commit f0295e047fcf52ccb42561fb7de6942f5201b676 upstream.
The current EEH callbacks can race with a driver unbind. This can
result in a backtraces like this:
EEH: Frozen PHB#0-PE#1fc detected
EEH: PE location: S000009, PHB location: N/A
CPU: 2 PID: 2312 Comm: kworker/u258:3 Not tainted 4.15.6-openpower1 #2
Workqueue: nvme-wq nvme_reset_work [nvme]
Call Trace:
dump_stack+0x9c/0xd0 (unreliable)
eeh_dev_check_failure+0x420/0x470
eeh_check_failure+0xa0/0xa4
nvme_reset_work+0x138/0x1414 [nvme]
process_one_work+0x1ec/0x328
worker_thread+0x2e4/0x3a8
kthread+0x14c/0x154
ret_from_kernel_thread+0x5c/0xc8
nvme nvme1: Removing after probe failure status: -19
<snip>
cpu 0x23: Vector: 300 (Data Access) at [c000000ff50f3800]
pc: c0080000089a0eb0: nvme_error_detected+0x4c/0x90 [nvme]
lr: c000000000026564: eeh_report_error+0xe0/0x110
sp: c000000ff50f3a80
msr: 9000000000009033
dar: 400
dsisr: 40000000
current = 0xc000000ff507c000
paca = 0xc00000000fdc9d80 softe: 0 irq_happened: 0x01
pid = 782, comm = eehd
Linux version 4.15.6-openpower1 (smc@smc-desktop) (gcc version 6.4.0 (Buildroot 2017.11.2-00008-g4b6188e)) #2 SM P Tue Feb 27 12:33:27 PST 2018
enter ? for help
eeh_pe_dev_traverse+0xc0/0xdc
eeh_handle_normal_event+0x184/0x4c4
eeh_handle_event+0x30/0x288
eeh_event_handler+0x124/0x170
kthread+0x14c/0x154
The first part is an EEH (on boot), the second half is the resulting
crash. nvme probe starts the nvme_reset_work() worker thread. This
worker thread starts touching the device which see a device error
(EEH) and hence queues up an event in the powerpc EEH worker
thread. nvme_reset_work() then continues and runs
nvme_remove_dead_ctrl_work() which results in unbinding the driver
from the device and hence releases all resources. At the same time,
the EEH worker thread starts doing the EEH .error_detected() driver
callback, which no longer works since the resources have been freed.
This fixes the problem in the same way the generic PCIe AER code (in
drivers/pci/pcie/aer/aerdrv_core.c) does. It makes the EEH code hold
the device_lock() while performing the driver EEH callbacks and
associated code. This ensures either the callbacks are no longer
register, or if they are registered the driver will not be removed
from underneath us.
This has been broken forever. The EEH call backs were first introduced
in 2005 (in 77bd7415610) but it's not clear if a lock was needed back
then.
Fixes: 77bd74156101 ("[PATCH] powerpc: PCI Error Recovery: PPC64 core recovery routines")
Cc: stable@vger.kernel.org # v2.6.16+
Signed-off-by: Michael Neuling <mikey@neuling.org>
Reviewed-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
commit 84749d83758af6576552046b215b9b7f37f9556b upstream.
save_mc_for_early() was a no-op on !CONFIG_HOTPLUG_CPU but the
generic_load_microcode() path saves the microcode patches it has found into
the cache of patches which is used for late loading too. Regardless of
whether CPU hotplug is used or not.
Make the saving unconditional so that late loading can find the proper
patch.
Reported-by: Vitezslav Samel <vitezslav@samel.cz>
Tested-by: Vitezslav Samel <vitezslav@samel.cz>
Tested-by: Ashok Raj <ashok.raj@intel.com>
Link: http://lkml.kernel.org/r/20180418081140.GA2439@pc11.op.pod.cz
Link: https://lkml.kernel.org/r/20180421081930.15741-1-bp@alien8.de
commit da6fa7ef67f07108a1b0cb9fd9e7fcaabd39c051 upstream.
