commit f03574f2d5b2d6229dcdf2d322848065f72953c7 upstream.
This code was an optimization for 32-bit NUMA systems.
It has probably been the cause of a number of subtle bugs over
the years, although the conditions to excite them would have
been hard to trigger. Essentially, we remap part of the kernel
linear mapping area, and then sometimes part of that area gets
freed back in to the bootmem allocator. If those pages get
used by kernel data structures (say mem_map[] or a dentry),
there's no big deal. But, if anyone ever tried to use the
linear mapping for these pages _and_ cared about their physical
address, bad things happen.
For instance, say you passed __GFP_ZERO to the page allocator
and then happened to get handed one of these pages, it zero the
remapped page, but it would make a pte to the _old_ page.
There are probably a hundred other ways that it could screw
with things.
We don't need to hang on to performance optimizations for
these old boxes any more. All my 32-bit NUMA systems are long
dead and buried, and I probably had access to more than most
people.
This code is causing real things to break today:
https://lkml.org/lkml/2013/1/9/376
I looked in to actually fixing this, but it requires surgery
to way too much brittle code, as well as stuff like
per_cpu_ptr_to_phys().
[ hpa: Cc: this for -stable, since it is a memory corruption issue.
However, an alternative is to simply mark NUMA as depends BROKEN
rather than EXPERIMENTAL in the X86_32 subclause... ]
Link: http://lkml.kernel.org/r/20130131005616.1C79F411@kernel.stglabs.ibm.com
Cc: Jiri Slaby <jslaby@suse.cz>
performed before the ANDCOND test
commit 9fb2640159f9d4f5a2a9d60e490482d4cbecafdb upstream.
Some versions of pHyp will perform the adjunct partition test before the
ANDCOND test. The result of this is that H_RESOURCE can be returned and
cause the BUG_ON condition to occur. The HPTE is not removed. So add a
check for H_RESOURCE, it is ok if this HPTE is not removed as
pSeries_lpar_hpte_remove is looking for an HPTE to remove and not a
specific HPTE to remove. So it is ok to just move on to the next slot
and try again.
Signed-off-by: Michael Wolf <mjw@linux.vnet.ibm.com>
commit aa8b4be3ac049c8b1df2a87e4d1d902ccfc1f7a9 upstream.
Fixes a NULL pointer dereference at boot on UP1500.
Reviewed-and-Tested-by: Matt Turner <mattst88@gmail.com>
Signed-off-by: Jay Estabrook <jay.estabrook@gmail.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
commit c2a2876e863356b092967ea62bebdb4dd663af80 upstream.
There is a bug introduced with commit 27c2127 that causes
devices which are hot unplugged and then hot-replugged to
not have per-device dma_ops set. This causes these devices
to not function correctly. Fixed with this patch.
Reported-by: Andreas Degert <andreas.degert@googlemail.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit 6d1068b3a98519247d8ba4ec85cd40ac136dbdf9 upstream.
On hosts without the XSAVE support unprivileged local user can trigger
oops similar to the one below by setting X86_CR4_OSXSAVE bit in guest
cr4 register using KVM_SET_SREGS ioctl and later issuing KVM_RUN
ioctl.
invalid opcode: 0000 [#2] SMP
Modules linked in: tun ip6table_filter ip6_tables ebtable_nat ebtables
Pid: 24935, comm: zoog_kvm_monito Tainted: G D 3.2.0-3-686-pae
EIP: 0060:[<f8b9550c>] EFLAGS: 00210246 CPU: 0
EIP is at kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm]
EAX: 00000001 EBX: 000f387e ECX: 00000000 EDX: 00000000
ESI: 00000000 EDI: 00000000 EBP: ef5a0060 ESP: d7c63e70
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process zoog_kvm_monito (pid: 24935, ti=d7c62000 task=ed84a0c0
task.ti=d7c62000)
Stack:
00000001 f70a1200 f8b940a9 ef5a0060 00000000 00200202 f8769009 00000000
ef5a0060 000f387e eda5c020 8722f9c8 00015bae 00000000 ed84a0c0 ed84a0c0
c12bf02d 0000ae80 ef7f8740 fffffffb f359b740 ef5a0060 f8b85dc1 0000ae80
Call Trace:
[<f8b940a9>] ? kvm_arch_vcpu_ioctl_set_sregs+0x2fe/0x308 [kvm]
[<c12bfb44>] ? syscall_call+0x7/0xb
Code: 89 e8 e8 14 ee ff ff ba 00 00 04 00 89 e8 e8 98 48 ff ff 85 c0 74
1e 83 7d 48 00 75 18 8b 85 08 07 00 00 31 c9 8b 95 0c 07 00 00 <0f> 01
d1 c7 45 48 01 00 00 00 c7 45 1c 01 00 00 00 0f ae f0 89
EIP: [<f8b9550c>] kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] SS:ESP
0068:d7c63e70
QEMU first retrieves the supported features via KVM_GET_SUPPORTED_CPUID
and then sets them later. So guest's X86_FEATURE_XSAVE should be masked
out on hosts without X86_FEATURE_XSAVE, making kvm_set_cr4 with
X86_CR4_OSXSAVE fail. Userspaces that allow specifying guest cpuid with
X86_FEATURE_XSAVE even on hosts that do not support it, might be
susceptible to this attack from inside the guest as well.
