path: root/block/blk-ioc.c
2020-04-17block: Fix use-after-free issue accessing struct io_cqSahitya Tummala
[ Upstream commit 30a2da7b7e225ef6c87a660419ea04d3cef3f6a7 ] There is a potential race between ioc_release_fn() and ioc_clear_queue() as shown below, due to which below kernel crash is observed. It also can result into use-after-free issue. context#1: context#2: ioc_release_fn() __ioc_clear_queue() gets the same icq ->spin_lock(&ioc->lock); ->spin_lock(&ioc->lock); ->ioc_destroy_icq(icq); ->list_del_init(&icq->q_node); ->call_rcu(&icq->__rcu_head, icq_free_icq_rcu); ->spin_unlock(&ioc->lock); ->ioc_destroy_icq(icq); ->hlist_del_init(&icq->ioc_node); This results into below crash as this memory is now used by icq->__rcu_head in context#1. There is a chance that icq could be free'd as well. 22150.386550: <6> Unable to handle kernel write to read-only memory at virtual address ffffffaa8d31ca50 ... Call trace: 22150.607350: <2> ioc_destroy_icq+0x44/0x110 22150.611202: <2> ioc_clear_queue+0xac/0x148 22150.615056: <2> blk_cleanup_queue+0x11c/0x1a0 22150.619174: <2> __scsi_remove_device+0xdc/0x128 22150.623465: <2> scsi_forget_host+0x2c/0x78 22150.627315: <2> scsi_remove_host+0x7c/0x2a0 22150.631257: <2> usb_stor_disconnect+0x74/0xc8 22150.635371: <2> usb_unbind_interface+0xc8/0x278 22150.639665: <2> device_release_driver_internal+0x198/0x250 22150.644897: <2> device_release_driver+0x24/0x30 22150.649176: <2> bus_remove_device+0xec/0x140 22150.653204: <2> device_del+0x270/0x460 22150.656712: <2> usb_disable_device+0x120/0x390 22150.660918: <2> usb_disconnect+0xf4/0x2e0 22150.664684: <2> hub_event+0xd70/0x17e8 22150.668197: <2> process_one_work+0x210/0x480 22150.672222: <2> worker_thread+0x32c/0x4c8 Fix this by adding a new ICQ_DESTROYED flag in ioc_destroy_icq() to indicate this icq is once marked as destroyed. Also, ensure __ioc_clear_queue() is accessing icq within rcu_read_lock/unlock so that icq doesn't get free'd up while it is still using it. Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Co-developed-by: Pradeep P V K <ppvk@codeaurora.org> Signed-off-by: Pradeep P V K <ppvk@codeaurora.org> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-15block: remove the queue_lock indirectionChristoph Hellwig
With the legacy request path gone there is no good reason to keep queue_lock as a pointer, we can always use the embedded lock now. Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Fixed floppy and blk-cgroup missing conversions and half done edits. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-15block: remove a few unused exportsChristoph Hellwig
Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-09block: remove set but not used variable 'et'YueHaibing
Fixes gcc '-Wunused-but-set-variable' warning: block/blk-ioc.c: In function 'put_io_context_active': block/blk-ioc.c:174:24: warning: variable 'et' set but not used [-Wunused-but-set-variable] It not used any more after commit a1ce35fa4985 ("block: remove dead elevator code") Signed-off-by: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-07block: get rid of MQ scheduler ops unionJens Axboe
This is a remnant of when we had ops for both SQ and MQ schedulers. Now it's just MQ, so get rid of the union. Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-07block: remove dead elevator codeJens Axboe
This removes a bunch of core and elevator related code. On the core front, we remove anything related to queue running, draining, initialization, plugging, and congestions. We also kill anything related to request allocation, merging, retrieval, and completion. Remove any checking for single queue IO schedulers, as they no longer exist. This means we can also delete a bunch of code related to request issue, adding, completion, etc - and all the SQ related ops and helpers. Also kill the load_default_modules(), as all that did was provide for a way to load the default single queue elevator. Tested-by: Ming Lei <ming.lei@redhat.com> Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-07-09block, mm: remove unnecessary __GFP_HIGH flagShakeel Butt
The flag GFP_ATOMIC already contains __GFP_HIGH. There is no need to explicitly or __GFP_HIGH again. So, just remove unnecessary __GFP_HIGH. Signed-off-by: Shakeel Butt <shakeelb@google.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A collection of fixes for this merge window, either fixes for existing issues, or parts that were waiting for acks to come in. This pull request contains: - Allocation of nvme queues on the right node from Shaohua. This was ready long before the merge window, but waiting on an ack from Bjorn on the PCI bit. Now that we have that, the three patches can go in. - Two fixes for blk-mq-sched with nvmeof, which uses hctx specific request allocations. This caused an oops. One part from Sagi, one part from Omar. - A loop partition scan deadlock fix from Omar, fixing a regression in this merge window. - A three-patch series from Keith, closing up a hole on clearing out requests on shutdown/resume. - A stable fix for nbd from Josef, fixing a leak of sockets. - Two fixes for a regression in this window from Jan, fixing a problem