path: root/block/Kconfig
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-08block: Add rdma affinity based queue mapping helperSagi Grimberg
Like pci and virtio, we add a rdma helper for affinity spreading. This achieves optimal mq affinity assignments according to the underlying rdma device affinity maps. Reviewed-by: Jens Axboe <axboe@fb.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Max Gurtovoy <maxg@mellanox.com> Signed-off-by: Sagi Grimberg <sagi@grimberg.me> Signed-off-by: Doug Ledford <dledford@redhat.com>
2017-05-12Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm fixes from Dan Williams: "Incremental fixes and a small feature addition on top of the main libnvdimm 4.12 pull request: - Geert noticed that tinyconfig was bloated by BLOCK selecting DAX. The size regression is fixed by moving all dax helpers into the dax-core and only specifying "select DAX" for FS_DAX and dax-capable drivers. He also asked for clarification of the NR_DEV_DAX config option which, on closer look, does not need to be a config option at all. Mike also throws in a DEV_DAX_PMEM fixup for good measure. - Ben's attention to detail on -stable patch submissions caught a case where the recent fixes to arch_copy_from_iter_pmem() missed a condition where we strand dirty data in the cache. This is tagged for -stable and will also be included in the rework of the pmem api to a proposed {memcpy,copy_user}_flushcache() interface for 4.13. - Vishal adds a feature that missed the initial pull due to pending review feedback. It allows the kernel to clear media errors when initializing a BTT (atomic sector update driver) instance on a pmem namespace. - Ross noticed that the dax_device + dax_operations conversion broke __dax_zero_page_range(). The nvdimm unit tests fail to check this path, but xfstests immediately trips over it. No excuse for missing this before submitting the 4.12 pull request. These all pass the nvdimm unit tests and an xfstests spot check. The set has received a build success notification from the kbuild robot" * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: filesystem-dax: fix broken __dax_zero_page_range() conversion libnvdimm, btt: ensure that initializing metadata clears poison libnvdimm: add an atomic vs process context flag to rw_bytes x86, pmem: Fix cache flushing for iovec write < 8 bytes device-dax: kill NR_DEV_DAX block, dax: move "select DAX" from BLOCK to FS_DAX device-dax: Tell kbuild DEV_DAX_PMEM depends on DEV_DAX
2017-05-08block, dax: move "select DAX" from BLOCK to FS_DAXDan Williams
For configurations that do not enable DAX filesystems or drivers, do not require the DAX core to be built. Given that the 'direct_access' method has been removed from 'block_device_operations', we can also go ahead and remove the block-related dax helper functions from fs/block_dev.c to drivers/dax/super.c. This keeps dax details out of the block layer and lets the DAX core be built as a module in the FS_DAX=n case. Filesystems need to include dax.h to call bdev_dax_supported(). Cc: linux-xfs@vger.kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Matthew Wilcox <mawilcox@microsoft.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: "Darrick J. Wong" <darrick.wong@oracle.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Reviewed-by: Jan Kara <jack@suse.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2017-05-05Merge tag 'libnvdimm-for-4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "The bulk of this has been in multiple -next releases. There were a few late breaking fixes and small features that got added in the last couple days, but the whole set has received a build success notification from the kbuild robot. Change summary: - Region media error reporting: A libnvdimm region device is the parent to one or more namespaces. To date, media errors have been reported via the "badblocks" attribute attached to pmem block devices for namespaces in "raw" or "memory" mode. Given that namespaces can be in "device-dax" or "btt-sector" mode this new interface reports media errors generically, i.e. independent of namespace modes or state. This subsequently allows userspace tooling to craft "ACPI 6.1 Section 9.20.7.6 Function Index 4 - Clear Uncorrectable Error" requests and submit them via the ioctl path for NVDIMM root bus devices. - Introduce 'struct dax_device' and 'struct dax_operations': Prompted by a request from Linus and feedback from Christoph this allows for dax capable drivers to publish their own custom dax operations. This fixes the broken assumption that all dax operations are related to a persistent memory device, and makes it easier for other architectures and platforms to add customized persistent memory support. - 'libnvdimm' core updates: A new "deep_flush" sysfs attribute is available for storage appliance applications to manually trigger memory controllers to drain write-pending buffers that would otherwise