commit 4d70dca4eadf2f95abe389116ac02b8439c2d16c upstream.
After arbitrary bio size was introduced, the incoming bio may
be very big. We have to split the bio into small bios so that
each holds at most BIO_MAX_PAGES bvecs for safety reason, such
as bio_clone().
This patch fixes the following kernel crash:
> [ 172.660142] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
> [ 172.660229] IP: [<ffffffff811e53b4>] bio_trim+0xf/0x2a
> [ 172.660289] PGD 7faf3e067 PUD 7f9279067 PMD 0
> [ 172.660399] Oops: 0000 [#1] SMP
> [ 172.664780] Call Trace:
> [ 172.664813] [<ffffffffa007f3be>] ? raid1_make_request+0x2e8/0xad7 [raid1]
> [ 172.664846] [<ffffffff811f07da>] ? blk_queue_split+0x377/0x3d4
> [ 172.664880] [<ffffffffa005fb5f>] ? md_make_request+0xf6/0x1e9 [md_mod]
> [ 172.664912] [<ffffffff811eb860>] ? generic_make_request+0xb5/0x155
> [ 172.664947] [<ffffffffa0445c89>] ? prio_io+0x85/0x95 [bcache]
> [ 172.664981] [<ffffffffa0448252>] ? register_cache_set+0x355/0x8d0 [bcache]
> [ 172.665016] [<ffffffffa04497d3>] ? register_bcache+0x1006/0x1174 [bcache]
The issue can be reproduced by the following steps:
- create one raid1 over two virtio-blk
- build bcache device over the above raid1 and another cache device
and bucket size is set as 2Mbytes
- set cache mode as writeback
- run random write over ext4 on the bcache device
Fixes: 54efd50(block: make generic_make_request handle arbitrarily sized bios)
Reported-by: Sebastian Roesner <sroesner-kernelorg@roesner-online.de>
Reported-by: Eric Wheeler <bcache@lists.ewheeler.net>
Cc: Shaohua Li <shli@fb.com>
Acked-by: Kent Overstreet <kent.overstreet@gmail.com>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit d0e5fbb01a67e400e82fefe4896ea40c6447ab98 upstream.
After commit e36f62042880(block: split bios to maxpossible length),
bio can be splitted in the middle of a vector entry, then it
is easy to split out one bio which size isn't aligned with block
size, especially when the block size is bigger than 512.
This patch fixes the issue by making the max io size aligned
to logical block size.
Fixes: e36f62042880(block: split bios to maxpossible length)
Reported-by: Stefan Haberland <sth@linux.vnet.ibm.com>
Cc: Keith Busch <keith.busch@intel.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit e36f6204288088fda50d1c84830340ccb70f85ff upstream.
This splits bio in the middle of a vector to form the largest possible
bio at the h/w's desired alignment, and guarantees the bio being split
will have some data.
The criteria for splitting is changed from the max sectors to the h/w's
optimal sector alignment if it is provided. For h/w that advertise their
block storage's underlying chunk size, it's a big performance win to not
submit commands that cross them. If sector alignment is not provided,
this patch uses the max sectors as before.
This addresses the performance issue commit d380561113 attempted to
fix, but was reverted due to splitting logic error.
Signed-off-by: Keith Busch <keith.busch@intel.com>
Cc: Jens Axboe <axboe@fb.com>
Cc: Ming Lei <tom.leiming@gmail.com>
Cc: Kent Overstreet <kent.overstreet@gmail.com>
This reverts commit d3805611130af9b911e908af9f67a3f64f4f0914.
If we end up splitting on the first segment, we don't adjust
the sector count. That results in hitting a BUG() with attempting
to split 0 sectors.
As this is just a performance issue and not a regression since
4.3 release, let's just rever this change. That gives us more
time to test a real fix for 4.5, which would be marked for
stable anyway.
For h/w that advertise their block storage's underlying chunk size, it's
a big performance win to not submit commands that cross them. This patch
uses that criteria if it is provided. If it is not provided, this patch
When bio has only one physical segment, we should set bio's
bi_seg_front_size as the real(final) size of the single segment.
Fixes: 02e707424c2ea(blk-merge: fix blk_bio_segment_split)
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
We had seen lots of reports of this kind issue, so add one
warnning in blk-merge, then it can be triggered easily and
avoid to depend on warning/bug from drivers.