Recent AMD systems support using MWAIT for C1 state. However, MWAIT will
not allow deeper cstates than C1 on current systems.
play_dead() expects to use the deepest state available. The deepest state
available on AMD systems is reached through SystemIO or HALT. If MWAIT is
available, it is preferred over the other methods, so the CPU never reaches
the deepest possible state.
Don't try to use MWAIT to play_dead() on AMD systems. Instead, use CPUIDLE
to enter the deepest state advertised by firmware. If CPUIDLE is not
available then fallback to HALT.
Signed-off-by: Yazen Ghannam <yazen.ghannam@amd.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: https://lkml.kernel.org/r/20180403140228.58540-1-Yazen.Ghannam@amd.com
commit 1a512c0882bd311c5b5561840fcfbe4c25b8f319 upstream.
A bugfix broke the x32 shmid64_ds and msqid64_ds data structure layout
(as seen from user space) a few years ago: Originally, __BITS_PER_LONG
was defined as 64 on x32, so we did not have padding after the 64-bit
__kernel_time_t fields, After __BITS_PER_LONG got changed to 32,
applications would observe extra padding.
In other parts of the uapi headers we seem to have a mix of those
expecting either 32 or 64 on x32 applications, so we can't easily revert
the path that broke these two structures.
Instead, this patch decouples x32 from the other architectures and moves
it back into arch specific headers, partially reverting the even older
commit 73a2d096fdf2 ("x86: remove all now-duplicate header files").
It's not clear whether this ever made any difference, since at least
glibc carries its own (correct) copy of both of these header files,
so possibly no application has ever observed the definitions here.
Based on a suggestion from H.J. Lu, I tried out the tool from
https://github.com/hjl-tools/linux-header to find other such
bugs, which pointed out the same bug in statfs(), which also has
a separate (correct) copy in glibc.
Fixes: f4b4aae18288 ("x86/headers/uapi: Fix __BITS_PER_LONG value for x32 builds")
Cc: "H . J . Lu" <hjl.tools@gmail.com>
Cc: Jeffrey Walton <noloader@gmail.com>
Link: https://lkml.kernel.org/r/20180424212013.3967461-1-arnd@arndb.de
commit 682e6b4da5cbe8e9a53f979a58c2a9d7dc997175 upstream.
The OPAL RTC driver does not sleep in case it gets OPAL_BUSY or
OPAL_BUSY_EVENT from firmware, which causes large scheduling
latencies, up to 50 seconds have been observed here when RTC stops
responding (BMC reboot can do it).
Fix this by converting it to the standard form OPAL_BUSY loop that
sleeps.
Fixes: 628daa8d5abf ("powerpc/powernv: Add RTC and NVRAM support plus RTAS fallbacks")
Cc: stable@vger.kernel.org # v3.2+
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
commit 783c3b53b9506db3e05daacfe34e0287eebb09d8 upstream.
Implement s390 specific arch_uretprobe_is_alive() to avoid SIGSEGVs
observed with uretprobes in combination with setjmp/longjmp.
See commit 2dea1d9c38e4 ("powerpc/uprobes: Implement
arch_uretprobe_is_alive()") for more details.
With this implemented all test cases referenced in the above commit
pass.
Reported-by: Ziqian SUN <zsun@redhat.com>
Cc: <stable@vger.kernel.org> # v4.3+
[ Upstream commit 6cf09958f32b9667bb3ebadf74367c791112771b ]
The main linker script vmlinux.lds.S for the kernel image merges
the expoline code patch tables into two section ".nospec_call_table"
and ".nospec_return_table". This is *not* done for the modules,
there the sections retain their original names as generated by gcc:
".s390_indirect_call", ".s390_return_mem" and ".s390_return_reg".
The module_finalize code has to check for the compiler generated
section names, otherwise no code patching is done. This slows down
the module code in case of "spectre_v2=off".
