link: http://lkml.kernel.org/r/20120119020753.GA7228@sgi.com
commit c25a785d6647984505fa165b5cd84cfc9a95970b upstream.
If the provided system call number is equal to __NR_syscalls, the
current check will pass and a function pointer just after the system
call table may be called, since sys_call_table is an array with total
size __NR_syscalls.
Whether or not this is a security bug depends on what the compiler puts
immediately after the system call table. It's likely that this won't do
anything bad because there is an additional NULL check on the syscall
entry, but if there happens to be a non-NULL value immediately after the
system call table, this may result in local privilege escalation.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Eugene Teo <eugeneteo@kernel.sg>
commit d059f9fa84a30e04279c6ff615e9e2cf3b260191 upstream.
Move the call to enable_timeouts() forward so that
BAU_MISC_CONTROL is initialized before using it in
calculate_destination_timeout().
Fix the calculation of a BAU destination timeout
for UV2 (in calculate_destination_timeout()).
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Link: http://lkml.kernel.org/r/20120116211848.GB5767@sgi.com
commit 9f10f6a520deb3639fac78d81151a3ade88b4e7f upstream.
In SRAT v1, we had 8bit proximity domain (PXM) fields; SRAT v2 provides
32bits for these. The new fields were reserved before.
According to the ACPI spec, the OS must disregrard reserved fields.
ia64 did handle the PXM fields almost consistently, but depending on
sgi's sn2 platform. This patch leaves the sn2 logic in, but does also
use 16/32 bits for PXM if the SRAT has rev 2 or higher.
The patch also adds __init to the two pxm accessor functions, as they
access __initdata now and are called from an __init function only anyway.
Note that the code only uses 16 bits for the PXM field in the processor
proximity field; the patch does not address this as 16 bits are more than
enough.
Signed-off-by: Kurt Garloff <kurt@garloff.de>
Signed-off-by: Len Brown <len.brown@intel.com>
commit cd298f60a2451a16e0f077404bf69b62ec868733 upstream.
x86/x86-64 was rather inconsistent prior to this patch; it used 8 bits
for the pxm field in cpu_affinity, but 32 bits in mem_affinity.
This patch makes it consistent: Either use 8 bits consistently (SRAT
rev 1 or lower) or 32 bits (SRAT rev 2 or higher).
cc: x86@kernel.org
commit da517a08ac5913cd80ce3507cddd00f2a091b13c upstream.
SGI UV systems print a message during boot:
UV: Found <num> blades
Due to packaging changes, the blade count is not accurate for
on the next generation of the platform. This patch corrects the
count.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Link: http://lkml.kernel.org/r/20120106191900.GA19772@sgi.com
commit 9af0c7a6fa860698d080481f24a342ba74b68982 upstream.
On x86_32 casting the unsigned int result of get_random_int() to
long may result in a negative value. On x86_32 the range of
mmap_rnd() therefore was -255 to 255. The 32bit mode on x86_64
used 0 to 255 as intended.
The bug was introduced by 675a081 ("x86: unify mmap_{32|64}.c")
in January 2008.
Signed-off-by: Ludwig Nussel <ludwig.nussel@suse.de>
Cc: harvey.harrison@gmail.com
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Link: http://lkml.kernel.org/r/201111152246.pAFMklOB028527@wpaz5.hot.corp.google.com
commit 5cf9a4e69c1ff0ccdd1d2b7404f95c0531355274 upstream.
We only need amd_bus.o for AMD systems with PCI. arch/x86/pci/Makefile
already depends on CONFIG_PCI=y, so this patch just adds the dependency
on CONFIG_AMD_NB.
Cc: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 24d25dbfa63c376323096660bfa9ad45a08870ce upstream.
