git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Eliminate NULL test after alloc_bootmem in iosapic_alloc_rte()
[IA64] Handle count==0 in sn2_ptc_proc_write()
[IA64] Fix boot failure on ia64/sn2
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm
* 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm:
KVM: Remove now unused structs from kvm_para.h
x86: KVM guest: Use the paravirt clocksource structs and functions
KVM: Make kvm host use the paravirt clocksource structs
x86: Make xen use the paravirt clocksource structs and functions
x86: Add structs and functions for paravirt clocksource
KVM: VMX: Fix host msr corruption with preemption enabled
KVM: ioapic: fix lost interrupt when changing a device's irq
KVM: MMU: Fix oops on guest userspace access to guest pagetable
KVM: MMU: large page update_pte issue with non-PAE 32-bit guests (resend)
KVM: MMU: Fix rmap_write_protect() hugepage iteration bug
KVM: close timer injection race window in __vcpu_run
KVM: Fix race between timer migration and vcpu migration
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
xen: remove support for non-PAE 32-bit
This patch updates the kvm host code to use the pvclock structs
and functions, thereby making it compatible with Xen.
The patch also fixes an initialization bug: on SMP systems the
per-cpu has two different locations early at boot and after CPU
bringup. kvmclock must take that in account when registering the
physical address within the host.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
This patch updates the kvm host code to use the pvclock structs.
It also makes the paravirt clock compatible with Xen.
This patch updates the xen guest to use the pvclock structs
and helper functions.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
This patch adds structs for the paravirt clocksource ABI
used by both xen and kvm (pvclock-abi.h).
It also adds some helper functions to read system time and
wall clock time from a paravirtual clocksource (pvclock.[ch]).
They are based on the xen code. They are enabled using
CONFIG_PARAVIRT_CLOCK.
Subsequent patches of this series will put the code in use.
As noted by Akinobu Mita alloc_bootmem and related functions never return
NULL and always return a zeroed region of memory. Thus a NULL test or
memset after calls to these functions is unnecessary.
Signed-off-by: Tony Luck <tony.luck@intel.com>
The fix applied in e0c6d97c65e0784aade7e97b9411f245a6c543e7
"security hole in sn2_ptc_proc_write" didn't take into account
the case where count==0 (which results in a buffer underrun
when adding the trailing '\0'). Thanks to Andi Kleen for
pointing this out.
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Call check_sal_cache_flush() after platform_setup() as
check_sal_cache_flush() now relies on being able to call platform
vector code.
Problem was introduced by: 3463a93def55c309f3c0d0a8aaf216be3be42d64
"Update check_sal_cache_flush to use platform_send_ipi()"
Signed-off-by: Jes Sorensen <jes@sgi.com>
Tested-by: Alex Chiang: <achiang@hp.com>
I can't see any reason to keep these semicolons.
Signed-off-by: WANG Cong <wangcong@zeuux.org>
Non-PAE operation has been deprecated in Xen for a while, and is
rarely tested or used. xen-unstable has now officially dropped
non-PAE support. Since Xen/pvops' non-PAE support has also been
broken for a while, we may as well completely drop it altogether.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Switching msrs can occur either synchronously as a result of calls to
the msr management functions (usually in response to the guest touching
virtualized msrs), or asynchronously when preempting a kvm thread that has
guest state loaded. If we're unlucky enough to have the two at the same
time, host msrs are corrupted and the machine goes kaput on the next syscall.
Most easily triggered by Windows Server 2008, as it does a lot of msr
switching during bootup.
KVM has a heuristic to unshadow guest pagetables when userspace accesses
them, on the assumption that most guests do not allow userspace to access
pagetables directly. Unfortunately, in addition to unshadowing the pagetables,
it also oopses.
This never triggers on ordinary guests since sane OSes will clear the
pagetables before assigning them to userspace, which will trigger the flood
heuristic, unshadowing the pagetables before the first userspace access. One
particular guest, though (Xenner) will run the kernel in userspace, triggering
the oops. Since the heuristic is incorrect in this case, we can simply
remove it.
kvm_mmu_pte_write() does not handle 32-bit non-PAE large page backed
guests properly. It will instantiate two 2MB sptes pointing to the same
physical 2MB page when a guest large pte update is trapped.
Instead of duplicating code to handle this, disallow directory level
updates to happen through kvm_mmu_pte_write(), so the two 2MB sptes
emulating one guest 4MB pte can be correctly created by the page fault
handling path.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
rmap_next() does not work correctly after rmap_remove(), as it expects
the rmap chains not to change during iteration. Fix (for now) by restarting
iteration from the beginning.
