path: root/arch
2011-02-17x86, mm: avoid possible bogus tlb entries by clearing prev mm_cpumask after ↵Suresh Siddha
switching mm commit 831d52bc153971b70e64eccfbed2b232394f22f8 upstream. Clearing the cpu in prev's mm_cpumask early will avoid the flush tlb IPI's while the cr3 is still pointing to the prev mm. And this window can lead to the possibility of bogus TLB fills resulting in strange failures. One such problematic scenario is mentioned below. T1. CPU-1 is context switching from mm1 to mm2 context and got a NMI etc between the point of clearing the cpu from the mm_cpumask(mm1) and before reloading the cr3 with the new mm2. T2. CPU-2 is tearing down a specific vma for mm1 and will proceed with flushing the TLB for mm1. It doesn't send the flush TLB to CPU-1 as it doesn't see that cpu listed in the mm_cpumask(mm1). T3. After the TLB flush is complete, CPU-2 goes ahead and frees the page-table pages associated with the removed vma mapping. T4. CPU-2 now allocates those freed page-table pages for something else. T5. As the CR3 and TLB caches for mm1 is still active on CPU-1, CPU-1 can potentially speculate and walk through the page-table caches and can insert new TLB entries. As the page-table pages are already freed and being used on CPU-2, this page walk can potentially insert a bogus global TLB entry depending on the (random) contents of the page that is being used on CPU-2. T6. This bogus TLB entry being global will be active across future CR3 changes and can result in weird memory corruption etc. To avoid this issue, for the prev mm that is handing over the cpu to another mm, clear the cpu from the mm_cpumask(prev) after the cr3 is changed. Marking it for -stable, though we haven't seen any reported failure that can be attributed to this. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ARM: oprofile: Fix backtraces in timer modeAri Kauppi
commit d14dd7e20d5e526557f5d3cfef4046a642f80924 upstream. Always allow backtraces when using oprofile on ARM, even if a PMU isn't present. Restores functionality originally introduced in commit 1b7b56982fdcd9d85effd76f3928cf5d6eb26155 ("oprofile: Always allow backtraces on ARM") by Richard Purdie. It is not that obvious, but there is now only one oprofile_arch_init() function. So the .backtrace callback is available also in timer mode. Implemented by removing code and using stubs for oprofile_perf_{init, exit} provided by <linux/oprofile.h>. This allows cleaning of other architecture specific implementations too. Signed-off-by: Ari Kauppi <kauppi@papupata.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17x86: Readd missing irq_to_desc() in fixup_irq()Thomas Gleixner
commit 5117348dea5e3ecbb785cfa1271386fb49332b41 upstream. commit a3c08e5d(x86: Convert irq_chip access to new functions) accidentally zapped desc = irq_to_desc(irq); in the vector loop. So we lock some random irq descriptor. Add it back. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17x86, dmi, debug: Log board name (when present) in dmesg/oops outputNaga Chumbalkar
commit 84e383b322e5348db03be54ff64cc6da87003717 upstream. The "Type 2" SMBIOS record that contains Board Name is not strictly required and may be absent in the SMBIOS on some platforms. ( Please note that Type 2 is not listed in Table 3 in Sec 6.2 ("Required Structures and Data") of the SMBIOS v2.7 Specification. ) Use the Manufacturer Name (aka System Vendor) name. Print Board Name only when it is present. Before the fix: (i) dmesg output: DMI: /ProLiant DL380 G6, BIOS P62 01/29/2011 (ii) oops output: Pid: 2170, comm: bash Not tainted 2.6.38-rc4+ #3 /ProLiant DL380 G6 After the fix: (i) dmesg output: DMI: HP ProLiant DL380 G6, BIOS P62 01/29/2011 (ii) oops output: Pid: 2278, comm: bash Not tainted 2.6.38-rc4+ #4 HP ProLiant DL380 G6 Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> LKML-Reference: <20110214224423.2182.13929.sendpatchset@nchumbalkar.americas.hpqcorp.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17parisc : Remove broken line wrapping handling pdc_iodc_print()Guy Martin