with one of his earlier patches dealing with queue vs bdi life times. - A fix for a regression with virtio-blk, causing an IO stall if scheduling is used. From me. - A fix for an io context lock ordering problem. From me" * 'for-linus' of git://git.kernel.dk/linux-block: block: Move bdi_unregister() to del_gendisk() blk-mq: ensure that bd->last is always set correctly block: don't call ioc_exit_icq() with the queue lock held for blk-mq block: Initialize bd_bdi on inode initialization loop: fix LO_FLAGS_PARTSCAN hang nvme: Complete all stuck requests blk-mq: Provide freeze queue timeout blk-mq: Export blk_mq_freeze_queue_wait nbd: stop leaking sockets blk-mq: move update of tags->rqs to __blk_mq_alloc_request() blk-mq: kill blk_mq_set_alloc_data() blk-mq: make blk_mq_alloc_request_hctx() allocate a scheduler request blk-mq-sched: Allocate sched reserved tags as specified in the original queue tagset nvme: allocate nvme_queue in correct node PCI: add an API to get node from vector blk-mq: allocate blk_mq_tags and requests in correct node
2017-03-02block: don't call ioc_exit_icq() with the queue lock held for blk-mqJens Axboe
For legacy scheduling, we always call ioc_exit_icq() with both the ioc and queue lock held. This poses a problem for blk-mq with scheduling, since the queue lock isn't what we use in the scheduler. And since we don't need the queue lock held for ioc exit there, don't grab it and leave any extra locking up to the blk-mq scheduler. Reported-by: Paolo Valente <paolo.valente@linaro.org> Tested-by: Paolo Valente <paolo.valente@linaro.org> Reviewed-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-03-02sched/headers: Prepare to move the task_lock()/unlock() APIs to ↵Ingo Molnar
<linux/sched/task.h> But first update the code that uses these facilities with the new header. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-10blk-mq-sched: don't hold queue_lock when calling exit_icqOmar Sandoval
None of the other blk-mq elevator hooks are called with this lock held. Additionally, it can lead to circular locking dependencies between queue_lock and the private scheduler lock. Reported-by: Paolo Valente <paolo.valente@linaro.org> Signed-off-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-01-17blk-mq-sched: add framework for MQ capable IO schedulersJens Axboe
This adds a set of hooks that intercepts the blk-mq path of allocating/inserting/issuing/completing requests, allowing us to develop a scheduler within that framework. We reuse the existing elevator scheduler API on the registration side, but augment that with the scheduler flagging support for the blk-mq interfce, and with a separate set of ops hooks for MQ devices. We split driver and scheduler tags, so we can run the scheduling independently of device queue depth. Signed-off-by: Jens Axboe <axboe@fb.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Omar Sandoval <osandov@fb.com>
2017-01-17block: move existing elevator ops to unionJens Axboe
Prep patch for adding MQ ops as well, since doing anon unions with named initializers doesn't work on older compilers. Signed-off-by: Jens Axboe <axboe@fb.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Omar Sandoval <osandov@fb.com>
2015-11-06mm, page_alloc: distinguish between being unable to sleep, unwilling to ↵Mel Gorman
sleep and avoiding waking kswapd __GFP_WAIT has been used to identify atomic context in callers that hold spinlocks or are in interrupts. They are expected to be high priority and have access one of two watermarks lower than "min" which can be referred to as the "atomic reserve". __GFP_HIGH users get access to the first lower watermark and can be called the "high priority reserve". Over time, callers had a requirement to not block when fallback options were available. Some have abused __GFP_WAIT leading to a situation where an optimisitic allocation with a fallback option can access atomic reserves. This patch uses __GFP_ATOMIC to identify callers that are truely atomic, cannot sleep and have no alternative. High priority users continue to use __GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify callers that want to wake kswapd for background reclaim. __GFP_WAIT is redefined as a caller that is willing to enter direct reclaim and wake kswapd for background reclaim. This patch then converts a number of sites o __GFP_ATOMIC is used by callers that are high priority and have memory pools for those requests. GFP_ATOMIC uses this flag. o Callers that have a limited mempool to guarantee forward progress clear __GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall into this category where kswapd will still be woken but atomic reserves are not used as there is a one-entry mempool to guarantee progress. o Callers that are checking if they are non-blocking should use the helper gfpflags_allow_blocking() where possible. This is because checking for __GFP_WAIT as was done historically now can trigger false positives. Some exceptions like dm-crypt.c exist where the code intent is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to flag manipulations. o Callers that built their own GFP flags instead of starting with GFP_KERNEL and friends now also need to specify __GFP_KSWAPD_RECLAIM. The first key hazard to watch out for is callers that removed __GFP_WAIT and was depending on access to atomic reserves for inconspicuous reasons. In some cases it may be appropriate for them to use __GFP_HIGH. The second key hazard is callers that assembled their own combination of GFP flags instead of starting with something like GFP_KERNEL. They may now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless if it's missed in most cases as other activity will wake kswapd. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-18block: Substitute rcu_access_pointer() for rcu_dereference_raw()Paul E. McKenney