be flushed automatically by the platform ADR (asynchronous-DRAM-refresh) mechanism at a power loss event. Support for "locked" DIMMs is included to prevent namespaces from surfacing when the namespace label data area is locked. Finally, fixes for various reported deadlocks and crashes, also tagged for -stable. - ACPI / nfit driver updates: General updates of the nfit driver to add DSM command overrides, ACPI 6.1 health state flags support, DSM payload debug available by default, and various fixes. Acknowledgements that came after the branch was pushed: - commmit 565851c972b5 "device-dax: fix sysfs attribute deadlock": Tested-by: Yi Zhang <yizhan@redhat.com> - commit 23f498448362 "libnvdimm: rework region badblocks clearing" Tested-by: Toshi Kani <toshi.kani@hpe.com>" * tag 'libnvdimm-for-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (52 commits) libnvdimm, pfn: fix 'npfns' vs section alignment libnvdimm: handle locked label storage areas libnvdimm: convert NDD_ flags to use bitops, introduce NDD_LOCKED brd: fix uninitialized use of brd->dax_dev block, dax: use correct format string in bdev_dax_supported device-dax: fix sysfs attribute deadlock libnvdimm: restore "libnvdimm: band aid btt vs clear poison locking" libnvdimm: fix nvdimm_bus_lock() vs device_lock() ordering libnvdimm: rework region badblocks clearing acpi, nfit: kill ACPI_NFIT_DEBUG libnvdimm: fix clear length of nvdimm_forget_poison() libnvdimm, pmem: fix a NULL pointer BUG in nd_pmem_notify libnvdimm, region: sysfs trigger for nvdimm_flush() libnvdimm: fix phys_addr for nvdimm_clear_poison x86, dax, pmem: remove indirection around memcpy_from_pmem() block: remove block_device_operations ->direct_access() block, dax: convert bdev_dax_supported() to dax_direct_access() filesystem-dax: convert to dax_direct_access() Revert "block: use DAX for partition table reads" ext2, ext4, xfs: retrieve dax_device for iomap operations ...
2017-04-20dax: introduce dax_direct_access()Dan Williams
Replace bdev_direct_access() with dax_direct_access() that uses dax_device and dax_operations instead of a block_device and block_device_operations for dax. Once all consumers of the old api have been converted bdev_direct_access() will be deleted. Given that block device partitioning decisions can cause dax page alignment constraints to be violated this also introduces the bdev_dax_pgoff() helper. It handles calculating a logical pgoff relative to the dax_device and also checks for page alignment. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2017-03-28blk-throttle: add configure option for new .low interfaceShaohua Li
As discussed in LSF, add configure option for the interface and mark it as experimental, so people can try/test. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-03-02Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull vhost updates from Michael Tsirkin: "virtio, vhost: optimizations, fixes Looks like a quiet cycle for vhost/virtio, just a couple of minor tweaks. Most notable is automatic interrupt affinity for blk and scsi. Hopefully other devices are not far behind" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio-console: avoid DMA from stack vhost: introduce O(1) vq metadata cache virtio_scsi: use virtio IRQ affinity virtio_blk: use virtio IRQ affinity blk-mq: provide a default queue mapping for virtio device virtio: provide a method to get the IRQ affinity mask for a virtqueue virtio: allow drivers to request IRQ affinity when creating VQs virtio_pci: simplify MSI-X setup virtio_pci: don't duplicate the msix_enable flag in struct pci_dev virtio_pci: use shared interrupts for virtqueues virtio_pci: remove struct virtio_pci_vq_info vhost: try avoiding avail index access when getting descriptor virtio_mmio: expose header to userspace
2017-02-27blk-mq: provide a default queue mapping for virtio deviceChristoph Hellwig
Similar to the PCI version, just calling into virtio instead. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2017-02-17Merge branch 'for-4.11/next' into for-4.11/linus-mergeJens Axboe
2017-02-06block: Add Sed-opal libraryScott Bauer
This patch implements the necessary logic to bring an Opal enabled drive out of a factory-enabled into a working Opal state. This patch set also enables logic to save a password to be replayed during a resume from suspend. Signed-off-by: Scott Bauer <scott.bauer@intel.com> Signed-off-by: Rafael Antognolli <Rafael.Antognolli@intel.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31block: make scsi_request and scsi ioctl support optionalChristoph Hellwig
We only need this code to support scsi, ide, cciss and virtio. And at least for virtio it's a deprecated feature to start with. This should shrink the kernel size for embedded device that only use, say eMMC a bit. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-27blk-mq: fix debugfs compilation issuesOmar Sandoval