Allow setting X86_CR4_OSXSAVE bit only if host has XSAVE support.
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 3e515705a1f46beb1c942bb8043c16f8ac7b1e9e upstream.
If some vcpus are created before KVM_CREATE_IRQCHIP, then
irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading
to potential NULL pointer dereferences.
Fix by:
- ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called
- ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP
This is somewhat long winded because vcpu->arch.apic is created without
kvm->lock held.
Based on earlier patch by Michael Ellerman.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Avi Kivity <avi@redhat.com>
commit 0924ab2cfa98b1ece26c033d696651fd62896c69 upstream.
User space may create the PIT and forgets about setting up the irqchips.
In that case, firing PIT IRQs will crash the host:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000128
IP: [<ffffffffa10f6280>] kvm_set_irq+0x30/0x170 [kvm]
Call Trace:
[<ffffffffa11228c1>] pit_do_work+0x51/0xd0 [kvm]
[<ffffffff81071431>] process_one_work+0x111/0x4d0
[<ffffffff81071bb2>] worker_thread+0x152/0x340
[<ffffffff81075c8e>] kthread+0x7e/0x90
[<ffffffff815a4474>] kernel_thread_helper+0x4/0x10
Prevent this by checking the irqchip mode before starting a timer. We
can't deny creating the PIT if the irqchips aren't set up yet as
current user land expects this order to work.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit d780592b99d7d8a5ff905f6bacca519d4a342c76 upstream.
So far kvm_arch_vcpu_setup is responsible for freeing the vcpu struct if
it fails. Move this confusing resonsibility back into the hands of
kvm_vm_ioctl_create_vcpu. Only kvm_arch_vcpu_setup of x86 is affected,
all other archs cannot fail.
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
commit 66db3feb486c01349f767b98ebb10b0c3d2d021b upstream.
The increment of "to" in copy_user_handle_tail() will have incremented
before a failure has been noted. This causes us to skip a byte in the
failure case.
Only do the increment when assured there is no failure.
Signed-off-by: CQ Tang <cq.tang@intel.com>
Link: http://lkml.kernel.org/r/20130318150221.8439.993.stgit@phlsvslse11.ph.intel.com
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit f6a70a07079518280022286a1dceb797d12e1edf upstream.
Our flush_tlb_kernel_range() implementation calls __tlb_flush_mm() with
&init_mm as argument. __tlb_flush_mm() however will only flush tlbs
for the passed in mm if its mm_cpumask is not empty.
For the init_mm however its mm_cpumask has never any bits set. Which in
turn means that our flush_tlb_kernel_range() implementation doesn't
work at all.
This can be easily verified with a vmalloc/vfree loop which allocates
a page, writes to it and then frees the page again. A crash will follow
almost instantly.
To fix this remove the cpumask_empty() check in __tlb_flush_mm() since
there shouldn't be too many mms with a zero mm_cpumask, besides the
init_mm of course.
commit 2a6e06b2aed6995af401dcd4feb5e79a0c7ea554 upstream.
Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after
suspend/resume") fixed a crash when doing PEBS performance profiling
after resuming, but in using init_debug_store_on_cpu() to restore the
DS_AREA mtrr it also resulted in a new WARN_ON() triggering.
init_debug_store_on_cpu() uses "wrmsr_on_cpu()", which in turn uses CPU
cross-calls to do the MSR update. Which is not really valid at the
early resume stage, and the warning is quite reasonable. Now, it all
happens to _work_, for the simple reason that smp_call_function_single()
ends up just doing the call directly on the CPU when the CPU number
matches, but we really should just do the wrmsr() directly instead.
This duplicates the wrmsr() logic, but hopefully we can just remove the
wrmsr_on_cpu() version eventually.
Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com>
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream.
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
commit d63ac5f6cf31c8a83170a9509b350c1489a7262b upstream.
Commit 44ae3ab3358e962039c36ad4ae461ae9fb29596c forgot to update
the entry for the 970MP rev 1.0 processor when moving some CPU
features bits to the MMU feature bit mask. This breaks booting
on some rare G5 models using that chip revision.
Reported-by: Phileas Fogg <phileas-fogg@mail.ru>
commit b255188f90e2bade1bd11a986dd1ca4861869f4d upstream.
