commit dd14be92fbf5bc1ef7343f34968440e44e21b46a upstream.
Instead of having two functions for cycling through the E820 map in
order to count to be remapped pages and remap them later, just use one
function with a caller supplied sub-function called for each region to
be processed. This eliminates the possibility of a mismatch between
both loops which showed up in certain configurations.
Suggested-by: Ed Swierk <eswierk@skyportsystems.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 5a0cdbfd17b90a89c64a71d8aec9773ecdb20d0d upstream.
The function eeh_pe_reset_and_recover() is used to recover EEH
error when the passthrou device are transferred to guest and
backwards. The content in the device's config space will be lost
on PE reset issued in the middle of the recovery. The function
saves/restores it before/after the reset. However, config access
to some adapters like Broadcom BCM5719 at this point will causes
fenced PHB. The config space is always blocked and we save 0xFF's
that are restored at late point. The memory BARs are totally
corrupted, causing another EEH error upon access to one of the
memory BARs.
This restores the config space on those adapters like BCM5719
from the content saved to the EEH device when it's populated,
to resolve above issue.
Fixes: 5cfb20b9 ("powerpc/eeh: Emulate EEH recovery for VFIO devices")
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Reviewed-by: Russell Currey <ruscur@russell.cc>
commit c2078d9ef600bdbe568c89e5ddc2c6f15b7982c8 upstream.
This reverts commit 89a51df5ab1d38b257300b8ac940bbac3bb0eb9b.
The function eeh_add_device_early() is used to perform EEH
initialization in devices added later on the system, like in
hotplug/DLPAR scenarios. Since the commit 89a51df5ab1d ("powerpc/eeh:
Fix crash in eeh_add_device_early() on Cell") a new check was introduced
in this function - Cell has no EEH capabilities which led to kernel oops
if hotplug was performed, so checking for eeh_enabled() was introduced
to avoid the issue.
However, in architectures that EEH is present like pSeries or PowerNV,
we might reach a case in which no PCI devices are present on boot time
and so EEH is not initialized. Then, if a device is added via DLPAR for
example, eeh_add_device_early() fails because eeh_enabled() is false,
and EEH end up not being enabled at all.
This reverts the aforementioned patch since a new verification was
introduced by the commit d91dafc02f42 ("powerpc/eeh: Delay probing EEH
device during hotplug") and so the original Cell issue does not happen
anymore.
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
commit affeb0f2d3a9af419ad7ef4ac782e1540b2f7b28 upstream.
error when the passthrough device are transferred to guest and
backwards, meaning the device's driver is vfio-pci or none.
When the driver is vfio-pci that provides error_detected() error
handler only, the handler simply stops the guest and it's not
expected behaviour. On the other hand, no error handlers will
be called if we don't have a bound driver.
This ignores the error handler in eeh_pe_reset_and_recover()
that reports the error to device driver to avoid the exceptional
behaviour.
commit 8ed8ab40047a570fdd8043a40c104a57248dd3fd upstream.
Some of the interrupt vectors on 64-bit POWER server processors are only
32 bytes long (8 instructions), which is not enough for the full
first-level interrupt handler. For these we need to branch to an
out-of-line (OOL) handler. But when we are running a relocatable kernel,
interrupt vectors till __end_interrupts marker are copied down to real
address 0x100. So, branching to labels (ie. OOL handlers) outside this
section must be handled differently (see LOAD_HANDLER()), considering
relocatable kernel, which would need at least 4 instructions.
However, branching from interrupt vector means that we corrupt the
CFAR (come-from address register) on POWER7 and later processors as
mentioned in commit 1707dd16. So, EXCEPTION_PROLOG_0 (6 instructions)
that contains the part up to the point where the CFAR is saved in the
PACA should be part of the short interrupt vectors before we branch out
to OOL handlers.
But as mentioned already, there are interrupt vectors on 64-bit POWER
server processors that are only 32 bytes long (like vectors 0x4f00,
0x4f20, etc.), which cannot accomodate the above two cases at the same
time owing to space constraint. Currently, in these interrupt vectors,
we simply branch out to OOL handlers, without using LOAD_HANDLER(),
which leaves us vulnerable when running a relocatable kernel (eg. kdump
case). While this has been the case for sometime now and kdump is used
widely, we were fortunate not to see any problems so far, for three
reasons:
1. In almost all cases, production kernel (relocatable) is used for
kdump as well, which would mean that crashed kernel's OOL handler
would be at the same place where we end up branching to, from short
interrupt vector of kdump kernel.
2. Also, OOL handler was unlikely the reason for crash in almost all
the kdump scenarios, which meant we had a sane OOL handler from
crashed kernel that we branched to.
3. On most 64-bit POWER server processors, page size is large enough
that marking interrupt vector code as executable (see commit
429d2e83) leads to marking OOL handler code from crashed kernel,
that sits right below interrupt vector code from kdump kernel, as
executable as well.
Let us fix this by moving the __end_interrupts marker down past OOL
handlers to make sure that we also copy OOL handlers to real address
0x100 when running a relocatable kernel.
This fix has been tested successfully in kdump scenario, on an LPAR with
4K page size by using different default/production kernel and kdump
kernel.
Also tested by manually corrupting the OOL handlers in the first kernel
and then kdump'ing, and then causing the OOL handlers to fire - mpe.