commit fbea668498e93bb38ac9226c7af9120a25957375 upstream. Remove the broken line wrapping handling in pdc_iodc_print(). It is broken in 3 ways : - It doesn't keep track of the current screen position, it just assumes that the new buffer will be printed at the begining of the screen. - It doesn't take in account that non printable characters won't increase the current position on the screen. - And last but not least, it triggers a kernel panic if a backspace is the first char in the provided buffer : Backtrace: [<0000000040128ec4>] pdc_console_write+0x44/0x78 [<0000000040128f18>] pdc_console_tty_write+0x20/0x38 [<000000004032f1ac>] n_tty_write+0x2a4/0x550 [<000000004032b158>] tty_write+0x1e0/0x2d8 [<00000000401bb420>] vfs_write+0xb8/0x188 [<00000000401bb630>] sys_write+0x68/0xb8 [<0000000040104eb8>] syscall_exit+0x0/0x14 Most terminals handle the line wrapping just fine. I've confirmed that it works correctly on a C8000 with both vga and serial output. Signed-off-by: Guy Martin <gmsoft@tuxicoman.be> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ARM: smp_on_up: allow non-ARM SMP processorsRussell King
commit e98ff0f55a0232b578c9aa7f1c245868277ac7bc upstream. Allow non-ARM SMP processors to use the SMP_ON_UP feature. CPUs supporting SMP must have the new CPU ID format, so check for this first. Then check for ARM11MPCore, which fails the MPIDR check. Lastly check the MPIDR reports multiprocessing extensions and that the CPU is part of a multiprocessing system. Reported-and-Tested-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ARM: SMP: use more sane register allocation for __fixup_smp_on_upRussell King
commit 0eb0511d176534674600a1986c3c766756288908 upstream. Use r0,r3-r6 rather than r0,r3,r4,r6,r7, which makes it easier to understand which registers can be modified. Also document which registers hold values which must be preserved. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17powerpc: Fix some 6xx/7xxx CPU setup functionsBenjamin Herrenschmidt
commit 1f1936ff3febf38d582177ea319eaa278f32c91f upstream. Some of those functions try to adjust the CPU features, for example to remove NAP support on some revisions. However, they seem to use r5 as an index into the CPU table entry, which might have been right a long time ago but no longer is. r4 is the right register to use. This probably caused some off behaviours on some PowerMac variants using 750cx or 7455 processor revisions. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17powerpc/numa: Fix bug in unmap_cpu_from_nodeAnton Blanchard
commit 429f4d8d20b91e4a6c239f951c06a56a6ac22957 upstream. When converting to the new cpumask code I screwed up: - if (cpu_isset(cpu, numa_cpumask_lookup_table[node])) { - cpu_clear(cpu, numa_cpumask_lookup_table[node]); + if (cpumask_test_cpu(cpu, node_to_cpumask_map[node])) { + cpumask_set_cpu(cpu, node_to_cpumask_map[node]); This was introduced in commit 25863de07af9 (powerpc/cpumask: Convert NUMA code to new cpumask API) Fix it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17powerpc: Fix hcall tracepoint recursionAnton Blanchard
commit 57cdfdf829a850a317425ed93c6a576c9ee6329c upstream. Spinlocks on shared processor partitions use H_YIELD to notify the hypervisor we are waiting on another virtual CPU. Unfortunately this means the hcall tracepoints can recurse. The patch below adds a percpu depth and checks it on both the entry and exit hcall tracepoints. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17powerpc/85xx: fix compatible properties of the P1022DS DMA nodes used for audioTimur Tabi
commit b2e0861e51f2961954330dcafe6d148ee3ab5cff upstream. In order to prevent the fsl_dma driver from claiming the DMA channels that the P1022DS audio driver needs, the compatible properties for those nodes must say "fsl,ssi-dma-channel" instead of "fsl,eloplus-dma-channel". Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17x86, olpc: Add missing Kconfig dependenciesH. Peter Anvin
