commit 5151412dd4338b273afdb107c3772528e9e67d92 upstream.
struct request_queue is allocated with __GFP_ZERO so its "node" field is
zero before initialization. This causes an oops if node 0 is offline in
the page allocator because its zonelists are not initialized. From Dave
Young's dmesg:
SRAT: Node 1 PXM 2 0-d0000000
SRAT: Node 1 PXM 2 100000000-330000000
SRAT: Node 0 PXM 1 330000000-630000000
Initmem setup node 1 0000000000000000-000000000affb000
Built 1 zonelists in Node order, mobility grouping on.
BUG: unable to handle kernel paging request at 0000000000001c08
IP: [<ffffffff8111c355>] __alloc_pages_nodemask+0xb5/0x870
and __alloc_pages_nodemask+0xb5 translates to a NULL pointer on
zonelist->_zonerefs.
The fix is to initialize q->node at the time of allocation so the correct
node is passed to the slab allocator later.
Since blk_init_allocated_queue_node() is no longer needed, merge it with
blk_init_allocated_queue().
[rientjes@google.com: changelog, initializing q->node]
Reported-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Tested-by: Dave Young <dyoung@redhat.com>
Change-Id: I24b14588aef6226f3bcdf37e78af61cbe9a31fd2
Reviewed-on: http://git-master/r/74168
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
commit e67b77c791ca2778198c9e7088f3266ed2da7a55 upstream.
A dm-multipath user reported[1] a problem when trying to boot
a kernel with commit 4853abaae7e4a2af938115ce9071ef8684fb7af4
(block: fix flush machinery for stacking drivers with differring
flush flags) applied. It turns out that an empty flush request
can be sent into blk_insert_flush. When the BUG_ON was fixed
to allow for this, I/O on the underlying device would stall. The
reason is that blk_insert_cloned_request does not kick the queue.
In the aforementioned commit, I had added a special case to
kick the queue if data was sent down but the queue flags did
not require a flush. A better solution is to push the queue
kick up into blk_insert_cloned_request.
This patch, along with a follow-on which fixes the BUG_ON, fixes
the issue reported.
[1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html
Reported-by: Christophe Saout <christophe@saout.de>
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
A kernel crash is observed when a mounted ext3/ext4 filesystem is
physically removed. The problem is that blk_cleanup_queue() frees up
some resources eg by calling elevator_exit(), which are not checked for
in normal operation. So we should rather move these calls to the
destructor function blk_release_queue() as at that point all remaining
references are gone. However, in doing so we have to ensure that any
externally supplied queue_lock is disconnected as the driver might free
up the lock after the call of blk_cleanup_queue(),
Signed-off-by: Hannes Reinecke <hare@suse.de>
Cleaning up the code a little bit. attempt_plug_merge() traverses the plug
list anyway, we can do the request counting there, so stack size is reduced
a little bit.
The motivation here is I suspect if we should count the requests for each
queue (task could handle multiple disks in the meantime), but my test doesn't
show it's worthy doing. If somebody proves we should do it, below change
will make that more easier.
Signed-off-by: Shaohua Li <shli@kernel.org>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Do blk_flush_plug_list() first and then add new request aDo blk_flush_plug_list() first and then add new request aDo blk_flush_plug_list() first and then add new request at the tail. New
request can't be merged to existing requests, but later new requests might
be merged with this new one. If blk_flush_plug_list() is done later, the
merge doesn't happen.
Believe it or not, this fixes a 10% regression running sysbench workload.
* 'for-linus' of git://git.kernel.dk/linux-block: (23 commits)
Revert "cfq: Remove special treatment for metadata rqs."
block: fix flush machinery for stacking drivers with differring flush flags
block: improve rq_affinity placement
blktrace: add FLUSH/FUA support
Move some REQ flags to the common bio/request area
allow blk_flush_policy to return REQ_FSEQ_DATA independent of *FLUSH
xen/blkback: Make description more obvious.
