path: root/block/bio-integrity.c
2014-12-02block: fix regression where bio_integrity_process uses wrong bio_vec iteratorDarrick J. Wong
bio integrity handling is broken on a system with LVM layered atop a DIF/DIX SCSI drive because device mapper clones the bio, modifies the clone, and sends the clone to the lower layers for processing. However, the clone bio has bi_vcnt == 0, which means that when the sd driver calls bio_integrity_process to attach DIX data, the for_each_segment_all() call (which uses bi_vcnt) returns immediately and random garbage is sent to the disk on a disk write. The disk of course returns an error. Therefore, teach bio_integrity_process() to use bio_for_each_segment() to iterate the bio_vecs, since the per-bio iterator tracks which bio_vecs are associated with that particular bio. The integrity handling code is effectively part of the "driver" (it's not the bio owner), so it must use the correct iterator function. v2: Fix a compiler warning about abandoned local variables. This patch supersedes "block: bio_integrity_process uses wrong bio_vec iterator". Patch applies against 3.18-rc6. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-13bio-integrity: remove the needless fail handle of bip_slab creatingGu Zheng
bip_slab is created with SLAB_PANIC, so the fail handler is unneeded. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Integrity checksum flagMartin K. Petersen
Make the choice of checksum a per-I/O property by introducing a flag that can be inspected by the SCSI layer. There are several reasons for this: 1. It allows us to switch choice of checksum without unloading and reloading the HBA driver. 2. During error recovery we need to be able to tell the HBA that checksums read from disk should not be verified and converted to IP checksums. 3. For error injection purposes we need to be able to write a bad guard tag to storage. Since the storage device only supports T10 CRC we need to be able to disable IP checksum conversion on the HBA. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Relocate bio integrity flagsMartin K. Petersen
Move flags affecting the integrity code out of the bio bi_flags and into the block integrity payload. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Add prefix to block integrity profile flagsMartin K. Petersen
Add a BLK_ prefix to the integrity profile flags. Also rename the flags to be more consistent with the generate/verify terminology in the rest of the integrity code. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Clean up the code used to generate and verify integrity metadataMartin K. Petersen
Instead of the "operate" parameter we pass in a seed value and a pointer to a function that can be used to process the integrity metadata. The generation function is changed to have a return value to fit into this scheme. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Make protection interval calculation genericMartin K. Petersen
Now that the protection interval has been detached from the sector size we need to be able to handle sizes that are different from 4K and 512. Make the interval calculation generic. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Deprecate the use of the term sector in the context of block integrityMartin K. Petersen
The protection interval is not necessarily tied to the logical block size of a block device. Stop using the terms "sector" and "sectors". Going forward we will use the term "seed" to describe the initial reference tag value for a given I/O. "Interval" will be used to describe the portion of the data buffer that a given piece of protection information is associated with. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Remove bip_bufMartin K. Petersen
bip_buf is not really needed so we can remove it. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Remove integrity tagging functionsMartin K. Petersen
None of the filesystems appear interested in using the integrity tagging feature. Potentially because very few storage devices actually permit using the application tag space. Remove the tagging functions. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Replace bi_integrity with bi_specialMartin K. Petersen
For commands like REQ_COPY we need a way to pass extra information along with each bio. Like integrity metadata this information must be available at the bottom of the stack so bi_private does not suffice. Rename the existing bi_integrity field to bi_special and make it a union so we can have different bio extensions for each class of command. We previously used bi_integrity != NULL as a way to identify whether a bio had integrity metadata or not. Introduce a REQ_INTEGRITY to be the indicator now that bi_special can contain different things. In addition, bio_integrity(bio) will now return a pointer to the integrity payload (when applicable). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Get rid of bdev_integrity_enabled()Martin K. Petersen
bdev_integrity_enabled() is only used by bio_integrity_enabled(). Combine these two functions. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-21block: Fix BUG_ON when pi errors occurSagi Grimberg
When getting a pi error we get to bio_integrity_end_io with bi_remaining already decremented to 0 where we will eventually need to call bio_endio with restored original bio completion handler. Calling bio_endio invokes a BUG_ON(). We should call bio_endio_nodec instead, like what is done in bio_integrity_verify_fn. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-07-01bio-integrity: add "bip_max_vcnt" into struct bio_integrity_payloadGu Zheng
Commit 08778795 ("block: Fix nr_vecs for inline integrity vectors") from Martin introduces the function bip_integrity_vecs(get the useful vectors) to fix the issue about nr_vecs for inline integrity vectors that reported by David Milburn. But it seems that bip_integrity_vecs() will return the wrong number if the bio is not based on any bio_set for some reason(bio->bi_pool == NULL), because in that case, the bip_inline_vecs[0] is malloced directly. So here we add the bip_max_vcnt to record the count of vector slots, and cleanup the function bip_integrity_vecs(). Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Kent Overstreet <kmo@daterainc.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-05-19block: move bio.c and bio-integrity.c from fs/ to block/Jens Axboe
They really belong in block/, especially now since it's not in drivers/block/ anymore. Additionally, the get_maintainer script gets it wrong when in fs/. Suggested-by: Christoph Hellwig <hch@infradead.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jens Axboe <axboe@fb.com>
