commit 137f7df8cead00688524c82360930845396b8a21 upstream.
Add _TIF_SECCOMP flag to _TIF_WORK_SYSCALL_ENTRY to indicate
that the system call needs to be checked against a seccomp filter.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/6405/
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 721a9205396c4ef2a811dd665ec2a232163b583d upstream.
Introduced by the following two commits:
75b5b5e0a262790fa11043fe45700499c7e3d818
"MIPS: Add support for FTLBs"
6de20451857ed14a4eecc28d08f6de5925d1cf96
"MIPS: Add printing of ES bit for Imgtec cores when cache error occurs"
Reported-by: Matheus Almeida <Matheus.Almeida@imgtec.com>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/6980/
commit 483a6c9d447f625b991fa04a1530493d893984db upstream.
According to the ARM ARM, the behaviour is UNPREDICTABLE if the PC read
from the exception return stack is not half word aligned. See the
pseudo code for ExceptionReturn() and PopStack().
The signal handler's address has the bit 0 set, and setup_return()
directly writes this to regs->ARM_pc. Current hardware happens to
discard this bit, but QEMU's emulation doesn't and this makes processes
crash. Mask out bit 0 before the exception return in order to get
predictable behaviour.
Fixes: 19c4d593f0b4 ("ARM: ARMv7-M: Add support for exception handling")
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit 537094b64b229bf3ad146042f83e74cf6abe59df upstream.
According to arm procedure call standart r2 register is call-cloberred.
So after the result of x expression was put into r2 any following
function call in p may overwrite r2. To fix this, the result of p
expression must be saved to the temporary variable before the
assigment x expression to __r2.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
commit 4b353a706a86598ba47307c47301c3c428b79e09 upstream.
On OMAP4 panda board, there have been several bug reports about boot
hang and lock-ups with CPU_IDLE enabled. The root cause of the issue
is missing interrupts while in idle state. Commit cb7094e8 {cpuidle / omap4 :
use CPUIDLE_FLAG_TIMER_STOP flag} moved the broadcast notifiers to common
code for right reasons but on OMAP4 which suffers from a nasty ROM code
bug with GIC, commit ff999b8a {ARM: OMAP4460: Workaround for ROM bug ..},
we loose interrupts which leads to issues like lock-up, hangs etc.
Patch reverts commit cb7094 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP
flag} and 54769d6 {cpuidle: OMAP4: remove timer broadcast initialization} to
avoid the issue. With this change, OMAP4 panda boards, the mentioned
issues are getting fixed. We no longer loose interrupts which was the cause
of the regression.
Fixes: cb7094e8 (cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag)
Fixes: ff999b8a (cpuidle: OMAP4: remove timer broadcast initialization)
Cc: Roger Quadros <rogerq@ti.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Reported-tested-by: Roger Quadros <rogerq@ti.com>
Reported-tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
all OMAP3 platforms
commit 98d7e1aee6dd534f468993f8c6a1bc730d4cfa81 upstream.
Commit 7b2e1277598e4187c9be3e61fd9b0f0423f97986 ("ARM: OMAP3: clock:
Back-propagate rate change from cam_mclk to dpll4_m5") enabled clock
rate back-propagation from cam_mclk do dpll4_m5 on OMAP3630 only.
Perform back-propagation on other OMAP3 platforms as well.
Reported-by: Jean-Philippe François <jp.francois@cynove.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit 5005e0b76781c37d0a16dd6dd17d015098e8ce92 upstream.
Commit c66d039197e4 broke NAND for non-DT boot on all OMAP2 and OMAP3
boards using board_nand_init(). Following error is seen at boot
[ 0.154998] (null): Unsupported NAND ECC scheme selected
For OMAP2 and OMAP3 platforms, the ecc_opt parameter in platform data
must be set to OMAP_ECC_HAM1_CODE_HW to work properly.
Tested on omap3-beagle c4.
Fixes: c66d039197e4 (mtd: nand: omap: combine different flavours of 1-bit hamming ecc schemes)
Signed-off-by: Roger Quadros <rogerq@ti.com>
commit 0f9e19ad88eee820f517b85531b555a0fa73e7e4 upstream.
McPDM need to be configured to NO_IDLE mode when it is in used otherwise
vital clocks will be gated which results 'slow motion' audio playback.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
commit d1d70e5dc2cfa9047bb935c41ba808ebb8135696 upstream.
If we fail to allocate struct platform_device pdev we
dereference it after the goto label err.
This bug was found using coccinelle.
Fixes: afa77ef (ARM: mx3: dynamically allocate "ipu-core" devices)
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
commit 601c942176d8ad8334118bddb747e3720bed24f8 upstream.
Commit 01f8fa4f01d8("genirq: Allow forcing cpu affinity of interrupts")
enabled the forced irq_set_affinity which previously refused to route an
interrupt to an offline cpu.
Commit ffde1de64012("irqchip: Gic: Support forced affinity setting")
implements this force logic and disables the cpu online check for GIC
interrupt controller.