Cc: stable@vger.kernel.org # 4.16
Fixes: f19fbd5ed6 ("s390: introduce execute-trampolines for branches")
[ Upstream commit 6a3d1e81a434fc311f224b8be77258bafc18ccc6 ]
With CONFIG_EXPOLINE_AUTO=y the call of spectre_v2_auto_early() via
early_initcall is done *after* the early_param functions. This
overwrites any settings done with the nobp/no_spectre_v2/spectre_v2
parameters. The code patching for the kernel is done after the
evaluation of the early parameters but before the early_initcall
is done. The end result is a kernel image that is patched correctly
but the kernel modules are not.
Make sure that the nospec auto detection function is called before the
early parameters are evaluated and before the code patching is done.
Fixes: 6e179d64126b ("s390: add automatic detection of the spectre defense")
[ Upstream commit d424986f1d6b16079b3231db0314923f4f8deed1 ]
Set CONFIG_GENERIC_CPU_VULNERABILITIES and provide the two functions
cpu_show_spectre_v1 and cpu_show_spectre_v2 to report the spectre
mitigations.
[ Upstream commit bc035599718412cfba9249aa713f90ef13f13ee9 ]
Add a boot message if either of the spectre defenses is active.
The message is
"Spectre V2 mitigation: execute trampolines."
or "Spectre V2 mitigation: limited branch prediction."
[ Upstream commit 6e179d64126b909f0b288fa63cdbf07c531e9b1d ]
Automatically decide between nobp vs. expolines if the spectre_v2=auto
kernel parameter is specified or CONFIG_EXPOLINE_AUTO=y is set.
The decision made at boot time due to CONFIG_EXPOLINE_AUTO=y being set
can be overruled with the nobp, nospec and spectre_v2 kernel parameters.
[ Upstream commit b2e2f43a01bace1a25bdbae04c9f9846882b727a ]
Keep the code for the nobp parameter handling with the code for
expolines. Both are related to the spectre v2 mitigation.
[ Upstream commit d3f468963cd6fd6d2aa5e26aed8b24232096d0e1 ]
when a system call is interrupted we might call the critical section
cleanup handler that re-does some of the operations. When we are between
.Lsysc_vtime and .Lsysc_do_svc we might also redo the saving of the
problem state registers r0-r7:
.Lcleanup_system_call:
0: # update accounting time stamp
mvc __LC_LAST_UPDATE_TIMER(8),__LC_SYNC_ENTER_TIMER
# set up saved register r11
lg %r15,__LC_KERNEL_STACK
la %r9,STACK_FRAME_OVERHEAD(%r15)
stg %r9,24(%r11) # r11 pt_regs pointer
# fill pt_regs
mvc __PT_R8(64,%r9),__LC_SAVE_AREA_SYNC
---> stmg %r0,%r7,__PT_R0(%r9)
The problem is now, that we might have already zeroed out r0.
The fix is to move the zeroing of r0 after sysc_do_svc.
Reported-by: Farhan Ali <alifm@linux.vnet.ibm.com>
Fixes: 7041d28115e91 ("s390: scrub registers on kernel entry and KVM exit")
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit d5feec04fe578c8dbd9e2e1439afc2f0af761ed4 ]
The system call path can be interrupted before the switch back to the
standard branch prediction with BPENTER has been done. The critical
section cleanup code skips forward to .Lsysc_do_svc and bypasses the
BPENTER. In this case the kernel and all subsequent code will run with
the limited branch prediction.
Fixes: eacf67eb9b32 ("s390: run user space and KVM guests with modified branch prediction")
[ Upstream commit 2cb370d615e9fbed9e95ed222c2c8f337181aa90 ]
I've accidentally stumbled upon the IS_ENABLED(EXPOLINE_*) lines, which
obviously always evaluate to false. Fix this.
Fixes: f19fbd5ed642 ("s390: introduce execute-trampolines for branches")
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
[ Upstream commit f315104ad8b0c32be13eac628569ae707c332cb5 ]
If the guest runs with bp isolation when doing a SIE instruction,
we must also run the nested guest with bp isolation when emulating
that SIE instruction.