Fixes: c1fb6816fb1b ("powerpc: Add relocation on exception vector handlers")
Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com>
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 330d12764e15f6e3e94ff34cda29db96d2589c24 upstream.
MAX8997 PMIC requires interrupt and fails probing without it.
Fixes: d105f0b1215d ("ARM: dts: Add basic dts file for Samsung Trats board")
[k.kozlowski: Write commit message, add CC-stable]
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit b1f3a3b03eb5f61b4051e2da9aa15653e705e111 upstream.
Fix a typo on PIN_PD24 for UTXD2 and FLEXCOM4_IO3 which were
wrongly linked to PIN_PD23).
Signed-off-by: Florian Vallee <fvallee@eukrea.fr>
Fixes: 7f16cb676c00 ("ARM: at91/dt: add sama5d2 pinmux")
[nicolas.ferre@atmel.com: add commit message, changed subject]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 9800917cf92f5b5fe5cae706cb70db8d014f663c upstream.
Some of the GPIO configs were wrong in the submitted DTS files,
this patch fixes all affected boards.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 94cc36b84acc29f543b48bc5ed786011b112a666 upstream.
Avoid an aliasing issue causing a build error in VDSO:
In file included from include/linux/srcu.h:34:0,
from include/linux/notifier.h:15,
from ./arch/mips/include/asm/uprobes.h:9,
from include/linux/uprobes.h:61,
from include/linux/mm_types.h:13,
from ./arch/mips/include/asm/vdso.h:14,
from arch/mips/vdso/vdso.h:27,
from arch/mips/vdso/gettimeofday.c:11:
include/linux/workqueue.h: In function 'work_static':
include/linux/workqueue.h:186:2: error: dereferencing type-punned pointer will break strict-aliasing rules [-Werror=strict-aliasing]
return *work_data_bits(work) & WORK_STRUCT_STATIC;
cc1: all warnings being treated as errors
make[2]: *** [arch/mips/vdso/gettimeofday.o] Error 1
with a CONFIG_DEBUG_OBJECTS_WORK configuration and GCC 5.2.0. Include
`-fno-strict-aliasing' along with compiler options used, as required for
kernel code, fixing a problem present since the introduction of VDSO
with commit ebb5e78cc634 ("MIPS: Initial implementation of a VDSO").
Thanks to Tejun for diagnosing this properly!
Signed-off-by: Maciej W. Rozycki <macro@imgtec.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Cc: Tejun Heo <tj@kernel.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/13357/
commit aedcfbe06558a9f53002e82d5be64c6c94687726 upstream.
On certain MIPS32 devices, the ftrace tracer "function_graph" uses
__lshrdi3() during the capturing of trace data. ftrace then attempts to
trace __lshrdi3() which leads to infinite recursion and a stack overflow.
Fix this by marking __lshrdi3() as notrace. Mark the other compiler
intrinsics as notrace in case the compiler decides to use them in the
ftrace path.
Signed-off-by: Harvey Hunt <harvey.hunt@imgtec.com>
Cc: <linux-mips@linux-mips.org>
Cc: <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/13354/
commit bb93078e655be1e24d68f28f2756676e62c037ce upstream.
MicroMIPS kernels may be expected to run on microMIPS only cores which
don't support the normal MIPS instruction set, so be sure to pass the
-mmicromips flag through to the VDSO cflags.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13349/
commit 13eb192d10bcc9ac518d57356179071d603bcb4e upstream.
In microMIPS kernels, handle_signal() sets the isa16 mode bit in the
vdso address so that the sigreturn trampolines (which are offset from
the VDSO) get executed as microMIPS.
However commit ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
changed the offsets to come from the VDSO image, which already have the
isa16 mode bit set correctly since they're extracted from the VDSO
shared library symbol table.
Drop the isa16 mode bit handling from handle_signal() to fix sigreturn
for cores which support both microMIPS and normal MIPS. This doesn't fix
microMIPS only cores, since the VDSO is still built for normal MIPS, but
thats a separate problem.
Patchwork: https://patchwork.linux-mips.org/patch/13348/
commit abf378be49f38c4d3e23581d3df3fa9f1b1b11d2 upstream.
Correct the cases missed with commit 9b26616c8d9d ("MIPS: Respect the
ISA level in FCSR handling") and prevent writes to read-only FCSR bits
there.
This in particular applies to FP context initialisation where any IEEE
754-2008 bits preset by `mips_set_personality_nan' are cleared before
the relevant ptrace(2) call takes effect and the PTRACE_POKEUSR request
addressing FPC_CSR where no masking of read-only FCSR bits is done.
Remove the FCSR clearing from FP context initialisation then and unify
PTRACE_POKEUSR/FPC_CSR and PTRACE_SETFPREGS handling, by factoring out
code from `ptrace_setfpregs' and calling it from both places.
This mostly matters to soft float configurations where the emulator can
be switched this way to a mode which should not be accessible and cannot
be set with the CTC1 instruction. With hard float configurations any
effect is transient anyway as read-only bits will retain their values at
the time the FP context is restored.
Patchwork: https://patchwork.linux-mips.org/patch/13239/
commit 4249548454f7ba4581aeee26bd83f42b48a14d15 upstream.
Fix a floating-point context restoration regression introduced with
commit 9b26616c8d9d ("MIPS: Respect the ISA level in FCSR handling")
that causes a Floating Point exception and consequently a kernel oops
with hard float configurations when one or more FCSR Enable and their
corresponding Cause bits are set both at a time via a ptrace(2) call.
