path: root/arch
2014-07-09arch/unicore32/mm/alignment.c: include "asm/pgtable.h" to avoid compiling errorChen Gang
commit 1ff38c56cbd095c4c0dfa581a859ba3557830f78 upstream. Need include "asm/pgtable.h" to include "asm-generic/pgtable-nopmd.h", so can let 'pmd_t' defined. The related error with allmodconfig: CC arch/unicore32/mm/alignment.o In file included from arch/unicore32/mm/alignment.c:24: arch/unicore32/include/asm/tlbflush.h:135: error: expected .). before .*. token arch/unicore32/include/asm/tlbflush.h:154: error: expected .). before .*. token In file included from arch/unicore32/mm/alignment.c:27: arch/unicore32/mm/mm.h:15: error: expected .=., .,., .;., .sm. or ._attribute__. before .*. token arch/unicore32/mm/mm.h:20: error: expected .=., .,., .;., .sm. or ._attribute__. before .*. token arch/unicore32/mm/mm.h:25: error: expected .=., .,., .;., .sm. or ._attribute__. before .*. token make[1]: *** [arch/unicore32/mm/alignment.o] Error 1 make: *** [arch/unicore32/mm] Error 2 Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Acked-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Signed-off-by: Xuetao Guan <gxt@mprc.pku.edu.cn> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09KVM: x86: preserve the high 32-bits of the PAT registerPaolo Bonzini
commit 7cb060a91c0efc5ff94f83c6df3ed705e143cdb9 upstream. KVM does not really do much with the PAT, so this went unnoticed for a long time. It is exposed however if you try to do rdmsr on the PAT register. Reported-by: Valentine Sinitsyn <valentine.sinitsyn@gmail.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09KVM: x86: Increase the number of fixed MTRR regs to 10Nadav Amit
commit 682367c494869008eb89ef733f196e99415ae862 upstream. Recent Intel CPUs have 10 variable range MTRRs. Since operating systems sometime make assumptions on CPUs while they ignore capability MSRs, it is better for KVM to be consistent with recent CPUs. Reporting more MTRRs than actually supported has no functional implications. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09arm64: Bug fix in stack alignment exceptionChiaHao
commit 3906c2b53cd23c2ae03e6ce41432c8e7f0a3cbbb upstream. The value of ESR has been stored into x1, and should be directly pass to do_sp_pc_abort function, "MOV x1, x25" is an extra operation and do_sp_pc_abort will get the wrong value of ESR. Signed-off-by: ChiaHao <andy.jhshiu@gmail.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09ARM: OMAP2+: Fix parser-bug in platform muxing codeDavid R. Piegdon
commit c021f241f4fab2bb4fc4120a38a828a03dd3f970 upstream. Fix a parser-bug in the omap2 muxing code where muxtable-entries will be wrongly selected if the requested muxname is a *prefix* of their m0-entry and they have a matching mN-entry. Fix by additionally checking that the length of the m0_entry is equal. For example muxing of "dss_data2.dss_data2" on omap32xx will fail because the prefix "dss_data2" will match the mux-entries "dss_data2" as well as "dss_data20", with the suffix "dss_data2" matching m0 (for dss_data2) and m4 (for dss_data20). Thus both are recognized as signal path candidates: Relevant muxentries from mux34xx.c: _OMAP3_MUXENTRY(DSS_DATA20, 90, "dss_data20", NULL, "mcspi3_somi", "dss_data2", "gpio_90", NULL, NULL, "safe_mode"), _OMAP3_MUXENTRY(DSS_DATA2, 72, "dss_data2", NULL, NULL, NULL, "gpio_72", NULL, NULL, "safe_mode"), This will result in a failure to mux the pin at all: _omap_mux_get_by_name: Multiple signal paths (2) for dss_data2.dss_data2 Patch should apply to linus' latest master down to rather old linux-2.6 trees. Signed-off-by: David R. Piegdon <lkml@p23q.org> Cc: stable@vger.kernel.org [tony@atomide.com: updated description to include full description] Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06ptrace,x86: force IRET path after a ptrace_stop()Tejun Heo
commit b9cd18de4db3c9ffa7e17b0dc0ca99ed5aa4d43a upstream. The 'sysret' fastpath does not correctly restore even all regular registers, much less any segment registers or reflags values. That is very much part of why it's faster than 'iret'. Normally that isn't a problem, because the normal ptrace() interface catches the process using the signal handler infrastructure, which always returns with an iret. However, some paths can get caught using ptrace_event() instead of the signal path, and for those we need to make sure that we aren't going to return to user space using 'sysret'. Otherwise the modifications that may have been done to the register set by the tracer wouldn't necessarily take effect. Fix it by forcing IRET path by setting TIF_NOTIFY_RESUME from arch_ptrace_stop_needed() which is invoked from ptrace_stop(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06MIPS: KVM: Fix memory leak on VCPUDeng-Cheng Zhu