If a timer fires after kvm_inject_pending_timer_irqs() but before
local_irq_disable() the code will enter guest mode and only inject such
timer interrupt the next time an unrelated event causes an exit.
It would be simpler if the timer->pending irq conversion could be done
with IRQ's disabled, so that the above problem cannot happen.
For now introduce a new vcpu requests bit to cancel guest entry.
A guest vcpu instance can be scheduled to a different physical CPU
between the test for KVM_REQ_MIGRATE_TIMER and local_irq_disable().
If that happens, the timer will only be migrated to the current pCPU on
the next exit, meaning that guest LAPIC timer event can be delayed until
a host interrupt is triggered.
Fix it by cancelling guest entry if any vcpu request is pending. This
has the side effect of nicely consolidating vcpu->requests checks.
xen: don't drop NX bit
xen: mask unwanted pte bits in __supported_pte_mask
xen: Use wmb instead of rmb in xen_evtchn_do_upcall().
x86: fix NULL pointer deref in __switch_to
[IA64] SN2: security hole in sn2_ptc_proc_write
Which was removed in the hope that generic legacy IDE quirk in
drivers/pci/probe.c is sufficient for Cypress IDE.
It isn't, as this controller has non-standard BAR layout:
secondary channel registers are in the BAR0-1 of the second
PCI function - not in the BAR2-3 of the same function, as the
generic quirk routine assumes.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Vast majority of these build failures are gcc-4.3 warnings
about static functions and objects being referenced from
non-static (read: "extern inline") functions, in conjunction
with our -Werror.
We cannot just convert "extern inline" to "static inline",
as people keep suggesting all the time, because "extern inline"
logic is crucial for generic kernel build.
So
- just make sure that all callees of critical "extern inline"
functions are also "extern inline";
- use "static inline", wherever it's possible.
traps.c: work around gcc-4.3 being too smart about array
bounds-checking.
TODO: add "gnu_inline" attribute to all our "extern inline"
functions to ensure desired behaviour with future compilers.
With built-in scsi disk driver, the final link fails with a following
error:
`.exit.text' referenced in section `.rodata' of drivers/built-in.o:
defined in discarded section `.exit.text' of drivers/built-in.o
This happens with -Os (CONFIG_CC_OPTIMIZE_FOR_SIZE=y) with all gcc-4
versions, and also with -O2 and gcc-4.3.
The problem is in sd.c:sd_major() being inlined into __exit function
exit_sd(), and the compiler generating a jump table in .rodata section
for the 'switch' statement in sd_major(). So we have references to
discarded section.
Fixed with a big hammer in the form of -fno-jump-tables.
Note that jump tables vs. discarded sections is a generic problem,
other architectures are just lucky not to suffer from it. But with
a slightly more complex switch/case statement it can be reproduced
on x86 as well. So maybe at some point we should consider
-fno-jump-tables as a generic compile option...
x86, geode: add a VSA2 ID for General Software
x86: use BOOTMEM_EXCLUSIVE on 32-bit
x86, 32-bit: fix boot failure on TSC-less processors
x86: set PAE PHYSICAL_MASK_SHIFT to 44 bits.
Security hole in sn2_ptc_proc_write
It is possible to overrun a buffer with a write to this /proc file.
KAMEZAWA Hiroyuki and Oleg Nesterov point out that since the commit
557ed1fa2620dc119adb86b34c614e152a629a80 ("remove ZERO_PAGE") removed
the ZERO_PAGE from the VM mappings, any users of get_user_pages() will
generally now populate the VM with real empty pages needlessly.
We used to get the ZERO_PAGE when we did the "handle_mm_fault()", but
since fault handling no longer uses ZERO_PAGE for new anonymous pages,
we now need to handle that special case in follow_page() instead.
In particular, the removal of ZERO_PAGE effectively removed the core
file writing optimization where we would skip writing pages that had not
been populated at all, and increased memory pressure a lot by allocating
all those useless newly zeroed pages.
This reinstates the optimization by making the unmapped PTE case the
same as for a non-existent page table, which already did this correctly.
While at it, this also fixes the XIP case for follow_page(), where the
caller could not differentiate between the case of a page that simply
could not be used (because it had no "struct page" associated with it)
and a page that just wasn't mapped.
We do that by simply returning an error pointer for pages that could not
be turned into a "struct page *". The error is arbitrarily picked to be
EFAULT, since that was what get_user_pages() already used for the
equivalent IO-mapped page case.
[ Also removed an impossible test for pte_offset_map_lock() failing:
that's not how that function works ]
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Roland McGrath <roland@redhat.com>
Because NX is now enforced properly, we must put the hypercall page
into the .text segment so that it is executable.
