commit 1dedefd1a066a795a87afca9c0236e1a94de9bf6 upstream.
Some extra CPU features such as ARAT is needed in early boot so
that x86_init function pointers can be set up properly.
http://lkml.org/lkml/2010/5/18/519
At start_kernel() level, this patch moves init_scattered_cpuid_features()
from check_bugs() to setup_arch() -> early_cpu_init() which is earlier than
platform specific x86_init layer setup. Suggested by HPA.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
LKML-Reference: <1274295685-6774-2-git-send-email-jacob.jun.pan@linux.intel.com>
commit 54a834043314c257210db2a9d59f8cc605571639 upstream.
In f761622e59433130bc33ad086ce219feee9eb961 we changed
early_setup_secondary so it's called using the proper kernel stack
rather than the emergency one.
Unfortunately, this stack pointer can't be used when translation is off
on PHYP as this stack pointer might be outside the RMO. This results in
the following on all non zero cpus:
cpu 0x1: Vector: 300 (Data Access) at [c00000001639fd10]
pc: 000000000001c50c
lr: 000000000000821c
sp: c00000001639ff90
msr: 8000000000001000
dar: c00000001639ffa0
dsisr: 42000000
current = 0xc000000016393540
paca = 0xc000000006e00200
pid = 0, comm = swapper
The original patch was only tested on bare metal system, so it never
caught this problem.
This changes __secondary_start so that we calculate the new stack
pointer but only start using it after we've called early_setup_secondary.
With this patch, the above problem goes away.
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit f761622e59433130bc33ad086ce219feee9eb961 upstream.
As early setup calls down to slb_initialize(), we must have kstack
initialised before checking "should we add a bolted SLB entry for our kstack?"
Failing to do so means stack access requires an SLB miss exception to refill
an entry dynamically, if the stack isn't accessible via SLB(0) (kernel text
& static data). It's not always allowable to take such a miss, and
intermittent crashes will result.
Primary CPUs don't have this issue; an SLB entry is not bolted for their
stack anyway (as that lives within SLB(0)). This patch therefore only
affects the init of secondaries.
Signed-off-by: Matt Evans <matt@ozlabs.org>
commit 6dcbfe4f0b4e17e289d56fa534b7ce5a6b7f63a3 upstream.
This fixes possible cases of not collecting valid error info in
the MCE error thresholding groups on F10h hardware.
The current code contains a subtle problem of checking only the
Valid bit of MSR0000_0413 (which is MC4_MISC0 - DRAM
thresholding group) in its first iteration and breaking out if
the bit is cleared.
But (!), this MSR contains an offset value, BlkPtr[31:24], which
points to the remaining MSRs in this thresholding group which
might contain valid information too. But if we bail out only
after we checked the valid bit in the first MSR and not the
block pointer too, we miss that other information.
The thing is, MC4_MISC0[BlkPtr] is not predicated on
MCi_STATUS[MiscV] or MC4_MISC0[Valid] and should be checked
prior to iterating over the MCI_MISCj thresholding group,
irrespective of the MC4_MISC0[Valid] setting.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit 47526903feb52f4c26a6350370bdf74e337fcdb1 upstream.
Commit f81f2f7c (ubd: drop unnecessary rq->sector manipulation)
dropped request->sector manipulation in preparation for global request
handling cleanup; unfortunately, it incorrectly assumed that the
updated sector wasn't being used.
ubd tries to issue as many requests as possible to io_thread. When
issuing fails due to memory pressure or other reasons, the device is
put on the restart list and issuing stops. On IO completion, devices
on the restart list are scanned and IO issuing is restarted.
ubd issues IOs sg-by-sg and issuing can be stopped in the middle of a
request, so each device on the restart queue needs to remember where
to restart in its current request. ubd needs to keep track of the
issue position itself because,
* blk_rq_pos(req) is now updated by the block layer to keep track of
_completion_ position.
* Multiple io_req's for the current request may be in flight, so it's
difficult to tell where blk_rq_pos(req) currently is.
