commit a558d99263936b8a67d4eff8918745a77bfd8c31 upstream.
Remove __initdata attribute, as the devices may be used after init
sections are freed.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 5a5e75f4714a592f31e57f248b8f5c866f278b8d upstream.
With commit d8d14bd09cdd ("fs/compat: fix lookup_dcookie() parameter
handling") I changed the type of the len parameter of the
lookup_dcookie() syscall.
However I missed that there was still a stale declaration in
arch/tile/.. which now causes a compile error on tile:
In file included from fs/dcookies.c:28:0:
include/linux/compat.h:425:17: error: conflicting types for 'compat_sys_lookup_dcookie'
fs/dcookies.c:207:1: error: conflicting types for 'compat_sys_lookup_dcookie'
Simply remove the declaration in the tile architecture, which is only a
leftover from before the different compat lookup_dcookie() versions have
been merged. The correct declaration is now in include/linux/compat.h
The build error was reported by Fenguang's build bot.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
commit dc4910d9e93f8cc56b190dd8fc9e789135978216 upstream.
When pci_base is accessed whereas it has not been properly mapped by
of_iomap() the kernel hang. The check of this pointer made an improper
use of IS_ERR() instead of comparing to NULL. This patch fix this
issue.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Reported-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Fixes: 930ab3d403ae (i2c: mv64xxx: Add I2C Transaction Generator support)
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit f28d7de6bd4d41774744e011141945affa127da4 upstream.
DT-enabled Marvell Kirkwood and Dove SoCs make use of an irqchip
driver. As expected for irqchip drivers, it uses a C-style
interrupt handler and therefore selects MULTI_IRQ_HANDLER.
Now, compiling a kernel with both non-DT and DT support enabled,
selecting MULTI_IRQ_HANDLER will break ASM irq handler used by
non-DT boards.
Therefore, we provide a C-style irq handler even for non-DT boards,
if MULTI_IRQ_HANDLER is set. By installing the C-style irq handler
in orion_irq_init this is transparent to all non-DT board files.
While the regression report was filed on Marvell Kirkwood, also
Marvell Dove non-DT boards are affected and fixed by this patch.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Tested-by: Ian Campbell <ijc@hellion.org.uk>
Reported-by: Ian Campbell <ijc@hellion.org.uk>
Fixes: 2326f04321a9 ("ARM: kirkwood: convert to DT irqchip and clocksource")
Fixes: f07d73e33d0e ("ARM: dove: convert to DT irqchip and clocksource")
Acked-by: Andrew Lunn <andrew@lunn.ch>
commit 24f91eba18bbfdb27e71a1aae5b3a61b67fcd091 upstream.
The SOFT_DIRTY bit shows that the content of memory was changed after a
defined point in the past. mprotect() doesn't change the content of
memory, so it must not change the SOFT_DIRTY bit.
This bug causes a malfunction: on the first iteration all pages are
dumped. On other iterations only pages with the SOFT_DIRTY bit are
dumped. So if the SOFT_DIRTY bit is cleared from a page by mistake, the
page is not dumped and its content will be restored incorrectly.
This patch does nothing with _PAGE_SWP_SOFT_DIRTY, becase pte_modify()
is called only for present pages.
Fixes commit 0f8975ec4db2 ("mm: soft-dirty bits for user memory changes
tracking").
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Wen Congyang <wency@cn.fujitsu.com>
commit 51c71a3bbaca868043cc45b3ad3786dd48a90235 upstream.
