path: root/arch
2016-11-10kvm: x86: Check memopp before dereference (CVE-2016-8630)Owen Hofmann
commit d9092f52d7e61dd1557f2db2400ddb430e85937e upstream. Commit 41061cdb98 ("KVM: emulate: do not initialize memopp") removes a check for non-NULL under incorrect assumptions. An undefined instruction with a ModR/M byte with Mod=0 and R/M-5 (e.g. 0xc7 0x15) will attempt to dereference a null pointer here. Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5 Message-Id: <1477592752-126650-2-git-send-email-osh@google.com> Signed-off-by: Owen Hofmann <osh@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ARM: 8584/1: floppy: avoid gcc-6 warningArnd Bergmann
commit dd665be0e243873343a28e18f9f345927b658daf upstream. gcc-6.0 warns about comparisons between two identical expressions, which is what we get in the floppy driver when writing to the FD_DOR register: drivers/block/floppy.c: In function 'set_dor': drivers/block/floppy.c:810:44: error: self-comparison always evaluates to true [-Werror=tautological-compare] fd_outb(newdor, FD_DOR); It would be nice to use a static inline function instead of the macro, to avoid the warning, but we cannot do that because the FD_DOR definition is incomplete at this point. Adding a cast to (u32) is a harmless way to shut up the warning, just not very nice. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10powerpc/ptrace: Fix out of bounds array access warningKhem Raj
commit 1e407ee3b21f981140491d5b8a36422979ca246f upstream. gcc-6 correctly warns about a out of bounds access arch/powerpc/kernel/ptrace.c:407:24: warning: index 32 denotes an offset greater than size of 'u64[32][1] {aka long long unsigned int[32][1]}' [-Warray-bounds] offsetof(struct thread_fp_state, fpr[32][0])); ^ check the end of array instead of beginning of next element to fix this Signed-off-by: Khem Raj <raj.khem@gmail.com> Cc: Kees Cook <keescook@chromium.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Segher Boessenkool <segher@kernel.crashing.org> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10x86/xen: fix upper bound of pmd loop in xen_cleanhighmap()Juergen Gross
commit 1cf38741308c64d08553602b3374fb39224eeb5a upstream. xen_cleanhighmap() is operating on level2_kernel_pgt only. The upper bound of the loop setting non-kernel-image entries to zero should not exceed the size of level2_kernel_pgt. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Juergen Gross <jgross@suse.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10parisc: Ensure consistent state when switching to kernel stack at syscall entryJohn David Anglin
commit 6ed518328d0189e0fdf1bb7c73290d546143ea66 upstream. We have one critical section in the syscall entry path in which we switch from the userspace stack to kernel stack. In the event of an external interrupt, the interrupt code distinguishes between those two states by analyzing the value of sr7. If sr7 is zero, it uses the kernel stack. Therefore it's important, that the value of sr7 is in sync with the currently enabled stack. This patch now disables interrupts while executing the critical section. This prevents the interrupt handler to possibly see an inconsistent state which in the worst case can lead to crashes. Interestingly, in the syscall exit path interrupts were already disabled in the critical section which switches back to the userspace stack. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10KVM: MIPS: Make ERET handle ERL before EXLJames Hogan
commit ede5f3e7b54a4347be4d8525269eae50902bd7cd upstream. The ERET instruction to return from exception is used for returning from exception level (Status.EXL) and error level (Status.ERL). If both bits are set however we should be returning from ERL first, as ERL can interrupt EXL, for example when an NMI is taken. KVM however checks EXL first. Fix the order of the checks to match the pseudocode in the instruction set manual. Fixes: e685c689f3a8 ("KVM/MIPS32: Privileged instruction/target branch emulation.") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: kvm@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10KVM: x86: fix wbinvd_dirty_mask use-after-freeIdo Yariv
commit bd768e146624cbec7122ed15dead8daa137d909d upstream. vcpu->arch.wbinvd_dirty_mask may still be used after freeing it, corrupting memory. For example, the following call trace may set a bit in an already freed cpu mask: kvm_arch_vcpu_load vcpu_load vmx_free_vcpu_nested vmx_free_vcpu kvm_arch_vcpu_free Fix this by deferring freeing of wbinvd_dirty_mask. Signed-off-by: Ido Yariv <ido@wizery.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10Fix potential infoleak in older kernelsLinus Torvalds
Not upstream as it is not needed there. So a patch something like this might be a safe way to fix the potential infoleak in older kernels. THIS IS UNTESTED. It's a very obvious patch, though, so if it compiles it probably works. It just initializes the output variable with 0 in the inline asm description, instead of doing it in the exception handler. It will generate slightly worse code (a few unnecessary ALU operations), but it doesn't have any interactions with the exception handler implementation. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10h8300: fix syscall restartingMark Rutland
