commit b5c3206190f1fddd100b3060eb15f0d775ffeab8 upstream.
My static checker complains that if "lvl" is ULONG_MAX (this is 64 bit)
then some of the strings will overflow. I don't know if that's possible
but it seems simple enough to make the buffers slightly larger.
Cc: Waldemar Brodkorb <wbx@openadk.org>
commit c0e7bb38c07cbd8269549ee0a0566021a3c729de upstream.
For most cases a protection exception in the host (e.g. copy
on write or dirty tracking) on the sie instruction will indicate
an instruction length of 4. Turns out that there are some corner
cases (e.g. runtime instrumentation) where this is not necessarily
true and the ILC is unpredictable.
Let's replace our 4 byte rewind_pad with 3 byte nops to prepare for
all possible ILCs.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit e5c86679d5e864947a52fb31e45a425dea3e7fa9 upstream.
Linux IRQ #0 is reserved for error reporting and may not be used.
Increase NR_IRQS for one additional slot and increase
irq_domain_add_legacy parameter first_irq value to 1, so that linux
IRQ #0 is not associated with hardware IRQ #0 in legacy IRQ domains.
Introduce macro XTENSA_PIC_LINUX_IRQ for static translation of xtensa
PIC hardware IRQ # to linux IRQ #. Use this macro in XTFPGA platform
data definitions.
This fixes inability to use hardware IRQ #0 in configurations that don't
use device tree and allows for non-identity mapping between linux IRQ #
and hardware IRQ #.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 46350b71a09ccf3573649e03db55d4b61d5da231 upstream.
Table 8 from MX6DL datasheet (IMX6SDLCEC Rev. 5, 06/2015):
http://cache.nxp.com/files/32bit/doc/data_sheet/IMX6SDLCEC.pdf
states the following:
"LDO Output Set Point (VDD_ARM_CAP) = 1.125 V minimum for operation
up to 396 MHz."
So fix the entry by adding the 25mV margin value as done in the other
entries of the table, which results in 1.15V for 396MHz operation.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Stephane Fillod <f8cfe@free.fr>
commit c34a69059d7876e0793eb410deedfb08ccb22b02 upstream.
The identity mapping is suboptimal for the last 2GB frame. The mapping
will be established with a mix of 4KB and 1MB mappings instead of a
single 2GB mapping.
This happens because of a off-by-one bug introduced with
commit 50be63450728 ("s390/mm: Convert bootmem to memblock").
Currently the identity mapping looks like this:
0x0000000080000000-0x0000000180000000 4G PUD RW
0x0000000180000000-0x00000001fff00000 2047M PMD RW
0x00000001fff00000-0x0000000200000000 1M PTE RW
With the bug fixed it looks like this:
0x0000000080000000-0x0000000200000000 6G PUD RW
Fixes: 50be63450728 ("s390/mm: Convert bootmem to memblock")
Cc: Jean Delvare <jdelvare@suse.de>
commit 994870bead4ab19087a79492400a5478e2906196 upstream.
When an inline assembly operand's type is narrower than the register it
is allocated to, the least significant bits of the register (up to the
operand type's width) are valid, and any other bits are permitted to
contain any arbitrary value. This aligns with the AAPCS64 parameter
passing rules.
Our __smp_store_release() implementation does not account for this, and
implicitly assumes that operands have been zero-extended to the width of
the type being stored to. Thus, we may store unknown values to memory
when the value type is narrower than the pointer type (e.g. when storing
a char to a long).
This patch fixes the issue by casting the value operand to the same
width as the pointer operand in all cases, which ensures that the value
is zero-extended as we expect. We use the same union trickery as
__smp_load_acquire and {READ,WRITE}_ONCE() to avoid GCC complaining that
pointers are potentially cast to narrower width integers in unreachable
paths.
A whitespace issue at the top of __smp_store_release() is also
corrected.
No changes are necessary for __smp_load_acquire(). Load instructions
implicitly clear any upper bits of the register, and the compiler will
only consider the least significant bits of the register as valid
regardless.
Fixes: 47933ad41a86 ("arch: Introduce smp_load_acquire(), smp_store_release()")
Fixes: 878a84d5a8a1 ("arm64: add missing data types in smp_load_acquire/smp_store_release")
Cc: <stable@vger.kernel.org> # 3.14.x-
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Matthias Kaehlcke <mka@chromium.org>
commit 55de49f9aa17b0b2b144dd2af587177b9aadf429 upstream.
Our compat swp emulation holds the compat user address in an unsigned
int, which it passes to __user_swpX_asm(). When a 32-bit value is passed
in a register, the upper 32 bits of the register are unknown, and we
must extend the value to 64 bits before we can use it as a base address.
This patch casts the address to unsigned long to ensure it has been
suitably extended, avoiding the potential issue, and silencing a related
warning from clang.
Fixes: bd35a4adc413 ("arm64: Port SWP/SWPB emulation support from arm")
Cc: <stable@vger.kernel.org> # 3.19.x-
commit 276e93279a630657fff4b086ba14c95955912dfa upstream.
This backport has a minor difference from the upstream commit: it adds
the asm-uaccess.h file, which is not present in 4.4, because 4.4 does
not have commit b4b8664d291a ("arm64: don't pull uaccess.h into *.S").
Original patch description:
When handling a data abort from EL0, we currently zero the top byte of
the faulting address, as we assume the address is a TTBR0 address, which
may contain a non-zero address tag. However, the address may be a TTBR1
address, in which case we should not zero the top byte. This patch fixes
that. The effect is that the full TTBR1 address is passed to the task's
signal handler (or printed out in the kernel log).
When handling a data abort from EL1, we leave the faulting address
intact, as we assume it's either a TTBR1 address or a TTBR0 address with
tag 0x00. This is true as far as I'm aware, we don't seem to access a
tagged TTBR0 address anywhere in the kernel. Regardless, it's easy to
forget about address tags, and code added in the future may not always
remember to remove tags from addresses before accessing them. So add tag
handling to the EL1 data abort handler as well. This also makes it
consistent with the EL0 data abort handler.