To do so reinstate Cause bit masking originally introduced with commit
b1442d39fac2 ("MIPS: Prevent user from setting FCSR cause bits") to
address this exact problem and then inadvertently removed from the
PTRACE_SETFPREGS request with the commit referred above.
Patchwork: https://patchwork.linux-mips.org/patch/13238/
commit bd239f1e1429e7781096bf3884bdb1b2b1bb4f28 upstream.
Whilst a PR_SET_FP_MODE prctl is performed there are decisions made
based upon whether the task is executing on the current CPU. This may
change if we're preempted, so disable preemption to avoid such changes
for the lifetime of the mode switch.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Reviewed-by: Maciej W. Rozycki <macro@imgtec.com>
Tested-by: Aurelien Jarno <aurelien@aurel32.net>
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13144/
commit 6533af4d4831c421cd9aa4dce7cfc19a3514cc09 upstream.
If a kernel doesn't support MSA context (ie. CONFIG_CPU_HAS_MSA=n) then
it will only keep 64 bits per FP register in thread context, and the
calls to set_fpr64 in restore_msa_extcontext will overrun the end of the
FP register context into the FCSR & MSACSR values. GCC 6.x has become
smart enough to detect this & complain like so:
arch/mips/kernel/signal.c: In function 'protected_restore_fp_context':
./arch/mips/include/asm/processor.h:114:17: error: array subscript is above array bounds [-Werror=array-bounds]
fpr->val##width[FPR_IDX(width, idx)] = val; \
./arch/mips/include/asm/processor.h:118:1: note: in expansion of macro 'BUILD_FPR_ACCESS'
BUILD_FPR_ACCESS(64)
The only way to trigger this code to run would be for a program to set
up an artificial extended MSA context structure following a sigframe &
execute sigreturn. Whilst this doesn't allow a program to write to any
state that it couldn't already, it makes little sense to allow this
"restoration" of MSA context in a system that doesn't support MSA.
Fix this by killing a program with SIGSYS if it tries something as crazy
as "restoring" fake MSA context in this way, also fixing the build error
& allowing for most of restore_msa_extcontext to be optimised out of
kernels without support for MSA.
Reported-by: Michal Toman <michal.toman@imgtec.com>
Fixes: bf82cb30c7e5 ("MIPS: Save MSA extended context around signals")
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Michal Toman <michal.toman@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13164/
commit ea1688573426adc2587ed52d086b51c7c62eaca3 upstream.
The MSA ld_*/st_* assembler macros for when the toolchain doesn't
support MSA use addu to offset the base address. However it is a virtual
memory pointer so fix it to use PTR_ADDU which expands to daddu for
64-bit kernels.
Patchwork: https://patchwork.linux-mips.org/patch/13062/
commit 8a3c8b48aca8771bff3536e40aa26ffb311699d1 upstream.
In revision 1.12 of the MSA specification, the copy_u.w instruction has
been removed for MIPS32 & the copy_u.d instruction has been removed for
MIPS64. Newer toolchains (eg. Codescape SDK essentials 2015.10) will
complain about this like so:
arch/mips/kernel/r4k_fpu.S:290: Error: opcode not supported on this
processor: mips32r2 (mips32r2) `copy_u.w $1,$w26[3]'
Since we always copy to the width of a GPR, simply use copy_s instead of
copy_u to fix this.
Patchwork: https://patchwork.linux-mips.org/patch/13061/
commit 3484de7bcbed20ecbf2b8d80671619e7059e2dd7 upstream.
Due to datasheet, reserving 0xff800000~0xffffffff (8MB below 4GB) is
not enough for RS780E integrated GPU's TOM (top of memory) registers
and MSI/MSI-x memory region, so we reserve 0xfe000000~0xffffffff (32MB
below 4GB).
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Steven J . Hill <sjhill@realitydiluted.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/12889/
commit a95d069204e178f18476f5499abab0d0d9cbc32c upstream.
After commit 92923ca3aacef63c92d ("mm: meminit: only set page reserved
in the memblock region"), the MIPS hibernation is broken. Because pages
in nosave data section should be "reserved", but currently they aren't
set to "reserved" at initialization. This patch makes hibernation work
again.
Patchwork: https://patchwork.linux-mips.org/patch/12888/
commit f5b556c94c8490d42fea79d7b4ae0ecbc291e69d upstream.
This makes the ath79 bootconsole behave the same way as the generic 8250
bootconsole.
Also waiting for TEMT (transmit buffer is empty) instead of just THRE
(transmit buffer is not full) ensures that all characters have been
transmitted before the real serial driver starts reconfiguring the serial
controller (which would sometimes result in garbage being transmitted.)
This change does not cause a visible performance loss.
In addition, this seems to fix a hang observed in certain configurations on
many AR7xxx/AR9xxx SoCs during autoconfig of the real serial driver.
A more complete follow-up patch will disable 8250 autoconfig for ath79
altogether (the serial controller is detected as a 16550A, which is not
fully compatible with the ath79 serial, and the autoconfig may lead to
undefined behavior on ath79.)
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
commit 37d22a0d798b5c938b277d32cfd86dc231381342 upstream.
