commit 2e4d88009f57057df7672fa69a32b5224af54d37 upstream.
While we can technically not run huge page guests right now, we can
setup a guest with huge pages. Trying to migrate it will trigger a
VM_BUG_ON and, if the kernel is not configured to panic on a BUG, it
will happily try to work on non-existing page table entries.
With this patch, we always return "dirty" if we encounter a large page
when migrating. This at least fixes the immediate problem until we
have proper handling for both kind of pages.
Fixes: 15f36eb ("KVM: s390: Add proper dirty bitmap support to S390 kvm.")
Signed-off-by: Janosch Frank <frankja@linux.vnet.ibm.com>
Acked-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit a69e2fb70350a66f91175cd2625f1e8215c5b6e9 upstream.
The CPPR (Current Processor Priority Register) of a XICS interrupt
presentation controller contains a value N, such that only interrupts
with a priority "more favoured" than N will be received by the CPU,
where "more favoured" means "less than". So if the CPPR has the value 5
then only interrupts with a priority of 0-4 inclusive will be received.
In theory the CPPR can support a value of 0 to 255 inclusive.
In practice Linux only uses values of 0, 4, 5 and 0xff. Setting the CPPR
to 0 rejects all interrupts, setting it to 0xff allows all interrupts.
The values 4 and 5 are used to differentiate IPIs from external
interrupts. Setting the CPPR to 5 allows IPIs to be received but not
external interrupts.
The CPPR emulation in the OPAL XICS implementation only directly
supports priorities 0 and 0xff. All other priorities are considered
equivalent, and mapped to a single priority value internally. This means
when using icp-opal we can not allow IPIs but not externals.
This breaks Linux's use of priority values when a CPU is hot unplugged.
After migrating IRQs away from the CPU that is being offlined, we set
the priority to 5, meaning we still want the offline CPU to receive
IPIs. But the effect of the OPAL XICS emulation's use of a single
priority value is that all interrupts are rejected by the CPU. With the
CPU offline, and not receiving IPIs, we may not be able to wake it up to
bring it back online.
The first part of the fix is in icp_opal_set_cpu_priority(). CPPR values
of 0 to 4 inclusive will correctly cause all interrupts to be rejected,
so we pass those CPPR values through to OPAL. However if we are called
with a CPPR of 5 or greater, the caller is expecting to be able to allow
IPIs but not external interrupts. We know this doesn't work, so instead
of rejecting all interrupts we choose the opposite which is to allow all
interrupts. This is still not correct behaviour, but we know for the
only existing caller (xics_migrate_irqs_away()), that it is the better
option.
The other part of the fix is in xics_migrate_irqs_away(). Instead of
setting priority (CPPR) to 0, and then back to 5 before migrating IRQs,
we migrate the IRQs before setting the priority back to 5. This should
have no effect on an ICP backend with a working set_priority(), and on
icp-opal it means we will keep all interrupts blocked until after we've
finished doing the IRQ migration. Additionally we wait for 5ms after
doing the migration to make sure there are no IRQs in flight.
Fixes: d74361881f0d ("powerpc/xics: Add ICP OPAL backend")
Suggested-by: Michael Ellerman <mpe@ellerman.id.au>
Reported-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Tested-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Signed-off-by: Balbir Singh <bsingharora@gmail.com>
[mpe: Rewrote comments and change log, change delay to 5ms]
commit e148bd17f48bd17fca2f4f089ec879fa6e47e34c upstream.
emulate_step() uses a number of underlying kernel functions that were
initially not enabled for LE. This has been rectified since. So, fix
emulate_step() for LE for the corresponding instructions.
Reported-by: Anton Blanchard <anton@samba.org>
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
commit 886f9c69fc68f56ddea34d3de51ac1fc2ac8dfbc upstream.
All pointers to these functions were removed, so now they produce
warnings:
arch/mips/ralink/rt305x.c:92:13: error: 'rt305x_wdt_reset' defined but not used [-Werror=unused-function]
This removes the functions. If we need them again, the patch can be
reverted later.
Fixes: f576fb6a0700 ("MIPS: ralink: cleanup the soc specific pinmux data")
Cc: John Crispin <john@phrozen.org>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/15044/
commit d92240d12a9c010e0094bbc9280aae4a6be9a2d5 upstream.
The functions were originally used for the module unload path,
but are not referenced any more and just cause warnings:
arch/mips/ralink/timer.c:104:13: error: 'rt_timer_disable' defined but not used [-Werror=unused-function]
arch/mips/ralink/timer.c:74:13: error: 'rt_timer_free' defined but not used [-Werror=unused-function]
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Fixes: 62ee73d284e7 ("MIPS: ralink: Make timer explicitly non-modular")
Patchwork: https://patchwork.linux-mips.org/patch/15041/
commit 9c48568b3692f1a56cbf1935e4eea835e6b185b1 upstream.