Commit bdced438acd83a(block: setup bi_phys_segments after
splitting) introduces function of computing bio->bi_phys_segments
during bio splitting.
Unfortunately both bio->bi_seg_front_size and bio->bi_seg_back_size
arn't computed, so too many physical segments may be obtained
for one request since both the two are used to check if one segment
across two bios can be possible.
This patch fixes the issue by computing the two variables in
blk_bio_segment_split().
Fixes: bdced438acd83a(block: setup bi_phys_segments after splitting)
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Reported-by: Mark Salter <msalter@redhat.com>
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Mark Salter <msalter@redhat.com>
Inside blk_bio_segment_split(), previous bvec pointer(bvprvp)
always points to the iterator local variable, which is obviously
wrong, so fix it by pointing to the local variable of 'bvprv'.
Fixes: 5014c311baa2b(block: fix bogus compiler warnings in blk-merge.c)
Cc: stable@kernel.org #4.3
The splitted bio has been already too fat to merge, so mark it
as NOMERGE.
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
The number of bio->bi_phys_segments is always obtained
during bio splitting, so it is natural to setup it
just after bio splitting, then we can avoid to compute
nr_segment again during merge.
biovecs has become immutable since v3.13, so it isn't necessary
to allocate biovecs for the new cloned bios, then we can save
one extra biovecs allocation/copy, and the allocation is often
not fixed-length and a bit more expensive.
For example, if the 'max_sectors_kb' of null blk's queue is set
as 16(32 sectors) via sysfs just for making more splits, this patch
can increase throught about ~70% in the sequential read test over
null_blk(direct io, bs: 1M).
Cc: Ming Lin <ming.l@ssi.samsung.com>
Cc: Dongsu Park <dpark@posteo.net>
This fixes a performance regression introduced by commit 54efd50bfd,
and allows us to take full advantage of the fact that we have immutable
bio_vecs. Hand applied, as it rejected violently with commit
5014c311baa2.
If a driver sets the block queue virtual boundary mask, it means that
it cannot handle gaps so we must not allow those in the integrity
payload as well.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Fixed up by me to have duplicate integrity merge functions, depending
on whether block integrity is enabled or not. Fixes a compilations
issue with CONFIG_BLK_DEV_INTEGRITY unset.
We are checking for gaps to previous bio_vec, which can
only detect back merges gaps. Moreover, at the point where
we check for a gap, we don't know if we will attempt a back
or a front merge. Thus, check for gap to prev in a back merge
attempt and check for a gap to next in a front merge attempt.
[sagig: Minor rename change]
The compiler can't figure out that bvprv is initialized whenever 'prev'
is set to 1 as well. Use a pointer to bvprv instead, setting it to NULL
initially, and get rid of the 'prev' tracking. This dumbs it down
enough that gcc is happy.
Pull SG updates from Jens Axboe:
"This contains a set of scatter-gather related changes/fixes for 4.3:
- Add support for limited chaining of sg tables even for
architectures that do not set ARCH_HAS_SG_CHAIN. From Christoph.
- Add sg chain support to target_rd. From Christoph.
- Fixup open coded sg->page_link in crypto/omap-sham. From
Christoph.
- Fixup open coded crypto ->page_link manipulation. From Dan.
- Also from Dan, automated fixup of manual sg_unmark_end()
manipulations.
- Also from Dan, automated fixup of open coded sg_phys()
implementations.
- From Robert Jarzmik, addition of an sg table splitting helper that
drivers can use"
* 'for-4.3/sg' of git://git.kernel.dk/linux-block:
lib: scatterlist: add sg splitting function
scatterlist: use sg_phys()
crypto/omap-sham: remove an open coded access to ->page_link
scatterlist: remove open coded sg_unmark_end instances
crypto: replace scatterwalk_sg_chain with sg_chain
target/rd: always chain S/G list
scatterlist: allow limited chaining without ARCH_HAS_SG_CHAIN
Corrects a coding error from earlier patch.
Reported by: Sagi Grimberg <sagig@dev.mellanox.co.il>
Fixes: 03100aada96f ("block: Replace SG_GAPS with new queue limits mask")
The SG_GAPS queue flag caused checks for bio vector alignment against
PAGE_SIZE, but the device may have different constraints. This patch
adds a queue limits so a driver with such constraints can set to allow
requests that would have been unnecessarily split. The new gaps check
takes the request_queue as a parameter to simplify the logic around
invoking this function.