Fixes: d50240a5f6ce ("arm64: mm: permit use of tagged pointers at EL0")
Reviewed-by: Dave Martin <Dave.Martin@arm.com>
Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com>
commit 7dcd9dd8cebe9fa626af7e2358d03a37041a70fb upstream.
This backport has a few small differences from the upstream commit:
- The address tag is removed in watchpoint_handler() instead of
get_distance_from_watchpoint(), because 4.4 does not have commit
fdfeff0f9e3d ("arm64: hw_breakpoint: Handle inexact watchpoint
addresses").
- A macro is backported (untagged_addr), as it is not present in 4.4.
When we take a watchpoint exception, the address that triggered the
watchpoint is found in FAR_EL1. We compare it to the address of each
configured watchpoint to see which one was hit.
The configured watchpoint addresses are untagged, while the address in
FAR_EL1 will have an address tag if the data access was done using a
tagged address. The tag needs to be removed to compare the address to
the watchpoints.
Currently we don't remove it, and as a result can report the wrong
watchpoint as being hit (specifically, always either the highest TTBR0
watchpoint or lowest TTBR1 watchpoint). This patch removes the tag.
Acked-by: Mark Rutland <mark.rutland@arm.com>
commit dc421b200f91930c9c6a9586810ff8c232cf10fc upstream.
When adding or removing memory, the aa_index (affinity value) for the
memblock must also be converted to match the endianness of the rest
of the 'ibm,dynamic-memory' property. Otherwise, subsequent retrieval
of the attribute will likely lead to non-existent nodes, followed by
using the default node in the code inappropriately.
Fixes: 5f97b2a0d176 ("powerpc/pseries: Implement memory hotplug add in the kernel")
Signed-off-by: Michael Bringmann <mwb@linux.vnet.ibm.com>
commit ba4a648f12f4cd0a8003dd229b6ca8a53348ee4b upstream.
In commit 8c272261194d ("powerpc/numa: Enable USE_PERCPU_NUMA_NODE_ID"), we
switched to the generic implementation of cpu_to_node(), which uses a percpu
variable to hold the NUMA node for each CPU.
Unfortunately we neglected to notice that we use cpu_to_node() in the allocation
of our percpu areas, leading to a chicken and egg problem. In practice what
happens is when we are setting up the percpu areas, cpu_to_node() reports that
all CPUs are on node 0, so we allocate all percpu areas on node 0.
This is visible in the dmesg output, as all pcpu allocs being in group 0:
pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
pcpu-alloc: [0] 16 17 18 19 [0] 20 21 22 23
pcpu-alloc: [0] 24 25 26 27 [0] 28 29 30 31
pcpu-alloc: [0] 32 33 34 35 [0] 36 37 38 39
pcpu-alloc: [0] 40 41 42 43 [0] 44 45 46 47
To fix it we need an early_cpu_to_node() which can run prior to percpu being
setup. We already have the numa_cpu_lookup_table we can use, so just plumb it
in. With the patch dmesg output shows two groups, 0 and 1:
pcpu-alloc: [1] 24 25 26 27 [1] 28 29 30 31
pcpu-alloc: [1] 32 33 34 35 [1] 36 37 38 39
pcpu-alloc: [1] 40 41 42 43 [1] 44 45 46 47
We can also check the data_offset in the paca of various CPUs, with the fix we
see:
CPU 0: data_offset = 0x0ffe8b0000
CPU 24: data_offset = 0x1ffe5b0000
And we can see from dmesg that CPU 24 has an allocation on node 1:
node 0: [mem 0x0000000000000000-0x0000000fffffffff]
node 1: [mem 0x0000001000000000-0x0000001fffffffff]
Fixes: 8c272261194d ("powerpc/numa: Enable USE_PERCPU_NUMA_NODE_ID")
Reviewed-by: Nicholas Piggin <npiggin@gmail.com>
commit daeba2956f32f91f3493788ff6ee02fb1b2f02fa upstream.
eeh_handle_special_event() is called when an EEH event is detected but
can't be narrowed down to a specific PE. This function looks through
every PE to find one in an erroneous state, then calls the regular event
handler eeh_handle_normal_event() once it knows which PE has an error.
However, if eeh_handle_normal_event() found that the PE cannot possibly
be recovered, it will free it, rendering the passed PE stale.
This leads to a use after free in eeh_handle_special_event() as it attempts to
clear the "recovering" state on the PE after eeh_handle_normal_event() returns.
Thus, make sure the PE is valid when attempting to clear state in
eeh_handle_special_event().
Fixes: 8a6b1bc70dbb ("powerpc/eeh: EEH core to handle special event")
Reported-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Signed-off-by: Russell Currey <ruscur@russell.cc>
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit d6dbdd3c8558cad3b6d74cc357b408622d122331 upstream.