commit 21753583056d48a5fad964d6f272e28168426845 upstream. Back in commit f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct"), all architectures and core code were changed to use task_struct::restart_block. However, when h8300 support was subsequently restored in v4.2, it was not updated to account for this, and maintains thread_info::restart_block, which is not kept in sync. This patch drops the redundant restart_block from thread_info, and moves h8300 to the common one in task_struct, ensuring that syscall restarting always works as expected. Fixes: f56141e3e2d9 ("all arches, signal: move restart_block to struct task_struct") Link: http://lkml.kernel.org/r/1476714934-11635-1-git-send-email-mark.rutland@arm.com Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-h8-devel@lists.sourceforge.jp Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31Revert "fix minor infoleak in get_user_ex()"Greg Kroah-Hartman
This reverts commit 9d25c78ec01c402dc56272693c44ef9d72ecdd2e which is 1c109fabbd51863475cd12ac206bdd249aee35af upstream Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31Revert "x86/mm: Expand the exception table logic to allow new handling options"Greg Kroah-Hartman
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream. Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31ARM: pxa: pxa_cplds: fix interrupt handlingRobert Jarzmik
commit 9ba63e3cc849cdaf3b675c47cc51fe35419e5117 upstream. Since its initial commit, the driver is buggy for multiple interrupts handling. The translation from the former lubbock.c file was not complete, and might stall all interrupt handling when multiple interrupts occur. This is especially true when inside the interrupt handler and if a new interrupt comes and is not handled, leaving the output line still held, and not creating a transition as the GPIO block behind would expect to trigger another cplds_irq_handler() call. For the record, the hardware is working as follows. The interrupt mechanism relies on : - one status register - one mask register Let's suppose the input irq lines are called : - i_sa1111 - i_lan91x - i_mmc_cd Let's suppose the status register for each irq line is called : - status_sa1111 - status_lan91x - status_mmc_cd Let's suppose the interrupt mask for each irq line is called : - irqen_sa1111 - irqen_lan91x - irqen_mmc_cd Let's suppose the output irq line, connected to GPIO0 is called : - o_gpio0 The behavior is as follows : - o_gpio0 = not((status_sa1111 & irqen_sa1111) | (status_lan91x & irqen_lan91x) | (status_mmc_cd & irqen_mmc_cd)) => this is a N-to-1 NOR gate and multiple AND gates - irqen_* is exactly as programmed by a write to the FPGA - status_* behavior is governed by a bi-stable D flip-flop => on next FPGA clock : - if i_xxx is high, status_xxx becomes 1 - if i_xxx is low, status_xxx remains as it is - if software sets status_xxx to 0, the D flip-flop is reset => status_xxx becomes 0 => on next FPGA clock cycle, if i_xxx is high, status_xxx becomes 1 again Fixes: fc9e38c0f4d3 ("ARM: pxa: lubbock: use new pxa_cplds driver") Reported-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31powerpc/nvram: Fix an incorrect partition mergePan Xinhui
commit 11b7e154b132232535befe51c55db048069c8461 upstream. When we merge two contiguous partitions whose signatures are marked NVRAM_SIG_FREE, We need update prev's length and checksum, then write it to nvram, not cur's. So lets fix this mistake now. Also use memset instead of strncpy to set the partition's name. It's more readable if we want to fill up with duplicate chars . Fixes: fa2b4e54d41f ("powerpc/nvram: Improve partition removal") Signed-off-by: Pan Xinhui <xinhui.pan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31x86/mm: Expand the exception table logic to allow new handling optionsTony Luck
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream. Huge amounts of help from Andy Lutomirski and Borislav Petkov to produce this. Andy provided the inspiration to add classes to the exception table with a clever bit-squeezing trick, Boris pointed out how much cleaner it would all be if we just had a new field. Linus Torvalds blessed the expansion with: ' I'd rather not be clever in order to save just a tiny amount of space in the exception table, which isn't really criticial for anybody. ' The third field is another relative function pointer, this one to a handler that executes the actions. We start out with three handlers: 1: Legacy - just jumps the to fixup IP 2: Fault - provide the trap number in %ax to the fixup code 3: Cleaned up legacy for the uaccess error hack Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31crypto: arm/ghash-ce - add missing async import/exportArd Biesheuvel
commit ed4767d612fd2c39e2c4c69eba484c1219dcddb6 upstream. Since commit 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero"), all ahash drivers are required to implement import()/export(), and must have a non-zero statesize. Fix this for the ARM Crypto Extensions GHASH implementation. Fixes: 8996eafdcbad ("crypto: ahash - ensure statesize is non-zero") Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31powerpc/eeh: Null check uses of eeh_pe_bus_getRussell Currey
commit 04fec21c06e35b169a83e75a84a015ab4606bf5e upstream. eeh_pe_bus_get() can return NULL if a PCI bus isn't found for a given PE. Some callers don't check this, and can cause a null pointer dereference under certain circumstances. Fix this by checking NULL everywhere eeh_pe_bus_get() is called. Fixes: 8a6b1bc70dbb ("powerpc/eeh: EEH core to handle special event") Cc: stable@vger.kernel.org # v3.11+ Signed-off-by: Russell Currey <ruscur@russell.cc> Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/i915: Account for TSEG size when determining 865G stolen baseVille Syrjälä