(Trivial patch.) If the code is looking at the RCU-protected pointer itself, but not dereferencing it, the rcu_dereference() functions can be downgraded to rcu_access_pointer(). This commit makes this downgrade in blkg_destroy() and ioc_destroy_icq(), both of which simply compare the RCU-protected pointer against another pointer with no dereferencing. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@fb.com>
2013-11-08block: cleanup removing dependency on bootmem headersGrygorii Strashko
Cc: Yinghai Lu <yinghai@kernel.org> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-09-11lib/radix-tree.c: make radix_tree_node_alloc() work correctly within interruptJan Kara
With users of radix_tree_preload() run from interrupt (block/blk-ioc.c is one such possible user), the following race can happen: radix_tree_preload() ... radix_tree_insert() radix_tree_node_alloc() if (rtp->nr) { ret = rtp->nodes[rtp->nr - 1]; <interrupt> ... radix_tree_preload() ... radix_tree_insert() radix_tree_node_alloc() if (rtp->nr) { ret = rtp->nodes[rtp->nr - 1]; And we give out one radix tree node twice. That clearly results in radix tree corruption with different results (usually OOPS) depending on which two users of radix tree race. We fix the problem by making radix_tree_node_alloc() always allocate fresh radix tree nodes when in interrupt. Using preloading when in interrupt doesn't make sense since all the allocations have to be atomic anyway and we cannot steal nodes from process-context users because some users rely on radix_tree_insert() succeeding after radix_tree_preload(). in_interrupt() check is somewhat ugly but we cannot simply key off passed gfp_mask as that is acquired from root_gfp_mask() and thus the same for all preload users. Another part of the fix is to avoid node preallocation in radix_tree_preload() when passed gfp_mask doesn't allow waiting. Again, preallocation in such case doesn't make sense and when preallocation would happen in interrupt we could possibly leak some allocated nodes. However, some users of radix_tree_preload() require following radix_tree_insert() to succeed. To avoid unexpected effects for these users, radix_tree_preload() only warns if passed gfp mask doesn't allow waiting and we provide a new function radix_tree_maybe_preload() for those users which get different gfp mask from different call sites and which are prepared to handle radix_tree_insert() failure. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-14block: queue work on power efficient wqViresh Kumar
Block layer uses workqueues for multiple purposes. There is no real dependency of scheduling these on the cpu which scheduled them. On a idle system, it is observed that and idle cpu wakes up many times just to service this work. It would be better if we can schedule it on a cpu which the scheduler believes to be the most appropriate one. This patch replaces normal workqueues with power efficient versions. Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-01block: uninitialized ioc->nr_tasks triggers WARN_ONOlof Johansson
Hi, I'm using the old-fashioned 'dump' backup tool, and I noticed that it spews the below warning as of 3.5-rc1 and later (3.4 is fine): [ 10.886893] ------------[ cut here ]------------ [ 10.886904] WARNING: at include/linux/iocontext.h:140 copy_process+0x1488/0x1560() [ 10.886905] Hardware name: Bochs [ 10.886906] Modules linked in: [ 10.886908] Pid: 2430, comm: dump Not tainted 3.5.0-rc7+ #27 [ 10.886908] Call Trace: [ 10.886911] [<ffffffff8107ce8a>] warn_slowpath_common+0x7a/0xb0 [ 10.886912] [<ffffffff8107ced5>] warn_slowpath_null+0x15/0x20 [ 10.886913] [<ffffffff8107c088>] copy_process+0x1488/0x1560 [ 10.886914] [<ffffffff8107c244>] do_fork+0xb4/0x340 [ 10.886918] [<ffffffff8108effa>] ? recalc_sigpending+0x1a/0x50 [ 10.886919] [<ffffffff8108f6b2>] ? __set_task_blocked+0x32/0x80 [ 10.886920] [<ffffffff81091afa>] ? __set_current_blocked+0x3a/0x60 [ 10.886923] [<ffffffff81051db3>] sys_clone+0x23/0x30 [ 10.886925] [<ffffffff8179bd73>] stub_clone+0x13/0x20 [ 10.886927] [<ffffffff8179baa2>] ? system_call_fastpath+0x16/0x1b [ 10.886928] ---[ end trace 32a14af7ee6a590b ]--- Reproducing is easy, I can hit it on a KVM system with a very basic config (x86_64 make defconfig + enable the drivers needed). To hit it, just install dump (on debian/ubuntu, not sure what the package might be called on Fedora), and: dump -o -f /tmp/foo / You'll see the warning in dmesg once it forks off the I/O