cfq-iosched: Add documentation about idling
block: Make rq_affinity = 1 work as expected
block: swim3: fix unterminated of_device_id table
block/genhd.c: remove useless cast in diskstats_show()
drivers/cdrom/cdrom.c: relax check on dvd manufacturer value
drivers/block/drbd/drbd_nl.c: use bitmap_parse instead of __bitmap_parse
bsg-lib: add module.h include
cfq-iosched: Reduce linked group count upon group destruction
blk-throttle: correctly determine sync bio
loop: fix deadlock when sysfs and LOOP_CLR_FD race against each other
loop: add BLK_DEV_LOOP_MIN_COUNT=%i to allow distros 0 pre-allocated loop devices
loop: add management interface for on-demand device allocation
loop: replace linked list of allocated devices with an idr index
Commit ae1b1539622fb46e51b4d13b3f9e5f4c713f86ae, block: reimplement
FLUSH/FUA to support merge, introduced a performance regression when
running any sort of fsyncing workload using dm-multipath and certain
storage (in our case, an HP EVA). The test I ran was fs_mark, and it
dropped from ~800 files/sec on ext4 to ~100 files/sec. It turns out
that dm-multipath always advertised flush+fua support, and passed
commands on down the stack, where those flags used to get stripped off.
The above commit changed that behavior:
static inline struct request *__elv_next_request(struct request_queue *q)
struct request *rq;
while (1) {
- while (!list_empty(&q->queue_head)) {
+ if (!list_empty(&q->queue_head)) {
rq = list_entry_rq(q->queue_head.next);
- if (!(rq->cmd_flags & (REQ_FLUSH | REQ_FUA)) ||
- (rq->cmd_flags & REQ_FLUSH_SEQ))
- return rq;
- rq = blk_do_flush(q, rq);
- if (rq)
- return rq;
+ return rq;
Note that previously, a command would come in here, have
REQ_FLUSH|REQ_FUA set, and then get handed off to blk_do_flush:
struct request *blk_do_flush(struct request_queue *q, struct request *rq)
unsigned int fflags = q->flush_flags; /* may change, cache it */
bool has_flush = fflags & REQ_FLUSH, has_fua = fflags & REQ_FUA;
bool do_preflush = has_flush && (rq->cmd_flags & REQ_FLUSH);
bool do_postflush = has_flush && !has_fua && (rq->cmd_flags &
REQ_FUA);
unsigned skip = 0;
if (blk_rq_sectors(rq) && !do_preflush && !do_postflush) {
rq->cmd_flags &= ~REQ_FLUSH;
if (!has_fua)
rq->cmd_flags &= ~REQ_FUA;
return rq;
So, the flush machinery was bypassed in such cases (q->flush_flags == 0
&& rq->cmd_flags & (REQ_FLUSH|REQ_FUA)).
Now, however, we don't get into the flush machinery at all. Instead,
__elv_next_request just hands a request with flush and fua bits set to
the scsi_request_fn, even if the underlying request_queue does not
support flush or fua.
The agreed upon approach is to fix the flush machinery to allow
stacking. While this isn't used in practice (since there is only one
request-based dm target, and that target will now reflect the flush
flags of the underlying device), it does future-proof the solution, and
make it function as designed.
In order to make this work, I had to add a field to the struct request,
inside the flush structure (to store the original req->end_io). Shaohua
had suggested overloading the union with rb_node and completion_data,
but the completion data is used by device mapper and can also be used by
other drivers. So, I didn't see a way around the additional field.
I tested this patch on an HP EVA with both ext4 and xfs, and it recovers
the lost performance. Comments and other testers, as always, are
appreciated.
Cheers,
Jeff
init_fault_attr_dentries() is used to export fault_attr via debugfs.
But it can only export it in debugfs root directory.
Per Forlin is working on mmc_fail_request which adds support to inject
data errors after a completed host transfer in MMC subsystem.
The fault_attr for mmc_fail_request should be defined per mmc host and
export it in debugfs directory per mmc host like
/sys/kernel/debug/mmc0/mmc_fail_request.
init_fault_attr_dentries() doesn't help for mmc_fail_request. So this
introduces fault_create_debugfs_attr() which is able to create a
directory in the arbitrary directory and replace
init_fault_attr_dentries().
[akpm@linux-foundation.org: extraneous semicolon, per Randy]
Tested-by: Per Forlin <per.forlin@linaro.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
This changes should_fail_request() to more usable wrapper function of
should_fail(). It can avoid putting #ifdef CONFIG_FAIL_MAKE_REQUEST in
the middle of a function.