When __cpu_disable calls migrate_irqs, it disables the current cpu in
cpu_online_mask and uses forced irq_set_affinity to migrate the IRQs
away from the cpu but passes affinity mask with the cpu being offlined
also included in it.
When calling irq_set_affinity with force == true in a cpu hotplug path,
the caller must ensure that the cpu being offlined is not present in the
affinity mask or it may be selected as the target CPU, leading to the
interrupt not being migrated.
This patch uses cpu_online_mask when using forced irq_set_affinity so
that the IRQs are properly migrated away.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
commit 011e4b02f1da156ac7fea28a9da878f3c23af739 upstream.
If we try to perform a kexec when the machine is in ST (Single-Threaded) mode
(ppc64_cpu --smt=off), the kexec operation doesn't succeed properly, and we
get the following messages during boot:
[ 0.089866] POWER8 performance monitor hardware support registered
[ 0.089985] power8-pmu: PMAO restore workaround active.
[ 5.095419] Processor 1 is stuck.
[ 10.097933] Processor 2 is stuck.
[ 15.100480] Processor 3 is stuck.
[ 20.102982] Processor 4 is stuck.
[ 25.105489] Processor 5 is stuck.
[ 30.108005] Processor 6 is stuck.
[ 35.110518] Processor 7 is stuck.
[ 40.113369] Processor 9 is stuck.
[ 45.115879] Processor 10 is stuck.
[ 50.118389] Processor 11 is stuck.
[ 55.120904] Processor 12 is stuck.
[ 60.123425] Processor 13 is stuck.
[ 65.125970] Processor 14 is stuck.
[ 70.128495] Processor 15 is stuck.
[ 75.131316] Processor 17 is stuck.
Note that only the sibling threads are stuck, while the primary threads (0, 8,
16 etc) boot just fine. Looking closer at the previous step of kexec, we observe
that kexec tries to wakeup (bring online) the sibling threads of all the cores,
before performing kexec:
[ 9464.131231] Starting new kernel
[ 9464.148507] kexec: Waking offline cpu 1.
[ 9464.148552] kexec: Waking offline cpu 2.
[ 9464.148600] kexec: Waking offline cpu 3.
[ 9464.148636] kexec: Waking offline cpu 4.
[ 9464.148671] kexec: Waking offline cpu 5.
[ 9464.148708] kexec: Waking offline cpu 6.
[ 9464.148743] kexec: Waking offline cpu 7.
[ 9464.148779] kexec: Waking offline cpu 9.
[ 9464.148815] kexec: Waking offline cpu 10.
[ 9464.148851] kexec: Waking offline cpu 11.
[ 9464.148887] kexec: Waking offline cpu 12.
[ 9464.148922] kexec: Waking offline cpu 13.
[ 9464.148958] kexec: Waking offline cpu 14.
[ 9464.148994] kexec: Waking offline cpu 15.
[ 9464.149030] kexec: Waking offline cpu 17.
Instrumenting this piece of code revealed that the cpu_up() operation actually
fails with -EBUSY. Thus, only the primary threads of all the cores are online
during kexec, and hence this is a sure-shot receipe for disaster, as explained
in commit e8e5c2155b (powerpc/kexec: Fix orphaned offline CPUs across kexec),
as well as in the comment above wake_offline_cpus().
It turns out that cpu_up() was returning -EBUSY because the variable
'cpu_hotplug_disabled' was set to 1; and this disabling of CPU hotplug was done
by migrate_to_reboot_cpu() inside kernel_kexec().
Now, migrate_to_reboot_cpu() was originally written with the assumption that
any further code will not need to perform CPU hotplug, since we are anyway in
the reboot path. However, kexec is clearly not such a case, since we depend on
onlining CPUs, atleast on powerpc.
So re-enable cpu-hotplug after returning from migrate_to_reboot_cpu() in the
kexec path, to fix this regression in kexec on powerpc.
Also, wrap the cpu_up() in powerpc kexec code within a WARN_ON(), so that we
can catch such issues more easily in the future.
Fixes: c97102ba963 (kexec: migrate to reboot cpu)
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 7998eb3dc700aaf499f93f50b3d77da834ef9e1d upstream.
With binutils 2.24, various 64 bit builds fail with relocation errors
such as
arch/powerpc/kernel/built-in.o: In function `exc_debug_crit_book3e':
(.text+0x165ee): relocation truncated to fit: R_PPC64_ADDR16_HI
against symbol `interrupt_base_book3e' defined in .text section
in arch/powerpc/kernel/built-in.o
(.text+0x16602): relocation truncated to fit: R_PPC64_ADDR16_HI
against symbol `interrupt_end_book3e' defined in .text section
The assembler maintainer says:
I changed the ABI, something that had to be done but unfortunately
happens to break the booke kernel code. When building up a 64-bit
value with lis, ori, shl, oris, ori or similar sequences, you now
should use @high and @higha in place of @h and @ha. @h and @ha
(and their associated relocs R_PPC64_ADDR16_HI and R_PPC64_ADDR16_HA)
now report overflow if the value is out of 32-bit signed range.
ie. @h and @ha assume you're building a 32-bit value. This is needed
to report out-of-range -mcmodel=medium toc pointer offsets in @toc@h
and @toc@ha expressions, and for consistency I did the same for all
other @h and @ha relocs.
