commit 90944e40ba1838de4b2a9290cf273f9d76bd3bdd upstream.
If the gcc is configured to do -fPIE by default then the build aborts
later with:
| Unsupported relocation type: unknown type rel type name (29)
Tagging it stable so it is possible to compile recent stable kernels as
well.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Michal Marek <mmarek@suse.com>
commit 1650b4ebc99da4c137bfbfc531be4a2405f951dd upstream.
Function user_notifier_unregister should be called only once for each
registered user notifier.
Function kvm_arch_hardware_disable can be executed from an IPI context
which could cause a race condition with a VCPU returning to user mode
and attempting to unregister the notifier.
Signed-off-by: Ignacio Alvarado <ikalvarado@google.com>
Fixes: 18863bdd60f8 ("KVM: x86 shared msr infrastructure")
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 7301d6abaea926d685832f7e1f0c37dd206b01f4 upstream.
Reported by syzkaller:
[ INFO: suspicious RCU usage. ]
4.9.0-rc4+ #47 Not tainted
./include/linux/kvm_host.h:536 suspicious rcu_dereference_check() usage!
stack backtrace:
CPU: 1 PID: 6679 Comm: syz-executor Not tainted 4.9.0-rc4+ #47
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
ffff880039e2f6d0 ffffffff81c2e46b ffff88003e3a5b40 0000000000000000
0000000000000001 ffffffff83215600 ffff880039e2f700 ffffffff81334ea9
ffffc9000730b000 0000000000000004 ffff88003c4f8420 ffff88003d3f8000
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff81c2e46b>] dump_stack+0xb3/0x118 lib/dump_stack.c:51
[<ffffffff81334ea9>] lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4445
[< inline >] __kvm_memslots include/linux/kvm_host.h:534
[< inline >] kvm_memslots include/linux/kvm_host.h:541
[<ffffffff8105d6ae>] kvm_gfn_to_hva_cache_init+0xa1e/0xce0 virt/kvm/kvm_main.c:1941
[<ffffffff8112685d>] kvm_lapic_set_vapic_addr+0xed/0x140 arch/x86/kvm/lapic.c:2217
Fixes: fda4e2e85589191b123d31cdc21fd33ee70f50fd
Cc: Andrew Honig <ahonig@google.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
commit b0b6e86846093c5f8820386bc01515f857dd8faa upstream.
cpu_llc_id (Last Level Cache ID) derivation on AMD Fam17h has an
underflow bug when extracting the socket_id value. It starts from 0
so subtracting 1 from it will result in an invalid value. This breaks
scheduling topology later on since the cpu_llc_id will be incorrect.
For example, the the cpu_llc_id of the *other* CPU in the loops in
set_cpu_sibling_map() underflows and we're generating the funniest
thread_siblings masks and then when I run 8 threads of nbench, they get
spread around the LLC domains in a very strange pattern which doesn't
give you the normal scheduling spread one would expect for performance.
Other things like EDAC use cpu_llc_id so they will be b0rked too.
So, the APIC ID is preset in APICx020 for bits 3 and above: they contain
the core complex, node and socket IDs.
The LLC is at the core complex level so we can find a unique cpu_llc_id
by right shifting the APICID by 3 because then the least significant bit
will be the Core Complex ID.
Tested-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
[ Cleaned up and extended the commit message. ]
Cc: Aravind Gopalakrishnan <aravindksg.lkml@gmail.com>
Fixes: 3849e91f571d ("x86/AMD: Fix last level cache topology for AMD Fam17h systems")
Link: http://lkml.kernel.org/r/20161108083506.rvqb5h4chrcptj7d@pd.tnic
[ Upstream commit 0fd0ff01d4c3c01e7fe69b762ee1a13236639acc ]
Now that all of the user copy routines are converted to return
accurate residual lengths when an exception occurs, we no longer need
the broken fixup routines.
[ Upstream commit 614da3d9685b67917cab48c8452fd8bf93de0867 ]
All of __ret{,l}_mone{_asi,_fp,_asi_fpu} are now unused.
[ Upstream commit ee841d0aff649164080e445e84885015958d8ff4 ]
Report the exact number of bytes which have not been successfully
copied when an exception occurs, using the running remaining length.