After commit 5757a6d7 introduced an unsafe calling of
smp_processor_id(), with preempt debuggin turned on we spew a lot of:
BUG: using smp_processor_id() in preemptible [00000000] code: kjournald/514
caller is __make_request+0x1b8/0x308
[<c0019f44>] (unwind_backtrace+0x0/0xe8) from [<c024b4cc>] (debug_smp_processor_id+0xbc/0xf0)
[<c024b4cc>] (debug_smp_processor_id+0xbc/0xf0) from [<c0223d14>] (__make_request+0x1b8/0x308)
[<c0223d14>] (__make_request+0x1b8/0x308) from [<c02215ac>] (generic_make_request+0x4dc/0x558)
[<c02215ac>] (generic_make_request+0x4dc/0x558) from [<c022173c>] (submit_bio+0x114/0x138)
[<c022173c>] (submit_bio+0x114/0x138) from [<c011f504>] (submit_bh+0x148/0x16c)
[<c011f504>] (submit_bh+0x148/0x16c) from [<c0121ed8>] (__sync_dirty_buffer+0x88/0xd8)
[<c0121ed8>] (__sync_dirty_buffer+0x88/0xd8) from [<c01aff78>] (journal_commit_transaction+0x1198/0x1688)
[<c01aff78>] (journal_commit_transaction+0x1198/0x1688) from [<c01b4034>] (kjournald+0xb4/0x224)
[<c01b4034>] (kjournald+0xb4/0x224) from [<c0069ea0>] (kthread+0x8c/0x94)
[<c0069ea0>] (kthread+0x8c/0x94) from [<c00137f8>] (kernel_thread_exit+0x0/0x8)
Fix this by just using raw_smp_processor_id(), it's just a hint
after all. There's no pinning of the CPU or accessing per-cpu
structures involved.
Reported-by: Ming Lei <tom.leiming@gmail.com>
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits)
block: strict rq_affinity
backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu
block: fix patch import error in max_discard_sectors check
block: reorder request_queue to remove 64 bit alignment padding
CFQ: add think time check for group
CFQ: add think time check for service tree
CFQ: move think time check variables to a separate struct
fixlet: Remove fs_excl from struct task.
block: document blk_plug list access
block: avoid building too big plug list
compat_ioctl: fix make headers_check regression
block: eliminate potential for infinite loop in blkdev_issue_discard
compat_ioctl: fix warning caused by qemu
block: flush MEDIA_CHANGE from drivers on close(2)
blk-throttle: Make total_nr_queued unsigned
block: Add __attribute__((format(printf...) and fix fallout
fs/partitions/check.c: make local symbols static
block:remove some spare spaces in genhd.c
block:fix the comment error in blkdev.h
Some systems benefit from completions always being steered to the strict
requester cpu rather than the looser "per-socket" steering that
blk_cpu_to_group() attempts by default. This is because the first
CPU in the group mask ends up being completely overloaded with work,
while the others (including the original submitter) has power left
to spare.
Allow the strict mode to be set by writing '2' to the sysfs control
file. This is identical to the scheme used for the nomerges file,
where '2' is a more aggressive setting than just being turned on.
echo 2 > /sys/block/<bdev>/queue/rq_affinity
Cc: Roland Dreier <roland@purestorage.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
USB surprise removal of sr is triggering an oops in
scsi_dispatch_command(). What seems to be happening is that USB is
hanging on to a queue reference until the last close of the upper
device, so the crash is caused by surprise remove of a mounted CD
followed by attempted unmount.
The problem is that USB doesn't issue its final commands as part of
the SCSI teardown path, but on last close when the block queue is long
gone. The long term fix is probably to make sr do the teardown in the
same way as sd (so remove all the lower bits on ejection, but keep the
upper disk alive until last close of user space). However, the
current oops can be simply fixed by not allowing any commands to be
sent to a dead queue.
Cc: stable@kernel.org
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
When I test fio script with big I/O depth, I found the total throughput drops
compared to some relative small I/O depth. The reason is the thread accumulates
big requests in its plug list and causes some delays (surely this depends
on CPU speed).
I thought we'd better have a threshold for requests. When a threshold reaches,
this means there is no request merge and queue lock contention isn't severe
when pushing per-task requests to queue, so the main advantages of blk plug
don't exist. We can force a plug list flush in this case.
With this, my test throughput actually increases and almost equals to small
I/O depth. Another side effect is irq off time decreases in blk_flush_plug_list()
for big I/O depth.
The BLK_MAX_REQUEST_COUNT is choosen arbitarily, but 16 is efficiently to
reduce lock contention to me. But I'm open here, 32 is ok in my test too.
We need them in SCSI to fix a bug, but currently they are not
exported to modules. Export them.
sector is never read inside the function.