This factors out the AMD native MMCONFIG discovery so we can use it
outside amd_bus.c.
amd_bus.c reads AMD MSRs so it can remove the MMCONFIG area from the
PCI resources. We may also need the MMCONFIG information to work
around BIOS defects in the ACPI MCFG table.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit ae5cd86455381282ece162966183d3f208c6fad7 upstream.
This assures that a _CRS reserved host bridge window or window region is
not used if it is not addressable by the CPU. The new code either trims
the window to exclude the non-addressable portion or totally ignores the
window if the entire window is non-addressable.
The current code has been shown to be problematic with 32-bit non-PAE
kernels on systems where _CRS reserves resources above 4GB.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Reviewed-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Thomas Renninger <trenn@novell.com>
commit e4f387d8db3ba3c2dae4d8bdfe7bb5f4fe1bcb0d upstream.
Unpaired calling of probe_hcall_entry and probe_hcall_exit might happen
as following, which could cause incorrect preempt count.
__trace_hcall_entry => trace_hcall_entry -> probe_hcall_entry =>
get_cpu_var => preempt_disable
__trace_hcall_exit => trace_hcall_exit -> probe_hcall_exit =>
put_cpu_var => preempt_enable
where:
A => B and A -> B means A calls B, but
=> means A will call B through function name, and B will definitely be
called.
-> means A will call B through function pointer, so B might not be
called if the function pointer is not set.
So error happens when only one of probe_hcall_entry and probe_hcall_exit
get called during a hcall.
This patch tries to move the preempt count operations from
probe_hcall_entry and probe_hcall_exit to its callers.
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 37fb9a0231ee43d42d069863bdfd567fca2b61af upstream.
When re-enabling interrupts we have code to handle edge sensitive
decrementers by resetting the decrementer to 1 whenever it is negative.
If interrupts were disabled long enough that the decrementer wrapped to
positive we do nothing. This means interrupts can be delayed for a long
time until it finally goes negative again.
While we hope interrupts are never be disabled long enough for the
decrementer to go positive, we have a very good test team that can
drive any kernel into the ground. The softlockup data we get back
from these fails could be seconds in the future, completely missing
the cause of the lockup.
We already keep track of the timebase of the next event so use that
to work out if we should trigger a decrementer exception.
[ Upstream commit a03ffcf873fe0f2565386ca8ef832144c42e67fa ]
x86 jump instruction size is 2 or 5 bytes (near/long jump), not 2 or 6
bytes.
In case a conditional jump is followed by a long jump, conditional jump
target is one byte past the start of target instruction.
Signed-off-by: Markus Kötter <nepenthesdev@gmail.com>
[ A combination of upstream commits 1d299bc7732c34d85bd43ac1a8745f5a2fed2078 and
e88d2468718b0789b4c33da2f7e1cef2a1eee279 ]
Although we provide a proper way for a debugger to control whether
syscall restart occurs, we run into problems because orig_i0 is not
saved and restored properly.
Luckily we can solve this problem without having to make debuggers
aware of the issue. Across system calls, several registers are
considered volatile and can be safely clobbered.
Therefore we use the pt_regs save area of one of those registers, %g6,
as a place to save and restore orig_i0.
Debuggers transparently will do the right thing because they save and
restore this register already.
[ Upstream commit 2e8ecdc008a16b9a6c4b9628bb64d0d1c05f9f92 ]
[ Upstream commit a52312b88c8103e965979a79a07f6b34af82ca4b ]
Properly return the original destination buffer pointer.
Tested-by: Kjetil Oftedal <oftedal@gmail.com>
[ Upstream commit 21f74d361dfd6a7d0e47574e315f780d8172084a ]
This is setting things up so that we can correct the return
value, so that it properly returns the original destination
buffer pointer.
[ Upstream commit 045b7de9ca0cf09f1adc3efa467f668b89238390 ]
[ Upstream commit 3e37fd3153ac95088a74f5e7c569f7567e9f993a ]
To handle the large physical addresses, just make a simple wrapper
around remap_pfn_range() like MIPS does.