Replacing @h with @high in one strategic location fixes the relocation
errors. This has to be done conditionally since the assembler either
supports @h or @high but not both.
commit 8050936caf125fbe54111ba5e696b68a360556ba upstream.
I am seeing an issue where a CPU running perf eventually hangs.
Traces show timer interrupts happening every 4 seconds even
when a userspace task is running on the CPU. /proc/timer_list
also shows pending hrtimers have not run in over an hour,
including the scheduler.
Looking closer, decrementers_next_tb is getting set to
0xffffffffffffffff, and at that point we will never take
a timer interrupt again.
In __timer_interrupt() we set decrementers_next_tb to
0xffffffffffffffff and rely on ->event_handler to update it:
*next_tb = ~(u64)0;
if (evt->event_handler)
evt->event_handler(evt);
In this case ->event_handler is hrtimer_interrupt. This will eventually
call back through the clockevents code with the next event to be
programmed:
static int decrementer_set_next_event(unsigned long evt,
struct clock_event_device *dev)
/* Don't adjust the decrementer if some irq work is pending */
if (test_irq_work_pending())
return 0;
__get_cpu_var(decrementers_next_tb) = get_tb_or_rtc() + evt;
If irq work came in between these two points, we will return
before updating decrementers_next_tb and we never process a timer
interrupt again.
This looks to have been introduced by 0215f7d8c53f (powerpc: Fix races
with irq_work). Fix it by removing the early exit and relying on
code later on in the function to force an early decrementer:
/* We may have raced with new irq work */
set_dec(1);
commit 372cf1244d7c271806b83b32b09a1c8b1b31b353 upstream.
Resetting root port has more stuff to do than that for PCIe switch
ports and we should have resetting root port done in firmware instead
of the kernel itself. The problem was introduced by commit 5b2e198e
("powerpc/powernv: Rework EEH reset").
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 3901c1124ec5099254a9396085f7798153a7293f upstream.
An additional testcase found an issue with the last
series of patches applied: the fallback solution may
not save the iv value after operation. This very small
fix just makes sure the iv is copied back to the
walk/desc struct.
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
commit fa81511bb0bbb2b1aace3695ce869da9762624ff upstream.
Checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
disabled 16-bit segments on 64-bit kernels due to an information
leak. However, it does seem that people are genuinely using Wine to
run old 16-bit Windows programs on Linux.
A proper fix for this ("espfix64") is coming in the upcoming merge
window, but as a temporary fix, create a sysctl to allow the
administrator to re-enable support for 16-bit segments.
It adds a "/proc/sys/abi/ldt16" sysctl that defaults to zero (off). If
you hit this issue and care about your old Windows program more than
you care about a kernel stack address information leak, you can do
echo 1 > /proc/sys/abi/ldt16
as root (add it to your startup scripts), and you should be ok.
The sysctl table is only added if you have COMPAT support enabled on
x86-64, but I assume anybody who runs old windows binaries very much
does that ;)
Link: http://lkml.kernel.org/r/CA%2B55aFw9BPoD10U1LfHbOMpHWZkvJTkMcfCs9s3urPr1YyWBxw@mail.gmail.com
commit d71f290b4e98a39f49f2595a13be3b4d5ce8e1f1 upstream.
Specify the maximum stack size for arches where the stack grows upward
(parisc and metag) in asm/processor.h rather than hard coding in
fs/exec.c so that metag can specify a smaller value of 256MB rather than
1GB.
This fixes a BUG on metag if the RLIMIT_STACK hard limit is increased
beyond a safe value by root. E.g. when starting a process after running
"ulimit -H -s unlimited" it will then attempt to use a stack size of the
maximum 1GB which is far too big for metag's limited user virtual
address space (stack_top is usually 0x3ffff000):
BUG: failure at fs/exec.c:589/shift_arg_pages()!
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: linux-parisc@vger.kernel.org
Cc: linux-metag@vger.kernel.org
Cc: John David Anglin <dave.anglin@bell.net>
commit 2425ce84026c385b73ae72039f90d042d49e0394 upstream.
Volatile access doesn't really imply the compiler barrier. Volatile access
is only ordered with respect to other volatile accesses, it isn't ordered
with respect to general memory accesses. Gcc may reorder memory accesses
around volatile access, as we can see in this simple example (if we
compile it with optimization, both increments of *b will be collapsed to
just one):
void fn(volatile int *a, long *b)
(*b)++;
*a = 10;
(*b)++;
Consequently, we need the compiler barrier after a write to the volatile
variable, to make sure that the compiler doesn't reorder the volatile
write with something else.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit c776cd89fc705fc8b5c2e5ad906bf5d791620fed upstream.
The attached change significantly improves the performance of the LWS-CAS code
in syscall.S.
This allows a number of packages to build (e.g., zeromq3, gtest and libxs)
that previously failed because slow LWS-CAS performance under contention. In
particular, interrupts taken while the lock was taken degraded performance
significantly.
