path: root/block/blk-integrity.c
2014-09-27block: Don't merge requests if integrity flags differMartin K. Petersen
We'd occasionally merge requests with conflicting integrity flags. Introduce a merge helper which checks that the requests have compatible integrity payloads. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Add a disk flag to block integrity profileMartin K. Petersen
So far we have relied on the app tag size to determine whether a disk has been formatted with T10 protection information or not. However, not all target devices provide application tag storage. Add a flag to the block integrity profile that indicates whether the disk has been formatted with protection information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Sagi Grimberg <sagig@dev.mellanox.co.il> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Add prefix to block integrity profile flagsMartin K. Petersen
Add a BLK_ prefix to the integrity profile flags. Also rename the flags to be more consistent with the generate/verify terminology in the rest of the integrity code. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Deprecate the use of the term sector in the context of block integrityMartin K. Petersen
The protection interval is not necessarily tied to the logical block size of a block device. Stop using the terms "sector" and "sectors". Going forward we will use the term "seed" to describe the initial reference tag value for a given I/O. "Interval" will be used to describe the portion of the data buffer that a given piece of protection information is associated with. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-09-27block: Remove integrity tagging functionsMartin K. Petersen
None of the filesystems appear interested in using the integrity tagging feature. Potentially because very few storage devices actually permit using the application tag space. Remove the tagging functions. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2013-11-23bio-integrity: Convert to bvec_iterKent Overstreet
The bio integrity is also stored in a bvec array, so if we use the bvec iter code we just added, the integrity code won't need to implement its own iteration stuff (bio_integrity_mark_head(), bio_integrity_mark_tail()) Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
2013-03-20scatterlist: introduce sg_unmark_endPaolo Bonzini
This is useful in places that recycle the same scatterlist multiple times, and do not want to incur the cost of sg_init_table every time in hot paths. Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-02-21bdi: allow block devices to say that they require stable page writesDarrick J. Wong
This patchset ("stable page writes, part 2") makes some key modifications to the original 'stable page writes' patchset. First, it provides creators (devices and filesystems) of a backing_dev_info a flag that declares whether or not it is necessary to ensure that page contents cannot change during writeout. It is no longer assumed that this is true of all devices (which was never true anyway). Second, the flag is used to relaxed the wait_on_page_writeback calls so that wait only occurs if the device needs it. Third, it fixes up the remaining disk-backed filesystems to use this improved conditional-wait logic to provide stable page writes on those filesystems. It is hoped that (for people not using checksumming devices, anyway) this patchset will give back unnecessary performance decreases since the original stable page write patchset went into 3.0. Sorry about not fixing it sooner. Complaints were registered by several people about the long write latencies introduced by the original stable page write patchset. Generally speaking, the kernel ought to allocate as little extra memory as possible to facilitate writeout, but for people who simply cannot wait, a second page stability strategy is (re)introduced: snapshotting page contents. The waiting behavior is still the default strategy; to enable page snapshotting, a superblock flag (MS_SNAP_STABLE) must be set. This flag is used to bandaid^Henable stable page writeback on ext3[1], and is not used anywhere else. Given that there are already a few storage devices and network FSes that have rolled their own page stability wait/page snapshot code, it would be nice to move towards consolidating all of these. It seems possible that iscsi and raid5 may wish to use the new stable page write support to enable zero-copy writeout. Thank you to Jan Kara for helping fix a couple more filesystems. Per Andrew Morton's request, here are the result of using dbench to measure latencies on ext2: 3.8.0-rc3: Operation Count AvgLat MaxLat ---------------------------------------- WriteX 109347 0.028 59.817 ReadX 347180 0.004 3.391 Flush 15514 29.828 287.283 Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms 3.8.0-rc3 + patches: WriteX 105556 0.029 4.273 ReadX 335004 0.005 4.112 Flush 14982 30.540 298.634 Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms As you can see, for ext2 the maximum write latency decreases from ~60ms on a laptop hard disk to ~4ms. I'm not sure why the flush latencies increase, though I suspect that being able to dirty pages faster gives the flusher more work to do. On ext4, the average write latency decreases as well as all the maximum latencies: 3.8.0-rc3: WriteX 85624 0.152 33.078 ReadX 272090 0.010 61.210 Flush 12129 36.219 168.260 Throughput 44.8618 MB/sec 4 clients 4 procs max_latency=168.276 ms 3.8.0-rc3 + patches: WriteX 86082 0.141 30.928 ReadX 273358 0.010 36.124 Flush 12214 34.800 165.689 Throughput 44.9941 MB/sec 4 clients 4 procs max_latency=165.722 ms XFS seems to exhibit similar latency improvements as ext2: 3.8.0-rc3: WriteX 125739 0.028 104.343 ReadX 399070 0.005 4.115 Flush 17851 25.004 131.390 Throughput 66.0024 MB/sec 4 clients 4 procs max_latency=131.406 ms 3.8.0-rc3 + patches: WriteX 123529 0.028 6.299 ReadX 392434 0.005 4.287 Flush 17549 25.120 188.687 Throughput 64.9113 MB/sec 4 clients 4 procs max_latency=188.704 ms ...and btrfs, just to