commit 76d1f7bfcd5872056902c5a88b5fcd5d4d00a7a9 upstream. OLPC uses select for OLPC_OPENFIRMWARE, which means OLPC has to enforce the dependencies for OLPC_OPENFIRMWARE. Make sure it does so. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Daniel Drake <dsd@laptop.org> Cc: Andres Salomon <dilinger@queued.net> Cc: Grant Likely <grant.likely@secretlab.ca> LKML-Reference: <20100923162846.D8D409D401B@zog.reactivated.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ARM: initrd: disable initrd if passed address overlaps reserved regionRussell King
commit b0a2679d27408d97ce31e5f800b44227d3388b84 upstream. Disable the initrd if the passed address already overlaps the reserved region. This avoids oopses on Netwinders when NeTTrom tells the kernel that an initrd is located at mem+4MB, but this overlaps the BSS, resulting in the kernels in-use BSS being freed. This should be applied to v2.6.37-stable. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17ARM: S5PV310: Set bit 22 in the PL310 (cache controller) AuxCtlr registerChanghwan Youn
commit a50eb1c7680973f5441ca20ac4da0af2055d0d87 upstream. This patch is applied according to the commit 1a8e41cd672f894bbd74874eac601e6cedf838fb (ARM: 6395/1: VExpress: Set bit 22 in the PL310 (cache controller) AuxCtlr register). Actually, S5PV310 has same cache controller(PL310). Following is from Catalin Marinas' commit. Clearing bit 22 in the PL310 Auxiliary Control register (shared attribute override enable) has the side effect of transforming Normal Shared Non-cacheable reads into Cacheable no-allocate reads. Coherent DMA buffers in Linux always have a Cacheable alias via the kernel linear mapping and the processor can speculatively load cache lines into the PL310 controller. With bit 22 cleared, Non-cacheable reads would unexpectedly hit such cache lines leading to buffer corruption. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17x86, mtrr: Avoid MTRR reprogramming on BP during boot on UP platformsSuresh Siddha
commit f7448548a9f32db38f243ccd4271617758ddfe2c upstream. Markus Kohn ran into a hard hang regression on an acer aspire 1310, when acpi is enabled. git bisect showed the following commit as the bad one that introduced the boot regression. commit d0af9eed5aa91b6b7b5049cae69e5ea956fd85c3 Author: Suresh Siddha <suresh.b.siddha@intel.com> Date: Wed Aug 19 18:05:36 2009 -0700 x86, pat/mtrr: Rendezvous all the cpus for MTRR/PAT init Because of the UP configuration of that platform, native_smp_prepare_cpus() bailed out (in smp_sanity_check()) before doing the set_mtrr_aps_delayed_init() Further down the boot path, native_smp_cpus_done() will call the delayed MTRR initialization for the AP's (mtrr_aps_init()) with mtrr_aps_delayed_init not set. This resulted in the boot processor reprogramming its MTRR's to the values seen during the start of the OS boot. While this is not needed ideally, this shouldn't have caused any side-effects. This is because the reprogramming of MTRR's (set_mtrr_state() that gets called via set_mtrr()) will check if the live register contents are different from what is being asked to write and will do the actual write only if they are different. BP's mtrr state is read during the start of the OS boot and typically nothing would have changed when we ask to reprogram it on BP again because of the above scenario on an UP platform. So on a normal UP platform no reprogramming of BP MTRR MSR's happens and all is well. However, on this platform, bios seems to be modifying the fixed mtrr range registers between the start of OS boot and when we double check the live registers for reprogramming BP MTRR registers. And as the live registers are modified, we end up reprogramming the MTRR's to the state seen during the start of the OS boot. During ACPI initialization, something in the bios (probably smi handler?) don't like this fact and results in a hard lockup. We didn't see this boot hang issue on this platform before the commit d0af9eed5aa91b6b7b5049cae69e5ea956fd85c3, because only the AP's (if any) will program its MTRR's to the value that BP had at the start of the OS boot. Fix this issue by checking mtrr_aps_delayed_init before continuing further in the mtrr_aps_init(). Now, only AP's (if