path: root/block/blk-exec.c
2017-06-09block: introduce new block status code typeChristoph Hellwig
Currently we use nornal Linux errno values in the block layer, and while we accept any error a few have overloaded magic meanings. This patch instead introduces a new blk_status_t value that holds block layer specific status codes and explicitly explains their meaning. Helpers to convert from and to the previous special meanings are provided for now, but I suspect we want to get rid of them in the long run - those drivers that have a errno input (e.g. networking) usually get errnos that don't know about the special block layer overloads, and similarly returning them to userspace will usually return somethings that strictly speaking isn't correct for file system operations, but that's left as an exercise for later. For now the set of errors is a very limited set that closely corresponds to the previous overloaded errno values, but there is some low hanging fruite to improve it. blk_status_t (ab)uses the sparse __bitwise annotations to allow for sparse typechecking, so that we can easily catch places passing the wrong values. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-20block: remove the errors field from struct requestChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <Bart.VanAssche@sandisk.com> Acked-by: Roger Pau Monné <roger.pau@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-20block: remove the blk_execute_rq return valueChristoph Hellwig
The function only returns -EIO if rq->errors is non-zero, which is not very useful and lets a large number of callers ignore the return value. Just let the callers figure out their error themselves. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Bart Van Assche <Bart.VanAssche@sandisk.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-31block: introduce blk_rq_is_passthroughChristoph Hellwig
This can be used to check for fs vs non-fs requests and basically removes all knowledge of BLOCK_PC specific from the block layer, as well as preparing for removing the cmd_type field in struct request. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-27block: split scsi_request out of struct requestChristoph Hellwig
And require all drivers that want to support BLOCK_PC to allocate it as the first thing of their private data. To support this the legacy IDE and BSG code is switched to set cmd_size on their queues to let the block layer allocate the additional space. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-27blk-mq-sched: add flush insertion into blk_mq_sched_insert_request()Jens Axboe
Instead of letting the caller check this and handle the details of inserting a flush request, put the logic in the scheduler insertion function. This fixes direct flush insertion outside of the usual make_request_fn calls, like from dm via blk_insert_cloned_request(). Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-17blk-mq-sched: add framework for MQ capable IO schedulersJens Axboe
This adds a set of hooks that intercepts the blk-mq path of allocating/inserting/issuing/completing requests, allowing us to develop a scheduler within that framework. We reuse the existing elevator scheduler API on the registration side, but augment that with the scheduler flagging support for the blk-mq interfce, and with a separate set of ops hooks for MQ devices. We split driver and scheduler tags, so we can run the scheduling independently of device queue depth. Signed-off-by: Jens Axboe <axboe@fb.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Omar Sandoval <osandov@fb.com>
2016-10-28block: split out request-only flags into a new namespaceChristoph Hellwig
A lot of the REQ_* flags are only used on struct requests, and only of use to the block layer and a few drivers that dig into struct request internals. This patch adds a new req_flags_t rq_flags field to struct request for them, and thus dramatically shrinks the number of common requests. It also removes the unfortunate situation where we have to fit the fields from the same enum into 32 bits for struct bio and 64 bits for struct request. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Shaun Tancheff <shaun.tancheff@seagate.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-07-20block: Fix spelling in a source code commentBart Van Assche
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-05block: move PM request support to IDEChristoph Hellwig
This removes the request types and hacks from the block code and into the old IDE driver. There is a small amunt of code duplication due to this, but it's not too bad. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-22blk-mq: avoid infinite recursion with the FUA flagChristoph Hellwig
We should not insert requests into the flush state machine from blk_mq_insert_request. All incoming flush requests come through blk_{m,s}q_make_request and are handled there, while blk_execute_rq_nowait should only be called for BLOCK_PC requests. All other callers deal with requests that already went through the flush statemchine and shouldn't be reinserted into it. Reported-by: Robert Elliott <Elliott@hp.com> Debugged-by: Ming Lei <ming.lei@canonical.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-06-08block: blk-exec.c: Cleaning up local variable address returndRickard Strandqvist
Address of local variable assigned to a function parameter This was partly found using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-21blk-mq: merge blk_mq_insert_request and blk_mq_run_requestChristoph Hellwig
It's almost identical to blk_mq_insert_request, so fold the two into one slightly more generic function by making the flush special case a bit smarted. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-02-07blk-mq: support at_head inserations for blk_execute_rqChristoph Hellwig
This is neede for proper SG_IO operation as well as various uses of blk_execute_rq from the SCSI midlayer. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2013-12-31block: blk-mq: support draining mq queueMing Lei