The user has the option of disabling the platform driver:
00:02.0 Unassigned class [ff80]: XenSource, Inc. Xen Platform Device (rev 01)
which is used to unplug the emulated drivers (IDE, Realtek 8169, etc)
and allow the PV drivers to take over. If the user wishes
to disable that they can set:
xen_platform_pci=0
(in the guest config file)
or
xen_emul_unplug=never
(on the Linux command line)
except it does not work properly. The PV drivers still try to
load and since the Xen platform driver is not run - and it
has not initialized the grant tables, most of the PV drivers
stumble upon:
input: Xen Virtual Keyboard as /devices/virtual/input/input5
input: Xen Virtual Pointer as /devices/virtual/input/input6M
kernel BUG at /home/konrad/ssd/konrad/linux/drivers/xen/grant-table.c:1206!
invalid opcode: 0000 [#1] SMP
Modules linked in: xen_kbdfront(+) xenfs xen_privcmd
CPU: 6 PID: 1389 Comm: modprobe Not tainted 3.13.0-rc1upstream-00021-ga6c892b-dirty #1
Hardware name: Xen HVM domU, BIOS 4.4-unstable 11/26/2013
RIP: 0010:[<ffffffff813ddc40>] [<ffffffff813ddc40>] get_free_entries+0x2e0/0x300
Call Trace:
[<ffffffff8150d9a3>] ? evdev_connect+0x1e3/0x240
[<ffffffff813ddd0e>] gnttab_grant_foreign_access+0x2e/0x70
[<ffffffffa0010081>] xenkbd_connect_backend+0x41/0x290 [xen_kbdfront]
[<ffffffffa0010a12>] xenkbd_probe+0x2f2/0x324 [xen_kbdfront]
[<ffffffff813e5757>] xenbus_dev_probe+0x77/0x130
[<ffffffff813e7217>] xenbus_frontend_dev_probe+0x47/0x50
[<ffffffff8145e9a9>] driver_probe_device+0x89/0x230
[<ffffffff8145ebeb>] __driver_attach+0x9b/0xa0
[<ffffffff8145eb50>] ? driver_probe_device+0x230/0x230
[<ffffffff8145cf1c>] bus_for_each_dev+0x8c/0xb0
[<ffffffff8145e7d9>] driver_attach+0x19/0x20
[<ffffffff8145e260>] bus_add_driver+0x1a0/0x220
[<ffffffff8145f1ff>] driver_register+0x5f/0xf0
[<ffffffff813e55c5>] xenbus_register_driver_common+0x15/0x20
[<ffffffff813e76b3>] xenbus_register_frontend+0x23/0x40
[<ffffffffa0015000>] ? 0xffffffffa0014fff
[<ffffffffa001502b>] xenkbd_init+0x2b/0x1000 [xen_kbdfront]
[<ffffffff81002049>] do_one_initcall+0x49/0x170
.. snip..
which is hardly nice. This patch fixes this by having each
PV driver check for:
- if running in PV, then it is fine to execute (as that is their
native environment).
- if running in HVM, check if user wanted 'xen_emul_unplug=never',
in which case bail out and don't load any PV drivers.
- if running in HVM, and if PCI device 5853:0001 (xen_platform_pci)
does not exist, then bail out and not load PV drivers.
- (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=ide-disks',
then bail out for all PV devices _except_ the block one.
Ditto for the network one ('nics').
- (v2) if running in HVM, and if the user wanted 'xen_emul_unplug=unnecessary'
then load block PV driver, and also setup the legacy IDE paths.
In (v3) make it actually load PV drivers.
Reported-by: Sander Eikelenboom <linux@eikelenboom.it
Reported-by: Anthony PERARD <anthony.perard@citrix.com>
Reported-and-Tested-by: Fabio Fantoni <fabio.fantoni@m2r.biz>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[v2: Add extra logic to handle the myrid ways 'xen_emul_unplug'
can be used per Ian and Stefano suggestion]
[v3: Make the unnecessary case work properly]
[v4: s/disks/ide-disks/ spotted by Fabio]
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> [for PCI parts]
commit 53a52f17d96c8d47c79a7dafa81426317e89c7c1 upstream.
arch/sh/kernel/kgdb.c: In function 'sleeping_thread_to_gdb_regs':
arch/sh/kernel/kgdb.c:225:32: error: implicit declaration of function 'task_stack_page' [-Werror=implicit-function-declaration]
arch/sh/kernel/kgdb.c:242:23: error: dereferencing pointer to incomplete type
arch/sh/kernel/kgdb.c:243:22: error: dereferencing pointer to incomplete type
arch/sh/kernel/kgdb.c: In function 'singlestep_trap_handler':
arch/sh/kernel/kgdb.c:310:27: error: 'SIGTRAP' undeclared (first use in this function)
arch/sh/kernel/kgdb.c:310:27: note: each undeclared identifier is reported only once for each function it appears in
This was introduced by commit 16559ae48c76 ("kgdb: remove #include
<linux/serial_8250.h> from kgdb.h").