process and starts dumping filesystem contents. I bisected it down to the following commit: commit f6e8d01bee036460e03bd4f6a79d014f98ba712e Author: Tejun Heo <tj@kernel.org> Date: Mon Mar 5 13:15:26 2012 -0800 block: add io_context->active_ref Currently ioc->nr_tasks is used to decide two things - whether an ioc is done issuing IOs and whether it's shared by multiple tasks. This patch separate out the first into ioc->active_ref, which is acquired and released using {get|put}_io_context_active() respectively. This will be used to associate bio's with a given task. This patch doesn't introduce any visible behavior change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> It seems like the init of ioc->nr_tasks was removed in that patch, so it starts out at 0 instead of 1. Tejun, is the right thing here to add back the init, or should something else be done? The below patch removes the warning, but I haven't done any more extensive testing on it. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-05-31block: avoid infinite loop in get_task_io_context()Eric Dumazet
Calling get_task_io_context() on a exiting task which isn't %current can loop forever. This triggers at boot time on my dev machine. BUG: soft lockup - CPU#3 stuck for 22s ! [mountall.1603] Fix this by making create_task_io_context() returns -EBUSY in this case to break the loop. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-01Merge branch 'for-3.5' of ../cgroup into block/for-3.5/core-mergedTejun Heo
cgroup/for-3.5 contains the following changes which blk-cgroup needs to proceed with the on-going cleanup. * Dynamic addition and removal of cftypes to make config/stat file handling modular for policies. * cgroup removal update to not wait for css references to drain to fix blkcg removal hang caused by cfq caching cfqgs. Pull in cgroup/for-3.5 into block/for-3.5/core. This causes the following conflicts in block/blk-cgroup.c. * 761b3ef50e "cgroup: remove cgroup_subsys argument from callbacks" conflicts with blkiocg_pre_destroy() addition and blkiocg_attach() removal. Resolved by removing @subsys from all subsys methods. * 676f7c8f84 "cgroup: relocate cftype and cgroup_subsys definitions in controllers" conflicts with ->pre_destroy() and ->attach() updates and removal of modular config. Resolved by dropping forward declarations of the methods and applying updates to the relocated blkio_subsys. * 4baf6e3325 "cgroup: convert all non-memcg controllers to the new cftype interface" builds upon the previous item. Resolved by adding ->base_cftypes to the relocated blkio_subsys. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-20block: remove ioc_*_changed()Tejun Heo
After the previous patch to cfq, there's no ioc_get_changed() user left. This patch yanks out ioc_{ioprio|cgroup|get}_changed() and all related stuff. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-14block: fix ioc leak in put_io_contextXiaotian Feng
When put_io_context is called, if ioc->icq_list is empty and refcount is 1, kernel will not free the ioc. This is caught by following kmemleak: unreferenced object 0xffff880036349fe0 (size 216): comm "sh", pid 2137, jiffies 4294931140 (age 290579.412s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 01 00 01 00 ad 4e ad de ff ff ff ff 00 00 00 00 .....N.......... backtrace: [<ffffffff8169f926>] kmemleak_alloc+0x26/0x50 [<ffffffff81195a9c>] kmem_cache_alloc_node+0x1cc/0x2a0 [<ffffffff81356b67>] create_io_context_slowpath+0x27/0x130 [<ffffffff81356d2b>] get_task_io_context+0xbb/0xf0 [<ffffffff81055f0e>] copy_process+0x188e/0x18b0 [<ffffffff8105609b>] do_fork+0x11b/0x420 [<ffffffff810247f8>] sys_clone+0x28/0x30 [<ffffffff816d3373>] stub_clone+0x13/0x20 [<ffffffffffffffff>] 0xffffffffffffffff ioc should be freed if ioc->icq_list is empty. Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-03-06block: add io_context->active_refTejun Heo
2012-03-06block: interface update for ioc/icq creation functionsTejun Heo
Make the following interface updates to prepare for future ioc related changes. * create_io_context() returning ioc only works for %current because it doesn't increment ref on the ioc. Drop @task parameter from it and always assume %current. * Make create_io_context_slowpath() return 0 or -errno and rename it to create_task_io_context(). * Make ioc_create_icq() take @ioc as parameter instead of assuming that of %current. The caller, get_request(), is updated to create ioc explicitly and then pass it into ioc_create_icq(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-15block: exit_io_context() should call elevator_exit_icq_fn()Tejun Heo