Signed-off-by: Luca Tettamanti <kronos.it@gmail.com>
Commit 73c101011926 ("block: initial patch for on-stack per-task plugging")
removed calls to elv_bio_merged() when @bio merged with @req. Re-add them.
This in turn will update merged stats in associated group. That
should be safe as long as request has got reference to the blkio_group.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Divyesh Shah <dpshah@google.com>
We don't need them anymore, so kill:
- REQ_ON_PLUG checks in various places
- !rq_mergeable() check in plug merging
Currently, all the cfq_group or throtl_group allocations happen while
we are holding ->queue_lock and sleeping is not allowed.
Soon, we will move to per cpu stats and also need to allocate the
per group stats. As one can not call alloc_percpu() from atomic
context as it can sleep, we need to drop ->queue_lock, allocate the
group, retake the lock and continue processing.
In throttling code, I check the queue DEAD flag again to make sure
that driver did not call blk_cleanup_queue() in the mean time.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Let's check a scenario:
1. blk_delay_queue(q, SCSI_QUEUE_DELAY);
2. blk_run_queue_async();
the second one will became a noop, because q->delay_work already has
WORK_STRUCT_PENDING_BIT set, so the delayed work will still run after
SCSI_QUEUE_DELAY. But blk_run_queue_async actually hopes the delayed
work runs immediately.
Fix this by doing a cancel on potentially pending delayed work
before queuing an immediate run of the workqueue.
We don't pass in a 'force_kblockd' anymore, get rid of the
stsale comment.
Reported-by: Mike Snitzer <snitzer@redhat.com>
We are currently using this flag to check whether it's safe
to call into ->request_fn(). If it is set, we punt to kblockd.
But we get a lot of false positives and excessive punts to
kblockd, which hurts performance.
The only real abuser of this infrastructure is SCSI. So export
the async queue run and convert SCSI over to use that. There's
room for improvement in that SCSI need not always use the async
call, but this fixes our performance issue and they can fix that
up in due time.
With all drivers and file systems converted, we only have
in-core use of this function. So remove the export.
Reporteed-by: Christoph Hellwig <hch@lst.de>
Instead of overloading __blk_run_queue to force an offload to kblockd
add a new blk_run_queue_async helper to do it explicitly. I've kept
the blk_queue_stopped check for now, but I suspect it's not needed
as the check we do when the workqueue items runs should be enough.
Reported-by: Christoph Hellwig <hch@lst.de>
If we know we are going to punt to kblockd, we can drop the queue
lock before calling into __blk_run_queue() since it only does a
safe bit test and a workqueue call. Since kblockd needs to grab
this very lock as one of the first things it does, it's a good
optimization to drop the lock before waking kblockd.
MD can't use this since it really requires us to be able to
keep more than a single piece of state for the unplug. Commit
048c9374 added the required support for MD, so get rid of this
now unused code.
This reverts commit f75664570d8b75469cc468f23c2b27220984983b.
block/blk-core.c
md/raid requires an unplug callback, but as it does not uses
requests the current code cannot provide one.
So allow arbitrary callbacks to be attached to the blk_plug.
Signed-off-by: NeilBrown <neilb@suse.de>
It's a pretty close match to what we had before - the timer triggering
would mean that nobody unplugged the plug in due time, in the new
scheme this matches very closely what the schedule() unplug now is.
It's essentially the difference between an explicit unplug (IO unplug)
or an implicit unplug (timer unplug, we scheduled with pending IO
queued).
For the explicit unplugging, we'd prefer to kick things off
immediately and not pay the penalty of the latency to switch
to kblockd. So let blk_finish_plug() do the run inline, while
the implicit-on-schedule-out unplug will punt to kblockd.
It's a bit of a mess currently. task->plug is being cleared
and reset in __blk_finish_plug(), and blk_finish_plug() is
testing for a NULL plug which cannot happen even from schedule()
anymore since it uses blk_needs_flush_plug() to determine
whether to call into this function at all.
So get rid of some of the cruft.
There are worries that we are now consuming a lot more stack in
some cases, since we potentially call into IO dispatch from
schedule() or io_schedule(). We can reduce this problem by moving
the running of the queue to kblockd, like the old plugging scheme
did as well.
This may or may not be a good idea from a performance perspective,
depending on how many tasks have queue plugs running at the same
time. For even the slightly contended case, doing just a single
queue run from kblockd instead of multiple runs directly from the
unpluggers will be faster.
