path: root/block/blk-lib.c
2010-04-29block: fix bad use of min() on different typesJens Axboe
Just cast the page size to sector_t, that will always fit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: add blkdev_issue_zeroout helper functionDmitry Monakhov
- Add bio_batch helper primitive. This is rather generic primitive for submitting/waiting a complex request which consists of several bios. - blkdev_issue_zeroout() generate number of zero filed write bios. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-28blkdev: move blkdev_issue helper functions to separate fileDmitry Monakhov
Move blkdev_issue_discard from blk-barrier.c because it is not barrier related. Later the file will be populated by other helpers. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