Under memory pressure, we start ageing pages, which amounts to parsing
the page tables. Since we don't want to allocate any extra level,
we pass NULL for our private allocation cache. Which means that
stage2_get_pud() is allowed to fail. This results in the following
splat:
[ 1520.409577] Unable to handle kernel NULL pointer dereference at virtual address 00000008
[ 1520.417741] pgd = ffff810f52fef000
[ 1520.421201] [00000008] *pgd=0000010f636c5003, *pud=0000010f56f48003, *pmd=0000000000000000
[ 1520.429546] Internal error: Oops: 96000006 [#1] PREEMPT SMP
[ 1520.435156] Modules linked in:
[ 1520.438246] CPU: 15 PID: 53550 Comm: qemu-system-aar Tainted: G W 4.12.0-rc4-00027-g1885c397eaec #7205
[ 1520.448705] Hardware name: FOXCONN R2-1221R-A4/C2U4N_MB, BIOS G31FB12A 10/26/2016
[ 1520.463726] task: ffff800ac5fb4e00 task.stack: ffff800ce04e0000
[ 1520.469666] PC is at stage2_get_pmd+0x34/0x110
[ 1520.474119] LR is at kvm_age_hva_handler+0x44/0xf0
[ 1520.478917] pc : [<ffff0000080b137c>] lr : [<ffff0000080b149c>] pstate: 40000145
[ 1520.486325] sp : ffff800ce04e33d0
[ 1520.489644] x29: ffff800ce04e33d0 x28: 0000000ffff40064
[ 1520.494967] x27: 0000ffff27e00000 x26: 0000000000000000
[ 1520.500289] x25: ffff81051ba65008 x24: 0000ffff40065000
[ 1520.505618] x23: 0000ffff40064000 x22: 0000000000000000
[ 1520.510947] x21: ffff810f52b20000 x20: 0000000000000000
[ 1520.516274] x19: 0000000058264000 x18: 0000000000000000
[ 1520.521603] x17: 0000ffffa6fe7438 x16: ffff000008278b70
[ 1520.526940] x15: 000028ccd8000000 x14: 0000000000000008
[ 1520.532264] x13: ffff7e0018298000 x12: 0000000000000002
[ 1520.537582] x11: ffff000009241b93 x10: 0000000000000940
[ 1520.542908] x9 : ffff0000092ef800 x8 : 0000000000000200
[ 1520.548229] x7 : ffff800ce04e36a8 x6 : 0000000000000000
[ 1520.553552] x5 : 0000000000000001 x4 : 0000000000000000
[ 1520.558873] x3 : 0000000000000000 x2 : 0000000000000008
[ 1520.571696] x1 : ffff000008fd5000 x0 : ffff0000080b149c
[ 1520.577039] Process qemu-system-aar (pid: 53550, stack limit = 0xffff800ce04e0000)
[ 1521.510735] [<ffff0000080b137c>] stage2_get_pmd+0x34/0x110
[ 1521.516221] [<ffff0000080b149c>] kvm_age_hva_handler+0x44/0xf0
[ 1521.522054] [<ffff0000080b0610>] handle_hva_to_gpa+0xb8/0xe8
[ 1521.527716] [<ffff0000080b3434>] kvm_age_hva+0x44/0xf0
[ 1521.532854] [<ffff0000080a58b0>] kvm_mmu_notifier_clear_flush_young+0x70/0xc0
[ 1521.539992] [<ffff000008238378>] __mmu_notifier_clear_flush_young+0x88/0xd0
[ 1521.546958] [<ffff00000821eca0>] page_referenced_one+0xf0/0x188
[ 1521.552881] [<ffff00000821f36c>] rmap_walk_anon+0xec/0x250
[ 1521.558370] [<ffff000008220f78>] rmap_walk+0x78/0xa0
[ 1521.563337] [<ffff000008221104>] page_referenced+0x164/0x180
[ 1521.569002] [<ffff0000081f1af0>] shrink_active_list+0x178/0x3b8
[ 1521.574922] [<ffff0000081f2058>] shrink_node_memcg+0x328/0x600
[ 1521.580758] [<ffff0000081f23f4>] shrink_node+0xc4/0x328
[ 1521.585986] [<ffff0000081f2718>] do_try_to_free_pages+0xc0/0x340
[ 1521.592000] [<ffff0000081f2a64>] try_to_free_pages+0xcc/0x240
The trivial fix is to handle this NULL pud value early, rather than
dereferencing it blindly.
Reviewed-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Christoffer Dall <cdall@linaro.org>
commit 9bc1f09f6fa76fdf31eb7d6a4a4df43574725f93 upstream.
INFO: task gnome-terminal-:1734 blocked for more than 120 seconds.
Not tainted 4.12.0-rc4+ #8
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
gnome-terminal- D 0 1734 1015 0x00000000
Call Trace:
__schedule+0x3cd/0xb30
schedule+0x40/0x90
kvm_async_pf_task_wait+0x1cc/0x270
? __vfs_read+0x37/0x150
? prepare_to_swait+0x22/0x70
do_async_page_fault+0x77/0xb0
? do_async_page_fault+0x77/0xb0
async_page_fault+0x28/0x30
This is triggered by running both win7 and win2016 on L1 KVM simultaneously,
and then gives stress to memory on L1, I can observed this hang on L1 when
at least ~70% swap area is occupied on L0.
This is due to async pf was injected to L2 which should be injected to L1,
L2 guest starts receiving pagefault w/ bogus %cr2(apf token from the host
actually), and L1 guest starts accumulating tasks stuck in D state in
kvm_async_pf_task_wait() since missing PAGE_READY async_pfs.
This patch fixes the hang by doing async pf when executing L1 guest.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit 33b5c38852b29736f3b472dd095c9a18ec22746f upstream.
We currently have the HSCTLR.A bit set, trapping unaligned accesses
at HYP, but we're not really prepared to deal with it.
Since the rest of the kernel is pretty happy about that, let's follow
its example and set HSCTLR.A to zero. Modern CPUs don't really care.
commit a3641631d14571242eec0d30c9faa786cbf52d44 upstream.
If "i" is the last element in the vcpu->arch.cpuid_entries[] array, it
potentially can be exploited the vulnerability. this will out-of-bounds
read and write. Luckily, the effect is small:
/* when no next entry is found, the current entry[i] is reselected */
for (j = i + 1; ; j = (j + 1) % nent) {
struct kvm_cpuid_entry2 *ej = &vcpu->arch.cpuid_entries[j];
if (ej->function == e->function) {
It reads ej->maxphyaddr, which is user controlled. However...
ej->flags |= KVM_CPUID_FLAG_STATE_READ_NEXT;
After cpuid_entries there is
int maxphyaddr;
struct x86_emulate_ctxt emulate_ctxt; /* 16-byte aligned */
So we have:
- cpuid_entries at offset 1B50 (6992)
- maxphyaddr at offset 27D0 (6992 + 3200 = 10192)
- padding at 27D4...27DF
- emulate_ctxt at 27E0
And it writes in the padding. Pfew, writing the ops field of emulate_ctxt
would have been much worse.
This patch fixes it by modding the index to avoid the out-of-bounds
access. Worst case, i == j and ej->function == e->function,
the loop can bail out.
Reported-by: Moguofang <moguofang@huawei.com>
Cc: Guofang Mo <moguofang@huawei.com>
commit bbaf0e2b1c1b4f88abd6ef49576f0efb1734eae5 upstream.
native_safe_halt enables interrupts, and you just shouldn't
call rcu_irq_enter() with interrupts enabled. Reorder the
call with the following local_irq_disable() to respect the
invariant.