The change does the following:
1) Disables interrupts around the CAS operation, and
2) Changes the loads and stores to use the ordered completer, "o", on
PA 2.0. "o" and "ma" with a zero offset are equivalent. The latter is
accepted on both PA 1.X and 2.0.
The use of ordered loads and stores probably makes no difference on all
existing hardware, but it seemed pedantically correct. In particular, the CAS
operation must complete before LDCW lock is released. As written before, a
processor could reorder the operations.
I don't believe the period interrupts are disabled is long enough to
significantly increase interrupt latency. For example, the TLB insert code is
longer. Worst case is a memory fault in the CAS operation.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit fef47e2a2e1e75fe50a10f634a80f16808348cc6 upstream.
Ratelimit printing of userspace segfaults and make it runtime
configurable via the /proc/sys/debug/exception-trace variable. This
should resolve syslog from growing way too fast and thus prevents
possible system service attacks.
commit b25bcf1bcaf6687991ae08dd76cd784bf9fe3d05 upstream.
Since the mvebu-soc-id code in mach-mvebu/ was introduced, several
users have noticed a regression: the PCIe card connected in the first
PCIe interface is not detected properly.
This is due to the fact that the mvebu-soc-id code enables the PCIe
clock of the first PCIe interface, reads the SoC device ID and
revision number (yes this information is made available as part of
PCIe registers), and then disables the clock. However, by doing this,
we gate the clock and therefore loose the complex PCIe configuration
that was done by the bootloader.
Unfortunately, as of today, the kernel is not capable of doing this
complex configuration by itself, so we really need to keep the PCIe
clock enabled. However, we don't want to keep it enabled
unconditionally: if the PCIe interface is not enabled or PCI support
is not compiled into the kernel, there is no reason to keep the PCIe
clock running.
This issue was discussed with Kevin Hilman, and the suggested solution
was to make the mvebu-soc-id code keep the clock enabled in case it
will be needed for PCIe. This is therefore the solution implemented in
this patch.
Long term, we hope to make the kernel more capable in terms of PCIe
configuration for this platform, which will anyway be needed to
support the compilation of the PCIe host controller driver as a
module. In the mean time however, we don't have much other choice than
to implement the currently proposed solution.
Reported-by: Neil Greatorex <neil@fatboyfat.co.uk>
Cc: Neil Greatorex <neil@fatboyfat.co.uk>
Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1399903900-29977-3-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: af8d1c63afcb ("ARM: mvebu: Add support to get the ID and the revision of a SoC")
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Tested-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 42a18d1cf484d02e23afadfa5dc09356e6bef9fa upstream.
The mvebu-soc-id code in mach-mvebu/ needs to enable a clock to read
the SoC device ID and revision number. To do so, it does a clk_get(),
then a clk_prepare_enable(), reads the value, and disables the clock
with clk_disable_unprepare(). However, it forgets to clk_put() the
clock. This commit fixes this issue.
Link: https://lkml.kernel.org/r/1399903900-29977-2-git-send-email-thomas.petazzoni@free-electrons.com
commit 8fad87bca7ac9737e413ba5f1656f1114a8c314d upstream.
When we configure CONFIG_ARM_LPAE=y, pfn << PAGE_SHIFT will
overflow if pfn >= 0x100000 in copy_oldmem_page.
So use __pfn_to_phys for converting.
Signed-off-by: Liu Hua <sdu.liu@huawei.com>
commit bfaed5abad998bfc88a66e6e71c7b08dcf82f04e upstream.
The current .dts for ste-ccu8540 lacks a 'device_type = "memory"' for
its memory node, relying on an old ppc quirk in order to discover its
memory. Fix the data so that all parsing code can handle it correctly.
Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Cc: devicetree@vger.kernel.org
Cc: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Grant Likely <grant.likely@linaro.org>
commit 6e20bae8a39c40d4e03698e4160bad2d2629062b upstream.
The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus
width declared in the Device Tree being considered as a 16 bits bus
width when configuring the hardware.
This bug in mvebu-devbus driver was compensated by a symetric mistake
in the Armada XP OpenBlocks AX3 Device Tree: a 8 bits bus width was
declared, even though the hardware actually has a 16 bits bus width
connection with the NOR flash.
Now that we have fixed the mvebu-devbus driver to behave according to
its Device Tree binding, this commit fixes the problematic Device Tree
files as well.
This bug was introduced in commit
a7d4f81821f7eec3175f8e23dd6949c71ab2da43 ('ARM: mvebu: Add support for
NOR flash device on Openblocks AX3 board') which was merged in v3.10.
Link: https://lkml.kernel.org/r/1397489361-5833-5-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: a7d4f81821f7 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board')
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
commit f3aec8f3f05025e7b450102dae0759375346706e upstream.
in the Armada XP DB Device Tree: a 8 bits bus width was declared, even
though the hardware actually has a 16 bits bus width connection with
the NOR flash.
files as well.
b484ff42df475c5087d614c4d477273e1906bcb9 ('ARM: mvebu: Add support for
NOR flash device on Armada XP-DB board') which was merged in v3.11.