While updating locking, b2efa05265 "block, cfq: unlink cfq_io_context's immediately" moved elevator_exit_icq_fn() invocation from exit_io_context() to the final ioc put. While this doesn't cause catastrophic failure, it effectively removes task exit notification to elevator and cause noticeable IO performance degradation with CFQ. On task exit, CFQ used to immediately expire the slice if it was being used by the exiting task as no more IO would be issued by the task; however, after b2efa05265, the notification is lost and disk could sit idle needlessly, leading to noticeable IO performance degradation for certain workloads. This patch renames ioc_exit_icq() to ioc_destroy_icq(), separates elevator_exit_icq_fn() invocation into ioc_exit_icq() and invokes it from exit_io_context(). ICQ_EXITED flag is added to avoid invoking the callback more than once for the same icq. Walking icq_list from ioc side and invoking elevator callback requires reverse double locking. This may be better implemented using RCU; unfortunately, using RCU isn't trivial. e.g. RCU protection would need to cover request_queue and queue_lock switch on cleanup makes grabbing queue_lock from RCU unsafe. Reverse double locking should do, at least for now. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-bisected-by: Shaohua Li <shli@kernel.org> LKML-Reference: <CANejiEVzs=pUhQSTvUppkDcc2TNZyfohBRLygW5zFmXyk5A-xQ@mail.gmail.com> Tested-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-15block: simplify ioc_release_fn()Tejun Heo
Reverse double lock dancing in ioc_release_fn() can be simplified by just using trylock on the queue_lock and back out from ioc lock on trylock failure. Simplify it. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-15block: replace icq->changed with icq->flagsTejun Heo
icq->changed was used for ICQ_*_CHANGED bits. Rename it to flags and access it under ioc->lock instead of using atomic bitops. ioc_get_changed() is added so that the changed part can be fetched and cleared as before. icq->flags will be used to carry other flags. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-11block: fix lockdep warning on io_context release put_io_context()Tejun Heo
11a3122f6c "block: strip out locking optimization in put_io_context()" removed ioc_lock depth lockdep annoation along with locking optimization; however, while recursing from put_io_context() is no longer possible, ioc_release_fn() may still end up putting the last reference of another ioc through elevator, which wlil grab ioc->lock triggering spurious (as the ioc is always different one) A-A deadlock warning. As this can only happen one time from ioc_release_fn(), using non-zero subclass from ioc_release_fn() is enough. Use subclass 1. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-07block: strip out locking optimization in put_io_context()Tejun Heo
put_io_context() performed a complex trylock dancing to avoid deferring ioc release to workqueue. It was also broken on UP because trylock was always assumed to succeed which resulted in unbalanced preemption count. While there are ways to fix the UP breakage, even the most pathological microbench (forced ioc allocation and tight fork/exit loop) fails to show any appreciable performance benefit of the optimization. Strip it out. If there turns out to be workloads which are affected by this change, simpler optimization from the discussion thread can be applied later. Signed-off-by: Tejun Heo <tj@kernel.org> LKML-Reference: <1328514611.21268.66.camel@sli10-conroe> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-06block: fix ioc locking warningShaohua Li
Meelis reported a warning: WARNING: at kernel/timer.c:1122 run_timer_softirq+0x199/0x1ec() Hardware name: 939Dual-SATA2 timer: cfq_idle_slice_timer+0x0/0xaa preempt leak: 00000102 -> 00000103 Modules linked in: sr_mod cdrom videodev media drm_kms_helper ohci_hcd ehci_hcd v4l2_compat_ioctl32 usbcore i2c_ali15x3 snd_seq drm snd_timer snd_seq Pid: 0, comm: swapper Not tainted 3.3.0-rc2-00110-gd125666 #176 Call Trace: <IRQ> [<ffffffff81022aaa>] warn_slowpath_common+0x7e/0x96 [<ffffffff8114c485>] ? cfq_slice_expired+0x1d/0x1d [<ffffffff81022b56>] warn_slowpath_fmt+0x41/0x43 [<ffffffff8114c526>] ? cfq_idle_slice_timer+0xa1/0xaa [<ffffffff8114c485>] ? cfq_slice_expired+0x1d/0x1d [<ffffffff8102c124>] run_timer_softirq+0x199/0x1ec [<ffffffff81047a53>] ? timekeeping_get_ns+0x12/0x31 [<ffffffff810145fd>] ? apic_write+0x11/0x13 [<ffffffff81027475>] __do_softirq+0x74/0xfa [<ffffffff812f337a>] call_softirq+0x1a/0x30 [<ffffffff81002ff9>] do_softirq+0x31/0x68 [<ffffffff810276cf>] irq_exit+0x3d/0xa3 [<ffffffff81014aca>] smp_apic_timer_interrupt+0x6b/0x77 [<ffffffff812f2de9>] apic_timer_interrupt+0x69/0x70 <EOI> [<ffffffff81040136>] ? sched_clock_cpu+0x73/0x7d [<ffffffff81040136>] ? sched_clock_cpu+0x73/0x7d [<ffffffff8100801f>] ? default_idle+0x1e/0x32 [<ffffffff81008019>] ? default_idle+0x18/0x32 [<ffffffff810008b1>] cpu_idle+0x87/0xd1 [<ffffffff812de861>] rest_init+0x85/0x89 [<ffffffff81659a4d>] start_kernel+0x2eb/0x2f8 [<ffffffff8165926e>] x86_64_start_reservations+0x7e/0x82 [<ffffffff81659362>] x86_64_start_kernel+0xf0/0xf7 this_q == locked_q is possible. There are two problems here: 1. In UP case, there is preemption counter issue as spin_trylock always successes. 2. In SMP case, the loop breaks too earlier. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Reported-by: Meelis Roos <mroos@linux.ee> Reported-by: Knut Petersen <Knut_Petersen@t-online.de> Tested-by: Knut Petersen <Knut_Petersen@t-online.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-27block: remove WARN_ON_ONCE() in exit_io_context()Tejun Heo