[geert@linux-m68k.org: reworded and reformatted]
Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 3b56496865f9f7d9bcb2f93b44c63f274f08e3b6 upstream.
This adds the workaround for erratum 793 as a precaution in case not
every BIOS implements it. This addresses CVE-2013-6885.
Erratum text:
[Revision Guide for AMD Family 16h Models 00h-0Fh Processors,
document 51810 Rev. 3.04 November 2013]
793 Specific Combination of Writes to Write Combined Memory Types and
Locked Instructions May Cause Core Hang
Description
Under a highly specific and detailed set of internal timing
conditions, a locked instruction may trigger a timing sequence whereby
the write to a write combined memory type is not flushed, causing the
locked instruction to stall indefinitely.
Potential Effect on System
Processor core hang.
Suggested Workaround
BIOS should set MSR
C001_1020[15] = 1b.
Fix Planned
No fix planned
[ hpa: updated description, fixed typo in MSR name ]
Link: http://lkml.kernel.org/r/20140114230711.GS29865@pd.tnic
Tested-by: Aravind Gopalakrishnan <aravind.gopalakrishnan@amd.com>
commit 91b973f90c1220d71923e7efe1e61f5329806380 upstream.
The code in remove_cache_dir() is supposed to remove the "cache"
subdirectory from the sysfs directory for a CPU when that CPU is
being offlined. It tries to do this by calling kobject_put() on
the kobject for the subdirectory. However, the subdirectory only
gets removed once the last reference goes away, and the reference
being put here may well not be the last reference. That means
that the "cache" subdirectory may still exist when the offlining
operation has finished. If the same CPU subsequently gets onlined,
the code tries to add a new "cache" subdirectory. If the old
subdirectory has not yet been removed, we get a WARN_ON in the
sysfs code, with stack trace, and an error message printed on the
console. Further, we ultimately end up with an online cpu with no
This fixes it by doing an explicit kobject_del() at the point where
we want the subdirectory to go away. kobject_del() removes the sysfs
directory even though the object still exists in memory. The object
will get freed at some point in the future. A subsequent onlining
operation can create a new sysfs directory, even if the old object
still exists in memory, without causing any problems.
commit d4edc5b6c480a0917e61d93d55531d7efa6230be upstream.
On POWER platforms, the hypervisor can notify the guest kernel about dynamic
changes in the cpu-numa associativity (VPHN topology update). Hence the
cpu-to-node mappings that we got from the firmware during boot, may no longer
be valid after such updates. This is handled using the arch_update_cpu_topology()
hook in the scheduler, and the sched-domains are rebuilt according to the new
mappings.
But unfortunately, at the moment, CPU hotplug ignores these updated mappings
and instead queries the firmware for the cpu-to-numa relationships and uses
them during CPU online. So the kernel can end up assigning wrong NUMA nodes
to CPUs during subsequent CPU hotplug online operations (after booting).
Further, a particularly problematic scenario can result from this bug:
On POWER platforms, the SMT mode can be switched between 1, 2, 4 (and even 8)
threads per core. The switch to Single-Threaded (ST) mode is performed by
offlining all except the first CPU thread in each core. Switching back to
SMT mode involves onlining those other threads back, in each core.
Now consider this scenario:
1. During boot, the kernel gets the cpu-to-node mappings from the firmware
and assigns the CPUs to NUMA nodes appropriately, during CPU online.