blk_mq_drain_queue() is introduced so that we can drain mq queue inside blk_cleanup_queue(). Also don't accept new requests any more if queue is marked as dying. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-10-25blk-mq: new multi-queue block IO queueing mechanismJens Axboe
Linux currently has two models for block devices: - The classic request_fn based approach, where drivers use struct request units for IO. The block layer provides various helper functionalities to let drivers share code, things like tag management, timeout handling, queueing, etc. - The "stacked" approach, where a driver squeezes in between the block layer and IO submitter. Since this bypasses the IO stack, driver generally have to manage everything themselves. With drivers being written for new high IOPS devices, the classic request_fn based driver doesn't work well enough. The design dates back to when both SMP and high IOPS was rare. It has problems with scaling to bigger machines, and runs into scaling issues even on smaller machines when you have IOPS in the hundreds of thousands per device. The stacked approach is then most often selected as the model for the driver. But this means that everybody has to re-invent everything, and along with that we get all the problems again that the shared approach solved. This commit introduces blk-mq, block multi queue support. The design is centered around per-cpu queues for queueing IO, which then funnel down into x number of hardware submission queues. We might have a 1:1 mapping between the two, or it might be an N:M mapping. That all depends on what the hardware supports. blk-mq provides various helper functions, which include: - Scalable support for request tagging. Most devices need to be able to uniquely identify a request both in the driver and to the hardware. The tagging uses per-cpu caches for freed tags, to enable cache hot reuse. - Timeout handling without tracking request on a per-device basis. Basically the driver should be able to get a notification, if a request happens to fail. - Optional support for non 1:1 mappings between issue and submission queues. blk-mq can redirect IO completions to the desired location. - Support for per-request payloads. Drivers almost always need to associate a request structure with some driver private command structure. Drivers can tell blk-mq this at init time, and then any request handed to the driver will have the required size of memory associated with it. - Support for merging of IO, and plugging. The stacked model gets neither of these. Even for high IOPS devices, merging sequential IO reduces per-command overhead and thus increases bandwidth. For now, this is provided as a potential 3rd queueing model, with the hope being that, as it matures, it can replace both the classic and stacked model. That would get us back to having just 1 real model for block devices, leaving the stacked approach to dm/md devices (as it was originally intended). Contributions in this patch from the following people: Shaohua Li <shli@fusionio.com> Alexander Gordeev <agordeev@redhat.com> Christoph Hellwig <hch@infradead.org> Mike Christie <michaelc@cs.wisc.edu> Matias Bjorling <m@bjorling.me> Jeff Moyer <jmoyer@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-10-25block: remove request ref_countChristoph Hellwig
This reference count has been around since before git history, but the only place where it's used is in blk_execute_rq, and ther it is entirely useless as it is incremented before submitting the request and decremented in the end_io handler before waking up the submitter thread. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-09-18If the queue is dying then we only call the rq->end_io callout.Mike Christie
This leaves bios setup on the request, because the caller assumes when the blk_execute_rq_nowait/blk_execute_rq call has completed that the rq->bios have been cleaned up. This patch has blk_execute_rq_nowait use __blk_end_request_all to free bios and also call rq->end_io. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-28Merge branch 'for-3.9/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO core bits from Jens Axboe: "Below are the core block IO bits for 3.9. It was delayed a few days since my workstation kept crashing every 2-8h after pulling it into current -git, but turns out it is a bug in the new pstate code (divide by zero, will report separately). In any case, it contains: - The big cfq/blkcg update from Tejun and and Vivek. - Additional block and writeback tracepoints from Tejun. - Improvement of the should sort (based on queues) logic in the plug flushing. - _io() variants of the wait_for_completion() interface, using io_schedule() instead of schedule() to contribute to io wait properly. - Various little fixes. You'll get two trivial merge conflicts, which should be easy enough to fix up" Fix up the trivial conflicts due to hlist traversal cleanups (commit b67bfe0d42ca: "hlist: drop the node parameter from iterators"). * 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits) block: remove redundant check to bd_openers() block: use i_size_write() in bd_set_size() cfq: fix lock imbalance with failed allocations drivers/block/swim3.c: fix null pointer dereference block: don't select PERCPU_RWSEM block: account iowait time when waiting for completion of IO request sched: add wait_for_completion_io[_timeout] writeback: add more tracepoints block: add block_{touch|dirty}_buffer tracepoint buffer: make touch_buffer() an exported function block: add @req to bio_{front|back}_merge tracepoints block: add missing block_bio_complete() tracepoint block: Remove should_sort judgement when flush blk_plug block,elevator: use new hashtable implementation cfq-iosched: add hierarchical cfq_group statistics cfq-iosched: collect stats from dead cfqgs cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats() blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock block: RCU free request_queue blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge() ...