This is done by activating BPBC in the lpar, which acts as an override
for lower level guests.
Reviewed-by: Janosch Frank <frankja@linux.vnet.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
[ Upstream commit f19fbd5ed642dc31c809596412dab1ed56f2f156 ]
Add CONFIG_EXPOLINE to enable the use of the new -mindirect-branch= and
-mfunction_return= compiler options to create a kernel fortified against
the specte v2 attack.
With CONFIG_EXPOLINE=y all indirect branches will be issued with an
execute type instruction. For z10 or newer the EXRL instruction will
be used, for older machines the EX instruction. The typical indirect
call
basr %r14,%r1
is replaced with a PC relative call to a new thunk
brasl %r14,__s390x_indirect_jump_r1
The thunk contains the EXRL/EX instruction to the indirect branch
__s390x_indirect_jump_r1:
exrl 0,0f
j .
0: br %r1
The detour via the execute type instruction has a performance impact.
To get rid of the detour the new kernel parameter "nospectre_v2" and
"spectre_v2=[on,off,auto]" can be used. If the parameter is specified
the kernel and module code will be patched at runtime.
[ Upstream commit 6b73044b2b0081ee3dd1cd6eaab7dee552601efb ]
Define TIF_ISOLATE_BP and TIF_ISOLATE_BP_GUEST and add the necessary
plumbing in entry.S to be able to run user space and KVM guests with
To switch a user space process to limited branch prediction the
s390_isolate_bp() function has to be call, and to run a vCPU of a KVM
guest associated with the current task with limited branch prediction
call s390_isolate_bp_guest().
[ Upstream commit d768bd892fc8f066cd3aa000eb1867bcf32db0ee ]
Add the PPA instruction to the system entry and exit path to switch
the kernel to a different branch prediction behaviour. The instructions
are added via CPU alternatives and can be disabled with the "nospec"
or the "nobp=0" kernel parameter. If the default behaviour selected
with CONFIG_KERNEL_NOBP is set to "n" then the "nobp=1" parameter can be
used to enable the changed kernel branch prediction.
Acked-by: Cornelia Huck <cohuck@redhat.com>
[ Upstream commit cf1489984641369611556bf00c48f945c77bcf02 ]
To be able to switch off specific CPU alternatives with kernel parameters
make a copy of the facility bit mask provided by STFLE and use the copy
for the decision to apply an alternative.
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
[ Upstream commit e2dd833389cc4069a96b57bdd24227b5f52288f5 ]
Add an optimized version of the array_index_mask_nospec function for
s390 based on a compare and a subtract with borrow.
[ Upstream commit 7041d28115e91f2144f811ffe8a195c696b1e1d0 ]
Clear all user space registers on entry to the kernel and all KVM guest
registers on KVM guest exit if the register does not contain either a
parameter or a result value.
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
[ Upstream commit 35b3fde6203b932b2b1a5b53b3d8808abc9c4f60 ]
The new firmware interfaces for branch prediction behaviour changes
are transparently available for the guest. Nevertheless, there is
new state attached that should be migrated and properly resetted.
Provide a mechanism for handling reset, migration and VSIE.
[Changed capability number to 152. - Radim]
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit 049a2c2d486e8cc82c5cd79fa479c5b105b109e9 ]
Remove the CPU_ALTERNATIVES config option and enable the code
unconditionally. The config option was only added to avoid a conflict
with the named saved segment support. Since that code is gone there is
no reason to keep the CPU_ALTERNATIVES config option.
Just enable it unconditionally to also reduce the number of config
options and make it less likely that something breaks.
[ Upstream commit 686140a1a9c41d85a4212a1c26d671139b76404b ]
Implement CPU alternatives, which allows to optionally patch newer
instructions at runtime, based on CPU facilities availability.
A new kernel boot parameter "noaltinstr" disables patching.