This fixes a couple of problems: 1. In the !CONFIG_DEBUG_FS case, the stub definitions were bogus. 2. In the !CONFIG_BLOCK case, blk-mq-debugfs.c shouldn't be compiled at all. Fix the stub definitions and add a CONFIG_BLK_DEBUG_FS Kconfig option. Fixes: 07e4fead45e6 ("blk-mq: create debugfs directory tree") Signed-off-by: Omar Sandoval <osandov@fb.com> Augment Kconfig description. Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-10block: hook up writeback throttlingJens Axboe
Enable throttling of buffered writeback to make it a lot more smooth, and has way less impact on other system activity. Background writeback should be, by definition, background activity. The fact that we flush huge bundles of it at the time means that it potentially has heavy impacts on foreground workloads, which isn't ideal. We can't easily limit the sizes of writes that we do, since that would impact file system layout in the presence of delayed allocation. So just throttle back buffered writeback, unless someone is waiting for it. The algorithm for when to throttle takes its inspiration in the CoDel networking scheduling algorithm. Like CoDel, blk-wb monitors the minimum latencies of requests over a window of time. In that window of time, if the minimum latency of any request exceeds a given target, then a scale count is incremented and the queue depth is shrunk. The next monitoring window is shrunk accordingly. Unlike CoDel, if we hit a window that exhibits good behavior, then we simply increment the scale count and re-calculate the limits for that scale value. This prevents us from oscillating between a close-to-ideal value and max all the time, instead remaining in the windows where we get good behavior. Unlike CoDel, blk-wb allows the scale count to to negative. This happens if we primarily have writes going on. Unlike positive scale counts, this doesn't change the size of the monitoring window. When the heavy writers finish, blk-bw quickly snaps back to it's stable state of a zero scale count. The patch registers a sysfs entry, 'wb_lat_usec'. This sets the latency target to me met. It defaults to 2 msec for non-rotational storage, and 75 msec for rotational storage. Setting this value to '0' disables blk-wb. Generally, a user would not have to touch this setting. We don't enable WBT on devices that are managed with CFQ, and have a non-root block cgroup attached. If we have a proportional share setup on this particular disk, then the wbt throttling will interfere with that. We don't have a strong need for wbt for that case, since we will rely on CFQ doing that for us. Signed-off-by: Jens Axboe <axboe@fb.com>
2016-11-02blk-mq: Introduce blk_mq_quiesce_queue()Bart Van Assche
blk_mq_quiesce_queue() waits until ongoing .queue_rq() invocations have finished. This function does *not* wait until all outstanding requests have finished (this means invocation of request.end_io()). The algorithm used by blk_mq_quiesce_queue() is as follows: * Hold either an RCU read lock or an SRCU read lock around .queue_rq() calls. The former is used if .queue_rq() does not block and the latter if .queue_rq() may block. * blk_mq_quiesce_queue() first calls blk_mq_stop_hw_queues() followed by synchronize_srcu() or synchronize_rcu(). The latter call waits for .queue_rq() invocations that started before blk_mq_quiesce_queue() was called. * The blk_mq_hctx_stopped() calls that control whether or not .queue_rq() will be called are called with the (S)RCU read lock held. This is necessary to avoid race conditions against blk_mq_quiesce_queue(). Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Hannes Reinecke <hare@suse.com> Cc: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-18block: Implement support for zoned block devicesHannes Reinecke
Implement zoned block device zone information reporting and reset. Zone information are reported as struct blk_zone. This implementation does not differentiate between host-aware and host-managed device models and is valid for both. Two functions are provided: blkdev_report_zones for discovering the zone configuration of a zoned block device, and blkdev_reset_zones for resetting the write pointer of sequential zones. The helper function blk_queue_zone_size and bdev_zone_size are also provided for, as the name suggest, obtaining the zone size (in 512B sectors) of the zones of the device. Signed-off-by: Hannes Reinecke <hare@suse.de> [Damien: * Removed the zone cache * Implement report zones operation based on earlier proposal by Shaun Tancheff <shaun.tancheff@seagate.com>] Signed-off-by: Damien Le Moal <damien.lemoal@hgst.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Shaun Tancheff <shaun.tancheff@seagate.com> Tested-by: Shaun Tancheff <shaun.tancheff@seagate.