2. Later on, the hypervisor updates the cpu-to-node mappings dynamically and
communicates this update to the kernel. The kernel in turn updates its
cpu-to-node associations and rebuilds its sched domains. Everything is
fine so far.
3. Now, the user switches the machine from SMT to ST mode (say, by running
ppc64_cpu --smt=1). This involves offlining all except 1 thread in each
core.
4. The user then tries to switch back from ST to SMT mode (say, by running
ppc64_cpu --smt=4), and this involves onlining those threads back. Since
CPU hotplug ignores the new mappings, it queries the firmware and tries to
associate the newly onlined sibling threads to the old NUMA nodes. This
results in sibling threads within the same core getting associated with
different NUMA nodes, which is incorrect.
The scheduler's build-sched-domains code gets thoroughly confused with this
and enters an infinite loop and causes soft-lockups, as explained in detail
in commit 3be7db6ab (powerpc: VPHN topology change updates all siblings).
So to fix this, use the numa_cpu_lookup_table to remember the updated
cpu-to-node mappings, and use them during CPU hotplug online operations.
Further, we also need to ensure that all threads in a core are assigned to a
common NUMA node, irrespective of whether all those threads were online during
the topology update. To achieve this, we take care not to use cpu_sibling_mask()
since it is not hotplug invariant. Instead, we use cpu_first_sibling_thread()
and set up the mappings manually using the 'threads_per_core' value for that
particular platform. This helps us ensure that we don't hit this bug with any
combination of CPU hotplug and SMT mode switching.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 70713fe315ed14cd1bb07d1a7f33e973d136ae3d upstream.
Use gva_t instead of unsigned int for eaddr in deliver_tlb_miss().
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
commit 48eaef0518a565d3852e301c860e1af6a6db5a84 upstream.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit 57737c49dd72c96cfbcd4f66559f3ffc399aeb4f upstream.
This commit:
f8dae00684d678afa13041ef170cecfd1297ed40: parisc: Ensure full cache coherency for kmap/kunmap
caused negative caching side-effects, e.g. hanging processes with expect and
too many inequivalent alias messages from flush_dcache_page() on Debian 5 systems.
This patch now partly reverts it and has been in production use on our debian buildd
makeservers since a week without any major problems.
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: John David Anglin <dave.anglin@bell.net>
commit 0ef38d70d4118b2ce1a538d14357be5ff9dc2bbd upstream.
The patch 3ddc5b46a8e90f3c9251338b60191d0a804b0d92 breaks networking on
alpha (there is a follow-up fix 5cfe8f1ba5eebe6f4b6e5858cdb1a5be4f3272a6,
but networking is still broken even with the second patch).
The patch 3ddc5b46a8e90f3c9251338b60191d0a804b0d92 makes
csum_partial_copy_from_user check the pointer with access_ok. However,
csum_partial_copy_from_user is called also from csum_partial_copy_nocheck
and csum_partial_copy_nocheck is called on kernel pointers and it is
supposed not to check pointer validity.
This bug results in ssh session hangs if the system is loaded and bulk
data are printed to ssh terminal.
This patch fixes csum_partial_copy_nocheck to call set_fs(KERNEL_DS), so
that access_ok in csum_partial_copy_from_user accepts kernel-space
addresses.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
[ Upstream commit 3af57f78c38131b7a66e2b01e06fdacae01992a3 ]
The s390 bpf jit compiler emits the signed divide instructions "dr" and "d"
for unsigned divisions.
This can cause problems: the dividend will be zero extended to a 64 bit value
and the divisor is the 32 bit signed value as specified A or X accumulator,
even though A and X are supposed to be treated as unsigned values.
The divide instrunctions will generate an exception if the result cannot be
expressed with a 32 bit signed value.
This is the case if e.g. the dividend is 0xffffffff and the divisor either 1
or also 0xffffffff (signed: -1).
To avoid all these issues simply use unsigned divide instructions.
