This patch fixes one issue reported by Kent, which can
be triggered in bcachefs over sata disk. Actually it
is a generic issue in block flush vs. blk-tag.
Reported-by: Kent Overstreet <kent.overstreet@gmail.com>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
All drivers use the default, so provide an inline version of it. If we
ever need other queue mapping we can add an optional method back,
although supporting will also require major changes to the queue setup
code.
This provides better code generation, and better debugability as well.
Reviewed-by: Keith Busch <keith.busch@intel.com>
To avoid confusion between REQ_OP_FLUSH, which is handled by
request_fn drivers, and upper layers requesting the block layer
perform a flush sequence along with possibly a WRITE, this patch
renames REQ_FLUSH to REQ_PREFLUSH.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This adds a REQ_OP_FLUSH operation that is sent to request_fn
based drivers by the block layer's flush code, instead of
sending requests with the request->cmd_flags REQ_FLUSH bit set.
This patch converts the simple bi_rw use cases in the block,
drivers, mm and fs code to set/get the bio operation using
bio_set_op_attrs/bio_op
These should be simple one or two liner cases, so I just did them
in one patch. The next patches handle the more complicated
cases in a module per patch.
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
Now that we converted everything to the newer block write cache
interface, kill off the queue flush_flags and queueable flush
entries.
This reverts commit 1b2ff19e6a957b1ef0f365ad331b608af80e932e.
Jan writes:
Thanks for report! After some investigation I found out we allocate
elevator specific data in __get_request() only for non-flush requests. And
this is actually required since the flush machinery uses the space in
struct request for something else. Doh. So my patch is just wrong and not
easy to fix since at the time __get_request() is called we are not sure
whether the flush machinery will be used in the end. Jens, please revert
1b2ff19e6a957b1ef0f365ad331b608af80e932e. Thanks!
I'm somewhat surprised that you can reliably hit the race where flushing
gets disabled for the device just while the request is in flight. But I
guess during boot it makes some sense.
So let's just revert it, we can fix the queue run manually after the
fact. This race is rare enough that it didn't trigger in testing, it
requires the specific disable-while-in-flight scenario to trigger.
Currently blk_insert_flush() just adds flush request to q->queue_head
when flush is not required. That completely bypasses IO scheduler so
e.g. CFQ can be idling waiting for new request to arrive and will idle
through the whole window unnecessarily. Luckily this only happens in
rare cases as usually checks in generic_make_request_checks() clear
FLUSH and FUA flags early if they are not needed.
When no flushing is actually required, we can easily fix the problem by
properly queueing the request through the IO scheduler. Ideally IO
scheduler should be also made aware of requests queued via
blk_flush_queue_rq(). However inserting flush request through IO
scheduler can have unwanted side-effects since due to flush batching
delaying the flush request in IO scheduler will delay all flush requests
possibly coming from other processes. So we keep adding the request
directly to q->queue_head.
Signed-off-by: Jan Kara <jack@suse.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Inside timeout handler, blk_mq_tag_to_rq() is called
to retrieve the request from one tag. This way is obviously
wrong because the request can be freed any time and some
fiedds of the request can't be trusted, then kernel oops
might be triggered[1].
Currently wrt. blk_mq_tag_to_rq(), the only special case is
that the flush request can share same tag with the request
cloned from, and the two requests can't be active at the same
time, so this patch fixes the above issue by updating tags->rqs[tag]
with the active request(either flush rq or the request cloned
from) of the tag.
Also blk_mq_tag_to_rq() gets much simplified with this patch.
Given blk_mq_tag_to_rq() is mainly for drivers and the caller must
make sure the request can't be freed, so in bt_for_each() this
helper is replaced with tags->rqs[tag].