Paolo Pisati reports that IPv6 triggers this warning:
BUG: scheduling while atomic: swapper/0/0/0x40000100
Modules linked in:
[<c001b1c4>] (unwind_backtrace+0x0/0xf0) from [<c0503c5c>] (__schedule_bug+0x48/0x5c)
[<c0503c5c>] (__schedule_bug+0x48/0x5c) from [<c0508608>] (__schedule+0x700/0x740)
[<c0508608>] (__schedule+0x700/0x740) from [<c007007c>] (__cond_resched+0x24/0x34)
[<c007007c>] (__cond_resched+0x24/0x34) from [<c05086dc>] (_cond_resched+0x3c/0x44)
[<c05086dc>] (_cond_resched+0x3c/0x44) from [<c0021f6c>] (do_alignment+0x178/0x78c)
[<c0021f6c>] (do_alignment+0x178/0x78c) from [<c00083e0>] (do_DataAbort+0x34/0x98)
[<c00083e0>] (do_DataAbort+0x34/0x98) from [<c0509a60>] (__dabt_svc+0x40/0x60)
Exception stack(0xc0763d70 to 0xc0763db8)
3d60: e97e805e e97e806e 2c000000 11000000
3d80: ea86bb00 0000002c 00000011 e97e807e c076d2a8 e97e805e e97e806e 0000002c
3da0: 3d000000 c0763dbc c04b98fc c02a8490 00000113 ffffffff
[<c0509a60>] (__dabt_svc+0x40/0x60) from [<c02a8490>] (__csum_ipv6_magic+0x8/0xc8)
Fix this by using probe_kernel_address() stead of __get_user().
Reported-by: Paolo Pisati <p.pisati@gmail.com>
Tested-by: Paolo Pisati <p.pisati@gmail.com>
commit 5e4ba617c1b584b2e376f31a63bd4e734109318a upstream.
Martin Storsjö reports that the sequence:
ee312ac1 vsub.f32 s4, s3, s2
ee702ac0 vsub.f32 s5, s1, s0
e59f0028 ldr r0, [pc, #40]
ee111a90 vmov r1, s3
on Raspberry Pi (implementor 41 architecture 1 part 20 variant b rev 5)
where s3 is a denormal and s2 is zero results in incorrect behaviour -
the instruction "vsub.f32 s5, s1, s0" is not executed:
VFP: bounce: trigger ee111a90 fpexc d0000780
VFP: emulate: INST=0xee312ac1 SCR=0x00000000
As we can see, the instruction triggering the exception is the "vmov"
instruction, and we emulate the "vsub.f32 s4, s3, s2" but fail to
properly take account of the FPEXC_FP2V flag in FPEXC. This is because
the test for the second instruction register being valid is bogus, and
will always skip emulation of the second instruction.
Reported-by: Martin Storsjö <martin@martin.st>
Tested-by: Martin Storsjö <martin@martin.st>
In 3.0.67, commit 58c9ce6fad8e00d9726447f939fe7e78e2aec891 (s390/kvm:
Fix store status for ACRS/FPRS), upstream commit
15bc8d8457875f495c59d933b05770ba88d1eacb, added a call to
save_access_regs to save ACRS. But we do not have ARCS in kvm_run in
3.0 yet, so this results in:
arch/s390/kvm/kvm-s390.c: In function 'kvm_s390_vcpu_store_status':
arch/s390/kvm/kvm-s390.c:593: error: 'struct kvm_run' has no member named 's'
Fix it by saving guest_acrs which is where ARCS are in 3.0.
commit cb214ede7657db458fd0b2a25ea0b28dbf900ebc upstream.
When a HP ProLiant DL980 G7 Server boots a regular kernel,
there will be intermittent lost interrupts which could
result in a hang or (in extreme cases) data loss.
The reason is that this system only supports x2apic physical
mode, while the kernel boots with a logical-cluster default
setting.
This bug can be worked around by specifying the "x2apic_phys" or
"nox2apic" boot option, but we want to handle this system
without requiring manual workarounds.
The BIOS sets ACPI_FADT_APIC_PHYSICAL in FADT table.
As all apicids are smaller than 255, BIOS need to pass the
control to the OS with xapic mode, according to x2apic-spec,
chapter 2.9.
Current code handle x2apic when BIOS pass with xapic mode
enabled:
When user specifies x2apic_phys, or FADT indicates PHYSICAL:
1. During madt oem check, apic driver is set with xapic logical
or xapic phys driver at first.
2. enable_IR_x2apic() will enable x2apic_mode.
3. if user specifies x2apic_phys on the boot line, x2apic_phys_probe()
will install the correct x2apic phys driver and use x2apic phys mode.
Otherwise it will skip the driver will let x2apic_cluster_probe to
take over to install x2apic cluster driver (wrong one) even though FADT
indicates PHYSICAL, because x2apic_phys_probe does not check
FADT PHYSICAL.
Add checking x2apic_fadt_phys in x2apic_phys_probe() to fix the
problem.
Signed-off-by: Stoney Wang <song-bo.wang@hp.com>
[ updated the changelog and simplified the code ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Zhang Lin-Bao <Linbao.zhang@hp.com>
[ make a patch specially for 3.0.66]
Link: http://lkml.kernel.org/r/1360263182-16226-1-git-send-email-yinghai@kernel.org
commit e575a86fdc50d013bf3ad3aa81d9100e8e6cc60d upstream.