[ Upstream commit aee636c4809fa54848ff07a899b326eb1f9987a2 ]
At first Jakub Zawadzki noticed that some divisions by reciprocal_divide
were not correct. (off by one in some cases)
http://www.wireshark.org/~darkjames/reciprocal-buggy.c
He could also show this with BPF:
http://www.wireshark.org/~darkjames/set-and-dump-filter-k-bug.c
The reciprocal divide in linux kernel is not generic enough,
lets remove its use in BPF, as it is not worth the pain with
current cpus.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Cc: Mircea Gherzan <mgherzan@gmail.com>
Cc: Daniel Borkmann <dxchgb@gmail.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Matt Evans <matt@ozlabs.org>
commit 85e618a1be2b2092318178d1d66bdad49cbbeeeb upstream.
The first variants of Armada XP SoCs (A0 stepping) have issues related
to the i2c controller which prevent to use the offload mechanism and
lead to a kernel hang during boot.
This commit add quirk in the mvebu platform code to check the SoC
version and then update the compatible string for the i2c controller
according to the revision of the SoC. Currently only some OpenBlocks
AX3-4 boards are known to use an A0 revision so the check is done only
for these boards.
commit af8d1c63afcbf36eea06789c92e22d4af118d2fb upstream.
All the mvebu SoCs have information related to their variant and
revision that can be read from the PCI control register.
This patch adds support for Armada XP and Armada 370. This reading of
the revision and the ID are done before the PCI initialization to
avoid any conflicts. Once these data are retrieved, the resources are
freed to let the PCI subsystem use it.
commit a96cc303e42ad7830dde929aad0046e448a05505 upstream.
This patch updates the Armada 370/XP SATA node with the new compatible
string "marvell,armada-370-sata".
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Lior Amsalem <alior@marvell.com>
Acked-by: Jason Cooper <jason@lakedaemon.net>
commit 4e078146dff728f4865270a47710d57797e81eb6 upstream.
With b8668fd0a7e1b59f "s390/uapi: change struct statfs[64] member types
to unsigned values" the size of a couple of struct statfs64 member got
incorrectly changed from 64 to 32 bit for 32 bit builds.
Fix this by changing the type of couple of struct statfs64 members from
unsigned long to unsigned long long.
The definition of struct compat_statfs64 was correct however.
commit ff1f3cb4b3ac5d039f02679f34cb1498d110d241 upstream.
The diagnose 500 subcode 3 contains the 32 bit subchannel id in bits 32-63
(counting from the left). As for other I/O instructions, bits 0-31 should be
ignored and thus not be passed to kvm_io_bus_write_cookie().
This fixes a bug where the guest passed non-zero bits 0-31 which the
host tried to interpret, leading to ioeventfd notification failures.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
commit 743db27c526e0f31cc507959d662e97e2048a86f upstream.
The diagnose code to be used is the contents of the base register (if not
zero), plus the displacement. The current code ignores the base register
contents. So let's fix that...
Cc: stable@vger.kernel.org
commit 1588c51cf6d782e63a8719681d905ef0ac22ee62 upstream.
There was a copy/paste error when reading the nwe_pulse value.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
Acked-by: Boris BREZILLON <b.brezillon@overkiz.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit 0645b93f6c223b594c0dca348e2ae0a23bccf6e3 upstream.
pinctrl-names property was missing from mmc nodes.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit 77f01bdfa5e55dc19d3eb747181d2730a9bb3ca8 upstream.
When Hyper-V hypervisor leaves are present, KVM must relocate
its own leaves at 0x40000100, because Windows does not look for
Hyper-V leaves at indices other than 0x40000000. In this case,
the KVM features are at 0x40000101, but the old code would always
look at 0x40000001.
Fix by using kvm_cpuid_base(). This also requires making the
function non-inline, since kvm_cpuid_base() is static.
Fixes: 1085ba7f552d84aa8ac0ae903fa8d0cc2ff9f79d
Cc: mtosatti@redhat.com
commit 1c300a40772dae829b91dad634999a6a522c0829 upstream.