[ Upstream commit e93704e4464fdc191f73fce35129c18de2ebf95d ]
[ Upstream commit 7ae3aaf53f1695877ccd5ebbc49ea65991e41f1e ]
[ Upstream commit 95707704800988093a9b9a27e0f2f67f5b4bf2fa ]
[ Upstream commit cb736fdbb208eb3420f1a2eb2bfc024a6e9dcada ]
[ Upstream commit d0796b555ba60c22eb41ae39a8362156cb08eee9 ]
[ Upstream commit 0096ac9f47b1a2e851b3165d44065d18e5f13d58 ]
[ Upstream commit 83a17d2661674d8c198adc0e183418f72aabab79 ]
The fixup helper function mechanism for handling user copy fault
handling is not %100 accurrate, and can never be made so.
We are going to transition the code to return the running return
return length, which is always kept track in one or more registers
of each of these routines.
In order to convert them one by one, we have to allow the existing
behavior to continue functioning.
Therefore make all the copy code that wants the fixup helper to be
used return negative one.
After all of the user copy routines have been converted, this logic
and the fixup helpers themselves can be removed completely.
[ Upstream commit aa95ce361ed95c72ac42dcb315166bce5cf1a014 ]
It is completely unused.
[ Upstream commit a74ad5e660a9ee1d071665e7e8ad822784a2dc7f ]
When the vmalloc area gets fragmented, and because the firmware
mapping area sits between where modules live and the vmalloc area, we
can sometimes receive requests for enormous kernel TLB range flushes.
When this happens the cpu just spins flushing billions of pages and
this triggers the NMI watchdog and other problems.
We took care of this on the TSB side by doing a linear scan of the
table once we pass a certain threshold.
Do something similar for the TLB flush, however we are limited by
the TLB flush facilities provided by the different chip variants.
First of all we use an (mostly arbitrary) cut-off of 256K which is
about 32 pages. This can be tuned in the future.
The huge range code path for each chip works as follows:
1) On spitfire we flush all non-locked TLB entries using diagnostic
acceses.
2) On cheetah we use the "flush all" TLB flush.
3) On sun4v/hypervisor we do a TLB context flush on context 0, which
unlike previous chips does not remove "permanent" or locked
entries.
We could probably do something better on spitfire, such as limiting
the flush to kernel TLB entries or even doing range comparisons.
However that probably isn't worth it since those chips are old and
the TLB only had 64 entries.
Reported-by: James Clarke <jrtc27@jrtc27.com>
Tested-by: James Clarke <jrtc27@jrtc27.com>
code.
[ Upstream commit a236441bb69723032db94128761a469030c3fe6d ]
Just like the non-cross-call TLB flush handlers, the cross-call ones need
to avoid doing PC-relative branches outside of their code blocks.
[ Upstream commit 830cda3f9855ff092b0e9610346d110846fc497c ]
Noticed by James Clarke.
[ Upstream commit b429ae4d5b565a71dfffd759dfcd4f6c093ced94 ]
When we copy code over to patch another piece of code, we can only use
PC-relative branches that target code within that piece of code.
Such PC-relative branches cannot be made to external symbols because
the patch moves the location of the code and thus modifies the
relative address of external symbols.
Use an absolute jmpl to fix this problem.
[ Upstream commit 849c498766060a16aad5b0e0d03206726e7d2fa4 ]
If the number of pages we are flushing is more than twice the number
of entries in the TSB, just scan the TSB table for matches rather
than probing each and every page in the range.
Based upon a patch and report by James Clarke.
[ Upstream commit 9d9fa230206a3aea6ef451646c97122f04777983 ]
Additionally, if the offset will overflow the immediate for a ba,pt
instruction, fall back on a standard ba to get an extra 3 bits.
Signed-off-by: James Clarke <jrtc27@jrtc27.com>
[ Upstream commit af1b1a9b36b8f9d583d4b4f90dd8946ed0cd4bd0 ]
do_sparc64_fault() calculates both the base and huge page RSS sizes and
uses this information in calls to tsb_grow(). The calculation for base
page TSB size is not correct if the task uses hugetlb pages. hugetlb
pages are not accounted for in RSS, therefore the call to get_mm_rss(mm)
does not include hugetlb pages. However, the number of pages based on
huge_pte_count (which does include hugetlb pages) is subtracted from
this value. This will result in an artificially small and often negative
RSS calculation. The base TSB size is then often set to max_tsb_size
as the passed RSS is unsigned, so a negative value looks really big.