Current implementation is derived from x86 alternatives. Although
ideal instructions padding (when altinstr is longer then oldinstr)
is added at compile time, and no oldinstr nops optimization has to be
done at runtime. Also couple of compile time sanity checks are done:
1. oldinstr and altinstr must be <= 254 bytes long,
2. oldinstr and altinstr must not have an odd length.
alternative(oldinstr, altinstr, facility);
alternative_2(oldinstr, altinstr1, facility1, altinstr2, facility2);
Both compile time and runtime padding consists of either 6/4/2 bytes nop
or a jump (brcl) + 2 bytes nop filler if padding is longer then 6 bytes.
.altinstructions and .altinstr_replacement sections are part of
__init_begin : __init_end region and are freed after initialization.
Signed-off-by: Vasily Gorbik <gor@linux.vnet.ibm.com>
commit a3078e593b74fe196e69f122f03ff0b32f652c53 upstream.
Big endian CPUs require SWAP_IO_SPACE enabled to swap accesses to little
endian peripherals.
Without this patch, big endian kernels fail to communicate with little
endian periperals, such as PCI devices, on QEMU and FPGA based
platforms.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Fixes: eed0eabd12ef ("MIPS: generic: Introduce generic DT-based board support")
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15105/
Cc: Amit Pundir <amit.pundir@linaro.org>
commit d3878e164dcd3925a237a20e879432400e369172 upstream.
The TSC calibration code uses HPET as reference. The conversion normalizes
the delta of two HPET timestamps:
hpetref = ((tshpet1 - tshpet2) * HPET_PERIOD) / 1e6
and then divides the normalized delta of the corresponding TSC timestamps
by the result to calulate the TSC frequency.
tscfreq = ((tstsc1 - tstsc2 ) * 1e6) / hpetref
This uses do_div() which takes an u32 as the divisor, which worked so far
because the HPET frequency was low enough that 'hpetref' never exceeded
32bit.
On Skylake machines the HPET frequency increased so 'hpetref' can exceed
32bit. do_div() truncates the divisor, which causes the calibration to
fail.
Use div64_u64() to avoid the problem.
[ tglx: Fixes whitespace mangled patch and rewrote changelog ]
Signed-off-by: Xiaoming Gao <newtongao@tencent.com>
Cc: peterz@infradead.org
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/38894564-4fc9-b8ec-353f-de702839e44e@gmail.com
commit a24cd490739586a7d2da3549a1844e1d7c4f4fc4 upstream.
hypfs_fill_super() might fail to allocate sbi; hypfs_kill_super()
should not oops on that.
commit b8858581febb050688e276b956796bc4a78299ed upstream.
When we patch an alternate feature section, we have to adjust any
relative branches that branch out of the alternate section.
But currently we have a bug if we have a branch that points to past
the last instruction of the alternate section, eg:
FTR_SECTION_ELSE
1: b 2f
or 6,6,6
2:
ALT_FTR_SECTION_END(...)
nop
This will result in a relative branch at 1 with a target that equals
the end of the alternate section.
That branch does not need adjusting when it's moved to the non-else
location. Currently we do adjust it, resulting in a branch that goes
off into the link-time location of the else section, which is junk.
The fix is to not patch branches that have a target == end of the
alternate section.
Fixes: d20fe50a7b3c ("KVM: PPC: Book3S HV: Branch inside feature section")
Fixes: 9b1a735de64c ("powerpc: Add logic to patch alternative feature sections")
Cc: stable@vger.kernel.org # v2.6.27+
commit 13a83eac373c49c0a081cbcd137e79210fe78acd upstream.
On boot we save the configuration space of PCIe bridges. We do this so
when we get an EEH event and everything gets reset that we can restore
them.
Unfortunately we save this state before we've enabled the MMIO space
on the bridges. Hence if we have to reset the bridge when we come back
MMIO is not enabled and we end up taking an PE freeze when the driver
starts accessing again.
This patch forces the memory/MMIO and bus mastering on when restoring
bridges on EEH. Ideally we'd do this correctly by saving the
configuration space writes later, but that will have to come later in
a larger EEH rewrite. For now we have this simple fix.