It is unnecessary to go through hypervisor_cpuid_base every time
a leaf is found (which will be every time a feature is requested
after the next patch).
commit 9ed96e87c5748de4c2807ef17e81287c7304186c upstream.
Limit PIT timer frequency similarly to the limit applied by
LAPIC timer.
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit a7f84f03f660d93574ac88835d056c0d6468aebe upstream.
Current code check boot service region with kernel text region by:
start+size >= __pa_symbol(_text)
The end of the above region should be start + size - 1 instead.
I see this problem in ovmf + Fedora 19 grub boot:
text start: 1000000 md start: 800000 md size: 800000
Signed-off-by: Dave Young <dyoung@redhat.com>
Acked-by: Borislav Petkov <bp@suse.de>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Tested-by: Toshi Kani <toshi.kani@hp.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 0dce7cd67fd9055c4a2ff278f8af1431e646d346 upstream.
Commit e66d2ae7c67bd moved the assignment
vcpu->arch.apic_base = value above a condition with
(vcpu->arch.apic_base ^ value), causing that check
to always fail. Use old_value, vcpu->arch.apic_base's
old value, in the condition instead.
Signed-off-by: Andrew Jones <drjones@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
commit b25f3e1c358434bf850220e04f28eebfc45eb634 upstream.
Kexec disables outer cache before jumping to reboot code, but it doesn't
flush it explicitly. Flush is done implicitly inside of l2x0_disable().
But some SoC's override default .disable handler and don't flush cache.
This may lead to a corrupted memory during Kexec reboot on these
platforms.
This patch adds cache flush inside of OMAP4 and Highbank outer_cache.disable()
handlers to make it consistent with default l2x0_disable().
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org>
Cc: Wang Nan <wangnan0@huawei.com>
commit e44ef891e9e68b6ce7d3fd3bac73b7d5433050ae upstream.
The MPIDR contains specific bitfields(MPIDR.Aff{2..0}) which uniquely
identify a CPU, in addition to some non-identifying information and
reserved bits. The ARM cpu binding defines the 'reg' property to only
contain the affinity bits, and any cpu nodes with other bits set in
their 'reg' entry are skipped.
As such it is not necessary to mask the phys_id with MPIDR_HWID_BITMASK,
and doing so could lead to matching erroneous CPU nodes in the device
tree. This patch removes the masking of the physical identifier.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
commit 1739f09e33d8f66bf48ddbc3eca615574da6c4f6 upstream.
Function tracing callbacks expect to have the ftrace_ops that registered it
passed to them, not the address of the variable that holds the ftrace_ops
that registered it.
Use a mov instead of a lea to store the ftrace_ops into the parameter
of the function tracing callback.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20131113152004.459787f9@gandalf.local.home
commit bee09ed91cacdbffdbcd3b05de8409c77ec9fcd6 upstream.
On AMD family 10h we see following error messages while waking up from
S3 for all non-boot CPUs leading to a failed IBS initialization:
Enabling non-boot CPUs ...
smpboot: Booting Node 0 Processor 1 APIC 0x1
[Firmware Bug]: cpu 1, try to use APIC500 (LVT offset 0) for vector 0x400, but the register is already in use for vector 0xf9 on another cpu
perf: IBS APIC setup failed on cpu #1
process: Switch to broadcast mode on CPU1
CPU1 is up
ACPI: Waking up from system sleep state S3
Reason for this is that during suspend the LVT offset for the IBS
vector gets lost and needs to be reinialized while resuming.
The offset is read from the IBSCTL msr. On family 10h the offset needs
to be 1 as offset 0 is used for the MCE threshold interrupt, but
firmware assings it for IBS to 0 too. The kernel needs to reprogram
the vector. The msr is a readonly node msr, but a new value can be
written via pci config space access. The reinitialization is
implemented for family 10h in setup_ibs_ctl() which is forced during
IBS setup.