THP pages are also accounted for in huge_pte_count, and THP pages are
accounted for in RSS so the calculation in do_sparc64_fault() is correct
if a task only uses THP pages.
A single huge_pte_count is not sufficient for TSB sizing if both hugetlb
and THP pages can be used. Instead of a single counter, use two: one
for hugetlb and one for THP.
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
[ Upstream commit 4f6deb8cbab532a8d7250bc09234c1795ecb5e2c ]
On pre-Niagara systems, we fetch the fault address on data TLB
exceptions from the TLB_TAG_ACCESS register. But this register also
contains the context ID assosciated with the fault in the low 13 bits
of the register value.
This propagates into current_thread_info()->fault_address and can
cause trouble later on.
So clear the low 13-bits out of the TLB_TAG_ACCESS value in the cases
where it matters.
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
commit e1e575f6b026734be3b1f075e780e91ab08ca541 upstream.
The advancing of the PC when completing an MMIO load is done before
re-entering the guest, i.e. before restoring the guest ASID. However if
the load is in a branch delay slot it may need to access guest code to
read the prior branch instruction. This isn't safe in TLB mapped code at
the moment, nor in the future when we'll access unmapped guest segments
using direct user accessors too, as it could read the branch from host
user memory instead.
Therefore calculate the resume PC in advance while we're still in the
right context and save it in the new vcpu->arch.io_pc (replacing the no
longer needed vcpu->arch.pending_load_cause), and restore it on MMIO
completion.
Fixes: e685c689f3a8 ("KVM/MIPS32: Privileged instruction/target branch emulation.")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: "Radim Krčmář" <rkrcmar@redhat.com>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
[james.hogan@imgtec.com: Backport to 3.18..4.4]
commit 922cc171998ac3dbe74d57011ef7ed57e9b0d7df upstream.
The current code doesn't even compile as somehow the inline assembly
can't see the register names defined as ARC_RTC_*
I'm pretty sure It worked when I first got it merged, but the tools were
definitely different then.
So better to write this in "C" anyways.
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 237d6e6884136923b6bd26d5141ebe1d065960c9 upstream.
Since commit d86bd1bece6f ("mm/slub: support left redzone") it is no longer
guaranteed that kmalloc(PAGE_SIZE) returns page aligned memory.
After the above commit we get an error for diag224 because aligned
memory is required. This leads to the following user visible error:
# mount none -t s390_hypfs /sys/hypervisor/
mount: unknown filesystem type 's390_hypfs'
# dmesg | grep hypfs
hypfs.cccfb8: The hardware system does not provide all functions
required by hypfs
hypfs.7a79f0: Initialization of hypfs failed with rc=-61
Fix this problem and use get_free_page() instead of kmalloc() to get
correctly aligned memory.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit 91e4f1b6073dd680d86cdb7e42d7cccca9db39d8 upstream.
When a guest TLB entry is replaced by TLBWI or TLBWR, we only invalidate
TLB entries on the local CPU. This doesn't work correctly on an SMP host
when the guest is migrated to a different physical CPU, as it could pick
up stale TLB mappings from the last time the vCPU ran on that physical
CPU.
Therefore invalidate both user and kernel host ASIDs on other CPUs,
which will cause new ASIDs to be generated when it next runs on those
CPUs.
We're careful only to do this if the TLB entry was already valid, and
only for the kernel ASID where the virtual address it mapped is outside
of the guest user address range.
Cc: <stable@vger.kernel.org> # 3.17.x-
[james.hogan@imgtec.com: Backport to 3.17..4.4]
This reverts commit d450527ad04ad180636679aeb3161ec58079f1ba which was
commit 91e4f1b6073dd680d86cdb7e42d7cccca9db39d8 upstream as it was
incorrect. A fixed version will be forthcoming.
Reported-by: James Hogan <james.hogan@imgtec.com>
commit d9092f52d7e61dd1557f2db2400ddb430e85937e upstream.