Add ubd->rq_pos to keep track of the issue position and use it to
correctly restart io_req issue.
Reported-by: Richard Weinberger <richard@nod.at>
Tested-by: Richard Weinberger <richard@nod.at>
Tested-by: Chris Frey <cdfrey@foursquare.net>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 1cf180c94e9166cda083ff65333883ab3648e852 upstream.
free_irq_cfg() is not freeing the cpumask_vars in irq_cfg. Fixing this
triggers a use after free caused by the fact that copying struct
irq_cfg is done with memcpy, which copies the pointer not the cpumask.
Fix both places.
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
LKML-Reference: <alpine.LFD.2.00.1009282052570.2416@localhost6.localdomain6>
commit 021989622810b02aab4b24f91e1f5ada2b654579 upstream.
create_irq() returns -1 if the interrupt allocation failed, but the
code checks for irq == 0.
Use create_irq_nr() instead.
Cc: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <alpine.LFD.2.00.1009282310360.2416@localhost6.localdomain6>
commit 258af47479980d8238a04568b94a4e55aa1cb537 upstream.
The guest can use the paravirt clock in kvmclock.c which is used
by sched_clock(), which in turn is used by the tracing mechanism
for timestamps, which leads to infinite recursion.
Disable mcount/tracing for kvmclock.o.
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Avi Kivity <avi@redhat.com>
commit 9ecd4e1689208afe9b059a5ce1333acb2f42c4d2 upstream.
When using a paravirt clock, pvclock.c can be used by sched_clock(),
which in turn is used by the tracing mechanism for timestamps,
Disable mcount/tracing for pvclock.o.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <4C9A9A3F.4040201@goop.org>
commit 4c894f47bb49284008073d351c0ddaac8860864e upstream.
This patch adds a workaround for an IOMMU BIOS problem to
the AMD IOMMU driver. The result of the bug is that the
IOMMU does not execute commands anymore when the system
comes out of the S3 state resulting in system failure. The
bug in the BIOS is that is does not restore certain hardware
specific registers correctly. This workaround reads out the
contents of these registers at boot time and restores them
on resume from S3. The workaround is limited to the specific
IOMMU chipset where this problem occurs.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 04e0463e088b41060c08c255eb0d3278a504f094 upstream.
In the __unmap_single function the dma_addr is rounded down
to a page boundary before the dma pages are unmapped. The
address is later also used to flush the TLB entries for that
mapping. But without the offset into the dma page the amount
of pages to flush might be miscalculated in the TLB flushing
path. This patch fixes this bug by using the original
address to flush the TLB.
commit e9bf51971157e367aabfc111a8219db010f69cd4 upstream.
This patch moves the setting of the configuration and
feature flags out out the acpi table parsing path and moves
it into the iommu-enable path. This is needed to reliably
fix resume-from-s3.
commit bb7ab785ad05a97a2c9ffb3a06547ed39f3133e8 upstream.
This patch adds CPU type detection for dunnington processor (Family 6
/ Model 29) to be identified as core 2 family cpu type (wikipedia
source).
I tested oprofile on Intel(R) Xeon(R) CPU E7440 reporting itself as
model 29, and it runs without an issue.
Spec:
http://www.intel.com/Assets/en_US/PDF/specupdate/320336.pdf
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit d900329e20f4476db6461752accebcf7935a8055 upstream.
After uncapping the CPUID level, we need to also re-run the CPU
feature detection code.
This resolves kernel bugzilla 16322.
Reported-by: boris64 <bugzilla.kernel.org@boris64.net>
LKML-Reference: <tip-@git.kernel.org>
commit 113fc5a6e8c2288619ff7e8187a6f556b7e0d372 upstream.
[ Backport to .32 by Tomáš Janoušek <tomi@nomi.cz> ]
xchg() and cmpxchg() modify their memory operands, not merely read
them. For some versions of gcc the "memory" clobber has apparently
dealt with the situation, but not for all.