Over the years the code has been changed various times leading to
argc/argv being defined in a different function to where we actually
use the variables. Clean this up by moving them to prom_init_cmdline().
Signed-off-by: John Crispin <john@phrozen.org>
Patchwork: https://patchwork.linux-mips.org/patch/14902/
commit b3f6046186ef45acfeebc5a59c9fb45cefc685e7 upstream.
Since linux-4.8, CPU_FREQ_STAT is a bool symbol, causing a warning in
kernelci.org:
arch/mips/configs/lemote2f_defconfig:42:warning: symbol value 'm' invalid for CPU_FREQ_STAT
This updates the defconfig to have the feature built-in.
Fixes: 1aefc75b2449 ("cpufreq: stats: Make the stats code non-modular")
Patchwork: https://patchwork.linux-mips.org/patch/15000/
commit 23ca9b522383d3b9b7991d8586db30118992af4a upstream.
kernelci reports a failure of the ip28_defconfig build after upgrading its
gcc version:
arch/mips/sgi-ip22/Platform:29: *** gcc doesn't support needed option -mr10k-cache-barrier=store. Stop.
The problem apparently is that the -mr10k-cache-barrier=store option is now
rejected for CPUs other than r10k. Explicitly including the CPU in the
check fixes this and is safe because both options were introduced in
gcc-4.4.
Patchwork: https://patchwork.linux-mips.org/patch/15049/
commit ea58fca1842a5dc410cae4167b01643db971a4e2 upstream.
Since linux-4.3, SCSI_DH is a bool symbol, causing a warning in
kernelci.org:
arch/mips/configs/ip27_defconfig:136:warning: symbol value 'm' invalid for SCSI_DH
Fixes: 086b91d052eb ("scsi_dh: integrate into the core SCSI code")
Patchwork: https://patchwork.linux-mips.org/patch/15001/
commit b617649468390713db1515ea79fc772d2eb897a8 upstream.
One of the last remaining failures in kernelci.org is for a gcc bug:
drivers/net/ethernet/qlogic/qlge/qlge_main.c:4819:1: error: insn does not satisfy its constraints:
drivers/net/ethernet/qlogic/qlge/qlge_main.c:4819:1: internal compiler error: in extract_constrain_insn, at recog.c:2190
This is apparently broken in gcc-6 but fixed in gcc-7, and I cannot
reproduce the problem here. However, it is clear that ip27_defconfig
does not actually need this driver as the platform has only PCI-X but
not PCIe, and the qlge adapter in turn is PCIe-only.
The driver was originally enabled in 2010 along with lots of other
drivers.
Fixes: 59d302b342e5 ("MIPS: IP27: Make defconfig useful again.")
Patchwork: https://patchwork.linux-mips.org/patch/15197/
Signed-off-by: James Hogan <james.hogan@imgtec.com>
commit 1742ac265046f34223e06d5d283496f0291be259 upstream.
vdso.h includes <spaces.h> implicitly after defining CONFIG_32BITS.
This defeats the override in mach-ip27/spaces.h, leading to
a build error that shows up in kernelci.org:
In file included from arch/mips/include/asm/mach-ip27/spaces.h:29:0,
from arch/mips/include/asm/page.h:12,
from arch/mips/vdso/vdso.h:26,
from arch/mips/vdso/gettimeofday.c:11:
arch/mips/include/asm/mach-generic/spaces.h:28:0: error: "CAC_BASE" redefined [-Werror]
#define CAC_BASE _AC(0x80000000, UL)
An earlier patch tried to make the second definition conditional,
but that patch had the #ifdef in the wrong place, and would lead
to another warning:
arch/mips/include/asm/io.h: In function 'phys_to_virt':
arch/mips/include/asm/io.h:138:9: error: cast to pointer from integer of different size [-Werror=int-to-pointer-cast]
For all I can tell, there is no other reason than vdso32 to ever
include this file with CONFIG_32BITS set, and the vdso itself should
never refer to the base addresses as it is running in user space,
so adding an #ifdef here is safe.
Link: https://patchwork.kernel.org/patch/9418187/
Fixes: 3ffc17d8768b ("MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0")
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/15039/
commit 9ddc16ad8e0bc7742fc96d5aaabc5b8698512cd1 upstream.
In linux-4.10-rc, NF_CT_PROTO_UDPLITE and NF_CT_PROTO_DCCP are bool
symbols instead of tristate, and kernelci.org reports a bunch of
warnings for this, like:
arch/mips/configs/malta_kvm_guest_defconfig:63:warning: symbol value 'm' invalid for NF_CT_PROTO_UDPLITE
arch/mips/configs/malta_defconfig:62:warning: symbol value 'm' invalid for NF_CT_PROTO_DCCP
arch/mips/configs/malta_defconfig:63:warning: symbol value 'm' invalid for NF_CT_PROTO_UDPLITE
arch/mips/configs/ip22_defconfig:70:warning: symbol value 'm' invalid for NF_CT_PROTO_DCCP
arch/mips/configs/ip22_defconfig:71:warning: symbol value 'm' invalid for NF_CT_PROTO_UDPLITE
This changes all the MIPS defconfigs with these symbols to have them
built-in.