commit 8c9eb041cf76038eb3b62ee259607eec9b89f48d upstream. kvm_arch_vcpu_free() is called in 2 code paths: 1) kvm_vm_ioctl() kvm_vm_ioctl_create_vcpu() kvm_arch_vcpu_destroy() kvm_arch_vcpu_free() 2) kvm_put_kvm() kvm_destroy_vm() kvm_arch_destroy_vm() kvm_mips_free_vcpus() kvm_arch_vcpu_free() Neither of the paths handles VCPU free. We need to do it in kvm_arch_vcpu_free() corresponding to the memory allocation in kvm_arch_vcpu_create(). Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06MIPS: KVM: Remove redundant NULL checks before kfree()James Hogan
commit c6c0a6637f9da54f9472144d44f71cf847f92e20 upstream. The kfree() function already NULL checks the parameter so remove the redundant NULL checks before kfree() calls in arch/mips/kvm/. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: kvm@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Sanjay Lal <sanjayl@kymasys.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06powerpc: Add AT_HWCAP2 to indicate V.CRYPTO category supportBenjamin Herrenschmidt
commit dd58a092c4202f2bd490adab7285b3ff77f8e467 upstream. The Vector Crypto category instructions are supported by current POWER8 chips, advertise them to userspace using a specific bit to properly differentiate with chips of the same architecture level that might not have them. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06powerpc: fix typo 'CONFIG_PPC_CPU'Paul Bolle
commit b69a1da94f3d1589d1942b5d1b384d8cfaac4500 upstream. Commit cd64d1697cf0 ("powerpc: mtmsrd not defined") added a check for CONFIG_PPC_CPU were a check for CONFIG_PPC_FPU was clearly intended. Fixes: cd64d1697cf0 ("powerpc: mtmsrd not defined") Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06powerpc: fix typo 'CONFIG_PMAC'Paul Bolle
commit 6e0fdf9af216887e0032c19d276889aad41cad00 upstream. Commit b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling perf_event_do_pending") added a check for CONFIG_PMAC were a check for CONFIG_PPC_PMAC was clearly intended. Fixes: b0d278b7d3ae ("powerpc/perf_event: Reduce latency of calling perf_event_do_pending") Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06powerpc: 64bit sendfile is capped at 2GBAnton Blanchard
commit 5d73320a96fcce80286f1447864c481b5f0b96fa upstream. commit 8f9c0119d7ba (compat: fs: Generic compat_sys_sendfile implementation) changed the PowerPC 64bit sendfile call from sys_sendile64 to sys_sendfile. Unfortunately this broke sendfile of lengths greater than 2G because sys_sendfile caps at MAX_NON_LFS. Restore what we had previously which fixes the bug. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06powerpc/pseries: Fix overwritten PE stateGavin Shan
commit 54f112a3837d4e7532bbedbbbf27c0de277be510 upstream. In pseries_eeh_get_state(), EEH_STATE_UNAVAILABLE is always overwritten by EEH_STATE_NOT_SUPPORT because of the missed "break" there. The patch fixes the issue. Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06MIPS: MSC: Prevent out-of-bounds writes to MIPS SC ioremap'd regionMarkos Chandras
commit ab6c15bc6620ebe220970cc040b29bcb2757f373 upstream. Previously, the lower limit for the MIPS SC initialization loop was set incorrectly allowing one extra loop leading to writes beyond the MSC ioremap'd space. More precisely, the value of the 'imp' in the last loop increased beyond the msc_irqmap_t boundaries and as a result of which, the 'n' variable was loaded with an incorrect value. This value was used later on to calculate the offset in the MSC01_IC_SUP which led to random crashes like the following one: CPU 0 Unable to handle kernel paging request at virtual address e75c0200, epc == 8058dba4, ra == 8058db90 [...] Call Trace: [<8058dba4>] init_msc_irqs+0x104/0x154 [<8058b5bc>] arch_init_irq+0xd8/0x154 [<805897b0>] start_kernel+0x220/0x36c Kernel panic - not syncing: Attempted to kill the idle task! This patch fixes the problem Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7118/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30x86_32, entry: Do syscall exit work on badsys (CVE-2014-4508)Andy Lutomirski
commit 554086d85e71f30abe46fc014fea31929a7c6a8a upstream. The bad syscall nr paths are their own incomprehensible route through the entry control flow. Rearrange them to work just like syscalls that return -ENOSYS. This fixes an OOPS in the audit code when fast-path auditing is enabled and sysenter gets a bad syscall nr (CVE-2014-4508). This has probably been broken since Linux 2.6.27: af0575bba0 i386 syscall audit fast-path Cc: Roland McGrath <roland@redhat.com> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/e09c499eade6fc321266dd6b54da7beb28d6991c.1403558229.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30x86, x32: Use compat shims for io_{setup,submit}Mike Frysinger