Link: https://lkml.kernel.org/r/1397489361-5833-4-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: b484ff42df47 ('ARM: mvebu: Add support for NOR flash device on Armada XP-DB board')
commit 1a88f809ccb5db1509a7514b187c00b3a995fc82 upstream.
in the Armada XP GP Device Tree: a 8 bits bus width was declared, even
the NOR flash.
files as well.
da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for
NOR flash device on Armada XP-GP board') which was merged in v3.10.
Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board')
commit cf7eb979116c2568e8bc3b6a7269c7a359864ace upstream.
This is another great example of trainwreck engineering:
commit 2646a0e529 (ARM: edma: Add EDMA crossbar event mux support)
added support for using EDMA on peripherals which have no direct EDMA
event mapping.
The code compiles and does not explode in your face, but that's it.
1) Reading an u16 array from an u32 device tree array simply does not
work. Even if the function is named "edma_of_read_u32_to_s16_array".
It merily calls of_property_read_u16_array. So the resulting 16bit
array will have every other entry = 0.
2) The DT entry for the xbar registers related to xbar has length 0x10
instead of the real length: 0xfd0 - 0xf90 = 0x40.
Not a real problem as it does not cross a page boundary, but
wrong nevertheless.
3) But none of this matters as the mapping never happens:
After reading nonsense edma_of_read_u32_to_s16_array() invalidates
the first array entry pair, so nobody can ever notice the
braindamage by immediate explosion.
Seems the QA criteria for this code was solely not to explode when
someone adds edma-xbar-event-map entries to the DT. Goal achieved,
congratulations!
Not really helpful if someone wants to use edma on a device which
requires a xbar mapping.
Fix the issues by:
- annotating the device tree entry with "/bits/ 16" as documented in
the of_property_read_u16_array kernel doc
- make the size of the xbar register mapping correct
- invalidating the end of the array and not the start
This convoluted mess wants to be completely rewritten as there is no
point to keep the xbar_chan array memory and the iomapping of the xbar
regs around forever. Marking the xbar mapped channels as used should
be done right there.
But that's a different issue and this patch is small enough to make it
work and allows a simple backport for stable.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit 6d66da89bf4422c0a0693627fb3e25f74af50f92 upstream.
The IPU register space is 128MB, not 2GB.
Fixes: abed9a6bf2bb 'ARM i.MX53: Add IPU support'
Acked-by: Shawn Guo <shawn.guo@freescale.com>
commit 788296b2d19d16ec33aba0a5ad1544d50bb58601 upstream.
Commit 54397d85349f
("ARM: kirkwood: Relocate PCIe device tree nodes")
moved the pcie-controller nodes for the Kirkwood SoCs to the mbus
bus node. For some reason, two boards were not properly converted
and have their pci-controller nodes still in the ocp bus node.
As the corresponding SoC pcie-controller does not exist anymore,
it is likely that pcie is broken on those boards since above commit.
Fix it by moving the pcie related nodes to the correct location.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Fixes: 54397d85349f ("ARM: kirkwood: Relocate PCIe device tree nodes")
Acked-by: Andrew Lunn <andrew@lunn.ch>
Link: https://lkml.kernel.org/r/1398862602-29595-2-git-send-email-sebastian.hesselbarth@gmail.com
commit 1cc9d48145b81e307fab94a5cf6ee66ec2f0de60 upstream.
In commit 4ca2c04085a1caa903e92a5fc0da25362150aac2 ('ARM: orion5x:
Move to ID based window creation'), the mach-orion5x code was changed
to use the new mvebu-mbus API. However, in the process, a mistake was
made on the crypto SRAM window target ID: it should have been 0x9
(verified in the datasheet) and not 0x0.
Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Link: https://lkml.kernel.org/r/1397400006-4315-2-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: 4ca2c04085a1 ('ARM: orion5x: Move to ID based window creation')
commit 4797ec2dc83a43be35bad56037d1b53db9e2b5d5 upstream.
The following happens when trying to run a kvm guest on a kernel
configured for 64k pages. This doesn't happen with 4k pages:
BUG: failure at include/linux/mm.h:297/put_page_testzero()!
Kernel panic - not syncing: BUG!
CPU: 2 PID: 4228 Comm: qemu-system-aar Tainted: GF 3.13.0-0.rc7.31.sa2.k32v1.aarch64.debug #1
Call trace:
[<fffffe0000096034>] dump_backtrace+0x0/0x16c
[<fffffe00000961b4>] show_stack+0x14/0x1c
[<fffffe000066e648>] dump_stack+0x84/0xb0
[<fffffe0000668678>] panic+0xf4/0x220
[<fffffe000018ec78>] free_reserved_area+0x0/0x110
[<fffffe000018edd8>] free_pages+0x50/0x88
[<fffffe00000a759c>] kvm_free_stage2_pgd+0x30/0x40
[<fffffe00000a5354>] kvm_arch_destroy_vm+0x18/0x44
[<fffffe00000a1854>] kvm_put_kvm+0xf0/0x184
[<fffffe00000a1938>] kvm_vm_release+0x10/0x1c
[<fffffe00001edc1c>] __fput+0xb0/0x288
[<fffffe00001ede4c>] ____fput+0xc/0x14
[<fffffe00000d5a2c>] task_work_run+0xa8/0x11c
[<fffffe0000095c14>] do_notify_resume+0x54/0x58
In arch/arm/kvm/mmu.c:unmap_range(), we end up doing an extra put_page()
on the stage2 pgd which leads to the BUG in put_page_testzero(). This
happens because a pud_huge() test in unmap_range() returns true when it
should always be false with 2-level pages tables used by 64k pages.