Fixes: 9b91c96c5d1f ("netfilter: conntrack: built-in support for UDPlite")
Fixes: c51d39010a1b ("netfilter: conntrack: built-in support for DCCP")
Patchwork: https://patchwork.linux-mips.org/patch/14999/
commit 2c4ea6e28dbf15ab93632c5c189f3948366b8885 upstream.
Fengguang reported random corruptions from various locations on x86-32
after commits d2852a224050 ("arch: add ARCH_HAS_SET_MEMORY config") and
9d876e79df6a ("bpf: fix unlocking of jited image when module ronx not set")
that uses the former. While x86-32 doesn't have a JIT like x86_64, the
bpf_prog_lock_ro() and bpf_prog_unlock_ro() got enabled due to
ARCH_HAS_SET_MEMORY, whereas Fengguang's test kernel doesn't have module
support built in and therefore never had the DEBUG_SET_MODULE_RONX setting
enabled.
After investigating the crashes further, it turned out that using
set_memory_ro() and set_memory_rw() didn't have the desired effect, for
example, setting the pages as read-only on x86-32 would still let
probe_kernel_write() succeed without error. This behavior would manifest
itself in situations where the vmalloc'ed buffer was accessed prior to
set_memory_*() such as in case of bpf_prog_alloc(). In cases where it
wasn't, the page attribute changes seemed to have taken effect, leading to
the conclusion that a TLB invalidate didn't happen. Moreover, it turned out
that this issue reproduced with qemu in "-cpu kvm64" mode, but not for
"-cpu host". When the issue occurs, change_page_attr_set_clr() did trigger
a TLB flush as expected via __flush_tlb_all() through cpa_flush_range(),
though.
There are 3 variants for issuing a TLB flush: invpcid_flush_all() (depends
on CPU feature bits X86_FEATURE_INVPCID, X86_FEATURE_PGE), cr4 based flush
(depends on X86_FEATURE_PGE), and cr3 based flush. For "-cpu host" case in
my setup, the flush used invpcid_flush_all() variant, whereas for "-cpu
kvm64", the flush was cr4 based. Switching the kvm64 case to cr3 manually
worked fine, and further investigating the cr4 one turned out that
X86_CR4_PGE bit was not set in cr4 register, meaning the
__native_flush_tlb_global_irq_disabled() wrote cr4 twice with the same
value instead of clearing X86_CR4_PGE in the first write to trigger the
flush.
It turned out that X86_CR4_PGE was cleared from cr4 during init from
lguest_arch_host_init() via adjust_pge(). The X86_FEATURE_PGE bit is also
cleared from there due to concerns of using PGE in guest kernel that can
lead to hard to trace bugs (see bff672e630a0 ("lguest: documentation V:
Host") in init()). The CPU feature bits are cleared in dynamic
boot_cpu_data, but they never propagated to __flush_tlb_all() as it uses
static_cpu_has() instead of boot_cpu_has() for testing which variant of TLB
flushing to use, meaning they still used the old setting of the host
kernel.
Clearing via setup_clear_cpu_cap(X86_FEATURE_PGE) so this would propagate
to static_cpu_has() checks is too late at this point as sections have been
patched already, so for now, it seems reasonable to switch back to
boot_cpu_has(X86_FEATURE_PGE) as it was prior to commit c109bf95992b
("x86/cpufeature: Remove cpu_has_pge"). This lets the TLB flush trigger via
cr3 as originally intended, properly makes the new page attributes visible
and thus fixes the crashes seen by Fengguang.
Fixes: c109bf95992b ("x86/cpufeature: Remove cpu_has_pge")
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: bp@suse.de
Cc: netdev@vger.kernel.org
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: lkp@01.org
Cc: Laura Abbott <labbott@redhat.com>
Link: http://lkml.kernrl.org/r/20170301125426.l4nf65rx4wahohyl@wfg-t540p.sh.intel.com
Link: http://lkml.kernel.org/r/25c41ad9eca164be4db9ad84f768965b7eb19d9e.1489191673.git.daniel@iogearbox.net
commit ef947b2529f918d9606533eb9c32b187ed6a5ede upstream.
gup_pte_range() fails to check pte_allows_gup() before translating a DAX
pte entry, pte_devmap(), to a page. This allows writes to read-only
mappings, and bypasses the DAX cacheline dirty tracking due to missed
'mkwrite' faults. The gup_huge_pmd() path and the gup_huge_pud() path
correctly check pte_allows_gup() before checking for _devmap() entries.
