path: root/arch
2006-12-07[PATCH] Pass struct dev pointer to dma_cache_sync()Ralf Baechle
Pass struct dev pointer to dma_cache_sync() dma_cache_sync() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync to take a struct device pointer as first argument and fix all its callers to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add struct dev pointer to dma_is_consistent()Ralf Baechle
dma_is_consistent() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_is_consistent to take a struct device pointer as first argument and fix the sole caller to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] add rtc-omap driverDavid Brownell
This creates a new RTC-framework driver for the RTC/calendar module found in various OMAP1 chips. (OMAP2 and OMAP3 use external RTCs, like those in TI's multifunction PM companion chips.) It's been in the Linux-OMAP tree for several months now, and other trees before that, so it's quite stable. The most notable issue is that the OMAP IRQ code doesn't yet support the RTC IRQ as a wakeup event. Once that's fixed, a patch will be needed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] smp_call_function_single() check that local interrupts are enabledAndrew Morton
smp_call_function_single() can deadlock if the caller disabled local interrupts (the target CPU could be spinning on call_lock). Check for that. Why on earth do these functions use spin_lock_bh()?? Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kprobes: enable booster on the preemptible kernelMasami Hiramatsu
When we are unregistering a kprobe-booster, we can't release its instruction buffer immediately on the preemptive kernel, because some processes might be preempted on the buffer. The freeze_processes() and thaw_processes() functions can clean most of processes up from the buffer. There are still some non-frozen threads who have the PF_NOFREEZE flag. If those threads are sleeping (not preempted) at the known place outside the buffer, we can ensure safety of freeing. However, the processing of this check routine takes a long time. So, this patch introduces the garbage collection mechanism of insn_slot. It also introduces the "dirty" flag to free_insn_slot because of efficiency. The "clean" instruction slots (dirty flag is cleared) are released immediately. But the "dirty" slots which are used by boosted kprobes, are marked as garbages. collect_garbage_slots() will be invoked to release "dirty" slots if there are more than INSNS_PER_PAGE garbage slots or if there are no unused slots. Cc: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: "bibo,mao" <bibo.mao@intel.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Yumiko Sugita <yumiko.sugita.yf@hitachi.com> Cc: Satoshi Oshima <soshima@redhat.com> Cc: Hideo Aoki <haoki@redhat.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] elf: include terminating zero in n_nameszMagnus Damm
The ELF32 spec says we should plus we include the zero on other platforms. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Cc: Daniel Jacobowitz <drow@false.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] elf: Always define elf_addr_t in linux/elf.hMagnus Damm
Define elf_addr_t in linux/elf.h. The size of the type is determined using ELF_CLASS. This allows us to remove the defines that today are spread all over .c and .h files. Signed-off-by: Magnus Damm <magnus@valinux.co.jp> Cc: Daniel Jacobowitz <drow@false.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] initrd: remove unused false condition for initrd_startHenry Nestler
After LOADER_TYPE && INITRD_START are true, the short if-condition for INITRD_START can never be false. Remove unused code from the else condition. Signed-off-by: Henry Nestler <henry.ne@arcor.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] remove kernel syscallsArnd Bergmann
The last thing we agreed on was to remove the macros entirely for 2.6.19, on all architectures. Unfortunately, I think nobody actually _did_ that, so they are still there. [akpm@osdl.org: x86_64 fix] Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg Schafer <gschafer@zip.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: name some old style locksPeter Zijlstra
Name some of the remaning 'old_style_spin_init' locks Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Export pm_suspend for the shared APM emulationRalf Baechle
The new shared APM emulation just like its ARM and MIPS predecessors uses pm_suspend() which was only exported on SH. Move export to close to it's definition where it really should be anyway. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uml: use get_random_bytes() after random pool is seededJeff Dike
When the UML network driver generates random MACs for its devices, it was possible for a number of UMLs to get the same MACs because the ethernet initialization was done before the random pool was properly seeded. This patch moves the initialization later so that it gets better randomness. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uml: size register files correctlyJeff Dike
We were using the wrong symbol to size register files. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uml: include asm/page.h in order to get PAGE_SHIFTJeff Dike
Include the proper header to get a definition of PAGE_SHIFT. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uml: include stddef.h correctlyJeff Dike
We were not including stddef.h in files that used offsetof. One file was also including linux/stddef.h for no perciptible reason. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] m68k: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] swsusp: Support i386 systems with PAE or without PSERafael J. Wysocki