The original bug can be triggered on a boston machine by doing:
echo 0x8000000000000000 > /sys/kernel/debug/powerpc/PCI0001/err_injct_outbound
On boston, this PHB has a PCIe switch on it. Without this patch,
you'll see two EEH events, 1 expected and 1 the failure we are fixing
here. The second EEH event causes the anything under the PHB to
disappear (i.e. the i40e eth).
With this patch, only 1 EEH event occurs and devices properly recover.
Fixes: 652defed4875 ("powerpc/eeh: Check PCIe link after reset")
Cc: stable@vger.kernel.org # v3.11+
Reported-by: Pridhiviraj Paidipeddi <ppaidipe@linux.vnet.ibm.com>
Acked-by: Russell Currey <ruscur@russell.cc>
commit c96eebf07692e53bf4dd5987510d8b550e793598 upstream.
The label .Llast_fixup\@ is jumped to on page fault within the final
byte set loop of memset (on < MIPSR6 architectures). For some reason, in
this fault handler, the v1 register is randomly set to a2 & STORMASK.
This clobbers v1 for the calling function. This can be observed with the
following test code:
static int __init __attribute__((optimize("O0"))) test_clear_user(void)
register int t asm("v1");
char *test;
int j, k;
pr_info("\n\n\nTesting clear_user\n");
test = vmalloc(PAGE_SIZE);
for (j = 256; j < 512; j++) {
t = 0xa5a5a5a5;
if ((k = clear_user(test + PAGE_SIZE - 256, j)) != j - 256) {
pr_err("clear_user (%px %d) returned %d\n", test + PAGE_SIZE - 256, j, k);
if (t != 0xa5a5a5a5) {
pr_err("v1 was clobbered to 0x%x!\n", t);
return 0;
late_initcall(test_clear_user);
Which demonstrates that v1 is indeed clobbered (MIPS64):
Testing clear_user
v1 was clobbered to 0x1!
v1 was clobbered to 0x2!
v1 was clobbered to 0x3!
v1 was clobbered to 0x4!
v1 was clobbered to 0x5!
v1 was clobbered to 0x6!
v1 was clobbered to 0x7!
Since the number of bytes that could not be set is already contained in
a2, the andi placing a value in v1 is not necessary and actively
harmful in clobbering v1.
Reported-by: James Hogan <jhogan@kernel.org>
Signed-off-by: Matt Redfearn <matt.redfearn@mips.com>
Patchwork: https://patchwork.linux-mips.org/patch/19109/
Signed-off-by: James Hogan <jhogan@kernel.org>
commit daf70d89f80c6e1772233da9e020114b1254e7e0 upstream.
The __clear_user function is defined to return the number of bytes that
could not be cleared. From the underlying memset / bzero implementation
this means setting register a2 to that number on return. Currently if a
page fault is triggered within the memset_partial block, the value
loaded into a2 on return is meaningless.
The label .Lpartial_fixup\@ is jumped to on page fault. In order to work
out how many bytes failed to copy, the exception handler should find how
many bytes left in the partial block (andi a2, STORMASK), add that to
the partial block end address (a2), and subtract the faulting address to
get the remainder. Currently it incorrectly subtracts the partial block
start address (t1), which has additionally been clobbered to generate a
jump target in memset_partial. Fix this by adding the block end address
instead.
This issue was found with the following test code:
int j, k;
for (j = 0; j < 512; j++) {
if ((k = clear_user(NULL, j)) != j) {
pr_err("clear_user (NULL %d) returned %d\n", j, k);
Which now passes on Creator Ci40 (MIPS32) and Cavium Octeon II (MIPS64).
Suggested-by: James Hogan <jhogan@kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/19108/
commit 8a8158c85e1e774a44fbe81106fa41138580dfd1 upstream.
The MIPS kernel memset / bzero implementation includes a small_memset
branch which is used when the region to be set is smaller than a long (4
bytes on 32bit, 8 bytes on 64bit). The current small_memset
implementation uses a simple store byte loop to write the destination.