6e736be7 "block: make ioc get/put interface more conventional and fix race on alloction" added WARN_ON_ONCE() in exit_io_context() which triggers if !PF_EXITING. All tasks hitting exit_io_context() from task exit should have PF_EXITING set but task struct tearing down after fork failure calls into the function without PF_EXITING, triggering the condition. WARNING: at block/blk-ioc.c:234 exit_io_context+0x40/0x92() Pid: 17090, comm: trinity Not tainted 3.2.0-rc6-next-20111222-sasha-dirty #77 Call Trace: [<ffffffff810b69a3>] warn_slowpath_common+0x8f/0xb2 [<ffffffff810b6a77>] warn_slowpath_null+0x18/0x1a [<ffffffff8181a7a2>] exit_io_context+0x40/0x92 [<ffffffff810b58c9>] copy_process+0x126f/0x1453 [<ffffffff810b5c1b>] do_fork+0x120/0x3e9 [<ffffffff8106242f>] sys_clone+0x26/0x28 [<ffffffff82425803>] stub_clone+0x13/0x20 ---[ end trace a2e4eb670b375238 ]--- Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-25block: an exiting task should be allowed to create io_contextTejun Heo
While fixing io_context creation / task exit race condition, 6e736be7f2 "block: make ioc get/put interface more conventional and fix race on alloction" also prevented an exiting (%PF_EXITING) task from creating its own io_context. This is incorrect as exit path may issue IOs, e.g. from exit_files(), and if those IOs are the first ones issued by the task, io_context needs to be created to process the IOs. Combined with the existing problem of io_context / io_cq creation failure having the possibility of stalling IO, this problem results in deterministic full IO lockup with certain workloads. Fix it by allowing io_context creation regardless of %PF_EXITING for %current. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Andrew Morton <akpm@linux-foundation.org> Reported-by: Hugh Dickins <hughd@google.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-19block: ioc_cgroup_changed() needs to be exportedJens Axboe
With the ioc changed, ioc_cgroup_changed() can be used by modular code. So ensure that it is exported. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move icq creation and rq->elv.icq association to block coreTejun Heo
Now block layer knows everything necessary to create and associate icq's with requests. Move ioc_create_icq() to blk-ioc.c and update get_request() such that, if elevator_type->icq_size is set, requests are automatically associated with their matching icq's before elv_set_request(). io_context reference is also managed by block core on request alloc/free. * Only ioprio/cgroup changed handling remains from cfq_get_cic(). Collapsed into cfq_set_request(). * This removes queue kicking on icq allocation failure (for now). As icq allocation failure is rare and the only effect of queue kicking achieved was possibily accelerating queue processing, this change shouldn't be noticeable. There is a larger underlying problem. Unlike request allocation, icq allocation is not guaranteed to succeed eventually after retries. The number of icq is unbound and thus mempool can't be the solution either. This effectively adds allocation dependency on memory free path and thus possibility of deadlock. This usually wouldn't happen because icq allocation is not a hot path and, even when the condition triggers, it's highly unlikely that none of the writeback workers already has icq. However, this is still possible especially if elevator is being switched under high memory pressure, so we better get it fixed. Probably the only solution is just bypassing elevator and appending to dispatch queue on any elevator allocation failure. * Comment added to explain how icq's are managed and synchronized. This completes cleanup of io_context interface. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move io_cq exit/release to blk-ioc.cTejun Heo
With kmem_cache managed by blk-ioc, io_cq exit/release can be moved to blk-ioc too. The odd ->io_cq->exit/release() callbacks are replaced with elevator_ops->elevator_exit_icq_fn() with unlinking from both ioc and q, and freeing automatically handled by blk-ioc. The elevator operation only need to perform exit operation specific to the elevator - in cfq's case, exiting the cfqq's. Also, clearing of io_cq's on q detach is moved to block core and automatically performed on elevator switch and q release. Because the q io_cq points to might be freed before RCU callback for the io_cq runs, blk-ioc code should remember to which cache the io_cq needs to be freed when the io_cq is released. New field io_cq->__rcu_icq_cache is added for this purpose. As both the new field and rcu_head are used only after io_cq is released and the q/ioc_node fields aren't, they are put into unions. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move io_cq lookup to blk-ioc.cTejun Heo
Now that all io_cq related data structures are in block core layer, io_cq lookup can be moved from cfq-iosched.c to blk-ioc.c. Lookup logic from cfq_cic_lookup() is moved to ioc_lookup_icq() with parameter return type changes (cfqd -> request_queue, cfq_io_cq -> io_cq) and cfq_cic_lookup() becomes thin wrapper around cfq_cic_lookup(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: reorganize cfq_io_context into generic and cfq specific partsTejun Heo