[1] kernel oops log
[ 439.696220] BUG: unable to handle kernel NULL pointer dereference at 0000000000000158^M
[ 439.697162] IP: [<ffffffff812d89ba>] blk_mq_tag_to_rq+0x21/0x6e^M
[ 439.700653] PGD 7ef765067 PUD 7ef764067 PMD 0 ^M
[ 439.700653] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC ^M
[ 439.700653] Dumping ftrace buffer:^M
[ 439.700653] (ftrace buffer empty)^M
[ 439.700653] Modules linked in: nbd ipv6 kvm_intel kvm serio_raw^M
[ 439.700653] CPU: 6 PID: 2779 Comm: stress-ng-sigfd Not tainted 4.2.0-rc5-next-20150805+ #265^M
[ 439.730500] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011^M
[ 439.730500] task: ffff880605308000 ti: ffff88060530c000 task.ti: ffff88060530c000^M
[ 439.730500] RIP: 0010:[<ffffffff812d89ba>] [<ffffffff812d89ba>] blk_mq_tag_to_rq+0x21/0x6e^M
[ 439.730500] RSP: 0018:ffff880819203da0 EFLAGS: 00010283^M
[ 439.730500] RAX: ffff880811b0e000 RBX: ffff8800bb465f00 RCX: 0000000000000002^M
[ 439.730500] RDX: 0000000000000000 RSI: 0000000000000202 RDI: 0000000000000000^M
[ 439.730500] RBP: ffff880819203db0 R08: 0000000000000002 R09: 0000000000000000^M
[ 439.730500] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000202^M
[ 439.730500] R13: ffff880814104800 R14: 0000000000000002 R15: ffff880811a2ea00^M
[ 439.730500] FS: 00007f165b3f5740(0000) GS:ffff880819200000(0000) knlGS:0000000000000000^M
[ 439.730500] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b^M
[ 439.730500] CR2: 0000000000000158 CR3: 00000007ef766000 CR4: 00000000000006e0^M
[ 439.730500] Stack:^M
[ 439.730500] 0000000000000008 ffff8808114eed90 ffff880819203e00 ffffffff812dc104^M
[ 439.755663] ffff880819203e40 ffffffff812d9f5e 0000020000000000 ffff8808114eed80^M
[ 439.755663] Call Trace:^M
[ 439.755663] <IRQ> ^M
[ 439.755663] [<ffffffff812dc104>] bt_for_each+0x6e/0xc8^M
[ 439.755663] [<ffffffff812d9f5e>] ? blk_mq_rq_timed_out+0x6a/0x6a^M
[ 439.755663] [<ffffffff812dc1b3>] blk_mq_tag_busy_iter+0x55/0x5e^M
[ 439.755663] [<ffffffff812d88b4>] ? blk_mq_bio_to_request+0x38/0x38^M
[ 439.755663] [<ffffffff812d8911>] blk_mq_rq_timer+0x5d/0xd4^M
[ 439.755663] [<ffffffff810a3e10>] call_timer_fn+0xf7/0x284^M
[ 439.755663] [<ffffffff810a3d1e>] ? call_timer_fn+0x5/0x284^M
[ 439.755663] [<ffffffff810a46d6>] run_timer_softirq+0x1ce/0x1f8^M
[ 439.755663] [<ffffffff8104c367>] __do_softirq+0x181/0x3a4^M
[ 439.755663] [<ffffffff8104c76e>] irq_exit+0x40/0x94^M
[ 439.755663] [<ffffffff81031482>] smp_apic_timer_interrupt+0x33/0x3e^M
[ 439.755663] [<ffffffff815559a4>] apic_timer_interrupt+0x84/0x90^M
[ 439.755663] <EOI> ^M
[ 439.755663] [<ffffffff81554350>] ? _raw_spin_unlock_irq+0x32/0x4a^M
[ 439.755663] [<ffffffff8106a98b>] finish_task_switch+0xe0/0x163^M
[ 439.755663] [<ffffffff8106a94d>] ? finish_task_switch+0xa2/0x163^M
[ 439.755663] [<ffffffff81550066>] __schedule+0x469/0x6cd^M
[ 439.755663] [<ffffffff8155039b>] schedule+0x82/0x9a^M
[ 439.789267] [<ffffffff8119b28b>] signalfd_read+0x186/0x49a^M
[ 439.790911] [<ffffffff8106d86a>] ? wake_up_q+0x47/0x47^M
[ 439.790911] [<ffffffff811618c2>] __vfs_read+0x28/0x9f^M
[ 439.790911] [<ffffffff8117a289>] ? __fget_light+0x4d/0x74^M
