path: root/block/blk-exec.c
2012-07-20[SCSI] block: Fix blk_execute_rq_nowait() dead queue handlingMuthukumar Ratty
If the queue is dead blk_execute_rq_nowait() doesn't invoke the done() callback function. That will result in blk_execute_rq() being stuck in wait_for_completion(). Avoid this by initializing rq->end_io to the done() callback before we check the queue state. Also, make sure the queue lock is held around the invocation of the done() callback. Found this through source code review. Signed-off-by: Muthukumar Ratty <muthur@gmail.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-14block: add missing blk_queue_dead() checksTejun Heo
blk_insert_cloned_request(), blk_execute_rq_nowait() and blk_flush_plug_list() either didn't check whether the queue was dead or did it without holding queue_lock. Update them so that dead state is checked while holding queue_lock. AFAICS, this plugs all holes (requeue doesn't matter as the request is transitioning atomically from in_flight to queued). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: add blk_queue_dead()Tejun Heo
There are a number of QUEUE_FLAG_DEAD tests. Add blk_queue_dead() macro and use it. This patch doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-07-21[SCSI] fix crash in scsi_dispatch_cmd()James Bottomley
USB surprise removal of sr is triggering an oops in scsi_dispatch_command(). What seems to be happening is that USB is hanging on to a queue reference until the last close of the upper device, so the crash is caused by surprise remove of a mounted CD followed by attempted unmount. The problem is that USB doesn't issue its final commands as part of the SCSI teardown path, but on last close when the block queue is long gone. The long term fix is probably to make sr do the teardown in the same way as sd (so remove all the lower bits on ejection, but keep the upper disk alive until last close of user space). However, the current oops can be simply fixed by not allowing any commands to be sent to a dead queue. Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-05-05block: Remove 'plug/unplug' comment in blk_execute_rq_nowaitTao Ma
unplug is replaced with blk_run_queue now in blk_execute_rq_nowait, so change the comment accordingly. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18block: add blk_run_queue_asyncChristoph Hellwig
Instead of overloading __blk_run_queue to force an offload to kblockd add a new blk_run_queue_async helper to do it explicitly. I've kept the blk_queue_stopped check for now, but I suspect it's not needed as the check we do when the workqueue items runs should be enough. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-24block: Prevent hang_check firing during long I/OMark Lord
During long I/O operations, the hang_check timer may fire, trigger stack dumps that unnecessarily alarm the user. Eg. hdparm --security-erase NULL /dev/sdb ## can take *hours* to complete So, if hang_check is armed, we should wake up periodically to prevent it from triggering. This patch uses a wake-up interval equal to half the hang_check timer period, which keeps overhead low enough. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2009-04-28block: don't set REQ_NOMERGE unnecessarilyTejun Heo
RQ_NOMERGE_FLAGS already clears defines which REQ flags aren't mergeable. There is no reason to specify it superflously. It only adds to confusion. Don't set REQ_NOMERGE for barriers and requests with specific queueing directive. REQ_NOMERGE is now exclusively used by the merging code. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-15block: unexport blk_end_sync_rqFUJITA Tomonori
All the users of blk_end_sync_rq has gone (they are converted to use blk_execute_rq). This unexports blk_end_sync_rq. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15block: handle blk_pm_resume_request() requests in blk_execute_rq_nowait()Bartlomiej Zolnierkiewicz
For blk_pm_resume_request() requests (which are used only by IDE subsystem currently) the queue is stopped so we need to call ->request_fn explicitly. Thanks to: - Rafael for reporting/bisecting the bug - Borislav/Rafael for testing the fix This is a preparation for converting IDE to use blk_execute_rq(). Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