[ Upstream commit 0b64120cceb86e93cb1bda0dc055f13016646907 ]
Some of the sun4v code patching occurs in inline functions visible
to, and usable by, modules.
Therefore we have to patch them up during module load.
[ Upstream commit b1f44e13a525d2ffb7d5afe2273b7169d6f2222e ]
The "(insn & 0x01800000) != 0x01800000" test matches 'restore'
but that is a legitimate place to see the %lo() part of a 32-bit
symbol relocation, particularly in tail calls.
Tested-by: Sergei Trofimovich <slyfox@gentoo.org>
[ Upstream commit 7cc8583372a21d98a23b703ad96cab03180b5030 ]
This silently was working for many years and stopped working on
Niagara-T3 machines.
We need to set the MSIQ to VALID before we can set it's state to IDLE.
On Niagara-T3, setting the state to IDLE first was causing HV_EINVAL
errors. The hypervisor documentation says, rather ambiguously, that
the MSIQ must be "initialized" before one can set the state.
I previously understood this to mean merely that a successful setconf()
operation has been performed on the MSIQ, which we have done at this
point. But it seems to also mean that it has been set VALID too.
commit 55205c916e179e09773d98d290334d319f45ac6b upstream.
This change fixes a linking problem, which happens if oprofile
is selected to be compiled as built-in:
`oprofile_arch_exit' referenced in section `.init.text' of
arch/arm/oprofile/built-in.o: defined in discarded section
`.exit.text' of arch/arm/oprofile/built-in.o
The problem is appeared after commit 87121ca504, which
introduced oprofile_arch_exit() calls from __init function. Note
that the aforementioned commit has been backported to stable
branches, and the problem is known to be reproduced at least
with 3.0.13 and 3.1.5 kernels.
Signed-off-by: Vladimir Zapolskiy <vladimir.zapolskiy@nokia.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111222151540.GB16765@erda.amd.com
commit 5776ac2eb33164c77cdb4d2b48feee15616eaba3 upstream.
According to imx pwm RM, the real period value should be
PERIOD value in PWMPR plus 2.
PWMO (Hz) = PCLK(Hz) / (period +2)
Signed-off-by: Jason Chen <jason.chen@linaro.org>
commit 913050b91eb94f194392dd797b1ff3779f606ac0 upstream.
If oprofilefs_ulong_from_user() is called with count equals
zero, *val remains unchanged. Depending on the implementation it
might be uninitialized.
Change oprofilefs_ulong_from_user()'s interface to return count
on success. Thus, we are able to return early if count equals
zero which avoids using *val uninitialized. Fixing all users of
oprofilefs_ulong_ from_user().
This follows write syscall implementation when count is zero:
"If count is zero ... [and if] no errors are detected, 0 will be
returned without causing any other effect." (man 2 write)
Reported-By: Mike Waychison <mikew@google.com>
Link: http://lkml.kernel.org/r/20111219153830.GH16765@erda.amd.com
commit c0d96aed8c6dd925afe9ea35491a0cd458642a86 upstream.
commit e5fe29c7198a1f6616286dfc8602a69da165cb3f upstream.
Commit 10299e2e4e3ed3b16503d4e04edd48b33083f4e2 (ARM: RX-51:
Enable isp1704 power on/off) added power management for isp1704.
However, the transceiver should be powered on by default,
otherwise USB doesn't work at all for networking during
boot.
All kernels after v3.0 are affected.
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
Reviewed-by: Sebastian Reichel <sre@debian.org>
[tony@atomide.com: updated comments]
commit d3db728125c4470a2d061ac10fa7395e18237263 upstream.
d312ae878b6a "xen: use maximum reservation to limit amount of usable RAM"
clamped the total amount of RAM to the current maximum reservation. This is
correct for dom0 but is not correct for guest domains. In order to boot a guest
"pre-ballooned" (e.g. with memory=1G but maxmem=2G) in order to allow for
future memory expansion the guest must derive max_pfn from the e820 provided by
the toolstack and not the current maximum reservation (which can reflect only
the current maximum, not the guest lifetime max). The existing algorithm
already behaves this correctly if we do not artificially limit the maximum
number of pages for the guest case.