[ 439.790911] [<ffffffff811620a7>] vfs_read+0x7a/0xc6^M
[ 439.790911] [<ffffffff8116292b>] SyS_read+0x49/0x7f^M
[ 439.790911] [<ffffffff81554c17>] entry_SYSCALL_64_fastpath+0x12/0x6f^M
[ 439.790911] Code: 48 89 e5 e8 a9 b8 e7 ff 5d c3 0f 1f 44 00 00 55 89
f2 48 89 e5 41 54 41 89 f4 53 48 8b 47 60 48 8b 1c d0 48 8b 7b 30 48 8b
53 38 <48> 8b 87 58 01 00 00 48 85 c0 75 09 48 8b 97 88 0c 00 00 eb 10
^M
[ 439.790911] RIP [<ffffffff812d89ba>] blk_mq_tag_to_rq+0x21/0x6e^M
[ 439.790911] RSP <ffff880819203da0>^M
[ 439.790911] CR2: 0000000000000158^M
[ 439.790911] ---[ end trace d40af58949325661 ]---^M
Cc: <stable@vger.kernel.org>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
This patch supports to run one single flush machinery for
each blk-mq dispatch queue, so that:
- current init_request and exit_request callbacks can
cover flush request too, then the buggy copying way of
initializing flush request's pdu can be fixed
- flushing performance gets improved in case of multi hw-queue
In fio sync write test over virtio-blk(4 hw queues, ioengine=sync,
iodepth=64, numjobs=4, bs=4K), it is observed that througput gets
increased a lot over my test environment:
- throughput: +70% in case of virtio-blk over null_blk
- throughput: +30% in case of virtio-blk over SSD image
The multi virtqueue feature isn't merged to QEMU yet, and patches for
the feature can be found in below tree:
git://kernel.ubuntu.com/ming/qemu.git v2.1.0-mq.4
And simply passing 'num_queues=4 vectors=5' should be enough to
enable multi queue(quad queue) feature for QEMU virtio-blk.
Suggested-by: Christoph Hellwig <hch@lst.de>
This patch adds 'blk_mq_ctx' parameter to blk_get_flush_queue(),
so that this function can find the corresponding blk_flush_queue
bound with current mq context since the flush queue will become
per hw-queue.
For legacy queue, the parameter can be simply 'NULL'.
For multiqueue case, the parameter should be set as the context
from which the related request is originated. With this context
info, the hw queue and related flush queue can be found easily.
Just figuring out flush queue at the entry of kicking off flush
machinery and request's completion handler, then pass it through.
Now mission of the two helpers is over, and just call
blk_alloc_flush_queue() and blk_free_flush_queue() directly.
This patch introduces 'struct blk_flush_queue' and puts all
flush machinery related fields into this structure, so that
- flush implementation details aren't exposed to driver
- it is easy to convert to per dispatch-queue flush machinery
This patch is basically a mechanical replacement.
This patch trys to use local variable to access flush request,
so that we can convert to per-queue flush machinery a bit easier.
These fields are always used with the flush request, so
initialize them together.
These two temporary functions are introduced for holding flush
initialization and de-initialization, so that we can
introduce 'flush queue' easier in the following patch. And
once 'flush queue' and its allocation/free functions are ready,
they will be removed for sake of code readability.
It is reasonable to allocate flush req in blk_mq_init_flush().