This patch removes support for huge puds if 2-level pagetables are
being used.
Signed-off-by: Mark Salter <msalter@redhat.com>
[catalin.marinas@arm.com: removed #ifndef around PUD_SIZE check]
commit 9844f5462392b53824e8b86726e7c33b5ecbb676 upstream.
The invalidation is required in order to maintain proper semantics
under CoW conditions. In scenarios where a process clones several
threads, a thread operating on a core whose DTLB entry for a
particular hugepage has not been invalidated, will be reading from
the hugepage that belongs to the forked child process, even after
hugetlb_cow().
The thread will not see the updated page as long as the stale DTLB
entry remains cached, the thread attempts to write into the page,
the child process exits, or the thread gets migrated to a different
processor.
Signed-off-by: Anthony Iliopoulos <anthony.iliopoulos@huawei.com>
Link: http://lkml.kernel.org/r/20140514092948.GA17391@server-36.huawei.corp
Suggested-by: Shay Goikhman <shay.goikhman@huawei.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream.
The current implementation of irq_set_affinity() refuses rightfully to
route an interrupt to an offline cpu.
But there is a special case, where this is actually desired. Some of
the ARM SoCs have per cpu timers which require setting the affinity
during cpu startup where the cpu is not yet in the online mask.
If we can't do that, then the local timer interrupt for the about to
become online cpu is routed to some random online cpu.
The developers of the affected machines tried to work around that
issue, but that results in a massive mess in that timer code.
We have a yet unused argument in the set_affinity callbacks of the irq
chips, which I added back then for a similar reason. It was never
required so it got not used. But I'm happy that I never removed it.
That allows us to implement a sane handling of the above scenario. So
the affected SoC drivers can add the required force handling to their
interrupt chip, switch the timer code to irq_force_affinity() and
things just work.
This does not affect any existing user of irq_set_affinity().
Tagged for stable to allow a simple fix of the affected SoC clock
event drivers.
Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>,
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>,
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: linux-arm-kernel@lists.infradead.org,
Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de
commit dfc44f8030653b345fc6fb337558c3a07536823f upstream.
A few platforms lack a 'device_type = "memory"' for their memory
nodes, relying on an old ppc quirk in order to discover its memory.
Add the missing data so that all parsing code can find memory nodes
correctly.
Acked-by: John Crispin <blogic@openwrt.org>
commit 8e8acb32960f42c81b1d50deac56a2c07bb6a18a upstream.
Loongson2 has been using (incorrectly) kHz for cpu_clk rate. This has
been unnoticed, as loongson2_cpufreq was the only place where the rate
was set/get. After commit 652ed95d5fa6074b3c4ea245deb0691f1acb6656
(cpufreq: introduce cpufreq_generic_get() routine) things however broke,
and now loops_per_jiffy adjustments are incorrect (1000 times too long).
The patch fixes this by changing cpu_clk rate to Hz.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: cpufreq@vger.kernel.org
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Patchwork: https://patchwork.linux-mips.org/patch/6678/
[ Upstream commit e84d2f8d2ae33c8215429824e1ecf24cbca9645e ]
This is the s390 variant of Alexei's JIT bug fix.
(patch description below stolen from Alexei's patch)
bpf_alloc_binary() adds 128 bytes of room to JITed program image
and rounds it up to the nearest page size. If image size is close
to page size (like 4000), it is rounded to two pages:
round_up(4000 + 4 + 128) == 8192
then 'hole' is computed as 8192 - (4000 + 4) = 4188
If prandom_u32() % hole selects a number >= PAGE_SIZE - sizeof(*header)
then kernel will crash during bpf_jit_free():
kernel BUG at arch/x86/mm/pageattr.c:887!
Call Trace:
[<ffffffff81037285>] change_page_attr_set_clr+0x135/0x460
[<ffffffff81694cc0>] ? _raw_spin_unlock_irq+0x30/0x50
[<ffffffff810378ff>] set_memory_rw+0x2f/0x40
[<ffffffffa01a0d8d>] bpf_jit_free_deferred+0x2d/0x60
[<ffffffff8106bf98>] process_one_work+0x1d8/0x6a0
[<ffffffff8106bf38>] ? process_one_work+0x178/0x6a0
[<ffffffff8106c90c>] worker_thread+0x11c/0x370
since bpf_jit_free() does:
unsigned long addr = (unsigned long)fp->bpf_func & PAGE_MASK;
struct bpf_binary_header *header = (void *)addr;
to compute start address of 'bpf_binary_header'
and header->pages will pass junk to:
set_memory_rw(addr, header->pages);
Fix it by making sure that &header->image[prandom_u32() % hole] and &header
are in the same page.