There are 2 issues with this implementation:
1. When EVA mode is active, user and kernel address spaces may overlap.
Currently the use of the sb instruction means kernel mode addressing is
always used and an intended write to userspace may actually overwrite
some critical kernel data.
2. If the write triggers a page fault, for example by calling
__clear_user(NULL, 2), instead of gracefully handling the fault, an OOPS
is triggered.
Fix these issues by replacing the sb instruction with the EX() macro,
which will emit EVA compatible instuctions as required. Additionally
implement a fault fixup for small_memset which sets a2 to the number of
bytes that could not be cleared (as defined by __clear_user).
Reported-by: Chuanhua Lei <chuanhua.lei@intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/18975/
commit b3d7e55c3f886493235bfee08e1e5a4a27cbcce8 upstream.
The micromips implementation of bzero additionally clobbers registers t7
& t8. Specify this in the clobbers list when invoking bzero.
Fixes: 26c5e07d1478 ("MIPS: microMIPS: Optimise 'memset' core library function.")
Cc: <stable@vger.kernel.org> # 3.10+
Patchwork: https://patchwork.linux-mips.org/patch/19110/
commit 4d1a535b8ec5e74b42dfd9dc809142653b2597f6 upstream.
glibc 2.26 removed the 'struct ucontext' to "improve" POSIX compliance
and break programs, including User Mode Linux. Fix User Mode Linux
by using POSIX ucontext_t.
This fixes:
arch/um/os-Linux/signal.c: In function 'hard_handler':
arch/um/os-Linux/signal.c:163:22: error: dereferencing pointer to incomplete type 'struct ucontext'
mcontext_t *mc = &uc->uc_mcontext;
arch/x86/um/stub_segv.c: In function 'stub_segv_handler':
arch/x86/um/stub_segv.c:16:13: error: dereferencing pointer to incomplete type 'struct ucontext'
&uc->uc_mcontext);
Signed-off-by: Krzysztof Mazur <krzysiek@podlesie.net>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 530ba6c7cb3c22435a4d26de47037bb6f86a5329 upstream.
Recent libcs have gotten a bit more strict, so we actually need to
include the right headers and use the right types. This enables UML to
compile again.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
commit 3b8070335f751aac9f1526ae2e012e6f5b8b0f21 upstream.
The OPAL NVRAM driver does not sleep in case it gets OPAL_BUSY or
latencies, and various lockup errors to trigger (again, BMC reboot
can cause it).
sleeps.
Depends-on: 34dd25de9fe3 ("powerpc/powernv: define a standard delay for OPAL_BUSY type retry loops")
commit 34dd25de9fe3f60bfdb31b473bf04b28262d0896 upstream.
This is the start of an effort to tidy up and standardise all the
delays. Existing loops have a range of delay/sleep periods from 1ms
to 20ms, and some have no delay. They all loop forever except rtc,
which times out after 10 retries, and that uses 10ms delays. So use
10ms as our standard delay. The OPAL maintainer agrees 10ms is a
reasonable starting point.
The idea is to use the same recipe everywhere, once this is proven to
work then it will be documented as an OPAL API standard. Then both
firmware and OS can agree, and if a particular call needs something
else, then that can be documented with reasoning.
This is not the end-all of this effort, it's just a relatively easy
change that fixes some existing high latency delays. There should be
provision for standardising timeouts and/or interruptible loops where
possible, so non-fatal firmware errors don't cause hangs.
Cc: Nathan Chancellor <natechancellor@gmail.com>
commit 0bfdf598900fd62869659f360d3387ed80eb71cf upstream.
asm/barrier.h is not always included after asm/synch.h, which meant
it was missing __SUBARCH_HAS_LWSYNC, so in some files smp_wmb() would
be eieio when it should be lwsync. kernel/time/hrtimer.c is one case.
__SUBARCH_HAS_LWSYNC is only used in one place, so just fold it in
to where it's used. Previously with my small simulator config, 377
instances of eieio in the tree. After this patch there are 55.