2013-02-15block: account iowait time when waiting for completion of IO requestVladimir Davydov
Using wait_for_completion() for waiting for a IO request to be executed results in wrong iowait time accounting. For example, a system having the only task doing write() and fdatasync() on a block device can be reported being idle instead of iowaiting as it should because blkdev_issue_flush() calls wait_for_completion() which in turn calls schedule() that does not increment the iowait proc counter and thus does not turn on iowait time accounting. The patch makes block layer use wait_for_completion_io() instead of wait_for_completion() where appropriate to account iowait time correctly. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-02-07sched: Move sched.h sysctl bits into separate headerClark Williams
Move the sysctl-related bits from include/linux/sched.h into a new file: include/linux/sched/sysctl.h. Then update source files requiring access to those bits by including the new header file. Signed-off-by: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20130207094659.06dced96@riff.lan Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-12-17Merge branch 'for-3.8/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer core updates from Jens Axboe: "Here are the core block IO bits for 3.8. The branch contains: - The final version of the surprise device removal fixups from Bart. - Don't hide EFI partitions under advanced partition types. It's fairly wide spread these days. This is especially dangerous for systems that have both msdos and efi partition tables, where you want to keep them in sync. - Cleanup of using -1 instead of the proper NUMA_NO_NODE - Export control of bdi flusher thread CPU mask and default to using the home node (if known) from Jeff. - Export unplug tracepoint for MD. - Core improvements from Shaohua. Reinstate the recursive merge, as the original bug has been fixed. Add plugging for discard and also fix a problem handling non pow-of-2 discard limits. There's a trivial merge in block/blk-exec.c due to a fix that went into 3.7-rc at a later point than -rc4 where this is based." * 'for-3.8/core' of git://git.kernel.dk/linux-block: block: export block_unplug tracepoint block: add plug for blkdev_issue_discard block: discard granularity might not be power of 2 deadline: Allow 0ms deadline latency, increase the read speed partitions: enable EFI/GPT support by default bsg: Remove unused function bsg_goose_queue() block: Make blk_cleanup_queue() wait until request_fn finished block: Avoid scheduling delayed work on a dead queue block: Avoid that request_fn is invoked on a dead queue block: Let blk_drain_queue() caller obtain the queue lock block: Rename queue dead flag bdi: add a user-tunable cpu_list for the bdi flusher threads block: use NUMA_NO_NODE instead of -1 block: recursive merge requests block CFQ: avoid moving request to different queue
2012-12-06block: Avoid that request_fn is invoked on a dead queueBart Van Assche
A block driver may start cleaning up resources needed by its request_fn as soon as blk_cleanup_queue() finished, so request_fn must not be invoked after draining finished. This is important when blk_run_queue() is invoked without any requests in progress. As an example, if blk_drain_queue() and scsi_run_queue() run in parallel, blk_drain_queue() may have finished all requests after scsi_run_queue() has taken a SCSI device off the starved list but before that last function has had a chance to run the queue. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Chanho Min <chanho.min@lge.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-12-06block: Rename queue dead flagBart Van Assche
QUEUE_FLAG_DEAD is used to indicate that queuing new requests must stop. After this flag has been set queue draining starts. However, during the queue draining phase it is still safe to invoke the queue's request_fn, so QUEUE_FLAG_DYING is a better name for this flag. This patch has been generated by running the following command over the kernel source tree: git grep -lEw 'blk_queue_dead|QUEUE_FLAG_DEAD' | xargs sed -i.tmp -e 's/blk_queue_dead/blk_queue_dying/g' \ -e 's/QUEUE_FLAG_DEAD/QUEUE_FLAG_DYING/g'; \ sed -i.tmp -e "s/QUEUE_FLAG_DYING$(printf \\t)*5/QUEUE_FLAG_DYING$(printf \\t)5/g" \ include/linux/blkdev.h; \ sed -i.tmp -e 's/ DEAD/ DYING/g' -e 's/dead queue/a dying queue/' \ -e 's/Dead queue/A dying queue/' block/blk-core.c Signed-off-by: Bart Van Assche <bvanassche@acm.org> Acked-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Jens Axboe <axboe@kernel.dk> Cc: Chanho Min <chanho.min@lge.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-23block: Don't access request after it might be freedRoland Dreier