For a guest booted with maxmem=512, memory=128 this results in:
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] Xen: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] Xen: 00000000000a0000 - 0000000000100000 (reserved)
-[ 0.000000] Xen: 0000000000100000 - 0000000008100000 (usable)
-[ 0.000000] Xen: 0000000008100000 - 0000000020800000 (unusable)
+[ 0.000000] Xen: 0000000000100000 - 0000000020800000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI not present or invalid.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
-[ 0.000000] last_pfn = 0x8100 max_arch_pfn = 0x1000000
+[ 0.000000] last_pfn = 0x20800 max_arch_pfn = 0x1000000
[ 0.000000] initial memory mapped : 0 - 027ff000
[ 0.000000] Base memory trampoline at [c009f000] 9f000 size 4096
-[ 0.000000] init_memory_mapping: 0000000000000000-0000000008100000
-[ 0.000000] 0000000000 - 0008100000 page 4k
-[ 0.000000] kernel direct mapping tables up to 8100000 @ 27bb000-27ff000
+[ 0.000000] init_memory_mapping: 0000000000000000-0000000020800000
+[ 0.000000] 0000000000 - 0020800000 page 4k
+[ 0.000000] kernel direct mapping tables up to 20800000 @ 26f8000-27ff000
[ 0.000000] xen: setting RW the range 27e8000 - 27ff000
[ 0.000000] 0MB HIGHMEM available.
-[ 0.000000] 129MB LOWMEM available.
-[ 0.000000] mapped low ram: 0 - 08100000
-[ 0.000000] low ram: 0 - 08100000
+[ 0.000000] 520MB LOWMEM available.
+[ 0.000000] mapped low ram: 0 - 20800000
+[ 0.000000] low ram: 0 - 20800000
With this change "xl mem-set <domain> 512M" will successfully increase the
guest RAM (by reducing the balloon).
There is no change for dom0.
Reported-and-Tested-by: George Shuklin <george.shuklin@gmail.com>
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
commit 2ded6e6a94c98ea453a156748cb7fabaf39a76b9 upstream.
When HPET is operating in RTC mode, the TN_ENABLE bit on timer1
controls whether the HPET or the RTC delivers interrupts to irq8. When
the system goes into suspend, the RTC driver sends a signal to the
HPET driver so that the HPET releases control of irq8, allowing the
RTC to wake the system from suspend. The switchover is accomplished by
a write to the HPET configuration registers which currently only
occurs while servicing the HPET interrupt.
On some systems, I have seen the system suspend before an HPET
interrupt occurs, preventing the write to the HPET configuration
register and leaving the HPET in control of the irq8. As the HPET is
not active during suspend, it does not generate a wake signal and RTC
alarms do not work.
This patch forces the HPET driver to immediately transfer control of
the irq8 channel to the RTC instead of waiting until the next
interrupt event.
Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com>
Link: http://lkml.kernel.org/r/20111118153306.GB16319@alberich.amd.com
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit b6999b19120931ede364fa3b685e698a61fed31d upstream.
With the 3.2-rc kernel, IOMMU 2M pages in KVM works. But when I tried
to use IOMMU 1GB pages in KVM, I encountered an oops and the 1GB page
failed to be used.
The root cause is that 1GB page allocation calls gup_huge_pud() while 2M
page calls gup_huge_pmd. If compound pages are used and the page is a
tail page, gup_huge_pmd() increases _mapcount to record tail page are
mapped while gup_huge_pud does not do that.
So when the mapped page is relesed, it will result in kernel oops
because the page is not marked mapped.
This patch add tail process for compound page in 1GB huge page which
keeps the same process as 2M page.