This patch fixes IBS setup after waking up from S3 by adding
resume/supend hooks for the boot cpu which does the offset
reinitialization.
Marking it as stable to let distros pick up this fix.
Signed-off-by: Robert Richter <rric@kernel.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1389797849-5565-1-git-send-email-rric.net@gmail.com
commit 26bef1318adc1b3a530ecc807ef99346db2aa8b0 upstream.
Before we do an EMMS in the AMD FXSAVE information leak workaround we
need to clear any pending exceptions, otherwise we trap with a
floating-point exception inside this code.
Reported-by: halfdog <me@halfdog.net>
Tested-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/CA%2B55aFxQnY_PCG_n4=0w-VG=YLXL-yr7oMxyy0WU2gCBAf3ydg@mail.gmail.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit f8dae00684d678afa13041ef170cecfd1297ed40 upstream.
Helge Deller noted a few weeks ago problems with the AIO support on
parisc. This change is the result of numerous iterations on how best to
deal with this problem.
The solution adopted here is to provide full cache coherency in a
uniform manner on all parisc systems. This involves calling
flush_dcache_page() on kmap operations and flush_kernel_dcache_page() on
kunmap operations. As a result, the copy_user_page() and
clear_user_page() functions can be removed and the overall code is
simpler.
The change ensures that both userspace and kernel aliases to a mapped
page are invalidated and flushed. This is necessary for the correct
operation of PA8800 and PA8900 based systems which do not support
inequivalent aliases.
With this change, I have observed no cache related issues on c8000 and
rp3440. It is now possible for example to do kernel builds with "-j64"
on four way systems.
On systems using XFS file systems, the patch recently posted by Mikulas
Patocka to "fix crash using XFS on loopback" is needed to avoid a hang
caused by an uninitialized lock passed to flush_dcache_page() in the
page struct.
commit b6328a6b7ba57fc84c38248f6f0e387e1170f1a8 upstream.
Commit 4dcfa60071b3d23f0181f27d8519f12e37cefbb9 ("ARM: DMA-API: better
handing of DMA masks for coherent allocations") added an additional
check to the coherent DMA mask that results in an error when the mask is
larger than what dma_addr_t can address.
Set the LCDC coherent DMA mask to DMA_BIT_MASK(32) instead of ~0 to fix
the problem.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
commit dcd740b645003b866d7eb30d13d34d0729cce9db upstream.
the problem.
commit 4f387323853c495ac589210832fad4503f75a0e7 upstream.
the problem.
commit 8777539479abd7b3efeb691685415dc2b057d0e0 upstream.
Due to incorrect clock specified in MDMA0 node, using MDMA0 controller
could cause system failures, due to wrong clock being controlled. This
patch fixes this by specifying correct clock.
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
[t.figa: Corrected commit message and description.]
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
commit 2a7cfcbc0553365d75716f69ee7b704cac7c9248 upstream.
When given a compound high page, __flush_dcache_page will only flush
the first page of the compound page repeatedly rather than the entire
set of constituent pages.
This error was introduced by:
0b19f93 ARM: mm: Add support for flushing HugeTLB pages.
This patch corrects the logic such that all constituent pages are now
flushed.
Signed-off-by: Steve Capper <steve.capper@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
commit 29c350bf28da333e41e30497b649fe335712a2ab upstream.
The array was missing the final entry for the undefined instruction
exception handler; this commit adds it.
commit 4ff859fe1dc0da0f87bbdfff78f527898878fa4a upstream.
The clockevents code was being told that the footbridge clock event
device ticks at 16x the rate which it actually does. This leads to
timekeeping problems since it allows the clocksource to wrap before
the kernel notices. Fix this by using the correct clock.
Fixes: 4e8d76373c9fd ("ARM: footbridge: convert to clockevents/clocksource")
sh_ksyms_32.c
commit ad70b029d2c678386384bd72c7fa2705c449b518 upstream.