Fixes: aa2d2c73c21f2 ("s390/bpf,jit: address randomize and write protect jit code")
Reported-by: Alexei Starovoitov <ast@plumgrid.com>
Cc: <stable@vger.kernel.org> # v3.11+
[ Upstream commit 773cd38f40b8834be991dbfed36683acc1dd41ee ]
Call Trace:
Fixes: 314beb9bcabfd ("x86: bpf_jit_comp: secure bpf jit against spraying attacks")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
commit e0fc17a936334c08b2729fff87168c03fdecf5b6 upstream.
The git commit a945928ea2709bc0e8e8165d33aed855a0110279
('xen: Do not enable spinlocks before jump_label_init() has executed')
was added to deal with the jump machinery. Earlier the code
that turned on the jump label was only called by Xen specific
functions. But now that it had been moved to the initcall machinery
it gets called on Xen, KVM, and baremetal - ouch!. And the detection
machinery to only call it on Xen wasn't remembered in the heat
of merge window excitement.
This means that the slowpath is enabled on baremetal while it should
not be.
Reported-by: Waiman Long <waiman.long@hp.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
CC: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit e0d8898d76a785453bfaf6cd08b830a7d5189f78 upstream.
There are only a couple of architectures that override _STK_LIM_MAX to
a non-infinity value. This changes the stack allocation semantics in
subtle ways. For example, GNU make changes its stack allocation to the
hard maximum defined by _STK_LIM_MAX. As a results, threads executed
by processes running under make are allocated a stack size of
_STK_LIM_MAX rather than a sensible default value. This causes various
thread stress tests to fail when they can't muster more than about 50
threads.
The attached change implements the default behavior used by the
majority of architectures.
Reviewed-by: Carlos O'Donell <carlos@systemhalted.org>
commit ab3e55b119c9653b19ea4edffb86f04db867ac98 upstream.
This bug was detected with the libio-epoll-perl debian package where the
test case IO-Ppoll-compat.t failed.
commit 0ef36bd2b37815719e31a72d2beecc28ca8ecd26 upstream.
On parisc, SHMLBA was defined to 0x00400000 (4MB) to reflect that we need to
take care of our caches for shared mappings. But actually, we can map a file at
any multiple address of PAGE_SIZE, so let us correct that now with a value of
PAGE_SIZE for SHMLBA. Instead we now take care of this cache colouring via the
constant SHM_COLOUR while we map shared pages.
CC: Jeroen Roovers <jer@gentoo.org>
CC: John David Anglin <dave.anglin@bell.net>
CC: Carlos O'Donell <carlos@systemhalted.org>
Many people reported preemption/reschedule problems with i386 kernels
for .13 and .14. After Michele bisected this to a combination of
3e8e42c69bb ("sched: Revert need_resched() to look at TIF_NEED_RESCHED")
ded79754754 ("irq: Force hardirq exit's softirq processing on its own stack")
it finally dawned on me that i386's current_thread_info() was to
blame.
When we are on interrupt/exception stacks, we fail to observe the
right TIF_NEED_RESCHED bit and therefore the PREEMPT_NEED_RESCHED
folding malfunctions.
Current upstream fixes this by making i386 behave the same as x86_64
already did:
2432e1364bbe ("x86: Nuke the supervisor_stack field in i386 thread_info")
b807902a88c4 ("x86: Nuke GET_THREAD_INFO_WITH_ESP() macro for i386")
0788aa6a23cb ("x86: Prepare removal of previous_esp from i386 thread_info structure")
198d208df437 ("x86: Keep thread_info on thread stack in x86_32")
However, that is far too much to stuff into -stable. Therefore I
propose we merge the below patch which uses task_thread_info(current)
for tif_need_resched() instead of the ESP based current_thread_info().
This makes sure we always observe the one true TIF_NEED_RESCHED bit
and things will work as expected again.
Cc: bp@alien8.de
Cc: fweisbec@gmail.com
Cc: david.a.cohen@linux.intel.com
Cc: mingo@kernel.org
Cc: greg@kroah.com
Cc: gregkh@linuxfoundation.org
Cc: pbonzini@redhat.com
Cc: rostedt@goodmis.org
Cc: stefan.bader@canonical.com
Cc: toralf.foerster@gmx.de
Cc: David Cohen <david.a.cohen@linux.intel.com>
Cc: torvalds@linux-foundation.org
Cc: <stable-commits@vger.kernel.org>
Cc: peterz@infradead.org
Cc: barra_cuda@katamail.com
Tested-by: Stefan Bader <stefan.bader@canonical.com>
Tested-by: Toralf F¿rster <toralf.foerster@gmx.de>
Tested-by: Michele Ballabio <barra_cuda@katamail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20140409142447.GD13658@twins.programming.kicks-ass.net
commit b351c39cc9e0151cee9b8d52a1e714928faabb38 upstream.