any) will program its MTRR's to the BP values during boot. Addresses https://bugzilla.novell.com/show_bug.cgi?id=623393 [ By the way, this behavior of the bios modifying MTRR's after the start of the OS boot is not common and the kernel is not prepared to handle this situation well. Irrespective of this issue, during suspend/resume, linux kernel will try to reprogram the BP's MTRR values to the values seen during the start of the OS boot. So suspend/resume might be already broken on this platform for all linux kernel versions. ] Reported-and-bisected-by: Markus Kohn <jabber@gmx.org> Tested-by: Markus Kohn <jabber@gmx.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Thomas Renninger <trenn@novell.com> Cc: Rafael Wysocki <rjw@novell.com> Cc: Venkatesh Pallipadi <venki@google.com> LKML-Reference: <1296694975.4418.402.camel@sbsiddha-MOBL3.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17avr32: use syscall prototypes from asm-generic instead of archHans-Christian Egtvedt
commit 664cb7142ced8b827e92e1851d1ed2cae922f225 upstream. This patch removes the redundant syscalls prototypes in the architecture specific syscalls.h header file. These were identical with the ones in asm-generic/syscalls.h. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reported-by: Peter Huewe <PeterHuewe@gmx.de> Reported-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17sh: Fix up legacy PTEA space attribute mapping.Paul Mundt
commit efb3e34b6176d30c4fe8635fa8e1beb6280cc2cd upstream. When p3_ioremap() was converted to ioremap_prot() there was some breakage introduced where the 29-bit segmentation logic would trap the area range and return an identity mapping without having allowed the area specification to force mapping through page tables. This wires up a PCC mask for pgprot verification to work out whether to short-circuit the identity mapping on legacy parts, restoring the previous behaviour. Reported-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17rapidio: fix hang on RapidIO doorbell queue full conditionThomas Taranowski
commit 12a4dc43911785f51a596f771ae0701b18d436f1 upstream. In fsl_rio_dbell_handler() the code currently simply acknowledges the QFI queue full interrupt, but does nothing to resolve the queue full condition. Instead, it jumps to the end of the isr. When a queue full condition occurs, the isr is then re-entered immediately and continually, forever. The fix is to just fall through and read out current doorbell entries. Signed-off-by: Thomas Taranowski <tom@baringforge.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: Micha Nelissen <micha@neli.hopto.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17x86, UV, BAU: Extend for more than 16 cpus per socketCliff Wickman
commit cfa60917f0ba6eca83f41aef3cb4a7dd7736ac9f upstream. Fix a hard-coded limit of a maximum of 16 cpu's per socket. The UV Broadcast Assist Unit code initializes by scanning the cpu topology of the system and assigning a master cpu for each socket and UV hub. That scan had an assumption of a limit of 16 cpus per socket. With Westmere we are going over that limit. The UV hub hardware will allow up to 32. If the scan finds the system has gone over that limit it returns an error and we print a warning and fall back to doing TLB shootdowns without the BAU. Signed-off-by: Cliff Wickman <cpw@sgi.com> LKML-Reference: <E1PZol7-0000mM-77@eag09.americas.sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-03Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pxa: fix page table corruption on resume ARM: it8152: add IT8152_LAST_IRQ definition to fix build error ARM: pxa: PXA_ESERIES depends on FB_W100. ARM: 6605/1: Add missing include "asm/memory.h" ARM: 6540/1: Stop irqsoff trace on return to user ARM: 6537/1: update Nomadik, U300 and Ux500 maintainers ARM: 6536/1: Add missing SZ_{32,64,128} ARM: fix cache-feroceon-l2 after stack based kmap_atomic() ARM: fix cache-xsc3l2 after stack based kmap_atomic() ARM: get rid of kmap_high_l1_vipt() ARM: smp: avoid incrementing mm_users on CPU startup ARM: pxa: PXA_ESERIES depends on FB_W100.