commit d721b02fd00bf133580f431b82ef37f3b746dfb2 upstream. Looks like the TSEG lives just above TOUD, stolen comes after TSEG. The spec seems somewhat self-contradictory in places, in the ESMRAMC register desctription it says: TSEG Size: 10=(TOUD + 512 KB) to TOUD 11 =(TOUD + 1 MB) to TOUD so that agrees with TSEG being at TOUD. But the example given elsehwere in the spec says: TOUD equals 62.5 MB = 03E7FFFFh TSEG selected as 512 KB in size, Graphics local memory selected as 1 MB in size General System RAM available in system = 62.5 MB General system RAM range00000000h to 03E7FFFFh TSEG address range03F80000h to 03FFFFFFh TSEG pre-allocated from03F80000h to 03FFFFFFh Graphics local memory pre-allocated from03E80000h to 03F7FFFFh so here we have TSEG above stolen. Real world evidence agrees with the TOUD->TSEG->stolen order however, so let's fix up the code to account for the TSEG size. Cc: Taketo Kabe <fdporg@vega.pgw.jp> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Fixes: 0ad98c74e093 ("drm/i915: Determine the stolen memory base address on gen2") Fixes: a4dff76924fe ("x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms") Reported-by: Taketo Kabe <fdporg@vega.pgw.jp> Tested-by: Taketo Kabe <fdporg@vega.pgw.jp> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96473 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1470653919-27251-1-git-send-email-ville.syrjala@linux.intel.com Link: http://download.intel.com/design/chipsets/datashts/25251405.pdf Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/mm: Prevent unlikely crash in copro_calculate_slb()Frederic Barrat
commit d2cf909cda5f8c5609cb7ed6cda816c3e15528c7 upstream. If a cxl adapter faults on an invalid address for a kernel context, we may enter copro_calculate_slb() with a NULL mm pointer (kernel context) and an effective address which looks like a user address. Which will cause a crash when dereferencing mm. It is clearly an AFU bug, but there's no reason to crash either. So return an error, so that cxl can ack the interrupt with an address error. Fixes: 73d16a6e0e51 ("powerpc/cell: Move data segment faulting code out of cell platform") Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28arm64: kernel: Init MDCR_EL2 even in the absence of a PMUMarc Zyngier
commit 850540351bb1a4fa5f192e5ce55b89928cc57f42 upstream. Commit f436b2ac90a0 ("arm64: kernel: fix architected PMU registers unconditional access") made sure we wouldn't access unimplemented PMU registers, but also left MDCR_EL2 uninitialized in that case, leading to trap bits being potentially left set. Make sure we always write something in that register. Fixes: f436b2ac90a0 ("arm64: kernel: fix architected PMU registers unconditional access") Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28arm64: percpu: rewrite ll/sc loops in assemblyWill Deacon
commit 1e6e57d9b34a9075d5f9e2048ea7b09756590d11 upstream. Writing the outer loop of an LL/SC sequence using do {...} while constructs potentially allows the compiler to hoist memory accesses between the STXR and the branch back to the LDXR. On CPUs that do not guarantee forward progress of LL/SC loops when faced with memory accesses to the same ERG (up to 2k) between the failed STXR and the branch back, we may end up livelocking. This patch avoids this issue in our percpu atomics by rewriting the outer loop as part of the LL/SC inline assembly block. Fixes: f97fc810798c ("arm64: percpu: Implement this_cpu operations") Reviewed-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28s390/mm: fix gmap tlb flush issuesDavid Hildenbrand
commit f045402984404ddc11016358411e445192919047 upstream. __tlb_flush_asce() should never be used if multiple asce belong to a mm. As this function changes mm logic determining if local or global tlb flushes will be neded, we might end up flushing only the gmap asce on all CPUs and a follow up mm asce flushes will only flush on the local CPU, although that asce ran on multiple CPUs. The missing tlb flushes will provoke strange faults in user space and even low address protections in user space, crashing the kernel. Fixes: 1b948d6caec4 ("s390/mm,tlb: optimize TLB flushing for zEC12") Cc: stable@vger.kernel.org # 3.15+ Reported-by: Sascha Silbe <silbe@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28kvm: x86: memset whole irq_eoiJiri Slaby
commit 8678654e3c7ad7b0f4beb03fa89691279cba71f9 upstream. gcc 7 warns: arch/x86/kvm/ioapic.c: In function 'kvm_ioapic_reset': arch/x86/kvm/ioapic.c:597:2: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size] And it is right. Memset whole array using sizeof operator. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Radim Krčmář <rkrcmar@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: x86@kernel.org Cc: kvm@vger.kernel.org Cc: linux-kernel@vger.kernel.org Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> [Added x86 subject tag] Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28x86/e820: Don't merge consecutive E820_PRAM rangesDan Williams
commit 23446cb66c073b827779e5eb3dec301623299b32 upstream. Commit: 917db484dc6a ("x86/boot: Fix kdump, cleanup aborted E820_PRAM max_pfn manipulation") ... fixed up the broken manipulations of max_pfn in the presence of E820_PRAM ranges. However, it also broke the sanitize_e820_map() support for not merging E820_PRAM ranges. Re-introduce the enabling to keep resource boundaries between consecutive defined ranges. Otherwise, for example, an environment that boots with memmap=2G!8G,2G!10G will end up with a single 4G /dev/pmem0 device instead of a /dev/pmem0 and /dev/pmem1 device 2G in size. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Zhang Yi <yizhan@redhat.com> Cc: linux-nvdimm@lists.01.org Fixes: 917db484dc6a ("x86/boot: Fix kdump, cleanup aborted E820_PRAM max_pfn manipulation") Link: http://lkml.kernel.org/r/147629530854.10618.10383744751594021268.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28arc: don't leak bits of kernel stack into coredumpAl Viro