Currently io_context and cfq logics are mixed without clear boundary. Most of io_context is independent from cfq but cfq_io_context handling logic is dispersed between generic ioc code and cfq. cfq_io_context represents association between an io_context and a request_queue, which is a concept useful outside of cfq, but it also contains fields which are useful only to cfq. This patch takes out generic part and put it into io_cq (io context-queue) and the rest into cfq_io_cq (cic moniker remains the same) which contains io_cq. The following changes are made together. * cfq_ttime and cfq_io_cq now live in cfq-iosched.c. * All related fields, functions and constants are renamed accordingly. * ioc->ioc_data is now "struct io_cq *" instead of "void *" and renamed to icq_hint. This prepares for io_context API cleanup. Documentation is currently sparse. It will be added later. Changes in this patch are mechanical and don't cause functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: replace current_io_context() with create_io_context()Tejun Heo
When called under queue_lock, current_io_context() triggers lockdep warning if it hits allocation path. This is because io_context installation is protected by task_lock which is not IRQ safe, so it triggers irq-unsafe-lock -> irq -> irq-safe-lock -> irq-unsafe-lock deadlock warning. Given the restriction, accessor + creator rolled into one doesn't work too well. Drop current_io_context() and let the users access task->io_context directly inside queue_lock combined with explicit creation using create_io_context(). Future ioc updates will further consolidate ioc access and the create interface will be unexported. While at it, relocate ioc internal interface declarations in blk.h and add section comments before and after. This patch does not introduce functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: unlink cfq_io_context's immediatelyTejun Heo
cic is association between io_context and request_queue. A cic is linked from both ioc and q and should be destroyed when either one goes away. As ioc and q both have their own locks, locking becomes a bit complex - both orders work for removal from one but not from the other. Currently, cfq tries to circumvent this locking order issue with RCU. ioc->lock nests inside queue_lock but the radix tree and cic's are also protected by RCU allowing either side to walk their lists without grabbing lock. This rather unconventional use of RCU quickly devolves into extremely fragile convolution. e.g. The following is from cfqd going away too soon after ioc and q exits raced. general protection fault: 0000 [#1] PREEMPT SMP CPU 2 Modules linked in: [ 88.503444] Pid: 599, comm: hexdump Not tainted 3.1.0-rc10-work+ #158 Bochs Bochs RIP: 0010:[<ffffffff81397628>] [<ffffffff81397628>] cfq_exit_single_io_context+0x58/0xf0 ... Call Trace: [<ffffffff81395a4a>] call_for_each_cic+0x5a/0x90 [<ffffffff81395ab5>] cfq_exit_io_context+0x15/0x20 [<ffffffff81389130>] exit_io_context+0x100/0x140 [<ffffffff81098a29>] do_exit+0x579/0x850 [<ffffffff81098d5b>] do_group_exit+0x5b/0xd0 [<ffffffff81098de7>] sys_exit_group+0x17/0x20 [<ffffffff81b02f2b>] system_call_fastpath+0x16/0x1b The only real hot path here is cic lookup during request initialization and avoiding extra locking requires very confined use of RCU. This patch makes cic removal from both ioc and request_queue perform double-locking and unlink immediately. * From q side, the change is almost trivial as ioc->lock nests inside queue_lock. It just needs to grab each ioc->lock as it walks cic_list and unlink it. * From ioc side, it's a bit more difficult because of inversed lock order. ioc needs its lock to walk its cic_list but can't grab the matching queue_lock and needs to perform unlock-relock dancing. Unlinking is now wholly done from put_io_context() and fast path is optimized by using the queue_lock the caller already holds, which is by far the most common case. If the ioc accessed multiple devices, it tries with trylock. In unlikely cases of fast path failure, it falls back to full double-locking dance from workqueue. Double-locking isn't the prettiest thing in the world but it's *far* simpler and more understandable than RCU trick without adding any meaningful overhead. This still leaves a lot of now unnecessary RCU logics. Future patches will trim them. -v2: Vivek pointed out that cic->q was being dereferenced after cic->release() was called. Updated to use local variable @this_q instead. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block, cfq: move ioc ioprio/cgroup changed handling to cicTejun Heo
ioprio/cgroup change was handled by marking the changed state in ioc and, on the following access to the ioc, performing RCU-protected iteration through all cic's grabbing the matching queue_lock. This patch moves the changed state to each cic. When ioprio or cgroup changes, the respective bit is set on all cic's of the ioc and when each of those cic (not ioc) is accessed, change is applied for that specific ioc-queue pair. This also fixes the following two race conditions between setting and clearing of changed states. * Missing barrier between assign/load of ioprio and ioprio_changed allowed applying old ioprio. * Change requests could happen between application of change and clearing of changed variables. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: make ioc get/put interface more conventional and fix race on alloctionTejun Heo