This new limit makes the queue flag redundant, so removing it and
all usage. Device-mappers will inherit the correct settings through
blk_stack_limits().
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
[hch: split from a larger patch by Dan]
As generic_make_request() is now able to handle arbitrarily sized bios,
it's no longer necessary for each individual block driver to define its
own ->merge_bvec_fn() callback. Remove every invocation completely.
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: drbd-user@lists.linbit.com
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Alex Elder <elder@kernel.org>
Cc: ceph-devel@vger.kernel.org
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: dm-devel@redhat.com
Cc: Neil Brown <neilb@suse.de>
Cc: linux-raid@vger.kernel.org
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Acked-by: NeilBrown <neilb@suse.de> (for the 'md' bits)
Acked-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com>
[dpark: also remove ->merge_bvec_fn() in dm-thin as well as
dm-era-target, and resolve merge conflicts]
Signed-off-by: Dongsu Park <dpark@posteo.net>
Signed-off-by: Ming Lin <ming.l@ssi.samsung.com>
The way the block layer is currently written, it goes to great lengths
to avoid having to split bios; upper layer code (such as bio_add_page())
checks what the underlying device can handle and tries to always create
bios that don't need to be split.
But this approach becomes unwieldy and eventually breaks down with
stacked devices and devices with dynamic limits, and it adds a lot of
complexity. If the block layer could split bios as needed, we could
eliminate a lot of complexity elsewhere - particularly in stacked
drivers. Code that creates bios can then create whatever size bios are
convenient, and more importantly stacked drivers don't have to deal with
both their own bio size limitations and the limitations of the
(potentially multiple) devices underneath them. In the future this will
let us delete merge_bvec_fn and a bunch of other code.
We do this by adding calls to blk_queue_split() to the various
make_request functions that need it - a few can already handle arbitrary
size bios. Note that we add the call _after_ any call to
blk_queue_bounce(); this means that blk_queue_split() and
blk_recalc_rq_segments() don't need to be concerned with bouncing
affecting segment merging.
Some make_request_fn() callbacks were simple enough to audit and verify
they don't need blk_queue_split() calls. The skipped ones are:
* nfhd_make_request (arch/m68k/emu/nfblock.c)
* axon_ram_make_request (arch/powerpc/sysdev/axonram.c)
* simdisk_make_request (arch/xtensa/platforms/iss/simdisk.c)
* brd_make_request (ramdisk - drivers/block/brd.c)
* mtip_submit_request (drivers/block/mtip32xx/mtip32xx.c)
* loop_make_request
* null_queue_bio
* bcache's make_request fns
Some others are almost certainly safe to remove now, but will be left
for future patches.
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Jim Paris <jim@jtan.com>
Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Andreas Dilger <andreas.dilger@intel.com>
Acked-by: NeilBrown <neilb@suse.de> (for the 'md/md.c' bits)
[dpark: skip more mq-based drivers, resolve merge conflicts, etc.]
Some places use helpers now, others don't. We only have the 'is set'
helper, add helpers for setting and clearing flags too.
It was a bit of a mess of atomic vs non-atomic access. With
BIO_UPTODATE gone, we don't have any risk of concurrent access to the
flags. So relax the restriction and don't make any of them atomic. The
flags that do have serialization issues (reffed and chained), we
already handle those separately.
We can safely merge anything that wont generate an SG list entry,
so if the bio is data-less (discard), don't look at potential
SG gaps.
Use the right array index to reference the last
element of rq->biotail->bi_io_vec[]
Signed-off-by: Wenbo Wang <wenbo.wang@memblaze.com>
Reviewed-by: Chong Yuan <chong.yuan@memblaze.com>
Fixes: 66cb45aa41315 ("block: add support for limiting gaps in SG lists")
If the queue has SG_GAPS set, we must not merge across an sg gap.
This is caught for the bio case, but currently not for the
more rare case of merging two requests directly.
Cut the dm bits, those will go through the dm tree, and fixed
the test_bit() test.
For cloned bio, bio->bi_vcnt can't be used at all, and we
have resort to bio_segments() to figure out how many
segment there are in the bio.
The problem is introduced by commit 764f612c6c3c231b(blk-merge:
don't compute bi_phys_segments from bi_vcnt for cloned bio),
and merge is needed if number of current segment isn't less than
max segments.
Strictly speaking, bio->bi_vcnt shouldn't be used here since
it may not be accurate in cases of both cloned bio or bio cloned
from, but bio_segments() is a bit expensive, and bi_vcnt is still
the biggest number, so the approach should work.