Without this patch, it is trivial to determine kernel page
mappings by examining the error code reported to dmesg[1].
Instead, declare the entire kernel memory space as a violation
of a present page.
Additionally, since show_unhandled_signals is enabled by
default, switch branch hinting to the more realistic
expectation, and unobfuscate the setting of the PF_PROT bit to
improve readability.
[1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/
Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Suggested-by: Brad Spengler <spender@grsecurity.net>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit 7c10093692ed2e6f318387d96b829320aa0ca64c upstream.
On non-BIOS platforms it is possible that the BIOS data area contains
garbage instead of being zeroed or something equivalent (firmware
people: we are talking of 1.5K here, so please do the sane thing.)
We need on the order of 20-30K of low memory in order to boot, which
may grow up to < 64K in the future. We probably want to avoid the
lowest of the low memory. At the same time, it seems extremely
unlikely that a legitimate EBDA would ever reach down to the 128K
(which would require it to be over half a megabyte in size.) Thus,
pick 128K as the cutoff for "this is insane, ignore." We may still
end up reserving a bunch of extra memory on the low megabyte, but that
is not really a major issue these days. In the worst case we lose
512K of RAM.
This code really should be merged with trim_bios_range() in
arch/x86/kernel/setup.c, but that is a bigger patch for a later merge
window.
Reported-by: Darren Hart <dvhart@linux.intel.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/n/tip-oebml055yyfm8yxmria09rja@git.kernel.org
commit f528d980c17b8714aedc918ba86e058af914d66b upstream.
When dma_ops are initialized the unity mappings are
created. The init_device_table_dma() function makes sure DMA
from all devices is blocked by default. This opens a short
window in time where DMA to unity mapped regions is blocked
by the IOMMU. Make sure this does not happen by initializing
the device table after dma_ops.
commit 7139bc1579901b53db7e898789e916ee2fb52d78 upstream.
This patch goes a long way toward fixing the minifail bug, and
it significantly improves the stability of SMP machines such as
the rp3440. When write protecting a page for COW, we need to
purge the existing translation. Otherwise, the COW break
doesn't occur as expected because the TLB may still have a stale entry
which allows writes.
[jejb: fix up checkpatch errors]
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 8520e443aa56cc157b015205ea53e7b9fc831291 upstream.
Disable hard IRQ before kexec a new kernel image.
Not doing it can result in corrupted data in the memory segments
reserved for the new kernel.
Signed-off-by: Phileas Fogg <phileas-fogg@mail.ru>
commit d107a204154ddd79339203c2deeb7433f0cf6777 upstream.
The Chip Select Configuration Register must be programmed to 0x2 in
order to achieve the correct behavior of the Static Memory Controller.
Without this patch devices wired to DFI and accessed through SMC cannot
be accessed after resume from S2.
Do not rely on the boot loader to program the CSMSADRCFG register by
programming it in the kernel smemc module.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
commit 15bc8d8457875f495c59d933b05770ba88d1eacb upstream.
On store status we need to copy the current state of registers
into a save area. Currently we might save stale versions:
The sie state descriptor doesnt have fields for guest ACRS,FPRS,
those registers are simply stored in the host registers. The host
program must copy these away if needed. We do that in vcpu_put/load.
If we now do a store status in KVM code between vcpu_put/load, the
saved values are not up-to-date. Lets collect the ACRS/FPRS before
saving them.
This also fixes some strange problems with hotplug and virtio-ccw,
since the low level machine check handler (on hotplug a machine check
will happen) will revalidate all registers with the content of the
save area.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit 76eaca031f0af2bb303e405986f637811956a422 upstream.
There is a loophole between Xen's current implementation of
pv-spinlocks and the scheduler. This was triggerable through
a testcase until v3.6 changed the TLB flushing code. The
problem potentially is still there just not observable in the
same way.
What could happen was (is):
1. CPU n tries to schedule task x away and goes into a slow
wait for the runq lock of CPU n-# (must be one with a lower
number).
2. CPU n-#, while processing softirqs, tries to balance domains
and goes into a slow wait for its own runq lock (for updating
some records). Since this is a spin_lock_irqsave in softirq
context, interrupts will be re-enabled for the duration of
the poll_irq hypercall used by Xen.
3. Before the runq lock of CPU n-# is unlocked, CPU n-1 receives
an interrupt (e.g. endio) and when processing the interrupt,
tries to wake up task x. But that is in schedule and still
on_cpu, so try_to_wake_up goes into a tight loop.
4. The runq lock of CPU n-# gets unlocked, but the message only
gets sent to the first waiter, which is CPU n-# and that is
busily stuck.
5. CPU n-# never returns from the nested interruption to take and
release the lock because the scheduler uses a busy wait.
And CPU n never finishes the task migration because the unlock
notification only went to CPU n-#.
To avoid this and since the unlocking code has no real sense of
which waiter is best suited to grab the lock, just send the IPI
to all of them. This causes the waiters to return from the hyper-
call (those not interrupted at least) and do active spinlocking.
