commit 98e4cff73a18af27f0d40d0b0d37f105dfc1994a upstream.
Fixes klibc build on ia64 after 85f8f7759e418c814ee2ceacf73eddb9bed39492.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Signed-off-by: maximilian attems <max@stro.at>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit c0525a6972d3f1fb83058ef503e183475d6e4e26 upstream.
When an NMI goes off and it sees that it preempted the debug stack,
to keep the debug stack safe, it changes the IDT to point to one that
does not modify the stack on breakpoint (to allow breakpoints in NMIs).
But the variable that gets set to know to undo it on exit never gets
cleared on exit. Thus every NMI will reset it on exit the first time
it is done even if it does not need to be reset.
[ Added H. Peter Anvin's suggestion to use this_cpu_read/write ]
commit bad1a753d4d4deb09d4bc0bac1dd4fc3298502e9 upstream.
When I added x32 ptrace to 3.4 kernel, I also include PTRACE_ARCH_PRCTL
support for x32 GDB For ARCH_GET_FS/GS, it takes a pointer to int64. But
at user level, ARCH_GET_FS/GS takes a pointer to int32. So I have to add
x32 ptrace to glibc to handle it with a temporary int64 passed to kernel and
copy it back to GDB as int32. Roland suggested that PTRACE_ARCH_PRCTL
is obsolete and x32 GDB should use fs_base and gs_base fields of
user_regs_struct instead.
Accordingly, remove PTRACE_ARCH_PRCTL completely from the x32 code to
avoid possible memory overrun when pointer to int32 is passed to
kernel.
Link: http://lkml.kernel.org/r/CAMe9rOpDzHfS7NH7m1vmD9QRw8SSj4Sc%2BaNOgcWm_WJME2eRsQ@mail.gmail.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 1ab46fd319bcf1fcd9fb6311727d532b580e4eba upstream.
Stub out MSR methods that aren't actually needed. This fixes a crash
as Xen Dom0 on AMD Trinity systems. A bigger patch should be added to
remove the paravirt machinery completely for the methods which
apparently have no users!
Reported-by: Andre Przywara <andre.przywara@amd.com>
Link: http://lkml.kernel.org/r/20120530222356.GA28417@andromeda.dapyr.net
commit 9dde0ae3769875ec1370cb316e50c54b57d52c1a upstream.
Once again, ixp4xx no longer even compiles. This patch fixes the issue
by converting over to gpiolib. This patch was first made by Imre and
posted by Marc, and I added in Russell's suggestion to empty the gpio
header file.
This fix should also go for 3.1, 3.2, 3.3, and 3.4.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
commit 442209f31dafef9fde852858e1ce566b675b720d upstream.
bcm63xx_gpio.h uses macros defined in bcm63xx_cpu.h without including it,
leading to the following build failure:
CC [M] drivers/mmc/core/cd-gpio.o
In file included from arch/mips/include/asm/mach-bcm63xx/gpio.h:4:0,
from arch/mips/include/asm/gpio.h:4,
from include/linux/gpio.h:30,
from drivers/mmc/core/cd-gpio.c:12:
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h: In function 'bcm63xx_gpio_count':
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:10:2: error: implicit declaration of function 'bcm63xx_get_cpu_id'
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:11:7: error: 'BCM6358_CPU_ID' undeclared (first use in this function)
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:11:7: note: each undeclared identifier is reported only once for each function it appears in
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:13:7: error: 'BCM6338_CPU_ID' undeclared (first use in this function)
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:15:7: error: 'BCM6345_CPU_ID' undeclared (first use in this function)
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:17:7: error: 'BCM6368_CPU_ID' undeclared (first use in this function)
arch/mips/include/asm/mach-bcm63xx/bcm63xx_gpio.h:19:7: error: 'BCM6348_CPU_ID' undeclared (first use in this function)
make[7]: *** [drivers/mmc/core/cd-gpio.o] Error 1
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: Maxime Bizon <mbizon@freebox.fr>
Cc: Florian Fainelli <florian@openwrt.org>
commit 2f649c1f6f0fef445ce79a19b79e5ce8fe9d7f19 upstream.
commit 5e185581d7c46ddd33cd9c01106d1fc86efb9376
Author: James Bottomley <JBottomley@Parallels.com>
[PARISC] fix PA1.1 oops on boot
Didn't quite fix the crash on boot. It moved it from PA1.1 processors to
PA2.0 narrow kernels. The final fix is to make sure the [id]tlb_miss_20 paths
also work. Even on narrow systems, these paths require using the wide
instructions becuase the tlb insertion format is wide. Fix this by
conditioning the dep[wd],z on whether we're being called from _11 or _20[w]
paths.