Min_low_pfn and max_low_pfn were used in pfn_valid macro if defined
CONFIG_FLATMEM. When the functions that use the pfn_valid is used in
driver module, max_low_pfn and min_low_pfn is to undefined, and fail to
build.
ERROR: "min_low_pfn" [drivers/block/aoe/aoe.ko] undefined!
ERROR: "max_low_pfn" [drivers/block/aoe/aoe.ko] undefined!
make[2]: *** [__modpost] Error 1
make[1]: *** [modules] Error 2
This patch fix this problem.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@gmail.com>
commit 84ed8a99058e61567f495cc43118344261641c5f upstream.
E.g. landisk_defconfig, which has CONFIG_NTFS_FS=m:
ERROR: "__ashrdi3" [fs/ntfs/ntfs.ko] undefined!
For "lib-y", if no symbols in a compilation unit are referenced by other
units, the compilation unit will not be included in vmlinux. This
breaks modules that do reference those symbols.
Use "obj-y" instead to fix this.
http://kisskb.ellerman.id.au/kisskb/buildresult/8838077/
This doesn't fix all cases. There are others, e.g. udivsi3.
This is also not limited to sh, many architectures handle this in the
same way.
A simple solution is to unconditionally include all helper functions.
A more complex solution is to make the choice of "lib-y" or "obj-y" depend
on CONFIG_MODULES:
obj-$(CONFIG_MODULES) += ...
lib-y($CONFIG_MODULES) += ...
Tested-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Reviewed-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
commit 378d0aee3b53bd8549b29dcc75f2bf47ee446e8f upstream.
The Allwinner A20 uses the ARM GIC as its internal interrupts controller. The
GIC can work on several interrupt triggers, and the A20 was actually setting it
up to use a rising edge as a trigger, while it was actually a level high
trigger, leading to some interrupts that would be completely ignored if the
edge was missed.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
commit 20841405940e7be0617612d521e206e4b6b325db upstream.
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
commit 2b4847e73004c10ae6666c2e27b5c5430aed8698 upstream.
Base pages are unmapped and flushed from cache and TLB during normal
page migration and replaced with a migration entry that causes any
parallel NUMA hinting fault or gup to block until migration completes.
THP does not unmap pages due to a lack of support for migration entries
at a PMD level. This allows races with get_user_pages and
get_user_pages_fast which commit 3f926ab945b6 ("mm: Close races between
THP migration and PMD numa clearing") made worse by introducing a
pmd_clear_flush().
This patch forces get_user_page (fast and normal) on a pmd_numa page to
go through the slow get_user_page path where it will serialise against
THP migration and properly account for the NUMA hinting fault. On the
migration side the page table lock is taken for each PTE update.
commit 286e4f90a72c0b0621dde0294af6ed4b0baddabb upstream.
p_end is an 8 byte value embedded in the text section. This means it
is only 4 byte aligned when it should be 8 byte aligned. Fix this
by adding an explicit alignment.
This fixes an issue where POWER7 little endian builds with
CONFIG_RELOCATABLE=y fail to boot.
commit 90ff5d688e61f49f23545ffab6228bd7e87e6dc7 upstream.
In EXCEPTION_PROLOG_COMMON() we check to see if the stack pointer (r1)
is valid when coming from the kernel. If it's not valid, we die but
with a nice oops message.
Currently we allocate a stack frame (subtract INT_FRAME_SIZE) before we
check to see if the stack pointer is negative. Unfortunately, this
won't detect a bad stack where r1 is less than INT_FRAME_SIZE.
This patch fixes the check to compare the modified r1 with
-INT_FRAME_SIZE. With this, bad kernel stack pointers (including NULL
pointers) are correctly detected again.
Kudos to Paulus for finding this.
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit e66d2ae7c67bd9ac982a3d1890564de7f7eabf4b upstream.
Update arch.apic_base before triggering recalculate_apic_map. Otherwise
the recalculation will work against the previous state of the APIC and
will fail to build the correct map when an APIC is hardware-enabled
again.
This fixes a regression of 1e08ec4a13.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