BugLink: http://bugs.launchpad.net/bugs/1011792
Acked-by: Jan Beulich <JBeulich@suse.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit bb112aec5ee41427e9b9726e3d57b896709598ed upstream.
Remove reference to removed function resume_map_numa_kva().
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
commit 13d2b4d11d69a92574a55bfd985cfb0ca77aebdc upstream.
This fixes CVE-2013-0228 / XSA-42
Drew Jones while working on CVE-2013-0190 found that that unprivileged guest user
in 32bit PV guest can use to crash the > guest with the panic like this:
general protection fault: 0000 [#1] SMP
last sysfs file: /sys/devices/vbd-51712/block/xvda/dev
Modules linked in: sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4
iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6
xt_state nf_conntrack ip6table_filter ip6_tables ipv6 xen_netfront ext4
mbcache jbd2 xen_blkfront dm_mirror dm_region_hash dm_log dm_mod [last
unloaded: scsi_wait_scan]
Pid: 1250, comm: r Not tainted 2.6.32-356.el6.i686 #1
EIP: 0061:[<c0407462>] EFLAGS: 00010086 CPU: 0
EIP is at xen_iret+0x12/0x2b
EAX: eb8d0000 EBX: 00000001 ECX: 08049860 EDX: 00000010
ESI: 00000000 EDI: 003d0f00 EBP: b77f8388 ESP: eb8d1fe0
DS: 0000 ES: 007b FS: 0000 GS: 00e0 SS: 0069
Process r (pid: 1250, ti=eb8d0000 task=c2953550 task.ti=eb8d0000)
Stack:
00000000 0027f416 00000073 00000206 b77f8364 0000007b 00000000 00000000
Call Trace:
Code: c3 8b 44 24 18 81 4c 24 38 00 02 00 00 8d 64 24 30 e9 03 00 00 00
8d 76 00 f7 44 24 08 00 00 02 80 75 33 50 b8 00 e0 ff ff 21 e0 <8b> 40
10 8b 04 85 a0 f6 ab c0 8b 80 0c b0 b3 c0 f6 44 24 0d 02
EIP: [<c0407462>] xen_iret+0x12/0x2b SS:ESP 0069:eb8d1fe0
general protection fault: 0000 [#2]
---[ end trace ab0d29a492dcd330 ]---
Kernel panic - not syncing: Fatal exception
Pid: 1250, comm: r Tainted: G D ---------------
Call Trace:
[<c08476df>] ? panic+0x6e/0x122
[<c084b63c>] ? oops_end+0xbc/0xd0
[<c084b260>] ? do_general_protection+0x0/0x210
[<c084a9b7>] ? error_code+0x73/
Petr says: "
I've analysed the bug and I think that xen_iret() cannot cope with
mangled DS, in this case zeroed out (null selector/descriptor) by either
xen_failsafe_callback() or RESTORE_REGS because the corresponding LDT
entry was invalidated by the reproducer. "
Jan took a look at the preliminary patch and came up a fix that solves
this problem:
"This code gets called after all registers other than those handled by
IRET got already restored, hence a null selector in %ds or a non-null
one that got loaded from a code or read-only data descriptor would
cause a kernel mode fault (with the potential of crashing the kernel
as a whole, if panic_on_oops is set)."
The way to fix this is to realize that the we can only relay on the
registers that IRET restores. The two that are guaranteed are the
%cs and %ss as they are always fixed GDT selectors. Also they are
inaccessible from user mode - so they cannot be altered. This is
the approach taken in this patch.
Another alternative option suggested by Jan would be to relay on
the subtle realization that using the %ebp or %esp relative references uses
the %ss segment. In which case we could switch from using %eax to %ebp and
would not need the %ss over-rides. That would also require one extra
instruction to compensate for the one place where the register is used
as scaled index. However Andrew pointed out that is too subtle and if
further work was to be done in this code-path it could escape folks attention
and lead to accidents.
Reviewed-by: Petr Matousek <pmatouse@redhat.com>
Reported-by: Petr Matousek <pmatouse@redhat.com>
Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 0ee364eb316348ddf3e0dfcd986f5f13f528f821 upstream.
A user reported the following oops when a backup process reads
/proc/kcore:
BUG: unable to handle kernel paging request at ffffbb00ff33b000
IP: [<ffffffff8103157e>] kern_addr_valid+0xbe/0x110
Call Trace:
[<ffffffff811b8aaa>] read_kcore+0x17a/0x370
[<ffffffff811ad847>] proc_reg_read+0x77/0xc0
[<ffffffff81151687>] vfs_read+0xc7/0x130
[<ffffffff811517f3>] sys_read+0x53/0xa0
[<ffffffff81449692>] system_call_fastpath+0x16/0x1b
Investigation determined that the bug triggered when reading
system RAM at the 4G mark. On this system, that was the first
address using 1G pages for the virt->phys direct mapping so the
PUD is pointing to a physical address, not a PMD page.