It's possible for pages to become visible prior to update_mmu_cache
running if a thread within the same address space preempts the current
thread or runs simultaneously on another CPU. That is, the following
scenario is possible:
CPU0 CPU1
write to page
flush_dcache_page
flush_icache_page
set_pte_at
map page
update_mmu_cache
If CPU1 maps the page in between CPU0's set_pte_at, which marks it valid
& visible, and update_mmu_cache where the dcache flush occurs then CPU1s
icache will fill from stale data (unless it fills from the dcache, in
which case all is good, but most MIPS CPUs don't have this property).
Commit 4d46a67a3eb8 ("MIPS: Fix race condition in lazy cache flushing.")
attempted to fix that by performing the dcache flush in
flush_icache_page such that it occurs before the set_pte_at call makes
the page visible. However it has the problem that not all code that
writes to pages exposed to userland call flush_icache_page. There are
many callers of set_pte_at under mm/ and only 2 of them do call
flush_icache_page. Thus the race window between a page becoming visible
& being coherent between the icache & dcache remains open in some cases.
To illustrate some of the cases, a WARN was added to __update_cache with
this patch applied that triggered in cases where a page about to be
flushed from the dcache was not the last page provided to
flush_icache_page. That is, backtraces were obtained for cases in which
the race window is left open without this patch. The 2 standout examples
follow.
When forking a process:
[ 15.271842] [<80417630>] __update_cache+0xcc/0x188
[ 15.277274] [<80530394>] copy_page_range+0x56c/0x6ac
[ 15.282861] [<8042936c>] copy_process.part.54+0xd40/0x17ac
[ 15.289028] [<80429f80>] do_fork+0xe4/0x420
[ 15.293747] [<80413808>] handle_sys+0x128/0x14c
When exec'ing an ELF binary:
[ 14.445964] [<80417630>] __update_cache+0xcc/0x188
[ 14.451369] [<80538d88>] move_page_tables+0x414/0x498
[ 14.457075] [<8055d848>] setup_arg_pages+0x220/0x318
[ 14.462685] [<805b0f38>] load_elf_binary+0x530/0x12a0
[ 14.468374] [<8055ec3c>] search_binary_handler+0xbc/0x214
[ 14.474444] [<8055f6c0>] do_execveat_common+0x43c/0x67c
[ 14.480324] [<8055f938>] do_execve+0x38/0x44
[ 14.485137] [<80413808>] handle_sys+0x128/0x14c
These code paths write into a page, call flush_dcache_page then call
set_pte_at without flush_icache_page inbetween. The end result is that
the icache can become corrupted & userland processes may execute
unexpected or invalid code, typically resulting in a reserved
instruction exception, a trap or a segfault.
Fix this race condition fully by performing any cache maintenance
required to keep the icache & dcache in sync in set_pte_at, before the
page is made valid. This has the added bonus of ensuring the cache
maintenance always happens in one location, rather than being duplicated
in flush_icache_page & update_mmu_cache. It also matches the way other
architectures solve the same problem (see arm, ia64 & powerpc).
Reported-by: Ionela Voinescu <ionela.voinescu@imgtec.com>
Cc: Lars Persson <lars.persson@axis.com>
Fixes: 4d46a67a3eb8 ("MIPS: Fix race condition in lazy cache flushing.")
Cc: Steven J. Hill <sjhill@realitydiluted.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/12722/
commit f4281bba818105c7c91799abe40bc05c0dbdaa25 upstream.
The following patch will expose __update_cache to highmem pages. Handle
them by mapping them in for the duration of the cache maintenance, just
like in __flush_dcache_page. The code for that isn't shared because we
need the page address in __update_cache so sharing became messy. Given
that the entirity is an extra 5 lines, just duplicate it.
Patchwork: https://patchwork.linux-mips.org/patch/12721/
commit 234859e49a15323cf1b2331bdde7f658c4cb45fb upstream.
When flush_dcache_page is called on an executable page, that page is
about to be provided to userland & we can presume that the icache
contains no valid entries for its address range. However if the icache
does not fill from the dcache then we cannot presume that the pages
content has been written back as far as the memories that the dcache
will fill from (ie. L2 or further out).
This was being done for lowmem pages, but not for highmem which can lead
to icache corruption. Fix this by mapping highmem pages & flushing their
content from the dcache in __flush_dcache_page before providing the page
to userland, just as is done for lowmem pages.
Patchwork: https://patchwork.linux-mips.org/patch/12720/
commit a7e89326b415b5d81c4b1016fd4a40db861eb58d upstream.
Commit f51246efee2b ("MIPS: Get rid of finish_arch_switch().") moved the
__restore_watch() call from finish_arch_switch() (i.e. after resume()
returns) to before the resume() call in switch_to(). This results in
watchpoints only being restored when a task is descheduled, preventing
the watchpoints from being effective most of the time, except due to
chance before the watchpoints are lazily removed.
Fix the call sequence from switch_to() through to
mips_install_watch_registers() to pass the task_struct pointer of the
next task, instead of using current. This allows the watchpoints for the
next (non-current) task to be restored without reintroducing
Fixes: f51246efee2b ("MIPS: Get rid of finish_arch_switch().")
Patchwork: https://patchwork.linux-mips.org/patch/12726/
commit 987e5b834467c9251ca584febda65ef8f66351a9 upstream.