commit 7798bf2140ebcc36eafec6a4194fffd8d585d471 upstream. On faulting sigreturn we do get SIGSEGV, all right, but anything we'd put into pt_regs could end up in the coredump. And since __copy_from_user() never zeroed on arc, we'd better bugger off on its failure without copying random uninitialized bits of kernel stack into pt_regs... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28metag: Only define atomic_dec_if_positive conditionallyGuenter Roeck
commit 35d04077ad96ed33ceea2501f5a4f1eacda77218 upstream. The definition of atomic_dec_if_positive() assumes that atomic_sub_if_positive() exists, which is only the case if metag specific atomics are used. This results in the following build error when trying to build metag1_defconfig. kernel/ucount.c: In function 'dec_ucount': kernel/ucount.c:211: error: implicit declaration of function 'atomic_sub_if_positive' Moving the definition of atomic_dec_if_positive() into the metag conditional code fixes the problem. Fixes: 6006c0d8ce94 ("metag: Atomics, locks and bitops") Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28MIPS: ptrace: Fix regs_return_value for kernel contextMarcin Nowakowski
commit 74f1077b5b783e7bf4fa3007cefdc8dbd6c07518 upstream. Currently regs_return_value always negates reg[2] if it determines the syscall has failed, but when called in kernel context this check is invalid and may result in returning a wrong value. This fixes errors reported by CONFIG_KPROBES_SANITY_TEST Fixes: d7e7528bcd45 ("Audit: push audit success and retcode into arch ptrace.h") Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14381/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28MIPS: Fix -mabi=64 build of vdso.ldsJames Hogan
commit 034827c727f7f3946a18355b63995b402c226c82 upstream. The native ABI vDSO linker script vdso.lds is built by preprocessing vdso.lds.S, with the native -mabi flag passed in to get the correct ABI definitions. Unfortunately however certain toolchains choke on -mabi=64 without a corresponding compatible -march flag, for example: cc1: error: ‘-march=mips32r2’ is not compatible with the selected ABI scripts/Makefile.build:338: recipe for target 'arch/mips/vdso/vdso.lds' failed Fix this by including ccflags-vdso in the KBUILD_CPPFLAGS for vdso.lds, which includes the appropriate -march flag. Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO") Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Maciej W. Rozycki <macro@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/14368/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/pseries: Fix stack corruption in htpe codeLaurent Dufour
commit 05af40e885955065aee8bb7425058eb3e1adca08 upstream. This commit fixes a stack corruption in the pseries specific code dealing with the huge pages. In __pSeries_lpar_hugepage_invalidate() the buffer used to pass arguments to the hypervisor is not large enough. This leads to a stack corruption where a previously saved register could be corrupted leading to unexpected result in the caller, like the following panic: Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=2048 NUMA pSeries Modules linked in: virtio_balloon ip_tables x_tables autofs4 virtio_blk 8139too virtio_pci virtio_ring 8139cp virtio CPU: 11 PID: 1916 Comm: mmstress Not tainted 4.8.0 #76 task: c000000005394880 task.stack: c000000005570000 NIP: c00000000027bf6c LR: c00000000027bf64 CTR: 0000000000000000 REGS: c000000005573820 TRAP: 0300 Not tainted (4.8.0) MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE> CR: 84822884 XER: 20000000 CFAR: c00000000010a924 DAR: 420000000014e5e0 DSISR: 40000000 SOFTE: 1 GPR00: c00000000027bf64 c000000005573aa0 c000000000e02800 c000000004447964 GPR04: c00000000404de18 c000000004d38810 00000000042100f5 00000000f5002104 GPR08: e0000000f5002104 0000000000000001 042100f5000000e0 00000000042100f5 GPR12: 0000000000002200 c00000000fe02c00 c00000000404de18 0000000000000000 GPR16: c1ffffffffffe7ff 00003fff62000000 420000000014e5e0 00003fff63000000 GPR20: 0008000000000000 c0000000f7014800 0405e600000000e0 0000000000010000 GPR24: c000000004d38810 c000000004447c10 c00000000404de18 c000000004447964 GPR28: c000000005573b10 c000000004d38810 00003fff62000000 420000000014e5e0 NIP [c00000000027bf6c] zap_huge_pmd+0x4c/0x470 LR [c00000000027bf64] zap_huge_pmd+0x44/0x470 Call Trace: [c000000005573aa0] [c00000000027bf64] zap_huge_pmd+0x44/0x470 (unreliable) [c000000005573af0] [c00000000022bbd8] unmap_page_range+0xcf8/0xed0 [c000000005573c30] [c00000000022c2d4] unmap_vmas+0x84/0x120 [c000000005573c80] [c000000000235448] unmap_region+0xd8/0x1b0 [c000000005573d80] [c0000000002378f0] do_munmap+0x2d0/0x4c0 [c000000005573df0] [c000000000237be4] SyS_munmap+0x64/0xb0 [c000000005573e30] [c000000000009560] system_call+0x38/0x108 Instruction dump: fbe1fff8 fb81ffe0 7c7f1b78 7ca32b78 7cbd2b78 f8010010 7c9a2378 f821ffb1 7cde3378 4bfffea9 7c7b1b79 41820298 <e87f0000> 48000130 7fa5eb78 7fc4f378 Most of the time, the bug is surfacing in a caller up in the stack from __pSeries_lpar_hugepage_invalidate() which is quite confusing. This bug is pending since v3.11 but was hidden if a caller of the caller of __pSeries_lpar_hugepage_invalidate() has pushed the corruped register (r18 in this case) in the stack and is not using it until restoring it. GCC 6.2.0 seems to raise it more frequently. This commit also change the definition of the parameter buffer in pSeries_lpar_flush_hash_range() to rely on the global define PLPAR_HCALL9_BUFSIZE (no functional change here). Fixes: 1a5272866f87 ("powerpc: Optimize hugepage invalidate") Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/64: Fix incorrect return value from __copy_tofrom_userPaul Mackerras