It isn't correct to figure out req->bi_phys_segments from bio->bi_vcnt
if the bio is cloned.
Tested-by: Jeff Mahoney <jeffm@suse.com>
We'd occasionally merge requests with conflicting integrity flags.
Introduce a merge helper which checks that the requests have compatible
integrity payloads.
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
QUEUE_FLAG_NO_SG_MERGE is set at default for blk-mq devices,
so bio->bi_phys_segment computed may be bigger than
queue_max_segments(q) for blk-mq devices, then drivers will
fail to handle the case, for example, BUG_ON() in
virtio_queue_rq() can be triggerd for virtio-blk:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1359146
This patch fixes the issue by ignoring the QUEUE_FLAG_NO_SG_MERGE
flag if the computed bio->bi_phys_segment is bigger than
queue_max_segments(q), and the regression is caused by commit
05f1dd53152173(block: add queue flag for disabling SG merging).
Reported-by: Kick In <pierre-andre.morey@canonical.com>
Tested-by: Chris J Arges <chris.j.arges@canonical.com>
Another restriction inherited for NVMe - those devices don't support
SG lists that have "gaps" in them. Gaps refers to cases where the
previous SG entry doesn't end on a page boundary. For NVMe, all SG
entries must start at offset 0 (except the first) and end on a page
boundary (except the last).
If devices are not SG starved, we waste a lot of time potentially
collapsing SG segments. Enough that 1.5% of the CPU time goes
to this, at only 400K IOPS. Add a queue flag, QUEUE_FLAG_NO_SG_MERGE,
which just returns the number of vectors in a bio instead of looping
over all segments and checking for collapsible ones.
Add a BLK_MQ_F_SG_MERGE flag so that drivers can opt-in on the sg
merging, if they so desire.
Immutable biovecs changed the way biovecs are interpreted - drivers no
longer use bi_vcnt, they have to go by bi_iter.bi_size (to allow for
using part of an existing segment without modifying it).
This breaks with discards and write_same bios, since for those bi_size
has nothing to do with segments in the biovec. So for now, we need a
fairly gross hack - we fortunately know that there will never be more
than one segment for the entire request, so we can special case
discard/write_same.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Tested-by: Hugh Dickins <hughd@google.com>
The uninitialized_var() macro appears to not work on structs...
Get rid of it, and manually initialize instead.
bio_iovec_idx() and __bio_iovec() don't have any valid uses anymore -
previous users have been converted to bio_iovec_iter() or other methods.
__BVEC_END() has to go too - the bvec array can't be used directly for
the last biovec because we might only be using the first portion of it,
we have to iterate over the bvec array with bio_for_each_segment() which
checks against the current value of bi_iter.bi_size.
More prep work for immutable biovecs - with immutable bvecs drivers
won't be able to use the biovec directly, they'll need to use helpers
that take into account bio->bi_iter.bi_bvec_done.
This updates callers for the new usage without changing the
implementation yet.
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Paul Clements <Paul.Clements@steeleye.com>
Cc: Alex Elder <elder@inktank.com>
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: linux390@de.ibm.com
Cc: Nagalakshmi Nandigama <Nagalakshmi.Nandigama@lsi.com>
Cc: Sreekanth Reddy <Sreekanth.Reddy@lsi.com>
Cc: support@lsi.com
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Quoc-Son Anh <quoc-sonx.anh@intel.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jan Kara <jack@suse.cz>
Cc: linux-m68k@lists.linux-m68k.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: nbd-general@lists.sourceforge.net
Cc: cbe-oss-dev@lists.ozlabs.org
Cc: xen-devel@lists.xensource.com
Cc: virtualization@lists.linux-foundation.org
Cc: linux-s390@vger.kernel.org
Cc: DL-MPTFusionLinux@lsi.com
Cc: linux-scsi@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: linux-fsdevel@vger.kernel.org
Cc: cluster-devel@redhat.com
Cc: linux-mm@kvack.org
Acked-by: Geoff Levand <geoff@infradead.org>
Immutable biovecs are going to require an explicit iterator. To
implement immutable bvecs, a later patch is going to add a bi_bvec_done
member to this struct; for now, this patch effectively just renames
things.