Reported-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Tested-by: Wanpeng Li <wanpeng.li@hotmail.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit c79a13734d104b5b147d7cb0870276ccdd660dae ]
Linux SPARC64 limits NR_CPUS to 4064 because init_cpu_send_mondo_info()
only allocates a single page for NR_CPUS mondo entries. Thus we cannot
use all 4096 CPUs on some SPARC platforms.
To fix, allocate (2^order) pages where order is set according to the size
of cpu_list for possible cpus. Since cpu_list_pa and cpu_mondo_block_pa
are not used in asm code, there are no imm13 offsets from the base PA
that will break because they can only reach one page.
Orabug: 25505750
Signed-off-by: Jane Chu <jane.chu@oracle.com>
Reviewed-by: Bob Picco <bob.picco@oracle.com>
Reviewed-by: Atish Patra <atish.patra@oracle.com>
[ Upstream commit 0197e41ce70511dc3b71f7fefa1a676e2b5cd60b ]
The old method that is using xcall and softint to get new context id is
deleted, as it is replaced by a method of using per_cpu_secondary_mm
without xcall to perform the context wrap.
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Reviewed-by: Steven Sistare <steven.sistare@oracle.com>
[ Upstream commit a0582f26ec9dfd5360ea2f35dd9a1b026f8adda0 ]
The current wrap implementation has a race issue: it is called outside of
the ctx_alloc_lock, and also does not wait for all CPUs to complete the
wrap. This means that a thread can get a new context with a new version
and another thread might still be running with the same context. The
problem is especially severe on CPUs with shared TLBs, like sun4v. I used
the following test to very quickly reproduce the problem:
- start over 8K processes (must be more than context IDs)
- write and read values at a memory location in every process.
Very quickly memory corruptions start happening, and what we read back
does not equal what we wrote.
Several approaches were explored before settling on this one:
Approach 1:
Move smp_new_mmu_context_version() inside ctx_alloc_lock, and wait for
every process to complete the wrap. (Note: every CPU must WAIT before
leaving smp_new_mmu_context_version_client() until every one arrives).
This approach ends up with deadlocks, as some threads own locks which other
threads are waiting for, and they never receive softint until these threads
exit smp_new_mmu_context_version_client(). Since we do not allow the exit,
deadlock happens.
Approach 2:
Handle wrap right during mondo interrupt. Use etrap/rtrap to enter into
into C code, and issue new versions to every CPU.
This approach adds some overhead to runtime: in switch_mm() we must add
some checks to make sure that versions have not changed due to wrap while
we were loading the new secondary context. (could be protected by PSTATE_IE
but that degrades performance as on M7 and older CPUs as it takes 50 cycles
for each access). Also, we still need a global per-cpu array of MMs to know
where we need to load new contexts, otherwise we can change context to a
thread that is going way (if we received mondo between switch_mm() and
switch_to() time). Finally, there are some issues with window registers in
rtrap() when context IDs are changed during CPU mondo time.
The approach in this patch is the simplest and has almost no impact on
runtime. We use the array with mm's where last secondary contexts were
loaded onto CPUs and bump their versions to the new generation without
changing context IDs. If a new process comes in to get a context ID, it
will go through get_new_mmu_context() because of version mismatch. But the
running processes do not need to be interrupted. And wrap is quicker as we
do not need to xcall and wait for everyone to receive and complete wrap.
[ Upstream commit 7a5b4bbf49fe86ce77488a70c5dccfe2d50d7a2d ]
The new wrap is going to use information from this array to figure out
mm's that currently have valid secondary contexts setup.
[ Upstream commit c4415235b2be0cc791572e8e7f7466ab8f73a2bf ]
CTX_FIRST_VERSION defines the first context version, but also it defines
first context. This patch redefines it to only include the first context
version.
[ Upstream commit 14d0334c6748ff2aedb3f2f7fdc51ee90a9b54e7 ]
The only difference between these two functions is that in activate_mm we
unconditionally flush context. However, there is no need to keep this
difference after fixing a bug where cpumask was not reset on a wrap. So, in
this patch we combine these.
[ Upstream commit 588974857359861891f478a070b1dc7ae04a3880 ]
After a wrap (getting a new context version) a process must get a new
context id, which means that we would need to flush the context id from
the TLB before running for the first time with this ID on every CPU. But,
we use mm_cpumask to determine if this process has been running on this CPU
before, and this mask is not reset after a wrap. So, there are two possible
fixes for this issue:
1. Clear mm cpumask whenever mm gets a new context id
2. Unconditionally flush context every time process is running on a CPU
This patch implements the first solution
[ Upstream commit c982aa9c304bf0b9a7522fd118fed4afa5a0263c ]
VIO devices were being looked up by their index in the machine
description node block, but this often varies over time as devices are
added and removed. Instead, store the ID and look up using the type,
config handle and ID.
Signed-off-by: James Clarke <jrtc27@jrtc27.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=112541
[ Upstream commit 654f4807624a657f364417c2a7454f0df9961734 ]
When a TSB grows beyond its current capacity, a new TSB is allocated
and copy_tsb is called to copy entries from the old TSB to the new.
A hash shift based on page size is used to calculate the index of an
entry in the TSB. copy_tsb has hard coded PAGE_SHIFT in these
calculations. However, for huge page TSBs the value REAL_HPAGE_SHIFT
should be used. As a result, when copy_tsb is called for a huge page
TSB the entries are placed at the incorrect index in the newly
allocated TSB. When doing hardware table walk, the MMU does not
match these entries and we end up in the TSB miss handling code.
This code will then create and write an entry to the correct index
in the TSB. We take a performance hit for the table walk miss and
recreation of these entries.
Pass a new parameter to copy_tsb that is the page size shift to be
used when copying the TSB.