2011-01-03arch/mn10300/kernel/irq.c: fix buildAndrew Morton
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=25702 Reported-by: Martin Ettl <ettl.martin@gmx.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-03Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
2011-01-03ARM: pxa: fix page table corruption on resumeAric D. Blumer
Before this patch, the following error would sometimes occur after a resume on pxa3xx: /path/to/mm/memory.c:144: bad pmd 8040542e. The problem was that a temporary page table mapping was being improperly restored. The PXA3xx resume code creates a temporary mapping of resume_turn_on_mmu to avoid a prefetch abort. The pxa3xx_resume_after_mmu code requires that the r1 register holding the address of this mapping not be modified, however, resume_turn_on_mmu does modify it. It is mostly correct in that r1 receives the base table address, but it may also get other bits in 13:0. This results in pxa3xx_resume_after_mmu restoring the original mapping to the wrong place, corrupting memory and leaving the temporary mapping in place. Signed-off-by: Matt Reimer <mreimer@sdgsystems.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-03ARM: it8152: add IT8152_LAST_IRQ definition to fix build errorMike Rapoport
The commit 6ac6b817f3f4c23c5febd960d8deb343e13af5f3 (ARM: pxa: encode IRQ number into .nr_irqs) removed definition of ITE_LAST_IRQ which caused the following build error: CC arch/arm/common/it8152.o arch/arm/common/it8152.c: In function 'it8152_init_irq': arch/arm/common/it8152.c:86: error: 'IT8152_LAST_IRQ' undeclared (first use in this function) arch/arm/common/it8152.c:86: error: (Each undeclared identifier is reported only once arch/arm/common/it8152.c:86: error: for each function it appears in.) make[2]: *** [arch/arm/common/it8152.o] Error 1 Defining the IT8152_LAST_IRQ in the arch/arm/include/hardware/it8152.c fixes the build. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-03ARM: pxa: PXA_ESERIES depends on FB_W100.Lennert Buytenhek
As arch/arm/mach-pxa/eseries.c references w100fb_gpio_{read,write}() directly. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-01-03arch/x86/oprofile/op_model_amd.c: Perform initialisation on a single CPURobert Richter
Disable preemption in init_ibs(). The function only checks the ibs capabilities and sets up pci devices (if necessary). It runs only on one cpu but operates with the local APIC and some MSRs, thus it is better to disable preemption. [ 7.034377] BUG: using smp_processor_id() in preemptible [00000000] code: modprobe/483 [ 7.034385] caller is setup_APIC_eilvt+0x155/0x180 [ 7.034389] Pid: 483, comm: modprobe Not tainted 2.6.37-rc1-20101110+ #1 [ 7.034392] Call Trace: [ 7.034400] [<ffffffff812a2b72>] debug_smp_processor_id+0xd2/0xf0 [ 7.034404] [<ffffffff8101e985>] setup_APIC_eilvt+0x155/0x180 [ ... ] Addresses https://bugzilla.kernel.org/show_bug.cgi?id=22812 Reported-by: <atswartz@gmail.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Cc: oprofile-list@lists.sourceforge.net <oprofile-list@lists.sourceforge.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Dan Carpenter <error27@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: <stable@kernel.org> [2.6.37.x] LKML-Reference: <20110103111514.GM4739@erda.amd.com> [ small cleanups ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-03ARM: 6605/1: Add missing include "asm/memory.h"Axel Lin
This patch fixes below build error by adding the missing asm/memory.h, which is needed for arch_is_coherent(). $ make pxa3xx_defconfig; make CC init/do_mounts_rd.o In file included from include/linux/list_bl.h:5, from include/linux/rculist_bl.h:7, from include/linux/dcache.h:7, from include/linux/fs.h:381, from init/do_mounts_rd.c:3: include/linux/bit_spinlock.h: In function 'bit_spin_unlock': include/linux/bit_spinlock.h:61: error: implicit declaration of function 'arch_is_coherent' make[1]: *** [init/do_mounts_rd.o] Error 1 make: *** [init] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-02Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: i8259: initialize isr_ack KVM: MMU: Fix incorrect direct gfn for unpaged mode shadow
2011-01-02KVM: i8259: initialize isr_ackAvi Kivity
isr_ack is never initialized. So, until the first PIC reset, interrupts may fail to be injected. This can cause Windows XP to fail to boot, as reported in the fallout from the fix to https://bugzilla.kernel.org/show_bug.cgi?id=21962. Reported-and-tested-by: Nicolas Prochazka <prochazka.nicolas@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-12-29KVM: MMU: Fix incorrect direct gfn for unpaged mode shadowAvi Kivity
We use the physical address instead of the base gfn for the four PAE page directories we use in unpaged mode. When the guest accesses an address above 1GB that is backed by a large host page, a BUG_ON() in kvm_mmu_set_gfn() triggers. Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=21962 Reported-and-tested-by: Nicolas Prochazka <prochazka.nicolas@gmail.com> KVM-Stable-Tag. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-12-28Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/microcode: Fix double vfree() and remove redundant pointer checks before vfree()
2010-12-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: Fix re-probing with PM_POST_RESTORE notification mmc: atmel-mci: fix multiblock SDIO transfers mmc: at91_mci: fix multiblock SDIO transfers
2010-12-28ARM: fix IXP4xx build failureImre Kaloz
arm: export dma_set_coherent_mask While a regression was fixed with commit 710224fa2750cf (arm: fix "arm: fix pci_set_consistent_dma_mask for dmabounce devices"), a new one was introduced as dma_set_coherent_mask wasn't exported for modules. This patch takes care for this issue. Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-27Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: intc: Initialize radix tree gfp mask explicitly. sh: Fix up SH7201 clkfwk build. sh: mach-se: Fix up SE7206 build. sh: Fix up SH4-202 clkfwk build.