This patch removes two unnecessary blk_clear_rq_complete(),
the REQ_ATOM_COMPLETE flag is cleared inside blk_mq_start_request(),
so:
- The blk_clear_rq_complete() in blk_flush_restore_request()
needn't because the request will be freed later, and clearing
it here may open a small race window with timeout.
- The blk_clear_rq_complete() in blk_mq_requeue_request() isn't
necessary too, even though REQ_ATOM_STARTED is cleared in
__blk_mq_requeue_request(), in theory it still may cause a small
race window with timeout since the two clear_bit() may be
reordered.
Signed-off-by: Ming Lei <ming.lei@canoical.com>
Now that we've changed the driver API on the submission side use the
opportunity to fix up the name on the completion side to fit into the
general scheme.
elv_abort_queue has no callers, and blk_abort_flushes is only called by
elv_abort_queue.
blk_mq_tag_to_rq() needs to be able to tell if it should return
the original request, or the flush request if we are doing a flush
sequence. Clear the flush tag when IO completes for a flush, since
that is what we are comparing against.
flush request is special, which borrows the tag from the parent
request. Hence blk_mq_tag_to_rq needs special handling to return
the flush request from the tag.
Signed-off-by: Shaohua Li <shli@fusionio.com>
Both the cache flush state machine and the SCSI midlayer want to submit
requests from irq context, and the current per-request requeue_work
unfortunately causes corruption due to sharing with the csd field for
flushes. Replace them with a per-request_queue list of requests to
be requeued.
Based on an earlier test by Ming Lei.
Reported-by: Ming Lei <tom.leiming@gmail.com>
Tested-by: Ming Lei <tom.leiming@gmail.com>
We will use this work_struct to requeue scsi commands from the
completion handler as well, so give it a more generic name.
Drivers shouldn't have to care about the block layer setting aside a
request to implement the flush state machine. We already override the
mq context and tag to make it more transparent, but so far haven't deal
with the driver private data in the request. Make sure to override this
as well, and while we're at it add a proper helper sitting in blk-mq.c
that implements the full impersonation.
Drivers can reach their private data easily using the blk_mq_rq_to_pdu
helper and don't need req->special. By not initializing it code can
be simplified nicely, and we also shave off a few more instructions from
the I/O path.
The queue parameter is never used, just get rid of it.
Commit 18741986 inadvertently changed the rq flush insertion
from a head to a tail insertion. Fix that back up.
Signed-off-by: Mike Snitzer <msnitzer@redhat.com>
It's almost identical to blk_mq_insert_request, so fold the two into one
slightly more generic function by making the flush special case a bit
smarted.
Witch to using a preallocated flush_rq for blk-mq similar to what's done
with the old request path. This allows us to set up the request properly
with a tag from the actually allowed range and ->rq_disk as needed by
some drivers. To make life easier we also switch to dynamic allocation
of ->flush_rq for the old path.
This effectively reverts most of
"blk-mq: fix for flush deadlock"
and
"blk-mq: Don't reserve a tag for flush request"
Reserving a tag (request) for flush to avoid dead lock is a overkill. A
tag is valuable resource. We can track the number of flush requests and
disallow having too many pending flush requests allocated. With this
patch, blk_mq_alloc_request_pinned() could do a busy nop (but not a dead
loop) if too many pending requests are allocated and new flush request
is allocated. But this should not be a problem, too many pending flush
requests are very rare case.
I verified this can fix the deadlock caused by too many pending flush
requests.
Immutable biovecs are going to require an explicit iterator. To
implement immutable bvecs, a later patch is going to add a bi_bvec_done
member to this struct; for now, this patch effectively just renames
things.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Alex Elder <elder@inktank.com>
Cc: ceph-devel@vger.kernel.org
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: dm-devel@redhat.com
Cc: linux390@de.ibm.com
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: xfs@oss.sgi.com
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: "Roger Pau Monné" <roger.pau@citrix.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Jerome Marchand <jmarchand@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Peng Tao <tao.peng@emc.com>
Cc: Andy Adamson <andros@netapp.com>
Cc: fanchaoting <fanchaoting@cn.fujitsu.com>
Cc: Jie Liu <jeff.liu@oracle.com>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Pankaj Kumar <pankaj.km@samsung.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Mel Gorman <mgorman@suse.de>6
It was being open coded in a few places.