Suggested-by: Anthony Yznaga <anthony.yznaga@oracle.com>
Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com>
[ Upstream commit deba804c90642c8ed0f15ac1083663976d578f54 ]
Greetings,
GCC 7 introduced the -Wstringop-overflow flag to detect buffer overflows
in calls to string handling functions [1][2]. Due to the way
``empty_zero_page'' is declared in arch/sparc/include/setup.h, this
causes a warning to trigger at compile time in the function mem_init(),
which is subsequently converted to an error. The ensuing patch fixes
this issue and aligns the declaration of empty_zero_page to that of
other architectures. Thank you.
Cheers,
Orlando.
[1] https://gcc.gnu.org/ml/gcc-patches/2016-10/msg02308.html
[2] https://gcc.gnu.org/gcc-7/changes.html
Signed-off-by: Orlando Arias <oarias@knights.ucf.edu>
commit a8c39544a6eb2093c04afd5005b6192bd0e880c6 upstream.
failing sys_wait4() won't fill struct rusage...
commit 3a158a62da0673db918b53ac1440845a5b64fd90 upstream.
The metag implementation of strncpy_from_user() doesn't validate the src
pointer, which could allow reading of arbitrary kernel memory. Add a
short access_ok() check to prevent that.
Its still possible for it to read across the user/kernel boundary, but
it will invariably reach a NUL character after only 9 bytes, leaking
only a static kernel address being loaded into D0Re0 at the beginning of
__start, which is acceptable for the immediate fix.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: linux-metag@vger.kernel.org
commit 8a8b56638bcac4e64cccc88bf95a0f9f4b19a2fb upstream.
The __user_bad() macro used by access_ok() has a few corner cases
noticed by Al Viro where it doesn't behave correctly:
- The kernel range check has off by 1 errors which permit access to the
first and last byte of the kernel mapped range.
- The kernel range check ends at LINCORE_BASE rather than
META_MEMORY_LIMIT, which is ineffective when the kernel is in global
space (an extremely uncommon configuration).
There are a couple of other shortcomings here too:
- Access to the whole of the other address space is permitted (i.e. the
global half of the address space when the kernel is in local space).
This isn't ideal as it could theoretically still contain privileged
mappings set up by the bootloader.
- The size argument is unused, permitting user copies which start on
valid pages at the end of the user address range and cross the
boundary into the kernel address space (e.g. addr = 0x3ffffff0, size
> 0x10).
It isn't very convenient to add size checks when disallowing certain
regions, and it seems far safer to be sure and explicit about what
userland is able to access, so invert the logic to allow certain regions
instead, and fix the off by 1 errors and missing size checks. This also
allows the get_fs() == KERNEL_DS check to be more easily optimised into
the user address range case.
We now have 3 such allowed regions:
- The user address range (incorporating the get_fs() == KERNEL_DS
check).
- NULL (some kernel code expects this to work, and we'll always catch
the fault anyway).
- The core code memory region.
Fixes: 373cd784d0fc ("metag: Memory handling")
commit a06040d7a791a9177581dcf7293941bd92400856 upstream.
Our access_ok() simply hands its arguments over to __range_ok(), which
implicitly assummes that the addr parameter is 64 bits wide. This isn't
necessarily true for compat code, which might pass down a 32-bit address
parameter.
In these cases, we don't have a guarantee that the address has been zero
extended to 64 bits, and the upper bits of the register may contain
unknown values, potentially resulting in a suprious failure.
Avoid this by explicitly casting the addr parameter to an unsigned long
(as is done on other architectures), ensuring that the parameter is
widened appropriately.
Fixes: 0aea86a2176c ("arm64: User access library functions")
commit fee960bed5e857eb126c4e56dd9ff85938356579 upstream.
The inline assembly in __XCHG_CASE() uses a +Q constraint to hazard
against other accesses to the memory location being exchanged. However,
the pointer passed to the constraint is a u8 pointer, and thus the
hazard only applies to the first byte of the location.
GCC can take advantage of this, assuming that other portions of the
location are unchanged, as demonstrated with the following test case:
union u {
unsigned long l;
unsigned int i[2];
unsigned long update_char_hazard(union u *u)
unsigned int a, b;
a = u->i[1];
asm ("str %1, %0" : "+Q" (*(char *)&u->l) : "r" (0UL));
b = u->i[1];
return a ^ b;
unsigned long update_long_hazard(union u *u)
unsigned int a, b;
a = u->i[1];
asm ("str %1, %0" : "+Q" (*(long *)&u->l) : "r" (0UL));
b = u->i[1];
return a ^ b;
The linaro 15.08 GCC 5.1.1 toolchain compiles the above as follows when
using -O2 or above:
0000000000000000 <update_char_hazard>:
0: d2800001 mov x1, #0x0 // #0
4: f9000001 str x1, [x0]
8: d2800000 mov x0, #0x0 // #0
c: d65f03c0 ret
0000000000000010 <update_long_hazard>:
10: b9400401 ldr w1, [x0,#4]
14: d2800002 mov x2, #0x0 // #0
18: f9000002 str x2, [x0]
1c: b9400400 ldr w0, [x0,#4]
20: 4a000020 eor w0, w1, w0
24: d65f03c0 ret
This patch fixes the issue by passing an unsigned long pointer into the
+Q constraint, as we do for our cmpxchg code. This may hazard against
more than is necessary, but this is better than missing a necessary
hazard.
Fixes: 305d454aaa29 ("arm64: atomics: implement native {relaxed, acquire, release} atomics")
commit d3df1ec06353e51fc44563d2e7e18d42811af290 upstream.
Remove ADC channels that are not available by default on the sama5d3_xplained
board (resistor not populated) in order to not create confusion.
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit 9cdd31e5913c1f86dce7e201b086155b3f24896b upstream.
The voltage reference for the ADC is not 3V but 3.3V since it is connected to
VDDANA.
commit fd615f69a18a9d4aa5ef02a1dc83f319f75da8e7 upstream.
Debug interrupts can be taken during interrupt entry, since interrupt
entry does not automatically turn them off. The kernel will check
whether the faulting instruction is between [interrupt_base_book3e,
__end_interrupts], and if so clear MSR[DE] and return.
However, when the kernel is built with CONFIG_RELOCATABLE, it can't use
LOAD_REG_IMMEDIATE(r14,interrupt_base_book3e) and
LOAD_REG_IMMEDIATE(r15,__end_interrupts), as they ignore relocation.