Commit 41061cdb98 ("KVM: emulate: do not initialize memopp") removes a
check for non-NULL under incorrect assumptions. An undefined instruction
with a ModR/M byte with Mod=0 and R/M-5 (e.g. 0xc7 0x15) will attempt
to dereference a null pointer here.
Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5
Message-Id: <1477592752-126650-2-git-send-email-osh@google.com>
Signed-off-by: Owen Hofmann <osh@google.com>
commit dd665be0e243873343a28e18f9f345927b658daf upstream.
gcc-6.0 warns about comparisons between two identical expressions,
which is what we get in the floppy driver when writing to the FD_DOR
register:
drivers/block/floppy.c: In function 'set_dor':
drivers/block/floppy.c:810:44: error: self-comparison always evaluates to true [-Werror=tautological-compare]
fd_outb(newdor, FD_DOR);
It would be nice to use a static inline function instead of the
macro, to avoid the warning, but we cannot do that because the
FD_DOR definition is incomplete at this point.
Adding a cast to (u32) is a harmless way to shut up the warning,
just not very nice.
commit 1e407ee3b21f981140491d5b8a36422979ca246f upstream.
gcc-6 correctly warns about a out of bounds access
arch/powerpc/kernel/ptrace.c:407:24: warning: index 32 denotes an offset greater than size of 'u64[32][1] {aka long long unsigned int[32][1]}' [-Warray-bounds]
offsetof(struct thread_fp_state, fpr[32][0]));
check the end of array instead of beginning of next element to fix this
Signed-off-by: Khem Raj <raj.khem@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Olof Johansson <olof@lixom.net>
commit 1cf38741308c64d08553602b3374fb39224eeb5a upstream.
xen_cleanhighmap() is operating on level2_kernel_pgt only. The upper
bound of the loop setting non-kernel-image entries to zero should not
exceed the size of level2_kernel_pgt.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Juergen Gross <jgross@suse.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 6ed518328d0189e0fdf1bb7c73290d546143ea66 upstream.
We have one critical section in the syscall entry path in which we switch from
the userspace stack to kernel stack. In the event of an external interrupt, the
interrupt code distinguishes between those two states by analyzing the value of
sr7. If sr7 is zero, it uses the kernel stack. Therefore it's important, that
the value of sr7 is in sync with the currently enabled stack.
This patch now disables interrupts while executing the critical section. This
prevents the interrupt handler to possibly see an inconsistent state which in
the worst case can lead to crashes.
Interestingly, in the syscall exit path interrupts were already disabled in the
critical section which switches back to the userspace stack.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Signed-off-by: Helge Deller <deller@gmx.de>
commit ede5f3e7b54a4347be4d8525269eae50902bd7cd upstream.
The ERET instruction to return from exception is used for returning from
exception level (Status.EXL) and error level (Status.ERL). If both bits
are set however we should be returning from ERL first, as ERL can
interrupt EXL, for example when an NMI is taken. KVM however checks EXL
first.
Fix the order of the checks to match the pseudocode in the instruction
set manual.
commit bd768e146624cbec7122ed15dead8daa137d909d upstream.
vcpu->arch.wbinvd_dirty_mask may still be used after freeing it,
corrupting memory. For example, the following call trace may set a bit
in an already freed cpu mask:
kvm_arch_vcpu_load
vcpu_load
vmx_free_vcpu_nested
vmx_free_vcpu
kvm_arch_vcpu_free
Fix this by deferring freeing of wbinvd_dirty_mask.
Signed-off-by: Ido Yariv <ido@wizery.com>
Not upstream as it is not needed there.
So a patch something like this might be a safe way to fix the
potential infoleak in older kernels.
THIS IS UNTESTED. It's a very obvious patch, though, so if it compiles
it probably works. It just initializes the output variable with 0 in
the inline asm description, instead of doing it in the exception
handler.
It will generate slightly worse code (a few unnecessary ALU
operations), but it doesn't have any interactions with the exception
handler implementation.
commit 21753583056d48a5fad964d6f272e28168426845 upstream.