The original use for this dates back to when we had to track write
requests for serializing around barriers. That's not needed anymore,
so kill it.
This was removed with the queue plug state. But we can easily readd
by checking if this is the first request going to this queue. It's
good information to have when tracing to see how effective the
plugging is.
MD would like to know when a queue is unplugged, so it can flush
it's bitmap writes. Add such a callback.
It's done at the top to avoid doing it for every queue we unplug.
It was removed with the on-stack plugging, readd it and track the
depth of requests added when flushing the plug.
If the request_fn ends up blocking, we could be re-entering
the plug flush. Since the list is protected by explicitly
not allowing schedule events, this isn't a terribly good idea.
Additionally, it can cause us to recurse. As request_fn called by
__blk_run_queue is allowed to 'schedule()' (after dropping the queue
lock of course), it is possible to get a recursive call:
schedule -> blk_flush_plug -> __blk_finish_plug -> flush_plug_list
-> __blk_run_queue -> request_fn -> schedule
We must make sure that the second schedule does not call into
blk_flush_plug again. So instead of leaving the list of requests on
blk_plug->list, move them to a separate list leaving blk_plug->list
empty.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
Comparison function for list_sort() must be anticommutative,
otherwise it is not sorting in ordinary meaning.
But fortunately list_sort() always check ((*cmp)(priv, a, b) <= 0)
it not distinguish negative and zero, so comparison function can
implement only less-or-equal instead of full three-way comparison.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Currently we just dump a non-informative 'request botched' message.
Lets actually try and print something sane to help debug issues
around this.
When the queue work handler was converted to delayed work, the
stopping was inadvertently made sync as well. Change this back
to being async stop, using __cancel_delayed_work() instead of
cancel_delayed_work().
Reported-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reported-by: Chris Mason <chris.mason@oracle.com>
With the introduction of the on-stack plugging, we would assume
that any request being inserted was a normal file system request.
As flush/fua requires a special insert mode, this caused problems.
Fix this up by checking for this in flush_plug_list() and use
the appropriate insert mechanism.
Big thanks goes to Markus Tripplesdorf for tirelessly testing
patches, and to Sergey Senozhatsky for helping find the real
issue.
Reported-by: Markus Tripplesdorf <markus@trippelsdorf.de>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
One of the disadvantages of on-stack plugging is that we potentially
lose out on merging since all pending IO isn't always visible to
everybody. When we flush the on-stack plugs, right now we don't do
any checks to see if potential merge candidates could be utilized.
Correct this by adding a new insert variant, ELEVATOR_INSERT_SORT_MERGE.
It works just ELEVATOR_INSERT_SORT, but first checks whether we can
merge with an existing request before doing the insertion (if we fail
merging).
This fixes a regression with multiple processes issuing IO that
can be merged.
Thanks to Shaohua Li <shaohua.li@intel.com> for testing and fixing
an accounting bug.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits)
[SCSI] scsi_dh_rdac: Add MD36xxf into device list
[SCSI] scsi_debug: add consecutive medium errors
[SCSI] libsas: fix ata list corruption issue
[SCSI] hpsa: export resettable host attribute
[SCSI] hpsa: move device attributes to avoid forward declarations
[SCSI] scsi_debug: Logical Block Provisioning (SBC3r26)
[SCSI] sd: Logical Block Provisioning update
[SCSI] Include protection operation in SCSI command trace
[SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try)
[SCSI] target: Fix volume size misreporting for volumes > 2TB
[SCSI] bnx2fc: Broadcom FCoE offload driver
[SCSI] fcoe: fix broken fcoe interface reset
[SCSI] fcoe: precedence bug in fcoe_filter_frames()
[SCSI] libfcoe: Remove stale fcoe-netdev entries
[SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h
[SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument
[SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs
[SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out"
[SCSI] libfc: Fixing a memory leak when destroying an interface
[SCSI] megaraid_sas: Version and Changelog update
Fix up trivial conflicts due to whitespace differences in
drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
block/blk-core.c
block/blk-flush.c
drivers/md/raid1.c
drivers/md/raid10.c
drivers/md/raid5.c
fs/nilfs2/btnode.c
fs/nilfs2/mdt.c
With the plugging now being explicitly controlled by the
submitter, callers need not pass down unplugging hints
to the block layer. If they want to unplug, it's because they
manually plugged on their own - in which case, they should just
unplug at will.
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
