commit bed9a31527af8ff3dfbad62a1a42815cef4baab7 upstream.
On a box with 8TB of RAM the MMU hashtable is 64GB in size. That
means we have 4G PTEs. pSeries_lpar_hptab_clear was using a signed
int to store the index which will overflow at 2G.
Acked-by: Michael Neuling <mikey@neuling.org>
commit 966728dd88b4026ec58fee169ccceaeaf56ef120 upstream.
I have a box that fails in OF during boot with:
DEFAULT CATCH!, exception-handler=fff00400
at %SRR0: 49424d2c4c6f6768 %SRR1: 800000004000b002
ie "IBM,Logh". OF got corrupted with a device tree string.
Looking at make_room and alloc_up, we claim the first chunk (1 MB)
but we never claim any more. mem_end is always set to alloc_top
which is the top of our available address space, guaranteeing we will
never call alloc_up and claim more memory.
Also alloc_up wasn't setting alloc_bottom to the bottom of the
available address space.
This doesn't help the box to boot, but we at least fail with
an obvious error. We could relocate the device tree in a future
patch.
commit 21c5977a836e399fc710ff2c5367845ed5c2527f upstream.
Fix several security issues in Alpha-specific syscalls. Untested, but
mostly trivial.
1. Signedness issue in osf_getdomainname allows copying out-of-bounds
kernel memory to userland.
2. Signedness issue in osf_sysinfo allows copying large amounts of
3. Typo (?) in osf_getsysinfo bounds minimum instead of maximum copy
size, allowing copying large amounts of kernel memory to userland.
4. Usage of user pointer in osf_wait4 while under KERNEL_DS allows
privilege escalation via writing return value of sys_wait4 to kernel
memory.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
(imported from commit v2.6.37-rc5-64-gf1c1807)
commit 995bd3bb5 (x86: Hpet: Avoid the comparator readback penalty)
chose 8 HPET cycles as a safe value for the ETIME check, as we had the
confirmation that the posted write to the comparator register is
delayed by two HPET clock cycles on Intel chipsets which showed
readback problems.
After that patch hit mainline we got reports from machines with newer
AMD chipsets which seem to have an even longer delay. See
http://thread.gmane.org/gmane.linux.kernel/1054283 and
http://thread.gmane.org/gmane.linux.kernel/1069458 for further
information.
Boris tried to come up with an ACPI based selection of the minimum
HPET cycles, but this failed on a couple of test machines. And of
course we did not get any useful information from the hardware folks.
For now our only option is to chose a paranoid high and safe value for
the minimum HPET cycles used by the ETIME check. Adjust the minimum ns
value for the HPET clockevent accordingly.
Reported-Bistected-and-Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
LKML-Reference: <alpine.LFD.2.00.1012131222420.2653@localhost6.localdomain6>
Cc: Simon Kirby <sim@hostway.ca>
Cc: Andreas Herrmann <Andreas.Herrmann3@amd.com>
Cc: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
(imported from commit v2.6.36-rc4-167-g995bd3b)
Due to the overly intelligent design of HPETs, we need to workaround
the problem that the compare value which we write is already behind
the actual counter value at the point where the value hits the real
compare register. This happens for two reasons:
1) We read out the counter, add the delta and write the result to the
compare register. When a NMI or SMI hits between the read out and
the write then the counter can be ahead of the event already
2) The write to the compare register is delayed by up to two HPET
cycles in certain chipsets.
We worked around this by reading back the compare register to make
sure that the written value has hit the hardware. For certain ICH9+
chipsets this can require two readouts, as the first one can return
the previous compare register value. That's bad performance wise for
the normal case where the event is far enough in the future.
As we already know that the write can be delayed by up to two cycles
we can avoid the read back of the compare register completely if we
make the decision whether the delta has elapsed already or not based
on the following calculation:
cmp = event - actual_count;
If cmp is less than 8 HPET clock cycles, then we decide that the event
has happened already and return -ETIME. That covers the above #1 and
#2 problems which would cause a wait for HPET wraparound (~306
seconds).
Tested-by: Nix <nix@esperi.org.uk>
Tested-by: Artur Skawina <art.08.09@gmail.com>
Cc: Damien Wyart <damien.wyart@free.fr>
Tested-by: John Drescher <drescherjm@gmail.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Tested-by: Borislav Petkov <borislav.petkov@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <alpine.LFD.2.00.1009151500060.2416@localhost6.localdomain6>
commit 51d33021425e1f905beb4208823146f2fb6517da upstream.
Return -EAGAIN when we get H_BUSY back from the hypervisor. This
makes the hvc console driver retry, avoiding dropped printks.
commit 0d0138ebe24b94065580bd2601f8bb7eb6152f56 upstream.
Prevent an arbitrary kernel read. Check the user pointer with access_ok()
before copying data in.