2010-12-27x86/microcode: Fix double vfree() and remove redundant pointer checks before ↵Jesper Juhl
vfree() In arch/x86/kernel/microcode_intel.c::generic_load_microcode() we have this: while (leftover) { ... if (get_ucode_data(mc, ucode_ptr, mc_size) || microcode_sanity_check(mc) < 0) { vfree(mc); break; } ... } if (mc) vfree(mc); This will cause a double free of 'mc'. This patch fixes that by just removing the vfree() call in the loop since 'mc' will be freed nicely just after we break out of the loop. There's also a second change in the patch. I noticed a lot of checks for pointers being NULL before passing them to vfree(). That's completely redundant since vfree() deals gracefully with being passed a NULL pointer. Removing the redundant checks yields a nice size decrease for the object file. Size before the patch: text data bss dec hex filename 4578 240 1032 5850 16da arch/x86/kernel/microcode_intel.o Size after the patch: text data bss dec hex filename 4489 240 984 5713 1651 arch/x86/kernel/microcode_intel.o Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Cc: Shaohua Li <shaohua.li@intel.com> LKML-Reference: <alpine.LNX.2.00.1012251946100.10759@swampdragon.chaosbits.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-24Merge branch 'merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'merge' of git://git.secretlab.ca/git/linux-2.6: spi/mpc52xx-spi: fix annotation for remove()-pointer spi/fsl_espi: fix wrong setting of the address in the command buffer spi/fsl_espi: change the read behaviour of the SPIRF of/i2c: Fix request module by alias powerpc/mpc5200: include fs.h in mpc52xx_gpt.c
2010-12-24ARM: 6540/1: Stop irqsoff trace on return to userTodd Android Poynor
If the irqsoff tracer is in use, stop tracing the interrupt disable interval when returning to userspace. Tracing userspace execution time as interrupts disabled time is not helpful for kernel performance analysis purposes. Only do so if the irqsoff tracer is enabled, to avoid overhead for lockdep, which doesn't care. Signed-off-by: Todd Poynor <toddpoynor@google.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-24ARM: 6536/1: Add missing SZ_{32,64,128}Stephen Warren
... and also remove misleading comment stating that this header is auto-generated. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Uwe Kleine-Knig <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-24sh: Fix up SH7201 clkfwk build.Paul Mundt
The master clock initialization for SH7201 was wholly bogus. Users of the legacy API must initialize the clock rate through the struct clk itself rather than returning the clock frequency. Given that the init function itself is void, returning the frequency isn't terribly effective. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-24sh: mach-se: Fix up SE7206 build.Paul Mundt
With some recent tidying of duplicate register definitions the se7206 IRQ code broke: arch/sh/boards/mach-se/7206/irq.c: error: 'INTC_ICR' undeclared (first use in this function) arch/sh/boards/mach-se/7206/irq.c: error: (Each undeclared identifier is reported only once arch/sh/boards/mach-se/7206/irq.c: error: for each function it appears in.) Fix it up. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-24sh: Fix up SH4-202 clkfwk build.Paul Mundt
Some of the SH4-202 code was overlooked in the set_rate() API conversion, resulting in: arch/sh/kernel/cpu/sh4/clock-sh4-202.c: error: too many arguments to function 'clk->ops->set_rate' Fix it up. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-23Merge branches 'perf-fixes-for-linus' and 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf probe: Fix to support libdwfl older than 0.148 perf tools: Fix lazy wildcard matching perf buildid-list: Fix error return for success perf buildid-cache: Fix symbolic link handling perf symbols: Stop using vmlinux files with no symbols perf probe: Fix use of kernel image path given by 'k' option * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, kexec: Limit the crashkernel address appropriately
