path: root/block/blk-mq.c
2013-11-19blk-mq: add blktrace insert event traceJens Axboe
We need it to make 'btt' from blktrace happy, otherwise we are missing one state transition. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-19blk-mq: ensure that we set REQ_IO_STAT so diskstats workJens Axboe
If disk stats are enabled on the queue, a request needs to be marked with REQ_IO_STAT for accounting to be active on that request. This fixes an issue with virtio-blk not showing up in /proc/diskstats after the conversion to blk-mq. Add QUEUE_FLAG_MQ_DEFAULT, setting stats and same cpu-group completion on by default. Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-15Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull second round of block driver updates from Jens Axboe: "As mentioned in the original pull request, the bcache bits were pulled because of their dependency on the immutable bio vecs. Kent re-did this part and resubmitted it, so here's the 2nd round of (mostly) driver updates for 3.13. It contains: - The bcache work from Kent. - Conversion of virtio-blk to blk-mq. This removes the bio and request path, and substitutes with the blk-mq path instead. The end result almost 200 deleted lines. Patch is acked by Asias and Christoph, who both did a bunch of testing. - A removal of bootmem.h include from Grygorii Strashko, part of a larger series of his killing the dependency on that header file. - Removal of __cpuinit from blk-mq from Paul Gortmaker" * 'for-linus' of git://git.kernel.dk/linux-block: (56 commits) virtio_blk: blk-mq support blk-mq: remove newly added instances of __cpuinit bcache: defensively handle format strings bcache: Bypass torture test bcache: Delete some slower inline asm bcache: Use ida for bcache block dev minor bcache: Fix sysfs splat on shutdown with flash only devs bcache: Better full stripe scanning bcache: Have btree_split() insert into parent directly bcache: Move spinlock into struct time_stats bcache: Kill sequential_merge option bcache: Kill bch_next_recurse_key() bcache: Avoid deadlocking in garbage collection bcache: Incremental gc bcache: Add make_btree_freeing_key() bcache: Add btree_node_write_sync() bcache: PRECEDING_KEY() bcache: bch_(btree|extent)_ptr_invalid() bcache: Don't bother with bucket refcount for btree node allocations bcache: Debug code improvements ...
2013-11-15kernel: remove CONFIG_USE_GENERIC_SMP_HELPERSChristoph Hellwig
We've switched over every architecture that supports SMP to it, so remove the new useless config variable. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14blk-mq: remove newly added instances of __cpuinitPaul Gortmaker
The new blk-mq code added new instances of __cpuinit usage. We removed this a couple versions ago; we now want to remove the compat no-op stubs. Introducing new users is not what we want to see at this point in time, as it will break once the stubs are gone. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-10-29blk-mq: mq plug list breakageShaohua Li
We switched to plug mq_list for mq, but some code are still using old list. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-10-28blk-mq: fix for flush deadlockChristoph Hellwig
The flush state machine takes in a struct request, which then is submitted multiple times to the underling driver. The old block code requeses the same request for each of those, so it does not have an issue with tapping into the request pool. The new one on the other hand allocates a new request for each of the actualy steps of the flush sequence. If have already allocated all of the tags for IO, we will fail allocating the flush request. Set aside a reserved request just for flushes. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-10-25blk-mq: add blk_mq_stop_hw_queuesChristoph Hellwig
Add a helper to iterate over all hw queues and stop them. This is useful for driver that implement PM suspend functionality. Signed-off-by: Christoph Hellwig <hch@lst.de> Modified to just call blk_mq_stop_hw_queue() by Jens. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-10-25blk-mq: new multi-queue block IO queueing mechanismJens Axboe
Linux currently has two models for block devices: - The classic request_fn based approach, where drivers use struct request units for IO. The block layer provides various helper functionalities to let drivers share code, things like tag management, timeout handling, queueing, etc. - The "stacked" approach, where a driver squeezes in between the block layer and IO submitter. Since this bypasses the IO stack, driver generally have to manage everything themselves. With drivers being written for new high IOPS devices, the classic request_fn based driver doesn't work well enough. The design dates back to when both SMP and high IOPS was rare. It has problems with scaling to bigger machines, and runs into scaling issues even on smaller machines when you have IOPS in the hundreds of thousands per device. The stacked approach is then most often selected as the model for the driver. But this means that everybody has to re-invent everything, and along with that we get all the problems again that the shared approach solved. This commit introduces blk-mq, block multi queue support. The design is centered around per-cpu queues for queueing IO, which then funnel down into x number of hardware submission queues. We might have a 1:1 mapping between the two, or it might be an N:M mapping. That all depends on what the hardware supports. blk-mq provides various helper functions, which include: - Scalable support for request tagging. Most devices need to be able to uniquely identify a request both in the driver and to the hardware. The tagging uses per-cpu caches for freed tags, to enable cache hot reuse. - Timeout handling without tracking request on a per-device basis. Basically the driver should be able to get a notification, if a request happens to fail. - Optional support for non 1:1 mappings between issue and submission queues. blk-mq can redirect IO completions to the desired location. - Support for per-request payloads. Drivers almost always need to associate a request structure with some driver private command structure. Drivers can tell blk-mq this at init time, and then any request handed to the driver will have the required size of memory associated with it. - Support for merging of IO, and plugging. The stacked model gets neither of these. Even for high IOPS devices, merging sequential IO reduces per-command overhead and thus increases bandwidth. For now, this is provided as a potential 3rd queueing model, with the hope being that, as it matures, it can replace both the classic and stacked model. That would get us back to having just 1 real model for block devices, leaving the stacked approach to dm/md devices (as it was originally intended). Contributions in this patch from the following people: Shaohua Li <shli@fusionio.com> Alexander Gordeev <agordeev@redhat.com> Christoph Hellwig <hch@infradead.org> Mike Christie <michaelc@cs.wisc.edu> Matias Bjorling <m@bjorling.me> Jeff Moyer <jmoyer@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