[akpm@linux-foundation.org: s/EIO/EFAULT/]
Cc: Christian Zankel <chris@zankel.net>
commit 63f21a56f1cc0b800a4c00349c59448f82473d19 upstream.
The existing code it pretty ugly. How about we clean it up even more
like this?
We check for timeout expiry in the outer loop, but we also need to
check it in the inner loop or we can lock up forever waiting for a
CPU to hit real mode.
Signed-off-by: Michael Neuling <mikey@neuling.org>
commit 050438ed5a05b25cdf287f5691e56a58c2606997 upstream.
In kexec jump support, jump back address passed to the kexeced
kernel via function calling ABI, that is, the function call
return address is the jump back entry.
Furthermore, jump back entry == 0 should be used to signal that
the jump back or preserve context is not enabled in the original
kernel.
But in the current implementation the stack position used for
function call return address is not cleared context
preservation is disabled. The patch fixes this bug.
Reported-and-tested-by: Yin Kangkai <kangkai.yin@intel.com>
Signed-off-by: Huang Ying <ying.huang@intel.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Link: http://lkml.kernel.org/r/1310607277-25029-1-git-send-email-ying.huang@intel.com
commit 6c7b3ea52e345ab614edb91d3f0e9f3bb3713871 upstream.
While in sleep mode the CS# and other V3020 RTC GPIOs must be driven
high, otherwise V3020 RTC fails to keep the right time in sleep mode.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit b7798d28ec15d20fd34b70fa57eb13f0cf6d1ecd upstream.
Rebooting on the Dell E5420 often hangs with the keyboard or ACPI
methods, but is reliable via the PCI method.
[ hpa: this was deferred because we believed for a long time that the
recent reshuffling of the boot priorities in commit
660e34cebf0a11d54f2d5dd8838607452355f321 fixed this platform.
Unfortunately that turned out to be incorrect. ]
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Link: http://lkml.kernel.org/r/1305248699-2347-1-git-send-email-daniel.blueman@gmail.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
commit 9daedd833a38edd90cf7baa1b1fcf61c3a0721e3 upstream.
Video input mux settings for tvp7002 and imager inputs were swapped.
Comment was correct.
Tested on EVM with tvp7002 input.
Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk>
Acked-by: Manjunath Hadli <manjunath.hadli@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
commit fb967ecc584c20c74a007de749ca597068b0fcac upstream.
The os-linux/mem.c file calls fchmod function, which is declared in sys/stat.h
header file, so include it. Fixes build breakage under FC13.
Signed-off-by: Liu Aleaxander <Aleaxander@gmail.com>
Acked-by: Boaz Harrosh <bharrosh@panasas.com>
Cc: Jeff Dike <jdike@addtoit.com>
commit aa5fb4dbfd121296ca97c68cf90043a7ea97579d upstream.
With glibc 2.11 or later that was built with --enable-multi-arch, the UML
link fails with undefined references to __rel_iplt_start and similar
symbols. In recent binutils, the default linker script defines these
symbols (see ld --verbose). Fix the UML linker scripts to match the new
defaults for these sections.
Signed-off-by: Roland McGrath <roland@redhat.com>
commit a91d92875ee94e4703fd017ccaadb48cfb344994 upstream.
We only need to set max_pfn_mapped to the last pfn mapped on x86_64 to
make sure that cleanup_highmap doesn't remove important mappings at
_end.
We don't need to do this on x86_32 because cleanup_highmap is not called
on x86_32. Besides lowering max_pfn_mapped on x86_32 has the unwanted
side effect of limiting the amount of memory available for the 1:1
kernel pagetable allocation.
This patch reverts the x86_32 part of the original patch.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 26018874e3584f1658570d41d57d4c34f6a53aa0 upstream.
Some PCIe cards ship with a PCI-PCIe bridge which is not
visible as a PCI device in Linux. But the device-id of the
bridge is present in the IOMMU tables which causes a boot
crash in the IOMMU driver.
This patch fixes by removing these cards from the IOMMU
handling. This is a pure -stable fix, a real fix to handle
this situation appriatly will follow for the next merge
window.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 0de66d5b35ee148455e268b2782873204ffdef4b upstream.
The driver contains several loops counting on an u16 value
where the exit-condition is checked against variables that
can have values up to 0xffff. In this case the loops will
never exit. This patch fixed 3 such loops.
commit 27c2127a15d340706c0aa84e311188a14468d841 upstream.
Unfortunatly there are systems where the AMD IOMMU does not
cover all devices. This breaks with the current driver as it
initializes the global dma_ops variable. This patch limits
the AMD IOMMU to the devices listed in the IVRS table fixing
DMA for devices not covered by the IOMMU.
commit f124c6ae59e193705c9ddac57684d50006d710e6 upstream.
b->args[] has MC_ARGS elements, so the comparison here should be
">=" instead of ">". Otherwise we read past the end of the array
one space.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
commit 7899891c7d161752f29abcc9bc0a9c6c3a3af26c upstream.