Ignoring copy_io() during fork, io_context can be allocated from two places - current_io_context() and set_task_ioprio(). The former is always called from local task while the latter can be called from different task. The synchornization between them are peculiar and dubious. * current_io_context() doesn't grab task_lock() and assumes that if it saw %NULL ->io_context, it would stay that way until allocation and assignment is complete. It has smp_wmb() between alloc/init and assignment. * set_task_ioprio() grabs task_lock() for assignment and does smp_read_barrier_depends() between "ioc = task->io_context" and "if (ioc)". Unfortunately, this doesn't achieve anything - the latter is not a dependent load of the former. ie, if ioc itself were being dereferenced "ioc->xxx", it would mean something (not sure what tho) but as the code currently stands, the dependent read barrier is noop. As only one of the the two test-assignment sequences is task_lock() protected, the task_lock() can't do much about race between the two. Nothing prevents current_io_context() and set_task_ioprio() allocating its own ioc for the same task and overwriting the other's. Also, set_task_ioprio() can race with exiting task and create a new ioc after exit_io_context() is finished. ioc get/put doesn't have any reason to be complex. The only hot path is accessing the existing ioc of %current, which is simple to achieve given that ->io_context is never destroyed as long as the task is alive. All other paths can happily go through task_lock() like all other task sub structures without impacting anything. This patch updates ioc get/put so that it becomes more conventional. * alloc_io_context() is replaced with get_task_io_context(). This is the only interface which can acquire access to ioc of another task. On return, the caller has an explicit reference to the object which should be put using put_io_context() afterwards. * The functionality of current_io_context() remains the same but when creating a new ioc, it shares the code path with get_task_io_context() and always goes through task_lock(). * get_io_context() now means incrementing ref on an ioc which the caller already has access to (be that an explicit refcnt or implicit %current one). * PF_EXITING inhibits creation of new io_context and once exit_io_context() is finished, it's guaranteed that both ioc acquisition functions return %NULL. * All users are updated. Most are trivial but smp_read_barrier_depends() removal from cfq_get_io_context() needs a bit of explanation. I suppose the original intention was to ensure ioc->ioprio is visible when set_task_ioprio() allocates new io_context and installs it; however, this wouldn't have worked because set_task_ioprio() doesn't have wmb between init and install. There are other problems with this which will be fixed in another patch. * While at it, use NUMA_NO_NODE instead of -1 for wildcard node specification. -v2: Vivek spotted contamination from debug patch. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-14block: misc ioc cleanupsTejun Heo
* int return from put_io_context() wasn't used by anybody. Make it return void like other put functions and docbook-fy the function comment. * Reorder dummy declarations for !CONFIG_BLOCK case a bit. * Make alloc_ioc_context() use __GFP_ZERO allocation, take init out of if block and drop 0'ing. * Docbook-fy current_io_context() comment. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-07-01Merge branch 'for-linus' into for-3.1/coreJens Axboe
Conflicts: block/blk-throttle.c block/cfq-iosched.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-06block: rename the return of two functionsPaul Bolle
If we rename the return of alloc_io_context() and get_io_context() from "ret" to "ioc" the code get's (a bit) more readable and (a lot) more grepable. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-02block: Use hlist_entry() for io_context.cic_list.firstPaul Bolle
list_entry() and hlist_entry() are both simply aliases for container_of(), but since io_context.cic_list.first is an hlist_node one should at least use the correct alias. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-23blk-cgroup: Initialize ioc->cgroup_changed at ioc creation timeVivek Goyal
If we don't explicitly initialize it to zero, CFQ might think that cgroup of ioc has changed and it generates lots of unnecessary calls to call_for_each_cic(changed_cgroup). Fix it. cfq_get_io_context() cfq_ioc_set_cgroup() call_for_each_cic(ioc, changed_cgroup) Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-21block: Clean up exit_io_context() source code.Bart Van Assche
This patch fixes a spelling error in a source code comment and removes superfluous braces in the function exit_io_context(). Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