Make swsusp support i386 systems with PAE or without PSE. This is done by creating temporary page tables located in resume-safe page frames before the suspend image is restored in the same way as x86_64 does it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Andi Kleen <ak@suse.de> Cc: Dave Jones <davej@redhat.com> Cc: Nigel Cunningham <ncunningham@linuxmail.org> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] alpha: switch to pci_get APIAlan Cox
Now that we have pci_get_bus_and_slot we can do the job correctly. Note that some of these calls intentionally leak a device - this is because the device in question is always needed from boot to reboot. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] h8300 stray bracket fixMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] avr32: fixup kprobes preemption handlingPaul Mundt
While working on SH kprobes, I noticed that avr32 got the preemption handling wrong in the no probe case. The idea is that upon entry of kprobe_handler() preemption is disabled outright across the life of the kprobe, only to be re-enabled in post_kprobe_handler(). However, in the event that the probe is never activated, there's never any chance of hitting the post probe handler, which allows for the current avr32 implementation to disable preemption indefinitely, as it's currently missing a re-enable when no probe is activated. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] arch/frv/kernel/futex.c must #include <linux/uaccess.h>Adrian Bunk
This patch fixes the following compile error with -Werror-implicit-function-declaration (without -Werror-implicit-function-declaration it's a link error): ... CC arch/frv/kernel/futex.o /home/bunk/linux/kernel-2.6/linux-2.6.19-rc6-mm2/arch/frv/kernel/futex.c: In function 'futex_atomic_op_inuser': /home/bunk/linux/kernel-2.6/linux-2.6.19-rc6-mm2/arch/frv/kernel/futex.c:203: error: implicit declaration of function 'pagefault_disable' /home/bunk/linux/kernel-2.6/linux-2.6.19-rc6-mm2/arch/frv/kernel/futex.c:226: error: implicit declaration of function 'pagefault_enable' make[2]: *** [arch/frv/kernel/futex.o] Error 1 ... Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Allow NULL pointers in percpu_freeAlan Stern
The patch (as824b) makes percpu_free() ignore NULL arguments, as one would expect for a deallocation routine. (Note that free_percpu is #defined as percpu_free in include/linux/percpu.h.) A few callers are updated to remove now-unneeded tests for NULL. A few other callers already seem to assume that passing a NULL pointer to percpu_free() is okay! The patch also removes an unnecessary NULL check in percpu_depopulate(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Fix kunmap_atomic's use of kpte_clear_flush()Jeremy Fitzhardinge
kunmap_atomic() will call kpte_clear_flush with vaddr/ptep arguments which don't correspond if the vaddr is just a normal lowmem address (ie, not in the KMAP area). This patch makes sure that the pte is only cleared if kmap area was actually used for the mapping. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Zachary Amsden <zach@vmware.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: pagefault_{disable,enable}()Peter Zijlstra
Introduce pagefault_{disable,enable}() and use these where previously we did manual preempt increments/decrements to make the pagefault handler do the atomic thing. Currently they still rely on the increased preempt count, but do not rely on the disabled preemption, this might go away in the future. (NOTE: the extra barrier() in pagefault_disable might fix some holes on machines which have too many registers for their own good) [heiko.carstens@de.ibm.com: s390 fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] mm: arch do_page_fault() vs in_atomic()Peter Zijlstra
In light of the recent pagefault and filemap_copy_from_user work I've gone through all the arch pagefault handlers to make sure the inc_preempt_count() 'feature' works as expected. Several sections of code (including the new filemap_copy_from_user) rely on the fact that faults do not take locks under increased preempt count. arch/x86_64 - good arch/powerpc - good arch/cris - fixed arch/i386 - good arch/parisc - fixed arch/sh - good arch/sparc - good arch/s390 - good arch/m68k - fixed arch/ppc - good arch/alpha - fixed arch/mips - good arch/sparc64 - good arch/ia64 - good arch/arm - fixed arch/um - good arch/avr32 - good arch/h8300 - NA arch/m32r - good arch/v850 - good arch/frv - fixed arch/m68knommu - NA arch/arm26 - fixed arch/sh64 - fixed arch/xtensa - good Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] shared page table for hugetlb pageChen, Kenneth W
Following up with the work on shared page table done by Dave McCracken. This set of patch target shared page table for hugetlb memory only. The shared page table is particular useful in the situation of large number of independent processes sharing large shared memory segments. In the normal page case, the amount of memory saved from process' page table is quite significant. For hugetlb, the saving on page table memory is not the primary objective (as hugetlb itself already cuts down page table overhead significantly), instead, the purpose of using shared page table on hugetlb is to allow faster TLB refill and smaller cache pollution upon TLB miss. With PT sharing, pte entries are shared among hundreds of processes, the cache consumption used by all the page table is smaller and in return, application gets much higher cache hit ratio. One other effect is that cache hit ratio with hardware page walker hitting on pte in cache will be higher and this helps to reduce tlb miss latency. These two effects contribute to higher application performance. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Dave McCracken <dmccr@us.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] uml: workqueue build fixAndrew Morton
arch/um/drivers/chan_kern.c:643: error: conflicting types for 'chan_interrupt' arch/um/include/chan_kern.h:31: error: previous declaration of 'chan_interrupt' Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Import updates from i386's i8259.c [MIPS] *-berr: Header inclusions for DEC bus error handlers [MIPS] Compile __do_IRQ() when really needed [MIPS] genirq: use name instead of typename [MIPS] Do not use handle_level_irq for ioasic_dma_irq_type. [MIPS] pte_offset(dir,addr): parenthesis fix