Function and callers can be preempted.
https://bugzilla.kernel.org/show_bug.cgi?id=73721
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
commit 14262d67fe348018af368a07430fbc06eadeabb1 upstream.
If you are using a 64-bit kernel with 32-bit userland, then
scripts/gcc-x86_64-has-stack-protector.sh invokes 32-bit gcc
with -mcmodel=kernel, which produces:
<stdin>:1:0: error: code model 'kernel' not supported in the 32 bit mode
and trips the "broken compiler" test at arch/x86/Makefile:120.
There are several places a fix is possible, but the following seems
cleanest. (But it's minimal; it would also be possible to factor
out a bunch of stuff from the two branches of the if.)
Signed-off-by: George Spelvin <linux@horizon.com>
Link: http://lkml.kernel.org/r/20140507210552.7581.qmail@ns.horizon.com
commit 8aa9e85adac609588eeec356e5a85059b3b819ba upstream.
There was a very small race window where resume to kernel mode from a
Exception Path (or pure kernel mode which is true for most of ARC
exceptions anyways), was not disabling interrupts in restore_regs,
clobbering the exception regs
Anton found the culprit call flow (after many sleepless nights)
| 1. we got a Trap from user land
| 2. started to service it.
| 3. While doing some stuff on user-land memory (I think it is padzero()),
| we got a DataTlbMiss
| 4. On return from it we are taking "resume_kernel_mode" path
| 5. NEED_RESHED is not set, so we go to "return from exception" path in
| restore regs.
| 6. there seems to be IRQ happening
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Anton Kolesov <Anton.Kolesov@synopsys.com>
Cc: Francois Bedard <Francois.Bedard@synopsys.com>
commit d345ea2892ae7a2b70f84cf881c20731e43e4993 upstream.
The symbol is an orphan, get rid of it.
Fixes: 7d0857a54aed ("ARC: [SMP] Disallow RTSC")
Signed-off-by: Richard Weinberger <richard@nod.at>
Acked-by: Paul Bolle <pebolle@tiscali.nl>
commit 6e0de817594c61f3b392a9245deeb09609ec707d upstream.
The A register needs to be initialized to zero in the prolog if the
first instruction of the BPF program is BPF_S_LDX_B_MSH to prevent
leaking the content of %r5 to user space.
commit 4fb8d027dca0236c811272d342cf185569d91311 upstream.
commit 41dd03a9 may cause Oops in rtas_stop_self().
The reason is that the rtas_args was moved into stack space. For a box
with more that 4GB RAM, the stack could easily be outside 32bit range,
but RTAS is 32bit.
So the patch moves rtas_args away from stack by adding static before
it.
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
commit e6b8fd028b584ffca7a7255b8971f254932c9fce upstream.
We can't take an IRQ when we're about to do a trechkpt as our GPR state is set
to user GPR values.
We've hit this when running some IBM Java stress tests in the lab resulting in
the following dump:
cpu 0x3f: Vector: 700 (Program Check) at [c000000007eb3d40]
pc: c000000000050074: restore_gprs+0xc0/0x148
lr: 00000000b52a8184
sp: ac57d360
msr: 8000000100201030
current = 0xc00000002c500000
paca = 0xc000000007dbfc00 softe: 0 irq_happened: 0x00
pid = 34535, comm = Pooled Thread #
R00 = 00000000b52a8184 R16 = 00000000b3e48fda
R01 = 00000000ac57d360 R17 = 00000000ade79bd8
R02 = 00000000ac586930 R18 = 000000000fac9bcc
R03 = 00000000ade60000 R19 = 00000000ac57f930
R04 = 00000000f6624918 R20 = 00000000ade79be8
R05 = 00000000f663f238 R21 = 00000000ac218a54
R06 = 0000000000000002 R22 = 000000000f956280
R07 = 0000000000000008 R23 = 000000000000007e
R08 = 000000000000000a R24 = 000000000000000c
R09 = 00000000b6e69160 R25 = 00000000b424cf00
R10 = 0000000000000181 R26 = 00000000f66256d4
R11 = 000000000f365ec0 R27 = 00000000b6fdcdd0
R12 = 00000000f66400f0 R28 = 0000000000000001
R13 = 00000000ada71900 R29 = 00000000ade5a300
R14 = 00000000ac2185a8 R30 = 00000000f663f238
R15 = 0000000000000004 R31 = 00000000f6624918
pc = c000000000050074 restore_gprs+0xc0/0x148
cfar= c00000000004fe28 dont_restore_vec+0x1c/0x1a4
lr = 00000000b52a8184
msr = 8000000100201030 cr = 24804888
ctr = 0000000000000000 xer = 0000000000000000 trap = 700
This moves tm_recheckpoint to a C function and moves the tm_restore_sprs into
that function. It then adds IRQ disabling over the trechkpt critical section.
It also sets the TEXASR FS in the signals code to ensure this is never set now
that we explictly write the TM sprs in tm_recheckpoint.
Signed-off-by: Michael Neuling <mikey@neuling.org>