Back in commit f56141e3e2d9 ("all arches, signal: move restart_block to
struct task_struct"), all architectures and core code were changed to
use task_struct::restart_block. However, when h8300 support was
subsequently restored in v4.2, it was not updated to account for this,
and maintains thread_info::restart_block, which is not kept in sync.
This patch drops the redundant restart_block from thread_info, and moves
h8300 to the common one in task_struct, ensuring that syscall restarting
always works as expected.
Fixes: f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct")
Link: http://lkml.kernel.org/r/1476714934-11635-1-git-send-email-mark.rutland@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: uclinux-h8-devel@lists.sourceforge.jp
This reverts commit 9d25c78ec01c402dc56272693c44ef9d72ecdd2e which is
1c109fabbd51863475cd12ac206bdd249aee35af upstream
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is
548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Cc: Borislav Petkov <bp@suse.de>
commit 9ba63e3cc849cdaf3b675c47cc51fe35419e5117 upstream.
Since its initial commit, the driver is buggy for multiple interrupts
handling. The translation from the former lubbock.c file was not
complete, and might stall all interrupt handling when multiple
interrupts occur.
This is especially true when inside the interrupt handler and if a new
interrupt comes and is not handled, leaving the output line still held,
and not creating a transition as the GPIO block behind would expect to
trigger another cplds_irq_handler() call.
For the record, the hardware is working as follows.
The interrupt mechanism relies on :
- one status register
- one mask register
Let's suppose the input irq lines are called :
- i_sa1111
- i_lan91x
- i_mmc_cd
Let's suppose the status register for each irq line is called :
- status_sa1111
- status_lan91x
- status_mmc_cd
Let's suppose the interrupt mask for each irq line is called :
- irqen_sa1111
- irqen_lan91x
- irqen_mmc_cd
Let's suppose the output irq line, connected to GPIO0 is called :
- o_gpio0
The behavior is as follows :
- o_gpio0 = not((status_sa1111 & irqen_sa1111) |
(status_lan91x & irqen_lan91x) |
(status_mmc_cd & irqen_mmc_cd))
=> this is a N-to-1 NOR gate and multiple AND gates
- irqen_* is exactly as programmed by a write to the FPGA
- status_* behavior is governed by a bi-stable D flip-flop
=> on next FPGA clock :
- if i_xxx is high, status_xxx becomes 1
- if i_xxx is low, status_xxx remains as it is
- if software sets status_xxx to 0, the D flip-flop is reset
=> status_xxx becomes 0
=> on next FPGA clock cycle, if i_xxx is high, status_xxx becomes
1 again
Fixes: fc9e38c0f4d3 ("ARM: pxa: lubbock: use new pxa_cplds driver")
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 11b7e154b132232535befe51c55db048069c8461 upstream.
When we merge two contiguous partitions whose signatures are marked
NVRAM_SIG_FREE, We need update prev's length and checksum, then write it
to nvram, not cur's. So lets fix this mistake now.
Also use memset instead of strncpy to set the partition's name. It's
more readable if we want to fill up with duplicate chars .
Fixes: fa2b4e54d41f ("powerpc/nvram: Improve partition removal")
Signed-off-by: Pan Xinhui <xinhui.pan@linux.vnet.ibm.com>
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
commit ed4767d612fd2c39e2c4c69eba484c1219dcddb6 upstream.
Since commit 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero"),
all ahash drivers are required to implement import()/export(), and must have
a non-zero statesize. Fix this for the ARM Crypto Extensions GHASH
implementation.
Fixes: 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 04fec21c06e35b169a83e75a84a015ab4606bf5e upstream.
eeh_pe_bus_get() can return NULL if a PCI bus isn't found for a given PE.
Some callers don't check this, and can cause a null pointer dereference
under certain circumstances.
Fix this by checking NULL everywhere eeh_pe_bus_get() is called.
Fixes: 8a6b1bc70dbb ("powerpc/eeh: EEH core to handle special event")
Cc: stable@vger.kernel.org # v3.11+
Signed-off-by: Russell Currey <ruscur@russell.cc>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit d721b02fd00bf133580f431b82ef37f3b746dfb2 upstream.
Looks like the TSEG lives just above TOUD, stolen comes after TSEG.