There's a race window in xen_drop_mm_ref, where remote cpu may exit
dirty bitmap between the check on this cpu and the point where remote
cpu handles drop request. So in drop_other_mm_ref we need check
whether TLB state is still lazy before calling into leave_mm. This
bug is rarely observed in earlier kernel, but exaggerated by the
commit 831d52bc153971b70e64eccfbed2b232394f22f8
("x86, mm: avoid possible bogus tlb entries by clearing prev mm_cpumask after switching mm")
which clears bitmap after changing the TLB state. the call trace is as below:
kernel BUG at arch/x86/mm/tlb.c:61!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/devices/system/xen_memory/xen_memory0/info/current_kb
CPU 1
Modules linked in: 8021q garp xen_netback xen_blkback blktap blkback_pagemap nbd bridge stp llc autofs4 ipmi_devintf ipmi_si ipmi_msghandler lockd sunrpc bonding ipv6 xenfs dm_multipath video output sbs sbshc parport_pc lp parport ses enclosure snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device serio_raw bnx2 snd_pcm_oss snd_mixer_oss snd_pcm snd_timer iTCO_wdt snd soundcore snd_page_alloc i2c_i801 iTCO_vendor_support i2c_core pcs pkr pata_acpi ata_generic ata_piix shpchp mptsas mptscsih mptbase [last unloaded: freq_table]
Pid: 25581, comm: khelper Not tainted 2.6.32.36fixxen #1 Tecal RH2285
RIP: e030:[<ffffffff8103a3cb>] [<ffffffff8103a3cb>] leave_mm+0x15/0x46
RSP: e02b:ffff88002805be48 EFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000001 RCX: ffff88015f8e2da0
RDX: ffff88002805be78 RSI: 0000000000000000 RDI: 0000000000000001
RBP: ffff88002805be48 R08: ffff88009d662000 R09: dead000000200200
R10: dead000000100100 R11: ffffffff814472b2 R12: ffff88009bfc1880
R13: ffff880028063020 R14: 00000000000004f6 R15: 0000000000000000
FS: 00007f62362d66e0(0000) GS:ffff880028058000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000003aabc11909 CR3: 000000009b8ca000 CR4: 0000000000002660
DR0: 0000000000000000 DR1: 0000000000000000 DR2: 00000000000000 00
Process khelper (pid: 25581, threadinfo ffff88007691e000, task ffff88009b92db40)
Stack:
ffff88002805be68 ffffffff8100e4ae 0000000000000001 ffff88009d733b88
<0> ffff88002805be98 ffffffff81087224 ffff88002805be78 ffff88002805be78
<0> ffff88015f808360 00000000000004f6 ffff88002805bea8 ffffffff81010108
Call Trace:
<IRQ>
[<ffffffff8100e4ae>] drop_other_mm_ref+0x2a/0x53
[<ffffffff81087224>] generic_smp_call_function_single_interrupt+0xd8/0xfc
[<ffffffff81010108>] xen_call_function_single_interrupt+0x13/0x28
[<ffffffff810a936a>] handle_IRQ_event+0x66/0x120
[<ffffffff810aac5b>] handle_percpu_irq+0x41/0x6e
[<ffffffff8128c1c0>] __xen_evtchn_do_upcall+0x1ab/0x27d
[<ffffffff8128dd11>] xen_evtchn_do_upcall+0x33/0x46
[<ffffffff81013efe>] xen_do_hyper visor_callback+0x1e/0x30
<EOI>
[<ffffffff814472b2>] ? _spin_unlock_irqrestore+0x15/0x17
[<ffffffff8100f8cf>] ? xen_restore_fl_direct_end+0x0/0x1
[<ffffffff81113f71>] ? flush_old_exec+0x3ac/0x500
[<ffffffff81150dc5>] ? load_elf_binary+0x0/0x17ef
[<ffffffff8115115d>] ? load_elf_binary+0x398/0x17ef
[<ffffffff81042fcf>] ? need_resched+0x23/0x2d
[<ffffffff811f4648>] ? process_measurement+0xc0/0xd7
[<ffffffff81113094>] ? search_binary_handler+0xc8/0x255
[<ffffffff81114362>] ? do_execve+0x1c3/0x29e
[<ffffffff8101155d>] ? sys_execve+0x43/0x5d
[<ffffffff8106fc45>] ? __call_usermodehelper+0x0/0x6f
[<ffffffff81013e28>] ? kernel_execve+0x68/0xd0
[<ffffffff 8106fc45>] ? __call_usermodehelper+0x0/0x6f
[<ffffffff8106fb64>] ? ____call_usermodehelper+0x113/0x11e
[<ffffffff81013daa>] ? child_rip+0xa/0x20
[<ffffffff81012f91>] ? int_ret_from_sys_call+0x7/0x1b
[<ffffffff8101371d>] ? retint_restore_args+0x5/0x6
[<ffffffff81013da0>] ? child_rip+0x0/0x20
Code: 41 5e 41 5f c9 c3 55 48 89 e5 0f 1f 44 00 00 e8 17 ff ff ff c9 c3 55 48 89 e5 0f 1f 44 00 00 65 8b 04 25 c8 55 01 00 ff c8 75 04 <0f> 0b eb fe 65 48 8b 34 25 c0 55 01 00 48 81 c6 b8 02 00 00 e8
RIP [<ffffffff8103a3cb>] leave_mm+0x15/0x46
RSP <ffff88002805be48>
---[ end trace ce9cee6832a9c503 ]---
Tested-by: Maoxiaoyun<tinnycloud@hotmail.com>
Signed-off-by: Kevin Tian <kevin.tian@intel.com>
[v1: Fleshed out the git description a bit]
commit a248b13b21ae00b97638b4f435c8df3075808b5d upstream.