Thus, if the kernel is actually running at a different address than it
was built at, the address comparison will fail, and the exception entry
code will hang at kernel_dbg_exc.
r2(toc) is also not usable here, as r2 still holds data from the
interrupted context, so LOAD_REG_ADDR() doesn't work either. So we use
the *name@got* to get the EV of two labels directly.
Test programs test.c shows as follows:
int main(int argc, char *argv[])
if (access("/proc/sys/kernel/perf_event_paranoid", F_OK) == -1)
printf("Kernel doesn't have perf_event support\n");
Steps to reproduce the bug, for example:
1) ./gdb ./test
2) (gdb) b access
3) (gdb) r
4) (gdb) s
Signed-off-by: Liu Hailong <liu.hailong6@zte.com.cn>
Signed-off-by: Jiang Xuexin <jiang.xuexin@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Reviewed-by: Liu Song <liu.song11@zte.com.cn>
Reviewed-by: Huang Jian <huang.jian@zte.com.cn>
[scottwood: cleaned up commit message, and specified bad behavior
as a hang rather than an oops to correspond to mainline kernel behavior]
Fixes: 1cb6e0649248 ("powerpc/book3e: support CONFIG_RELOCATABLE")
Signed-off-by: Scott Wood <oss@buserror.net>
commit 68baf692c435339e6295cb470ea5545cbc28160e upstream.
Historically struct device_node references were tracked using a kref embedded as
a struct field. Commit 75b57ecf9d1d ("of: Make device nodes kobjects so they
show up in sysfs") (Mar 2014) refactored device_nodes to be kobjects such that
the device tree could by more simply exposed to userspace using sysfs.
Commit 0829f6d1f69e ("of: device_node kobject lifecycle fixes") (Mar 2014)
followed up these changes to better control the kobject lifecycle and in
particular the referecne counting via of_node_get(), of_node_put(), and
of_node_init().
A result of this second commit was that it introduced an of_node_put() call when
a dynamic node is detached, in of_node_remove(), that removes the initial kobj
reference created by of_node_init().
Traditionally as the original dynamic device node user the pseries code had
assumed responsibilty for releasing this final reference in its platform
specific DLPAR detach code.
This patch fixes a refcount underflow introduced by commit 0829f6d1f6, and
recently exposed by the upstreaming of the recount API.
Messages like the following are no longer seen in the kernel log with this
patch following DLPAR remove operations of cpus and pci devices.
rpadlpar_io: slot PHB 72 removed
refcount_t: underflow; use-after-free.
WARNING: CPU: 5 PID: 3335 at lib/refcount.c:128 refcount_sub_and_test+0xf4/0x110
Fixes: 0829f6d1f69e ("of: device_node kobject lifecycle fixes")
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
[mpe: Make change log commit references more verbose]
commit d93b0ac01a9ce276ec39644be47001873d3d183c upstream.
machine_check_early() gets called in real mode. The very first time when
add_taint() is called, it prints a warning which ends up calling opal
call (that uses OPAL_CALL wrapper) for writing it to console. If we get a
very first machine check while we are in opal we are doomed. OPAL_CALL
overwrites the PACASAVEDMSR in r13 and in this case when we are done with
MCE handling the original opal call will use this new MSR on it's way
back to opal_return. This usually leads to unexpected behaviour or the
kernel to panic. Instead move the add_taint() call later in the virtual
mode where it is safe to call.
This is broken with current FW level. We got lucky so far for not getting
very first MCE hit while in OPAL. But easily reproducible on Mambo.
Fixes: 27ea2c420cad ("powerpc: Set the correct kernel taint on machine check errors.")
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 07a63cbe8bcb6ba72fb989dcab1ec55ec6c36c7e upstream.
git commit c5328901aa1db134 "[S390] entry[64].S improvements" removed
the update of the exit_timer lowcore field from the critical section
cleanup of the .Lsysc_restore/.Lsysc_done and .Lio_restore/.Lio_done
blocks. If the PSW is updated by the critical section cleanup to point to
user space again, the interrupt entry code will do a vtime calculation
after the cleanup completed with an exit_timer value which has *not* been
updated. Due to this incorrect system time deltas are calculated.
If an interrupt occured with an old PSW between .Lsysc_restore/.Lsysc_done
or .Lio_restore/.Lio_done update __LC_EXIT_TIMER with the system entry
time of the interrupt.
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit dcc00b79fc3d076832f7240de8870f492629b171 upstream.
Since linux v3.14 with commit 38dfac843cb6d7be1 ("vmcore: prevent PT_NOTE
p_memsz overflow during header update") on s390 we get the following
message in the kdump kernel:
Warning: Exceeded p_memsz, dropping PT_NOTE entry n_namesz=0x6b6b6b6b,
n_descsz=0x6b6b6b6b
The reason for this is that we don't create a final zero note in
the ELF header which the proc/vmcore code uses to find out the end
of the notes section (see also kernel/kexec_core.c:final_note()).
It still worked on s390 by chance because we (most of the time?) have the
byte pattern 0x6b6b6b6b after the notes section which also makes the notes
parsing code stop in update_note_header_size_elf64() because 0x6b6b6b6b is
interpreded as note size:
if ((real_sz + sz) > max_sz) {
pr_warn("Warning: Exceeded p_memsz, dropping P ...);
break;
So fix this and add the missing final note to the ELF header.
We don't have to adjust the memory size for ELF header ("alloc_size")
because the new ELF note still fits into the 0x1000 base memory.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit cbfc6c9184ce71b52df4b1d82af5afc81a709178 upstream.
Huawei folks reported a read out-of-bounds vulnerability in kvm pio emulation.
- "inb" instruction to access PIT Mod/Command register (ioport 0x43, write only,
a read should be ignored) in guest can get a random number.
- "rep insb" instruction to access PIT register port 0x43 can control memcpy()
in emulator_pio_in_emulated() to copy max 0x400 bytes but only read 1 bytes,
which will disclose the unimportant kernel memory in host but no crash.