commit 7fd44dacdd803c0bbf38bf478d51d280902bb0f1 upstream. The io_setup takes a pointer to a context id of type aio_context_t. This in turn is typed to a __kernel_ulong_t. We could tweak the exported headers to define this as a 64bit quantity for specific ABIs, but since we already have a 32bit compat shim for the x86 ABI, let's just re-use that logic. The libaio package is also written to expect this as a pointer type, so a compat shim would simplify that. The io_submit func operates on an array of pointers to iocb structs. Padding out the array to be 64bit aligned is a huge pain, so convert it over to the existing compat shim too. We don't convert io_getevents to the compat func as its only purpose is to handle the timespec struct, and the x32 ABI uses 64bit times. With this change, the libaio package can now pass its testsuite when built for the x32 ABI. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Link: http://lkml.kernel.org/r/1399250595-5005-1-git-send-email-vapier@gentoo.org Cc: H.J. Lu <hjl.tools@gmail.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30x86-32, espfix: Remove filter for espfix32 due to raceH. Peter Anvin
commit 246f2d2ee1d715e1077fc47d61c394569c8ee692 upstream. It is not safe to use LAR to filter when to go down the espfix path, because the LDT is per-process (rather than per-thread) and another thread might change the descriptors behind our back. Fortunately it is always *safe* (if a bit slow) to go down the espfix path, and a 32-bit LDT stack segment is extremely rare. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30ARM: 8037/1: mm: support big-endian page tablesJianguo Wu
commit 86f40622af7329375e38f282f6c0aab95f3e5f72 upstream. When enable LPAE and big-endian in a hisilicon board, while specify mem=384M mem=512M@7680M, will get bad page state: Freeing unused kernel memory: 180K (c0466000 - c0493000) BUG: Bad page state in process init pfn:fa442 page:c7749840 count:0 mapcount:-1 mapping: (null) index:0x0 page flags: 0x40000400(reserved) Modules linked in: CPU: 0 PID: 1 Comm: init Not tainted 3.10.27+ #66 [<c000f5f0>] (unwind_backtrace+0x0/0x11c) from [<c000cbc4>] (show_stack+0x10/0x14) [<c000cbc4>] (show_stack+0x10/0x14) from [<c009e448>] (bad_page+0xd4/0x104) [<c009e448>] (bad_page+0xd4/0x104) from [<c009e520>] (free_pages_prepare+0xa8/0x14c) [<c009e520>] (free_pages_prepare+0xa8/0x14c) from [<c009f8ec>] (free_hot_cold_page+0x18/0xf0) [<c009f8ec>] (free_hot_cold_page+0x18/0xf0) from [<c00b5444>] (handle_pte_fault+0xcf4/0xdc8) [<c00b5444>] (handle_pte_fault+0xcf4/0xdc8) from [<c00b6458>] (handle_mm_fault+0xf4/0x120) [<c00b6458>] (handle_mm_fault+0xf4/0x120) from [<c0013754>] (do_page_fault+0xfc/0x354) [<c0013754>] (do_page_fault+0xfc/0x354) from [<c0008400>] (do_DataAbort+0x2c/0x90) [<c0008400>] (do_DataAbort+0x2c/0x90) from [<c0008fb4>] (__dabt_usr+0x34/0x40) The bad pfn:fa442 is not system memory(mem=384M mem=512M@7680M), after debugging, I find in page fault handler, will get wrong pfn from pte just after set pte, as follow: do_anonymous_page() { ... set_pte_at(mm, address, page_table, entry); //debug code pfn = pte_pfn(entry); pr_info("pfn:0x%lx, pte:0x%llxn", pfn, pte_val(entry)); //read out the pte just set new_pte = pte_offset_map(pmd, address); new_pfn = pte_pfn(*new_pte); pr_info("new pfn:0x%lx, new pte:0x%llxn", pfn, pte_val(entry)); ... } pfn: 0x1fa4f5, pte:0xc00001fa4f575f new_pfn:0xfa4f5, new_pte:0xc00000fa4f5f5f //new pfn/pte is wrong. The bug is happened in cpu_v7_set_pte_ext(ptep, pte): An LPAE PTE is a 64bit quantity, passed to cpu_v7_set_pte_ext in the r2 and r3 registers. On an LE kernel, r2 contains the LSB of the PTE, and r3 the MSB. On a BE kernel, the assignment is reversed. Unfortunately, the current code always assumes the LE case, leading to corruption of the PTE when clearing/setting bits. This patch fixes this issue much like it has been done already in the cpu_v7_switch_mm case. Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30ARM: stacktrace: avoid listing stacktrace functions in stacktraceRussell King
commit 3683f44c42e991d313dc301504ee0fca1aeb8580 upstream. While debugging the FEC ethernet driver using stacktrace, it was noticed that the stacktraces always begin as follows: [<c00117b4>] save_stack_trace_tsk+0x0/0x98 [<c0011870>] save_stack_trace+0x24/0x28 ... This is because the stack trace code includes the stack frames for itself. This is incorrect behaviour, and also leads to "skip" doing the wrong thing (which is the number of stack frames to avoid recording.) Perversely, it does the right thing when passed a non-current thread. Fix this by ensuring that we have a known constant number of frames above the main stack trace function, and always skip these. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30s390/lowcore: reserve 96 bytes for IRB in lowcoreChristian Borntraeger