Cc: Stable Kernel <stable@kernel.org>
Cc: the arch/x86 maintainers <x86@kernel.org>
[ Stable: this isn't a bugfix in itself, but it's a pre-requiste
for "xen: don't drop NX bit" ]
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: "Andi Kleen" <andi@firstfloor.org>
General Software writes their own VSA2 module for their version
of the Geode BIOS, which returns a different ID then the standard
VSA2. This was causing the framebuffer driver to break for most
GSW boards.
Signed-off-by: Jordan Crouse <jordan.crouse@amd.com>
Cc: tglx@linutronix.de
Cc: linux-geode@lists.infradead.org
This patch uses the BOOTMEM_EXCLUSIVE for crashkernel reservation also for
i386 and prints a error message on failure.
The patch is still for 2.6.26 since it is only bug fixing. The unification
of reserve_crashkernel() between i386 and x86_64 should be done for 2.6.27.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <stable@kernel.org>
Booting 2.6.26-rc6 on my 486 DX/4 fails with a "BUG: Int 6"
(invalid opcode) and a kernel halt immediately after the
kernel has been uncompressed. The BUG shows EIP pointing
to an rdtsc instruction in native_read_tsc(), invoked from
native_sched_clock().
(This error occurs so early that not even the serial console
can capture it.)
A bisection showed that this bug first occurs in 2.6.26-rc3-git7,
via commit 9ccc906c97e34fd91dc6aaf5b69b52d824386910:
>x86: distangle user disabled TSC from unstable
>tsc_enabled is set to 0 from the command line switch "notsc" and from
>the mark_tsc_unstable code. Seperate those functionalities and replace
>tsc_enable with tsc_disable. This makes also the native_sched_clock()
>decision when to use TSC understandable.
>Preparatory patch to solve the sched_clock() issue on 32 bit.
The core reason for this bug is that native_sched_clock() gets
called before tsc_init().
Before the commit above, tsc_32.c used a "tsc_enabled" variable
which defaulted to 0 == disabled, and which only got enabled late
in tsc_init(). Thus early calls to native_sched_clock() would skip
the TSC and use jiffies instead.
After the commit above, tsc_32.c uses a "tsc_disabled" variable
which defaults to 0, meaning that the TSC is Ok to use. Early calls
to native_sched_clock() now erroneously try to use the TSC on
!cpu_has_tsc processors, leading to invalid opcode exceptions.
My proposed fix is to initialise tsc_disabled to a "soft disabled"
state distinct from the hard disabled state set up by the "notsc"
kernel option. This fixes the native_sched_clock() problem. It also
allows tsc_init() to be simplified: instead of setting tsc_disabled = 1
on every error return, we just set tsc_disabled = 0 once when all
checks have succeeded.
I've verified that this lets my 486 boot again. I've also verified
that a Core2 machine still uses the TSC as clocksource after the patch.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
Patrick McHardy reported a crash:
> > I get this oops once a day, its apparently triggered by something
> > run by cron, but the process is a different one each time.
> > Kernel is -git from yesterday shortly before the -rc6 release
> > (last commit is the usb-2.6 merge, the x86 patches are missing),
> > .config is attached.
> > I'll retry with current -git, but the patches that have gone in
> > since I last updated don't look related.
> > [62060.043009] BUG: unable to handle kernel NULL pointer dereference at
> > 000001ff
> > [62060.043009] IP: [<c0102a9b>] __switch_to+0x2f/0x118
> > [62060.043009] *pde = 00000000
> > [62060.043009] Oops: 0002 [#1] PREEMPT
Vegard Nossum analyzed it:
> This decodes to
> 0: 0f ae 00 fxsave (%eax)
> so it's related to the floating-point context. This is the exact
> location of the crash:
> $ addr2line -e arch/x86/kernel/process_32.o -i ab0
> include/asm/i387.h:232
> include/asm/i387.h:262
> arch/x86/kernel/process_32.c:595
> ...so it looks like prev_task->thread.xstate->fxsave has become NULL.
> Or maybe it never had any other value.
Somehow (as described below) TS_USEDFPU is set but the fpu is not
allocated or freed.
Another possible FPU pre-emption issue with the sleazy FPU optimization
which was benign before but not so anymore, with the dynamic FPU allocation
patch.
New task is getting exec'd and it is prempted at the below point.
flush_thread() {
* Forget coprocessor state..
clear_fpu(tsk);
<----- Preemption point
clear_used_math();
Now when it context switches in again, as the used_math() is still set
and fpu_counter can be > 5, we will do a math_state_restore() which sets
the task's TS_USEDFPU. After it continues from the above preemption point
it does clear_used_math() and much later free_thread_xstate().