The similar test program below can reproduce the read out-of-bounds vulnerability:
void hexdump(void *mem, unsigned int len)
unsigned int i, j;
for(i = 0; i < len + ((len % HEXDUMP_COLS) ? (HEXDUMP_COLS - len % HEXDUMP_COLS) : 0); i++)
/* print offset */
if(i % HEXDUMP_COLS == 0)
printf("0x%06x: ", i);
/* print hex data */
if(i < len)
printf("%02x ", 0xFF & ((char*)mem)[i]);
else /* end of block, just aligning for ASCII dump */
printf(" ");
/* print ASCII dump */
if(i % HEXDUMP_COLS == (HEXDUMP_COLS - 1))
for(j = i - (HEXDUMP_COLS - 1); j <= i; j++)
if(j >= len) /* end of block, not really printing */
putchar(' ');
else if(isprint(((char*)mem)[j])) /* printable char */
putchar(0xFF & ((char*)mem)[j]);
else /* other char */
putchar('.');
putchar('\n');
int main(void)
int i;
if (iopl(3))
err(1, "set iopl unsuccessfully\n");
return -1;
static char buf[0x40];
/* test ioport 0x40,0x41,0x42,0x43,0x44,0x45 */
memset(buf, 0xab, sizeof(buf));
asm volatile("push %rdi;");
asm volatile("mov %0, %%rdi;"::"q"(buf));
asm volatile ("mov $0x40, %rdx;");
asm volatile ("in %dx,%al;");
asm volatile ("stosb;");
asm volatile ("mov $0x41, %rdx;");
asm volatile ("mov $0x42, %rdx;");
asm volatile ("mov $0x43, %rdx;");
asm volatile ("mov $0x44, %rdx;");
asm volatile ("mov $0x45, %rdx;");
asm volatile ("pop %rdi;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x40 */
asm volatile ("mov $0x20, %rcx;");
asm volatile ("rep insb;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x43 */
hexdump(buf, 0x40);
printf("\n");
return 0;
The vcpu->arch.pio_data buffer is used by both in/out instrutions emulation
w/o clear after using which results in some random datas are left over in
the buffer. Guest reads port 0x43 will be ignored since it is write only,
however, the function kernel_pio() can't distigush this ignore from successfully
reads data from device's ioport. There is no new data fill the buffer from
port 0x43, however, emulator_pio_in_emulated() will copy the stale data in
the buffer to the guest unconditionally. This patch fixes it by clearing the
buffer before in instruction emulation to avoid to grant guest the stale data
in the buffer.
In addition, string I/O is not supported for in kernel device. So there is no
iteration to read ioport %RCX times for string I/O. The function kernel_pio()
just reads one round, and then copy the io size * %RCX to the guest unconditionally,
actually it copies the one round ioport data w/ other random datas which are left
over in the vcpu->arch.pio_data buffer to the guest. This patch fixes it by
introducing the string I/O support for in kernel device in order to grant the right
ioport datas to the guest.
Before the patch:
0x000000: fe 38 93 93 ff ff ab ab .8......
0x000008: ab ab ab ab ab ab ab ab ........
0x000010: ab ab ab ab ab ab ab ab ........
0x000018: ab ab ab ab ab ab ab ab ........
0x000020: ab ab ab ab ab ab ab ab ........
0x000028: ab ab ab ab ab ab ab ab ........
0x000030: ab ab ab ab ab ab ab ab ........
0x000038: ab ab ab ab ab ab ab ab ........
0x000000: f6 00 00 00 00 00 00 00 ........
0x000008: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 4d 51 30 30 ....MQ00
0x000018: 30 30 20 33 20 20 20 20 00 3
After the patch:
0x000000: 1e 02 f8 00 ff ff ab ab ........
0x000000: d2 e2 d2 df d2 db d2 d7 ........
0x000008: d2 d3 d2 cf d2 cb d2 c7 ........
0x000010: d2 c4 d2 c0 d2 bc d2 b8 ........
0x000018: d2 b4 d2 b0 d2 ac d2 a8 ........
0x000000: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 00 00 00 00 ........
0x000018: 00 00 00 00 00 00 00 00 ........
Cc: Moguofang <moguofang@huawei.com>
commit a575813bfe4bc15aba511a5e91e61d242bff8b9d upstream.
Reported by syzkaller:
BUG: unable to handle kernel paging request at ffffffffc07f6a2e
IP: report_bug+0x94/0x120
PGD 348e12067
P4D 348e12067
PUD 348e14067
PMD 3cbd84067
PTE 80000003f7e87161
Oops: 0003 [#1] SMP
CPU: 2 PID: 7091 Comm: kvm_load_guest_ Tainted: G OE 4.11.0+ #8
task: ffff92fdfb525400 task.stack: ffffbda6c3d04000
RIP: 0010:report_bug+0x94/0x120
RSP: 0018:ffffbda6c3d07b20 EFLAGS: 00010202
do_trap+0x156/0x170
do_error_trap+0xa3/0x170
? kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? mark_held_locks+0x79/0xa0
? retint_kernel+0x10/0x10
? trace_hardirqs_off_thunk+0x1a/0x1c
do_invalid_op+0x20/0x30
invalid_op+0x1e/0x30
RIP: 0010:kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? kvm_load_guest_fpu.part.175+0x1c/0x170 [kvm]
kvm_arch_vcpu_ioctl_run+0xed6/0x1b70 [kvm]
kvm_vcpu_ioctl+0x384/0x780 [kvm]
? kvm_vcpu_ioctl+0x384/0x780 [kvm]
? sched_clock+0x13/0x20
? __do_page_fault+0x2a0/0x550
do_vfs_ioctl+0xa4/0x700
? up_read+0x1f/0x40
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x23/0xc2
SDM mentioned that "The MXCSR has several reserved bits, and attempting to write
a 1 to any of these bits will cause a general-protection exception(#GP) to be
generated". The syzkaller forks' testcase overrides xsave area w/ random values
and steps on the reserved bits of MXCSR register. The damaged MXCSR register
values of guest will be restored to SSEx MXCSR register before vmentry. This
patch fixes it by catching userspace override MXCSR register reserved bits w/
random values and bails out immediately.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
commit 0c18927f51f4d390abdcf385bff5f995407ee732 upstream.