Tested-by: Helge Deller <deller@gmx.de>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
before .text
commit ed5fb2471b7060767957fb964eb1aaec71533ab1 upstream.
In certain configurations, the resulting kernel becomes too large to boot
because the linker places the long branch stubs for the merged .text section
at the very start of the image. As a result, the initial transfer of control
jumps to an unexpected location. Fix this by placing the head text in a
separate section so the stubs for .text are not at the start of the image.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
commit 59516b07b4ffa7e607a5787674ea3c405f1b390c upstream.
The microblaze architecture does not provide a native GPIO API implementation
nor requires GPIOLIB, but still selects GENERIC_GPIO by default. As a result the
following build error occurs, if GPIOLIB is not selected:
include/asm-generic/gpio.h: In function 'gpio_get_value_cansleep':
include/asm-generic/gpio.h:218: error: implicit declaration of function '__gpio_get_value'
include/asm-generic/gpio.h: In function 'gpio_set_value_cansleep':
include/asm-generic/gpio.h:224: error: implicit declaration of function '__gpio_set_value'
This patch addresses the issue by not selecting GENERIC_GPIO by default. This
causes the GPIO API to be stubbed out if no implementation is provided.
Tested-by: Michal Simek <monstr@monstr.eu>
commit a129a7c84582629741e5fa6f40026efcd7a65bd4 upstream.
When running on 32bit the mce handler could misinterpret
vm86 mode as ring 0. This can affect whether it does recovery
or not; it was possible to panic when recovery was actually
possible.
Fix this by always forcing vm86 to look like ring 3.
commit 1dfebb426cfd16e2080f8c95e00ca2462f2325d4 upstream.
Cardhu's eMMC controller is on sdhci@78000600, not sdhci@78000400.
Fix the typo. This roughly doubles the IO performance, since the
support-8bit property actually takes effect.
commit 435a7ef52db7d86e67a009b36cac1457f8972391 upstream.
We can't be holding the mmap_sem while calling flush_cache_user_range
because the flush can fault. If we fault on a user address, the
page fault handler will try to take mmap_sem again. Since both places
acquire the read lock, most of the time it succeeds. However, if another
thread tries to acquire the write lock on the mmap_sem (e.g. mmap) in
between the call to flush_cache_user_range and the fault, the down_read
in do_page_fault will deadlock.
[will: removed drop of vma parameter as already queued by rmk (7365/1)]
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Dima Zavin <dima@android.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 4542b6a0fa6b48d9ae6b41c1efeb618b7a221b2a upstream.
vma isn't used and flush_cache_user_range isn't a standard macro that
is used on several archs with the same prototype. In fact only unicore32
has a macro with the same name (with an identical implementation and no
in-tree users).
This is a part of a patch proposed by Dima Zavin (with Message-id:
1272439931-12795-1-git-send-email-dima@android.com) that didn't get
accepted.
Cc: Dima Zavin <dima@android.com>
commit 9f1d62bed7f015d11b9164078b7fea433b474114 upstream.
This is because __builtin_clz(0) returns 64 for the "undefined" case
of 0, since the builtin just does a right-shift 32 and "clz" instruction.
So, use the alpha approach of casting to u32 and using __builtin_clzll().
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
commit 875e26648cf9b6db9d8dc07b7959d7c61fb3f49c upstream.
Linus pointed out that there was no value is checking whether m->ip
was zero - because zero is a legimate value. If we have a reliable
(or faked in the VM86 case) "m->cs" we can use it to tell whether we
were in user mode or kernelwhen the machine check hit.