Since commit 8cb48fe169dd ("MIPS: Provide correct siginfo_t.si_stime"),
MIPS' uapi/asm/siginfo.h has included uapi/asm-generic/siginfo.h
directly before defining MIPS' struct siginfo, in order to get the
necessary definitions needed for the siginfo struct without the generic
copy_siginfo() hitting compiler errors due to struct siginfo not yet
being defined.
Now that the generic copy_siginfo() is moved out to linux/signal.h we
can safely include asm-generic/siginfo.h before defining the MIPS
specific struct siginfo, which avoids the uapi/ include as well as
breakage due to generic copy_siginfo() being defined before struct
siginfo.
Reported-by: Christopher Ferris <cferris@google.com>
Fixes: 8cb48fe169dd ("MIPS: Provide correct siginfo_t.si_stime")
Cc: Petr Malat <oss@malat.biz>
commit 5daebc477da4dfeb31ae193d83084def58fd2697 upstream.
Commit 85efde6f4e0d ("make exported headers use strict posix types")
changed the asm-generic siginfo.h to use the __kernel_* types, and
commit 3a471cbc081b ("remove __KERNEL_STRICT_NAMES") make the internal
types accessible only to the kernel, but the MIPS implementation hasn't
been updated to match.
Switch to proper types now so that the exported asm/siginfo.h won't
produce quite so many compiler errors when included alone by a user
program.
Cc: Christopher Ferris <cferris@google.com>
Patchwork: https://patchwork.linux-mips.org/patch/12477/
commit 81a76d7119f63c359750e4adeff922a31ad1135f upstream.
When showing backtraces in response to traps, for example crashes and
address errors (usually unaligned accesses) when they are set in debugfs
to be reported, unwind_stack will be used if the PC was in the kernel
text address range. However since EVA it is possible for user and kernel
address ranges to overlap, and even without EVA userland can still
trigger an address error by jumping to a KSeg0 address.
Adjust the check to also ensure that it was running in kernel mode. I
don't believe any harm can come of this problem, since unwind_stack() is
sufficiently defensive, however it is only meant for unwinding kernel
code, so to be correct it should use the raw backtracing instead.
Reviewed-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/11701/
(cherry picked from commit d2941a975ac745c607dfb590e92bb30bc352dad9)
commit a816b306c62195b7c43c92cb13330821a96bdc27 upstream.
When unwinding through IRQs and exceptions, the unwinding only continues
if the PC is a kernel text address, however since EVA it is possible for
user and kernel address ranges to overlap, potentially allowing
unwinding to continue to user mode if the user PC happens to be in the
kernel text address range.
Adjust the check to also ensure that the register state from before the
exception is actually running in kernel mode, i.e. !user_mode(regs).
I don't believe any harm can come of this problem, since the PC is only
output, the stack pointer is checked to ensure it resides within the
task's stack page before it is dereferenced in search of the return
address, and the return address register is similarly only output (if
the PC is in a leaf function or the beginning of a non-leaf function).
However unwind_stack() is only meant for unwinding kernel code, so to be
correct the unwind should stop there.
Patchwork: https://patchwork.linux-mips.org/patch/11700/
commit e49d38488515057dba8f0c2ba4cfde5be4a7281f upstream.
Fix a build regression from commit c9017757c532 ("MIPS: init upper 64b
of vector registers when MSA is first used"):
arch/mips/built-in.o: In function `enable_restore_fp_context':
traps.c:(.text+0xbb90): undefined reference to `_init_msa_upper'
traps.c:(.text+0xbb90): relocation truncated to fit: R_MIPS_26 against `_init_msa_upper'
traps.c:(.text+0xbef0): undefined reference to `_init_msa_upper'
traps.c:(.text+0xbef0): relocation truncated to fit: R_MIPS_26 against `_init_msa_upper'
to !CONFIG_CPU_HAS_MSA configurations with older GCC versions, which are
unable to figure out that calls to `_init_msa_upper' are indeed dead.
Of the many ways to tackle this failure choose the approach we have
already taken in `thread_msa_context_live'.
[ralf@linux-mips.org: Drop patch segment to junk file.]
Patchwork: https://patchwork.linux-mips.org/patch/13271/
commit ab4a92e66741b35ca12f8497896bafbe579c28a1 upstream.
When emulating a jalr instruction with rd == $0, the code in
isBranchInstr was incorrectly writing to GPR $0 which should actually
always remain zeroed. This would lead to any further instructions
emulated which use $0 operating on a bogus value until the task is next
context switched, at which point the value of $0 in the task context
would be restored to the correct zero by a store in SAVE_SOME. Fix this
by not writing to rd if it is $0.
Fixes: 102cedc32a6e ("MIPS: microMIPS: Floating point support.")
Cc: Maciej W. Rozycki <macro@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13160/
commit 41fa29e4d8cf4150568a0fe9bb4d62229f9caed5 upstream.
Error recovery pointers for fixups was improperly set as ".word"
which is unsuitable for MIPS64.
Replaced by STR(PTR)
[ralf@linux-mips.org: Apply changes as requested in the review process.]
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Reviewed-by: Markos Chandras <markos.chandras@imgtec.com>
Fixes: b0a668fb2038 ("MIPS: kernel: mips-r2-to-r6-emul: Add R2 emulator for MIPS R6")
Cc: macro@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9911/
commit 702f926067d2a4b28c10a3c41a1172dd62d9e735 upstream.
b4ff8389ed14 is incomplete: relies on nr_legacy_irqs() to get the number
of legacy interrupts when actually nr_legacy_irqs() returns 0 after
probe_8259A(). Use NR_IRQS_LEGACY instead.