commit 993072ee67aa179c48c85eb19869804e68887d86 upstream. The IRB might be 96 bytes if the extended-I/O-measurement facility is used. This feature is currently not used by Linux, but struct irb already has the emw defined. So let's make the irb in lowcore match the size of the internal data structure to be future proof. We also have to add a pad, to correctly align the paste. The bigger irb field also circumvents a bug in some QEMU versions that always write the emw field on test subchannel and therefore destroy the paste definitions of this CPU. Running under these QEMU version broke some timing functions in the VDSO and all users of these functions, e.g. some JREs. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30arm64: ptrace: change fs when passing kernel pointer to regset codeWill Deacon
commit c168870704bcde6bb63d05f7882b620dd3985a46 upstream. Our compat PTRACE_POKEUSR implementation simply passes the user data to regset_copy_from_user after some simple range checking. Unfortunately, the data in question has already been copied to the kernel stack by this point, so the subsequent access_ok check fails and the ptrace request returns -EFAULT. This causes problems tracing fork() with older versions of strace. This patch briefly changes the fs to KERNEL_DS, so that the access_ok check passes even with a kernel address. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30ARM: OMAP: replace checks for CONFIG_USB_GADGET_OMAPPaul Bolle
commit 77c2f02edbeda9409a7cf3fd66233015820c213a upstream. Commit 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built") apparently required that checks for CONFIG_USB_GADGET_OMAP would be replaced with checks for CONFIG_USB_OMAP. Do so now for the remaining checks for CONFIG_USB_GADGET_OMAP, even though these checks have basically been broken since v3.1. And, since we're touching this code, use the IS_ENABLED() macro, so things will now (hopefully) also work if USB_OMAP is modular. Fixes: 193ab2a60700 ("usb: gadget: allow multiple gadgets to be built") Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26MIPS: KVM: Allocate at least 16KB for exception handlersJames Hogan
commit 7006e2dfda9adfa40251093604db76d7e44263b3 upstream. Each MIPS KVM guest has its own copy of the KVM exception vector. This contains the TLB refill exception handler at offset 0x000, the general exception handler at offset 0x180, and interrupt exception handlers at offset 0x200 in case Cause_IV=1. A common handler is copied to offset 0x2000 and offset 0x3000 is used for temporarily storing k1 during entry from guest. However the amount of memory allocated for this purpose is calculated as 0x200 rounded up to the next page boundary, which is insufficient if 4KB pages are in use. This can lead to the common handler at offset 0x2000 being overwritten and infinitely recursive exceptions on the next exit from the guest. Increase the minimum size from 0x200 to 0x4000 to cover the full use of the page. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: kvm@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Sanjay Lal <sanjayl@kymasys.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26ARM: at91: fix at91_sysirq_mask_rtc for sam9x5 SoCsBoris BREZILLON
commit 9dcc87fec8947308e0111c65dcd881e6aa5b1673 upstream. sam9x5 SoCs have the following errata: "RTC: Interrupt Mask Register cannot be used Interrupt Mask Register read always returns 0." Hence we should not rely on what IMR claims about already masked IRQs and just disable all IRQs. Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com> Reported-by: Bryan Evenson <bevenson@melinkcorp.com> Reviewed-by: Johan Hovold <johan@hovold.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Bryan Evenson <bevenson@melinkcorp.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Roszko <mark.roszko@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26KVM: lapic: sync highest ISR to hardware apic on EOIPaolo Bonzini
commit fc57ac2c9ca8109ea97fcc594f4be436944230cc upstream. When Hyper-V enlightenments are in effect, Windows prefers to issue an Hyper-V MSR write to issue an EOI rather than an x2apic MSR write. The Hyper-V MSR write is not handled by the processor, and besides being slower, this also causes bugs with APIC virtualization. The reason is that on EOI the processor will modify the highest in-service interrupt (SVI) field of the VMCS, as explained in section 29.1.4 of the SDM; every other step in EOI virtualization is already done by apic_send_eoi or on VM entry, but this one is missing. We need to do the same, and be careful not to muck with the isr_count and highest_isr_cache fields that are unused when virtual interrupt delivery is enabled. Reviewed-by: Yang Zhang <yang.z.zhang@intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26net: filter: fix sparc32 typoAlexei Starovoitov