Reported-by: Linus Torvalds <torvalds@linuxfoundation.org>
commit ea17e7414bc62e8d3bde8d08e3df1d921c518c17 upstream.
The symbol jiffies is created in the linker script as an alias to
jiffies_64. Unfortunately this is done outside any section, and
apparently GNU ld 2.21 doesn't carry the section with it, so we end up
with an absolute symbol and therefore a broken kernel.
Add jiffies and jiffies_64 to the whitelist.
The most disturbing bit with this discovery is that it shows that we
have had multiple linker bugs in this area crossing multiple
generations, and have been silently building bad kernels for some time.
Link: http://lkml.kernel.org/r/20120524171604.0d98284f3affc643e9714470@canb.auug.org.au
commit fd952815307f0f272bf49fd364a7fd2f9992bc42 upstream.
As noted in checkin:
a3e854d95 x86, relocs: Workaround for binutils 2.22.52.0.1 section bug
ld version 2.22.52.0.[12] can incorrectly promote relative symbols to
absolute, if the output section they appear in is otherwise empty.
Since checkin:
6520fe55 x86, realmode: 16-bit real-mode code support for relocs tool
we actually check for this and error out rather than silently creating
a kernel which will malfunction if relocated.
Ingo found a configuration in which __start_builtin_fw triggered the
warning.
Go through the linker script sources and look for more symbols that
could plausibly get bogusly promoted to absolute, and add them to the
whitelist.
In general, if the following error triggers:
Invalid absolute R_386_32 relocation: <symbol>
... then we should verify that <symbol> is really meant to be
relocated, and add it and any related symbols manually to the S_REL
regexp.
Please note that 6520fe55 does not introduce the error, only the check
for the error -- without 6520fe55 this version of ld will simply
produce a corrupt kernel if CONFIG_RELOCATABLE is set on x86-32.
Reported-by: Ingo Molnar <mingo@kernel.org>
commit b2d668da9307c4c163dd603d2bb3cadb10f9fd37 upstream.
relocs was not cleaned up when "make clean" is issued. This
patch fixes the issue.
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
Link: http://lkml.kernel.org/r/1337622684-6834-1-git-send-email-jarkko.sakkinen@intel.com
commit 68c2c39a76b094e9b2773e5846424ea674bf2c46 upstream.
PV on HVM guests map GSIs into event channels. At restore time the
event channels are resumed by restore_pirqs.
Device drivers might try to register the same GSI again through ACPI at
restore time, but the GSI has already been mapped and bound by
restore_pirqs. This patch detects these situations and avoids
mapping the same GSI multiple times.
Without this patch we get:
(XEN) irq.c:2235: dom4: pirq 23 or emuirq 28 already mapped
and waste a pirq.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit f15b9000eb1d09bbaa4b0a6b2089d7e1f64e84b3 upstream.
UML uses the _PAGE_NEWPAGE flag to mark pages which are not jet
installed on the host side using mmap().
pte_same() has to ignore this flag, otherwise unuse_pte_range()
is unable to unuse the page because two identical
page tables entries with different _PAGE_NEWPAGE flags would not
match and swapoff() would never return.
Analyzed-by: Hugh Dickins <hughd@google.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 2b76ebaa728f8a3967c52aa189261c72fe56a6f1 upstream.
The current __swp_type() function uses a too small bitshift.
Using more than one swap files causes bad pages because
the type bits clash with other page flags.
commit 5bcdf5e4fee3c45e1281c25e4941f2163cb28c65 upstream.
This update is for newer family 15h cpu models from 0x02 to 0x1f.
Signed-off-by: Robert Richter <robert.richter@amd.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1337337642-1621-1-git-send-email-robert.richter@amd.com
commit 45de6767dc51358a188f75dc4ad9dfddb7fb9480 upstream.
Use the 32-bit compat keyctl() syscall wrapper on Sparc64 for Sparc32 binary
compatibility.
Without this, keyctl(KEYCTL_INSTANTIATE_IOV) is liable to malfunction as it
uses an iovec array read from userspace - though the kernel should survive this
as it checks pointers and sizes anyway.