After we've done __elv_add_request() and __blk_run_queue() in blk_execute_rq_nowait(), the request might finish and be freed immediately. Therefore checking if the type is REQ_TYPE_PM_RESUME isn't safe afterwards, because if it isn't, rq might be gone. Instead, check beforehand and stash the result in a temporary. This fixes crashes in blk_execute_rq_nowait() I get occasionally when running with lots of memory debugging options enabled -- I think this race is usually harmless because the window for rq to be reallocated is so small. Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-07-20[SCSI] block: Fix blk_execute_rq_nowait() dead queue handlingMuthukumar Ratty
If the queue is dead blk_execute_rq_nowait() doesn't invoke the done() callback function. That will result in blk_execute_rq() being stuck in wait_for_completion(). Avoid this by initializing rq->end_io to the done() callback before we check the queue state. Also, make sure the queue lock is held around the invocation of the done() callback. Found this through source code review. Signed-off-by: Muthukumar Ratty <muthur@gmail.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-14block: add missing blk_queue_dead() checksTejun Heo
blk_insert_cloned_request(), blk_execute_rq_nowait() and blk_flush_plug_list() either didn't check whether the queue was dead or did it without holding queue_lock. Update them so that dead state is checked while holding queue_lock. AFAICS, this plugs all holes (requeue doesn't matter as the request is transitioning atomically from in_flight to queued). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: add blk_queue_dead()Tejun Heo
There are a number of QUEUE_FLAG_DEAD tests. Add blk_queue_dead() macro and use it. This patch doesn't introduce any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-07-21[SCSI] fix crash in scsi_dispatch_cmd()James Bottomley
USB surprise removal of sr is triggering an oops in scsi_dispatch_command(). What seems to be happening is that USB is hanging on to a queue reference until the last close of the upper device, so the crash is caused by surprise remove of a mounted CD followed by attempted unmount. The problem is that USB doesn't issue its final commands as part of the SCSI teardown path, but on last close when the block queue is long gone. The long term fix is probably to make sr do the teardown in the same way as sd (so remove all the lower bits on ejection, but keep the upper disk alive until last close of user space). However, the current oops can be simply fixed by not allowing any commands to be sent to a dead queue. Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-05-05block: Remove 'plug/unplug' comment in blk_execute_rq_nowaitTao Ma
unplug is replaced with blk_run_queue now in blk_execute_rq_nowait, so change the comment accordingly. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18block: add blk_run_queue_asyncChristoph Hellwig
Instead of overloading __blk_run_queue to force an offload to kblockd add a new blk_run_queue_async helper to do it explicitly. I've kept the blk_queue_stopped check for now, but I suspect it's not needed as the check we do when the workqueue items runs should be enough. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-24block: Prevent hang_check firing during long I/OMark Lord
During long I/O operations, the hang_check timer may fire, trigger stack dumps that unnecessarily alarm the user. Eg. hdparm --security-erase NULL /dev/sdb ## can take *hours* to complete So, if hang_check is armed, we should wake up periodically to prevent it from triggering. This patch uses a wake-up interval equal to half the hang_check timer period, which keeps overhead low enough. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2009-04-28block: don't set REQ_NOMERGE unnecessarilyTejun Heo
RQ_NOMERGE_FLAGS already clears defines which REQ flags aren't mergeable. There is no reason to specify it superflously. It only adds to confusion. Don't set REQ_NOMERGE for barriers and requests with specific queueing directive. REQ_NOMERGE is now exclusively used by the merging code. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-15block: unexport blk_end_sync_rqFUJITA Tomonori
All the users of blk_end_sync_rq has gone (they are converted to use blk_execute_rq). This unexports blk_end_sync_rq. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15block: handle blk_pm_resume_request() requests in blk_execute_rq_nowait()Bartlomiej Zolnierkiewicz
For blk_pm_resume_request() requests (which are used only by IDE subsystem currently) the queue is stopped so we need to call ->request_fn explicitly. Thanks to: - Rafael for reporting/bisecting the bug - Borislav/Rafael for testing the fix This is a preparation for converting IDE to use blk_execute_rq(). Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