Now, at the next context switch, it is quite possible that xstate is
null, used_math() is not set and TS_USEDFPU is still set. This will
trigger unlazy_fpu() causing kernel oops.
Fix this by clearing tsk's fpu_counter before clearing task's fpu.
Reported-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Before:
total: 22 errors, 8 warnings, 440 lines checked
After:
total: 0 errors, 8 warnings, 442 lines checked
paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/cpufreq-nforce2.o.*
3d4330a5d188fe904446e5948a618b48 /tmp/cpufreq-nforce2.o.after
1477e6b0dcd6f59b1fb6b4490042eca6 /tmp/cpufreq-nforce2.o.before
^^^ I guess this is because I fixed a few "do not initialise statics to 0 or NULL"
paolo@paolo-desktop:~/linux.trees.git$ size /tmp/cpufreq-nforce2.o.*
1923 72 16 2011 7db /tmp/cpufreq-nforce2.o.after
1923 72 16 2011 7db /tmp/cpufreq-nforce2.o.before
Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com>
Before:
total: 6 errors, 1 warnings, 117 lines checked
After:
total: 0 errors, 1 warnings, 117 lines checked
paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/reg_constant.o.*
780388a3056d58fb759efaf190d5d3d1 /tmp/reg_constant.o.after
780388a3056d58fb759efaf190d5d3d1 /tmp/reg_constant.o.before
paolo@paolo-desktop:~/linux.trees.git$ size /tmp/reg_constant.o.*
457 0 0 457 1c9 /tmp/reg_constant.o.after
457 0 0 457 1c9 /tmp/reg_constant.o.before
Before:
total: 6 errors, 13 warnings, 105 lines checked
After:
total: 0 errors, 0 warnings, 105 lines checked
paolo@paolo-desktop:~/linux.trees.git$ size /tmp/k7*
1135 0 0 1135 46f /tmp/k7.o.after
1135 0 0 1135 46f /tmp/k7.o.before
paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/k7*
87b14954045aa37dbaee6fb7e022ed9a /tmp/k7.o.after
87b14954045aa37dbaee6fb7e022ed9a /tmp/k7.o.before
Before:
total: 16 errors, 34 warnings, 257 lines checked
After:
total: 0 errors, 2 warnings, 257 lines checked
No changes in the compiled code:
paolo@paolo-desktop:~/linux.trees.git$ size /tmp/p4*
2644 4 4 2652 a5c /tmp/p4.o.after
2644 4 4 2652 a5c /tmp/p4.o.before
paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/p4*
13f1b21c4246b31a28aaff38184586ca /tmp/p4.o.after
13f1b21c4246b31a28aaff38184586ca /tmp/p4.o.before
When we demote a slice from 64k to 4k, and we are about to insert an
HPTE for a 4k subpage and we notice that there is an existing 64k
HPTE, we first invalidate that HPTE before inserting the new 4k
subpage HPTE. Since the bits that encode which hash bucket the old
HPTE was in overlap with the bits that encode which of the 16 subpages
have HPTEs, we need to clear out the subpage HPTE-present bits before
starting to insert HPTEs for the 4k subpages. If we don't do that, we
can erroneously think that a subpage already has an HPTE when it
doesn't.
That in itself wouldn't be such a problem except that when we go to
update the HPTE that we think is present on machines with a
hypervisor, the hypervisor can tell us that the HPTE we think is there
is actually there even though it isn't, which can lead to a process
getting stuck in a loop, continually faulting. The reason for the
confusion is that the AVPN (abbreviated virtual page number) we are
looking for in the HPTE for a 4k subpage can actually match the AVPN
in a stale HPTE for another 64k page. For example, the HPTE for
the 4k subpage at 0x84000f000 will be in the same hash bucket and have
the same AVPN as the HPTE for the 64k page at 0x8400f0000.
This fixes the code to clear out the subpage HPTE-present bits.
A recent commit added support for the new 440x6 and 464 cores that have the
added WL1, IL1I, IL1D, IL2I, and ILD2 bits for the caching attributes in the
TLBs. The new bits were cleared in the finish_tlb_load function, however a
similar bit of code was missed in the DataStorage interrupt vector.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Most users by far do not care about the exact return value (they only
really care about whether the copy succeeded in its entirety or not),
but a few special core routines actually care deeply about exactly how
many bytes were copied from user space.
And the unrolled versions of the x86-64 user copy routines would
sometimes report that it had copied more bytes than it actually had.