I think all the other keyctl() function should just work, provided (a) the top
32-bits of each 64-bit argument register are cleared prior to invoking the
syscall routine, and the 32-bit address space is right at the 0-end of the
64-bit address space. Most of the arguments are 32-bit anyway, and so for
those clearing is not required.
Signed-off-by: David Howells <dhowells@redhat.com
cc: "David S. Miller" <davem@davemloft.net>
cc: sparclinux@vger.kernel.org
commit 9cd75e13de2dcf32ecc21c7f277cff3c0ced059e upstream.
commit 771dae818 (powerpc/cpuidle: Add cpu_idle_wait() to allow
switching of idle routines) implemented cpu_idle_wait() for powerpc.
The changelog says:
"The equivalent routine for x86 is in arch/x86/kernel/process.c
but the powerpc implementation is different.":
Unfortunately the changelog is completely useless as it does not tell
_WHY_ it is different.
Aside of being different the implementation is patently wrong.
The rescheduling IPI is async. That means that there is no guarantee,
that the other cores have executed the IPI when cpu_idle_wait()
returns. But that's the whole purpose of this function: to guarantee
that no CPU uses the old idle handler anymore.
Use the smp_functional_call() based implementation, which fulfils the
requirements.
[ This code is going to replaced by a core version to remove all the
pointless copies in arch/*, but this one should go to stable ]
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Trinabh Gupta <g.trinabh@gmail.com>
Cc: Arun R Bharadwaj <arun.r.bharadwaj@gmail.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Link: http://lkml.kernel.org/r/20120507175651.980164748@linutronix.de
commit d5e50a51ccbda36b379aba9d1131a852eb908dda upstream.
When setting the current task state to TASK_UNINTERRUPTIBLE this can
race with a different cpu. The other cpu could set the task state after
it inspected it (while it was still TASK_RUNNING) to TASK_RUNNING which
would change the state from TASK_UNINTERRUPTIBLE to TASK_RUNNING again.
This race was always present in the pfault interrupt code but didn't
cause anything harmful before commit f2db2e6c "[S390] pfault: cpu hotplug
vs missing completion interrupts" which relied on the fact that after
setting the task state to TASK_UNINTERRUPTIBLE the task would really
sleep.
Since this is not necessarily the case the result may be a list corruption
of the pfault_list or, as observed, a use-after-free bug while trying to
access the task_struct of a task which terminated itself already.
To fix this, we need to get a reference of the affected task when receiving
the initial pfault interrupt and add special handling if we receive yet
another initial pfault interrupt when the task is already enqueued in the
pfault list.
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6
Pull PA-RISC fixes from James Bottomley:
"This is a set of three bug fixes that gets parisc running again on
systems with PA1.1 processors.
Two fix regressions introduced in 2.6.39 and one fixes a prefetch bug
that only affects PA7300LC processors. We also have another pending
fix to do with the sectional arrangement of vmlinux.lds, but there's a
query on it during testing on one particular system type, so I'll hold
off sending it in for now."
* tag 'parisc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6:
[PARISC] fix panic on prefetch(NULL) on PA7300LC
[PARISC] fix crash in flush_icache_page_asm on PA1.1
Pull x86 linker bug workarounds from Peter Anvin.
GNU ld-2.22.52.0.[12] (*) has an unfortunate bug where it incorrectly
turns certain relocation entries absolute. Section-relative symbols
that are part of otherwise empty sections are silently changed them to
absolute. We rely on section-relative symbols staying section-relative,
and actually have several sections in the linker script solely for this
purpose.
See for example
http://sourceware.org/bugzilla/show_bug.cgi?id=14052
We could just black-list the buggy linker, but it appears that it got
shipped in at least F17, and possibly other distros too, so it's sadly
not some rare unusual case.
This backports the workaround from the x86/trampoline branch, and as
Peter says: "This is not a minimal fix, not at all, but it is a tested
code base."
* 'x86/ld-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, relocs: When printing an error, say relative or absolute
(*) That's a manly release numbering system. Stupid, sure. But manly.