[ Upstream commit 588f5d629b3369aba88f52217d1c473a28fa7723 ] Fixes: 569810d1e327 ("net: filter: fix typo in sparc BPF JIT") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26net: filter: fix typo in sparc BPF JITAlexei Starovoitov
[ Upstream commit 569810d1e3278907264f5b115281fca3f0038d53 ] fix typo in sparc codegen for SKF_AD_IFINDEX and SKF_AD_HATYPE classic BPF extensions Fixes: 2809a2087cc4 ("net: filter: Just In Time compiler for sparc") Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16ARM: mvebu: fix NOR bus-width in Armada XP OpenBlocks AX3 Device TreeThomas Petazzoni
commit 6e20bae8a39c40d4e03698e4160bad2d2629062b upstream. The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus width declared in the Device Tree being considered as a 16 bits bus width when configuring the hardware. This bug in mvebu-devbus driver was compensated by a symetric mistake in the Armada XP OpenBlocks AX3 Device Tree: a 8 bits bus width was declared, even though the hardware actually has a 16 bits bus width connection with the NOR flash. Now that we have fixed the mvebu-devbus driver to behave according to its Device Tree binding, this commit fixes the problematic Device Tree files as well. This bug was introduced in commit a7d4f81821f7eec3175f8e23dd6949c71ab2da43 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board') which was merged in v3.10. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397489361-5833-5-git-send-email-thomas.petazzoni@free-electrons.com Fixes: a7d4f81821f7 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board') Cc: stable@vger.kernel.org # v3.10+ Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16ARM: mvebu: fix NOR bus-width in Armada XP GP Device TreeThomas Petazzoni
commit 1a88f809ccb5db1509a7514b187c00b3a995fc82 upstream. The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus width declared in the Device Tree being considered as a 16 bits bus width when configuring the hardware. This bug in mvebu-devbus driver was compensated by a symetric mistake in the Armada XP GP Device Tree: a 8 bits bus width was declared, even though the hardware actually has a 16 bits bus width connection with the NOR flash. Now that we have fixed the mvebu-devbus driver to behave according to its Device Tree binding, this commit fixes the problematic Device Tree files as well. This bug was introduced in commit da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board') which was merged in v3.10. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board') Cc: stable@vger.kernel.org # v3.10+ Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: perf: hook up perf_sample_event_took around pmu irq handlingWill Deacon
commit 5f5092e72cc25a6a5785308270e0085b2b2772cc upstream. Since we indirect all of our PMU IRQ handling through a dispatcher, it's trivial to hook up perf_sample_event_took to prevent applications such as oprofile from generating interrupt storms due to an unrealisticly low sample period. Reported-by: Robert Richter <rric@kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11perf: Drop sample rate when sampling is too slowDave Hansen
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream. This patch keeps track of how long perf's NMI handler is taking, and also calculates how many samples perf can take a second. If the sample length times the expected max number of samples exceeds a configurable threshold, it drops the sample rate. This way, we don't have a runaway sampling process eating up the CPU. This patch can tend to drop the sample rate down to level where perf doesn't work very well. *BUT* the alternative is that my system hangs because it spends all of its time handling NMIs. I'll take a busted performance tool over an entire system that's busted and undebuggable any day. BTW, my suspicion is that there's still an underlying bug here. Using the HPET instead of the TSC is definitely a contributing factor, but I suspect there are some other things going on. But, I can't go dig down on a bug like that with my machine hanging all the time. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org Cc: acme@ghostprotocols.net Cc: Dave Hansen <dave@sr71.net> [ Prettified it a bit. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: 8051/1: put_user: fix possible data corruption in put_userAndrey Ryabinin