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-09Merge branch 'for-4.9/block-irq' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull blk-mq irq/cpu mapping updates from Jens Axboe: "This is the block-irq topic branch for 4.9-rc. It's mostly from Christoph, and it allows drivers to specify their own mappings, and more importantly, to share the blk-mq mappings with the IRQ affinity mappings. It's a good step towards making this work better out of the box" * 'for-4.9/block-irq' of git://git.kernel.dk/linux-block: blk_mq: linux/blk-mq.h does not include all the headers it depends on blk-mq: kill unused blk_mq_create_mq_map() blk-mq: get rid of the cpumask in struct blk_mq_tags nvme: remove the post_scan callout nvme: switch to use pci_alloc_irq_vectors blk-mq: provide a default queue mapping for PCI device blk-mq: allow the driver to pass in a queue mapping blk-mq: remove ->map_queue blk-mq: only allocate a single mq_map per tag_set blk-mq: don't redistribute hardware queues on a CPU hotplug event
2016-09-19blk_mq: linux/blk-mq.h does not include all the headers it depends onStephen Rothwell
and building block/blk-mq-pci.o should depend on CONFIG_BLOCK Fixes: 973c4e372c8f ("blk-mq: provide a default queue mapping for PCI device") Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-09-17blk-mq: abstract tag allocation out into sbitmap libraryOmar Sandoval
This is a generally useful data structure, so make it available to anyone else who might want to use it. It's also a nice cleanup separating the allocation logic from the rest of the tag handling logic. The code is behind a new Kconfig option, CONFIG_SBITMAP, which is only selected by CONFIG_BLOCK for now. This should be a complete noop functionality-wise. Signed-off-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-08-04block: remove BLK_DEV_DAX config optionRoss Zwisler
The functionality for block device DAX was already removed with commit acc93d30d7d4 ("Revert "block: enable dax for raw block devices"") However, we still had a config option hanging around that was always disabled because it depended on CONFIG_BROKEN. This config option was introduced in commit 03cdadb04077 ("block: disable block device DAX by default") This change reverts that commit, removing the dead config option. Link: http://lkml.kernel.org/r/20160729182314.6368-1-ross.zwisler@linux.intel.com Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-27block: disable block device DAX by defaultDan Williams
The recent *sync enabling discovered that we are inserting into the block_device pagecache counter to the expectations of the dirty data tracking for dax mappings. This can lead to data corruption. We want to support DAX for block devices eventually, but it requires wider changes to properly manage the pagecache. dump_stack+0x85/0xc2 dax_writeback_mapping_range+0x60/0xe0 blkdev_writepages+0x3f/0x50 do_writepages+0x21/0x30 __filemap_fdatawrite_range+0xc6/0x100 filemap_write_and_wait+0x4a/0xa0 set_blocksize+0x70/0xd0 sb_set_blocksize+0x1d/0x50 ext4_fill_super+0x75b/0x3360 mount_bdev+0x180/0x1b0 ext4_mount+0x15/0x20 mount_fs+0x38/0x170 Mark the support broken so its disabled by default, but otherwise still available for testing. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com> Reported-by: Ross Zwisler <ross.zwisler@linux.intel.com> Suggested-by: Dave Chinner <david@fromorbit.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@fb.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-27block: Add T10 Protection Information functionsMartin K. Petersen
The T10 Protection Information format is also used by some devices that do not go through the SCSI layer (virtual block devices, NVMe). Relocate the relevant functions to a block layer library that can be used without involving SCSI. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2013-09-30block: change config option name for cmdline partition parsingPaul Gortmaker
Recently commit bab55417b10c ("block: support embedded device command line partition") introduced CONFIG_CMDLINE_PARSER. However, that name is too generic and sounds like it enables/disables generic kernel boot arg processing, when it really is block specific. Before this option becomes a part of a full/final release, add the BLK_ prefix to it so that it is clear in absence of any other context that it is block specific. In addition, fix up the following less critical items: - help text was not really at all helpful. - index file for Documentation was not updated - add the new arg to Documentation/kernel-parameters.txt - clarify wording in source comments Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Cai Zhiyong <caizhiyong@huawei.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11block: support embedded device command line partitionCai Zhiyong