commit 1a34439e5a0b2235e43f96816dbb15ee1154f656 upstream. Debugging a data corruption issue with virtio-net/vhost-net led to the observation that __copy_tofrom_user was occasionally returning a value 16 larger than it should. Since the return value from __copy_tofrom_user is the number of bytes not copied, this means that __copy_tofrom_user can occasionally return a value larger than the number of bytes it was asked to copy. In turn this can cause higher-level copy functions such as copy_page_to_iter_iovec to corrupt memory by copying data into the wrong memory locations. It turns out that the failing case involves a fault on the store at label 79, and at that point the first unmodified byte of the destination is at R3 + 16. Consequently the exception handler for that store needs to add 16 to R3 before using it to work out how many bytes were not copied, but in this one case it was not adding the offset to R3. To fix it, this moves the label 179 to the point where we add 16 to R3. I have checked manually all the exception handlers for the loads and stores in this code and the rest of them are correct (it would be excellent to have an automated test of all the exception cases). This bug has been present since this code was initially committed in May 2002 to Linux version 2.5.20. Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/powernv: Use CPU-endian PEST in pnv_pci_dump_p7ioc_diag_data()Gavin Shan
commit 5adaf8629b193f185ca5a1665b9e777a0579f518 upstream. This fixes the warnings reported from sparse: pci.c:312:33: warning: restricted __be64 degrades to integer pci.c:313:33: warning: restricted __be64 degrades to integer Fixes: cee72d5bb489 ("powerpc/powernv: Display diag data on p7ioc EEH errors") Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/powernv: Use CPU-endian hub diag-data type in ↵Gavin Shan
pnv_eeh_get_and_dump_hub_diag() commit a7032132d7560a8434e1f54b71efd7fa20f073bd upstream. The hub diag-data type is filled with big-endian data by OPAL call opal_pci_get_hub_diag_data(). We need convert it to CPU-endian value before using it. The issue is reported by sparse as pointed by Michael Ellerman: eeh-powernv.c:1309:21: warning: restricted __be16 degrades to integer This converts hub diag-data type to CPU-endian before using it in pnv_eeh_get_and_dump_hub_diag(). Fixes: 2a485ad7c88d ("powerpc/powernv: Drop PHB operation next_error()") Suggested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: Russell Currey <ruscur@russell.cc> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/powernv: Pass CPU-endian PE number to opal_pci_eeh_freeze_clear()Gavin Shan
commit d63e51b31e0b655ed0f581b8a8fd4c4b4f8d1919 upstream. The PE number (@frozen_pe_no), filled by opal_pci_next_error() is in big-endian format. It should be converted to CPU-endian before it is passed to opal_pci_eeh_freeze_clear() when clearing the frozen state if the PE is invalid one. As Michael Ellerman pointed out, the issue is also detected by sparse: eeh-powernv.c:1541:41: warning: incorrect type in argument 2 (different base types) This passes CPU-endian PE number to opal_pci_eeh_freeze_clear() and it should be part of commit <0f36db77643b> ("powerpc/eeh: Fix wrong printed PE number"), which was merged to 4.3 kernel. Fixes: 71b540adffd9 ("powerpc/powernv: Don't escalate non-existing frozen PE") Suggested-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: Russell Currey <ruscur@russell.cc> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28powerpc/vdso64: Use double word compare on pointersAnton Blanchard
commit 5045ea37377ce8cca6890d32b127ad6770e6dce5 upstream. __kernel_get_syscall_map() and __kernel_clock_getres() use cmpli to check if the passed in pointer is non zero. cmpli maps to a 32 bit compare on binutils, so we ignore the top 32 bits. A simple test case can be created by passing in a bogus pointer with the bottom 32 bits clear. Using a clk_id that is handled by the VDSO, then one that is handled by the kernel shows the problem: printf("%d\n", clock_getres(CLOCK_REALTIME, (void *)0x100000000)); printf("%d\n", clock_getres(CLOCK_BOOTTIME, (void *)0x100000000)); And we get: 0 -1 The bigger issue is if we pass a valid pointer with the bottom 32 bits clear, in this case we will return success but won't write any data to the pointer. I stumbled across this issue because the LLVM integrated assembler doesn't accept cmpli with 3 arguments. Fix this by converting them to cmpldi. Fixes: a7f290dad32e ("[PATCH] powerpc: Merge vdso's and add vdso support to 32 bits kernel") Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28parisc: Increase initial kernel mapping sizeHelge Deller
commit 65bf34f59594c11f13d371c5334a6a0a385cd7ae upstream. Increase the initial kernel default page mapping size for 64-bit kernels to 64 MB and for 32-bit kernels to 32 MB. Due to the additional support of ftrace, tracepoint and huge pages the kernel size can exceed the sizes we used up to now. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28parisc: Fix kernel memory layout regarding position of __gpHelge Deller