Acked-by: NeilBrown <neilb@suse.de>
The flush state machine takes in a struct request, which then is
submitted multiple times to the underling driver. The old block code
requeses the same request for each of those, so it does not have an
issue with tapping into the request pool. The new one on the other hand
allocates a new request for each of the actualy steps of the flush
sequence. If have already allocated all of the tags for IO, we will
fail allocating the flush request.
Set aside a reserved request just for flushes.
Linux currently has two models for block devices:
- The classic request_fn based approach, where drivers use struct
request units for IO. The block layer provides various helper
functionalities to let drivers share code, things like tag
management, timeout handling, queueing, etc.
- The "stacked" approach, where a driver squeezes in between the
block layer and IO submitter. Since this bypasses the IO stack,
driver generally have to manage everything themselves.
With drivers being written for new high IOPS devices, the classic
request_fn based driver doesn't work well enough. The design dates
back to when both SMP and high IOPS was rare. It has problems with
scaling to bigger machines, and runs into scaling issues even on
smaller machines when you have IOPS in the hundreds of thousands
per device.
The stacked approach is then most often selected as the model
for the driver. But this means that everybody has to re-invent
everything, and along with that we get all the problems again
that the shared approach solved.
This commit introduces blk-mq, block multi queue support. The
design is centered around per-cpu queues for queueing IO, which
then funnel down into x number of hardware submission queues.
We might have a 1:1 mapping between the two, or it might be
an N:M mapping. That all depends on what the hardware supports.
blk-mq provides various helper functions, which include:
- Scalable support for request tagging. Most devices need to
be able to uniquely identify a request both in the driver and
to the hardware. The tagging uses per-cpu caches for freed
tags, to enable cache hot reuse.
- Timeout handling without tracking request on a per-device
basis. Basically the driver should be able to get a notification,
if a request happens to fail.
- Optional support for non 1:1 mappings between issue and
submission queues. blk-mq can redirect IO completions to the
desired location.
- Support for per-request payloads. Drivers almost always need
to associate a request structure with some driver private
command structure. Drivers can tell blk-mq this at init time,
and then any request handed to the driver will have the
required size of memory associated with it.
- Support for merging of IO, and plugging. The stacked model
gets neither of these. Even for high IOPS devices, merging
sequential IO reduces per-command overhead and thus
increases bandwidth.
For now, this is provided as a potential 3rd queueing model, with
the hope being that, as it matures, it can replace both the classic
and stacked model. That would get us back to having just 1 real
model for block devices, leaving the stacked approach to dm/md
devices (as it was originally intended).
Contributions in this patch from the following people:
Alexander Gordeev <agordeev@redhat.com>
Mike Christie <michaelc@cs.wisc.edu>
Matias Bjorling <m@bjorling.me>
Acked-by: Christoph Hellwig <hch@lst.de>
Fixed code indent should use tabs where possible.
Signed-off-by: Alice Ferrazzi <alice.ferrazzi@gmail.com>
Using wait_for_completion() for waiting for a IO request to be executed
results in wrong iowait time accounting. For example, a system having
the only task doing write() and fdatasync() on a block device can be
reported being idle instead of iowaiting as it should because
blkdev_issue_flush() calls wait_for_completion() which in turn calls
schedule() that does not increment the iowait proc counter and thus does
not turn on iowait time accounting.