Very few uses actually have partial copies to begin with, but to make
this bug even harder to trigger, most x86 CPU's use the "rep string"
instructions for normal user copies, and that version didn't have this
issue.
To make it even harder to hit, the one user of this that really cared
about the return value (and used the uncached version of the copy that
doesn't use the "rep string" instructions) was the generic write
routine, which pre-populated its source, once more hiding the problem by
avoiding the exception case that triggers the bug.
In other words, very special thanks to Bron Gondwana who not only
triggered this, but created a test-program to show it, and bisected the
behavior down to commit 08291429cfa6258c4cd95d8833beb40f828b194e ("mm:
fix pagecache write deadlocks") which changed the access pattern just
enough that you can now trigger it with 'writev()' with multiple
iovec's.
That commit itself was not the cause of the bug, it just allowed all the
stars to align just right that you could trigger the problem.
[ Side note: this is just the minimal fix to make the copy routines
(with __copy_from_user_inatomic_nocache as the particular version that
was involved in showing this) have the right return values.
We really should improve on the exceptional case further - to make the
copy do a byte-accurate copy up to the exact page limit that causes it
to fail. As it is, the callers have to do extra work to handle the
limit case gracefully. ]
Reported-by: Bron Gondwana <brong@fastmail.fm>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
(which didn't have this problem), and since
most users that do the carethis was very hard to trigger, but
[IA64] Fix CONFIG_IA64_SGI_UV build error
[IA64] Update check_sal_cache_flush to use platform_send_ipi()
[IA64] perfmon: fix async exit bug
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (21 commits)
[POWERPC] Turn on ATA_SFF so we get SATA_SVW back in defconfigs
[POWERPC] Remove ppc32's export of console_drivers
[POWERPC] Fix -Os kernel builds with newer gcc versions
[POWERPC] Fix bootwrapper builds with newer gcc versions
[POWERPC] Build fix for drivers/macintosh/mediabay.c
[POWERPC] Fix warning in pseries/eeh_driver.c
[POWERPC] Add missing of_node_put in drivers/macintosh/therm_adt746x.c
[POWERPC] Add missing of_node_put in drivers/macintosh/smu.c
[POWERPC] Add missing of_node_put in pseries/nvram.c
[POWERPC] Fix return value check logic in debugfs virq_mapping setup
[POWERPC] Fix rmb to order cacheable vs. noncacheable
powerpc/spufs: fix missed stop-and-signal event
powerpc/spufs: synchronize interaction between spu exception handling and time slicing
powerpc/spufs: remove class_0_dsisr from spu exception handling
powerpc/spufs: wait for stable spu status in spu_stopped()
[POWERPC] bootwrapper: add simpleImage* to list of boot targets
[POWERPC] 83xx: MPC837xRDB's VSC7385 ethernet switch isn't on the MDIO bus
[POWERPC] Updated Freescale PPC defconfigs
[POWERPC] 8610: Update defconfig for MPC8610 HPCD
[POWERPC] 85xx: MPC8548CDS - Fix size of PCIe IO space
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Au1200: MMC resource size off by one
[MIPS] TANBAC: Update defconfig
[MIPS] Vr41xx: Initialize PCI io_map_base
[MIPS] Malta: Always compile MTD platform device registration code.
[MIPS] Malta: Fix build errors for 64-bit kernels
[MIPS] Lasat: sysctl fixup
[MIPS] Fix buggy use of kmap_coherent.
[MIPS] Lasat: bring back from the dead
[MIPS] vpe_id is required for VSMP and SMTC builds
[MIPS] Export smp_call_function and smp_call_function_single.
[MIPS] Bring the SWARM defconfig up to date
[MIPS] Sibyte: Build RTC support as an object
[MIPS] Fix the fix for divide by zero error in build_{clear,copy}_page
[MIPS] Fix build for PNX platforms.
[MIPS] Add RM200 with R5000 CPU to known ARC machines
[MIPS] Better load address for big endian SNI RM
[MIPS] SB1250: Initialize io_map_base
[MIPS] Alchemy: Add au1500 reserved interrupt
[MIPS] Export empty_zero_page for sake of the ext4 module.
Kill linux/a.out.h inclusions in the MN10300 arch code.
Fix build error in CONFIG_IA64_SGI_UV config. (GENERIC builds
are ok).
Signed-off-by: Jack Steiner <steiner@sgi.com>
Au12x0 MMC platform device strangely claims 0x41 bytes for its
memory-mapped registers. Make it claim the whole 0x80000 instead according
to the memory map given in the datasheets.
These boards need cca setup on CMDLINE.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