Signed-off-by: Stefano Stabellini <sstabellini@kernel.org>
commit 316314cae15fb0e3869b76b468f59a0c83ac3d4e upstream.
This ensures that the guest doesn't see XSAVE extensions
(e.g. xgetbv1 or xsavec) that the host lacks.
Cc: stable@vger.kernel.org
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
[4.5 does have CPUID_D_1_EAX, but earlier kernels don't, so use
the numeric value. This is consistent with other occurrences
of cpuid_mask in arch/x86/kvm/cpuid.c - Paolo]
commit b45bacd2d048f405c7760e5cc9b60dd67708734f upstream.
Writing CP0_Compare clears the timer interrupt pending bit
(CP0_Cause.TI), but this wasn't being done atomically. If a timer
interrupt raced with the write of the guest CP0_Compare, the timer
interrupt could end up being pending even though the new CP0_Compare is
nowhere near CP0_Count.
We were already updating the hrtimer expiry with
kvm_mips_update_hrtimer(), which used both kvm_mips_freeze_hrtimer() and
kvm_mips_resume_hrtimer(). Close the race window by expanding out
kvm_mips_update_hrtimer(), and clearing CP0_Cause.TI and setting
CP0_Compare between the freeze and resume. Since the pending timer
interrupt should not be cleared when CP0_Compare is written via the KVM
user API, an ack argument is added to distinguish the source of the
write.
Fixes: e30492bbe95a ("MIPS: KVM: Rewrite count/compare timer emulation")
Cc: "Radim KrÄmář" <rkrcmar@redhat.com>
Cc: kvm@vger.kernel.org
commit 4355c44f063d3de4f072d796604c7f4ba4085cc3 upstream.
There's a particularly narrow and subtle race condition when the
software emulated guest timer is frozen which can allow a guest timer
interrupt to be missed.
This happens due to the hrtimer expiry being inexact, so very
occasionally the freeze time will be after the moment when the emulated
CP0_Count transitions to the same value as CP0_Compare (so an IRQ should
be generated), but before the moment when the hrtimer is due to expire
(so no IRQ is generated). The IRQ won't be generated when the timer is
resumed either, since the resume CP0_Count will already match CP0_Compare.
With VZ guests in particular this is far more likely to happen, since
the soft timer may be frozen frequently in order to restore the timer
state to the hardware guest timer. This happens after 5-10 hours of
guest soak testing, resulting in an overflow in guest kernel timekeeping
calculations, hanging the guest. A more focussed test case to
intentionally hit the race (with the help of a new hypcall to cause the
timer state to migrated between hardware & software) hits the condition
fairly reliably within around 30 seconds.
Instead of relying purely on the inexact hrtimer expiry to determine
whether an IRQ should be generated, read the guest CP0_Compare and
directly check whether the freeze time is before or after it. Only if
CP0_Count is on or after CP0_Compare do we check the hrtimer expiry to
determine whether the last IRQ has already been generated (which will
have pushed back the expiry by one timer period).
commit f24632475d4ffed5626abbfab7ef30a128dd1474 upstream.
Commit d28bc9dd25ce reversed the order of two lines which initialize cr0,
allowing the current (old) cr0 value to mess up vcpu initialization.
This was observed in the checks for cr0 X86_CR0_WP bit in the context of
kvm_mmu_reset_context(). Besides, setting vcpu->arch.cr0 after vmx_set_cr0()
is completely redundant. Change the order back to ensure proper vcpu
initialization.
The combination of booting with ovmf firmware when guest vcpus > 1 and kvm's
ept=N option being set results in a VM-entry failure. This patch fixes that.
Fixes: d28bc9dd25ce ("KVM: x86: INIT and reset sequences are different")
Signed-off-by: Bruce Rogers <brogers@suse.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 9842df62004f366b9fed2423e24df10542ee0dc5 upstream.
MSR 0x2f8 accessed the 124th Variable Range MTRR ever since MTRR support
was introduced by 9ba075a664df ("KVM: MTRR support").
0x2f8 became harmful when 910a6aae4e2e ("KVM: MTRR: exactly define the
size of variable MTRRs") shrinked the array of VR MTRRs from 256 to 8,
which made access to index 124 out of bounds. The surrounding code only
WARNs in this situation, thus the guest gained a limited read/write
access to struct kvm_arch_vcpu.
0x2f8 is not a valid VR MTRR MSR, because KVM has/advertises only 16 VR
MTRR MSRs, 0x200-0x20f. Every VR MTRR is set up using two MSRs, 0x2f8
was treated as a PHYSBASE and 0x2f9 would be its PHYSMASK, but 0x2f9 was
not implemented in KVM, therefore 0x2f8 could never do anything useful
and getting rid of it is safe.
This fixes CVE-2016-3713.
Fixes: 910a6aae4e2e ("KVM: MTRR: exactly define the size of variable MTRRs")
Reported-by: David Matlack <dmatlack@google.com>
Signed-off-by: Andy Honig <ahonig@google.com>
commit e4fe9e7dc3828bf6a5714eb3c55aef6260d823a2 upstream.
The EC field of the constructed ESR is conditionally modified by ORing in
ESR_ELx_EC_DABT_LOW for a data abort. However, ESR_ELx_EC_SHIFT is missing
from this condition.