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: xfs@oss.sgi.com
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: "Roger Pau Monné" <roger.pau@citrix.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Jerome Marchand <jmarchand@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Peng Tao <tao.peng@emc.com>
Cc: Andy Adamson <andros@netapp.com>
Cc: fanchaoting <fanchaoting@cn.fujitsu.com>
Cc: Jie Liu <jeff.liu@oracle.com>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Pankaj Kumar <pankaj.km@samsung.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Mel Gorman <mgorman@suse.de>6
For blk-mq, if a driver has requested per-request payload data
to carry command structures, they are stuffed into req->special.
For an old style request based driver, req->special is used
for the same purpose but indicates that a per-driver request
structure has been prepared for the request already. So for the
old style driver, we do not merge such requests.
As most/all blk-mq drivers will use the payload feature, and
since we have no problem merging on these, make this check
dependent on whether it's a blk-mq enabled driver or not.
Reported-by: Shaohua Li <shli@fusionio.com>
This is useful in places that recycle the same scatterlist multiple
times, and do not want to incur the cost of sg_init_table every
time in hot paths.
Acked-by: Jens Axboe <axboe@kernel.dk>
The WRITE SAME command supported on some SCSI devices allows the same
block to be efficiently replicated throughout a block range. Only a
single logical block is transferred from the host and the storage device
writes the same data to all blocks described by the I/O.
This patch implements support for WRITE SAME in the block layer. The
blkdev_issue_write_same() function can be used by filesystems and block
drivers to replicate a buffer across a block range. This can be used to
efficiently initialize software RAID devices, etc.
- blk_check_merge_flags() verifies that cmd_flags / bi_rw are
compatible. This function is called for both req-req and req-bio
merging.
- blk_rq_get_max_sectors() and blk_queue_get_max_sectors() can be used
to query the maximum sector count for a given request or queue. The
calls will return the right value from the queue limits given the
type of command (RW, discard, write same, etc.)
Remove special-casing of non-rw fs style requests (discard). The nomerge
flags are consolidated in blk_types.h, and rq_mergeable() and
bio_mergeable() have been modified to use them.
bio_is_rw() is used in place of bio_has_data() a few places. This is
done to to distinguish true reads and writes from other fs type requests
that carry a payload (e.g. write same).
Add a helper to map a bio to a scatterlist, modelled after
blk_rq_map_sg.
This helper is useful for any driver that wants to create
a scatterlist from its ->make_request_fn method.
Changes in v2:
- Use __blk_segment_map_sg to avoid duplicated code
- Add cocbook style function comment
Cc: Shaohua Li <shli@kernel.org>
Cc: kvm@vger.kernel.org
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Signed-off-by: Asias He <asias@redhat.com>
Split the mapping code in blk_rq_map_sg() to a helper
__blk_segment_map_sg(), so that other mapping function, e.g.
blk_bio_map_sg(), can share the code.
Suggested-by: Jens Axboe <axboe@kernel.dk>
Suggested-by: Tejun Heo <tj@kernel.org>
functions
blk_rq_merge_ok() is the elevator-neutral part of merge eligibility
test. blk_try_merge() determines merge direction and expects the
caller to have tested elv_rq_merge_ok() previously.
elv_rq_merge_ok() now wraps blk_rq_merge_ok() and then calls
elv_iosched_allow_merge(). elv_try_merge() is removed and the two
callers are updated to call elv_rq_merge_ok() explicitly followed by
blk_try_merge(). While at it, make rq_merge_ok() functions return
bool.
This is to prepare for plug merge update and doesn't introduce any
behavior change.
This is based on Jens' patch to skip elevator_allow_merge_fn() from
plug merge.
LKML-Reference: <4F16F3CA.90904@kernel.dk>
Original-patch-by: Jens Axboe <axboe@kernel.dk>
One of the disadvantages of on-stack plugging is that we potentially
lose out on merging since all pending IO isn't always visible to
everybody. When we flush the on-stack plugs, right now we don't do
any checks to see if potential merge candidates could be utilized.
Correct this by adding a new insert variant, ELEVATOR_INSERT_SORT_MERGE.
It works just ELEVATOR_INSERT_SORT, but first checks whether we can
merge with an existing request before doing the insertion (if we fail
merging).
This fixes a regression with multiple processes issuing IO that
can be merged.
Thanks to Shaohua Li <shaohua.li@intel.com> for testing and fixing
an accounting bug.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
We can't use krefs since it's apparently restricted to very basic
reference counting.
This reverts commit e4a683c8.