Originally-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Glauber Costa <glommer@redhat.com>
Cc: Peter Palfrader <peter@palfrader.org>
Cc: Greg KH <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Zachary Amsden <zamsden@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
LKML-Reference: <4C4F7277.8050306@zytor.com>
commit 3e073367a57d41e506f20aebb98e308387ce3090 upstream.
When compiling alpha generic build get errors such as:
arch/alpha/kernel/err_marvel.c: In function ‘marvel_print_err_cyc’:
arch/alpha/kernel/err_marvel.c:119: error: format ‘%ld’ expects type ‘long int’, but argument 6 has type ‘u64’
Replaced a number of %ld format specifiers with %lld since u64
is unsigned long long.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
Signed-off-by: Matt Turner <mattst88@gmail.com>
commit 3d45285dd1ff4d4a1361b95e2d6508579a4402b5 upstream.
The M3 workaround needs to cmpare the region and VPN2 fields only.
commit 5808184f1b2fe06ef8a54a2b7fb1596d58098acf upstream.
This is needed for the fix of the M3 workaround.
[Backported by Aurelien Jarno <aurelien@aurel32.net>]
commit 8faf2e6c201d95b780cd3b4674b7a55ede6dcbbb upstream.
Several MIPS platforms don't set pci_controller::io_map_base for their
PCI bridges. This results in a panic in pci_iomap(). (The panic is
conditional on CONFIG_PCI_DOMAINS, but that is now enabled for all PCI
MIPS systems.)
Cc: linux-mips@linux-mips.org
Cc: Martin Michlmayr <tbm@cyrius.com>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: 584784@bugs.debian.org
Patchwork: https://patchwork.linux-mips.org/patch/1377/
commit f2a68272d799bf4092443357142f63b74f7669a1 upstream.
For 64-bit, we must use DADDU and DSUBU.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1483/
commit 8d2602e0778299e2d6084f03086b716d6e7a1e1e upstream.
Reported-by: Dan Liang <dan.liang@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 2d2b6901649a62977452be85df53eda2412def24 upstream.
Tony's fix (f574c843191728d9407b766a027f779dcd27b272) has a small bug,
it incorrectly uses "r3" as a scratch register in the first of the two
unlock paths ... it is also inefficient. Optimize the fast path again.
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit f574c843191728d9407b766a027f779dcd27b272 upstream.
When ia64 converted to using ticket locks, an inline implementation
of trylock/unlock in fsys.S was missed. This was not noticed because
in most circumstances it simply resulted in using the slow path because
the siglock was apparently not available (under old spinlock rules).
Problems occur when the ticket spinlock has value 0x0 (when first
initialised, or when it wraps around). At this point the fsys.S
code acquires the lock (changing the 0x0 to 0x1. If another process
attempts to get the lock at this point, it will change the value from
0x1 to 0x2 (using new ticket lock rules). Then the fsys.S code will
free the lock using old spinlock rules by writing 0x0 to it. From
here a variety of bad things can happen.
commit c33f543d320843e1732534c3931da4bbd18e6c14 upstream.
This patch adds CPU type detection for the Intel Celeron 540, which is
part of the Core 2 family according to Wikipedia; the family and ID pair
is absent from the Volume 3B table referenced in the source code
comments. I have tested this patch on an Intel Celeron 540 machine
reporting itself as Family 6 Model 22, and OProfile runs on the machine
without issue.
Spec:
http://download.intel.com/design/mobile/SPECUPDT/317667.pdf
Signed-off-by: Patrick Simmons <linuxrocks123@netscape.net>
[ Upstream commit 25edd6946a1d74e5e77813c2324a0908c68bcf9e ]
This is based upon a report by Meelis Roos showing that it's possible
that we'll try to fetch a property that is 32K in size with some
devices. With the current fixed 3K buffer we use for moving data in
and out of the firmware during PROM calls, that simply won't work.
In fact, it will scramble random kernel data during bootup.