Read block device partition table from command line. The partition used for fixed block device (eMMC) embedded device. It is no MBR, save storage space. Bootloader can be easily accessed by absolute address of data on the block device. Users can easily change the partition. This code reference MTD partition, source "drivers/mtd/cmdlinepart.c" About the partition verbose reference "Documentation/block/cmdline-partition.txt" [akpm@linux-foundation.org: fix printk text] [yongjun_wei@trendmicro.com.cn: fix error return code in parse_parts()] Signed-off-by: Cai Zhiyong <caizhiyong@huawei.com> Cc: Karel Zak <kzak@redhat.com> Cc: "Wanglin (Albert)" <albert.wanglin@huawei.com> Cc: Marius Groeger <mag@sysgo.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Brian Norris <computersforpeace@gmail.com> Cc: Artem Bityutskiy <dedekind@infradead.org> Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22block: don't select PERCPU_RWSEMMikulas Patocka
The block device doesn't use percpu rw-semaphore anymore, so don't select it for compilation. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-12-17percpu_rw_semaphore: introduce CONFIG_PERCPU_RWSEMOleg Nesterov
Currently only block_dev and uprobes use percpu_rw_semaphore, add the config option selected by BLOCK || UPROBES. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Anton Arapov <anton@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-23block: remove CONFIG_EXPERIMENTALKees Cook
This config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it. CC: Jens Axboe <axboe@kernel.dk> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-03move fs/partitions to block/Al Viro
2011-07-31block: add bsg helper libraryMike Christie
This moves the FC classes bsg code to the block layer and makes it a lib so that other classes like iscsi and SAS can use it. It is helpful because working with the request queue, bios, creating scatterlists, etc are a pain that the LLD does not have to worry about with normal IOs and should not have to worry about for bsg requests. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-16blkio: Core implementation of throttle policyVivek Goyal
o Actual implementation of throttling policy in block layer. Currently it implements READ and WRITE bytes per second throttling logic. IOPS throttling comes in later patches. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-04-26blk-cgroup: config options re-arrangementVivek Goyal
This patch fixes few usability and configurability issues. o All the cgroup based controller options are configurable from "Genral Setup/Control Group Support/" menu. blkio is the only exception. Hence make this option visible in above menu and make it configurable from there to bring it inline with rest of the cgroup based controllers. o Get rid of CONFIG_DEBUG_CFQ_IOSCHED. This option currently does two things. - Enable printing of cgroup paths in blktrace - Enables CONFIG_DEBUG_BLK_CGROUP, which in turn displays additional stat files in cgroup. If we are using group scheduling, blktrace data is of not really much use if cgroup information is not present. To get this data, currently one has to also enable CONFIG_DEBUG_CFQ_IOSCHED, which in turn brings the overhead of all the additional debug stat files which is not desired. Hence, this patch moves printing of cgroup paths under CONFIG_CFQ_GROUP_IOSCHED. This allows us to get rid of CONFIG_DEBUG_CFQ_IOSCHED completely. Now all the debug stat files are controlled only by CONFIG_DEBUG_BLK_CGROUP which can be enabled through config menu. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Divyesh Shah <dpshah@google.com> Reviewed-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-16block: make CONFIG_BLK_CGROUP visibleLi Zefan
Make the config visible, so we can choose from CONFIG_BLK_CGROUP=y and CONFIG_BLK_CGROUP=m when CONFIG_IOSCHED_CFQ=m. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-03blkio: Some debugging aids for CFQVivek Goyal
o Some debugging aids for CFQ. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-03blkio: Introduce blkio controller cgroup interfaceVivek Goyal
o This is basic implementation of blkio controller cgroup interface. This is the common interface visible to user space and should be used by different IO control policies as we implement those. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-04Make SCSI SG v4 driver enabled by default and remove EXPERIMENTAL ↵John Stoffel
dependency, since udev depends on BSG Make Block Layer SG support v4 the default, since recent udev versions depend on this to access serial numbers and other low level info properly. This should be backported to older kernels as well, since most distros have enabled this for a long time. Signed-off-by: John Stoffel <john@stoffel.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-19block: rename CONFIG_LBD to CONFIG_LBDAFBartlomiej Zolnierkiewicz
Follow-up to "block: enable by default support for large devices and files on 32-bit archs". Rename CONFIG_LBD to CONFIG_LBDAF to: - allow update of existing [def]configs for "default y" change - reflect that it is used also for large files support nowadays Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: enable by default support for large devices and files on 32-bit archsBartlomiej Zolnierkiewicz