round things out, also shows some latency decreases: 3.8.0-rc3: WriteX 67122 0.083 82.355 ReadX 212719 0.005 2.828 Flush 9547 47.561 147.418 Throughput 35.3391 MB/sec 4 clients 4 procs max_latency=147.433 ms 3.8.0-rc3 + patches: WriteX 64898 0.101 71.631 ReadX 206673 0.005 7.123 Flush 9190 47.963 219.034 Throughput 34.0795 MB/sec 4 clients 4 procs max_latency=219.044 ms Before this patchset, all filesystems would block, regardless of whether or not it was necessary. ext3 would wait, but still generate occasional checksum errors. The network filesystems were left to do their own thing, so they'd wait too. After this patchset, all the disk filesystems except ext3 and btrfs will wait only if the hardware requires it. ext3 (if necessary) snapshots pages instead of blocking, and btrfs provides its own bdi so the mm will never wait. Network filesystems haven't been touched, so either they provide their own wait code, or they don't block at all. The blocking behavior is back to what it was before 3.0 if you don't have a disk requiring stable page writes. This patchset has been tested on 3.8.0-rc3 on x64 with ext3, ext4, and xfs. I've spot-checked 3.8.0-rc4 and seem to be getting the same results as -rc3. [1] The alternative fixes to ext3 include fixing the locking order and page bit handling like we did for ext4 (but then why not just use ext4?), or setting PG_writeback so early that ext3 becomes extremely slow. I tried that, but the number of write()s I could initiate dropped by nearly an order of magnitude. That was a bit much even for the author of the stable page series! :) This patch: Creates a per-backing-device flag that tracks whether or not pages must be held immutable during writeout. Eventually it will be used to waive wait_for_page_writeback() if nothing requires stable pages. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31block: add export.h to files using EXPORT_SYMBOL/THIS_MODULE macrosPaul Gortmaker
These files were getting <linux/module.h> via an implicit include path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give them the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-05dm: improve block integrity supportMike Snitzer
The current block integrity (DIF/DIX) support in DM is verifying that all devices' integrity profiles match during DM device resume (which is past the point of no return). To some degree that is unavoidable (stacked DM devices force this late checking). But for most DM devices (which aren't stacking on other DM devices) the ideal time to verify all integrity profiles match is during table load. Introduce the notion of an "initialized" integrity profile: a profile that was blk_integrity_register()'d with a non-NULL 'blk_integrity' template. Add blk_integrity_is_initialized() to allow checking if a profile was initialized. Update DM integrity support to: - check all devices with _initialized_ integrity profiles match during table load; uninitialized profiles (e.g. for underlying DM device(s) of a stacked DM device) are ignored. - disallow a table load that would result in an integrity profile that conflicts with a DM device's existing (in-use) integrity profile - avoid clearing an existing integrity profile - validate all integrity profiles match during resume; but if they don't all we can do is report the mismatch (during resume we're past the point of no return) Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-15block: Fix double free in blk_integrity_unregisterMartin K. Petersen
Commit 3839e4b introduced a kobject_put but failed to remove the kmem_cache_free beneath it, leading to a double free. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block/scsi: Provide a limit on the number of integrity segmentsMartin K. Petersen
Some controllers have a hardware limit on the number of protection information scatter-gather list segments they can handle. Introduce a max_integrity_segments limit in the block layer and provide a new scsi_host_template setting that allows HBA drivers to provide a value suitable for the hardware. Add support for honoring the integrity segment limit when merging both bios and requests. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28block: fix improper kobject release in blk_integrity_unregisterXiaotian Feng
blk_integrity_unregister should use kobject_put to release the kobject, otherwise after bi is freed, memory of bi->kobj->name is leaked. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-30block: Allow empty integrity profileMartin K. Petersen
Allow a block device to allocate and register an integrity profile without providing a template. This allows DM to preallocate a profile to avoid deadlocks during table reconfiguration. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Switch blk_integrity_compare from bdev to gendiskMartin K. Petersen
The DM and MD integrity support now depends on being able to use gendisks instead of block_devices when comparing integrity profiles. Change function parameters accordingly. Also update comparison logic so that two NULL profiles are a valid configuration. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Fix double put in blk_integrity_unregisterMartin K. Petersen
- kobject_del already puts the parent. - Set integrity profile to NULL to prevent stale data. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement and use {disk|part}_to_dev()Tejun Heo
Implement {disk|part}_to_dev() and use them to access generic device instead of directly dereferencing {disk|part}->dev. To make sure no user is left behind, rename generic devices fields to __dev. This is in preparation of unifying partition 0 handling with other partitions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: integrity flags can't use bit ops on unsigned shortJens Axboe
Just use normal open coded bit operations instead, they need not be atomic. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: integrity checkpatch cleanupsJens Axboe
> 80 char lines and that sort of thing. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