The reasoning behind the temporary buffer is entirely historical. It
used to be the case that we had problems referencing dynamic kernel
memory (including the stack) early in the boot process before we
explicitly told the firwmare to switch us over to the kernel trap
table.
So what we did was always give the firmware buffers that were locked
into the main kernel image.
But we no longer have problems like that, so get rid of all of this
indirect bounce buffering.
Besides fixing Meelis's bug, this also makes the kernel data about 3K
smaller.
It was also discovered during these conversions that the
implementation of prom_retain() was completely wrong, so that was
fixed here as well. Currently that interface is not in use.
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
[ Upstream commit 1bff4dbb79a2bc0ee4881c8ea6a4fbed64ea6309 ]
commit 653d48b22166db2d8b1515ebe6f9f0f7c95dfc86 upstream.
If a signal hits us outside of a syscall and another gets delivered
when we are in sigreturn (e.g. because it had been in sa_mask for
the first one and got sent to us while we'd been in the first handler),
we have a chance of returning from the second handler to location one
insn prior to where we ought to return. If r0 happens to contain -513
(-ERESTARTNOINTR), sigreturn will get confused into doing restart
syscall song and dance.
Incredible joy to debug, since it manifests as random, infrequent and
very hard to reproduce double execution of instructions in userland
code...
The fix is simple - mark it "don't bother with restarts" in wrapper,
i.e. set r8 to 0 in sys_sigreturn and sys_rt_sigreturn wrappers,
suppressing the syscall restart handling on return from these guys.
They can't legitimately return a restart-worthy error anyway.
Testcase:
#include <unistd.h>
#include <signal.h>
#include <stdlib.h>
#include <sys/time.h>
#include <errno.h>
void f(int n)
__asm__ __volatile__(
"ldr r0, [%0]\n"
"b 1f\n"
"b 2f\n"
"1:b .\n"
"2:\n" : : "r"(&n));
void handler1(int sig) { }
void handler2(int sig) { raise(1); }
void handler3(int sig) { exit(0); }
main()
struct sigaction s = {.sa_handler = handler2};
struct itimerval t1 = { .it_value = {1} };
struct itimerval t2 = { .it_value = {2} };
signal(1, handler1);
sigemptyset(&s.sa_mask);
sigaddset(&s.sa_mask, 1);
sigaction(SIGALRM, &s, NULL);
signal(SIGVTALRM, handler3);
setitimer(ITIMER_REAL, &t1, NULL);
setitimer(ITIMER_VIRTUAL, &t2, NULL);
f(-513); /* -ERESTARTNOINTR */
write(1, "buggered\n", 9);
return 1;
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit eefdca043e8391dcd719711716492063030b55ac upstream.
In commit d4d6715, we reopened an old hole for a 64-bit ptracer touching a
32-bit tracee in system call entry. A %rax value set via ptrace at the
entry tracing stop gets used whole as a 32-bit syscall number, while we
only check the low 32 bits for validity.
Fix it by truncating %rax back to 32 bits after syscall_trace_enter,
in addition to testing the full 64 bits as has already been added.
Reported-by: Ben Hawkes <hawkes@sota.gen.nz>
Signed-off-by: Roland McGrath <roland@redhat.com>
commit c41d68a513c71e35a14f66d71782d27a79a81ea6 upstream.
compat_alloc_user_space() expects the caller to independently call
access_ok() to verify the returned area. A missing call could
introduce problems on some architectures.
This patch incorporates the access_ok() check into
compat_alloc_user_space() and also adds a sanity check on the length.
The existing compat_alloc_user_space() implementations are renamed
arch_compat_alloc_user_space() and are used as part of the
implementation of the new global function.
This patch assumes NULL will cause __get_user()/__put_user() to either
fail or access userspace on all architectures. This should be
followed by checking the return value of compat_access_user_space()
for NULL in the callers, at which time the access_ok() in the callers
can also be removed.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
commit 36d001c70d8a0144ac1d038f6876c484849a74de upstream.