commit 537094b64b229bf3ad146042f83e74cf6abe59df upstream. According to arm procedure call standart r2 register is call-cloberred. So after the result of x expression was put into r2 any following function call in p may overwrite r2. To fix this, the result of p expression must be saved to the temporary variable before the assigment x expression to __r2. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: OMAP4: Fix the boot regression with CPU_IDLE enabledSantosh Shilimkar
commit 4b353a706a86598ba47307c47301c3c428b79e09 upstream. On OMAP4 panda board, there have been several bug reports about boot hang and lock-ups with CPU_IDLE enabled. The root cause of the issue is missing interrupts while in idle state. Commit cb7094e8 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag} moved the broadcast notifiers to common code for right reasons but on OMAP4 which suffers from a nasty ROM code bug with GIC, commit ff999b8a {ARM: OMAP4460: Workaround for ROM bug ..}, we loose interrupts which leads to issues like lock-up, hangs etc. Patch reverts commit cb7094 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag} and 54769d6 {cpuidle: OMAP4: remove timer broadcast initialization} to avoid the issue. With this change, OMAP4 panda boards, the mentioned issues are getting fixed. We no longer loose interrupts which was the cause of the regression. Fixes: cb7094e8 (cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag) Fixes: ff999b8a (cpuidle: OMAP4: remove timer broadcast initialization) Cc: Roger Quadros <rogerq@ti.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Reported-tested-by: Roger Quadros <rogerq@ti.com> Reported-tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: OMAP3: clock: Back-propagate rate change from cam_mclk to dpll4_m5 on ↵Laurent Pinchart
all OMAP3 platforms commit 98d7e1aee6dd534f468993f8c6a1bc730d4cfa81 upstream. Commit 7b2e1277598e4187c9be3e61fd9b0f0423f97986 ("ARM: OMAP3: clock: Back-propagate rate change from cam_mclk to dpll4_m5") enabled clock rate back-propagation from cam_mclk do dpll4_m5 on OMAP3630 only. Perform back-propagation on other OMAP3 platforms as well. Reported-by: Jean-Philippe François <jp.francois@cynove.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: imx: fix error handling in ipu device registrationEmil Goode
commit d1d70e5dc2cfa9047bb935c41ba808ebb8135696 upstream. If we fail to allocate struct platform_device pdev we dereference it after the goto label err. This bug was found using coccinelle. Fixes: afa77ef (ARM: mx3: dynamically allocate "ipu-core" devices) Signed-off-by: Emil Goode <emilgoode@gmail.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07powerpc: Fix 64 bit builds with binutils 2.24Guenter Roeck
commit 7998eb3dc700aaf499f93f50b3d77da834ef9e1d upstream. With binutils 2.24, various 64 bit builds fail with relocation errors such as arch/powerpc/kernel/built-in.o: In function `exc_debug_crit_book3e': (.text+0x165ee): relocation truncated to fit: R_PPC64_ADDR16_HI against symbol `interrupt_base_book3e' defined in .text section in arch/powerpc/kernel/built-in.o arch/powerpc/kernel/built-in.o: In function `exc_debug_crit_book3e': (.text+0x16602): relocation truncated to fit: R_PPC64_ADDR16_HI against symbol `interrupt_end_book3e' defined in .text section in arch/powerpc/kernel/built-in.o The assembler maintainer says: I changed the ABI, something that had to be done but unfortunately happens to break the booke kernel code. When building up a 64-bit value with lis, ori, shl, oris, ori or similar sequences, you now should use @high and @higha in place of @h and @ha. @h and @ha (and their associated relocs R_PPC64_ADDR16_HI and R_PPC64_ADDR16_HA) now report overflow if the value is out of 32-bit signed range. ie. @h and @ha assume you're building a 32-bit value. This is needed to report out-of-range -mcmodel=medium toc pointer offsets in @toc@h and @toc@ha expressions, and for consistency I did the same for all other @h and @ha relocs. Replacing @h with @high in one strategic location fixes the relocation errors. This has to be done conditionally since the assembler either supports @h or @high but not both. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07crypto: s390 - fix aes,des ctr mode concurrency finding.Harald Freudenberger
commit 3901c1124ec5099254a9396085f7798153a7293f upstream. An additional testcase found an issue with the last series of patches applied: the fallback solution may not save the iv value after operation. This very small fix just makes sure the iv is copied back to the walk/desc struct. Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07powerpc/tm: Fix crash when forking inside a transactionMichael Neuling