Fixes: 3565fce3a659 ("mm, x86: get_user_pages() for dax mappings")
Link: http://lkml.kernel.org/r/148804251312.36605.12665024794196605053.stgit@dwillia2-desk3.amr.corp.intel.com
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Reported-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Xiong Zhou <xzhou@redhat.com>
commit 4ab18701c66552944188dbcd0ce0012729baab84 upstream.
FDT tag parsing is not related to whether BLK_DEV_INITRD is configured
or not, move it out of the corresponding #ifdef/#endif block.
This fixes passing external FDT to the kernel configured w/o
BLK_DEV_INITRD support.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
commit 4920e3cf77347d7d7373552d4839e8d832321313 upstream.
The current implementation of setup_randomness uses the stack address
and therefore the pointer to the SYSIB 3.2.2 block as input data
address. Furthermore the length of the input data is the number of
virtual-machine description blocks which is typically one.
This means that typically a single zero byte is fed to
add_device_randomness.
Fix both of these and use the address of the first virtual machine
description block as input data address and also use the correct
length.
Fixes: bcfcbb6bae64 ("s390: add system information as device randomness")
commit da8fd820f389a0e29080b14c61bf5cf1d8ef5ca1 upstream.
Commit bcfcbb6bae64 ("s390: add system information as device
randomness") intended to add some virtual machine specific information
to the randomness pool.
Unfortunately it uses the page allocator before it is ready to use. In
result the page allocator always returns NULL and the setup_randomness
function never adds anything to the randomness pool.
To fix this use memblock_alloc and memblock_free instead.
commit fb94a687d96c570d46332a4a890f1dcb7310e643 upstream.
Return a sensible value if TASK_SIZE if called from a kernel thread.
This gets us around an issue with copy_mount_options that does a magic
size calculation "TASK_SIZE - (unsigned long)data" while in a kernel
thread and data pointing to kernel space.
commit a4a81d8eebdc1d209d034f62a082a5131e4242b5 upstream.
In binutils/libbfd (bfd/elf.c) it is enforced that all s390 specific ELF
notes like e.g. NT_S390_PREFIX or NT_S390_CTRS have "LINUX" specified
as note name. Otherwise the notes are ignored.
For /proc/vmcore we currently use "CORE" for these notes.
Up to now this has not been a real problem because the dump analysis tool
"crash" does not check the note name. But it will break all programs that
use libbfd for processing ELF notes.
So fix this and use "LINUX" for all s390 specific notes to comply with
libbfd.
Reported-by: Philipp Rudo <prudo@linux.vnet.ibm.com>
Reviewed-by: Philipp Rudo <prudo@linux.vnet.ibm.com>
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit 96794e4ed4d758272c486e1529e431efb7045265 upstream.
Guest segment selector is 16 bit field and guest segment base is natural
width field. Fix two incorrect invocations accordingly.
Without this patch, build fails when aggressive inlining is used with ICC.
Signed-off-by: Chao Peng <chao.p.peng@linux.intel.com>
commit e1e8a9624f7ba8ead4f056ff558ed070e86fa747 upstream.
User controlled KVM guests do not support the dirty log, as they have
no single gmap that we can check for changes.
As they have no single gmap, kvm->arch.gmap is NULL and all further
referencing to it for dirty checking will result in a NULL
dereference.
Let's return -EINVAL if a caller tries to sync dirty logs for a
UCONTROL guest.
Reported-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit ae2f5e5ed04a17c1aa1f0a3714c725e12c21d2a9 upstream.
Fix the following build error with binutils 2.25.
CC arch/mips/mm/sc-ip22.o
{standard input}: Assembler messages:
{standard input}:132: Error: number (0x9000000080000000) larger than 32 bits
{standard input}:159: Error: number (0x9000000080000000) larger than 32 bits
{standard input}:200: Error: number (0x9000000080000000) larger than 32 bits
scripts/Makefile.build:293: recipe for target 'arch/mips/mm/sc-ip22.o' failed
make[1]: *** [arch/mips/mm/sc-ip22.o] Error 1
MIPS has used .set mips3 to temporarily switch the assembler to 64 bit
mode in 64 bit kernels virtually forever. Binutils 2.25 broke this
behavious partially by happily accepting 64 bit instructions in .set mips3
mode but puking on 64 bit constants when generating 32 bit ELF. Binutils
2.26 restored the old behaviour again.
Fix build with binutils 2.25 by open coding the offending
dli $1, 0x9000000080000000
as
li $1, 0x9000
dsll $1, $1, 48
which is ugly be the only thing that will build on all binutils vintages.
Cc: stable@vger.kernel.org
commit f9f1c8db1c37253805eaa32265e1e1af3ae7d0a4 upstream.
commit fda2d27db6eae5c2468f9e4657539b72bbc238bb upstream.
We will set LPCR with correct value for radix during int. This make sure we
start with a sanitized value of LPCR. In case of kexec, cpus can have LPCR
value based on the previous translation mode we were running.