Signed-off-by: Matt Evans <matt.evans@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit d4b9e0790aa764c0b01e18d4e8d33e93ba36d51f upstream.
The ARM architecture mandates that when changing a page table entry
from a valid entry to another valid entry, an invalid entry is first
written, TLB invalidated, and only then the new entry being written.
The current code doesn't respect this, directly writing the new
entry and only then invalidating TLBs. Let's fix it up.
Reported-by: Christoffer Dall <christoffer.dall@linaro.org>
commit f228b494e56d949be8d8ea09d4f973d1979201bf upstream.
The loop that browses the array compat_hwcap_str will stop when a NULL
is encountered, however NULL is missing at the end of array. This will
lead to overrun until a NULL is found somewhere in the following memory.
In reality, this works out because the compat_hwcap2_str array tends to
follow immediately in memory, and that *is* terminated correctly.
Furthermore, the unsigned int compat_elf_hwcap is checked before
printing each capability, so we end up doing the right thing because
the size of the two arrays is less than 32. Still, this is an obvious
mistake and should be fixed.
Note for backporting: commit 12d11817eaafa414 ("arm64: Move
/proc/cpuinfo handling code") moved this code in v4.4. Prior to that
commit, the same change should be made in arch/arm64/kernel/setup.c.
Fixes: 44b82b7700d0 "arm64: Fix up /proc/cpuinfo"
Signed-off-by: Julien Grall <julien.grall@arm.com>
commit 282aa7051b0169991b34716f0f22d9c2f59c46c4 upstream.
The update to the accessed or dirty states for block mappings must be
done atomically on hardware with support for automatic AF/DBM. The
ptep_set_access_flags() function has been fixed as part of commit
66dbd6e61a52 ("arm64: Implement ptep_set_access_flags() for hardware
AF/DBM"). This patch brings pmdp_set_access_flags() in line with the pte
counterpart.
Fixes: 2f4b829c625e ("arm64: Add support for hardware updates of the access and dirty pte bits")
Reviewed-by: Will Deacon <will.deacon@arm.com>
commit 66dbd6e61a526ae7d11a208238ae2c17e5cacb6b upstream.
When hardware updates of the access and dirty states are enabled, the
default ptep_set_access_flags() implementation based on calling
set_pte_at() directly is potentially racy. This triggers the "racy dirty
state clearing" warning in set_pte_at() because an existing writable PTE
is overridden with a clean entry.
There are two main scenarios for this situation:
1. The CPU getting an access fault does not support hardware updates of
the access/dirty flags. However, a different agent in the system
(e.g. SMMU) can do this, therefore overriding a writable entry with a
clean one could potentially lose the automatically updated dirty
status
2. A more complex situation is possible when all CPUs support hardware
AF/DBM:
a) Initial state: shareable + writable vma and pte_none(pte)
b) Read fault taken by two threads of the same process on different
CPUs
c) CPU0 takes the mmap_sem and proceeds to handling the fault. It
eventually reaches do_set_pte() which sets a writable + clean pte.
CPU0 releases the mmap_sem
d) CPU1 acquires the mmap_sem and proceeds to handle_pte_fault(). The
pte entry it reads is present, writable and clean and it continues
to pte_mkyoung()
e) CPU1 calls ptep_set_access_flags()
If between (d) and (e) the hardware (another CPU) updates the dirty
state (clears PTE_RDONLY), CPU1 will override the PTR_RDONLY bit
marking the entry clean again.
This patch implements an arm64-specific ptep_set_access_flags() function
to perform an atomic update of the PTE flags.
Reported-by: Ming Lei <tom.leiming@gmail.com>
Tested-by: Julien Grall <julien.grall@arm.com>
[will: reworded comment]
commit 5bb1cc0ff9a6b68871970737e6c4c16919928d8b upstream.
Currently, pmd_present() only checks for a non-zero value, returning
true even after pmd_mknotpresent() (which only clears the type bits).
This patch converts pmd_present() to using pte_present(), similar to the
other pmd_*() checks. As a side effect, it will return true for
PROT_NONE mappings, though they are not yet used by the kernel with
transparent huge pages.
For consistency, also change pmd_mknotpresent() to only clear the
PMD_SECT_VALID bit, even though the PMD_TABLE_BIT is already 0 for block
mappings (no functional change). The unused PMD_SECT_PROT_NONE
definition is removed as transparent huge pages use the pte page prot
values.
Fixes: 9c7e535fcc17 ("arm64: mm: Route pmd thp functions through pte equivalents")
commit 911f56eeb87ee378f5e215469268a7a2f68a5a8a upstream.
With hardware AF/DBM support, pmd modifications (transparent huge pages)
should be performed atomically using load/store exclusive. The initial
patches defined the get-and-clear function and __HAVE_ARCH_* macro
without the "huge" word, leaving the pmdp_huge_get_and_clear() to the
default, non-atomic implementation.
commit ab92b232ae05c382c3df0e3d6a5c6d16b639ac8c upstream.
Currently, the PT driver always sets the PMI bit one region (page) before
the STOP region so that we can wake up the consumer before we run out of
room in the buffer and have to disable the event. However, we also need
an interrupt in the last output region, so that we actually get to disable
the event (if no more room from new data is available at that point),
otherwise hardware just quietly refuses to start, but the event is
scheduled in and we end up losing trace data till the event gets removed.