Reproduce like:
1. Add grub boot option: hugepagesz=1G hugepages=8
2. mount -t hugetlbfs -o pagesize=1G hugetlbfs /dev/hugepages
3. qemu-kvm -m 2048 -hda os-kvm.img -cpu kvm64 -smp 4 -mem-path /dev/hugepages
-net none -device pci-assign,host=07:00.1
kernel BUG at mm/swap.c:114!
invalid opcode: 0000 [#1] SMP
Call Trace:
put_page+0x15/0x37
kvm_release_pfn_clean+0x31/0x36
kvm_iommu_put_pages+0x94/0xb1
kvm_iommu_unmap_memslots+0x80/0xb6
kvm_assign_device+0xba/0x117
kvm_vm_ioctl_assigned_device+0x301/0xa47
kvm_vm_ioctl+0x36c/0x3a2
do_vfs_ioctl+0x49e/0x4e4
sys_ioctl+0x5a/0x7c
system_call_fastpath+0x16/0x1b
RIP put_compound_page+0xd4/0x168
Signed-off-by: Youquan Song <youquan.song@intel.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
commit 83713fc9373be2e943f82e9d36213708c6b0050e upstream.
The function setup_vpif_input_channel_mode() used the VSCLKDIS register
instead of VIDCLKCTL. This meant that when in HD mode videoport channel 0
used a different clock from channel 1.
Clearly a copy-and-paste error.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Manjunath Hadli <manjunath.hadli@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit 1808958d27b1250295f01dff4997d8a8814adaab upstream.
The conid is supposed to be t0/t1/t2_clk.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 11357be9246c7d1acf9b37ad54a18b29bbb734be upstream.
Adding the machine_is_* line was forgotten when converting mach-stmp378x to
mach-mxs.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
commit f1b21c525693b0159aed83b5871f2d0f077f208e upstream.
On OMAP-L138 platform, EDMA event queue 0 should be used for audio
transfers so that they are not starved by video data moving on event queue 1.
Commit 48519f0ae03bc7e86b3dc93e56f1334d53803770 (ASoC: davinci: let platform
data define edma queue numbers) had a side-effect of changing this behavior
by making the driver actually honor the platform data passed.
Fix this now by passing event queue 0 as the queue to be used for audio
transfers.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
commit b934069c991355d27a053a932591c77960f4e414 upstream.
The last breaking event address is a read-only value, the regset misses the
.set function. If a PTRACE_SETREGSET is done for NT_S390_LAST_BREAK we
get an oops due to a branch to zero:
Kernel BUG at 0000000000000002 verbose debug info unavailable
illegal operation: 0001 #1 SMP
Call Trace:
(<0000000000158294> ptrace_regset+0x184/0x188)
<00000000001595b6> ptrace_request+0x37a/0x4fc
<0000000000109a78> arch_ptrace+0x108/0x1fc
<00000000001590d6> SyS_ptrace+0xaa/0x12c
<00000000005c7a42> sysc_noemu+0x16/0x1c
<000003fffd5ec10c> 0x3fffd5ec10c
Last Breaking-Event-Address:
<0000000000158242> ptrace_regset+0x132/0x188
Add a nop .set function to prevent the branch to zero.
commit 97f7f8189fe54e3cfe324ef9ad35064f3d2d3bff upstream.