Fixes: fe036a0605d60 ("powerpc/64/kexec: Fix MMU cleanup on radix")
Acked-by: Michael Neuling <mikey@neuling.org>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit a5ecdad4847897007399d7a14c9109b65ce4c9b7 upstream.
Without this we will always find the feature disabled.
Fixes: 984d7a1ec6 ("powerpc/mm: Fixup kernel read only mapping")
Acked-by: Balbir Singh <bsingharora@gmail.com>
commit c21a493a2b44650707d06741601894329486f2ad upstream.
Currently xmon data-breakpoint feature is broken.
Whenever there is a watchpoint match occurs, hw_breakpoint_handler will
be called by do_break via notifier chains mechanism. If watchpoint is
registered by xmon, hw_breakpoint_handler won't find any associated
perf_event and returns immediately with NOTIFY_STOP. Similarly, do_break
also returns without notifying to xmon.
Solve this by returning NOTIFY_DONE when hw_breakpoint_handler does not
find any perf_event associated with matched watchpoint, rather than
NOTIFY_STOP, which tells the core code to continue calling the other
breakpoint handlers including the xmon one.
commit 7d0928f18bf890d2853281f59aba0dd5a46b34f9 upstream.
Since it was introduced in commit da8d02d19ffdd201 ("arm64/capabilities:
Make use of system wide safe value"), __raw_read_system_reg() has
erroneously mapped some sysreg IDs to other registers.
For the fields in ID_ISAR5_EL1, our local feature detection will be
erroneous. We may spuriously detect that a feature is uniformly
supported, or may fail to detect when it actually is, meaning some
compat hwcaps may be erroneous (or not enforced upon hotplug).
This patch corrects the erroneous entries.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Fixes: da8d02d19ffdd201 ("arm64/capabilities: Make use of system wide safe value")
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
commit adbe7e26f4257f72817495b9bce114284060b0d7 upstream.
When bypassing SWIOTLB on small-memory systems, we need to avoid calling
into swiotlb_dma_mapping_error() in exactly the same way as we avoid
swiotlb_dma_supported(), because the former also relies on SWIOTLB state
being initialised.
Under the assumptions for which we skip SWIOTLB, dma_map_{single,page}()
will only ever return the DMA-offset-adjusted physical address of the
page passed in, thus we can report success unconditionally.
Fixes: b67a8b29df7e ("arm64: mm: only initialize swiotlb when necessary")
CC: Jisheng Zhang <jszhang@marvell.com>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
commit 8f36ebaf21fdae99c091c67e8b6fab33969f2667 upstream.
When we fault in a page, we flush it to the PoC (Point of Coherency)
if the faulting vcpu has its own caches off, so that it can observe
the page we just brought it.
But if the vcpu has its caches on, we skip that step. Bad things
happen when *another* vcpu tries to access that page with its own
caches disabled. At that point, there is no garantee that the
data has made it to the PoC, and we access stale data.
The obvious fix is to always flush to PoC when a page is faulted
in, no matter what the state of the vcpu is.
Fixes: 2d58b733c876 ("arm64: KVM: force cache clean on page fault when caches are off")
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 58ab9a088ddac4efe823471275859d64f735577e upstream.
Kirill reported a warning from UBSAN about undefined behavior when using
protection keys. He is running on hardware that actually has support for
it, which is not widely available.
The warning triggers because of very large shifts of integers when doing a
pkey_free() of a large, invalid value. This happens because we never check
that the pkey "fits" into the mm_pkey_allocation_map().
I do not believe there is any danger here of anything bad happening
other than some aliasing issues where somebody could do:
pkey_free(35);
and the kernel would effectively execute:
pkey_free(8);
While this might be confusing to an app that was doing something stupid, it
has to do something stupid and the effects are limited to the app shooting
itself in the foot.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: linux-kselftest@vger.kernel.org
Cc: shuah@kernel.org
Cc: kirill.shutemov@linux.intel.com
Link: http://lkml.kernel.org/r/20170223222603.A022ED65@viggo.jf.intel.com
commit 78162d48466d23c45a784034630c5928af631e3d upstream.
Enable DMA on uart1 to get a more reliable console.
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit ef8d02d4a2c36f7a93e74c95a9c419353b310117 upstream.
Enable DMA on usart3 to get a more reliable console. This is especially
useful for automation and kernelci were a kernel with PROVE_LOCKING enabled
is quite susceptible to character loss, resulting in tests failure.
commit 096a0de427ea333f56f0ee00328cff2a2731bcf1 upstream.
is_jump_ins() checks for plain jump ("j") instructions since commit
e7438c4b893e ("MIPS: Fix sibling call handling in get_frame_info") but
that commit didn't make the same change to the microMIPS code, leaving
it inconsistent with the MIPS32/MIPS64 code. Handle the microMIPS
encoding of the jump instruction too such that it behaves consistently.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fixes: e7438c4b893e ("MIPS: Fix sibling call handling in get_frame_info")
Cc: Tony Wu <tung7970@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/14533/
commit bb9bc4689b9c635714fbcd5d335bad9934a7ebfc upstream.
get_frame_info() calculates the offset of the return address within a
stack frame simply by dividing a the bottom 16 bits of the instruction,
treated as a signed integer, by the size of a long. Whilst this works
for MIPS32 & MIPS64 ISAs where the sw or sd instructions are used, it's
incorrect for microMIPS where encodings differ. The result is that we
typically completely fail to unwind the stack on microMIPS.