The v6 and v7 implementations of flush_kern_dcache_area do not align
the passed MVA to the size of a cacheline in the data cache. If a
misaligned address is used, only a subset of the requested area will
be flushed. This has been observed to cause failures in SMP boot where
the secondary_data initialised by the primary CPU is not cacheline
aligned, causing the secondary CPUs to read incorrect values for their
pgd and stack pointers.
This patch ensures that the base address is cacheline aligned before
flushing the d-cache.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit d47cc0db8fd6011de2248df505fc34990b7451bf upstream.
The workaround for Bugzilla:
https://bugzilla.kernel.org/show_bug.cgi?id=33012
introduced a read and a write to the MC4 mask msr.
Unfortunatly this MSR is not emulated by the KVM hypervisor
so that the kernel will get a #GP and crashes when applying
this workaround when running inside KVM.
This issue was reported as:
https://bugzilla.kernel.org/show_bug.cgi?id=35132
and is fixed with this patch. The change just let the kernel
ignore any #GP it gets while accessing this MSR by using the
_safe msr access methods.
Reported-by: Török Edwin <edwintorok@gmail.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
Cc: Avi Kivity <avi@redhat.com>
commit e9cdd343a5e42c43bcda01e609fa23089e026470 upstream.
Commit b87cf80af3ba4b4c008b4face3c68d604e1715c6 added support for
ARAT (Always Running APIC timer) on AMD processors that are not
affected by erratum 400. This erratum is present on certain processor
families and prevents APIC timer from waking up the CPU when it
is in a deep C state, including C1E state.
Determining whether a processor is affected by this erratum may
have some corner cases and handling these cases is somewhat
complicated. In the interest of simplicity we won't claim ARAT
support on processor families below 0x12 and will go back to
broadcasting timer when going idle.
Signed-off-by: Boris Ostrovsky <ostr@amd64.org>
Link: http://lkml.kernel.org/r/1306423192-19774-1-git-send-email-ostr@amd64.org
Tested-by: Boris Petkov <borislav.petkov@amd.com>
Cc: Hans Rosenfeld <Hans.Rosenfeld@amd.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 26afb7c661080ae3f1f13ddf7f0c58c4f931c22b upstream.
As reported in BZ #30352:
https://bugzilla.kernel.org/show_bug.cgi?id=30352
there's a kernel bug related to reading the last allowed page on x86_64.
The _copy_to_user() and _copy_from_user() functions use the following
check for address limit:
if (buf + size >= limit)
fail();
while it should be more permissive:
if (buf + size > limit)
fail();
That's because the size represents the number of bytes being
read/write from/to buf address AND including the buf address.
So the copy function will actually never touch the limit
address even if "buf + size == limit".
Following program fails to use the last page as buffer
due to the wrong limit check:
#include <sys/mman.h>
#include <sys/socket.h>
#include <assert.h>
#define PAGE_SIZE (4096)
#define LAST_PAGE ((void*)(0x7fffffffe000))
int main()
int fds[2], err;
void * ptr = mmap(LAST_PAGE, PAGE_SIZE, PROT_READ | PROT_WRITE,
MAP_ANONYMOUS | MAP_PRIVATE | MAP_FIXED, -1, 0);
assert(ptr == LAST_PAGE);
err = socketpair(AF_LOCAL, SOCK_STREAM, 0, fds);
assert(err == 0);
err = send(fds[0], ptr, PAGE_SIZE, 0);
perror("send");
assert(err == PAGE_SIZE);
err = recv(fds[1], ptr, PAGE_SIZE, MSG_WAITALL);
perror("recv");
return 0;
The other place checking the addr limit is the access_ok() function,
which is working properly. There's just a misleading comment
for the __range_not_ok() macro - which this patch fixes as well.