The spec seems somewhat self-contradictory in places, in the ESMRAMC
register desctription it says:
TSEG Size:
10=(TOUD + 512 KB) to TOUD
11 =(TOUD + 1 MB) to TOUD
so that agrees with TSEG being at TOUD. But the example given
elsehwere in the spec says:
TOUD equals 62.5 MB = 03E7FFFFh
TSEG selected as 512 KB in size,
Graphics local memory selected as 1 MB in size
General System RAM available in system = 62.5 MB
General system RAM range00000000h to 03E7FFFFh
TSEG address range03F80000h to 03FFFFFFh
TSEG pre-allocated from03F80000h to 03FFFFFFh
Graphics local memory pre-allocated from03E80000h to 03F7FFFFh
so here we have TSEG above stolen.
Real world evidence agrees with the TOUD->TSEG->stolen order however, so
let's fix up the code to account for the TSEG size.
Cc: Taketo Kabe <fdporg@vega.pgw.jp>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: x86@kernel.org
Fixes: 0ad98c74e093 ("drm/i915: Determine the stolen memory base address on gen2")
Fixes: a4dff76924fe ("x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms")
Reported-by: Taketo Kabe <fdporg@vega.pgw.jp>
Tested-by: Taketo Kabe <fdporg@vega.pgw.jp>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96473
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1470653919-27251-1-git-send-email-ville.syrjala@linux.intel.com
Link: http://download.intel.com/design/chipsets/datashts/25251405.pdf
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
commit d2cf909cda5f8c5609cb7ed6cda816c3e15528c7 upstream.
If a cxl adapter faults on an invalid address for a kernel context, we
may enter copro_calculate_slb() with a NULL mm pointer (kernel
context) and an effective address which looks like a user
address. Which will cause a crash when dereferencing mm. It is clearly
an AFU bug, but there's no reason to crash either. So return an error,
so that cxl can ack the interrupt with an address error.
Fixes: 73d16a6e0e51 ("powerpc/cell: Move data segment faulting code out of cell platform")
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Acked-by: Ian Munsie <imunsie@au1.ibm.com>
commit 850540351bb1a4fa5f192e5ce55b89928cc57f42 upstream.
Commit f436b2ac90a0 ("arm64: kernel: fix architected PMU registers
unconditional access") made sure we wouldn't access unimplemented
PMU registers, but also left MDCR_EL2 uninitialized in that case,
leading to trap bits being potentially left set.
Make sure we always write something in that register.
Fixes: f436b2ac90a0 ("arm64: kernel: fix architected PMU registers unconditional access")
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
commit 1e6e57d9b34a9075d5f9e2048ea7b09756590d11 upstream.
Writing the outer loop of an LL/SC sequence using do {...} while
constructs potentially allows the compiler to hoist memory accesses
between the STXR and the branch back to the LDXR. On CPUs that do not
guarantee forward progress of LL/SC loops when faced with memory
accesses to the same ERG (up to 2k) between the failed STXR and the
branch back, we may end up livelocking.
This patch avoids this issue in our percpu atomics by rewriting the
outer loop as part of the LL/SC inline assembly block.
Fixes: f97fc810798c ("arm64: percpu: Implement this_cpu operations")
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
commit f045402984404ddc11016358411e445192919047 upstream.
__tlb_flush_asce() should never be used if multiple asce belong to a mm.
As this function changes mm logic determining if local or global tlb
flushes will be neded, we might end up flushing only the gmap asce on all
CPUs and a follow up mm asce flushes will only flush on the local CPU,
although that asce ran on multiple CPUs.
The missing tlb flushes will provoke strange faults in user space and even
low address protections in user space, crashing the kernel.
Fixes: 1b948d6caec4 ("s390/mm,tlb: optimize TLB flushing for zEC12")
Cc: stable@vger.kernel.org # 3.15+
Reported-by: Sascha Silbe <silbe@linux.vnet.ibm.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
commit 8678654e3c7ad7b0f4beb03fa89691279cba71f9 upstream.
gcc 7 warns:
arch/x86/kvm/ioapic.c: In function 'kvm_ioapic_reset':
arch/x86/kvm/ioapic.c:597:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
And it is right. Memset whole array using sizeof operator.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: x86@kernel.org
[Added x86 subject tag]