2006-12-06[IA64] Fix pci.c kernel compilation breakage.Peter Chubb
The recent change to convert the is_enabled flag in the PCI device to an atomic count broke the IA64 compilation. As pcibios_disable_device is only ever called if the reference count is zero, convert the if to a BUG_ON. Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-12-06[MIPS] Import updates from i386's i8259.cAtsushi Nemoto
Import many updates from i386's i8259.c, especially genirq transitions. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] *-berr: Header inclusions for DEC bus error handlersMaciej W. Rozycki
A fixup to add missing header inclusions for bus error handlers for DECstation system after the recent switch to get_irq_regs(). Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] Compile __do_IRQ() when really neededFranck Bui-Huu
__do_IRQ() is needed only by irq handlers that can't use default handlers defined in kernel/irq/chip.c. For others platforms there's no need to compile this function since it won't be used. For those platforms this patch defines GENERIC_HARDIRQS_NO__DO_IRQ symbol which is used exactly for this purpose. Futhermore for platforms which do not use __do_IRQ(), end() method which is part of the 'irq_chip' structure is not used. This patch simply removes this method in this case. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] genirq: use name instead of typenameAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] Do not use handle_level_irq for ioasic_dma_irq_type.Atsushi Nemoto
2006-12-06Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: (43 commits) sh: sh775x/titan fixes for irq header changes. sh: update r7780rp defconfig. sh: compile fixes for header cleanup. sh: Fixup pte_mkhuge() build failure. sh: set KBUILD_IMAGE to something sensible. sh: show held locks in stack trace with lockdep. sh: platform_pata support for R7780RP sh: stacktrace/lockdep/irqflags tracing support. sh: Fixup movli.l/movco.l atomic ops for gcc4. sh: dyntick infrastructure. sh: Clock framework tidying. sh: Turn off IRQs around get_timer_offset() calls. sh: Get the PGD right in oops case with 64-bit PTEs. sh: Fix store queue bitmap end. sh: More flexible + SH7780 earlyprintk SCIF support. sh: Fixup various PAGE_SIZE == 4096 assumptions. sh: Fixup 4K irq stacks. sh: dma-api channel capability extensions. sh: Drop name overload in dma-sh. sh: Make dma-isa depend on ISA_DMA_API. ...
2006-12-06Merge git://git.infradead.org/users/dhowells/workq-2.6Linus Torvalds
* git://git.infradead.org/users/dhowells/workq-2.6: Actually update the fixed up compile failures. WorkQueue: Fix up arch-specific work items where possible WorkStruct: make allyesconfig WorkStruct: Pass the work_struct pointer instead of context data WorkStruct: Merge the pending bit into the wq_data pointer WorkStruct: Typedef the work function prototype WorkStruct: Separate delayable and non-delayable events.
2006-12-06[PATCH] m68knommu: switch 68360 to using rtc_timeGreg Ungerer
Adds support for RTCs (through genrtc) for M68KNOMMU. Board-specific code will have to link the appropriate RTC driver to the mach_hwclk callback, at minimum. This patch switches the 68360 code over to using rtc_time. Signed-off-by: Gavin Lambert <gavinl@compacsort.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06[PATCH] m68knommu: fix timer register access on 523x ColdFire platformsGreg Ungerer
The 523x timer TRR register is a full 32bits, the older register (on other ColdFire parts) was only 16 bits. Use the right type of __raw_read when accessing it. Problem found by Yaroslav Vinogradov <yaroslav.vinogradov@freescale.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06sh: sh775x/titan fixes for irq header changes.Jamie Lenehan
The following moves the creation of IPR interupts into setup-7750.c and updates a few other things to make it all work after the "Drop CPU subtype IRQ headers" commit. It boots and runs fine on my titan board. - adds an ipr_idx to the ipr_data and uses a function in the subtype code to calculate the address of the IPR registers - adds a function to enable individual interrupt mode for externals in the subtype code and calls that from the titan board code instead of doing it directly. - I changed the shift in the ipr_data to be the actual # of bits to shift, instead of the numnber / 4 - made it easier to match with the manual. Signed-off-by: Jamie Lenehan <lenehan@twibble.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: update r7780rp defconfig.Paul Mundt
2006-12-06sh: compile fixes for header cleanup.Paul Mundt
Since some header inclusion paths were cleaned up, compilation broke. Add in the headers we need directly to build again. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: set KBUILD_IMAGE to something sensible.Paul Mundt
This was missing for sh too, wire it up.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: show held locks in stack trace with lockdep.Paul Mundt
Follows the same change as other architectures.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: platform_pata support for R7780RPPaul Mundt
This adds a platform device for the directly connected CF interface on R7780RP boards, for use with the pata_platform libata driver. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: stacktrace/lockdep/irqflags tracing support.Paul Mundt
Wire up all of the essentials for lockdep.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: dyntick infrastructure.Paul Mundt
This adds basic NO_IDLE_HZ support to the SH timer API so timers are able to wire it up. Taken from the ARM version, as it fit in to our API with very few changes needed. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