When the relocs tool throws an error, let the error message say if it
is an absolute or relative symbol. This should make it a lot more
clear what action the programmer needs to take and should help us find
the reason if additional symbol bugs show up.
Cc: <stable@vger.kernel.org>
GNU ld 2.22.52.0.1 has a bug that it blindly changes symbols from
section-relative to absolute if they are in a section of zero length.
This turns the symbols __init_begin and __init_end into absolute
symbols. Let the relocs program know that those should be treated as
relative symbols.
Cc: H.J. Lu <hjl.tools@gmail.com>
Cc: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
A new option is added to the relocs tool called '--realmode'.
This option causes the generation of 16-bit segment relocations
and 32-bit linear relocations for the real-mode code. When
the real-mode code is moved to the low-memory during kernel
initialization, these relocation entries can be used to
relocate the code properly.
In the assembly code 16-bit segment relocations must be relative
to the 'real_mode_seg' absolute symbol. Linear relocations must be
relative to a symbol prefixed with 'pa_'.
16-bit segment relocation is used to load cs:ip in 16-bit code.
Linear relocations are used in the 32-bit code for relocatable
data references. They are declared in the linker script of the
real-mode code.
The relocs tool is moved to arch/x86/tools/relocs.c, and added new
target archscripts that can be used to build scripts needed building
an architecture. be compiled before building the arch/x86 tree.
[ hpa: accelerating this because it detects invalid absolute
relocations, a serious bug in binutils 2.22.52.0.x which currently
produces bad kernels. ]
Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull tile tree bugfix from Chris Metcalf:
"This fixes a security vulnerability (and correctness bug) in tilegx"
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tilegx: enable SYSCALL_WRAPPERS support
Merge misc fixes from Andrew Morton.
* emailed from Andrew Morton <akpm@linux-foundation.org>: (4 patches)
frv: delete incorrect task prototypes causing compile fail
slub: missing test for partial pages flush work in flush_all()
fs, proc: fix ABBA deadlock in case of execution attempt of map_files/ entries
drivers/rtc/rtc-pl031.c: configure correct wday for 2000-01-01
Some discussion with the glibc mailing lists revealed that this was
necessary for 64-bit platforms with MIPS-like sign-extension rules
for 32-bit values. The original symptom was that passing (uid_t)-1 to
setreuid() was failing in programs linked -pthread because of the "setxid"
mechanism for passing setxid-type function arguments to the syscall code.
SYSCALL_WRAPPERS handles ensuring that all syscall arguments end up with
proper sign-extension and is thus the appropriate fix for this problem.
On other platforms (s390, powerpc, sparc64, and mips) this was fixed
in 2.6.28.6. The general issue is tracked as CVE-2009-0029.
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras
Pull a machine check recovery fix from Tony Luck.
I really don't like how the MCE code does some of the things it does,
but this does seem to be an improvement.
* tag 'linus-mce-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras:
x86/mce: Only restart instruction after machine check recovery if it is safe
Commit 41101809a865 ("fork: Provide weak arch_release_[task_struct|
thread_info] functions") in -tip highlights a problem in the frv arch,
where it has needles prototypes for alloc_task_struct_node and
free_task_struct. This now shows up as:
kernel/fork.c:120:66: error: static declaration of 'alloc_task_struct_node' follows non-static declaration
kernel/fork.c:127:51: error: static declaration of 'free_task_struct' follows non-static declaration
since that commit turned them into real functions. Since arch/frv does
does not define define __HAVE_ARCH_TASK_STRUCT_ALLOCATOR (i.e. it just
uses the generic ones) it shouldn't list these at all.
Pull ARM fixes from Russell King:
"Small set of fixes again."
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7419/1: vfp: fix VFP flushing regression on sigreturn path
ARM: 7418/1: LPAE: fix access flag setup in mem_type_table
ARM: prevent VM_GROWSDOWN mmaps extending below FIRST_USER_ADDRESS
ARM: 7417/1: vfp: ensure preemption is disabled when enabling VFP access
Pull ARM: SoC fixes from Olof Johansson:
"I will stop trying to predict when we're done with fixes for a
release.
