path: root/block/blk-exec.c
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2009-04-28block: don't set REQ_NOMERGE unnecessarilyTejun Heo
RQ_NOMERGE_FLAGS already clears defines which REQ flags aren't mergeable. There is no reason to specify it superflously. It only adds to confusion. Don't set REQ_NOMERGE for barriers and requests with specific queueing directive. REQ_NOMERGE is now exclusively used by the merging code. [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-15block: unexport blk_end_sync_rqFUJITA Tomonori
All the users of blk_end_sync_rq has gone (they are converted to use blk_execute_rq). This unexports blk_end_sync_rq. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15block: handle blk_pm_resume_request() requests in blk_execute_rq_nowait()Bartlomiej Zolnierkiewicz
For blk_pm_resume_request() requests (which are used only by IDE subsystem currently) the queue is stopped so we need to call ->request_fn explicitly. Thanks to: - Rafael for reporting/bisecting the bug - Borislav/Rafael for testing the fix This is a preparation for converting IDE to use blk_execute_rq(). Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Borislav Petkov <petkovbb@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