commit f8850abb7ba68229838014b3409460e576751c6d upstream. Architecturally we need to keep __gp below 0x1000000. But because of ftrace and tracepoint support, the RO_DATA_SECTION now gets much bigger than it was before. By moving the linkage tables before RO_DATA_SECTION we can avoid that __gp gets positioned at a too high address. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28parisc: Increase KERNEL_INITIAL_SIZE for 32-bit SMP kernelsHelge Deller
commit 690d097c00c88fa9d93d198591e184164b1d8c20 upstream. Increase the initial kernel default page mapping size for SMP kernels to 32MB and add a runtime check which panics early if the kernel is bigger than the initial mapping size. This fixes boot crashes of 32bit SMP kernels. Due to the introduction of huge page support in kernel 4.4 and it's required initial kernel layout in memory, a 32bit SMP kernel usually got bigger (in layout, not size) than 16MB. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-20x86/build: Build compressed x86 kernels as PIEH.J. Lu
commit 6d92bc9d483aa1751755a66fee8fb39dffb088c0 upstream. The 32-bit x86 assembler in binutils 2.26 will generate R_386_GOT32X relocation to get the symbol address in PIC. When the compressed x86 kernel isn't built as PIC, the linker optimizes R_386_GOT32X relocations to their fixed symbol addresses. However, when the compressed x86 kernel is loaded at a different address, it leads to the following load failure: Failed to allocate space for phdrs during the decompression stage. If the compressed x86 kernel is relocatable at run-time, it should be compiled with -fPIE, instead of -fPIC, if possible and should be built as Position Independent Executable (PIE) so that linker won't optimize R_386_GOT32X relocation to its fixed symbol address. Older linkers generate R_386_32 relocations against locally defined symbols, _bss, _ebss, _got and _egot, in PIE. It isn't wrong, just less optimal than R_386_RELATIVE. But the x86 kernel fails to properly handle R_386_32 relocations when relocating the kernel. To generate R_386_RELATIVE relocations, we mark _bss, _ebss, _got and _egot as hidden in both 32-bit and 64-bit x86 kernels. To build a 64-bit compressed x86 kernel as PIE, we need to disable the relocation overflow check to avoid relocation overflow errors. We do this with a new linker command-line option, -z noreloc-overflow, which got added recently: commit 4c10bbaa0912742322f10d9d5bb630ba4e15dfa7 Author: H.J. Lu <hjl.tools@gmail.com> Date: Tue Mar 15 11:07:06 2016 -0700 Add -z noreloc-overflow option to x86-64 ld Add -z noreloc-overflow command-line option to the x86-64 ELF linker to disable relocation overflow check. This can be used to avoid relocation overflow check if there will be no dynamic relocation overflow at run-time. The 64-bit compressed x86 kernel is built as PIE only if the linker supports -z noreloc-overflow. So far 64-bit relocatable compressed x86 kernel boots fine even when it is built as a normal executable. Signed-off-by: H.J. Lu <hjl.tools@gmail.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org [ Edited the changelog and comments. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16ARM: dts: MSM8064 remove flags from SPMI/MPP IRQsLinus Walleij
commit ca88696e8b73a9fa2b1de445747e9235c3a7bd50 upstream. The Qualcomm PMIC GPIO and MPP lines are problematic: the are fetched from the main MFD driver with platform_get_irq() which means that at this point they will all be assigned the flags set up for the interrupts in the device tree. That is problematic since these are flagged as rising edge and an this point the interrupt descriptor is assigned a rising edge, while the only thing the GPIO/MPP drivers really do is issue irq_get_irqchip_state() on the line to read it out and to provide a .to_irq() helper for *other* IRQ consumers. If another device tree node tries to flag the same IRQ for use as something else than rising edge, the kernel irqdomain core will protest like this: type mismatch, failed to map hwirq-NN for <FOO>! Which is what happens when the device tree defines two contradictory flags for the same interrupt line. To work around this and alleviate the problem, assign 0 as flag for the interrupts taken by the PM GPIO and MPP drivers. This will lead to the flag being unset, and a second consumer requesting rising, falling, both or level interrupts will be respected. This is what the qcom-pm*.dtsi files already do. Switched to using the symbolic name IRQ_TYPE_NONE so that we get this more readable. Fixes: bce360469676 ("ARM: dts: apq8064: add pm8921 mpp support") Fixes: 874443fe9e33 ("ARM: dts: apq8064: Add pm8921 mfd and its gpio node") Cc: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Björn Andersson <bjorn.andersson@linaro.org> Cc: Ivan T. Ivanov <ivan.ivanov@linaro.org> Cc: John Stultz <john.stultz@linaro.org> Cc: Andy Gross <andy.gross@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16ARM: dts: mvebu: armada-390: add missing compatibility string and bracketGrzegorz Jaszczyk
commit 061492cfad9f11dbc32df741a7164f307b69b6e6 upstream. The armada-390.dtsi was broken since the first patch which adds Device Tree files for Armada 39x SoC was introduced. Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Fixes 538da83 ("ARM: mvebu: add Device Tree files for Armada 39x SoC and board") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2016-10-16x86/dumpstack: Fix x86_32 kernel_stack_pointer() previous stack accessJosh Poimboeuf