For a cpu-wide event it is even worse since there may not be any
re-scheduling at all and no chance for the ring buffer code to notice
that its buffer is filled up and the event needs to be disabled (so that
the consumer can re-enable it when it finishes reading the data out). In
other words, all the trace data will be lost after the buffer gets filled
up.
This patch makes PT also generate a PMI when the last output region is
full.
Reported-by: Markus Metzger <markus.t.metzger@intel.com>
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: vince@deater.net
Link: http://lkml.kernel.org/r/1462886313-13660-2-git-send-email-alexander.shishkin@linux.intel.com
commit aab0a4c83ceb344d2327194bf354820e50607af6 upstream.
The memory range assigned to the PMC (Power Management Controller) was
not including the PMC_PCR register which are used to control peripheral
clocks.
This was working fine thanks to the page granularity of ioremap(), but
started to fail when we switched to syscon/regmap, because regmap is
making sure that all accesses are falling into the reserved range.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reported-by: Richard Genoud <richard.genoud@gmail.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
Fixes: 863a81c3be1d ("clk: at91: make use of syscon to share PMC registers in several drivers")
commit 723cacbd9dc79582e562c123a0bacf8bfc69e72a upstream.
There is a race with multi-threaded applications between context switch and
pagetable upgrade. In switch_mm() a new user_asce is built from mm->pgd and
mm->context.asce_bits, w/o holding any locks. A concurrent mmap with a
pagetable upgrade on another thread in crst_table_upgrade() could already
have set new asce_bits, but not yet the new mm->pgd. This would result in a
corrupt user_asce in switch_mm(), and eventually in a kernel panic from a
translation exception.
Fix this by storing the complete asce instead of just the asce_bits, which
can then be read atomically from switch_mm(), so that it either sees the
old value or the new value, but no mixture. Both cases are OK. Having the
old value would result in a page fault on access to the higher level memory,
but the fault handler would see the new mm->pgd, if it was a valid access
after the mmap on the other thread has completed. So as worst-case scenario
we would have a page fault loop for the racing thread until the next time
slice.
Also remove dead code and simplify the upgrade/downgrade path, there are no
upgrades from 2 levels, and only downgrades from 3 levels for compat tasks.
There are also no concurrent upgrades, because the mmap_sem is held with
down_write() in do_mmap, so the flush and table checks during upgrade can
be removed.
Reported-by: Michael Munday <munday@ca.ibm.com>
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit a21211672c9a1d730a39aa65d4a5b3414700adfb upstream.
There are several reports of freeze on enabling HWP (Hardware PStates)
feature on Skylake-based systems by the Intel P-states driver. The root
cause is identified as the HWP interrupts causing BIOS code to freeze.
HWP interrupts use the thermal LVT which can be handled by Linux
natively, but on the affected Skylake-based systems SMM will respond
to it by default. This is a problem for several reasons:
- On the affected systems the SMM thermal LVT handler is broken (it
will crash when invoked) and a BIOS update is necessary to fix it.
- With thermal interrupt handled in SMM we lose all of the reporting
features of the arch/x86/kernel/cpu/mcheck/therm_throt driver.
- Some thermal drivers like x86-package-temp depend on the thermal
threshold interrupts signaled via the thermal LVT.
- The HWP interrupts are useful for debugging and tuning
performance (if the kernel can handle them).
The native handling of thermal interrupts needs to be enabled
because of that.
This requires some way to tell SMM that the OS can handle thermal
interrupts. That can be done by using _OSC/_PDC in processor
scope very early during ACPI initialization.
The meaning of _OSC/_PDC bit 12 in processor scope is whether or
not the OS supports native handling of interrupts for Collaborative
Processor Performance Control (CPPC) notifications. Since on
HWP-capable systems CPPC is a firmware interface to HWP, setting
this bit effectively tells the firmware that the OS will handle
thermal interrupts natively going forward.
For details on _OSC/_PDC refer to:
http://www.intel.com/content/www/us/en/standards/processor-vendor-specific-acpi-specification.html
To implement the _OSC/_PDC handshake as described, introduce a new
function, acpi_early_processor_osc(), that walks the ACPI
namespace looking for ACPI processor objects and invokes _OSC for
them with bit 12 in the capabilities buffer set and terminates the
namespace walk on the first success.
Also modify intel_thermal_interrupt() to clear HWP status bits in
the HWP_STATUS MSR to acknowledge HWP interrupts (which prevents
them from firing continuously).
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
[ rjw: Subject & changelog, function rename ]
commit b4c112114aab9aff5ed4568ca5e662bb02cdfe74 upstream.
In create_zero_mask() we have:
addi %1,%2,-1
andc %1,%1,%2
popcntd %0,%1
using the "r" constraint for %2. r0 is a valid register in the "r" set,
but addi X,r0,X turns it into an li:
li r7,-1
andc r7,r7,r0
popcntd r4,r7
Fix this by using the "b" constraint, for which r0 is not a valid
register.
This was found with a kernel build using gcc trunk, narrowed down to
when -frename-registers was enabled at -O2. It is just luck however
that we aren't seeing this on older toolchains.
Thanks to Segher for working with me to find this issue.
Fixes: d0cebfa650a0 ("powerpc: word-at-a-time optimization for 64-bit Little Endian")