On 64 bits, we always, by necessity, jump through the system call
table via %rax. For 32-bit system calls, in theory the system call
number is stored in %eax, and the code was testing %eax for a valid
system call number. At one point we loaded the stored value back from
the stack to enforce zero-extension, but that was removed in checkin
d4d67150165df8bf1cc05e532f6efca96f907cab. An actual 32-bit process
will not be able to introduce a non-zero-extended number, but it can
happen via ptrace.
Instead of re-introducing the zero-extension, test what we are
actually going to use, i.e. %rax. This only adds a handful of REX
prefixes to the code.
Cc: Roland McGrath <roland@redhat.com>
commit 55496c896b8a695140045099d4e0175cf09d4eae upstream.
Doh, a real life genuine preemption leak..
This caused a suspend failure.
Reported-bisected-and-tested-by-the-invaluable: Jeff Chua <jeff.chua.linux@gmail.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Nico Schottelius <nico-linux-20100709@schottelius.org>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Florian Pritz <flo@xssn.at>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Len Brown <lenb@kernel.org>
sleep states
LKML-Reference: <1284150773.402.122.camel@laptop>
commit 269f45c25028c75fe10e6d9be86e7202ab461fbc upstream.
The use of the return value of init_sysfs() with commit
10f0412 oprofile, x86: fix init_sysfs error handling
discovered the following build error for !CONFIG_PM:
.../linux/arch/x86/oprofile/nmi_int.c: In function ‘op_nmi_init’:
.../linux/arch/x86/oprofile/nmi_int.c:784: error: expected expression before ‘do’
make[2]: *** [arch/x86/oprofile/nmi_int.o] Error 1
make[1]: *** [arch/x86/oprofile] Error 2
This patch fixes this.
Reported-by: Ingo Molnar <mingo@elte.hu>
commit 10f0412f57f2a76a90eff4376f59cbb0a39e4e18 upstream.
On failure init_sysfs() might not properly free resources. The error
code of the function is not checked. And, when reinitializing the exit
function might be called twice. This patch fixes all this.
commit 30da55242818a8ca08583188ebcbaccd283ad4d9 upstream.
commit 2ca1af9aa3285c6a5f103ed31ad09f7399fc65d7 "PCI: MSI: Remove
unsafe and unnecessary hardware access" changed read_msi_msg_desc() to
return the last MSI message written instead of reading it from the
device, since it may be called while the device is in a reduced
power state.
However, the pSeries platform code really does need to read messages
from the device, since they are initially written by firmware.
Therefore:
- Restore the previous behaviour of read_msi_msg_desc()
- Add new functions get_cached_msi_msg{,_desc}() which return the
- Use the new functions where appropriate
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit cd7240c0b900eb6d690ccee088a6c9b46dae815a upstream.
TSC's get reset after suspend/resume (even on cpu's with invariant TSC
which runs at a constant rate across ACPI P-, C- and T-states). And in
some systems BIOS seem to reinit TSC to arbitrary large value (still
sync'd across cpu's) during resume.
This leads to a scenario of scheduler rq->clock (sched_clock_cpu()) less
than rq->age_stamp (introduced in 2.6.32). This leads to a big value
returned by scale_rt_power() and the resulting big group power set by the
update_group_power() is causing improper load balancing between busy and
idle cpu's after suspend/resume.
This resulted in multi-threaded workloads (like kernel-compilation) go
slower after suspend/resume cycle on core i5 laptops.
Fix this by recomputing cyc2ns_offset's during resume, so that
sched_clock() continues from the point where it was left off during
suspend.
Reported-by: Florian Pritz <flo@xssn.at>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1282262618.2675.24.camel@sbsiddha-MOBL3.sc.intel.com>
commit 8c3ba8d049247dc06b6dcee1711a11b26647aa44 upstream.
When the SMP kernel decides to crash_kexec() the local APICs may have
pending interrupts in their vector tables.
The setup routine for the local APIC has a deficient mechanism for
clearing these interrupts, it only handles interrupts that has already
been dispatched to the local core for servicing (the ISR register) safely,
it doesn't consider lower prioritized queued interrupts stored in the IRR
register.
