path: root/block/blk-integrity.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28block: fix improper kobject release in blk_integrity_unregisterXiaotian Feng
blk_integrity_unregister should use kobject_put to release the kobject, otherwise after bi is freed, memory of bi->kobj->name is leaked. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-30block: Allow empty integrity profileMartin K. Petersen
Allow a block device to allocate and register an integrity profile without providing a template. This allows DM to preallocate a profile to avoid deadlocks during table reconfiguration. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Switch blk_integrity_compare from bdev to gendiskMartin K. Petersen
The DM and MD integrity support now depends on being able to use gendisks instead of block_devices when comparing integrity profiles. Change function parameters accordingly. Also update comparison logic so that two NULL profiles are a valid configuration. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Fix double put in blk_integrity_unregisterMartin K. Petersen
- kobject_del already puts the parent. - Set integrity profile to NULL to prevent stale data. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: implement and use {disk|part}_to_dev()Tejun Heo
Implement {disk|part}_to_dev() and use them to access generic device instead of directly dereferencing {disk|part}->dev. To make sure no user is left behind, rename generic devices fields to __dev. This is in preparation of unifying partition 0 handling with other partitions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09Add some block/ source files to the kernel-api docbook. Fix kernel-doc ↵Randy Dunlap
notation in them as needed. Fix changed function parameter names. Fix typos/spellos. In comments, change REQ_SPECIAL to REQ_TYPE_SPECIAL and REQ_BLOCK_PC to REQ_TYPE_BLOCK_PC. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: integrity flags can't use bit ops on unsigned shortJens Axboe
Just use normal open coded bit operations instead, they need not be atomic. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: integrity checkpatch cleanupsJens Axboe
> 80 char lines and that sort of thing. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: Block layer data integrity supportMartin K. Petersen
Some block devices support verifying the integrity of requests by way of checksums or other protection information that is submitted along with the I/O. This patch implements support for generating and verifying integrity metadata, as well as correctly merging, splitting and cloning bios and requests that have this extra information attached. See Documentation/block/data-integrity.txt for more information. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