The last page of the user-space address range is a guard page and
Brian Gerst observed that the guard page itself due to an erratum on K8 cpus
(#121 Sequential Execution Across Non-Canonical Boundary Causes Processor
Hang).
However, the test code is using the last valid page before the guard page.
The bug is that the last byte before the guard page can't be read
because of the off-by-one error. The guard page is left in place.
This bug would normally not show up because the last page is
part of the process stack and never accessed via syscalls.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/1305210630-7136-1-git-send-email-jolsa@redhat.com
commit ad5d5292f16c6c1d7d3e257c4c7407594286b97e upstream.
Commit 0837e3242c73566fc1c0196b4ec61779c25ffc93 fixes a situation on POWER7
where events can roll back if a specualtive event doesn't actually complete.
This can raise a performance monitor exception. We need to catch this to ensure
that we reset the PMC. In all cases the PMC will be less than 256 cycles from
overflow.
This patch lifts Anton's fix for the problem in perf and applies it to oprofile
as well.
Signed-off-by: Eric B Munson <emunson@mgebm.net>
commit d9a5ac9ef306eb5cc874f285185a15c303c50009 upstream.
b may be added to a list, but is not removed before being freed
in the case of an error. This is done in the corresponding
deallocation function, so the code here has been changed to
follow that.
The sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression E,E1,E2;
identifier l;
*list_add(&E->l,E1);
... when != E1
when != list_del(&E->l)
when != list_del_init(&E->l)
when != E = E2
*kfree(E);// </smpl>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1305294731-12127-1-git-send-email-julia@diku.dk
commit e503f9e4b092e2349a9477a333543de8f3c7f5d9 upstream.
This patch fixes a bug reported by a customer, who found
that many unreasonable error interrupts reported on all
non-boot CPUs (APs) during the system boot stage.
According to Chapter 10 of Intel Software Developer Manual
Volume 3A, Local APIC may signal an illegal vector error when
an LVT entry is set as an illegal vector value (0~15) under
FIXED delivery mode (bits 8-11 is 0), regardless of whether
the mask bit is set or an interrupt actually happen. These
errors are seen as error interrupts.
The initial value of thermal LVT entries on all APs always reads
0x10000 because APs are woken up by BSP issuing INIT-SIPI-SIPI
sequence to them and LVT registers are reset to 0s except for
the mask bits which are set to 1s when APs receive INIT IPI.
When the BIOS takes over the thermal throttling interrupt,
the LVT thermal deliver mode should be SMI and it is required
from the kernel to keep AP's LVT thermal monitoring register
programmed as such as well.
This issue happens when BIOS does not take over thermal throttling
interrupt, AP's LVT thermal monitor register will be restored to
0x10000 which means vector 0 and fixed deliver mode, so all APs will
signal illegal vector error interrupts.
This patch check if interrupt delivery mode is not fixed mode before
restoring AP's LVT thermal monitor register.
Signed-off-by: Youquan Song <youquan.song@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Yong Wang <yong.y.wang@intel.com>
Cc: hpa@linux.intel.com
Cc: joe@perches.com
Cc: jbaron@redhat.com
Cc: trenn@suse.de
Cc: kent.liu@intel.com
Cc: chaohong.guo@intel.com
Link: http://lkml.kernel.org/r/1303402963-17738-1-git-send-email-youquan.song@intel.com
commit 14fb57dccb6e1defe9f89a66f548fcb24c374c1d upstream.
Trying to enable the local APIC timer on early K8 revisions
uncovers a number of other issues with it, in conjunction with
the C1E enter path on AMD. Fixing those causes much more churn
and troubles than the benefit of using that timer brings so
don't enable it on K8 at all, falling back to the original
functionality the kernel had wrt to that.
Reported-and-bisected-by: Nick Bowler <nbowler@elliptictech.com>
Cc: Boris Ostrovsky <Boris.Ostrovsky@amd.com>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Cc: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: Nick Bowler <nbowler@elliptictech.com>
Cc: Joerg-Volker-Peetz <jvpeetz@web.de>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Link: http://lkml.kernel.org/r/1305636919-31165-3-git-send-email-bp@amd64.org
commit 328935e6348c6a7cb34798a68c326f4b8372e68a upstream.
This reverts commit e20a2d205c05cef6b5783df339a7d54adeb50962, as it crashes
certain boxes with specific AMD CPU models.