If you have more than one pending interrupt within the same 32 bit word in
the LAPIC vector table registers you may find yourself entering the IO
APIC setup with pending interrupts left in the LAPIC. This is a situation
for wich the IO APIC setup is not prepared. Depending of what/which
interrupt vector/vectors are stuck in the APIC tables your system may show
various degrees of malfunctioning. That was the reason why the
check_timer() failed in our system, the timer interrupts was blocked by
pending interrupts from the old kernel when routed trough the IO APIC.
Additional comment from Jiri Bohac:
If this should go into stable release,
I'd add some kind of limit on the number of iterations, just to be safe from
hard to debug lock-ups:
+if (loops++ > MAX_LOOPS) {
+ printk("LAPIC pending clean-up")
+ break;
while (queued);
with MAX_LOOPS something like 1E9 this would leave plenty of time for the
pending IRQs to be cleared and would and still cause at most a second of delay
if the loop were to lock-up for whatever reason.
[trenn@suse.de:
V2: Use tsc if avail to bail out after 1 sec due to possible virtual
apic_read calls which may take rather long (suggested by: Avi Kivity
<avi@redhat.com>) If no tsc is available bail out quickly after
cpu_khz, if we broke out too early and still have irqs pending (which
should never happen?) we still get a WARN_ON...
V3: - Fixed indentation -> checkpatch clean
- max_loops must be signed
V4: - Fix typo, mixed up tsc and ntsc in first rdtscll() call
V5: Adjust WARN_ON() condition to also catch error in cpu_has_tsc case]
Cc: <jbohac@novell.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Kerstin Jonsson <kerstin.jonsson@ericsson.com>
Tested-by: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
LKML-Reference: <201005241913.o4OJDGWM010865@imap1.linux-foundation.org>
Cc: Thomas Renninger <trenn@suse.de>
commit c686ecf5040d287a68d4fca7f1948472f556a6d3 upstream.
Commit e32e78c5ee8aadef020fbaecbe6fb741ed9029fd
(powerpc: fix build with make 3.82) introduced a
typo in uImage target and broke building uImage:
make: *** No rule to make target `uImage'. Stop.
commit a7c55cbee0c1bae9bf5a15a08300e91d88706e45 upstream.
Newer Intel processors identifying themselves as model 30 are not recognized by
oprofile.
<cpuinfo snippet>
model : 30
model name : Intel(R) Xeon(R) CPU X3470 @ 2.93GHz
</cpuinfo snippet>
Running oprofile on these machines gives the following:
+ opcontrol --init
+ opcontrol --list-events
oprofile: available events for CPU type "Intel Architectural Perfmon"
See Intel 64 and IA-32 Architectures Software Developer's Manual
Volume 3B (Document 253669) Chapter 18 for architectural perfmon events
This is a limited set of fallback events because oprofile doesn't know your CPU
CPU_CLK_UNHALTED: (counter: all)
Clock cycles when not halted (min count: 6000)
INST_RETIRED: (counter: all)
number of instructions retired (min count: 6000)
LLC_MISSES: (counter: all)
Last level cache demand requests from this core that missed the LLC
(min count: 6000)
Unit masks (default 0x41)
0x41: No unit mask
LLC_REFS: (counter: all)
Last level cache demand requests from this core (min count: 6000)
Unit masks (default 0x4f)
0x4f: No unit mask
BR_MISS_PRED_RETIRED: (counter: all)
number of mispredicted branches retired (precise) (min count: 500)
+ opcontrol --shutdown
Tested using oprofile 0.9.6.
Signed-off-by: Josh Hunt <johunt@akamai.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
commit 45c34e05c4e3d36e7c44e790241ea11a1d90d54e upstream.
Back when the patch was submitted for "Add Xeon 7500 series support to
oprofile", Robert Richter had asked for a followon patch that
converted all the CPU ID values to hex.