If oprofile uses the nmi timer interrupt there is a crash while
unloading the module. The bug can be triggered with oprofile build as
module and kernel parameter nolapic set. This patch fixes this.
oprofile: using NMI timer interrupt.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
PGD 42dbca067 PUD 41da6a067 PMD 0
Oops: 0002 [#1] PREEMPT SMP
CPU 5
Modules linked in: oprofile(-) [last unloaded: oprofile]
Pid: 2518, comm: modprobe Not tainted 3.1.0-rc7-00019-gb2fb49d #19 Advanced Micro Device Anaheim/Anaheim
RIP: 0010:[<ffffffff8123c226>] [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP: 0018:ffff88041ef71e98 EFLAGS: 00010296
RAX: 0000000000000000 RBX: ffffffffa0017100 RCX: dead000000200200
RDX: 0000000000000000 RSI: dead000000100100 RDI: ffffffff8178c620
RBP: ffff88041ef71ea8 R08: 0000000000000001 R09: 0000000000000082
R10: 0000000000000000 R11: ffff88041ef71de8 R12: 0000000000000080
R13: fffffffffffffff5 R14: 0000000000000001 R15: 0000000000610210
FS: 00007fc902f20700(0000) GS:ffff88042fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000008 CR3: 000000041cdb6000 CR4: 00000000000006e0
Process modprobe (pid: 2518, threadinfo ffff88041ef70000, task ffff88041d348040)
Stack:
ffff88041ef71eb8 ffffffffa0017790 ffff88041ef71eb8 ffffffffa0013532
ffff88041ef71ec8 ffffffffa00132d6 ffff88041ef71ed8 ffffffffa00159b2
ffff88041ef71f78 ffffffff81073115 656c69666f72706f 0000000000610200
Call Trace:
[<ffffffffa0013532>] op_nmi_exit+0x15/0x17 [oprofile]
[<ffffffffa00132d6>] oprofile_arch_exit+0xe/0x10 [oprofile]
[<ffffffffa00159b2>] oprofile_exit+0x1e/0x20 [oprofile]
[<ffffffff81073115>] sys_delete_module+0x1c3/0x22f
[<ffffffff811bf09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff8148070b>] system_call_fastpath+0x16/0x1b
Code: 20 c6 78 81 e8 c5 cc 23 00 48 8b 13 48 8b 43 08 48 be 00 01 10 00 00 00 ad de 48 b9 00 02 20 00 00 00 ad de 48 c7 c7 20 c6 78 81
89 42 08 48 89 10 48 89 33 48 89 4b 08 e8 a6 c0 23 00 5a 5b
RIP [<ffffffff8123c226>] unregister_syscore_ops+0x41/0x58
RSP <ffff88041ef71e98>
---[ end trace 43a541a52956b7b0 ]---
commit 57d1c0c03c6b48b2b96870d831b9ce6b917f53ac upstream.
Masami spotted that we always try to decode the instruction stream as
64bit instructions when running a 64bit kernel, this doesn't work for
ia32-compat proglets.
Use TIF_IA32 to detect if we need to use the 32bit instruction
decoder.
Reported-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
regardless of lazy_mmu mode
commit 2cd1c8d4dc7ecca9e9431e2dabe41ae9c7d89e51 upstream.
Fix an outstanding issue that has been reported since 2.6.37.
Under a heavy loaded machine processing "fork()" calls could
crash with:
BUG: unable to handle kernel paging request at f573fc8c
IP: [<c01abc54>] swap_count_continued+0x104/0x180
*pdpt = 000000002a3b9027 *pde = 0000000001bed067 *pte = 0000000000000000 Oops: 0000 [#1] SMP
Modules linked in:
Pid: 1638, comm: apache2 Not tainted 3.0.4-linode37 #1
EIP: 0061:[<c01abc54>] EFLAGS: 00210246 CPU: 3
EIP is at swap_count_continued+0x104/0x180
.. snip..