Moving the lower endpoint of the Erratum 400 check to accomodate
earlier K8 revisions (A-E) opens a can of worms which is simply
not worth to fix properly by tweaking the errata checking
framework:
* missing IntPenging MSR on revisions < CG cause #GP:
http://marc.info/?l=linux-kernel&m=130541471818831
* makes earlier revisions use the LAPIC timer instead of the C1E
idle routine which switches to HPET, thus not waking up in
deeper C-states:
http://lkml.org/lkml/2011/4/24/20
Therefore, leave the original boundary starting with K8-revF.
commit 87dc669ba25777b67796d7262c569429e58b1ed4 upstream.
While the tracer accesses ptrace breakpoints, the child task may
concurrently exit due to a SIGKILL and thus release its breakpoints
at the same time. We can then dereference some freed pointers.
To fix this, hold a reference on the child breakpoints before
manipulating them.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: Prasad <prasad@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1302284067-7860-3-git-send-email-fweisbec@gmail.com
commit 0f22072ab50cac7983f9660d33974b45184da4f9 upstream.
When CONFIG_OABI_COMPAT is set, the wrapper for semtimedop does not
bound the nsops argument. A sufficiently large value will cause an
integer overflow in allocation size, followed by copying too much data
into the allocated buffer. Fix this by restricting nsops to SEMOPM.
Untested.
commit e20a2d205c05cef6b5783df339a7d54adeb50962 upstream.
Older AMD K8 processors (Revisions A-E) are affected by erratum
400 (APIC timer interrupts don't occur in C states greater than
C1). This, for example, means that X86_FEATURE_ARAT flag should
not be set for these parts.
This addresses regression introduced by commit
b87cf80af3ba4b4c008b4face3c68d604e1715c6 ("x86, AMD: Set ARAT
feature on AMD processors") where the system may become
unresponsive until external interrupt (such as keyboard input)
occurs. This results, for example, in time not being reported
correctly, lack of progress on the system and other lockups.
Reported-by: Joerg-Volker Peetz <jvpeetz@web.de>
Tested-by: Joerg-Volker Peetz <jvpeetz@web.de>
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
Signed-off-by: Boris Ostrovsky <Boris.Ostrovsky@amd.com>
Link: http://lkml.kernel.org/r/1304113663-6586-1-git-send-email-ostr@amd64.org
commit 4aac0b4815ba592052758f4b468f253d383dc9d6 upstream.
For m68k, N_NORMAL_MEMORY represents all nodes that have present memory
since it does not support HIGHMEM. This patch sets the bit at the time
node_present_pages has been set by free_area_init_node.
At the time the node is brought online, the node state would have to be
done unconditionally since information about present memory has not yet
been recorded.
If N_NORMAL_MEMORY is not accurate, slub may encounter errors since it
uses this nodemask to setup per-cache kmem_cache_node data structures.
This pach is an alternative to the one proposed by David Rientjes
<rientjes@google.com> attempting to set node state immediately when
bringing the node online.
Signed-off-by: Michael Schmitz <schmitz@debian.org>
Tested-by: Thorsten Glaser <tg@debian.org>
commit d9b41e0b54fd7e164daf1e9c539c1070398aa02e upstream.
When a DISCONTIGMEM memory range is brought online as a NUMA node, it
also needs to have its bet set in N_NORMAL_MEMORY. This is necessary for
generic kernel code that utilizes N_NORMAL_MEMORY as a subset of N_ONLINE
for memory savings.
These types of hacks can hopefully be removed once DISCONTIGMEM is either
removed or abstracted away from CONFIG_NUMA.
Fixes a panic in the slub code which only initializes structures for
N_NORMAL_MEMORY to save memory:
Backtrace:
[<000000004021c938>] add_partial+0x28/0x98
[<000000004021faa0>] __slab_free+0x1d0/0x1d8
[<000000004021fd04>] kmem_cache_free+0xc4/0x128
[<000000004033bf9c>] ida_get_new_above+0x21c/0x2c0
[<00000000402a8980>] sysfs_new_dirent+0xd0/0x238
[<00000000402a974c>] create_dir+0x5c/0x168
[<00000000402a9ab0>] sysfs_create_dir+0x98/0x128
[<000000004033d6c4>] kobject_add_internal+0x114/0x258
[<000000004033d9ac>] kobject_add_varg+0x7c/0xa0
[<000000004033df20>] kobject_add+0x50/0x90
[<000000004033dfb4>] kobject_create_and_add+0x54/0xc8
[<00000000407862a0>] cgroup_init+0x138/0x1f0
[<000000004077ce50>] start_kernel+0x5a0/0x840
[<000000004011fa3c>] start_parisc+0xa4/0xb8
[<00000000404bb034>] packet_ioctl+0x16c/0x208
[<000000004049ac30>] ip_mroute_setsockopt+0x260/0xf20
Signed-off-by: David Rientjes <rientjes@google.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 665d3e2af83c8fbd149534db8f57d82fa6fa6753 upstream.