Fix this by adjusting is_ra_save_ins() to calculate the return address
offset, and take into account the various different encodings there in
the same place as we consider whether an instruction is storing the
ra/$31 register.
With this we are now able to unwind the stack for kernels targetting the
microMIPS ISA, for example we can produce:
Call Trace:
[<80109e1f>] show_stack+0x63/0x7c
[<8011ea17>] __warn+0x9b/0xac
[<8011ea45>] warn_slowpath_fmt+0x1d/0x20
[<8013fe53>] register_console+0x43/0x314
[<8067c58d>] of_setup_earlycon+0x1dd/0x1ec
[<8067f63f>] early_init_dt_scan_chosen_stdout+0xe7/0xf8
[<8066c115>] do_early_param+0x75/0xac
[<801302f9>] parse_args+0x1dd/0x308
[<8066c459>] parse_early_options+0x25/0x28
[<8066c48b>] parse_early_param+0x2f/0x38
[<8066e8cf>] setup_arch+0x113/0x488
[<8066c4f3>] start_kernel+0x57/0x328
---[ end trace 0000000000000000 ]---
Whereas previously we only produced:
Call Trace:
Fixes: 34c2f668d0f6 ("MIPS: microMIPS: Add unaligned access support.")
Cc: Leonid Yegoshin <leonid.yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14532/
commit 67c75057709a6d85c681c78b9b2f9b71191f01a2 upstream.
is_jump_ins() checks 16b instruction fields without verifying that the
instruction is indeed 16b, as is done by is_ra_save_ins() &
is_sp_move_ins(). Add the appropriate check.
Patchwork: https://patchwork.linux-mips.org/patch/14531/
commit b6c7a324df37bf05ef7a2c1580683cf10d082d97 upstream.
get_frame_info() is meant to iterate over up to the first 128
instructions within a function, but for microMIPS kernels it will not
reach that many instructions unless the function is 512 bytes long since
we calculate the maximum number of instructions to check by dividing the
function length by the 4 byte size of a union mips_instruction. In
microMIPS kernels this won't do since instructions are variable length.
Fix this by instead checking whether the pointer to the current
instruction has reached the end of the function, and use max_insns as a
simple constant to check the number of iterations against.
Patchwork: https://patchwork.linux-mips.org/patch/14530/
commit a3552dace7d1d0cabf573e88fc3025cb90c4a601 upstream.
During stack unwinding we call a number of functions to determine what
type of instruction we're looking at. The union mips_instruction pointer
provided to them may be pointing at a 2 byte, but not 4 byte, aligned
address & we thus cannot directly access the 4 byte wide members of the
union mips_instruction. To avoid this is_ra_save_ins() copies the
required half-words of the microMIPS instruction to a correctly aligned
union mips_instruction on the stack, which it can then access safely.
The is_jump_ins() & is_sp_move_ins() functions do not correctly perform
this temporary copy, and instead attempt to directly dereference 4 byte
fields which may be misaligned and lead to an address exception.
Fix this by copying the instruction halfwords to a temporary union
mips_instruction in get_frame_info() such that we can provide a 4 byte
aligned union mips_instruction to the is_*_ins() functions and they do
not need to deal with misalignment themselves.
Patchwork: https://patchwork.linux-mips.org/patch/14529/
commit ccaf7caf2c73c6db920772bf08bf1d47b2170634 upstream.
get_frame_info() can be called in microMIPS kernels with the ISA bit
already clear. For example this happens when unwind_stack_by_address()
is called because we begin with a PC that has the ISA bit set & subtract
the (odd) offset from the preceding symbol (which does not have the ISA
bit set). Since get_frame_info() unconditionally subtracts 1 from the PC
in microMIPS kernels it incorrectly misaligns the address it then
attempts to access code at, leading to an address error exception.
Fix this by using msk_isa16_mode() to clear the ISA bit, which allows
get_frame_info() to function regardless of whether it is provided with a
PC that has the ISA bit set or not.
Patchwork: https://patchwork.linux-mips.org/patch/14528/
commit 774f0c6419bb8f9d83901d33582c7fe3ba6a6cb3 upstream.
Disabling ethernet during reboot (only to enable it again when the
ethernet driver attaches) can put the chip into a faulty state where it
corrupts the header of all incoming packets.