2010-12-23powerpc/mpc5200: include fs.h in mpc52xx_gpt.cWolfram Sang
Fix build errors like these (from a randconfig and my defconfig for a custom board): src/arch/powerpc/platforms/52xx/mpc52xx_gpt.c:549: error: dereferencing pointer to incomplete type: 1 errors in 1 logs src/arch/powerpc/platforms/52xx/mpc52xx_gpt.c:636: error: implicit declaration of function 'nonseekable_open': 1 errors in 1 logs src/arch/powerpc/platforms/52xx/mpc52xx_gpt.c:657: error: variable 'mpc52xx_wdt_fops' has initializer but incomplete type: 1 errors in 1 logs src/arch/powerpc/platforms/52xx/mpc52xx_gpt.c:658: error: excess elements in struct initializer: 1 errors in 1 logs src/arch/powerpc/platforms/52xx/mpc52xx_gpt.c:658: error: unknown field 'owner' specified in initializer: 1 errors in 1 logs ... Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-22Merge branch 'fix' of ↵Russell King
2010-12-21mmc: at91_mci: fix multiblock SDIO transfersYauhen Kharuzhy
The AT91 MCI has special SDIO transfer types: SDIO block and SDIO byte transfers, but at91_mci driver doesn't use them and handles all SDIO transfers as ordinary MMC block transfers. This causes problems for multiple-block SDIO transfers (in particular for 256-bytes blocks). Fix this situation by checking the opcode for SDIO CMD53 and setting the transfer type in the AT91_MCI_CMDR register properly. This patch was tested with libertas SDIO driver: problem with TX timeouts on big packets was eliminated. Signed-off-by: Yauhen Kharuzhy <yauhen.kharuzhy@promwad.com> Cc: <stable@kernel.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-12-20Merge branch 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: ARM: mach-shmobile: INTC interrupt priority level demux fix ARM: mach-shmobile: fix compile warning in mm/init.c
2010-12-20Merge branch 's5p-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung * 's5p-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: S5PV210: update MAX8998 platform data to get rid of WARN() ARM S3C24XX: Fix compilation of PM code for S3C2416 ARM: S3C24XX: Fix CONFIG_S3C_DEV_NAND Kconfig entry
2010-12-20clarify a usage constraint for cnt32_to_63()Nicolas Pitre
The cnt32_to_63 algorithm relies on proper counter data evaluation ordering to work properly. This was missing from the provided documentation. Let's augment the documentation with the missing usage constraint and fix the only instance that got it wrong. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-20Merge branch 'kmap_atomic_fixes' of git://git.linaro.org/people/nico/linuxRussell King
2010-12-19Merge branches 'x86-fixes-for-linus' and 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32: Make sure we can map all of lowmem if we need to x86, vt-d: Handle previous faults after enabling fault handling x86: Enable the intr-remap fault handling after local APIC setup x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic mode x86, vt-d: Quirk for masking vtd spec errors to platform error handling logic x86, xsave: Use alloc_bootmem_align() instead of alloc_bootmem() bootmem: Add alloc_bootmem_align() x86, gcc-4.6: Use gcc -m options when building vdso x86: HPET: Chose a paranoid safe value for the ETIME check x86: io_apic: Avoid unused variable warning when CONFIG_GENERIC_PENDING_IRQ=n * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Fix off by one in perf_swevent_init() perf: Fix duplicate events with multiple-pmu vs software events ftrace: Have recordmcount honor endianness in fn_ELF_R_INFO scripts/tags.sh: Add magic for trace-events tracing: Fix panic when lseek() called on "trace" opened for writing