I have done that here for the "i386/core_i7" and "i386/atom" class
processors in the ppro_init() function and also added some comments on
where to find documentation on the Intel processors.
Signed-off-by: John L. Villalovos <john.l.villalovos@intel.com>
[ Upstream commits 86fa04b8742ac681d470786f55e2403ada0075b2
and b10f997bb0f4e5b34d447f498fb85834a40d3acb ]
Should return 'long' instead of 'int'.
Thanks to Dimitris Michailidis and Tony Luck.
[ Upstream commit ef201bebe5afc91a2b99b45dacc8c6dd88ca9e58 ]
As noticed by Linus, it is critical that some of the
rwsem constants be signed. Yet, hex constants are
unsigned unless explicitly casted or negated.
The most critical one is RWSEM_WAITING_BIAS.
This bug was exacerbated by commit
424acaaeb3a3932d64a9b4bd59df6cf72c22d8f3 ("rwsem: wake queued readers
when writer blocks on active read lock")
[ Upstream commit bf8253bf5e7cfe17dd53e3f6340a45b11d9fb51c ]
SunBlade-2500 has 'parallel' device node with compatible
property "pnpALI,1533,3" so add that to the ID table.
Reported-by: Mikael Pettersson <mikpe@it.uu.se>
commit 41e2e8fd34fff909a0e40129f6ac4233ecfa67a9 upstream.
Reviewed-by: Arve Hjønnevåg <arve@android.com>
Acked-by: Dima Zavin <dima@android.com>
commit 05e407603e527f9d808dd3866d3a17c2ce4dfcc5 upstream.
Fix a boot crash when apic=debug is used and the APIC is
not properly initialized.
This issue appears during Xen Dom0 kernel boot but the
fix is generic and the crash could occur on real hardware
as well.
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
Cc: xen-devel@lists.xensource.com
Cc: konrad.wilk@oracle.com
Cc: jeremy@goop.org
LKML-Reference: <20100819224616.GB9967@router-fw-old.local.net-space.pl>
commit d7c53c9e822a4fefa13a0cae76f3190bfd0d5c11 upstream.
When testing cpu hotplug code on 32-bit we kept hitting the "CPU%d:
Stuck ??" message due to multiple cores concurrently accessing the
cpu_callin_mask, among others.
Since these codepaths are not protected from concurrent access due to
the fact that there's no sane reason for making an already complex
code unnecessarily more complex - we hit the issue only when insanely
switching cores off- and online - serialize hotplugging cores on the
sysfs level and be done with it.
[ v2.1: fix !HOTPLUG_CPU build ]
LKML-Reference: <20100819181029.GC17171@aftab>
commit 96054569190bdec375fe824e48ca1f4e3b53dd36 upstream.
It's wrong for several reasons, but the most direct one is that the
fault may be for the stack accesses to set up a previous SIGBUS. When
we have a kernel exception, the kernel exception handler does all the
fixups, not some user-level signal handler.
Even apart from the nested SIGBUS issue, it's also wrong to give out
kernel fault addresses in the signal handler info block, or to send a
SIGBUS when a system call already returns EFAULT.
commit 8d3d50bf1913561ef3b1f5b53115c5a481ba9b1e upstream.
During a EEH recover, the pci_dev structure can be null, mainly if an
eeh event is detected during cpi config operation. In this case, the
pci_dev will not be known (and will be null) the kernel will crash
with the following message:
Unable to handle kernel paging request for data at address 0x000000a0
Faulting instruction address: 0xc00000000006b8b4
Oops: Kernel access of bad area, sig: 11 [#1]
NIP [c00000000006b8b4] .eeh_event_handler+0x10c/0x1a0
LR [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
Call Trace:
[c0000003a80dff00] [c00000000006b8a8] .eeh_event_handler+0x100/0x1a0
[c0000003a80dff90] [c000000000031f1c] .kernel_thread+0x54/0x70
The bug occurs because pci_name() tries to access a null pointer.
This patch just guarantee that pci_name() is not called on Null pointers.
Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com>
Signed-off-by: Linas Vepstas <linasvepstas@gmail.com>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit fad539956c9e69749a03f7817d22d1bab87657bf upstream.
Iranna D Ankad reported that IBM x3950 systems have boot
problems after this commit:
| commit b9c61b70075c87a8612624736faf4a2de5b1ed30
| x86/pci: update pirq_enable_irq() to setup io apic routing
The problem is that with the patch, the machine freezes when
console=ttyS0,... kernel serial parameter is passed.
It seem to freeze at DVD initialization and the whole problem
seem to be DVD/pata related, but somehow exposed through the
serial parameter.
Such apic problems can expose really weird behavior:
ACPI: IOAPIC (id[0x10] address[0xfecff000] gsi_base[0])
IOAPIC[0]: apic_id 16, version 0, address 0xfecff000, GSI 0-2
ACPI: IOAPIC (id[0x0f] address[0xfec00000] gsi_base[3])
IOAPIC[1]: apic_id 15, version 0, address 0xfec00000, GSI 3-38
ACPI: IOAPIC (id[0x0e] address[0xfec01000] gsi_base[39])
IOAPIC[2]: apic_id 14, version 0, address 0xfec01000, GSI 39-74
ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 4 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 5 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 3 global_irq 6 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 4 global_irq 7 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 6 global_irq 9 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 7 global_irq 10 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 8 global_irq 11 low edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 12 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 12 global_irq 15 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 13 global_irq 16 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 17 low edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 18 dfl dfl)
It turns out that the system has three io apic controllers, but
boot ioapic routing is in the second one, and that gsi_base is
not 0 - it is using a bunch of INT_SRC_OVR...
So these recent changes:
1. one set routing for first io apic controller
2. assume irq = gsi
... will break that system.
So try to remap those gsis, need to seperate boot_ioapic_idx
detection out of enable_IO_APIC() and call them early.
So introduce boot_ioapic_idx, and remap_ioapic_gsi()...
-v2: shift gsi with delta instead of gsi_base of boot_ioapic_idx
-v3: double check with find_isa_irq_apic(0, mp_INT) to get right
boot_ioapic_idx
-v4: nr_legacy_irqs
-v5: add print out for boot_ioapic_idx, and also make it could be
applied for current kernel and previous kernel
-v6: add bus_irq, in acpi_sci_ioapic_setup, so can get overwride
for sci right mapping...
-v7: looks like pnpacpi get irq instead of gsi, so need to revert
them back...
-v8: split into two patches
-v9: according to Eric, use fixed 16 for shifting instead of remap
-v10: still need to touch rsparser.c
-v11: just revert back to way Eric suggest...
anyway the ioapic in first ioapic is blocked by second...
-v12: two patches, this one will add more loop but check apic_id and irq > 16
Reported-by: Iranna D Ankad <iranna.ankad@in.ibm.com>
Bisected-by: Iranna D Ankad <iranna.ankad@in.ibm.com>
Tested-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: len.brown@intel.com
LKML-Reference: <4B8A321A.1000008@kernel.org>
commit ea0854170c95245a258b386c7a9314399c949fe0 upstream.
Newly added memory can not be accessed via /dev/mem, because we do not
update the variables high_memory, max_pfn and max_low_pfn.
Add a function update_end_of_memory_vars() to update these variables for
64-bit kernels.
[akpm@linux-foundation.org: simplify comment]
Signed-off-by: Shaohui Zheng <shaohui.zheng@intel.com>
Cc: Li Haicheng <haicheng.li@intel.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit e2a465675dc089e9a56ba2fa2a5fbd9bd8844d18 upstream.
It's possible that SBA IOMMU might fail to find I/O space under heavy
I/Os. SBA IOMMU panics on allocation failure but it shouldn't; drivers
can handle the failure. The majority of other IOMMU drivers don't panic
on allocation failure.
This patch fixes SBA IOMMU path to handle allocation failure properly.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Leonardo Chiquitto <lchiquitto@novell.com>