commit 72b4f6a5e903b071f2a7c4eb1418cbe4eefdc344 upstream. On x86_32, when an interrupt happens from kernel space, SS and SP aren't pushed and the existing stack is used. So pt_regs is effectively two words shorter, and the previous stack pointer is normally the memory after the shortened pt_regs, aka '&regs->sp'. But in the rare case where the interrupt hits right after the stack pointer has been changed to point to an empty stack, like for example when call_on_stack() is used, the address immediately after the shortened pt_regs is no longer on the stack. In that case, instead of '&regs->sp', the previous stack pointer should be retrieved from the beginning of the current stack page. kernel_stack_pointer() wants to do that, but it forgets to dereference the pointer. So instead of returning a pointer to the previous stack, it returns a pointer to the beginning of the current stack. Note that it's probably outside of kernel_stack_pointer()'s scope to be switching stacks at all. The x86_64 version of this function doesn't do it, and it would be better for the caller to do it if necessary. But that's a patch for another day. This just fixes the original intent. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Byungchul Park <byungchul.park@lge.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nilay Vaish <nilayvaish@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 0788aa6a23cb ("x86: Prepare removal of previous_esp from i386 thread_info structure") Link: http://lkml.kernel.org/r/472453d6e9f6a2d4ab16aaed4935f43117111566.1471535549.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16x86/irq: Prevent force migration of irqs which are not in the vector domainMika Westerberg
commit db91aa793ff984ac048e199ea1c54202543952fe upstream. When a CPU is about to be offlined we call fixup_irqs() that resets IRQ affinities related to the CPU in question. The same thing is also done when the system is suspended to S-states like S3 (mem). For each IRQ we try to complete any on-going move regardless whether the IRQ is actually part of x86_vector_domain. For each IRQ descriptor we fetch its chip_data, assume it is of type struct apic_chip_data and manipulate it by clearing old_domain mask etc. For irq_chips that are not part of the x86_vector_domain, like those created by various GPIO drivers, will find their chip_data being changed unexpectly. Below is an example where GPIO chip owned by pinctrl-sunrisepoint.c gets corrupted after resume: # cat /sys/kernel/debug/gpio gpiochip0: GPIOs 360-511, parent: platform/INT344B:00, INT344B:00: gpio-511 ( |sysfs ) in hi # rtcwake -s10 -mmem <10 seconds passes> # cat /sys/kernel/debug/gpio gpiochip0: GPIOs 360-511, parent: platform/INT344B:00, INT344B:00: gpio-511 ( |sysfs ) in ? Note '?' in the output. It means the struct gpio_chip ->get function is NULL whereas before suspend it was there. Fix this by first checking that the IRQ belongs to x86_vector_domain before we try to use the chip_data as struct apic_chip_data. Reported-and-tested-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Link: http://lkml.kernel.org/r/20161003101708.34795-1-mika.westerberg@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16x86/boot: Fix kdump, cleanup aborted E820_PRAM max_pfn manipulationDan Williams
commit 917db484dc6a69969d317b3e57add4208a8d9d42 upstream. In commit: ec776ef6bbe1 ("x86/mm: Add support for the non-standard protected e820 type") Christoph references the original patch I wrote implementing pmem support. The intent of the 'max_pfn' changes in that commit were to enable persistent memory ranges to be covered by the struct page memmap by default. However, that approach was abandoned when Christoph ported the patches [1], and that functionality has since been replaced by devm_memremap_pages(). In the meantime, this max_pfn manipulation is confusing kdump [2] that assumes that everything covered by the max_pfn is "System RAM". This results in kdump hanging or crashing. [1]: https://lists.01.org/pipermail/linux-nvdimm/2015-March/000348.html [2]: https://bugzilla.redhat.com/show_bug.cgi?id=1351098 So fix it. Reported-by: Zhang Yi <yizhan@redhat.com> Reported-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Zhang Yi <yizhan@redhat.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-nvdimm@lists.01.org Fixes: ec776ef6bbe1 ("x86/mm: Add support for the non-standard protected e820 type") Link: http://lkml.kernel.org/r/147448744538.34910.11287693517367139607.stgit@dwillia2-desk3.amr.corp.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16KVM: PPC: BookE: Fix a sanity checkDan Carpenter
commit ac0e89bb4744d3882ccd275f2416d9ce22f4e1e7 upstream. We use logical negate where bitwise negate was intended. It means that we never return -EINVAL here. Fixes: ce11e48b7fdd ('KVM: PPC: E500: Add userspace debug stub support') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16KVM: MIPS: Drop other CPU ASIDs on guest MMU changesJames Hogan
commit 91e4f1b6073dd680d86cdb7e42d7cccca9db39d8 upstream. When a guest TLB entry is replaced by TLBWI or TLBWR, we only invalidate TLB entries on the local CPU. This doesn't work correctly on an SMP host when the guest is migrated to a different physical CPU, as it could pick up stale TLB mappings from the last time the vCPU ran on that physical CPU. Therefore invalidate both user and kernel host ASIDs on other CPUs, which will cause new ASIDs to be generated when it next runs on those CPUs. We're careful only to do this if the TLB entry was already valid, and only for the kernel ASID where the virtual address it mapped is outside of the guest user address range. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Radim Krčmář" <rkrcmar@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: kvm@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16KVM: PPC: Book3s PR: Allow access to unprivileged MMCR2 registerThomas Huth