The patch makes block layer use wait_for_completion_io() instead of
wait_for_completion() where appropriate to account iowait time
correctly.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
A dm-multipath user reported[1] a problem when trying to boot
a kernel with commit 4853abaae7e4a2af938115ce9071ef8684fb7af4
(block: fix flush machinery for stacking drivers with differring
flush flags) applied. It turns out that an empty flush request
can be sent into blk_insert_flush. When the BUG_ON was fixed
to allow for this, I/O on the underlying device would stall. The
reason is that blk_insert_cloned_request does not kick the queue.
In the aforementioned commit, I had added a special case to
kick the queue if data was sent down but the queue flags did
not require a flush. A better solution is to push the queue
kick up into blk_insert_cloned_request.
This patch, along with a follow-on which fixes the BUG_ON, fixes
the issue reported.
[1] http://www.redhat.com/archives/dm-devel/2011-September/msg00154.html
Reported-by: Christophe Saout <christophe@saout.de>
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Tejun Heo <tj@kernel.org>
Stable note: 3.1
Cc: stable@vger.kernel.org
A user reported a regression due to commit
4853abaae7e4a2af938115ce9071ef8684fb7af4 (block: fix flush
machinery for stacking drivers with differring flush flags).
Part of the problem is that blk_insert_flush required a
single bio be attached to the request. In reality, having
no attached bio is also a valid case, as can be observed with
an empty flush.
Stable note: 3.1
Commit ae1b1539622fb46e51b4d13b3f9e5f4c713f86ae, block: reimplement
FLUSH/FUA to support merge, introduced a performance regression when
running any sort of fsyncing workload using dm-multipath and certain
storage (in our case, an HP EVA). The test I ran was fs_mark, and it
dropped from ~800 files/sec on ext4 to ~100 files/sec. It turns out
that dm-multipath always advertised flush+fua support, and passed
commands on down the stack, where those flags used to get stripped off.
The above commit changed that behavior:
static inline struct request *__elv_next_request(struct request_queue *q)
struct request *rq;
while (1) {
- while (!list_empty(&q->queue_head)) {
+ if (!list_empty(&q->queue_head)) {
rq = list_entry_rq(q->queue_head.next);
- if (!(rq->cmd_flags & (REQ_FLUSH | REQ_FUA)) ||
- (rq->cmd_flags & REQ_FLUSH_SEQ))
- return rq;
- rq = blk_do_flush(q, rq);
- if (rq)
- return rq;
+ return rq;
Note that previously, a command would come in here, have
REQ_FLUSH|REQ_FUA set, and then get handed off to blk_do_flush:
struct request *blk_do_flush(struct request_queue *q, struct request *rq)
unsigned int fflags = q->flush_flags; /* may change, cache it */
bool has_flush = fflags & REQ_FLUSH, has_fua = fflags & REQ_FUA;
bool do_preflush = has_flush && (rq->cmd_flags & REQ_FLUSH);
bool do_postflush = has_flush && !has_fua && (rq->cmd_flags &
REQ_FUA);
unsigned skip = 0;
if (blk_rq_sectors(rq) && !do_preflush && !do_postflush) {
rq->cmd_flags &= ~REQ_FLUSH;
if (!has_fua)
rq->cmd_flags &= ~REQ_FUA;
return rq;
So, the flush machinery was bypassed in such cases (q->flush_flags == 0
&& rq->cmd_flags & (REQ_FLUSH|REQ_FUA)).
Now, however, we don't get into the flush machinery at all. Instead,
__elv_next_request just hands a request with flush and fua bits set to
the scsi_request_fn, even if the underlying request_queue does not
support flush or fua.
The agreed upon approach is to fix the flush machinery to allow
stacking. While this isn't used in practice (since there is only one
request-based dm target, and that target will now reflect the flush
flags of the underlying device), it does future-proof the solution, and
make it function as designed.
In order to make this work, I had to add a field to the struct request,
inside the flush structure (to store the original req->end_io). Shaohua
had suggested overloading the union with rb_node and completion_data,
but the completion data is used by device mapper and can also be used by
other drivers. So, I didn't see a way around the additional field.