The problem is that the page table walker in kern_addr_valid() is
not checking pud_large() and treats the physical address as if
it was a PMD. If it happens to look like pmd_none then it'll
silently fail, probably returning zeros instead of real data. If
the data happens to look like a present PMD though, it will be
walked resulting in the oops above.
This patch adds the necessary pud_large() check.
Unfortunately the problem was not readily reproducible and now
they are running the backup program without accessing
/proc/kcore so the patch has not been validated but I think it
makes sense.
Reviewed-by: Rik van Riel <riel@redhat.coM>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20130211145236.GX21389@suse.de
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream.
For some reason they didn't get replaced so far by their
paravirt equivalents, resulting in code to be run with
interrupts disabled that doesn't expect so (causing, in the
observed case, a BUG_ON() to trigger) when syscall auditing is
enabled.
David (Cc-ed) came up with an identical fix, so likely this can
be taken to count as an ack from him.
Reported-by: Peter Moody <pmoody@google.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com
Tested-by: Peter Moody <pmoody@google.com>
commit e43b3cec711a61edf047adf6204d542f3a659ef8 upstream.
early_pci_allowed() and read_pci_config_16() are only available if
CONFIG_PCI is defined.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com>
commit b8f2c21db390273c3eaf0e5308faeaeb1e233840 upstream.
Update efi_call_phys_prelog to install an identity mapping of all available
memory. This corrects a bug on very large systems with more then 512 GB in
which bios would not be able to access addresses above not in the mapping.
The result is a crash that looks much like this.
BUG: unable to handle kernel paging request at 000000effd870020
IP: [<0000000078bce331>] 0x78bce330
PGD 0
Oops: 0000 [#1] SMP
Modules linked in:
CPU 0
Pid: 0, comm: swapper/0 Tainted: G W 3.8.0-rc1-next-20121224-medusa_ntz+ #2 Intel Corp. Stoutland Platform
RIP: 0010:[<0000000078bce331>] [<0000000078bce331>] 0x78bce330
RSP: 0000:ffffffff81601d28 EFLAGS: 00010006
RAX: 0000000078b80e18 RBX: 0000000000000004 RCX: 0000000000000004
RDX: 0000000078bcf958 RSI: 0000000000002400 RDI: 8000000000000000
RBP: 0000000078bcf760 R08: 000000effd870000 R09: 0000000000000000
R10: 0000000000000000 R11: 00000000000000c3 R12: 0000000000000030
R13: 000000effd870000 R14: 0000000000000000 R15: ffff88effd870000
FS: 0000000000000000(0000) GS:ffff88effe400000(0000) knlGS:0000000000000000
CR2: 000000effd870020 CR3: 000000000160c000 CR4: 00000000000006b0
Process swapper/0 (pid: 0, threadinfo ffffffff81600000, task ffffffff81614400)
Stack:
0000000078b80d18 0000000000000004 0000000078bced7b ffff880078b81fff
0000000000000000 0000000000000082 0000000078bce3a8 0000000000002400
0000000060000202 0000000078b80da0 0000000078bce45d ffffffff8107cb5a
Call Trace:
[<ffffffff8107cb5a>] ? on_each_cpu+0x77/0x83
[<ffffffff8102f4eb>] ? change_page_attr_set_clr+0x32f/0x3ed
[<ffffffff81035946>] ? efi_call4+0x46/0x80
[<ffffffff816c5abb>] ? efi_enter_virtual_mode+0x1f5/0x305
[<ffffffff816aeb24>] ? start_kernel+0x34a/0x3d2
[<ffffffff816ae5ed>] ? repair_env_string+0x60/0x60
[<ffffffff816ae2be>] ? x86_64_start_reservations+0xba/0xc1
[<ffffffff816ae120>] ? early_idt_handlers+0x120/0x120
[<ffffffff816ae419>] ? x86_64_start_kernel+0x154/0x163
Code: Bad RIP value.
RIP [<0000000078bce331>] 0x78bce330
RSP <ffffffff81601d28>
---[ end trace ead828934fef5eab ]---
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Signed-off-by: Robin Holt <holt@sgi.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit c903f0456bc69176912dee6dd25c6a66ee1aed00 upstream.
At the moment the MSR driver only relies upon file system
checks. This means that anything as root with any capability set
can write to MSRs. Historically that wasn't very interesting but
on modern processors the MSRs are such that writing to them
provides several ways to execute arbitary code in kernel space.
Sample code and documentation on doing this is circulating and
MSR attacks are used on Windows 64bit rootkits already.
In the Linux case you still need to be able to open the device
file so the impact is fairly limited and reduces the security of
some capability and security model based systems down towards
that of a generic "root owns the box" setup.
Therefore they should require CAP_SYS_RAWIO to prevent an
elevation of capabilities. The impact of this is fairly minimal
on most setups because they don't have heavy use of
capabilities. Those using SELinux, SMACK or AppArmor rules might
want to consider if their rulesets on the MSR driver could be
tighter.