The GART can only map physical memory below 1TB. Make sure
the gart driver in the kernel does not try to map memory
above 1TB.
Link: http://lkml.kernel.org/r/1303134346-5805-5-git-send-email-joerg.roedel@amd.com
commit 07a7795ca2e6e66d00b184efb46bd0e23d90d3fe upstream.
A bug in the family-model-stepping matching code caused the presence of
errata to go undetected when OSVW was not used. This causes hangs on
some K8 systems because the E400 workaround is not enabled.
Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
LKML-Reference: <1282141190-930137-1-git-send-email-hans.rosenfeld@amd.com>
commit 5bbc097d890409d8eff4e3f1d26f11a9d6b7c07e upstream.
This patch disables GartTlbWlk errors on AMD Fam10h CPUs if
the BIOS forgets to do is (or is just too old). Letting
these errors enabled can cause a sync-flood on the CPU
causing a reboot.
The AMD BKDG recommends disabling GART TLB Wlk Error completely.
This patch is the fix for
on my machine.
Link: http://lkml.kernel.org/r/20110415131152.GJ18463@8bytes.org
Tested-by: Alexandre Demers <alexandre.f.demers@gmail.com>
commit 9d8888c2a214aece2494a49e699a097c2ba9498b upstream.
Remove check_c1e_idle() and use the new AMD errata checking framework
instead.
LKML-Reference: <1280336972-865982-2-git-send-email-hans.rosenfeld@amd.com>
commit d78d671db478eb8b14c78501c0cee1cc7baf6967 upstream.
Errata are defined using the AMD_LEGACY_ERRATUM() or AMD_OSVW_ERRATUM()
macros. The latter is intended for newer errata that have an OSVW id
assigned, which it takes as first argument. Both take a variable number
of family-specific model-stepping ranges created by AMD_MODEL_RANGE().
Iff an erratum has an OSVW id, OSVW is available on the CPU, and the
OSVW id is known to the hardware, it is used to determine whether an
erratum is present. Otherwise, the model-stepping ranges are matched
against the current CPU to find out whether the erratum applies.
For certain special errata, the code using this framework might have to
conduct further checks to make sure an erratum is really (not) present.
LKML-Reference: <1280336972-865982-1-git-send-email-hans.rosenfeld@amd.com>
commit b87cf80af3ba4b4c008b4face3c68d604e1715c6 upstream.
Support for Always Running APIC timer (ARAT) was introduced in
commit db954b5898dd3ef3ef93f4144158ea8f97deb058. This feature
allows us to avoid switching timers from LAPIC to something else
(e.g. HPET) and go into timer broadcasts when entering deep
C-states.
AMD processors don't provide a CPUID bit for that feature but
they also keep APIC timers running in deep C-states (except for
cases when the processor is affected by erratum 400). Therefore
we should set ARAT feature bit on AMD CPUs.
Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Mark Langsdorf <mark.langsdorf@amd.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
LKML-Reference: <1300205624-4813-1-git-send-email-ostr@amd64.org>
commit c1d036c4d1cb00b7e8473a2ad0a78f13e13a8183 upstream.
ia64_mca_cpu_init has a void *data local variable that is assigned
the value from either __get_free_pages() or mca_bootmem(). The problem
is that __get_free_pages returns an unsigned long and mca_bootmem, via
alloc_bootmem(), returns a void *. format_mca_init_stack takes the void *,
and it's also used with __pa(), but that casts it to long anyway.
This results in the following build warning:
arch/ia64/kernel/mca.c:1898: warning: assignment makes pointer from
integer without a cast
Cast the return of __get_free_pages to a void * to avoid
the warning.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit b4a6b3436531f6c5256e6d60d388c3c28ff1a0e9 upstream.
The prototype for sn_pci_provider->{dma_map,dma_map_consistent} expects
an unsigned long instead of a u64.
commit e938c287ea8d977e079f07464ac69923412663ce upstream.
'simple' would have required specifying current frame address
and return address location manually, but that's obviously not
the case (and not necessary) here.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4D6D1082020000780003454C@vpn.id2.novell.com>
This reverts upstream commit e5f15b45ddf3afa2bbbb10c7ea34fb32b6de0a0e
It caused problems in the stable tree and should not have been there.
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
powerpc: Fix default_machine_crash_shutdown #ifdef botch
Commit: c2be05481f6125254c45b78f334d4dd09c701c82 upstream
crash_kexec_wait_realmode() is defined only if CONFIG_PPC_STD_MMU_64
and CONFIG_SMP, but is called if CONFIG_PPC_STD_MMU_64 even if !CONFIG_SMP.
Fix the conditional compilation around the invocation.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
cc: Anton Blanchard <anton@samba.org>
powerpc/kexec: Add ifdef CONFIG_PPC_STD_MMU_64 to PPC64 code
This patch introduces PPC64 specific #ifdef bits from the upstream
commit: b3df895aebe091b1657a42a8c859bd49fc96646b.