This happens if packets arrive during the time window where the core is
disabled, and it can be easily reproduced by rebooting while sending a
flood ping to the broadcast address.
Fixes: 95135bfa7ead ("MIPS: Lantiq: Deactivate most of the devices by default")
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Acked-by: John Crispin <john@phrozen.org>
Cc: hauke.mehrtens@lantiq.com
Patchwork: https://patchwork.linux-mips.org/patch/15078/
commit 884b426917e4b3c85f33b382c792a94305dfdd62 upstream.
If copy_from_user is called with a large buffer (>= 128 bytes) and the
userspace buffer refers partially to unreadable memory, then it is
possible for Octeon's copy_from_user to report the wrong number of bytes
have been copied. In the case where the buffer size is an exact multiple
of 128 and the fault occurs in the last 64 bytes, copy_from_user will
report that all the bytes were copied successfully but leave some
garbage in the destination buffer.
The bug is in the main __copy_user_common loop in octeon-memcpy.S where
in the middle of the loop, src and dst are incremented by 128 bytes. The
l_exc_copy fault handler is used after this but that assumes that
"src < THREAD_BUADDR($28)". This is not the case if src has already been
incremented.
Fix by adding an extra fault handler which rewinds the src and dst
pointers 128 bytes before falling though to l_exc_copy.
Thanks to the pwritev test from the strace test suite for originally
highlighting this bug!
Fixes: 5b3b16880f40 ("MIPS: Add Cavium OCTEON processor support ...")
Signed-off-by: James Cowgill <James.Cowgill@imgtec.com>
Acked-by: David Daney <david.daney@cavium.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14978/
commit bdfdaf1a016ef09cb941f2edad485a713510b8d5 upstream.
The Asus WL-500W buttons are active high, but the software treats them
as active low. Fix the inverted logic.
Fixes: 3be972556fa1 ("MIPS: BCM47XX: Import buttons database from OpenWrt")
Signed-off-by: Mirko Parthey <mirko.parthey@web.de>
Acked-by: Rafał Miłecki <rafal@milecki.pl>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Patchwork: https://patchwork.linux-mips.org/patch/15295/
commit 66fd848cadaa6be974a8c780fbeb328f0af4d3bd upstream.
For certain arguments such as saddr = 0xc0a8fd60, daddr = 0xc0a8fda1,
len = 80, proto = 17, sum = 0x7eae049d there will be a carry when
folding the intermediate 64 bit checksum to 32 bit but the code doesn't
add the carry back to the one's complement sum, thus an incorrect result
will be generated.
Reported-by: Mark Zhang <bomb.zhang@gmail.com>
commit a726f1d2dd4fee179aa4513176d688ad309de6cc upstream.
Early clock API pic32_get_pbclk() is defined in early_clk.c and used by
time.c and early_console.c. When CONFIG_EARLY_PRINTK isn't set,
early_clk.c isn't compiled and time.c fails to link.
Fix it by compiling early_clk.c always. Also sort files in alphabetical
order.
Fixes: 6e4ad1b41360 ("MIPS: pic32mzda: fix getting timer clock rate.")
Reported-by: Harvey Hunt <harvey.hunt@imgtec.com>
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
Reviewed-by: Harvey Hunt <harvey.hunt@imgtec.com>
Cc: Joshua Henderson <digitalpeer@digitalpeer.com>
Patchwork: https://patchwork.linux-mips.org/patch/13383/
commit 47512cfd0d7a8bd6ab71d01cd89fca19eb2093eb upstream.
The goldfish platform code registers the platform device unconditionally
which causes havoc in several ways if the goldfish_pdev_bus driver is
enabled:
- Access to the hardcoded physical memory region, which is either not
available or contains stuff which is completely unrelated.
- Prevents that the interrupt of the serial port can be requested
- In case of a spurious interrupt it goes into a infinite loop in the
interrupt handler of the pdev_bus driver (which needs to be fixed
seperately).
Add a 'goldfish' command line option to make the registration opt-in when
the platform is compiled in.
I'm seriously grumpy about this engineering trainwreck, which has seven
SOBs from Intel developers for 50 lines of code. And none of them figured
out that this is broken. Impressive fail!
Fixes: ddd70cf93d78 ("goldfish: platform device for x86")
Reported-by: Gabriel C <nix.or.die@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 9e3440481845b2ec22508f60837ee2cab2b6054f upstream.
The 64-bit get_user() wasn't clearing the high word due to a typo in the
error handler. The exception handler entry was already correct, though.
Noticed during recent usercopy test additions in lib/test_user_copy.c.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 3f91a89d424a79f8082525db5a375e438887bb3e upstream.