Here's another small batch of three patches for arm-soc:
- A fix for a boot time WARN_ON() due to irq domain conversion on
PRIMA2
- Fix for a regression in Tegra SMP spinup code due to swapped
register offsets
- Fixed config dependency for mv_cesa crypto driver to avoid build
breakage"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: PRIMA2: fix irq domain size and IRQ mask of internal interrupt controller
crypto: mv_cesa requires on CRYPTO_HASH to build
ARM: tegra: Fix flow controller accesses
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull perf, x86 and scheduler updates from Ingo Molnar.
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tracing: Do not enable function event with enable
perf stat: handle ENXIO error for perf_event_open
perf: Turn off compiler warnings for flex and bison generated files
perf stat: Fix case where guest/host monitoring is not supported by kernel
perf build-id: Fix filename size calculation
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, kvm: KVM paravirt kernels don't check for CPUID being unavailable
x86: Fix section annotation of acpi_map_cpu2node()
x86/microcode: Ensure that module is only loaded on supported Intel CPUs
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Fix KVM and ia64 boot crash due to sched_groups circular linked list assumption
Commit ff9a184c ("ARM: 7400/1: vfp: clear fpscr length and stride bits
on entry to sig handler") flushes the VFP state prior to entering a
signal handler so that a VFP operation inside the handler will trap and
force a restore of ABI-compliant registers. Reflushing and disabling VFP
on the sigreturn path is predicated on the saved thread state indicating
that VFP was used by the handler -- however for SMP platforms this is
only set on context-switch, making the check unreliable and causing VFP
register corruption in userspace since the register values are not
necessarily those restored from the sigframe.
This patch unconditionally flushes the VFP state after a signal handler.
Since we already perform the flush before the handler and the flushing
itself happens lazily, the redundant flush when VFP is not used by the
handler is essentially a nop.
Reported-by: Jon Medhurst <tixy@linaro.org>
Signed-off-by: Jon Medhurst <tixy@linaro.org>
A zero value for prot_sect in the memory types table implies that
section mappings should never be created for the memory type in question.
This is checked for in alloc_init_section().
With LPAE, we set a bit to mask access flag faults for kernel mappings.
This breaks the aforementioned (!prot_sect) check in alloc_init_section().
This patch fixes this bug by first checking for a non-zero
prot_sect before setting the PMD_SECT_AF flag.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
the old codes will cause 3.4 kernel warning as irq domain size is wrong:
WARNING: at kernel/irq/irqdomain.c:74 irq_domain_legacy_revmap+0x24/0x48()
Modules linked in:
[<c0013f50>] (unwind_backtrace+0x0/0xf8) from [<c001e7d8>] (warn_slowpath_common+0x54/0x64)
[<c001e7d8>] (warn_slowpath_common+0x54/0x64) from [<c001e804>] (warn_slowpath_null+0x1c/0x24)
[<c001e804>] (warn_slowpath_null+0x1c/0x24) from [<c005c3c4>] (irq_domain_legacy_revmap+0x24/0x48)
[<c005c3c4>] (irq_domain_legacy_revmap+0x24/0x48) from [<c005c704>] (irq_create_mapping+0x20/0x120)
[<c005c704>] (irq_create_mapping+0x20/0x120) from [<c005c880>] (irq_create_of_mapping+0x7c/0xf0)
[<c005c880>] (irq_create_of_mapping+0x7c/0xf0) from [<c01a6c48>] (irq_of_parse_and_map+0x2c/0x34)
[<c01a6c48>] (irq_of_parse_and_map+0x2c/0x34) from [<c01a6c68>] (of_irq_to_resource+0x18/0x74)
[<c01a6c68>] (of_irq_to_resource+0x18/0x74) from [<c01a6ce8>] (of_irq_count+0x24/0x34)
[<c01a6ce8>] (of_irq_count+0x24/0x34) from [<c01a7220>] (of_device_alloc+0x58/0x158)
[<c01a7220>] (of_device_alloc+0x58/0x158) from [<c01a735c>] (of_platform_device_create_pdata+0x3c/0x80)
[<c01a735c>] (of_platform_device_create_pdata+0x3c/0x80) from [<c01a7468>] (of_platform_bus_create+0xc8/0x190)
[<c01a7468>] (of_platform_bus_create+0xc8/0x190) from [<c01a74cc>] (of_platform_bus_create+0x12c/0x190)
---[ end trace 1b75b31a2719ed32 ]---