Current U-Boot enables the display already. Marking the regulator as
enabled on boot fixes sporadic panel initialization failures.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Tested-by: Misha Komarovskiy <zombah@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
commit c667186f1c01ca8970c785888868b7ffd74e51ee upstream.
Our 32bit CP14/15 handling inherited some of the ARMv7 code for handling
the trapped system registers, completely missing the fact that the
fields for Rt and Rt2 are now 5 bit wide, and not 4...
Let's fix it, and provide an accessor for the most common Rt case.
commit 6c7a5dce22b3f3cc44be098e2837fa6797edb8b8 upstream.
Fix potential races in kvm_psci_vcpu_on() by taking the kvm->lock
mutex. In general, it's a bad idea to allow more than one PSCI_CPU_ON
to process the same target VCPU at the same time. One such problem
that may arise is that one PSCI_CPU_ON could be resetting the target
vcpu, which fills the entire sys_regs array with a temporary value
including the MPIDR register, while another looks up the VCPU based
on the MPIDR value, resulting in no target VCPU found. Resolves both
races found with the kvm-unit-tests/arm/psci unit test.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Reported-by: Levente Kurusa <lkurusa@redhat.com>
Suggested-by: Christoffer Dall <cdall@linaro.org>
Signed-off-by: Andrew Jones <drjones@redhat.com>
commit 28bf28887976d8881a3a59491896c718fade7355 upstream.
If we already entered/are about to enter SMM, don't allow switching to
INIT/SIPI_RECEIVED, otherwise the next call to kvm_apic_accept_events()
will report a warning.
Same applies if we are already in MP state INIT_RECEIVED and SMM is
requested to be turned on. Refuse to set the VCPU events in this case.
Fixes: cd7764fe9f73 ("KVM: x86: latch INITs while in system management mode")
Signed-off-by: David Hildenbrand <david@redhat.com>
commit 9abc74a22d85ab29cef9896a2582a530da7e79bf upstream.
This is broken since ever but sadly nobody noticed.
Recent versions of GDB set DR_CONTROL unconditionally and
UML dies due to a heap corruption. It turns out that
the PTRACE_POKEUSER was copy&pasted from i386 and assumes
that addresses are 4 bytes long.
Fix that by using 8 as address size in the calculation.
Reported-by: jie cao <cj3054@gmail.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 8376efd31d3d7c44bd05be337adde023cc531fa1 upstream.
Commit 11e63f6d920d added cache flushing for unaligned writes from an
iovec, covering the first and last cache line of a >= 8 byte write and
the first cache line of a < 8 byte write. But an unaligned write of
2-7 bytes can still cover two cache lines, so make sure we flush both
in that case.
Fixes: 11e63f6d920d ("x86, pmem: fix broken __copy_user_nocache ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d594aa0277e541bb997aef0bc0a55172d8138340 upstream.
The minimum size for a new stack (512 bytes) setup for arch/x86/boot components
when the bootloader does not setup/provide a stack for the early boot components
is not "enough".
The setup code executing as part of early kernel startup code, uses the stack
beyond 512 bytes and accidentally overwrites and corrupts part of the BSS
section. This is exposed mostly in the early video setup code, where
it was corrupting BSS variables like force_x, force_y, which in-turn affected
kernel parameters such as screen_info (screen_info.orig_video_cols) and
later caused an exception/panic in console_init().
Most recent boot loaders setup the stack for early boot components, so this
stack overwriting into BSS section issue has not been exposed.
Signed-off-by: Ashish Kalra <ashish@bluestacks.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20170419152015.10011-1-ashishkalra@Ashishs-MacBook-Pro.local
commit 69861e0a52f8733355ce246f0db15e1b240ad667 upstream.
When booted as pv-guest the p2m list presented by the Xen is already
mapped to virtual addresses. In dom0 case the hypervisor might make use
of 2M- or 1G-pages for this mapping. Unfortunately while being properly
aligned in virtual and machine address space, those pages might not be
aligned properly in guest physical address space.
So when trying to obtain the guest physical address of such a page
pud_pfn() and pmd_pfn() must be avoided as those will mask away guest
physical address bits not being zero in this special case.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Jan Beulich <jbeulich@suse.com>
[ Upstream commit ddc665a4bb4b728b4e6ecec8db1b64efa9184b9c ]
When the instruction right before the branch destination is
a 64 bit load immediate, we currently calculate the wrong
jump offset in the ctx->offset[] array as we only account
one instruction slot for the 64 bit load immediate although
it uses two BPF instructions. Fix it up by setting the offset
into the right slot after we incremented the index.
Before (ldimm64 test 1):
00000020: 52800007 mov w7, #0x0 // #0
00000024: d2800060 mov x0, #0x3 // #3
00000028: d2800041 mov x1, #0x2 // #2
0000002c: eb01001f cmp x0, x1
00000030: 54ffff82 b.cs 0x00000020
00000034: d29fffe7 mov x7, #0xffff // #65535
00000038: f2bfffe7 movk x7, #0xffff, lsl #16
0000003c: f2dfffe7 movk x7, #0xffff, lsl #32
00000040: f2ffffe7 movk x7, #0xffff, lsl #48
00000044: d29dddc7 mov x7, #0xeeee // #61166
00000048: f2bdddc7 movk x7, #0xeeee, lsl #16
0000004c: f2ddddc7 movk x7, #0xeeee, lsl #32
00000050: f2fdddc7 movk x7, #0xeeee, lsl #48
After (ldimm64 test 1):
00000030: 540000a2 b.cs 0x00000044
Also, add a couple of test cases to make sure JITs pass
this test. Tested on Cavium ThunderX ARMv8. The added
test cases all pass after the fix.
Fixes: 8eee539ddea0 ("arm64: bpf: fix out-of-bounds read in bpf2a64_offset()")
Reported-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Cc: Xi Wang <xi.wang@gmail.com>