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit 15653371c67c3fbe359ae37b720639dd4c7b42c5 upstream.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
[Based on commit c94082656dac74257f63e91f78d5d458ac781fa5 upstream, only
taking the traps.h portion.]
The traps are referred to by their numbers and it can be difficult to
understand them while reading the code without context. This patch adds
enumeration of the trap numbers and replaces the numbers with the correct
enum for x86.
Link: http://lkml.kernel.org/r/20120310000710.GA32667@www.outflux.net
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 9174adbee4a9a49d0139f5d71969852b36720809 upstream.
This fixes CVE-2013-0190 / XSA-40
There has been an error on the xen_failsafe_callback path for failed
iret, which causes the stack pointer to be wrong when entering the
iret_exc error path. This can result in the kernel crashing.
In the classic kernel case, the relevant code looked a little like:
popl %eax # Error code from hypervisor
jz 5f
addl $16,%esp
jmp iret_exc # Hypervisor said iret fault
5: addl $16,%esp
# Hypervisor said segment selector fault
Here, there are two identical addls on either option of a branch which
appears to have been optimised by hoisting it above the jz, and
converting it to an lea, which leaves the flags register unaffected.
In the PVOPS case, the code looks like:
popl_cfi %eax # Error from the hypervisor
lea 16(%esp),%esp # Add $16 before choosing fault path
CFI_ADJUST_CFA_OFFSET -16
jz 5f
addl $16,%esp # Incorrectly adjust %esp again
jmp iret_exc
It is possible unprivileged userspace applications to cause this
behaviour, for example by loading an LDT code selector, then changing
the code selector to be not-present. At this point, there is a race
condition where it is possible for the hypervisor to return back to
userspace from an interrupt, fault on its own iret, and inject a
failsafe_callback into the kernel.
This bug has been present since the introduction of Xen PVOPS support
in commit 5ead97c84 (xen: Core Xen implementation), in 2.6.23.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Signed-off-by: Andrew Cooper <andrew.cooper3@citrix.com>
[not upstream as the code involved was removed in the 3.3.0 release]
Fix wii_memory_fixups() the following compile error on 3.0.y tree with
wii_defconfig on 3.0.y tree.
CC arch/powerpc/platforms/embedded6xx/wii.o
arch/powerpc/platforms/embedded6xx/wii.c: In function ‘wii_memory_fixups’:
arch/powerpc/platforms/embedded6xx/wii.c:88:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Werror=format]
arch/powerpc/platforms/embedded6xx/wii.c:88:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Werror=format]
arch/powerpc/platforms/embedded6xx/wii.c:90:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Werror=format]
arch/powerpc/platforms/embedded6xx/wii.c:90:2: error: format ‘%llx’ expects argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Werror=format]
cc1: all warnings being treated as errors
make[2]: *** [arch/powerpc/platforms/embedded6xx/wii.o] Error 1
make[1]: *** [arch/powerpc/platforms/embedded6xx] Error 2
make: *** [arch/powerpc/platforms] Error 2
commit a9acc5365dbda29f7be2884efb63771dc24bd815 upstream.
SNB graphics devices have a bug that prevent them from accessing certain
memory ranges, namely anything below 1M and in the pages listed in the
table. So reserve those at boot if set detect a SNB gfx device on the
CPU to avoid GPU hangs.
Stephane Marchesin had a similar patch to the page allocator awhile
back, but rather than reserving pages up front, it leaked them at
allocation time.
[ hpa: made a number of stylistic changes, marked arrays as static
const, and made less verbose; use "memblock=debug" for full
verbosity. ]
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: CAI Qian <caiqian@redhat.com>
commit ed4f20943cd4c7b55105c04daedf8d63ab6d499c upstream.
Converting a 64 Bit TOD format value to nanoseconds means that the value
must be divided by 4.096. In order to achieve that we multiply with 125
and divide by 512.
When used within sched_clock() this triggers an overflow after appr.
417 days. Resulting in a sched_clock() return value that is much smaller
than previously and therefore may cause all sort of weird things in
subsystems that rely on a monotonic sched_clock() behaviour.
To fix this implement a tod_to_ns() helper function which converts TOD
values without overflow and call this function from both places that
open coded the conversion: sched_clock() and kvm_s390_handle_wait().
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 4a71997a3279a339e7336ea5d0cd27282e2dea44 upstream.
Ensure that the aux table is properly initialized, even when optional features
are missing. Without this, the FDPIC loader did not work. This was meant to
be included in commit d5ab780305bb6d60a7b5a74f18cf84eb6ad153b1.
Signed-off-by: Thomas Schwinge <thomas@codesourcery.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit e43a028752fed049e4bd94ef895542f96d79fa74 upstream.
When remembering the direction of a DCR transaction, we should write
to the same variable that we interpret on later when doing vcpu_run
again.
commit 2bbf0a1427c377350f001fbc6260995334739ad7 upstream.