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Pull kvm powerpc fixes from Marcelo Tosatti:
"Urgent KVM PPC updates, quoting Alexander Graf:
There are a few bugs in 3.4 that really should be fixed before
people can be all happy and fuzzy about KVM on PowerPC. These fixes
are:
* fix POWER7 bare metal with PR=y
* fix deadlock on HV=y book3s_64 mode in low memory cases
* fix invalid MMU scope of PR=y mode on book3s_64, possibly eading
to memory corruption"
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: PPC: Book3S HV: Fix bug leading to deadlock in guest HPT updates
powerpc/kvm: Fix VSID usage in 64-bit "PR" KVM
KVM: PPC: Book3S: PR: Fix hsrr code
KVM: PPC: Fix PR KVM on POWER7 bare metal
KVM: PPC: Book3S: PR: Handle EMUL_ASSIST
Pull two Tile arch fixes from Chris Metcalf:
"These are both bug-fixes, one to avoid some issues in how we invoke
the "pending userspace work" flags on return to userspace, and the
other to provide the same signal handler arguments for tilegx32 that
we do for tilegx64."
arch/tile: apply commit 74fca9da0 to the compat signal handling as well
arch/tile: fix up some issues in calling do_work_pending()
This passes siginfo and mcontext to tilegx32 signal handlers that
don't have SA_SIGINFO set just as we have been doing for tilegx64.
Cc: stable@vger.kernel.org
First, we were at risk of handling thread-info flags, in particular
do_signal(), when returning from kernel space. This could happen
after a failed kernel_execve(), or when forking a kernel thread.
The fix is to test in do_work_pending() for user_mode() and return
immediately if so; we already had this test for one of the flags,
so I just hoisted it to the top of the function.
Second, if a ptraced process updated the callee-saved registers
in the ptregs struct and then processed another thread-info flag, we
would overwrite the modifications with the original callee-saved
registers. To fix this, we add a register to note if we've already
saved the registers once, and skip doing it on additional passes
through the loop. To avoid a performance hit from the couple of
extra instructions involved, I modified the GET_THREAD_INFO() macro
to be guaranteed to be one instruction, then bundled it with adjacent
instructions, yielding an overall net savings.
Reported-By: Al Viro <viro@ZenIV.linux.org.uk>
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
When handling the H_BULK_REMOVE hypercall, we were forgetting to
invalidate and unlock the hashed page table entry (HPTE) in the case
where the page had been paged out. This fixes it by clearing the
first doubleword of the HPTE in that case.
This fixes a regression introduced in commit a92bce95f0 ("KVM: PPC:
Book3S HV: Keep HPTE locked when invalidating"). The effect of the
regression is that the host kernel will sometimes hang when under
memory pressure.
The code forgot to scramble the VSIDs the way we normally do
and was basically using the "proto VSID" directly with the MMU.
This means that in practice, KVM used random VSIDs that could
collide with segments used by other user space programs.
[agraf: simplify ppc32 case]
When jumping back into the kernel to code that knows that it would be
using HSRR registers instead of SRR registers, we need to make sure we
pass it all information on where to jump to in HSRR registers.
Unfortunately, we used r10 to store the information to distinguish between
the HSRR and SRR case. That register got clobbered in between though,
rendering the later comparison invalid.
Instead, let's use cr1 to store this information. That way we don't
need yet another register and everyone's happy.
This fixes PR KVM on POWER7 bare metal for me.
When running on a system that is HV capable, some interrupts use HSRR
SPRs instead of the normal SRR SPRs. These are also used in the Linux
handlers to jump back to code after an interrupt got processed.
Unfortunately, in our "jump back to the real host handler after we've
done the context switch" code, we were only setting the SRR SPRs,
rendering Linux to jump back to some invalid IP after it's processed
the interrupt.
This fixes random crashes on p7 opal mode with PR KVM for me.