I tested this patch on an HP EVA with both ext4 and xfs, and it recovers
the lost performance. Comments and other testers, as always, are
appreciated.
Cheers,
Jeff
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
blk_insert_flush has the following check:
* If there's data but flush is not necessary, the request can be
* processed directly without going through flush machinery. Queue
* for normal execution.
if ((policy & REQ_FSEQ_DATA) &&
!(policy & (REQ_FSEQ_PREFLUSH | REQ_FSEQ_POSTFLUSH))) {
list_add_tail(&rq->queuelist, &q->queue_head);
return;
However, blk_flush_policy will not return with policy set to only
REQ_FSEQ_DATA:
static unsigned int blk_flush_policy(unsigned int fflags, struct request *rq)
unsigned int policy = 0;
if (fflags & REQ_FLUSH) {
if (rq->cmd_flags & REQ_FLUSH)
policy |= REQ_FSEQ_PREFLUSH;
if (blk_rq_sectors(rq))
policy |= REQ_FSEQ_DATA;
if (!(fflags & REQ_FUA) && (rq->cmd_flags & REQ_FUA))
policy |= REQ_FSEQ_POSTFLUSH;
return policy;
Notice that REQ_FSEQ_DATA is only set if REQ_FLUSH is set. Fix this
mismatch by moving the setting of REQ_FSEQ_DATA outside of the REQ_FLUSH
check.
Tejun notes:
Hmmm... yes, this can become a correctness issue if (and only if)
blk_queue_flush() is called to change q->flush_flags while requests
are in-flight; otherwise, requests wouldn't reach the function at all.
Also, I think it would be a generally good idea to always set
FSEQ_DATA if the request has data.
Cheers,
Jeff
In some drives, flush requests are non-queueable. When flush request is
running, normal read/write requests can't run. If block layer dispatches
such request, driver can't handle it and requeue it. Tejun suggested we
can hold the queue when flush is running. This can avoid unnecessary
requeue. Also this can improve performance. For example, we have
request flush1, write1, flush 2. flush1 is dispatched, then queue is
hold, write1 isn't inserted to queue. After flush1 is finished, flush2
will be dispatched. Since disk cache is already clean, flush2 will be
finished very soon, so looks like flush2 is folded to flush1.
In my test, the queue holding completely solves a regression introduced by
commit 53d63e6b0dfb95882ec0219ba6bbd50cde423794:
block: make the flush insertion use the tail of the dispatch list
It's not a preempt type request, in fact we have to insert it
behind requests that do specify INSERT_FRONT.
which causes about 20% regression running a sysbench fileio
workload.
Stable: 2.6.39 only
Cc: stable@kernel.org
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Instead of overloading __blk_run_queue to force an offload to kblockd
add a new blk_run_queue_async helper to do it explicitly. I've kept
the blk_queue_stopped check for now, but I suspect it's not needed
as the check we do when the workqueue items runs should be enough.
Merge it with __elv_add_request(), it's pretty pointless to
have a function with only two callers. The main interface
is elv_add_request()/__elv_add_request().
block/blk-core.c
block/blk-flush.c
drivers/md/raid1.c
drivers/md/raid10.c
drivers/md/raid5.c
fs/nilfs2/btnode.c
fs/nilfs2/mdt.c
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
This patch adds support for creating a queuing context outside
of the queue itself. This enables us to batch up pieces of IO
before grabbing the block device queue lock and submitting them to
the IO scheduler.
The context is created on the stack of the process and assigned in
the task structure, so that we can auto-unplug it if we hit a schedule
event.
The current queue plugging happens implicitly if IO is submitted to
an empty device, yet callers have to remember to unplug that IO when
they are going to wait for it. This is an ugly API and has caused bugs
in the past. Additionally, it requires hacks in the vm (->sync_page()
callback) to handle that logic. By switching to an explicit plugging
scheme we make the API a lot nicer and can get rid of the ->sync_page()
hack in the vm.