commit 621b5060e823301d0cba4cb52a7ee3491922d291 upstream. When we fork/clone we currently don't copy any of the TM state to the new thread. This results in a TM bad thing (program check) when the new process is switched in as the kernel does a tmrechkpt with TEXASR FS not set. Also, since R1 is from userspace, we trigger the bad kernel stack pointer detection. So we end up with something like this: Bad kernel stack pointer 0 at c0000000000404fc cpu 0x2: Vector: 700 (Program Check) at [c00000003ffefd40] pc: c0000000000404fc: restore_gprs+0xc0/0x148 lr: 0000000000000000 sp: 0 msr: 9000000100201030 current = 0xc000001dd1417c30 paca = 0xc00000000fe00800 softe: 0 irq_happened: 0x01 pid = 0, comm = swapper/2 WARNING: exception is not recoverable, can't continue The below fixes this by flushing the TM state before we copy the task_struct to the clone. To do this we go through the tmreclaim patch, which removes the checkpointed registers from the CPU and transitions the CPU out of TM suspend mode. Hence we need to call tmrechkpt after to restore the checkpointed state and the TM mode for the current task. To make this fail from userspace is simply: tbegin li r0, 2 sc <boom> Kudos to Adhemerval Zanella Neto for finding this. Signed-off-by: Michael Neuling <mikey@neuling.org> cc: Adhemerval Zanella Neto <azanella@br.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [Backported to 3.10: context adjust] Signed-off-by: Xue Liu <liuxueliu.liu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07x86-64, modify_ldt: Make support for 16-bit segments a runtime optionLinus Torvalds
commit fa81511bb0bbb2b1aace3695ce869da9762624ff upstream. Checkin: b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels disabled 16-bit segments on 64-bit kernels due to an information leak. However, it does seem that people are genuinely using Wine to run old 16-bit Windows programs on Linux. A proper fix for this ("espfix64") is coming in the upcoming merge window, but as a temporary fix, create a sysctl to allow the administrator to re-enable support for 16-bit segments. It adds a "/proc/sys/abi/ldt16" sysctl that defaults to zero (off). If you hit this issue and care about your old Windows program more than you care about a kernel stack address information leak, you can do echo 1 > /proc/sys/abi/ldt16 as root (add it to your startup scripts), and you should be ok. The sysctl table is only added if you have COMPAT support enabled on x86-64, but I assume anybody who runs old windows binaries very much does that ;) Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/CA%2B55aFw9BPoD10U1LfHbOMpHWZkvJTkMcfCs9s3urPr1YyWBxw@mail.gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07metag: Reduce maximum stack size to 256MBJames Hogan
commit d71f290b4e98a39f49f2595a13be3b4d5ce8e1f1 upstream. Specify the maximum stack size for arches where the stack grows upward (parisc and metag) in asm/processor.h rather than hard coding in fs/exec.c so that metag can specify a smaller value of 256MB rather than 1GB. This fixes a BUG on metag if the RLIMIT_STACK hard limit is increased beyond a safe value by root. E.g. when starting a process after running "ulimit -H -s unlimited" it will then attempt to use a stack size of the maximum 1GB which is far too big for metag's limited user virtual address space (stack_top is usually 0x3ffff000): BUG: failure at fs/exec.c:589/shift_arg_pages()! Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: linux-parisc@vger.kernel.org Cc: linux-metag@vger.kernel.org Cc: John David Anglin <dave.anglin@bell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07metag: fix memory barriersMikulas Patocka
commit 2425ce84026c385b73ae72039f90d042d49e0394 upstream. Volatile access doesn't really imply the compiler barrier. Volatile access is only ordered with respect to other volatile accesses, it isn't ordered with respect to general memory accesses. Gcc may reorder memory accesses around volatile access, as we can see in this simple example (if we compile it with optimization, both increments of *b will be collapsed to just one): void fn(volatile int *a, long *b) { (*b)++; *a = 10; (*b)++; } Consequently, we need the compiler barrier after a write to the volatile variable, to make sure that the compiler doesn't reorder the volatile write with something else. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ARM: 8012/1: kdump: Avoid overflow when converting pfn to physaddrLiu Hua
commit 8fad87bca7ac9737e413ba5f1656f1114a8c314d upstream. When we configure CONFIG_ARM_LPAE=y, pfn << PAGE_SHIFT will overflow if pfn >= 0x100000 in copy_oldmem_page. So use __pfn_to_phys for converting. Signed-off-by: Liu Hua <sdu.liu@huawei.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07ARM: dts: i.MX53: Fix ipu register space sizeSascha Hauer