commit fa73c3b25bd8d0d393dc6109a1dba3c2aef0451e upstream. The MMCR2 register is available twice, one time with number 785 (privileged access), and one time with number 769 (unprivileged, but it can be disabled completely). In former times, the Linux kernel was using the unprivileged register 769 only, but since commit 8dd75ccb571f3c92c ("powerpc: Use privileged SPR number for MMCR2"), it uses the privileged register 785 instead. The KVM-PR code then of course also switched to use the SPR 785, but this is causing older guest kernels to crash, since these kernels still access 769 instead. So to support older kernels with KVM-PR again, we have to support register 769 in KVM-PR, too. Fixes: 8dd75ccb571f3c92c48014b3dabd3d51a115ab41 Signed-off-by: Thomas Huth <thuth@redhat.com> Signed-off-by: Paul Mackerras <paulus@ozlabs.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07KVM: nVMX: postpone VMCS changes on MSR_IA32_APICBASE writeRadim Krčmář
commit dccbfcf52cebb8963246eba5b177b77f26b34da0 upstream. If vmcs12 does not intercept APIC_BASE writes, then KVM will handle the write with vmcs02 as the current VMCS. This will incorrectly apply modifications intended for vmcs01 to vmcs02 and L2 can use it to gain access to L0's x2APIC registers by disabling virtualized x2APIC while using msr bitmap that assumes enabled. Postpone execution of vmx_set_virtual_x2apic_mode until vmcs01 is the current VMCS. An alternative solution would temporarily make vmcs01 the current VMCS, but it requires more care. Fixes: 8d14695f9542 ("x86, apicv: add virtual x2apic support") Reported-by: Jim Mattson <jmattson@google.com> Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07powerpc/prom: Fix sub-processor option passed to ibm, ↵Michael Ellerman
client-architecture-support commit 66443efa83dc73775100b7442962ce2cb0d4472e upstream. When booting from an OpenFirmware which supports it, we use the "ibm,client-architecture-support" firmware call to communicate our capabilities to firmware. The format of the structure we pass to firmware is specified in PAPR (Power Architecture Platform Requirements), or the public version LoPAPR (Linux on Power Architecture Platform Reference). Referring to table 244 in LoPAPR v1.1, option vector 5 contains a 4 byte field at bytes 17-20 for the "Platform Facilities Enable". This is followed by a 1 byte field at byte 21 for "Sub-Processor Represenation Level". Comparing to the code, there we have the Platform Facilities options (OV5_PFO_*) at byte 17, but we fail to pad that field out to its full width of 4 bytes. This means the OV5_SUB_PROCESSORS option is incorrectly placed at byte 18. Fix it by adding zero bytes for bytes 18, 19, 20, and comment the bytes to hopefully make it clearer in future. As far as I'm aware nothing actually consumes this value at this time, so the effect of this bug is nil in practice. It does mean we've been incorrectly setting bit 15 of the "Platform Facilities Enable" option for the past ~3 1/2 years, so we should avoid allocating that bit to anything else in future. Fixes: df77c7992029 ("powerpc/pseries: Update ibm,architecture.vec for PAPR 2.7/POWER8") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07avr32: off by one in at32_init_pio()Dan Carpenter
commit 55f1cf83d5cf885c75267269729805852039c834 upstream. The pio_dev[] array has MAX_NR_PIO_DEVICES elements so the > should be >=. Fixes: 5f97f7f9400d ('[PATCH] avr32 architecture') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07tile: Define AT_VECTOR_SIZE_ARCH for ARCH_DLINFOJames Hogan
commit cdf8b4633075f2171d440d2e37c9c2609019a81a upstream. AT_VECTOR_SIZE_ARCH should be defined with the maximum number of NEW_AUX_ENT entries that ARCH_DLINFO can contain, but it wasn't defined for tile at all even though ARCH_DLINFO will contain one NEW_AUX_ENT for the VDSO address. This shouldn't be a problem as AT_VECTOR_SIZE_BASE includes space for AT_BASE_PLATFORM which tile doesn't use, but lets define it now and add the comment above ARCH_DLINFO as found in several other architectures to remind future modifiers of ARCH_DLINFO to keep AT_VECTOR_SIZE_ARCH up to date. Fixes: 4a556f4f56da ("tile: implement gettimeofday() via vDSO") Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07ARM: sa1111: fix pcmcia suspend/resumeRussell King
commit 06dfe5cc0cc684e735cb0232fdb756d30780b05d upstream. SA1111 PCMCIA was broken when PCMCIA switched to using dev_pm_ops for the PCMCIA socket class. PCMCIA used to handle suspend/resume via the socket hosting device, which happened at normal device suspend/resume time. However, the referenced commit changed this: much of the resume now happens much earlier, in the noirq resume handler of dev_pm_ops. However, on SA1111, the PCMCIA device is not accessible as the SA1111 has not been resumed at _noirq time. It's slightly worse than that, because the SA1111 has already been put to sleep at _noirq time, so suspend doesn't work properly. Fix this by converting the core SA1111 code to use dev_pm_ops as well, and performing its own suspend/resume at noirq time. This fixes these errors in the kernel log: pcmcia_socket pcmcia_socket0: time out after reset pcmcia_socket pcmcia_socket1: time out after reset and the resulting lack of PCMCIA cards after a S2RAM cycle. Fixes: d7646f7632549 ("pcmcia: use dev_pm_ops for class pcmcia_socket_class") Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