Fixes: 46d075be585e ("powerpc: Optimise smp_wmb")
Cc: stable@vger.kernel.org # v2.6.29+
commit 741de617661794246f84a21a02fc5e327bffc9ad upstream.
opal_nvram_write currently just assumes success if it encounters an
error other than OPAL_BUSY or OPAL_BUSY_EVENT. Have it return -EIO
on other errors instead.
Reviewed-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com>
Acked-by: Stewart Smith <stewart@linux.ibm.com>
commit 9a06757dcc8509c162ac00488c8c82fc98e04227 upstream.
The compatible string is incorrect. Add atmel,sama5d3-pinctrl since
it's the appropriate compatible string. Remove the
atmel,at91rm9200-pinctrl compatible string, this fallback is
useless, there are too many changes.
Signed-off-by: Santiago Esteban <Santiago.Esteban@microchip.com>
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Cc: stable@vger.kernel.org #v3.18
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
commit 6f4870753f29edf7dc39444246f9e39987b8b158 upstream.
The proper name for the property, which assign given device to IOMMU is
'iommus', not 'iommu'. Fix incorrect name and let all GScaler devices
to be properly handled when IOMMU support is enabled.
Reported-by: Andrzej Hajda <a.hajda@samsung.com>
Fixes: 6cbfdd73a94f ("ARM: dts: add sysmmu nodes for exynos5250")
Cc: <stable@vger.kernel.org> # v4.8+
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit e8fd0adf105e132fd84545997bbef3d5edc2c9c1 upstream.
There are only 19 PIOB pins having primary names PB0-PB18. Not all of them
have a 'C' function. So the pinctrl property mask ends up being the same as the
other SoC of the at91sam9x5 series.
Reported-by: Marek Sieranski <marek.sieranski@microchip.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: <stable@vger.kernel.org> # v3.8+
commit 91b2d3442f6a44dce875670d702af22737ad5eff upstream.
The arm64 futex code has some explicit dereferencing of user pointers
where performing atomic operations in response to a futex command. This
patch uses masking to limit any speculative futex operations to within
the user address space.
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
commit 15deb080a6087b73089139569558965750e69d67 upstream.
When loadparm is set in reipl parm block, the kernel should also set
DIAG308_FLAGS_LP_VALID flag.
This fixes loadparm ignoring during z/VM fcp -> ccw reipl and kvm direct
boot -> ccw reipl.
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
commit 3a0a397ff5ff8b56ca9f7908b75dee6bf0b5fabb upstream.
Now that we've standardised on SMCCC v1.1 to perform the branch
prediction invalidation, let's drop the previous band-aid.
If vendors haven't updated their firmware to do SMCCC 1.1, they
haven't updated PSCI either, so we don't loose anything.
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Greg Hackmann <ghackmann@google.com>
commit b092201e0020614127f495c092e0a12d26a2116e upstream.
Add the detection and runtime code for ARM_SMCCC_ARCH_WORKAROUND_1.
It is lovely. Really.
commit f72af90c3783d924337624659b43e2d36f1b36b4 upstream.
We want SMCCC_ARCH_WORKAROUND_1 to be fast. As fast as possible.
So let's intercept it as early as we can by testing for the
function call number as soon as we've identified a HVC call
coming from the guest.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 6167ec5c9145cdf493722dfd80a5d48bafc4a18a upstream.
A new feature of SMCCC 1.1 is that it offers firmware-based CPU
workarounds. In particular, SMCCC_ARCH_WORKAROUND_1 provides
BP hardening for CVE-2017-5715.
If the host has some mitigation for this issue, report that
we deal with it using SMCCC_ARCH_WORKAROUND_1, as we apply the
host workaround on every guest exit.
[v4.9: account for files moved to virt/ upstream]
commit a4097b351118e821841941a79ec77d3ce3f1c5d9 upstream.
We're about to need kvm_psci_version in HYP too. So let's turn it
into a static inline, and pass the kvm structure as a second
parameter (so that HYP can do a kern_hyp_va on it).