commit 6d66da89bf4422c0a0693627fb3e25f74af50f92 upstream. The IPU register space is 128MB, not 2GB. Fixes: abed9a6bf2bb 'ARM i.MX53: Add IPU support' Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07x86, mm, hugetlb: Add missing TLB page invalidation for hugetlb_cow()Anthony Iliopoulos
commit 9844f5462392b53824e8b86726e7c33b5ecbb676 upstream. The invalidation is required in order to maintain proper semantics under CoW conditions. In scenarios where a process clones several threads, a thread operating on a core whose DTLB entry for a particular hugepage has not been invalidated, will be reading from the hugepage that belongs to the forked child process, even after hugetlb_cow(). The thread will not see the updated page as long as the stale DTLB entry remains cached, the thread attempts to write into the page, the child process exits, or the thread gets migrated to a different processor. Signed-off-by: Anthony Iliopoulos <anthony.iliopoulos@huawei.com> Link: http://lkml.kernel.org/r/20140514092948.GA17391@server-36.huawei.corp Suggested-by: Shay Goikhman <shay.goikhman@huawei.com> Acked-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07genirq: Allow forcing cpu affinity of interruptsThomas Gleixner
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream. The current implementation of irq_set_affinity() refuses rightfully to route an interrupt to an offline cpu. But there is a special case, where this is actually desired. Some of the ARM SoCs have per cpu timers which require setting the affinity during cpu startup where the cpu is not yet in the online mask. If we can't do that, then the local timer interrupt for the about to become online cpu is routed to some random online cpu. The developers of the affected machines tried to work around that issue, but that results in a massive mess in that timer code. We have a yet unused argument in the set_affinity callbacks of the irq chips, which I added back then for a similar reason. It was never required so it got not used. But I'm happy that I never removed it. That allows us to implement a sane handling of the above scenario. So the affected SoC drivers can add the required force handling to their interrupt chip, switch the timer code to irq_force_affinity() and things just work. This does not affect any existing user of irq_set_affinity(). Tagged for stable to allow a simple fix of the affected SoC clock event drivers. Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Tomasz Figa <t.figa@samsung.com>, Cc: Daniel Lezcano <daniel.lezcano@linaro.org>, Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-arm-kernel@lists.infradead.org, Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07mips: dts: Fix missing device_type="memory" property in memory nodesLeif Lindholm
commit dfc44f8030653b345fc6fb337558c3a07536823f upstream. A few platforms lack a 'device_type = "memory"' for their memory nodes, relying on an old ppc quirk in order to discover its memory. Add the missing data so that all parsing code can find memory nodes correctly. Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org> Cc: linux-mips@linux-mips.org Cc: devicetree@vger.kernel.org Cc: Mark Rutland <mark.rutland@arm.com> Acked-by: John Crispin <blogic@openwrt.org> Signed-off-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-30parisc: fix epoll_pwait syscall on compat kernelHelge Deller
commit ab3e55b119c9653b19ea4edffb86f04db867ac98 upstream. This bug was detected with the libio-epoll-perl debian package where the test case IO-Ppoll-compat.t failed. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-30powerpc: Add vr save/restore functionsAndreas Schwab
commit 8fe9c93e7453e67b8bd09f263ec1bb0783c733fc upstream. GCC 4.8 now generates out-of-line vr save/restore functions when optimizing for size. They are needed for the raid6 altivec support. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-30ARM: multi_v7_defconfig: enable ARM_ATAG_DTB_COMPATOlof Johansson
commit a0396b9bd5a4a7baf598b60d2ca53c605c440a42 upstream. Without this, legacy platforms that can boot with a multiplatform kernel but that need the DTB to be appended, won't have a way to pass firmware-set bootargs to the kernel. This is needed to boot multi_v7_defconfig on snowball, for instance. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Kevin Hilman <khilman@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-30arm: multi_v7_defconfig: Enable initrd/initramfs supportSoren Brinkmann
commit c12d82b84353784f8233c28ee43cec0ac9fbd7d2 upstream. Add CONFIG_BLK_DEV_INITRD to the defconfig to support initramfs and initrd. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