Currently, if the kernel is running on a POWER9 processor under a
hypervisor, it may try to use the radix MMU even though it doesn't have
the necessary code to do so (it doesn't negotiate use of radix, and it
doesn't do the H_REGISTER_PROC_TBL hcall). If the hypervisor supports
both radix and HPT, then it will set up the guest to use HPT (since the
guest doesn't request radix in the CAS call), but if the radix feature
bit is set in the ibm,pa-features property (which is valid, since
ibm,pa-features is defined to represent the capabilities of the
processor) the guest will try to use radix, resulting in a crash when
it turns the MMU on.
This makes the minimal fix for the current code, which is to disable
radix unless we are running in hypervisor mode.
Fixes: 2bfd65e45e87 ("powerpc/mm/radix: Add radix callbacks for early init routines")
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
commit dffba9a31c7769be3231c420d4b364c92ba3f1ac upstream.
The compacted-format XSAVES area is determined at boot time and
never changed after. The field xsave.header.xcomp_bv indicates
which components are in the fixed XSAVES format.
In fpstate_init() we did not set xcomp_bv to reflect the XSAVES
format since at the time there is no valid data.
However, after we do copy_init_fpstate_to_fpregs() in fpu__clear(),
as in commit:
b22cbe404a9c x86/fpu: Fix invalid FPU ptrace state after execve()
and when __fpu_restore_sig() does fpu__restore() for a COMPAT-mode
app, a #GP occurs. This can be easily triggered by doing valgrind on
a COMPAT-mode "Hello World," as reported by Joakim Tjernlund and
others:
https://bugzilla.kernel.org/show_bug.cgi?id=190061
Fix it by setting xcomp_bv correctly.
This patch also moves the xcomp_bv initialization to the proper
place, which was in copyin_to_xsaves() as of:
4c833368f0bf x86/fpu: Set the xcomp_bv when we fake up a XSAVES area
which fixed the bug too, but it's more efficient and cleaner to
initialize things once per boot, not for every signal handling
operation.
Reported-by: Kevin Hao <haokexin@gmail.com>
Reported-by: Joakim Tjernlund <Joakim.Tjernlund@infinera.com>
Signed-off-by: Yu-cheng Yu <yu-cheng.yu@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Cc: haokexin@gmail.com
Link: http://lkml.kernel.org/r/1485212084-4418-1-git-send-email-yu-cheng.yu@intel.com
[ Combined it with 4c833368f0bf. ]
commit 08b259631b5a1d912af4832847b5642f377d9101 upstream.
After:
a33d331761bc ("x86/CPU/AMD: Fix Bulldozer topology")
our SMT scheduling topology for Fam17h systems is broken, because
the ThreadId is included in the ApicId when SMT is enabled.
So, without further decoding cpu_core_id is unique for each thread
rather than the same for threads on the same core. This didn't affect
systems with SMT disabled. Make cpu_core_id be what it is defined to be.
Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/20170205105022.8705-2-bp@alien8.de
commit 79a8b9aa388b0620cc1d525d7c0f0d9a8a85e08e upstream.
Commit:
restored the initial approach we had with the Fam15h topology of
enumerating CU (Compute Unit) threads as cores. And this is still
correct - they're beefier than HT threads but still have some
shared functionality.
Our current approach has a problem with the Mad Max Steam game, for
example. Yves Dionne reported a certain "choppiness" while playing on
v4.9.5.
That problem stems most likely from the fact that the CU threads share
resources within one CU and when we schedule to a thread of a different
compute unit, this incurs latency due to migrating the working set to a
different CU through the caches.
When the thread siblings mask mirrors that aspect of the CUs and
threads, the scheduler pays attention to it and tries to schedule within
one CU first. Which takes care of the latency, of course.
Reported-by: Yves Dionne <yves.dionne@gmail.com>
Cc: Brice Goglin <Brice.Goglin@inria.fr>
Cc: Yazen Ghannam <yazen.ghannam@amd.com>
Link: http://lkml.kernel.org/r/20170205105022.8705-1-bp@alien8.de
commit 146fbb766934dc003fcbf755b519acef683576bf upstream.
CONFIG_KASAN=y needs a lot of virtual memory mapped for its shadow.
In that case ptdump_walk_pgd_level_core() takes a lot of time to
walk across all page tables and doing this without
a rescheduling causes soft lockups:
NMI watchdog: BUG: soft lockup - CPU#3 stuck for 23s! [swapper/0:1]
Call Trace:
ptdump_walk_pgd_level_core+0x40c/0x550
ptdump_walk_pgd_level_checkwx+0x17/0x20
mark_rodata_ro+0x13b/0x150
kernel_init+0x2f/0x120
ret_from_fork+0x2c/0x40
I guess that this issue might arise even without KASAN on huge machines
with several terabytes of RAM.
Stick cond_resched() in pgd loop to fix this.
Reported-by: Tobias Regnery <tobias.regnery@gmail.com>
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: kasan-dev@googlegroups.com
Cc: Alexander Potapenko <glider@google.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Link: http://lkml.kernel.org/r/20170210095405.31802-1-aryabinin@virtuozzo.com