Reported-and-tested-by: dann frazier <dannf@dannf.org>
cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
commit 84ac7cdbdd0f04df6b96153f7a79127fd6e45467 upstream.
On laptops with core i5/i7, there were reports that after resume
graphics workloads were performing poorly on a specific AP, while
the other cpu's were ok. This was observed on a 32bit kernel
specifically.
Debug showed that the PAT init was not happening on that AP
during resume and hence it contributing to the poor workload
performance on that cpu.
On this system, resume flow looked like this:
1. BP starts the resume sequence and we reinit BP's MTRR's/PAT
early on using mtrr_bp_restore()
2. Resume sequence brings all AP's online
3. Resume sequence now kicks off the MTRR reinit on all the AP's.
4. For some reason, between point 2 and 3, we moved from BP
to one of the AP's. My guess is that printk() during resume
sequence is contributing to this. We don't see similar
behavior with the 64bit kernel but there is no guarantee that
at this point the remaining resume sequence (after AP's bringup)
has to happen on BP.
5. set_mtrr() was assuming that we are still on BP and skipped the
MTRR/PAT init on that cpu (because of 1 above)
6. But we were on an AP and this led to not reprogramming PAT
on this cpu leading to bad performance.
Fix this by doing unconditional mtrr_if->set_all() in set_mtrr()
during MTRR/PAT init. This might be unnecessary if we are still
running on BP. But it is of no harm and will guarantee that after
resume, all the cpu's will be in sync with respect to the
MTRR/PAT registers.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1301438292-28370-1-git-send-email-eric@anholt.net>
Signed-off-by: Eric Anholt <eric@anholt.net>
Tested-by: Keith Packard <keithp@keithp.com>
commit e5f15b45ddf3afa2bbbb10c7ea34fb32b6de0a0e upstream.
Now cleanup_highmap actually is in two steps: one is early in head64.c
and only clears above _end; a second one is in init_memory_mapping() and
tries to clean from _brk_end to _end.
It should check if those boundaries are PMD_SIZE aligned but currently
does not.
Also init_memory_mapping() is called several times for numa or memory
hotplug, so we really should not handle initial kernel mappings there.
This patch moves cleanup_highmap() down after _brk_end is settled so
we can do everything in one step.
Also we honor max_pfn_mapped in the implementation of cleanup_highmap.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <alpine.DEB.2.00.1103171739050.3382@kaball-desktop>
commit 14988a4d350ce3b41ecad4f63c4f44c56f5ae34d upstream.
Do not set max_pfn_mapped to the end of the initial memory mappings,
that also contain pages that don't belong in pfn space (like the mfn
list).
Set max_pfn_mapped to the last real pfn mapped in the initial memory
mappings that is the pfn backing _end.
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 371c394af27ab7d1e58a66bc19d9f1f3ac1f67b4 upstream.
The latest binutils (2.21.0.20110302/Ubuntu) breaks the build
yet another time, under CONFIG_XEN=y due to a .size directive that
refers to a slightly differently named (hence, to the now very
strict and unforgiving assembler, non-existent) symbol.
[ mingo:
This unnecessary build breakage caused by new binutils
version 2.21 gets escallated back several kernel releases spanning
several years of Linux history, affecting over 130,000 upstream
kernel commits (!), on CONFIG_XEN=y 64-bit kernels (i.e. essentially
affecting all major Linux distro kernel configs).
Git annotate tells us that this slight debug symbol code mismatch
bug has been introduced in 2008 in commit 3d75e1b8:
3d75e1b8 (Jeremy Fitzhardinge 2008-07-08 15:06:49 -0700 1231) ENTRY(xen_do_hypervisor_callback) # do_hypervisor_callback(struct *pt_regs)
The 'bug' is just a slight assymetry in ENTRY()/END()
debug-symbols sequences, with lots of assembly code between the
ENTRY() and the END():
END(do_hypervisor_callback)
Human reviewers almost never catch such small mismatches, and binutils
never even warned about it either.
This new binutils version thus breaks the Xen build on all upstream kernels
since v2.6.27, out of the blue.
This makes a straightforward Git bisection of all 64-bit Xen-enabled kernels
impossible on such binutils, for a bisection window of over hundred
thousand historic commits. (!)
This is a major fail on the side of binutils and binutils needs to turn
this show-stopper build failure into a warning ASAP. ]
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Jan Beulich <jbeulich@novell.com>
Cc: H.J. Lu <hjl.tools@gmail.com>
Cc: Kees Cook <kees.cook@canonical.com>
LKML-Reference: <1299877178-26063-1-git-send-email-heukelum@fastmail.fm>