The Way Access Filter in recent AMD CPUs may hurt the performance of
some workloads, caused by aliasing issues in the L1 cache.
This patch disables it on the affected CPUs.
The issue is similar to that one of last year:
http://lkml.indiana.edu/hypermail/linux/kernel/1107.3/00041.html
This new patch does not replace the old one, we just need another
quirk for newer CPUs.
The performance penalty without the patch depends on the
circumstances, but is a bit less than the last year's 3%.
The workloads affected would be those that access code from the same
physical page under different virtual addresses, so different
processes using the same libraries with ASLR or multiple instances of
PIE-binaries. The code needs to be accessed simultaneously from both
cores of the same compute unit.
More details can be found here:
http://developer.amd.com/Assets/SharedL1InstructionCacheonAMD15hCPU.pdf
CPUs affected are anything with the core known as Piledriver.
That includes the new parts of the AMD A-Series (aka Trinity) and the
just released new CPUs of the FX-Series (aka Vishera).
The model numbering is a bit odd here: FX CPUs have model 2,
A-Series has model 10h, with possible extensions to 1Fh. Hence the
range of model ids.
Signed-off-by: Andre Przywara <osp@andrep.de>
Link: http://lkml.kernel.org/r/1351700450-9277-1-git-send-email-osp@andrep.de
commit ce73ec6db47af84d1466402781ae0872a9e7873c upstream.
The locking in update_vsyscall_tz() is not only unnecessary because the vdso
code copies the data unproteced in __kernel_gettimeofday() but also
introduces a hard to reproduce race condition between update_vsyscall()
and update_vsyscall_tz(), which causes user space process to loop
forever in vdso code.
The following patch removes the locking from update_vsyscall_tz().
Locking is not only unnecessary because the vdso code copies the data
unprotected in __kernel_gettimeofday() but also erroneous because updating
the tb_update_count is not atomic and introduces a hard to reproduce race
condition between update_vsyscall() and update_vsyscall_tz(), which further
causes user space process to loop forever in vdso code.
The below scenario describes the race condition,
x==0 Boot CPU other CPU
proc_P: x==0
timer interrupt
update_vsyscall
x==1 x++;sync settimeofday
update_vsyscall_tz
x==2 x++;sync
x==3 sync;x++
sync;x++
proc_P: x==3 (loops until x becomes even)
Because the ++ operator would be implemented as three instructions and not
atomic on powerpc.
A similar change was made for x86 in commit 6c260d58634
("x86: vdso: Remove bogus locking in update_vsyscall_tz")
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit 11ee7e99f35ecb15f59b21da6a82d96d2cd3fcc8 upstream.
If we build a kernel with CONFIG_RELOCATABLE=y CONFIG_CRASH_DUMP=n,
the kernel fails when we run at a non zero offset. It turns out
we were incorrectly wrapping some of the relocatable kernel code
with CONFIG_CRASH_DUMP.
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream.
The inb/outb macros for CRIS are broken from a number of points of view,
missing () around parameters and they have an unprotected if statement
in them. This was breaking the compile of IPMI on CRIS and thus I was
being annoyed by build regressions, so I fixed them.
Plus I don't think they would have worked at all, since the data values
were missing "&" and the outsl had a "3" instead of a "4" for the size.
From what I can tell, this stuff is not used at all, so this can't be
any more broken than it was before, anyway.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Mikael Starvik <starvik@axis.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit 7bf9b7bef881aac820bf1f2e9951a17b09bd7e04 upstream.
find_vma() is *not* safe when somebody else is removing vmas. Not just
the return value might get bogus just as you are getting it (this instance
doesn't try to dereference the resulting vma), the search itself can get
buggered in rather spectacular ways. IOW, ->mmap_sem really, really is
not optional here.
commit 864aa04cd02979c2c755cb28b5f4fe56039171c0 upstream.
When updating the page protection map after calculating the user_pgprot
value, the base protection map is temporarily stored in an unsigned long
type, causing truncation of the protection bits when LPAE is enabled.
This effectively means that calls to mprotect() will corrupt the upper
page attributes, clearing the XN bit unconditionally.
This patch uses pteval_t to store the intermediate protection values,
preserving the upper bits for 64-bit descriptors.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
[ Upstream commit 6cb9c3697585c47977c42c5cc1b9fc49247ac530 ]
Modifying the huge pte's requires that all the underlying pte's be
modified.
Version 2: added missing flush_tlb_page()
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Cc: sparclinux@vger.kernel.org
range of model ids.
commit 00ca0de02f80924dfff6b4f630e1dff3db005e35 upstream.
When we update the DSCR either via emulation of mtspr(DSCR) or via
a change to dscr_default in sysfs we don't update thread.dscr.
We will eventually update it at context switch time but there is
a period where thread.dscr is incorrect.
If we fork at this point we will copy the old value of thread.dscr
into the child. To avoid this, always keep thread.dscr in sync with
reality.
This issue was found with the following testcase:
http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c
Signed-off-by: Haren Myneni <haren@us.ibm.com>