Enable by default support for large devices and files (CONFIG_LBD): - With 1TB disks being a commodity hardware it is quite easy to hit 2TB limitation while building RAIDs etc. and many distros have been using CONFIG_LBD=y by default already (at least Fedora 10 and openSUSE 11.1). - This should also prevent a subtle ext4 filesystem compatibility issue: mke2fs.ext4 defaults to creating filesystems with huge_files feature enabled and such filesystems cannot be later mounted read-write on machines with CONFIG_LBD=n (it should be quite easy to hit this issue when trying to use filesystem created using distro kernel on system running the self-build kernel, think about USB disk enclosures & co.). While at it: - Clarify config option help text w.r.t. mounting ext4 filesystems (they can be mounted with CONFIG_LBD=n but in the read-only mode). Cc: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-09tracing/blktrace: move the tracing file to kernel/traceFrederic Weisbecker
Impact: cleanup Move blktrace.c to kernel/trace, also move its config entry. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-27blktrace: the ftrace interface needs CONFIG_TRACINGArnaldo Carvalho de Melo
Impact: build fix Also mention in the help text that blktrace now can be used using the ftrace interface. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06block: Add Kconfig help which notes that ext4 needs CONFIG_LBDTheodore Ts'o
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Jens Axboe <jens.axboe@oracle.com>
2008-12-29Get rid of CONFIG_LSFJens Axboe
We have two seperate config entries for large devices/files. One is CONFIG_LBD that guards just the devices, the other is CONFIG_LSF that handles large files. This doesn't make a lot of sense, you typically want both or none. So get rid of CONFIG_LSF and change CONFIG_LBD wording to indicate that it covers both. Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-26blktrace: port to tracepointsArnaldo Carvalho de Melo
This was a forward port of work done by Mathieu Desnoyers, I changed it to encode the 'what' parameter on the tracepoint name, so that one can register interest in specific events and not on classes of events to then check the 'what' parameter. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-21Kconfig: clean up block/Kconfig help descriptionsNick Andrew
Modify the help descriptions of block/Kconfig for clarity, accuracy and consistency. Refactor the BLOCK description a bit. The wording "This permits ... to be removed" isn't quite right; the block layer is removed when the option is disabled, whereas most descriptions talk about what happens when the option is enabled. Reformat the list of what is affected by disabling the block layer. Add more examples of large block devices to LBD and strive for technical accuracy; block devices of size _exactly_ 2TB require CONFIG_LBD, not only "bigger than 2TB". Also try to say (perhaps not very clearly) that the config option is only needed when you want to have individual block devices of size >= 2TB, for example if you had 3 x 1TB disks in your computer you'd have a total storage size of 3TB but you wouldn't need the option unless you want to aggregate those disks into a RAID or LVM. Improve terminology and grammar on BLK_DEV_IO_TRACE. I also added the boilerplate "If unsure, say N" to most options. Precisely say "2TB and larger" for LSF. Indent the help text for BLK_DEV_BSG by 2 spaces in accordance with the standard. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-15block: update git url for blktraceJens Axboe
2007-10-12Only enable BLOCK_COMPAT if COMPAT is neededLinus Torvalds
IOW, it needs to depend on both CONFIG_BLOCK and CONFIG_COMPAT. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[BLOCK] Only include the compat ioctl code if CONFIG_BLOCK is setJens Axboe
Add an extra CONFIG_BLOCK_COMPAT that we can use in the Makefile Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-27bsg: Fix build for CONFIG_BLOCK=nPaul Mundt
BLK_DEV_BSG was added outside of the if BLOCK check, which allows it to be enabled when CONFIG_BLOCK=n. This leads to many screenlengths of errors, starting with a parse error on the request_queue_t definition. Obviously this wasn't intended for CONFIG_BLOCK=n usage, so just move the option back in to the block. Caught with a randconfig on sh. Signed-off-by: Paul Mundt <lethal@linux-sh.org> -- block/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-) Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-19[SCSI] bsg: separate bsg and SCSI (so SCSI can be modular)James Bottomley
This patch moves the bsg registration into SCSI so that bsg no longer has a dependency on the scsi_interface_register API. This can be viewed as a temporary expedient until we can get universal bsg binding sorted out properly. Also use the sdev bus_id as the generic bsg name (to avoid clashes with the queue name). Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