Call Trace:
[<c01ac222>] ? __swap_duplicate+0xc2/0x160
[<c01040f7>] ? pte_mfn_to_pfn+0x87/0xe0
[<c01ac2e4>] ? swap_duplicate+0x14/0x40
[<c01a0a6b>] ? copy_pte_range+0x45b/0x500
[<c01a0ca5>] ? copy_page_range+0x195/0x200
[<c01328c6>] ? dup_mmap+0x1c6/0x2c0
[<c0132cf8>] ? dup_mm+0xa8/0x130
[<c013376a>] ? copy_process+0x98a/0xb30
[<c013395f>] ? do_fork+0x4f/0x280
[<c01573b3>] ? getnstimeofday+0x43/0x100
[<c010f770>] ? sys_clone+0x30/0x40
[<c06c048d>] ? ptregs_clone+0x15/0x48
[<c06bfb71>] ? syscall_call+0x7/0xb
The problem is that in copy_page_range() we turn lazy mode on,
and then in swap_entry_free() we call swap_count_continued()
which ends up in:
map = kmap_atomic(page, KM_USER0) + offset;
and then later we touch *map.
Since we are running in batched mode (lazy) we don't actually
set up the PTE mappings and the kmap_atomic is not done
synchronously and ends up trying to dereference a page that has
not been set.
Looking at kmap_atomic_prot_pfn(), it uses
'arch_flush_lazy_mmu_mode' and doing the same in
kmap_atomic_prot() and __kunmap_atomic() makes the problem go
away.
Interestingly, commit b8bcfe997e4615 ("x86/paravirt: remove lazy
mode in interrupts") removed part of this to fix an interrupt
issue - but it went to far and did not consider this scenario.
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 1ef03890969932e9359b9a4c658f7f87771910ac upstream.
Looks like on some Acer Aspire 1s with older bioses, reboot via bios
fails. It works on my machine, (with BIOS version 0.3310) but
not on some others (BIOS version 0.3309).
There's a log of problems at:
https://bbs.archlinux.org/viewtopic.php?id=124136
This patch adds a different callback to the reboot quirk table,
to allow rebooting via keybaord controller.
Reported-by: Uroš Vampl <mobile.leecher@gmail.com>
Tested-by: Vasily Khoruzhick <anarsoul@gmail.com>
Signed-off-by: Peter Chubb <peter.chubb@nicta.com.au>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/1323093233-9481-1-git-send-email-anarsoul@gmail.com
commit 9e6866686bdf2dcf3aeb0838076237ede532dcc8 upstream.
In commit f8924e770e04 ("x86: unify mp_bus_info"), the 32-bit
and 64-bit versions of MP_bus_info were rearranged to match each
other better. Unfortunately it introduced a regression: prior
to that change we used to always set the mp_bus_not_pci bit,
then clear it if we found a PCI bus. After it, we set
mp_bus_not_pci for ISA buses, clear it for PCI buses, and leave
it alone otherwise.
In the cases of ISA and PCI, there's not much difference. But
ISA is not the only non-PCI bus, so it's better to always set
mp_bus_not_pci and clear it only for PCI.
Without this change, Dan's Dell PowerEdge 4200 panics on boot
with a log indicating interrupt routing trouble unless the
"noapic" option is supplied. With this change, the machine
boots reliably without "noapic".
Fixes http://bugs.debian.org/586494
Reported-bisected-and-tested-by: Dan McGrath <troubledaemon@gmail.com>
Cc: Dan McGrath <troubledaemon@gmail.com>
Cc: Alexey Starikovskiy <aystarik@gmail.com>
[jrnieder@gmail.com: clarified commit message]
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Link: http://lkml.kernel.org/r/20111122215000.GA9151@elie.hsd1.il.comcast.net
commit 4cecf6d401a01d054afc1e5f605bcbfe553cb9b9 upstream.
(Added the missing signed-off-by line)
In hundreds of days, the __cycles_2_ns calculation in sched_clock
has an overflow. cyc * per_cpu(cyc2ns, cpu) exceeds 64 bits, causing
the final value to become zero. We can solve this without losing
any precision.
We can decompose TSC into quotient and remainder of division by the
scale factor, and then use this to convert TSC into nanoseconds.
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: John Stultz <johnstul@us.ibm.com>
Reviewed-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20111115221121.7262.88871.stgit@dungbeetle.mtv.corp.google.com
